This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
commit 678cce4019d746da6c680c48ba9e6d417803e127 upstream.
The x86_64 implementation of Poly1305 produces the wrong result on some
inputs because poly1305_4block_avx2() incorrectly assumes that when
partially reducing the accumulator, the bits carried from limb 'd4' to
limb 'h0' fit in a 32-bit integer. This is true for poly1305-generic
which processes only one block at a time. However, it's not true for
the AVX2 implementation, which processes 4 blocks at a time and
therefore can produce intermediate limbs about 4x larger.
Fix it by making the relevant calculations use 64-bit arithmetic rather
than 32-bit. Note that most of the carries already used 64-bit
arithmetic, but the d4 -> h0 carry was different for some reason.
To be safe I also made the same change to the corresponding SSE2 code,
though that only operates on 1 or 2 blocks at a time. I don't think
it's really needed for poly1305_block_sse2(), but it doesn't hurt
because it's already x86_64 code. It *might* be needed for
poly1305_2block_sse2(), but overflows aren't easy to reproduce there.
This bug was originally detected by my patches that improve testmgr to
fuzz algorithms against their generic implementation. But also add a
test vector which reproduces it directly (in the AVX2 case).
Fixes: b1ccc8f4b631 ("crypto: poly1305 - Add a four block AVX2 variant for x86_64")
Fixes: c70f4abef07a ("crypto: poly1305 - Add a SSE2 SIMD variant for x86_64")
Cc: <stable@vger.kernel.org> # v4.3+
Cc: Martin Willi <martin@strongswan.org>
Cc: Jason A. Donenfeld <Jason@zx2c4.com>
Reviewed-by: Martin Willi <martin@strongswan.org>
Commit 110492183c4b ("crypto: compress - remove unused pcomp interface")
removed pcomp interface but missed cleaning up tcrypt.
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
Signed-off-by: Franck LENORMAND <franck.lenormand@nxp.com>
commit 333e18c5cc74438f8940c7f3a8b3573748a371f9 upstream.
The RSA private key for the first form should have
version, prime1, prime2, exponent1, exponent2, coefficient
values 0.
With non-zero values for prime1,2, exponent 1,2 and coefficient
the Intel QAT driver will assume that values are provided for the
private key second form. This will result in signature verification
failures for modules where QAT device is present and the modules
are signed with rsa,sha256.
Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com>
Signed-off-by: Conor McLoughlin <conor.mcloughlin@intel.com>
Reviewed-by: Stephan Mueller <smueller@chronox.de>
We failed to catch a bug in the chacha20 code after porting it to the
skcipher API. We would have caught it if any chunked tests had been
defined, so define some now so we will catch future regressions.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
The PKCS#1 RSA implementation is provided with a self test with RSA 2048
and SHA-256. This self test implicitly covers other RSA keys and other
hashes. Also, this self test implies that the pkcs1pad(rsa) is FIPS
140-2 compliant.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
The test considers a party that already has a private-public
key pair and a party that provides a NULL key. The kernel will
generate the private-public key pair for the latter, computes
the shared secret on both ends and verifies if it's the same.
The explicit private-public key pair was copied from
the previous test vector.
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
Add scomp backend for zlib-deflate compression algorithm.
This backend outputs data using the format defined in rfc1950
(raw deflate surrounded by zlib header and footer).
Cryptographic test vectors should never be modified, so constify them to
enforce this at both compile-time and run-time. This moves a significant
amount of data from .data to .rodata when the crypto tests are enabled.
