path: root/crypto
2018-02-16crypto: poly1305 - remove ->setkey() methodEric Biggers
commit a16e772e664b9a261424107784804cffc8894977 upstream. Since Poly1305 requires a nonce per invocation, the Linux kernel implementations of Poly1305 don't use the crypto API's keying mechanism and instead expect the key and nonce as the first 32 bytes of the data. But ->setkey() is still defined as a stub returning an error code. This prevents Poly1305 from being used through AF_ALG and will also break it completely once we start enforcing that all crypto API users (not just AF_ALG) call ->setkey() if present. Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16crypto: cryptd - pass through absence of ->setkey()Eric Biggers
commit 841a3ff329713f796a63356fef6e2f72e4a3f6a3 upstream. When the cryptd template is used to wrap an unkeyed hash algorithm, don't install a ->setkey() method to the cryptd instance. This change is necessary for cryptd to keep working with unkeyed hash algorithms once we start enforcing that ->setkey() is called when present. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16crypto: hash - introduce crypto_hash_alg_has_setkey()Eric Biggers
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream. Templates that use an shash spawn can use crypto_shash_alg_has_setkey() to determine whether the underlying algorithm requires a key or not. But there was no corresponding function for ahash spawns. Add it. Note that the new function actually has to support both shash and ahash algorithms, since the ahash API can be used with either. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16crypto: tcrypt - fix S/G table for test_aead_speed()Robert Baronescu
commit 5c6ac1d4f8fbdbed65dbeb8cf149d736409d16a1 upstream. In case buffer length is a multiple of PAGE_SIZE, the S/G table is incorrectly generated. Fix this by handling buflen = k * PAGE_SIZE separately. Signed-off-by: Robert Baronescu <robert.baronescu@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03crypto: af_alg - whitelist mask and typeStephan Mueller
commit bb30b8848c85e18ca7e371d0a869e94b3e383bdf upstream. The user space interface allows specifying the type and mask field used to allocate the cipher. Only a subset of the possible flags are intended for user space. Therefore, white-list the allowed flags. In case the user space caller uses at least one non-allowed flag, EINVAL is returned. Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17crypto: algapi - fix NULL dereference in crypto_remove_spawns()Eric Biggers
commit 9a00674213a3f00394f4e3221b88f2d21fc05789 upstream. syzkaller triggered a NULL pointer dereference in crypto_remove_spawns() via a program that repeatedly and concurrently requests AEADs "authenc(cmac(des3_ede-asm),pcbc-aes-aesni)" and hashes "cmac(des3_ede)" through AF_ALG, where the hashes are requested as "untested" (CRYPTO_ALG_TESTED is set in ->salg_mask but clear in ->salg_feat; this causes the template to be instantiated for every request). Although AF_ALG users really shouldn't be able to request an "untested" algorithm, the NULL pointer dereference is actually caused by a longstanding race condition where crypto_remove_spawns() can encounter an instance which has had spawn(s) "grabbed" but hasn't yet been registered, resulting in ->cra_users still being NULL. We probably should properly initialize ->cra_users earlier, but that would require updating many templates individually. For now just fix the bug in a simple way that can easily be backported: make crypto_remove_spawns() treat a NULL ->cra_users list as empty. Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10crypto: pcrypt - fix freeing pcrypt instancesEric Biggers
commit d76c68109f37cb85b243a1cf0f40313afd2bae68 upstream. pcrypt is using the old way of freeing instances, where the ->free() method specified in the 'struct crypto_template' is passed a pointer to the 'struct crypto_instance'. But the crypto_instance is being kfree()'d directly, which is incorrect because the memory was actually allocated as an aead_instance, which contains the crypto_instance at a nonzero offset. Thus, the wrong pointer was being kfree()'d. Fix it by switching to the new way to free aead_instance's where the ->free() method is specified in the aead_instance itself. Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: 0496f56065e0 ("crypto: pcrypt - Add support for new AEAD interface") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10crypto: chacha20poly1305 - validate the digest sizeEric Biggers
commit e57121d08c38dabec15cf3e1e2ad46721af30cae upstream. If the rfc7539 template was instantiated with a hash algorithm with digest size larger than 16 bytes (POLY1305_DIGEST_SIZE), then the digest overran the 'tag' buffer in 'struct chachapoly_req_ctx', corrupting the subsequent memory, including 'cryptlen'. This caused a crash during crypto_skcipher_decrypt(). Fix it by, when instantiating the template, requiring that the underlying hash algorithm has the digest size expected for Poly1305. Reproducer: #include <linux/if_alg.h> #include <sys/socket.h> #include <unistd.h> int main() { int algfd, reqfd; struct sockaddr_alg addr = { .salg_type = "aead", .salg_name = "rfc7539(chacha20,sha256)", }; unsigned char buf[32] = { 0 }; algfd = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(algfd, (void *)&addr, sizeof(addr)); setsockopt(algfd, SOL_ALG, ALG_SET_KEY, buf, sizeof(buf)); reqfd = accept(algfd, 0, 0); write(reqfd, buf, 16); read(reqfd, buf, 16); } Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: 71ebc4d1b27d ("crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02crypto: mcryptd - protect the per-CPU queue with a lockSebastian Andrzej Siewior
