commit 8996eafdcbad149ac0f772fb1649fbb75c482a6a upstream.
Unlike shash algorithms, ahash drivers must implement export
and import as their descriptors may contain hardware state and
cannot be exported as is. Unfortunately some ahash drivers did
not provide them and end up causing crashes with algif_hash.
This patch adds a check to prevent these drivers from registering
ahash algorithms until they are fixed.
The backport of commit 5d26a105b5a7 ("crypto: prefix module autoloading
with "crypto-"") lost the MODULE_ALIAS_CRYPTO() annotation of crc32c.c.
Add it to fix the reported filesystem related regressions.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Reported-by: Philip Müller <philm@manjaro.org>
Cc: Rob McCathie <rob@manjaro.org>
Cc: Luis Henriques <luis.henriques@canonical.com>
Cc: Kamal Mostafa <kamal@canonical.com>
Cc: Jiri Slaby <jslaby@suse.cz>
commit 3e14dcf7cb80b34a1f38b55bc96f02d23fdaaaaf upstream.
Commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
changed the automatic module loading when requesting crypto algorithms
to prefix all module requests with "crypto-". This requires all crypto
modules to have a crypto specific module alias even if their file name
would otherwise match the requested crypto algorithm.
Even though commit 5d26a105b5a7 added those aliases for a vast amount of
modules, it was missing a few. Add the required MODULE_ALIAS_CRYPTO
annotations to those files to make them get loaded automatically, again.
This fixes, e.g., requesting 'ecb(blowfish-generic)', which used to work
with kernels v3.18 and below.
Also change MODULE_ALIAS() lines to MODULE_ALIAS_CRYPTO(). The former
won't work for crypto modules any more.
Fixes: 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
commit 4943ba16bbc2db05115707b3ff7b4874e9e3c560 upstream.
This adds the module loading prefix "crypto-" to the template lookup
as well.
For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly
includes the "crypto-" prefix at every level, correctly rejecting "vfat":
net-pf-38
algif-hash
crypto-vfat(blowfish)
crypto-vfat(blowfish)-all
crypto-vfat
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Mathias Krause <minipli@googlemail.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 7e77bdebff5cb1e9876c561f69710b9ab8fa1f7e upstream.
If a request is backlogged, it's complete() handler will get called
twice: once with -EINPROGRESS, and once with the final error code.
af_alg's complete handler, unlike other users, does not handle the
-EINPROGRESS but instead always completes the completion that recvmsg()
is waiting on. This can lead to a return to user space while the
request is still pending in the driver. If userspace closes the sockets
before the requests are handled by the driver, this will lead to
use-after-frees (and potential crashes) in the kernel due to the tfm
having been freed.
The crashes can be easily reproduced (for example) by reducing the max
queue length in cryptod.c and running the following (from
http://www.chronox.de/libkcapi.html) on AES-NI capable hardware:
$ while true; do kcapi -x 1 -e -c '__ecb-aes-aesni' \
-k 00000000000000000000000000000000 \
-p 00000000000000000000000000000000 >/dev/null & done
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
commit e2cffb5f493a8b431dc87124388ea59b79f0bccb upstream.
On archs with PAGE_SIZE >= 64 KiB the function skcipher_alloc_sgl()
fails with -ENOMEM no matter what user space actually requested.
This is caused by the fact sock_kmalloc call inside the function tried
to allocate more memory than allowed by the default kernel socket buffer
size (kernel param net.core.optmem_max).
Signed-off-by: Ondrej Kozina <okozina@redhat.com>
commit 4c63f83c2c2e16a13ce274ee678e28246bd33645 upstream.
Th AF_ALG socket was missing a security label (e.g. SELinux)
which means that socket was in "unlabeled" state.
This was recently demonstrated in the cryptsetup package
(cryptsetup v1.6.5 and later.)
See https://bugzilla.redhat.com/show_bug.cgi?id=1115120
This patch clones the sock's label from the parent sock
and resolves the issue (similar to AF_BLUETOOTH protocol family).
