path: root/crypto/testmgr.h
2020-02-07Merge tag 'v4.14.164' into 4.14-2.3.x-imxMarcel Ziswiler
This is the 4.14.164 stable release Conflicts: arch/arm/Kconfig.debug arch/arm/boot/dts/imx7s.dtsi arch/arm/mach-imx/cpuidle-imx6q.c arch/arm/mach-imx/cpuidle-imx6sx.c arch/arm64/kernel/cpu_errata.c arch/arm64/kvm/hyp/tlb.c drivers/crypto/caam/caamalg.c drivers/crypto/mxs-dcp.c drivers/dma/imx-sdma.c drivers/gpio/gpio-vf610.c drivers/gpu/drm/bridge/adv7511/adv7511_drv.c drivers/input/keyboard/imx_keypad.c drivers/input/keyboard/snvs_pwrkey.c drivers/mmc/core/block.c drivers/mmc/core/queue.h drivers/mmc/host/sdhci-esdhc-imx.c drivers/net/can/flexcan.c drivers/net/can/rx-offload.c drivers/net/ethernet/freescale/fec_main.c drivers/net/wireless/ath/ath10k/pci.c drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c drivers/pci/dwc/pci-imx6.c drivers/spi/spi-fsl-lpspi.c drivers/usb/dwc3/gadget.c include/net/tcp.h sound/soc/fsl/Kconfig sound/soc/fsl/fsl_esai.c
2019-04-27crypto: x86/poly1305 - fix overflow during partial reductionEric Biggers
commit 678cce4019d746da6c680c48ba9e6d417803e127 upstream. The x86_64 implementation of Poly1305 produces the wrong result on some inputs because poly1305_4block_avx2() incorrectly assumes that when partially reducing the accumulator, the bits carried from limb 'd4' to limb 'h0' fit in a 32-bit integer. This is true for poly1305-generic which processes only one block at a time. However, it's not true for the AVX2 implementation, which processes 4 blocks at a time and therefore can produce intermediate limbs about 4x larger. Fix it by making the relevant calculations use 64-bit arithmetic rather than 32-bit. Note that most of the carries already used 64-bit arithmetic, but the d4 -> h0 carry was different for some reason. To be safe I also made the same change to the corresponding SSE2 code, though that only operates on 1 or 2 blocks at a time. I don't think it's really needed for poly1305_block_sse2(), but it doesn't hurt because it's already x86_64 code. It *might* be needed for poly1305_2block_sse2(), but overflows aren't easy to reproduce there. This bug was originally detected by my patches that improve testmgr to fuzz algorithms against their generic implementation. But also add a test vector which reproduces it directly (in the AVX2 case). Fixes: b1ccc8f4b631 ("crypto: poly1305 - Add a four block AVX2 variant for x86_64") Fixes: c70f4abef07a ("crypto: poly1305 - Add a SSE2 SIMD variant for x86_64") Cc: <stable@vger.kernel.org> # v4.3+ Cc: Martin Willi <martin@strongswan.org> Cc: Jason A. Donenfeld <Jason@zx2c4.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-02-12MLK-19365: crypto: tcrypt - remove remnants of pcomp-based zlibFranck LENORMAND
Commit 110492183c4b ("crypto: compress - remove unused pcomp interface") removed pcomp interface but missed cleaning up tcrypt. Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Franck LENORMAND <franck.lenormand@nxp.com>
2018-04-08crypto: testmgr - Fix incorrect values in PKCS#1 test vectorConor McLoughlin
commit 333e18c5cc74438f8940c7f3a8b3573748a371f9 upstream. The RSA private key for the first form should have version, prime1, prime2, exponent1, exponent2, coefficient values 0. With non-zero values for prime1,2, exponent 1,2 and coefficient the Intel QAT driver will assume that values are provided for the private key second form. This will result in signature verification failures for modules where QAT device is present and the modules are signed with rsa,sha256. Cc: <stable@vger.kernel.org> Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com> Signed-off-by: Conor McLoughlin <conor.mcloughlin@intel.com> Reviewed-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-22crypto: testmgr - add chunked test cases for chacha20Ard Biesheuvel
We failed to catch a bug in the chacha20 code after porting it to the skcipher API. We would have caught it if any chunked tests had been defined, so define some now so we will catch future regressions. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2017-06-20crypto: testmgr - add testvector for pkcs1pad(rsa)Stephan Mueller
The PKCS#1 RSA implementation is provided with a self test with RSA 2048 and SHA-256. This self test implicitly covers other RSA keys and other hashes. Also, this self test implies that the pkcs1pad(rsa) is FIPS 140-2 compliant. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2017-06-10crypto: testmgr - add genkey kpp testTudor-Dan Ambarus
