commit 124df926090b32a998483f6e43ebeccdbe5b5302 upstream.
Remove the certificate date checks that are performed when a certificate is
parsed. There are two checks: a valid from and a valid to. The first check is
causing a lot of problems with system clocks that don't keep good time and the
second places an implicit expiry date upon the kernel when used for module
signing, so do we really need them?
cc: David Woodhouse <dwmw2@infradead.org>
cc: Rusty Russell <rusty@rustcorp.com.au>
cc: Josh Boyer <jwboyer@redhat.com>
cc: Alexander Holler <holler@ahsoftware.de>
commit 714b33d15130cbb5ab426456d4e3de842d6c5b8a upstream.
Stephan Mueller reported to me recently a error in random number generation in
the ansi cprng. If several small requests are made that are less than the
instances block size, the remainder for loop code doesn't increment
rand_data_valid in the last iteration, meaning that the last bytes in the
rand_data buffer gets reused on the subsequent smaller-than-a-block request for
random data.
The fix is pretty easy, just re-code the for loop to make sure that
rand_data_valid gets incremented appropriately
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Stephan Mueller <stephan.mueller@atsec.com>
CC: Stephan Mueller <stephan.mueller@atsec.com>
CC: Petr Matousek <pmatouse@redhat.com>
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: "David S. Miller" <davem@davemloft.net>
Cc: Luis Henriques <luis.henriques@canonical.com>
Unfortunately, even with a softdep some distros fail to include
the necessary modules in the initrd. Therefore this patch adds
a fallback path to restore existing behaviour where we cannot
load the new crypto crct10dif algorithm.
In order to do this, the underlying crct10dif has been split out
from the crypto implementation so that it can be used on the
fallback path.
crypto_larval_lookup should only return a larval if it created one.
Any larval created by another entity must be processed through
crypto_larval_wait before being returned.
Otherwise this will lead to a larval being killed twice, which
will most likely lead to a crash.
Cc: stable@vger.kernel.org
Reported-by: Kees Cook <keescook@chromium.org>
Tested-by: Kees Cook <keescook@chromium.org>
Pull crypto update from Herbert Xu:
"Here is the crypto update for 3.12:
- Added MODULE_SOFTDEP to allow pre-loading of modules.
- Reinstated crct10dif driver using the module softdep feature.
- Allow via rng driver to be auto-loaded.
- Split large input data when necessary in nx.
- Handle zero length messages correctly for GCM/XCBC in nx.
- Handle SHA-2 chunks bigger than block size properly in nx.
- Handle unaligned lengths in omap-aes.
- Added SHA384/SHA512 to omap-sham.
- Added OMAP5/AM43XX SHAM support.
- Added OMAP4 TRNG support.
- Misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (66 commits)
Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework"
hwrng: via - Add MODULE_DEVICE_TABLE
crypto: fcrypt - Fix bitoperation for compilation with clang
crypto: nx - fix SHA-2 for chunks bigger than block size
crypto: nx - fix GCM for zero length messages
crypto: nx - fix XCBC for zero length messages
crypto: nx - fix limits to sg lists for AES-CCM
crypto: nx - fix limits to sg lists for AES-XCBC
crypto: nx - fix limits to sg lists for AES-GCM
crypto: nx - fix limits to sg lists for AES-CTR
crypto: nx - fix limits to sg lists for AES-CBC
crypto: nx - fix limits to sg lists for AES-ECB
crypto: nx - add offset to nx_build_sg_lists()
padata - Register hotcpu notifier after initialization
padata - share code between CPU_ONLINE and CPU_DOWN_FAILED, same to CPU_DOWN_PREPARE and CPU_UP_CANCELED
hwrng: omap - reorder OMAP TRNG driver code
crypto: omap-sham - correct dma burst size
crypto: omap-sham - Enable Polling mode if DMA fails
crypto: tegra-aes - bitwise vs logical and
crypto: sahara - checking the wrong variable
This patch reinstates commits
67822649d7305caf3dd50ed46c27b99c94eff996
39761214eefc6b070f29402aa1165f24d789b3f7
0b95a7f85718adcbba36407ef88bba0a7379ed03
31d939625a9a20b1badd2d4e6bf6fd39fa523405
2d31e518a42828df7877bca23a958627d60408bc
Now that module softdeps are in the kernel we can use that to resolve
the boot issue which cause the revert.
Merge upstream tree in order to reinstate crct10dif.
v2: Fix bug in statement as pointed out by Herbert Xu. Kudos to pipacs.