Signed-off-by: Milan Broz <gmazyland@gmail.com>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 90f62cf30a78721641e08737bda787552428061e ]
It is possible by passing a netlink socket to a more privileged
executable and then to fool that executable into writing to the socket
data that happens to be valid netlink message to do something that
privileged executable did not intend to do.
To keep this from happening replace bare capable and ns_capable calls
with netlink_capable, netlink_net_calls and netlink_ns_capable calls.
Which act the same as the previous calls except they verify that the
opener of the socket had the desired permissions as well.
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit 130fa5bc81b44b6cc1fbdea3abf6db0da22964e0 upstream.
The crypto algorithm modules utilizing the crypto daemon could
be used early when the system start up. Using module_init
does not guarantee that the daemon's work queue is initialized
when the cypto alorithm depending on crypto_wq starts. It is necessary
to initialize the crypto work queue earlier at the subsystem
init time to make sure that it is initialized
when used.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
It turns out that commit: d3f7d56a7a4671d395e8af87071068a195257bf6 was
applied to the tree twice, which didn't hurt anything, but it's good to
fix this up.
Reported-by: Veaceslav Falico <veaceslav@falico.eu>
Cc: Richard Weinberger <richard@nod.at>
Cc: Shawn Landden <shawnlandden@gmail.com>
Cc: Tom Herbert <therbert@google.com>
commit d3f7d56a7a4671d395e8af87071068a195257bf6 upstream.
Commit 35f9c09fe (tcp: tcp_sendpages() should call tcp_push() once)
added an internal flag MSG_SENDPAGE_NOTLAST, similar to
MSG_MORE.
algif_hash, algif_skcipher, and udp used MSG_MORE from tcp_sendpages()
and need to see the new flag as identical to MSG_MORE.
This fixes sendfile() on AF_ALG.
v3: also fix udp
Reported-and-tested-by: Shawn Landden <shawnlandden@gmail.com>
Original-patch: Richard Weinberger <richard@nod.at>
Signed-off-by: Shawn Landden <shawn@churchofgit.com>
commit fc019c7122dfcd69c50142b57a735539aec5da95 upstream.
When performing an asynchronous ablkcipher operation the authenc
completion callback routine is invoked, but it does not locate and use
the proper IV.
The callback routine, crypto_authenc_encrypt_done, is updated to use
the same method of calculating the address of the IV as is done in
crypto_authenc_encrypt function which sets up the callback.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
commit 5638cabf3e4883f38dfb246c30980cebf694fbda upstream.
There are cases when cryptlen can be zero in crypto_ccm_auth():
-encryptiom: input scatterlist length is zero (no plaintext)
-decryption: input scatterlist contains only the mac
plus the condition of having different source and destination buffers
(or else scatterlist length = max(plaintext_len, ciphertext_len)).
These are not handled correctly, leading to crashes like:
root@p4080ds:~/crypto# insmod tcrypt.ko mode=45
kernel BUG at crypto/scatterwalk.c:37!
