path: root/crypto
2010-02-17percpu: add __percpu sparse annotations to what's leftTejun Heo
Add __percpu sparse annotations to places which didn't make it in one of the previous patches. All converions are trivial. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Neil Brown <neilb@suse.de>
2010-02-16crypto: aes_generic - Fix checkpatch errorsRichard Hartmann
Signed-off-by: Richard Hartmann <richih.mailinglist@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-16crypto: fcrypt - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: ecb - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: des_generic - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: deflate - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: crypto_null - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: cipher - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: crc32 - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: compress - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: cast6 - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: cast5 - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: camellia - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: authenc - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: api - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: anubis - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: algapi - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: blowfish - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: aead - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: ablkcipher - Fix checkpatch errorsRichard Hartmann
2010-02-05crypto: fix typo in Kconfig help textJiri Kosina
Reported-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-04crypto: pcrypt - call the complete function on errorSteffen Klassert
This fixes three forgotten calls to the complete function in the error case. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-17crypto: md5 - Add export supportMax Vozeler
This patch adds export/import support to md5. The exported type is defined by struct md5_state. This is modeled after the equivalent change to sha1_generic. Signed-off-by: Max Vozeler <max@hinterhof.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-17crypto: gcm - Add RFC4543 wrapper for GCMTobias Brunner
This patch adds the RFC4543 (GMAC) wrapper for GCM similar to the existing RFC4106 wrapper. The main differences between GCM and GMAC are the contents of the AAD and that the plaintext is empty for the latter. Signed-off-by: Tobias Brunner <tobias@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-07crypto: pcrypt - Add pcrypt crypto parallelization wrapperSteffen Klassert
This patch adds a parallel crypto template that takes a crypto algorithm and converts it to process the crypto transforms in parallel. For the moment only aead algorithms are supported. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-12-30Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: drivers/dma: Correct use after free drivers/dma: drop unnecesary memset ioat2,3: put channel hardware in known state at init async_tx: expand async raid6 test to cover ioatdma corner case ioat3: fix p-disabled q-continuation sh: fix DMA driver's descriptor chaining and cookie assignment dma: at_hdmac: correct incompatible type for argument 1 of 'spin_lock_bh'
2009-12-23crypto: testmgr - Fix complain about lack test for internal used algorithmYouquan, Song
When load aesni-intel and ghash_clmulni-intel driver,kernel will complain no test for some internal used algorithm. The strange information as following: alg: No test for __aes-aesni (__driver-aes-aesni) alg: No test for __ecb-aes-aesni (__driver-ecb-aes-aesni) alg: No test for __cbc-aes-aesni (__driver-cbc-aes-aesni) alg: No test for __ecb-aes-aesni (cryptd(__driver-ecb-aes-aesni) alg: No test for __ghash (__ghash-pclmulqdqni) alg: No test for __ghash (cryptd(__ghash-pclmulqdqni)) This patch add NULL test entries for these algorithm and driver. Signed-off-by: Youquan, Song <youquan.song@intel.com> Signed-off-by: Ying, Huang <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-12-17async_tx: expand async raid6 test to cover ioatdma corner caseDan Williams
Add explicit 11 and 12 disks cases to exercise the 0 < src_cnt % 8 < 3 corner case in the ioatdma driver. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: hwrng: core - Prevent too-small buffer sizes hwrng: virtio-rng - Convert to new API hwrng: core - Replace u32 in driver API with byte array crypto: ansi_cprng - Move FIPS functions under CONFIG_CRYPTO_FIPS crypto: testmgr - Add ghash algorithm test before provide to users crypto: ghash-clmulni-intel - Put proper .data section in place crypto: ghash-clmulni-intel - Use gas macro for PCLMULQDQ-NI and PSHUFB crypto: aesni-intel - Use gas macro for AES-NI instructions x86: Generate .byte code for some new instructions via gas macro crypto: ghash-intel - Fix irq_fpu_usable usage crypto: ghash-intel - Add PSHUFB macros crypto: ghash-intel - Hard-code pshufb crypto: ghash-intel - Fix building failure on x86_32 crypto: testmgr - Fix warning crypto: ansi_cprng - Fix test in get_prng_bytes crypto: hash - Remove cra_u.{digest,hash} crypto: api - Remove digest case from procfs show handler crypto: hash - Remove legacy hash/digest code crypto: ansi_cprng - Add FIPS wrapper crypto: ghash - Add PCLMULQDQ accelerated implementation
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
2009-12-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Herbert Xu
2009-11-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: gcm - fix another complete call in complete fuction crypto: padlock-aes - Use the correct mask when checking whether copying is required
2009-11-23crypto: ansi_cprng - Move FIPS functions under CONFIG_CRYPTO_FIPSJaswinder Singh Rajput