The test considers a party that already has a private-public key pair and a party that provides a NULL key. The kernel will generate the private-public key pair for the latter, computes the shared secret on both ends and verifies if it's the same. The explicit private-public key pair was copied from the previous test vector. Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2017-04-24crypto: scomp - add support for deflate rfc1950 (zlib)Giovanni Cabiddu
Add scomp backend for zlib-deflate compression algorithm. This backend outputs data using the format defined in rfc1950 (raw deflate surrounded by zlib header and footer). Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2017-03-09crypto: testmgr - constify all test vectorsEric Biggers
Cryptographic test vectors should never be modified, so constify them to enforce this at both compile-time and run-time. This moves a significant amount of data from .data to .rodata when the crypto tests are enabled. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2017-03-04Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fixes from Herbert Xu: - vmalloc stack regression in CCM - Build problem in CRC32 on ARM - Memory leak in cavium - Missing Kconfig dependencies in atmel and mediatek - XTS Regression on some platforms (s390 and ppc) - Memory overrun in CCM test vector * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: vmx - Use skcipher for xts fallback crypto: vmx - Use skcipher for cbc fallback crypto: testmgr - Pad aes_ccm_enc_tv_template vector crypto: arm/crc32 - add build time test for CRC instruction support crypto: arm/crc32 - fix build error with outdated binutils crypto: ccm - move cbcmac input off the stack crypto: xts - Propagate NEED_FALLBACK bit crypto: api - Add crypto_requires_off helper crypto: atmel - CRYPTO_DEV_MEDIATEK should depend on HAS_DMA crypto: atmel - CRYPTO_DEV_ATMEL_TDES and CRYPTO_DEV_ATMEL_SHA should depend on HAS_DMA crypto: cavium - fix leak on curr if curr->head fails to be allocated crypto: cavium - Fix couple of static checker errors
2017-03-01crypto: testmgr - Pad aes_ccm_enc_tv_template vectorLaura Abbott
Running with KASAN and crypto tests currently gives BUG: KASAN: global-out-of-bounds in __test_aead+0x9d9/0x2200 at addr ffffffff8212fca0 Read of size 16 by task cryptomgr_test/1107 Address belongs to variable 0xffffffff8212fca0 CPU: 0 PID: 1107 Comm: cryptomgr_test Not tainted 4.10.0+ #45 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014 Call Trace: dump_stack+0x63/0x8a kasan_report.part.1+0x4a7/0x4e0 ? __test_aead+0x9d9/0x2200 ? crypto_ccm_init_crypt+0x218/0x3c0 [ccm] kasan_report+0x20/0x30 check_memory_region+0x13c/0x1a0 memcpy+0x23/0x50 __test_aead+0x9d9/0x2200 ? kasan_unpoison_shadow+0x35/0x50 ? alg_test_akcipher+0xf0/0xf0 ? crypto_skcipher_init_tfm+0x2e3/0x310 ? crypto_spawn_tfm2+0x37/0x60 ? crypto_ccm_init_tfm+0xa9/0xd0 [ccm] ? crypto_aead_init_tfm+0x7b/0x90 ? crypto_alloc_tfm+0xc4/0x190 test_aead+0x28/0xc0 alg_test_aead+0x54/0xd0 alg_test+0x1eb/0x3d0 ? alg_find_test+0x90/0x90 ? __sched_text_start+0x8/0x8 ? __wake_up_common+0x70/0xb0 cryptomgr_test+0x4d/0x60 kthread+0x173/0x1c0 ? crypto_acomp_scomp_free_ctx+0x60/0x60 ? kthread_create_on_node+0xa0/0xa0 ret_from_fork+0x2c/0x40 Memory state around the buggy address: ffffffff8212fb80: 00 00 00 00 01 fa fa fa fa fa fa fa 00 00 00 00 ffffffff8212fc00: 00 01 fa fa fa fa fa fa 00 00 00 00 01 fa fa fa >ffffffff8212fc80: fa fa fa fa 00 05 fa fa fa fa fa fa 00 00 00 00 ^ ffffffff8212fd00: 01 fa fa fa fa fa fa fa 00 00 00 00 01 fa fa fa ffffffff8212fd80: fa fa fa fa 00 00 00 00 00 05 fa fa fa fa fa fa This always happens on the same IV which is less than 16 bytes. Per Ard, "CCM IVs are 16 bytes, but due to the way they are constructed internally, the final couple of bytes of input IV are dont-cares. Apparently, we do read all 16 bytes, which triggers the KASAN errors." Fix this by padding the IV with null bytes to be at least 16 bytes. Cc: stable@vger.kernel.org Fixes: 0bc5a6c5c79a ("crypto: testmgr - Disable rfc4309 test and convert test vectors") Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2017-02-24crypto: change LZ4 modules to work with new LZ4 module versionSven Schmidt
Update the crypto modules using LZ4 compression as well as the test cases in testmgr.h to work with the new LZ4 module version. Link: http://lkml.kernel.org/r/1486321748-19085-4-git-send-email-4sschmid@informatik.uni-hamburg.de Signed-off-by: Sven Schmidt <4sschmid@informatik.uni-hamburg.de> Cc: Bongkyu Kim <bongkyu.kim@lge.com> Cc: Rui Salvaterra <rsalvaterra@gmail.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David S. Miller <davem@davemloft.net> Cc: Anton Vorontsov <anton@enomsg.org> Cc: Colin Cross <ccross@android.com> Cc: Kees Cook <keescook@chromium.org> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-11crypto: testmgr - add test cases for cbcmac(aes)Ard Biesheuvel
