Added ofb(aes) and cmac(aes) tests
Change-Id: Ia79b0f979af88d337e91164f0b8b6d0eba18cd03
Reviewed-on: http://git-master/r/34701
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
This patch is to fix the vmac algorithm, add more test cases for vmac,
and fix the test failure on some big endian system like s390.
Signed-off-by: Shane Wang <shane.wang@intel.com>
Add ghash algorithm test before provide it to users
Signed-off-by: Youquan, Song <youquan.song@intel.com>
This patch adds VMAC (a fast MAC) support into crypto framework.
Signed-off-by: Joseph Cihula <joseph.cihula@intel.com>
Now with multi-block test vectors, all from SP800-38A, Appendix F.5.
Also added ctr(aes) to case 10 in tcrypt.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Add ANSI X9.31 Continuous Pseudo-Random Number Generator (AES mode),
aka 'ansi_cprng' test vectors, taken from Appendix B.2.9 and B.2.10
of the NIST RNGVS document, found here:
http://csrc.nist.gov/groups/STM/cavp/documents/rng/RNGVS.pdf
Successfully tested against both the cryptodev-2.6 tree and a Red
Hat Enterprise Linux 5.4 kernel, via 'modprobe tcrypt mode=150'.
The selection of 150 was semi-arbitrary, didn't seem like it should
go any place in particular, so I started a new range for rng tests.
Add some necessary infrastructure to make it possible to run
self-tests for ansi_cprng. The bits are likely very specific
to the ANSI X9.31 CPRNG in AES mode, and thus perhaps should
be named more specifically if/when we grow additional CPRNG
support...
Successfully tested against the cryptodev-2.6 tree and a
Red Hat Enterprise Linux 5.x kernel with the follow-on
patch that adds the actual test vectors.
Add an array of encryption and decryption + verification self-tests
for rfc4309(ccm(aes)).
Test vectors all come from sample FIPS CAVS files provided to
Red Hat by a testing lab. Unfortunately, all the published sample
vectors in RFC 3610 and NIST Special Publication 800-38C contain nonce
lengths that the kernel's rfc4309 implementation doesn't support, so
while using some public domain vectors would have been preferred, its
not possible at this time.
Add infrastructure to tcrypt/testmgr to support handling ccm decryption
test vectors that are expected to fail verification.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
The comment for the deflate test vectors says the winbits parameter is 11,
while the deflate module actually uses -11 (a negative window bits parameter
enables the raw deflate format instead of the zlib format).
Correct this, to avoid confusion about the format used.
This patch moves the newly created alg_test infrastructure into
cryptomgr. This shall allow us to use it for testing at algorithm
registrations.
