path: root/crypto/xts.c
2014-11-26crypto: include crypto- module prefix in templateKees Cook
This adds the module loading prefix "crypto-" to the template lookup as well. For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly includes the "crypto-" prefix at every level, correctly rejecting "vfat": net-pf-38 algif-hash crypto-vfat(blowfish) crypto-vfat(blowfish)-all crypto-vfat Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: xts: add interface for parallelized cipher implementationsJussi Kivilinna
Add xts_crypt() function that can be used by cipher implementations that can benefit from parallelized cipher operations. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: xts - use blocksize constantJussi Kivilinna
XTS has fixed blocksize of 16. Define XTS_BLOCK_SIZE and use in place of crypto_cipher_blocksize(). Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-26crypto: Use ERR_CASTJulia Lawall
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more clear what is the purpose of the operation, which otherwise looks like a no-op. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ type T; T x; identifier f; @@ T f (...) { <+... - ERR_PTR(PTR_ERR(x)) + x ...+> } @@ expression x; @@ - ERR_PTR(PTR_ERR(x)) + ERR_CAST(x) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-03-06[CRYPTO] xts: Use proper alignmentSebastian Siewior
The XTS blockmode uses a copy of the IV which is saved on the stack and may or may not be properly aligned. If it is not, it will break hardware cipher like the geode or padlock. This patch encrypts the IV in place so we don't have to worry about alignment. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Tested-by: Stefan Hellermann <stefan@the2masters.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] xts: XTS blockcipher mode implementation without partial blocksRik Snel
XTS currently considered to be the successor of the LRW mode by the IEEE1619 workgroup. LRW was discarded, because it was not secure if the encyption key itself is encrypted with LRW. XTS does not have this problem. The implementation is pretty straightforward, a new function was added to gf128mul to handle GF(128) elements in ble format. Four testvectors from the specification http://grouper.ieee.org/groups/1619/email/pdf00086.pdf were added, and they verify on my system. Signed-off-by: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