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto fixes from Herbert Xu:
- vmalloc stack regression in CCM
- Build problem in CRC32 on ARM
- Memory leak in cavium
- Missing Kconfig dependencies in atmel and mediatek
- XTS Regression on some platforms (s390 and ppc)
- Memory overrun in CCM test vector
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: vmx - Use skcipher for xts fallback
crypto: vmx - Use skcipher for cbc fallback
crypto: testmgr - Pad aes_ccm_enc_tv_template vector
crypto: arm/crc32 - add build time test for CRC instruction support
crypto: arm/crc32 - fix build error with outdated binutils
crypto: ccm - move cbcmac input off the stack
crypto: xts - Propagate NEED_FALLBACK bit
crypto: api - Add crypto_requires_off helper
crypto: atmel - CRYPTO_DEV_MEDIATEK should depend on HAS_DMA
crypto: atmel - CRYPTO_DEV_ATMEL_TDES and CRYPTO_DEV_ATMEL_SHA should depend on HAS_DMA
crypto: cavium - fix leak on curr if curr->head fails to be allocated
crypto: cavium - Fix couple of static checker errors
Running with KASAN and crypto tests currently gives
BUG: KASAN: global-out-of-bounds in __test_aead+0x9d9/0x2200 at addr ffffffff8212fca0
Read of size 16 by task cryptomgr_test/1107
Address belongs to variable 0xffffffff8212fca0
CPU: 0 PID: 1107 Comm: cryptomgr_test Not tainted 4.10.0+ #45
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014
Call Trace:
dump_stack+0x63/0x8a
kasan_report.part.1+0x4a7/0x4e0
? __test_aead+0x9d9/0x2200
? crypto_ccm_init_crypt+0x218/0x3c0 [ccm]
kasan_report+0x20/0x30
check_memory_region+0x13c/0x1a0
memcpy+0x23/0x50
? kasan_unpoison_shadow+0x35/0x50
? alg_test_akcipher+0xf0/0xf0
? crypto_skcipher_init_tfm+0x2e3/0x310
? crypto_spawn_tfm2+0x37/0x60
? crypto_ccm_init_tfm+0xa9/0xd0 [ccm]
? crypto_aead_init_tfm+0x7b/0x90
? crypto_alloc_tfm+0xc4/0x190
test_aead+0x28/0xc0
alg_test_aead+0x54/0xd0
alg_test+0x1eb/0x3d0
? alg_find_test+0x90/0x90
? __sched_text_start+0x8/0x8
? __wake_up_common+0x70/0xb0
cryptomgr_test+0x4d/0x60
kthread+0x173/0x1c0
? crypto_acomp_scomp_free_ctx+0x60/0x60
? kthread_create_on_node+0xa0/0xa0
ret_from_fork+0x2c/0x40
Memory state around the buggy address:
ffffffff8212fb80: 00 00 00 00 01 fa fa fa fa fa fa fa 00 00 00 00
ffffffff8212fc00: 00 01 fa fa fa fa fa fa 00 00 00 00 01 fa fa fa
>ffffffff8212fc80: fa fa fa fa 00 05 fa fa fa fa fa fa 00 00 00 00
ffffffff8212fd00: 01 fa fa fa fa fa fa fa 00 00 00 00 01 fa fa fa
ffffffff8212fd80: fa fa fa fa 00 00 00 00 00 05 fa fa fa fa fa fa
This always happens on the same IV which is less than 16 bytes.
Per Ard,
"CCM IVs are 16 bytes, but due to the way they are constructed
internally, the final couple of bytes of input IV are dont-cares.
Apparently, we do read all 16 bytes, which triggers the KASAN errors."
Fix this by padding the IV with null bytes to be at least 16 bytes.
Cc: stable@vger.kernel.org
Fixes: 0bc5a6c5c79a ("crypto: testmgr - Disable rfc4309 test and convert
test vectors")
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Laura Abbott <labbott@redhat.com>
Update the crypto modules using LZ4 compression as well as the test
cases in testmgr.h to work with the new LZ4 module version.
Link: http://lkml.kernel.org/r/1486321748-19085-4-git-send-email-4sschmid@informatik.uni-hamburg.de
Signed-off-by: Sven Schmidt <4sschmid@informatik.uni-hamburg.de>
Cc: Bongkyu Kim <bongkyu.kim@lge.com>
Cc: Rui Salvaterra <rsalvaterra@gmail.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
In preparation of splitting off the CBC-MAC transform in the CCM
driver into a separate algorithm, define some test cases for the
AES incarnation of cbcmac.
When working on AES in CCM mode for ARM, my code passed the internal
tcrypt test before I had even bothered to implement the AES-192 and
AES-256 code paths, which is strange because the tcrypt does contain
AES-192 and AES-256 test vectors for CCM.