In preparation of splitting off the CBC-MAC transform in the CCM driver into a separate algorithm, define some test cases for the AES incarnation of cbcmac. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2017-01-13crypto: testmgr - use calculated count for number of test vectorsArd Biesheuvel
When working on AES in CCM mode for ARM, my code passed the internal tcrypt test before I had even bothered to implement the AES-192 and AES-256 code paths, which is strange because the tcrypt does contain AES-192 and AES-256 test vectors for CCM. As it turned out, the define AES_CCM_ENC_TEST_VECTORS was out of sync with the actual number of test vectors, causing only the AES-128 ones to be executed. So get rid of the defines, and wrap the test vector references in a macro that calculates the number of vectors automatically. The following test vector counts were out of sync with the respective defines: BF_CTR_ENC_TEST_VECTORS 2 -> 3 BF_CTR_DEC_TEST_VECTORS 2 -> 3 TF_CTR_ENC_TEST_VECTORS 2 -> 3 TF_CTR_DEC_TEST_VECTORS 2 -> 3 SERPENT_CTR_ENC_TEST_VECTORS 2 -> 3 SERPENT_CTR_DEC_TEST_VECTORS 2 -> 3 AES_CCM_ENC_TEST_VECTORS 8 -> 14 AES_CCM_DEC_TEST_VECTORS 7 -> 17 AES_CCM_4309_ENC_TEST_VECTORS 7 -> 23 AES_CCM_4309_DEC_TEST_VECTORS 10 -> 23 CAMELLIA_CTR_ENC_TEST_VECTORS 2 -> 3 CAMELLIA_CTR_DEC_TEST_VECTORS 2 -> 3 Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-12-07crypto: testmgr - add/enhance test cases for CRC-T10DIFArd Biesheuvel
The existing test cases only exercise a small slice of the various possible code paths through the x86 SSE/PCLMULQDQ implementation, and the upcoming ports of it for arm64. So add one that exceeds 256 bytes in size, and convert another to a chunked test. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-31crypto: FIPS - allow tests to be disabled in FIPS modeStephan Mueller
In FIPS mode, additional restrictions may apply. If these restrictions are violated, the kernel will panic(). This patch allows test vectors for symmetric ciphers to be marked as to be skipped in FIPS mode. Together with the patch, the XTS test vectors where the AES key is identical to the tweak key is disabled in FIPS mode. This test vector violates the FIPS requirement that both keys must be different. Reported-by: Tapas Sarangi <TSarangi@trustwave.com> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-05crypto: testmgr - Add 4K private key to RSA testvectorSalvatore Benedetto
Key generated with openssl. It also contains all fields required for testing CRT mode Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-01crypto: sha3 - Add HMAC-SHA3 test modes and test vectorsraveendra padasalagi
This patch adds HMAC-SHA3 test modes in tcrypt module and related test vectors. Signed-off-by: Raveendra Padasalagi <raveendra.padasalagi@broadcom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-06-23crypto: ecdh - Add ECDH software supportSalvatore Benedetto
* Implement ECDH under kpp API * Provide ECC software support for curve P-192 and P-256. * Add kpp test for ECDH with data generated by OpenSSL Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-06-23crypto: dh - Add DH software implementationSalvatore Benedetto
* Implement MPI based Diffie-Hellman under kpp API * Test provided uses data generad by OpenSSL Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-06-20crypto: sha3 - Add SHA-3 Test's in tcryptraveendra padasalagi
Added support for SHA-3 algorithm test's in tcrypt module and related test vectors. Signed-off-by: Raveendra Padasalagi <raveendra.padasalagi@broadcom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-01-27crypto: compress - remove unused pcomp interfaceJoonsoo Kim
It is unused now, so remove it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-15crypto: keywrap - add testmgr supportStephan Mueller
The testmanager code for symmetric ciphers is extended to allow verification of the IV after a cipher operation. In addition, test vectors for kw(aes) for encryption and decryption are added. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-15crypto: testmgr - test IV value after a cipher operationBoris BREZILLON
The crypto drivers are supposed to update the IV passed to the crypto request before calling the completion callback. Test for the IV value before considering the test as successful. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-14crypto: akcipher - Changes to asymmetric key APITadeusz Struk