Oops: Exception in kernel mode, sig: 5 [#1]
SMP NR_CPUS=8 P4080 DS
Modules linked in: tcrypt(+) crc32c xts xcbc vmac pcbc ecb gcm ghash_generic gf128mul ccm ctr seqiv
CPU: 3 PID: 1082 Comm: cryptomgr_test Not tainted 3.11.0 #14
task: ee12c5b0 ti: eecd0000 task.ti: eecd0000
NIP: c0204d98 LR: f9225848 CTR: c0204d80
REGS: eecd1b70 TRAP: 0700 Not tainted (3.11.0)
MSR: 00029002 <CE,EE,ME> CR: 22044022 XER: 20000000
GPR00: f9225c94 eecd1c20 ee12c5b0 eecd1c28 ee879400 ee879400 00000000 ee607464
GPR08: 00000001 00000001 00000000 006b0000 c0204d80 00000000 00000002 c0698e20
GPR16: ee987000 ee895000 fffffff4 ee879500 00000100 eecd1d58 00000001 00000000
GPR24: ee879400 00000020 00000000 00000000 ee5b2800 ee607430 00000004 ee607460
NIP [c0204d98] scatterwalk_start+0x18/0x30
LR [f9225848] get_data_to_compute+0x28/0x2f0 [ccm]
Call Trace:
[eecd1c20] [f9225974] get_data_to_compute+0x154/0x2f0 [ccm] (unreliable)
[eecd1c70] [f9225c94] crypto_ccm_auth+0x184/0x1d0 [ccm]
[eecd1cb0] [f9225d40] crypto_ccm_encrypt+0x60/0x2d0 [ccm]
[eecd1cf0] [c020d77c] __test_aead+0x3ec/0xe20
[eecd1e20] [c020f35c] test_aead+0x6c/0xe0
[eecd1e40] [c020f420] alg_test_aead+0x50/0xd0
[eecd1e60] [c020e5e4] alg_test+0x114/0x2e0
[eecd1ee0] [c020bd1c] cryptomgr_test+0x4c/0x60
[eecd1ef0] [c0047058] kthread+0xa8/0xb0
[eecd1f40] [c000eb0c] ret_from_kernel_thread+0x5c/0x64
Instruction dump:
0f080000 81290024 552807fe 0f080000 5529003a 4bffffb4 90830000 39400000
39000001 8124000c 2f890000 7d28579e <0f090000> 81240008 91230004 4e800020
---[ end trace 6d652dfcd1be37bd ]---
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Signed-off-by: Horia Geanta <horia.geanta@freescale.com>
[ Upstream commit d3f7d56a7a4671d395e8af87071068a195257bf6 ]
MSG_MORE.
v3: also fix udp
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
commit 124df926090b32a998483f6e43ebeccdbe5b5302 upstream.
Remove the certificate date checks that are performed when a certificate is
parsed. There are two checks: a valid from and a valid to. The first check is
causing a lot of problems with system clocks that don't keep good time and the
second places an implicit expiry date upon the kernel when used for module
signing, so do we really need them?
cc: David Woodhouse <dwmw2@infradead.org>
cc: Rusty Russell <rusty@rustcorp.com.au>
cc: Josh Boyer <jwboyer@redhat.com>
cc: Alexander Holler <holler@ahsoftware.de>
commit 714b33d15130cbb5ab426456d4e3de842d6c5b8a upstream.
Stephan Mueller reported to me recently a error in random number generation in
the ansi cprng. If several small requests are made that are less than the
instances block size, the remainder for loop code doesn't increment
rand_data_valid in the last iteration, meaning that the last bytes in the
rand_data buffer gets reused on the subsequent smaller-than-a-block request for
random data.
The fix is pretty easy, just re-code the for loop to make sure that
rand_data_valid gets incremented appropriately
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Stephan Mueller <stephan.mueller@atsec.com>
CC: Stephan Mueller <stephan.mueller@atsec.com>
CC: Petr Matousek <pmatouse@redhat.com>
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: "David S. Miller" <davem@davemloft.net>
commit 77dbd7a95e4a4f15264c333a9e9ab97ee27dc2aa upstream.
crypto_larval_lookup should only return a larval if it created one.
Any larval created by another entity must be processed through
crypto_larval_wait before being returned.
Otherwise this will lead to a larval being killed twice, which
will most likely lead to a crash.
Reported-by: Kees Cook <keescook@chromium.org>
Tested-by: Kees Cook <keescook@chromium.org>
commit 1c8fca1d92e14859159a82b8a380d220139b7344 upstream.
The template lookup interface does not provide a way to use format
strings, so make sure that the interface cannot be abused accidentally.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
On Thu, Jun 20, 2013 at 10:00:21AM +0200, Daniel Borkmann wrote:
> After having fixed a NULL pointer dereference in SCTP 1abd165e ("net:
> sctp: fix NULL pointer dereference in socket destruction"), I ran into
> the following NULL pointer dereference in the crypto subsystem with
> the same reproducer, easily hit each time:
> BUG: unable to handle kernel NULL pointer dereference at (null)
> IP: [<ffffffff81070321>] __wake_up_common+0x31/0x90
> PGD 0
> Oops: 0000 [#1] SMP
> Modules linked in: padlock_sha(F-) sha256_generic(F) sctp(F) libcrc32c(F) [..]