As it turned out, the define AES_CCM_ENC_TEST_VECTORS was out of sync
with the actual number of test vectors, causing only the AES-128 ones
to be executed.
So get rid of the defines, and wrap the test vector references in a
macro that calculates the number of vectors automatically.
The following test vector counts were out of sync with the respective
defines:
BF_CTR_ENC_TEST_VECTORS 2 -> 3
BF_CTR_DEC_TEST_VECTORS 2 -> 3
TF_CTR_ENC_TEST_VECTORS 2 -> 3
TF_CTR_DEC_TEST_VECTORS 2 -> 3
SERPENT_CTR_ENC_TEST_VECTORS 2 -> 3
SERPENT_CTR_DEC_TEST_VECTORS 2 -> 3
AES_CCM_ENC_TEST_VECTORS 8 -> 14
AES_CCM_DEC_TEST_VECTORS 7 -> 17
AES_CCM_4309_ENC_TEST_VECTORS 7 -> 23
AES_CCM_4309_DEC_TEST_VECTORS 10 -> 23
CAMELLIA_CTR_ENC_TEST_VECTORS 2 -> 3
CAMELLIA_CTR_DEC_TEST_VECTORS 2 -> 3
The existing test cases only exercise a small slice of the various
possible code paths through the x86 SSE/PCLMULQDQ implementation,
and the upcoming ports of it for arm64. So add one that exceeds 256
bytes in size, and convert another to a chunked test.
In FIPS mode, additional restrictions may apply. If these restrictions
are violated, the kernel will panic(). This patch allows test vectors
for symmetric ciphers to be marked as to be skipped in FIPS mode.
Together with the patch, the XTS test vectors where the AES key is
identical to the tweak key is disabled in FIPS mode. This test vector
violates the FIPS requirement that both keys must be different.
Reported-by: Tapas Sarangi <TSarangi@trustwave.com>
Key generated with openssl. It also contains all fields required
for testing CRT mode
Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
This patch adds HMAC-SHA3 test modes in tcrypt module
and related test vectors.
Signed-off-by: Raveendra Padasalagi <raveendra.padasalagi@broadcom.com>
* Implement ECDH under kpp API
* Provide ECC software support for curve P-192 and
P-256.
* Add kpp test for ECDH with data generated by OpenSSL
* Implement MPI based Diffie-Hellman under kpp API
* Test provided uses data generad by OpenSSL
Added support for SHA-3 algorithm test's
in tcrypt module and related test vectors.
It is unused now, so remove it.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
The testmanager code for symmetric ciphers is extended to allow
verification of the IV after a cipher operation.
In addition, test vectors for kw(aes) for encryption and decryption are
added.
The crypto drivers are supposed to update the IV passed to the crypto
request before calling the completion callback.
Test for the IV value before considering the test as successful.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Setkey function has been split into set_priv_key and set_pub_key.
Akcipher requests takes sgl for src and dst instead of void *.
Users of the API i.e. two existing RSA implementation and
test mgr code have been updated accordingly.
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
This patch disables the authenc tests while the conversion to the
new IV calling convention takes place. It also replaces the authenc
test vectors with ones that will work with the new IV convention.
The AVX2 variant of ChaCha20 is used only for messages with >= 512 bytes
length. With the existing test vectors, the implementation could not be
tested. Due that lack of such a long official test vector, this one is
self-generated using chacha20-generic.
Signed-off-by: Martin Willi <martin@strongswan.org>
This patch converts rfc7539 and rfc7539esp to the new AEAD interface.
The test vectors for rfc7539esp have also been updated to include
the IV.
Tested-by: Martin Willi <martin@strongswan.org>
This patch disables the rfc4309 test while the conversion to the
new seqiv calling convention takes place. It also replaces the
rfc4309 test vectors with ones that will work with the new IV
convention.
This patch disables the rfc4106 test while the conversion to the
new seqiv calling convention takes place. It also converts the
rfc4106 test vectors to the new format.
All tests for cbc(aes) use only blocks of data with a multiple of 4.
This test adds a test with some odd SG size.
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
New test vectors for RSA algorithm.
The Poly1305 authenticator requires a unique key for each generated tag. This
implies that we can't set the key per tfm, as multiple users set individual
keys. Instead we pass a desc specific key as the first two blocks of the
message to authenticate in update().