commit 9abffc6f2efe46c3564c04312e52e07622d40e51 upstream. mcryptd_enqueue_request() grabs the per-CPU queue struct and protects access to it with disabled preemption. Then it schedules a worker on the same CPU. The worker in mcryptd_queue_worker() guards access to the same per-CPU variable with disabled preemption. If we take CPU-hotplug into account then it is possible that between queue_work_on() and the actual invocation of the worker the CPU goes down and the worker will be scheduled on _another_ CPU. And here the preempt_disable() protection does not work anymore. The easiest thing is to add a spin_lock() to guard access to the list. Another detail: mcryptd_queue_worker() is not processing more than MCRYPTD_BATCH invocation in a row. If there are still items left, then it will invoke queue_work() to proceed with more later. *I* would suggest to simply drop that check because it does not use a system workqueue and the workqueue is already marked as "CPU_INTENSIVE". And if preemption is required then the scheduler should do it. However if queue_work() is used then the work item is marked as CPU unbound. That means it will try to run on the local CPU but it may run on another CPU as well. Especially with CONFIG_DEBUG_WQ_FORCE_RR_CPU=y. Again, the preempt_disable() won't work here but lock which was introduced will help. In order to keep work-item on the local CPU (and avoid RR) I changed it to queue_work_on(). Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20crypto: tcrypt - fix buffer lengths in test_aead_speed()Robert Baronescu
[ Upstream commit 7aacbfcb331ceff3ac43096d563a1f93ed46e35e ] Fix the way the length of the buffers used for encryption / decryption are computed. For e.g. in case of encryption, input buffer does not contain an authentication tag. Signed-off-by: Robert Baronescu <robert.baronescu@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20crypto: salsa20 - fix blkcipher_walk API usageEric Biggers
commit ecaaab5649781c5a0effdaf298a925063020500e upstream. When asked to encrypt or decrypt 0 bytes, both the generic and x86 implementations of Salsa20 crash in blkcipher_walk_done(), either when doing 'kfree(walk->buffer)' or 'free_page((unsigned long)walk->page)', because walk->buffer and walk->page have not been initialized. The bug is that Salsa20 is calling blkcipher_walk_done() even when nothing is in 'walk.nbytes'. But blkcipher_walk_done() is only meant to be called when a nonzero number of bytes have been provided. The broken code is part of an optimization that tries to make only one call to salsa20_encrypt_bytes() to process inputs that are not evenly divisible by 64 bytes. To fix the bug, just remove this "optimization" and use the blkcipher_walk API the same way all the other users do. Reproducer: #include <linux/if_alg.h> #include <sys/socket.h> #include <unistd.h> int main() { int algfd, reqfd; struct sockaddr_alg addr = { .salg_type = "skcipher", .salg_name = "salsa20", }; char key[16] = { 0 }; algfd = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(algfd, (void *)&addr, sizeof(addr)); reqfd = accept(algfd, 0, 0); setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key)); read(reqfd, key, sizeof(key)); } Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: eb6f13eb9f81 ("[CRYPTO] salsa20_generic: Fix multi-page processing") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20crypto: hmac - require that the underlying hash algorithm is unkeyedEric Biggers
commit af3ff8045bbf3e32f1a448542e73abb4c8ceb6f1 upstream. Because the HMAC template didn't check that its underlying hash algorithm is unkeyed, trying to use "hmac(hmac(sha3-512-generic))" through AF_ALG or through KEYCTL_DH_COMPUTE resulted in the inner HMAC being used without having been keyed, resulting in sha3_update() being called without sha3_init(), causing a stack buffer overflow. This is a very old bug, but it seems to have only started causing real problems when SHA-3 support was added (requires CONFIG_CRYPTO_SHA3) because the innermost hash's state is ->import()ed from a zeroed buffer, and it just so happens that other hash algorithms are fine with that, but SHA-3 is not. However, there could be arch or hardware-dependent hash algorithms also affected; I couldn't test everything. Fix the bug by introducing a function crypto_shash_alg_has_setkey() which tests whether a shash algorithm is keyed. Then update the HMAC template to require that its underlying hash algorithm is unkeyed. Here is a reproducer: #include <linux/if_alg.h> #include <sys/socket.h> int main() { int algfd; struct sockaddr_alg addr = { .salg_type = "hash", .salg_name = "hmac(hmac(sha3-512-generic))", }; char key[4096] = { 0 }; algfd = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(algfd, (const struct sockaddr *)&addr, sizeof(addr)); setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key)); } Here was the KASAN report from syzbot: BUG: KASAN: stack-out-of-bounds in memcpy include/linux/string.h:341 [inline] BUG: KASAN: stack-out-of-bounds in sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161 Write of size 4096 at addr ffff8801cca07c40 by task syzkaller076574/3044 CPU: 1 PID: 3044 Comm: syzkaller076574 Not tainted 4.14.0-mm1+ #25 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:53 print_address_description+0x73/0x250 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x25b/0x340 mm/kasan/report.c:409 check_memory_region_inline mm/kasan/kasan.c:260 [inline] check_memory_region+0x137/0x190 mm/kasan/kasan.c:267 memcpy+0x37/0x50 mm/kasan/kasan.c:303 memcpy include/linux/string.h:341 [inline] sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161 crypto_shash_update+0xcb/0x220 crypto/shash.c:109 shash_finup_unaligned+0x2a/0x60 crypto/shash.c:151 crypto_shash_finup+0xc4/0x120 crypto/shash.c:165 hmac_finup+0x182/0x330 crypto/hmac.c:152 crypto_shash_finup+0xc4/0x120 crypto/shash.c:165 shash_digest_unaligned+0x9e/0xd0 crypto/shash.c:172 crypto_shash_digest+0xc4/0x120 crypto/shash.c:186 hmac_setkey+0x36a/0x690 crypto/hmac.c:66 crypto_shash_setkey+0xad/0x190 crypto/shash.c:64 shash_async_setkey+0x47/0x60 crypto/shash.c:207 crypto_ahash_setkey+0xaf/0x180 crypto/ahash.c:200 hash_setkey+0x40/0x90 crypto/algif_hash.c:446 alg_setkey crypto/af_alg.c:221 [inline] alg_setsockopt+0x2a1/0x350 crypto/af_alg.c:254 SYSC_setsockopt net/socket.c:1851 [inline] SyS_setsockopt+0x189/0x360 net/socket.c:1830 entry_SYSCALL_64_fastpath+0x1f/0x96 Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-16X.509: reject invalid BIT STRING for subjectPublicKeyEric Biggers