Setkey function has been split into set_priv_key and set_pub_key. Akcipher requests takes sgl for src and dst instead of void *. Users of the API i.e. two existing RSA implementation and test mgr code have been updated accordingly. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-04crypto: testmgr - Disable authenc test and convert test vectorsHerbert Xu
This patch disables the authenc tests while the conversion to the new IV calling convention takes place. It also replaces the authenc test vectors with ones that will work with the new IV convention. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-17crypto: testmgr - Add a longer ChaCha20 test vectorMartin Willi
The AVX2 variant of ChaCha20 is used only for messages with >= 512 bytes length. With the existing test vectors, the implementation could not be tested. Due that lack of such a long official test vector, this one is self-generated using chacha20-generic. Signed-off-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-17crypto: chacha20poly1305 - Convert to new AEAD interfaceHerbert Xu
This patch converts rfc7539 and rfc7539esp to the new AEAD interface. The test vectors for rfc7539esp have also been updated to include the IV. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Martin Willi <martin@strongswan.org>
2015-07-17crypto: testmgr - Disable rfc4309 test and convert test vectorsHerbert Xu
This patch disables the rfc4309 test while the conversion to the new seqiv calling convention takes place. It also replaces the rfc4309 test vectors with ones that will work with the new IV convention. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-14crypto: testmgr - Disable rfc4106 test and convert test vectorsHerbert Xu
This patch disables the rfc4106 test while the conversion to the new seqiv calling convention takes place. It also converts the rfc4106 test vectors to the new format. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-07crypto: testmgr - add a chunking test for cbc(aes)LABBE Corentin
All tests for cbc(aes) use only blocks of data with a multiple of 4. This test adds a test with some odd SG size. Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-17crypto: testmgr - add tests vectors for RSATadeusz Struk
New test vectors for RSA algorithm. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-17crypto: poly1305 - Pass key as first two message blocks to each desc_ctxMartin Willi
The Poly1305 authenticator requires a unique key for each generated tag. This implies that we can't set the key per tfm, as multiple users set individual keys. Instead we pass a desc specific key as the first two blocks of the message to authenticate in update(). Signed-off-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-17crypto: testmgr - Add mcgrew test vectors for rfc4106Herbert Xu
This patch adds rfc4106 test vectors sourced from draft-mcgrew-gcm-test-01. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-17crypto: testmgr - Update rfc4543 test vectorsHerbert Xu
This patch updates the rfc4543 test vectors to the new format where the IV is part of the AD. For now these vectors are still unused. They will be reactivated once all rfc4543 implementations have migrated. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-09crypto: testmgr - Document struct cipher_testvecLABBE Corentin
2015-06-04crypto: testmgr - Add draft-ietf-ipsecme-chacha20-poly1305 test vectorMartin Willi
Signed-off-by: Martin Willi <martin@strongswan.org> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-04crypto: testmgr - Add ChaCha20-Poly1305 test vectors from RFC7539Martin Willi
2015-06-04crypto: testmgr - Add Poly1305 test vectors from RFC7539Martin Willi
2015-06-04crypto: testmgr - Add ChaCha20 test vectors from RFC7539Martin Willi
We explicitly set the Initial block Counter by prepending it to the nonce in Little Endian. The same test vector is used for both encryption and decryption, ChaCha20 is a cipher XORing a keystream. Signed-off-by: Martin Willi <martin@strongswan.org> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-25crypto: testmgr - Added one larger ghash testvector (400 bytes) to the testmgr.Harald Freudenberger
Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-11crypto: testmgr - add test cases for CRC32Ard Biesheuvel
