path: root/crypto/tgr192.c
2006-06-26[CRYPTO] all: Pass tfm instead of ctx to algorithmsHerbert Xu
Up until now algorithms have been happy to get a context pointer since they know everything that's in the tfm already (e.g., alignment, block size). However, once we have parameterised algorithms, such information will be specific to each tfm. So the algorithm API needs to be changed to pass the tfm structure instead of the context pointer. This patch is basically a text substitution. The only tricky bit is the assembly routines that need to get the context pointer offset through asm-offsets.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] digest: Remove unnecessary zeroing during initHerbert Xu
Various digest algorithms operate one block at a time and therefore keep a temporary buffer of partial blocks. This buffer does not need to be initialised since there is a counter which indicates what is and isn't valid in it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] digest: Add alignment handlingAtsushi Nemoto
Some hash modules load/store data words directly. The digest layer should pass properly aligned buffer to update()/final() method. This patch also add cra_alignmask to some hash modules. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] Use standard byte order macros wherever possibleHerbert Xu
A lot of crypto code needs to read/write a 32-bit/64-bit words in a specific gender. Many of them open code them by reading/writing one byte at a time. This patch converts all the applicable usages over to use the standard byte order macros. This is based on a previous patch by Denis Vlasenko. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