This patch adds rfc4106 test vectors sourced from
draft-mcgrew-gcm-test-01.
This patch updates the rfc4543 test vectors to the new format
where the IV is part of the AD. For now these vectors are still
unused. They will be reactivated once all rfc4543 implementations
have migrated.
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
We explicitly set the Initial block Counter by prepending it to the nonce in
Little Endian. The same test vector is used for both encryption and decryption,
ChaCha20 is a cipher XORing a keystream.
Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com>
This adds a couple of test cases for CRC32 (not CRC32c) to
ensure that the generic and arch specific implementations
are in sync.
Acked-by: Steve Capper <steve.capper@linaro.org>
In the test manager, there are a number of if-statements with expressions of
the form !x == y that incur warnings with gcc-5 of the following form:
../crypto/testmgr.c: In function '__test_aead':
../crypto/testmgr.c:523:12: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]
if (!ret == template[i].fail) {
By converting the 'fail' member of struct aead_testvec and struct
cipher_testvec to a bool, we can get rid of the warnings.
In testmgr, struct pcomp_testvec takes a non-const 'params' field, which is
pointed to a const deflate_comp_params or deflate_decomp_params object. With
gcc-5 this incurs the following warnings:
In file included from ../crypto/testmgr.c:44:0:
../crypto/testmgr.h:28736:13: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers]
.params = &deflate_comp_params,
../crypto/testmgr.h:28748:13: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers]
../crypto/testmgr.h:28776:13: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers]
.params = &deflate_decomp_params,
../crypto/testmgr.h:28800:13: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers]
Fix this by making the parameters pointer const and constifying the things
that use it.
This patch adds a simple test vector for the lz4 and lz4hc compression
algorithms.
Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu>
This patch updates many of the chunked tcrypt test cases so that not all of the
chunks are an exact multiple of the block size. This should help uncover cases
where the residue passed to blkcipher_walk_done() is incorrect.
With DMA_API_DEBUG set, following warnings are emitted
(tested on CAAM accelerator):
DMA-API: device driver maps memory from kernel text or rodata
DMA-API: device driver maps memory from stack
and the culprits are:
-key in __test_aead and __test_hash
-result in __test_hash
MAX_KEYLEN is changed to accommodate maximum key length from
existing test vectors in crypto/testmgr.h (131 bytes) and rounded.
Signed-off-by: Horia Geanta <horia.geanta@freescale.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
This adds 4 test vectors for GHASH (of which one for chunked mode), making
a total of 5.
All types of the DRBG (CTR, HMAC, Hash) are covered with test vectors.
In addition, all permutations of use cases of the DRBG are covered:
* with and without predition resistance
* with and without additional information string
* with and without personalization string
As the DRBG implementation is agnositc of the specific backend cipher,
only test vectors for one specific backend cipher is used. For example:
the Hash DRBG uses the same code paths irrespectively of using SHA-256
or SHA-512. Thus, the test vectors for SHA-256 cover the testing of all
DRBG code paths of SHA-512.
Test vectors were taken from existing test for
CBC(DES3_EDE). Associated data has been added to test vectors.
HMAC computed with Crypto++ has been used. Following algos have
been covered.
(a) "authenc(hmac(sha1),cbc(des))"
(b) "authenc(hmac(sha1),cbc(des3_ede))"
(c) "authenc(hmac(sha224),cbc(des))"
(d) "authenc(hmac(sha224),cbc(des3_ede))"
(e) "authenc(hmac(sha256),cbc(des))"
(f) "authenc(hmac(sha256),cbc(des3_ede))"
(g) "authenc(hmac(sha384),cbc(des))"
(h) "authenc(hmac(sha384),cbc(des3_ede))"
(i) "authenc(hmac(sha512),cbc(des))"
(j) "authenc(hmac(sha512),cbc(des3_ede))"
Signed-off-by: Vakul Garg <vakul@freescale.com>
[NiteshNarayanLal@freescale.com: added hooks for the missing algorithms test and tested the patch]
Signed-off-by: Nitesh Lal <NiteshNarayanLal@freescale.com>