> CPU: 6 PID: 3326 Comm: cryptomgr_probe Tainted: GF 3.10.0-rc5+ #1
> Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011
> task: ffff88007b6cf4e0 ti: ffff88007b7cc000 task.ti: ffff88007b7cc000
> RIP: 0010:[<ffffffff81070321>] [<ffffffff81070321>] __wake_up_common+0x31/0x90
> RSP: 0018:ffff88007b7cde08 EFLAGS: 00010082
> RAX: ffffffffffffffe8 RBX: ffff88003756c130 RCX: 0000000000000000
> RDX: 0000000000000000 RSI: 0000000000000003 RDI: ffff88003756c130
> RBP: ffff88007b7cde48 R08: 0000000000000000 R09: ffff88012b173200
> R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000282
> R13: ffff88003756c138 R14: 0000000000000000 R15: 0000000000000000
> FS: 0000000000000000(0000) GS:ffff88012fc60000(0000) knlGS:0000000000000000
> CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
> CR2: 0000000000000000 CR3: 0000000001a0b000 CR4: 00000000000007e0
> DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
> DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
> Stack:
> ffff88007b7cde28 0000000300000000 ffff88007b7cde28 ffff88003756c130
> 0000000000000282 ffff88003756c128 ffffffff81227670 0000000000000000
> ffff88007b7cde78 ffffffff810722b7 ffff88007cdcf000 ffffffff81a90540
> Call Trace:
> [<ffffffff81227670>] ? crypto_alloc_pcomp+0x20/0x20
> [<ffffffff810722b7>] complete_all+0x47/0x60
> [<ffffffff81227708>] cryptomgr_probe+0x98/0xc0
> [<ffffffff8106760e>] kthread+0xce/0xe0
> [<ffffffff81067540>] ? kthread_freezable_should_stop+0x70/0x70
> [<ffffffff815450dc>] ret_from_fork+0x7c/0xb0
> Code: 41 56 41 55 41 54 53 48 83 ec 18 66 66 66 66 90 89 75 cc 89 55 c8
> 4c 8d 6f 08 48 8b 57 08 41 89 cf 4d 89 c6 48 8d 42 e
> RIP [<ffffffff81070321>] __wake_up_common+0x31/0x90
> RSP <ffff88007b7cde08>
> ---[ end trace b495b19270a4d37e ]---
> My assumption is that the following is happening: the minimal SCTP
> tool runs under ``echo 1 > /proc/sys/net/sctp/auth_enable'', hence
> it's making use of crypto_alloc_hash() via sctp_auth_init_hmacs().
> It forks itself, heavily allocates, binds, listens and waits in
> accept on sctp sockets, and then randomly kills some of them (no
> need for an actual client in this case to hit this). Then, again,
> allocating, binding, etc, and then killing child processes.
> The problem that might be happening here is that cryptomgr requests
> the module to probe/load through cryptomgr_schedule_probe(), but
> before the thread handler cryptomgr_probe() returns, we return from
> the wait_for_completion_interruptible() function and probably already
> have cleared up larval, thus we run into a NULL pointer dereference
> when in cryptomgr_probe() complete_all() is being called.
> If we wait with wait_for_completion() instead, this panic will not
> occur anymore. This is valid, because in case a signal is pending,
> cryptomgr_probe() returns from probing anyway with properly calling
> complete_all().
The use of wait_for_completion_interruptible is intentional so that
we don't lock up the thread if a bug causes us to never wake up.
This bug is caused by the helper thread using the larval without
holding a reference count on it. If the helper thread completes
after the original thread requesting for help has gone away and
destroyed the larval, then we get the crash above.
So the fix is to hold a reference count on the larval.