commit 0f30cbea005bd3077bd98cd29277d7fc2699c1da upstream. Adding a specially crafted X.509 certificate whose subjectPublicKey ASN.1 value is zero-length caused x509_extract_key_data() to set the public key size to SIZE_MAX, as it subtracted the nonexistent BIT STRING metadata byte. Then, x509_cert_parse() called kmemdup() with that bogus size, triggering the WARN_ON_ONCE() in kmalloc_slab(). This appears to be harmless, but it still must be fixed since WARNs are never supposed to be user-triggerable. Fix it by updating x509_cert_parse() to validate that the value has a BIT STRING metadata byte, and that the byte is 0 which indicates that the number of bits in the bitstring is a multiple of 8. It would be nice to handle the metadata byte in asn1_ber_decoder() instead. But that would be tricky because in the general case a BIT STRING could be implicitly tagged, and/or could legitimately have a length that is not a whole number of bytes. Here was the WARN (cleaned up slightly): WARNING: CPU: 1 PID: 202 at mm/slab_common.c:971 kmalloc_slab+0x5d/0x70 mm/slab_common.c:971 Modules linked in: CPU: 1 PID: 202 Comm: keyctl Tainted: G B 4.14.0-09238-g1d3b78bbc6e9 #26 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014 task: ffff880033014180 task.stack: ffff8800305c8000 Call Trace: __do_kmalloc mm/slab.c:3706 [inline] __kmalloc_track_caller+0x22/0x2e0 mm/slab.c:3726 kmemdup+0x17/0x40 mm/util.c:118 kmemdup include/linux/string.h:414 [inline] x509_cert_parse+0x2cb/0x620 crypto/asymmetric_keys/x509_cert_parser.c:106 x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174 asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388 key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0x96 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21Revert "crypto: xts - Add ECB dependency"Sasha Levin
This reverts commit 6145171a6bc0abdc3eca7a4b795ede467d2ba569. The commit fixes a bug that was only introduced in 4.10, thus is irrelevant for <=4.9. Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15PKCS#7: fix unitialized boolean 'want'Colin Ian King
commit 06aae592425701851e02bb850cb9f4997f0ae163 upstream. The boolean want is not initialized and hence garbage. The default should be false (later it is only set to true on tne sinfo->authattrs check). Found with static analysis using CoverityScan Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27pkcs7: Prevent NULL pointer dereference, since sinfo is not always set.Eric Sesterhenn
commit 68a1fdbbf8bd3378325e45c19e167a165f9ffc3a upstream. The ASN.1 parser does not necessarily set the sinfo field, this patch prevents a NULL pointer dereference on broken input. Fixes: 99db44350672 ("PKCS#7: Appropriately restrict authenticated attributes and content type") Signed-off-by: Eric Sesterhenn <eric.sesterhenn@x41-dsec.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21crypto: xts - Add ECB dependencyMilan Broz
[ Upstream commit 12cb3a1c4184f891d965d1f39f8cfcc9ef617647 ] Since the commit f1c131b45410a202eb45cc55980a7a9e4e4b4f40 crypto: xts - Convert to skcipher the XTS mode is based on ECB, so the mode must select ECB otherwise it can fail to initialize. Signed-off-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18crypto: shash - Fix zero-length shash ahash digest crashHerbert Xu
commit b61907bb42409adf9b3120f741af7c57dd7e3db2 upstream. The shash ahash digest adaptor function may crash if given a zero-length input together with a null SG list. This is because it tries to read the SG list before looking at the length. This patch fixes it by checking the length first. Reported-by: Stephan Müller<smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Stephan Müller <smueller@chronox.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27crypto: AF_ALG - remove SGL terminator indicator when chainingStephan Mueller
Fixed differently upstream as commit 2d97591ef43d ("crypto: af_alg - consolidation of duplicate code") The SGL is MAX_SGL_ENTS + 1 in size. The last SG entry is used for the chaining and is properly updated with the sg_chain invocation. During the filling-in of the initial SG entries, sg_mark_end is called for each SG entry. This is appropriate as long as no additional SGL is chained with the current SGL. However, when a new SGL is chained and the last SG entry is updated with sg_chain, the last but one entry still contains the end marker from the sg_mark_end. This end marker must be removed as otherwise a walk of the chained SGLs will cause a NULL pointer dereference at the last but one SG entry, because sg_next will return NULL. The patch only applies to all kernels up to and including 4.13. The patch 2d97591ef43d0587be22ad1b0d758d6df4999a0b added to 4.14-rc1 introduced a complete new code base which addresses this bug in a different way. Yet, that patch is too invasive for stable kernels and was therefore not marked for stable. Fixes: 8ff590903d5fc ("crypto: algif_skcipher - User-space interface for skcipher operations") Signed-off-by: Stephan Mueller <smueller@chronox.de> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07crypto: algif_skcipher - only call put_page on referenced and used pagesStephan Mueller
