path: root/crypto/testmgr.h
2011-05-04crypto: testmgr - add support for aes ofb modePuneet Saxena
the fix add testcase for testing aes ofb mode. Signed-off-by: Puneet Saxena <puneets@nvidia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-02-17crypto: sha1 - Add test vector to test partial block processingHerbert Xu
In light of the recent discovery of the bug with partial block processing on s390, we need best test coverage for that. This patch adds a test vector for SHA1 that should catch such problems. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-11-13crypto: rfc4106 - Extending the RC4106 AES-GCM test vectorsAdrian Hoban
Updated RFC4106 AES-GCM testing. Some test vectors were taken from http://csrc.nist.gov/groups/ST/toolkit/BCM/documents/proposedmodes/ gcm/gcm-test-vectors.tar.gz Signed-off-by: Adrian Hoban <adrian.hoban@intel.com> Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com> Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-18crypto: vmac - Fix big-endian supportShane Wang
This patch is to fix the vmac algorithm, add more test cases for vmac, and fix the test failure on some big endian system like s390. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-11-23crypto: testmgr - Add ghash algorithm test before provide to usersYouquan, Song
Add ghash algorithm test before provide it to users Signed-off-by: Youquan, Song <youquan.song@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-02crypto: vmac - New hash algorithm for intel_txt supportShane Wang
This patch adds VMAC (a fast MAC) support into crypto framework. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add ctr(aes) test vectorsJarod Wilson
Now with multi-block test vectors, all from SP800-38A, Appendix F.5. Also added ctr(aes) to case 10 in tcrypt. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add ansi_cprng test vectorsJarod Wilson
Add ANSI X9.31 Continuous Pseudo-Random Number Generator (AES mode), aka 'ansi_cprng' test vectors, taken from Appendix B.2.9 and B.2.10 of the NIST RNGVS document, found here: http://csrc.nist.gov/groups/STM/cavp/documents/rng/RNGVS.pdf Successfully tested against both the cryptodev-2.6 tree and a Red Hat Enterprise Linux 5.4 kernel, via 'modprobe tcrypt mode=150'. The selection of 150 was semi-arbitrary, didn't seem like it should go any place in particular, so I started a new range for rng tests. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add infrastructure for ansi_cprng self-testsJarod Wilson
Add some necessary infrastructure to make it possible to run self-tests for ansi_cprng. The bits are likely very specific to the ANSI X9.31 CPRNG in AES mode, and thus perhaps should be named more specifically if/when we grow additional CPRNG support... Successfully tested against the cryptodev-2.6 tree and a Red Hat Enterprise Linux 5.x kernel with the follow-on patch that adds the actual test vectors. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add self-tests for rfc4309(ccm(aes))Jarod Wilson
Add an array of encryption and decryption + verification self-tests for rfc4309(ccm(aes)). Test vectors all come from sample FIPS CAVS files provided to Red Hat by a testing lab. Unfortunately, all the published sample vectors in RFC 3610 and NIST Special Publication 800-38C contain nonce lengths that the kernel's rfc4309 implementation doesn't support, so while using some public domain vectors would have been preferred, its not possible at this time. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Handle AEAD test vectors expected to fail verificationJarod Wilson
Add infrastructure to tcrypt/testmgr to support handling ccm decryption test vectors that are expected to fail verification. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: testmgr - add zlib testGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: testmgr - Add support for the pcomp interfaceGeert Uytterhoeven
2008-12-25crypto: testmgr - Correct comment about deflate parametersGeert Uytterhoeven
The comment for the deflate test vectors says the winbits parameter is 11, while the deflate module actually uses -11 (a negative window bits parameter enables the raw deflate format instead of the zlib format). Correct this, to avoid confusion about the format used. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Add test infrastructureHerbert Xu
This patch moves the newly created alg_test infrastructure into cryptomgr. This shall allow us to use it for testing at algorithm registrations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