Cc: <stable@vger.kernel.org> # 3.6+
Reported-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Daniel Borkmann <dborkman@redhat.com>
It appears that the performance of 'vpgatherdd' is suboptimal for this kind of
workload (tested on Core i5-4570) and causes blowfish-avx2 to be significantly
slower than blowfish-amd64. So disable the AVX2 implementation to avoid
performance regressions.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
workload (tested on Core i5-4570) and causes twofish_avx2 to be significantly
slower than twofish_avx. So disable the AVX2 implementation to avoid
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull mudule updates from Rusty Russell:
"We get rid of the general module prefix confusion with a binary config
option, fix a remove/insert race which Never Happens, and (my
favorite) handle the case when we have too many modules for a single
commandline. Seriously, the kernel is full, please go away!"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modpost: fix unwanted VMLINUX_SYMBOL_STR expansion
X.509: Support parse long form of length octets in Authority Key Identifier
module: don't unlink the module until we've removed all exposure.
kernel: kallsyms: memory override issue, need check destination buffer length
MODSIGN: do not send garbage to stderr when enabling modules signature
modpost: handle huge numbers of modules.
modpost: add -T option to read module names from file/stdin.
modpost: minor cleanup.
genksyms: pass symbol-prefix instead of arch
module: fix symbol versioning with symbol prefixes
CONFIG_SYMBOL_PREFIX: cleanup.
Pull crypto update from Herbert Xu:
- XTS mode optimisation for twofish/cast6/camellia/aes on x86
- AVX2/x86_64 implementation for blowfish/twofish/serpent/camellia
- SSSE3/AVX/AVX2 optimisations for sha256/sha512
- Added driver for SAHARA2 crypto accelerator
- Fix for GMAC when used in non-IPsec secnarios
- Added generic CMAC implementation (including IPsec glue)
- IP update for crypto/atmel
- Support for more than one device in hwrng/timeriomem
- Added Broadcom BCM2835 RNG driver
- Misc fixes
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (59 commits)
crypto: caam - fix job ring cleanup code
crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of camellia cipher
crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipher
crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher
crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher
crypto: tcrypt - add async cipher speed tests for blowfish
crypto: testmgr - extend camellia test-vectors for camellia-aesni/avx2
crypto: aesni_intel - fix Kconfig problem with CRYPTO_GLUE_HELPER_X86
crypto: aesni_intel - add more optimized XTS mode for x86-64
crypto: x86/camellia-aesni-avx - add more optimized XTS code
crypto: cast6-avx: use new optimized XTS code
crypto: x86/twofish-avx - use optimized XTS code
crypto: x86 - add more optimized XTS-mode for serpent-avx
xfrm: add rfc4494 AES-CMAC-96 support
crypto: add CMAC support to CryptoAPI
crypto: testmgr - add empty test vectors for null ciphers
crypto: testmgr - add AES GMAC test vectors
crypto: gcm - fix rfc4543 to handle async crypto correctly
crypto: gcm - make GMAC work when dst and src are different
hwrng: timeriomem - added devicetree hooks
Use prandom_bytes() to generate random bytes for test data.
Cc: Dan Williams <djbw@fb.com>
Cc: Vinod Koul <vinod.koul@intel.com>
camellia cipher
Patch adds AVX2/AES-NI/x86-64 implementation of Camellia cipher, requiring
32 parallel blocks for input (512 bytes). Compared to AVX implementation, this
version is extended to use the 256-bit wide YMM registers. For AES-NI
instructions data is split to two 128-bit registers and merged afterwards.
Even with this additional handling, performance should be higher compared
to the AES-NI/AVX implementation.
Patch adds AVX2/x86-64 implementation of Serpent cipher, requiring 16 parallel
blocks for input (256 bytes). Implementation is based on the AVX implementation
and extends to use the 256-bit wide YMM registers. Since serpent does not use
table look-ups, this implementation should be close to two times faster than
the AVX implementation.