commit 445a582738de6802669aeed9c33ca406c23c3b1f upstream. For asynchronous operation, SGs are allocated without a page mapped to them or with a page that is not used (ref-counted). If the SGL is freed, the code must only call put_page for an SG if there was a page assigned and ref-counted in the first place. This fixes a kernel crash when using io_submit with more than one iocb using the sendmsg and sendpage (vmsplice/splice) interface. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06crypto: authencesn - Fix digest_null crashHerbert Xu
commit 41cdf7a45389e01991ee31e3301ed83cb3e3f7dc upstream. When authencesn is used together with digest_null a crash will occur on the decrypt path. This is because normally we perform a special setup to preserve the ESN, but this is skipped if there is no authentication. However, on the post-authentication path it always expects the preservation to be in place, thus causing a crash when digest_null is used. This patch fixes this by also skipping the post-processing when there is no authentication. Fixes: 104880a6b470 ("crypto: authencesn - Convert to new AEAD...") Reported-by: Jan Tluka <jtluka@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14crypto: gcm - wait for crypto op not signal safeGilad Ben-Yossef
commit f3ad587070d6bd961ab942b3fd7a85d00dfc934b upstream. crypto_gcm_setkey() was using wait_for_completion_interruptible() to wait for completion of async crypto op but if a signal occurs it may return before DMA ops of HW crypto provider finish, thus corrupting the data buffer that is kfree'ed in this case. Resolve this by using wait_for_completion() instead. Reported-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20crypto: algif_aead - Require setkey before accept(2)Stephan Mueller
commit 2a2a251f110576b1d89efbd0662677d7e7db21a8 upstream. Some cipher implementations will crash if you try to use them without calling setkey first. This patch adds a check so that the accept(2) call will fail with -ENOKEY if setkey hasn't been done on the socket yet. Fixes: 400c40cf78da ("crypto: algif - add AEAD support") Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02crypto: testmgr - fix out of bound read in __test_aead()Jerome Marchand
commit abfa7f4357e3640fdee87dfc276fd0f379fb5ae6 upstream. __test_aead() reads MAX_IVLEN bytes from template[i].iv, but the actual length of the initialisation vector can be shorter. The length of the IV is already calculated earlier in the function. Let's just reuses that. Also the IV length is currently calculated several time for no reason. Let's fix that too. This fix an out-of-bound error detected by KASan. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21crypto: ahash - Fix EINPROGRESS notification callbackHerbert Xu
commit ef0579b64e93188710d48667cb5e014926af9f1b upstream. The ahash API modifies the request's callback function in order to clean up after itself in some corner cases (unaligned final and missing finup). When the request is complete ahash will restore the original callback and everything is fine. However, when the request gets an EBUSY on a full queue, an EINPROGRESS callback is made while the request is still ongoing. In this case the ahash API will incorrectly call its own callback. This patch fixes the problem by creating a temporary request object on the stack which is used to relay EINPROGRESS back to the original completion function. This patch also adds code to preserve the original flags value. Fixes: ab6bf4e5e5e4 ("crypto: hash - Fix the pointer voodoo in...") Reported-by: Sabrina Dubroca <sd@queasysnail.net> Tested-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30crypto: algif_hash - avoid zero-sized arrayJiri Slaby
commit 6207119444595d287b1e9e83a2066c17209698f3 upstream. With this reproducer: struct sockaddr_alg alg = { .salg_family = 0x26, .salg_type = "hash", .salg_feat = 0xf, .salg_mask = 0x5, .salg_name = "digest_null", }; int sock, sock2; sock = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(sock, (struct sockaddr *)&alg, sizeof(alg)); sock2 = accept(sock, NULL, NULL); setsockopt(sock, SOL_ALG, ALG_SET_KEY, "\x9b\xca", 2); accept(sock2, NULL, NULL); ==== 8< ======== 8< ======== 8< ======== 8< ==== one can immediatelly see an UBSAN warning: UBSAN: Undefined behaviour in crypto/algif_hash.c:187:7 variable length array bound value 0 <= 0 CPU: 0 PID: 15949 Comm: syz-executor Tainted: G E 4.4.30-0-default #1 ... Call Trace: ... [<ffffffff81d598fd>] ? __ubsan_handle_vla_bound_not_positive+0x13d/0x188 [<ffffffff81d597c0>] ? __ubsan_handle_out_of_bounds+0x1bc/0x1bc [<ffffffffa0e2204d>] ? hash_accept+0x5bd/0x7d0 [algif_hash] [<ffffffffa0e2293f>] ? hash_accept_nokey+0x3f/0x51 [algif_hash] [<ffffffffa0e206b0>] ? hash_accept_parent_nokey+0x4a0/0x4a0 [algif_hash] [<ffffffff8235c42b>] ? SyS_accept+0x2b/0x40 It is a correct warning, as hash state is propagated to accept as zero, but creating a zero-length variable array is not allowed in C. Fix this as proposed by Herbert -- do "?: 1" on that site. No sizeof or similar happens in the code there, so we just allocate one byte even though we do not use the array. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> (maintainer:CRYPTO API) Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-26crypto: mcryptd - Fix load failureWang, Rui Y
commit ddef482420b1ba8ec45e6123a7e8d3f67b21e5e3 upstream. mcryptd_create_hash() fails by returning -EINVAL, causing any driver using mcryptd to fail to load. It is because it needs to set its statesize properly. Signed-off-by: Rui Wang <rui.y.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-26crypto: cryptd - Assign statesize properlyWang, Rui Y