fips_cprng_get_random and fips_cprng_reset is used only by CONFIG_CRYPTO_FIPS. This also fixes compilation warnings: crypto/ansi_cprng.c:360: warning: ‘fips_cprng_get_random’ defined but not used crypto/ansi_cprng.c:393: warning: ‘fips_cprng_reset’ defined but not used Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-11-23crypto: testmgr - Add ghash algorithm test before provide to usersYouquan, Song
Add ghash algorithm test before provide it to users Signed-off-by: Youquan, Song <youquan.song@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-11-19async_tx: build-time toggling of async_{syndrome,xor}_val dma supportDan Williams
ioat3.2 does not support asynchronous error notifications which makes the driver experience latencies when non-zero pq validate results are expected. Provide a mechanism for turning off async_xor_val and async_syndrome_val via Kconfig. This approach is generally useful for any driver that specifies ASYNC_TX_DISABLE_CHANNEL_SWITCH and would like to force the async_tx api to fall back to the synchronous path for certain operations. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-16crypto: gcm - fix another complete call in complete fuctionHuang Ying
The flow of the complete function (xxx_done) in gcm.c is as follow: void complete(struct crypto_async_request *areq, int err) { struct aead_request *req = areq->data; if (!err) { err = async_next_step(); if (err == -EINPROGRESS || err == -EBUSY) return; } complete_for_next_step(areq, err); } But *areq may be destroyed in async_next_step(), this makes complete_for_next_step() can not work properly. To fix this, one of following methods is used for each complete function. - Add a __complete() for each complete(), which accept struct aead_request *req instead of areq, so avoid using areq after it is destroyed. - Expand complete_for_next_step(). The fixing method is based on the idea of Herbert Xu. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-11-12sysctl crypto: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name and .strategy members of sysctl tables are dead code. Remove them. Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-10-31Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: async_tx: fix asynchronous raid6 recovery for ddf layouts async_pq: rename scribble page async_pq: kill a stray dma_map() call and other cleanups md/raid6: kill a gcc-4.0.1 'uninitialized variable' warning raid6/async_tx: handle holes in block list in async_syndrome_val md/async: don't pass a memory pointer as a page pointer. md: Fix handling of raid5 array which is being reshaped to fewer devices. md: fix problems with RAID6 calculations for DDF. md/raid456: downlevel multicore operations to raid_run_ops md: drivers/md/unroll.pl replaced with awk analog md: remove clumsy usage of do_sync_mapping_range from bitmap code md: raid1/raid10: handle allocation errors during array setup. md/raid5: initialize conf->device_lock earlier md/raid1/raid10: add a cond_resched Revert "md: do not progress the resync process if the stripe was blocked"
2009-10-29async_tx: Move ASYNC_RAID6_TEST option to crypto/async_tx/, fix dependenciesDavid Woodhouse
2009-10-27crypto: ghash-intel - Fix building failure on x86_32Huang Ying
CLMUL-NI accelerated GHASH should be turned off on non-x86_64 machine. Reported-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-27crypto: testmgr - Fix warningFelipe Contreras
crypto/testmgr.c: In function ‘test_cprng’: crypto/testmgr.c:1204: warning: ‘err’ may be used uninitialized in this function Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-27crypto: ansi_cprng - Fix test in get_prng_bytesRoel Kluin
size_t nbytes cannot be less than 0 and the test was redundant. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-19async_tx: fix asynchronous raid6 recovery for ddf layoutsDan Williams
The raid6 recovery code currently requires special handling of the 4-disk and 5-disk recovery scenarios for the native layout. Quoting from commit 0a82a623: In these situations the default N-disk algorithm will present 0-source or 1-source operations to dma devices. To cover for dma devices where the minimum source count is 2 we implement 4-disk and 5-disk handling in the recovery code. The ddf layout presents disks=6 and disks=7 to the recovery code in these situations. Instead of looking at the number of disks count the number of non-zero sources in the list and call the special case code when the number of non-failed sources is 0 or 1. [neilb@suse.de: replace 'ddf' flag with counting good sources] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-19async_pq: rename scribble pageDan Williams
The global scribble page is used as a temporary destination buffer when disabling the P or Q result is requested. The local scribble buffer contains memory for performing address conversions. Rename the global variable to avoid confusion. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-19async_pq: kill a stray dma_map() call and other cleanupsDan Williams
- update the kernel doc for async_syndrome to indicate what NULL in the source list means - whitespace fixups Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-19crypto: api - Remove digest case from procfs show handlerBenjamin Gilbert
Remove special handling of old-style digest algorithms from the procfs show handler. Signed-off-by: Benjamin Gilbert <bgilbert@cs.cmu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-19crypto: hash - Remove legacy hash/digest codeBenjamin Gilbert
6941c3a0 disabled compilation of the legacy digest code but didn't actually remove it. Rectify this. Also, remove the crypto_hash_type extern declaration from algapi.h now that the struct is gone. Signed-off-by: Benjamin Gilbert <bgilbert@cs.cmu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-19crypto: ansi_cprng - Add FIPS wrapperNeil Horman
Patch to add fips(ansi_cprng) alg, which is ansi_cprng plus a continuous test Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