Patch adds AVX2/x86-64 implementation of Twofish cipher, requiring 16 parallel
blocks for input (256 bytes). Table look-ups are performed using vpgatherdd
instruction directly from vector registers and thus should be faster than
earlier implementations. Implementation also uses 256-bit wide YMM registers,
which should give additional speed up compared to the AVX implementation.
Patch adds AVX2/x86-64 implementation of Blowfish cipher, requiring 32 parallel
The Kconfig setting for glue helper module is CRYPTO_GLUE_HELPER_X86, but
recent change for aesni_intel used CRYPTO_GLUE_HELPER instead. Patch corrects
this issue.
Cc: kbuild-all@01.org
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Add more optimized XTS code for aesni_intel in 64-bit mode, for smaller stack
usage and boost for speed.
tcrypt results, with Intel i5-2450M:
256-bit key
enc dec
16B 0.98x 0.99x
64B 0.64x 0.63x
256B 1.29x 1.32x
1024B 1.54x 1.58x
8192B 1.57x 1.60x
512-bit key
enc dec
16B 0.98x 0.99x
64B 0.60x 0.59x
256B 1.24x 1.25x
1024B 1.39x 1.42x
8192B 1.38x 1.42x
I chose not to optimize smaller than block size of 256 bytes, since XTS is
practically always used with data blocks of size 512 bytes. This is why
performance is reduced in tcrypt for 64 byte long blocks.
Cc: Huang Ying <ying.huang@intel.com>
Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI.
This work is based on Tom St Denis' earlier patch,
http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2
Cc: Tom St Denis <tstdenis@elliptictech.com>
Without these, kernel log shows:
[ 5.984881] alg: No test for cipher_null (cipher_null-generic)
[ 5.985096] alg: No test for ecb(cipher_null) (ecb-cipher_null)
[ 5.985170] alg: No test for compress_null (compress_null-generic)
[ 5.985297] alg: No test for digest_null (digest_null-generic)
If the gcm cipher used by rfc4543 does not complete request immediately,
the authentication tag is not copied to destination buffer. Patch adds
correct async logic for this case.
The GMAC code assumes that dst==src, which causes problems when trying to add
rfc4543(gcm(aes)) test vectors.
So fix this code to work when source and destination buffer are different.
SSSE3, AVX or AVX2 instructions.
We added glue code and config options to create crypto
module that uses SSE/AVX/AVX2 optimized SHA512 x86_64 assembly routines.
Other SHA512 routines may need to use the generic routine when
FPU is not available.
module that uses SSE/AVX/AVX2 optimized SHA256 x86_64 assembly routines.
Pull crypto fix from Herbert Xu:
"This fixes a kernel memory leak in the algif interface"
crypto: algif - suppress sending source address information in recvmsg
Per X.509 spec in 4.2.1.1 section, the structure of Authority Key
Identifier Extension is:
AuthorityKeyIdentifier ::= SEQUENCE {
keyIdentifier [0] KeyIdentifier OPTIONAL,
authorityCertIssuer [1] GeneralNames OPTIONAL,
authorityCertSerialNumber [2] CertificateSerialNumber OPTIONAL }
KeyIdentifier ::= OCTET STRING
When a certificate also provides
authorityCertIssuer and authorityCertSerialNumber then the length of
AuthorityKeyIdentifier SEQUENCE is likely to long form format.
e.g.
The example certificate demos/tunala/A-server.pem in openssl source:
X509v3 Authority Key Identifier:
keyid:49:FB:45:72:12:C4:CC:E1:45:A1:D3:08:9E:95:C4:2C:6D:55:3F:17
DirName:/C=NZ/L=Wellington/O=Really Irresponsible Authorisation Authority (RIAA)/OU=Cert-stamping/CN=Jackov al-Trades/emailAddress=none@fake.domain
serial:00
Current parsing rule of OID_authorityKeyIdentifier only take care the
short form format, it causes load certificate to modsign_keyring fail:
[ 12.061147] X.509: Extension: 47
[ 12.075121] MODSIGN: Problem loading in-kernel X.509 certificate (-74)
So, this patch add the parsing rule for support long form format against
Authority Key Identifier.
v3:
Changed the size check in "Short Form length" case, we allow v[3] smaller
then (vlen - 4) because authorityCertIssuer and authorityCertSerialNumber
are also possible attach in AuthorityKeyIdentifier sequence.
v2:
- Removed comma from author's name.