commit 1a07834024dfca5c4bed5de8f8714306e0a11836 upstream. cryptd_create_hash() fails by returning -EINVAL. It is because after 8996eafdc ("crypto: ahash - ensure statesize is non-zero") all ahash drivers must have a non-zero statesize. This patch fixes the problem by properly assigning the statesize. Signed-off-by: Rui Wang <rui.y.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-18crypto: improve gcc optimization flags for serpent and wp512Arnd Bergmann
commit 7d6e9105026788c497f0ab32fa16c82f4ab5ff61 upstream. An ancient gcc bug (first reported in 2003) has apparently resurfaced on MIPS, where kernelci.org reports an overly large stack frame in the whirlpool hash algorithm: crypto/wp512.c:987:1: warning: the frame size of 1112 bytes is larger than 1024 bytes [-Wframe-larger-than=] With some testing in different configurations, I'm seeing large variations in stack frames size up to 1500 bytes for what should have around 300 bytes at most. I also checked the reference implementation, which is essentially the same code but also comes with some test and benchmarking infrastructure. It seems that recent compiler versions on at least arm, arm64 and powerpc have a partial fix for this problem, but enabling "-fsched-pressure", but even with that fix they suffer from the issue to a certain degree. Some testing on arm64 shows that the time needed to hash a given amount of data is roughly proportional to the stack frame size here, which makes sense given that the wp512 implementation is doing lots of loads for table lookups, and the problem with the overly large stack is a result of doing a lot more loads and stores for spilled registers (as seen from inspecting the object code). Disabling -fschedule-insns consistently fixes the problem for wp512, in my collection of cross-compilers, the results are consistently better or identical when comparing the stack sizes in this function, though some architectures (notable x86) have schedule-insns disabled by default. The four columns are: default: -O2 press: -O2 -fsched-pressure nopress: -O2 -fschedule-insns -fno-sched-pressure nosched: -O2 -no-schedule-insns (disables sched-pressure) default press nopress nosched alpha-linux-gcc-4.9.3 1136 848 1136 176 am33_2.0-linux-gcc-4.9.3 2100 2076 2100 2104 arm-linux-gnueabi-gcc-4.9.3 848 848 1048 352 cris-linux-gcc-4.9.3 272 272 272 272 frv-linux-gcc-4.9.3 1128 1000 1128 280 hppa64-linux-gcc-4.9.3 1128 336 1128 184 hppa-linux-gcc-4.9.3 644 308 644 276 i386-linux-gcc-4.9.3 352 352 352 352 m32r-linux-gcc-4.9.3 720 656 720 268 microblaze-linux-gcc-4.9.3 1108 604 1108 256 mips64-linux-gcc-4.9.3 1328 592 1328 208 mips-linux-gcc-4.9.3 1096 624 1096 240 powerpc64-linux-gcc-4.9.3 1088 432 1088 160 powerpc-linux-gcc-4.9.3 1080 584 1080 224 s390-linux-gcc-4.9.3 456 456 624 360 sh3-linux-gcc-4.9.3 292 292 292 292 sparc64-linux-gcc-4.9.3 992 240 992 208 sparc-linux-gcc-4.9.3 680 592 680 312 x86_64-linux-gcc-4.9.3 224 240 272 224 xtensa-linux-gcc-4.9.3 1152 704 1152 304 aarch64-linux-gcc-7.0.0 224 224 1104 208 arm-linux-gnueabi-gcc-7.0.1 824 824 1048 352 mips-linux-gcc-7.0.0 1120 648 1120 272 x86_64-linux-gcc-7.0.1 240 240 304 240 arm-linux-gnueabi-gcc-4.4.7 840 392 arm-linux-gnueabi-gcc-4.5.4 784 728 784 320 arm-linux-gnueabi-gcc-4.6.4 736 728 736 304 arm-linux-gnueabi-gcc-4.7.4 944 784 944 352 arm-linux-gnueabi-gcc-4.8.5 464 464 760 352 arm-linux-gnueabi-gcc-4.9.3 848 848 1048 352 arm-linux-gnueabi-gcc-5.3.1 824 824 1064 336 arm-linux-gnueabi-gcc-6.1.1 808 808 1056 344 arm-linux-gnueabi-gcc-7.0.1 824 824 1048 352 Trying the same test for serpent-generic, the picture is a bit different, and while -fno-schedule-insns is generally better here than the default, -fsched-pressure wins overall, so I picked that instead. default press nopress nosched alpha-linux-gcc-4.9.3 1392 864 1392 960 am33_2.0-linux-gcc-4.9.3 536 524 536 528 arm-linux-gnueabi-gcc-4.9.3 552 552 776 536 cris-linux-gcc-4.9.3 528 528 528 528 frv-linux-gcc-4.9.3 536 400 536 504 hppa64-linux-gcc-4.9.3 524 208 524 480 hppa-linux-gcc-4.9.3 768 472 768 508 i386-linux-gcc-4.9.3 564 564 564 564 m32r-linux-gcc-4.9.3 712 576 712 532 microblaze-linux-gcc-4.9.3 724 392 724 512 mips64-linux-gcc-4.9.3 720 384 720 496 mips-linux-gcc-4.9.3 728 384 728 496 powerpc64-linux-gcc-4.9.3 704 304 704 480 powerpc-linux-gcc-4.9.3 704 296 704 480 s390-linux-gcc-4.9.3 560 560 592 536 sh3-linux-gcc-4.9.3 540 540 540 540 sparc64-linux-gcc-4.9.3 544 352 544 496 sparc-linux-gcc-4.9.3 544 344 544 496 x86_64-linux-gcc-4.9.3 528 536 576 528 xtensa-linux-gcc-4.9.3 752 544 752 544 aarch64-linux-gcc-7.0.0 432 432 656 480 arm-linux-gnueabi-gcc-7.0.1 616 616 808 536 mips-linux-gcc-7.0.0 720 464 720 488 x86_64-linux-gcc-7.0.1 536 528 600 536 arm-linux-gnueabi-gcc-4.4.7 592 440 arm-linux-gnueabi-gcc-4.5.4 776 448 776 544 arm-linux-gnueabi-gcc-4.6.4 776 448 776 544 arm-linux-gnueabi-gcc-4.7.4 768 448 768 544 arm-linux-gnueabi-gcc-4.8.5 488 488 776 544 arm-linux-gnueabi-gcc-4.9.3 552 552 776 536 arm-linux-gnueabi-gcc-5.3.1 552 552 776 536 arm-linux-gnueabi-gcc-6.1.1 560 560 776 536 arm-linux-gnueabi-gcc-7.0.1 616 616 808 536 I did not do any runtime tests with serpent, so it is possible that stack frame size does not directly correlate with runtime performance here and it actually makes things worse, but it's more likely to help here, and the reduced stack frame size is probably enough reason to apply the patch, especially given that the crypto code is often used in deep call chains. Link: https://kernelci.org/build/id/58797d7559b5149efdf6c3a9/logs/ Link: http://www.larc.usp.br/~pbarreto/WhirlpoolPage.html Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=11488 Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=79149 Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12crypto: testmgr - Pad aes_ccm_enc_tv_template vectorLaura Abbott