This adds a couple of test cases for CRC32 (not CRC32c) to ensure that the generic and arch specific implementations are in sync. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Steve Capper <steve.capper@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-01crypto: testmgr - Wrap the LHS in expressions of the form !x == yDavid Howells
In the test manager, there are a number of if-statements with expressions of the form !x == y that incur warnings with gcc-5 of the following form: ../crypto/testmgr.c: In function '__test_aead': ../crypto/testmgr.c:523:12: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses] if (!ret == template[i].fail) { ^ By converting the 'fail' member of struct aead_testvec and struct cipher_testvec to a bool, we can get rid of the warnings. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-01crypto: pcomp - Constify (de)compression parametersDavid Howells
In testmgr, struct pcomp_testvec takes a non-const 'params' field, which is pointed to a const deflate_comp_params or deflate_decomp_params object. With gcc-5 this incurs the following warnings: In file included from ../crypto/testmgr.c:44:0: ../crypto/testmgr.h:28736:13: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers] .params = &deflate_comp_params, ^ ../crypto/testmgr.h:28748:13: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers] .params = &deflate_comp_params, ^ ../crypto/testmgr.h:28776:13: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers] .params = &deflate_decomp_params, ^ ../crypto/testmgr.h:28800:13: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers] .params = &deflate_decomp_params, ^ Fix this by making the parameters pointer const and constifying the things that use it. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-08-29crypto: testmgr - add test for lz4 and lz4hcKOVACS Krisztian
This patch adds a simple test vector for the lz4 and lz4hc compression algorithms. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-08-01crypto: testmgr - use chunks smaller than algo block size in chunk testsArd Biesheuvel
This patch updates many of the chunked tcrypt test cases so that not all of the chunks are an exact multiple of the block size. This should help uncover cases where the residue passed to blkcipher_walk_done() is incorrect. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-07-23crypto: testmgr - avoid DMA mapping from text, rodata, stackHoria Geanta
With DMA_API_DEBUG set, following warnings are emitted (tested on CAAM accelerator): DMA-API: device driver maps memory from kernel text or rodata DMA-API: device driver maps memory from stack and the culprits are: -key in __test_aead and __test_hash -result in __test_hash MAX_KEYLEN is changed to accommodate maximum key length from existing test vectors in crypto/testmgr.h (131 bytes) and rounded. Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-06-21crypto: testmgr - add 4 more test vectors for GHASHArd Biesheuvel
This adds 4 test vectors for GHASH (of which one for chunked mode), making a total of 5. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-06-20crypto: drbg - DRBG testmgr test vectorsStephan Mueller
All types of the DRBG (CTR, HMAC, Hash) are covered with test vectors. In addition, all permutations of use cases of the DRBG are covered: * with and without predition resistance * with and without additional information string * with and without personalization string As the DRBG implementation is agnositc of the specific backend cipher, only test vectors for one specific backend cipher is used. For example: the Hash DRBG uses the same code paths irrespectively of using SHA-256 or SHA-512. Thus, the test vectors for SHA-256 cover the testing of all DRBG code paths of SHA-512. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-05-22crypto: testmgr - add aead cbc des, des3_ede testsNitesh Lal
Test vectors were taken from existing test for CBC(DES3_EDE). Associated data has been added to test vectors. HMAC computed with Crypto++ has been used. Following algos have been covered. (a) "authenc(hmac(sha1),cbc(des))" (b) "authenc(hmac(sha1),cbc(des3_ede))" (c) "authenc(hmac(sha224),cbc(des))" (d) "authenc(hmac(sha224),cbc(des3_ede))" (e) "authenc(hmac(sha256),cbc(des))" (f) "authenc(hmac(sha256),cbc(des3_ede))" (g) "authenc(hmac(sha384),cbc(des))" (h) "authenc(hmac(sha384),cbc(des3_ede))" (i) "authenc(hmac(sha512),cbc(des))" (j) "authenc(hmac(sha512),cbc(des3_ede))" Signed-off-by: Vakul Garg <vakul@freescale.com> [NiteshNarayanLal@freescale.com: added hooks for the missing algorithms test and tested the patch] Signed-off-by: Nitesh Lal <NiteshNarayanLal@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