- Moved 'Short Form length' comment inside the if-body.
- Changed the type of sub to size_t.
- Use ASN1_INDEFINITE_LENGTH rather than writing 0x80 and 127.
- Moved the key_len's value assignment before alter v.
- Fixed the typo of octets.
- Add 2 to v before entering the loop for calculate the length.
- Removed the comment of check vlen.
Cc: Josh Boyer <jwboyer@redhat.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Chun-Yi Lee <jlee@suse.com>
The current code does not set the msg_namelen member to 0 and therefore
makes net/socket.c leak the local sockaddr_storage variable to userland
-- 128 bytes of kernel stack memory. Fix that.
Cc: <stable@vger.kernel.org> # 2.6.38
Pull crypto fixes from Herbert Xu:
"This fixes a GCM bug that breaks IPsec and a compile problem in
ux500."
crypto: ux500 - add missing comma
crypto: gcm - fix assumption that assoc has one segment
Other SHA256 routine may need to use the generic routine when
rfc4543(gcm(*)) code for GMAC assumes that assoc scatterlist always contains
only one segment and only makes use of this first segment. However ipsec passes
assoc with three segments when using 'extended sequence number' thus in this
case rfc4543(gcm(*)) fails to function correctly. Patch fixes this issue.
Reported-by: Chaoxing Lin <Chaoxing.Lin@ultra-3eti.com>
Tested-by: Chaoxing Lin <Chaoxing.Lin@ultra-3eti.com>
Cc: stable@vger.kernel.org
There is no need to modify the netlink dispatch table at runtime and
making it const even makes the resulting object file slightly smaller.
Cc: Steffen Klassert <steffen.klassert@secunet.com>
git://github.com/markus-oberhumer/linux
Pull LZO compression update from Markus Oberhumer:
"Summary:
Update the Linux kernel LZO compression and decompression code to the
current upstream version which features significant performance
improvements on modern machines.
Some *synthetic* benchmarks:
x86_64 (Sandy Bridge), gcc-4.6 -O3, Silesia test corpus, 256 kB block-size:
compression speed decompression speed
LZO-2005 : 150 MB/sec 468 MB/sec
LZO-2012 : 434 MB/sec 1210 MB/sec
i386 (Sandy Bridge), gcc-4.6 -O3, Silesia test corpus, 256 kB block-size:
LZO-2005 : 143 MB/sec 409 MB/sec
LZO-2012 : 372 MB/sec 1121 MB/sec
armv7 (Cortex-A9), Linaro gcc-4.6 -O3, Silesia test corpus, 256 kB block-size:
LZO-2005 : 27 MB/sec 84 MB/sec
LZO-2012 : 44 MB/sec 117 MB/sec
**LZO-2013-UA : 47 MB/sec 167 MB/sec
Legend:
LZO-2005 : LZO version in current 3.8 kernel (which is based on
the LZO 2.02 release from 2005)
LZO-2012 : updated LZO version available in linux-next
**LZO-2013-UA : updated LZO version available in linux-next plus experimental
ARM Unaligned Access patch. This needs approval
from some ARM maintainer ist NOT YET INCLUDED."
Andrew Morton <akpm@linux-foundation.org> acks it and says:
"There's a new LZ4 on the block which is even faster than the sped-up
LZO, but various filesystems and things use LZO"
* tag 'lzo-update-signature-20130226' of git://github.com/markus-oberhumer/linux:
crypto: testmgr - update LZO compression test vectors
lib/lzo: Update LZO compression to current upstream version
lib/lzo: Rename lzo1x_decompress.c to lzo1x_decompress_safe.c