commit 1c68bb0f62bf8de8bb30123ea840d5168f25abea upstream. Running with KASAN and crypto tests currently gives BUG: KASAN: global-out-of-bounds in __test_aead+0x9d9/0x2200 at addr ffffffff8212fca0 Read of size 16 by task cryptomgr_test/1107 Address belongs to variable 0xffffffff8212fca0 CPU: 0 PID: 1107 Comm: cryptomgr_test Not tainted 4.10.0+ #45 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014 Call Trace: dump_stack+0x63/0x8a kasan_report.part.1+0x4a7/0x4e0 ? __test_aead+0x9d9/0x2200 ? crypto_ccm_init_crypt+0x218/0x3c0 [ccm] kasan_report+0x20/0x30 check_memory_region+0x13c/0x1a0 memcpy+0x23/0x50 __test_aead+0x9d9/0x2200 ? kasan_unpoison_shadow+0x35/0x50 ? alg_test_akcipher+0xf0/0xf0 ? crypto_skcipher_init_tfm+0x2e3/0x310 ? crypto_spawn_tfm2+0x37/0x60 ? crypto_ccm_init_tfm+0xa9/0xd0 [ccm] ? crypto_aead_init_tfm+0x7b/0x90 ? crypto_alloc_tfm+0xc4/0x190 test_aead+0x28/0xc0 alg_test_aead+0x54/0xd0 alg_test+0x1eb/0x3d0 ? alg_find_test+0x90/0x90 ? __sched_text_start+0x8/0x8 ? __wake_up_common+0x70/0xb0 cryptomgr_test+0x4d/0x60 kthread+0x173/0x1c0 ? crypto_acomp_scomp_free_ctx+0x60/0x60 ? kthread_create_on_node+0xa0/0xa0 ret_from_fork+0x2c/0x40 Memory state around the buggy address: ffffffff8212fb80: 00 00 00 00 01 fa fa fa fa fa fa fa 00 00 00 00 ffffffff8212fc00: 00 01 fa fa fa fa fa fa 00 00 00 00 01 fa fa fa >ffffffff8212fc80: fa fa fa fa 00 05 fa fa fa fa fa fa 00 00 00 00 ^ ffffffff8212fd00: 01 fa fa fa fa fa fa fa 00 00 00 00 01 fa fa fa ffffffff8212fd80: fa fa fa fa 00 00 00 00 00 05 fa fa fa fa fa fa This always happens on the same IV which is less than 16 bytes. Per Ard, "CCM IVs are 16 bytes, but due to the way they are constructed internally, the final couple of bytes of input IV are dont-cares. Apparently, we do read all 16 bytes, which triggers the KASAN errors." Fix this by padding the IV with null bytes to be at least 16 bytes. Fixes: 0bc5a6c5c79a ("crypto: testmgr - Disable rfc4309 test and convert test vectors") Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09crypto: api - Clear CRYPTO_ALG_DEAD bit before registering an algSalvatore Benedetto
commit d6040764adcb5cb6de1489422411d701c158bb69 upstream. Make sure CRYPTO_ALG_DEAD bit is cleared before proceeding with the algorithm registration. This fixes qat-dh registration when driver is restarted Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15crypto: rsa - Add Makefile dependencies to fix parallel buildsDavid Michael
commit 57891633eeef60e732e045731cf20e50ee80acb4 upstream. Both asn1 headers are included by rsa_helper.c, so rsa_helper.o should explicitly depend on them. Signed-off-by: David Michael <david.michael@coreos.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15crypto: mcryptd - Check mcryptd algorithm compatibilitytim
commit 48a992727d82cb7db076fa15d372178743b1f4cd upstream. Algorithms not compatible with mcryptd could be spawned by mcryptd with a direct crypto_alloc_tfm invocation using a "mcryptd(alg)" name construct. This causes mcryptd to crash the kernel if an arbitrary "alg" is incompatible and not intended to be used with mcryptd. It is an issue if AF_ALG tries to spawn mcryptd(alg) to expose it externally. But such algorithms must be used internally and not be exposed. We added a check to enforce that only internal algorithms are allowed with mcryptd at the time mcryptd is spawning an algorithm. Link: http://marc.info/?l=linux-crypto-vger&m=148063683310477&w=2 Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31crypto: gcm - Fix IV buffer size in crypto_gcm_setkeyOndrej Mosnáček
commit 50d2e6dc1f83db0563c7d6603967bf9585ce934b upstream. The cipher block size for GCM is 16 bytes, and thus the CTR transform used in crypto_gcm_setkey() will also expect a 16-byte IV. However, the code currently reserves only 8 bytes for the IV, causing an out-of-bounds access in the CTR transform. This patch fixes the issue by setting the size of the IV buffer to 16 bytes. Fixes: 84c911523020 ("[CRYPTO] gcm: Add support for async ciphers") Signed-off-by: Ondrej Mosnacek <omosnacek@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28PKCS#7: Don't require SpcSpOpusInfo in Authenticode pkcs7 signaturesPeter Jones
commit 7ee7014d0eb6bcac679c0bd5fe9ce65bc4325648 upstream. Dave Young reported: > Hi, > > I saw the warning "Missing required AuthAttr" when testing kexec, > known issue? Idea about how to fix it? > > The kernel is latest linus tree plus sevral patches from Toshi to > cleanup io resource structure. > > in function pkcs7_sig_note_set_of_authattrs(): > if (!test_bit(sinfo_has_content_type, &sinfo->aa_set) || > !test_bit(sinfo_has_message_digest, &sinfo->aa_set) || > (ctx->msg->data_type == OID_msIndirectData && > !test_bit(sinfo_has_ms_opus_info, &sinfo->aa_set))) { > pr_warn("Missing required AuthAttr\n"); > return -EBADMSG; > } > > The third condition below is true: > (ctx->msg->data_type == OID_msIndirectData && > !test_bit(sinfo_has_ms_opus_info, &sinfo->aa_set)) > > I signed the kernel with redhat test key like below: > pesign -c 'Red Hat Test Certificate' -i arch/x86/boot/bzImage -o /boot/vmlinuz-4.4.0-rc8+ -s --force And right he is! The Authenticode specification is a paragon amongst technical documents, and has this pearl of wisdom to offer: --------------------------------- Authenticode-Specific SignerInfo UnauthenticatedAttributes Structures The following Authenticode-specific data structures are present in SignerInfo authenticated attributes. SpcSpOpusInfo SpcSpOpusInfo is identified by SPC_SP_OPUS_INFO_OBJID (1.3.6.1.4.1.311.2.1.12) and is defined as follows: SpcSpOpusInfo ::= SEQUENCE { programName [0] EXPLICIT SpcString OPTIONAL, moreInfo [1] EXPLICIT SpcLink OPTIONAL, } --#public-- SpcSpOpusInfo has two fields: programName This field contains the program description: If publisher chooses not to specify a description, the SpcString structure contains a zero-length program name. If the publisher chooses to specify a description, the SpcString structure contains a Unicode string. moreInfo This field is set to an SPCLink structure that contains a URL for a Web site with more information about the signer. The URL is an ASCII string. --------------------------------- Which is to say that this is an optional *unauthenticated* field which may be present in the Authenticated Attribute list. This is not how pkcs7 is supposed to work, so when David implemented this, he didn't appreciate the subtlety the original spec author was working with, and missed the part of the sublime prose that says this Authenticated Attribute is an Unauthenticated Attribute. As a result, the code in question simply takes as given that the Authenticated Attributes should be authenticated. But this one should not, individually. Because it says it's not authenticated. It still has to hash right so the TBS digest is correct. So it is both authenticated and unauthenticated, all at once. Truly, a wonder of technical accomplishment. Additionally, pesign's implementation has always attempted to be compatible with the signatures emitted from contemporary versions of Microsoft's signtool.exe. During the initial implementation, Microsoft signatures always produced the same values for SpcSpOpusInfo - {U"Microsoft Windows", "http://www.microsoft.com"} - without regard to who the signer was. Sometime between Windows 8 and Windows 8.1 they stopped including the field in their signatures altogether, and as such pesign stopped producing them in commits c0c4da6 and d79cb0c, sometime around June of 2012. The theory here is that anything that breaks with pesign signatures would also be breaking with signtool.exe sigs as well, and that'll be a more noticed problem for firmwares parsing it, so it'll get fixed. The fact that we've done exactly this bug in Linux code is first class, grade A irony. So anyway, we should not be checking this field for presence or any particular value: if the field exists, it should be at the right place, but aside from that, as long as the hash matches the field is good. Signed-off-by: Peter Jones <pjones@redhat.com> Tested-by: Dave Young <dyoung@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-22crypto: ghash-generic - move common definitions to a new header fileMarcelo Cerri
commit a397ba829d7f8aff4c90af3704573a28ccd61a59 upstream. Move common values and types used by ghash-generic to a new header file so drivers can directly use ghash-generic as a fallback implementation. Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module") Signed-off-by: Marcelo Cerri <marcelo.cerri@canonical.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-22async_pq_val: fix DMA memory leakJustin Maggard
commit c84750906b4818d4929fbf73a4ae6c113b94f52b upstream. Add missing dmaengine_unmap_put(), so we don't OOM during RAID6 sync. Fixes: 1786b943dad0 ("async_pq_val: convert to dmaengine_unmap_data") Signed-off-by: Justin Maggard <jmaggard@netgear.com> Reviewed-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30crypto: echainiv - Replace chaining with multiplicationHerbert Xu
commit 53a5d5ddccf849dbc27a8c1bba0b43c3a45fb792 upstream. The current implementation uses a global per-cpu array to store data which are used to derive the next IV. This is insecure as the attacker may change the stored data. This patch removes all traces of chaining and replaces it with multiplication of the salt and the sequence number. Fixes: a10f554fa7e0 ("crypto: echainiv - Add encrypted chain IV...") Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30crypto: skcipher - Fix blkcipher walk OOM crashHerbert Xu
commit acdb04d0b36769b3e05990c488dc74d8b7ac8060 upstream. When we need to allocate a temporary blkcipher_walk_next and it fails, the code is supposed to take the slow path of processing the data block by block. However, due to an unrelated change we instead end up dereferencing the NULL pointer. This patch fixes it by moving the unrelated bsize setting out of the way so that we enter the slow path as inteded. Fixes: 7607bd8ff03b ("[CRYPTO] blkcipher: Added blkcipher_walk_virt_block") Reported-by: xiakaixu <xiakaixu@huawei.com> Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24crypto: cryptd - initialize child shash_desc on importArd Biesheuvel
commit 0bd2223594a4dcddc1e34b15774a3a4776f7749e upstream. When calling .import() on a cryptd ahash_request, the structure members that describe the child transform in the shash_desc need to be initialized like they are when calling .init() Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-16crypto: scatterwalk - Fix test in scatterwalk_doneHerbert Xu
commit 5f070e81bee35f1b7bd1477bb223a873ff657803 upstream. When there is more data to be processed, the current test in scatterwalk_done may prevent us from calling pagedone even when we should. In particular, if we're on an SG entry spanning multiple pages where the last page is not a full page, we will incorrectly skip calling pagedone on the second last page. This patch fixes this by adding a separate test for whether we've reached the end of a page. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-16crypto: gcm - Filter out async ghash if necessaryHerbert Xu
commit b30bdfa86431afbafe15284a3ad5ac19b49b88e3 upstream. As it is if you ask for a sync gcm you may actually end up with an async one because it does not filter out async implementations of ghash. This patch fixes this by adding the necessary filter when looking for ghash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-11crypto: user - re-add size check for CRYPTO_MSG_GETALGMathias Krause
commit 055ddaace03580455a7b7dbea8e93d62acee61fc upstream. Commit 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG") accidentally removed the minimum size check for CRYPTO_MSG_GETALG netlink messages. This allows userland to send a truncated CRYPTO_MSG_GETALG message as short as a netlink header only making crypto_report() operate on uninitialized memory by accessing data beyond the end of the netlink message. Fix this be re-adding the minimum required size of CRYPTO_MSG_GETALG messages to the crypto_msg_min[] array. Fixes: 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG") Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-24crypto: public_key: select CRYPTO_AKCIPHERArnd Bergmann
commit bad6a185b4d6f81d0ed2b6e4c16307969f160b95 upstream. In some rare randconfig builds, we can end up with ASYMMETRIC_PUBLIC_KEY_SUBTYPE enabled but CRYPTO_AKCIPHER disabled, which fails to link because of the reference to crypto_alloc_akcipher: crypto/built-in.o: In function `public_key_verify_signature': :(.text+0x110e4): undefined reference to `crypto_alloc_akcipher' This adds a Kconfig 'select' statement to ensure the dependency is always there. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18crypto: testmgr - Use kmalloc memory for RSA inputHerbert Xu
commit df27b26f04ed388ff4cc2b5d8cfdb5d97678816f upstream. As akcipher uses an SG interface, you must not use vmalloc memory as input for it. This patch fixes testmgr to copy the vmalloc test vectors to kmalloc memory before running the test. This patch also removes a superfluous sg_virt call in do_test_rsa. Reported-by: Anatoly Pugachev <matorola@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18crypto: hash - Fix page length clamping in hash walkHerbert Xu
commit 13f4bb78cf6a312bbdec367ba3da044b09bf0e29 upstream. The crypto hash walk code is broken when supplied with an offset greater than or equal to PAGE_SIZE. This patch fixes it by adjusting walk->pg and walk->offset when this happens. Reported-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20PKCS#7: pkcs7_validate_trust(): initialize the _trusted output argumentNicolai Stange
commit e54358915d0a00399c11c2c23ae1be674cba188a upstream. Despite what the DocBook comment to pkcs7_validate_trust() says, the *_trusted argument is never set to false. pkcs7_validate_trust() only positively sets *_trusted upon encountering a trusted PKCS#7 SignedInfo block. This is quite unfortunate since its callers, system_verify_data() for example, depend on pkcs7_validate_trust() clearing *_trusted on non-trust. Indeed, UBSAN splats when attempting to load the uninitialized local variable 'trusted' from system_verify_data() in pkcs7_validate_trust(): UBSAN: Undefined behaviour in crypto/asymmetric_keys/pkcs7_trust.c:194:14 load of value 82 is not a valid value for type '_Bool' [...] Call Trace: [<ffffffff818c4d35>] dump_stack+0xbc/0x117 [<ffffffff818c4c79>] ? _atomic_dec_and_lock+0x169/0x169 [<ffffffff8194113b>] ubsan_epilogue+0xd/0x4e [<ffffffff819419fa>] __ubsan_handle_load_invalid_value+0x111/0x158 [<ffffffff819418e9>] ? val_to_string.constprop.12+0xcf/0xcf [<ffffffff818334a4>] ? x509_request_asymmetric_key+0x114/0x370 [<ffffffff814b83f0>] ? kfree+0x220/0x370 [<ffffffff818312c2>] ? public_key_verify_signature_2+0x32/0x50 [<ffffffff81835e04>] pkcs7_validate_trust+0x524/0x5f0 [<ffffffff813c391a>] system_verify_data+0xca/0x170 [<ffffffff813c3850>] ? top_trace_array+0x9b/0x9b [<ffffffff81510b29>] ? __vfs_read+0x279/0x3d0 [<ffffffff8129372f>] mod_verify_sig+0x1ff/0x290 [...] The implication is that pkcs7_validate_trust() effectively grants trust when it really shouldn't have. Fix this by explicitly setting *_trusted to false at the very beginning of pkcs7_validate_trust(). Signed-off-by: Nicolai Stange <nicstange@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12X.509: Fix leap year handling againDavid Howells
commit ac4cbedfdf55455b4c447f17f0fa027dbf02b2a6 upstream. There are still a couple of minor issues in the X.509 leap year handling: (1) To avoid doing a modulus-by-400 in addition to a modulus-by-100 when determining whether the year is a leap year or not, I divided the year by 100 after doing the modulus-by-100, thereby letting the compiler do one instruction for both, and then did a modulus-by-4. Unfortunately, I then passed the now-modified year value to mktime64() to construct a time value. Since this isn't a fast path and since mktime64() does a bunch of divisions, just condense down to "% 400". It's also easier to read. (2) The default month length for any February where the year doesn't divide by four exactly is obtained from the month_length[] array where the value is 29, not 28. This is fixed by altering the table. Reported-by: Rudolf Polzer <rpolzer@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12crypto: keywrap - memzero the correct memoryDan Carpenter
commit 2b8b28fd232233c22fb61009dd8b0587390d2875 upstream. We're clearing the wrong memory. The memory corruption is likely harmless because we weren't going to use that stack memory again but not zeroing is a potential information leak. Fixes: e28facde3c39 ('crypto: keywrap - add key wrapping block chaining mode') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Do not set MAY_BACKLOG on the async pathHerbert Xu
commit dad41997063723eaf5f77bc2015606a5a9bce320 upstream. The async path cannot use MAY_BACKLOG because it is not meant to block, which is what MAY_BACKLOG does. On the other hand, both the sync and async paths can make use of MAY_SLEEP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