Author: PaX Team <pageexec at freemail.hu>
ML-Post: http://lists.cs.uiuc.edu/pipermail/llvm-commits/Week-of-Mon-20120507/142707.html
URL: http://llvm.linuxfoundation.org
Merge: Jan-Simon Möller <dl9pf at gmx.de>
Description:
Fix for warning:
linux/crypto/fcrypt.c:143:47: warning: signed shift result (0x598000000) requires 36 bits to
represent, but 'int' only has 32 bits [-Wshift-overflow]
Z(0xef), Z(0x70), Z(0xcf), Z(0xc2), Z(0x2a), Z(0xb3), Z(0x61), Z(0xad),
linux/crypto/fcrypt.c:113:29: note: expanded from macro 'Z'
linux/include/uapi/linux/byteorder/little_endian.h:38:53: note: expanded from macro
'__cpu_to_be32'
linux/include/uapi/linux/swab.h:116:21: note: expanded from macro '__swab32'
___constant_swab32(x) : \
linux/include/uapi/linux/swab.h:18:12: note: expanded from macro '___constant_swab32'
(((__u32)(x) & (__u32)0x0000ff00UL) << 8) | \
Solution - make sure we don't exceed the 32 bit range.
#define Z(x) cpu_to_be32(((x & 0x1f) << 27) | (x >> 5))
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
CC: pageexec@freemail.hu
CC: llvmlinux@lists.linuxfoundation.org
CC: behanw@converseincode.com
CC: herbert@gondor.apana.org.au
CC: davem@davemloft.net
CC: linux-crypto@vger.kernel.org
CC: linux-kernel@vger.kernel.org
Crypto layer only passes nbytes to encrypt but in omap-aes driver we need to
know number of SG elements to pass to dmaengine slave API. We add function for
the same to scatterwalk library.
Signed-off-by: Joel Fernandes <joelf@ti.com>
alignment
Adjust alignment and replace commas by semicolons in automatically
generated code.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com>
Tables used from assembler should be marked __visible to let
the compiler know.
This patch removes redundant execution of the same test suite in cases
where alg and driver variables are the same (e.g. when alg_test is
called from tcrypt_test)
Reviewed-by: Horia Geanta <horia.geanta@freescale.com>
Reviewed-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Pull crypto fixes from Herbert Xu:
"This push fixes a memory corruption issue in caam, as well as
reverting the new optimised crct10dif implementation as it breaks boot
on initrd systems.
Hopefully crct10dif will be reinstated once the supporting code is
added so that it doesn't break boot"
Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework"
crypto: caam - Fixed the memory out of bound overwrite issue
This reverts commits
Unfortunately this change broke boot on some systems that used an
initrd which does not include the newly created crct10dif modules.
As these modules are required by sd_mod under certain configurations
this is a serious problem.
Add support for lz4 and lz4hc compression algorithm using the lib/lz4/*
codebase.
[akpm@linux-foundation.org: fix warnings]
Signed-off-by: Chanho Min <chanho.min@lge.com>
Cc: "Darrick J. Wong" <djwong@us.ibm.com>
Cc: Bob Pearson <rpearson@systemfabricworks.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Herbert Xu <herbert@gondor.hengli.com.au>
Cc: Yann Collet <yann.collet.73@gmail.com>
Cc: Kyungsik Lee <kyungsik.lee@lge.com>
- Do not idle omap device between crypto operations in one session.
- Added sha224/sha384 shims for SSSE3.
- More optimisations for camellia-aesni-avx2.
- Removed defunct blowfish/twofish AVX2 implementations.
- Added unaligned buffer self-tests.
- Added PCLMULQDQ optimisation for CRCT10DIF.
- Added support for Freescale's DCP co-processor
- Misc fixes.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (44 commits)
crypto: testmgr - test hash implementations with unaligned buffers
crypto: testmgr - test AEADs with unaligned buffers
crypto: testmgr - test skciphers with unaligned buffers
crypto: testmgr - check that entries in alg_test_descs are in correct order
Revert "crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher"
Revert "crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher"
crypto: camellia-aesni-avx2 - tune assembly code for more performance
hwrng: bcm2835 - fix MODULE_LICENSE tag
hwrng: nomadik - use clk_prepare_enable()
crypto: picoxcell - replace strict_strtoul() with kstrtoul()
crypto: dcp - Staticize local symbols
crypto: dcp - Use NULL instead of 0
crypto: dcp - Use devm_* APIs
crypto: dcp - Remove redundant platform_set_drvdata()
hwrng: use platform_{get,set}_drvdata()
crypto: omap-aes - Don't idle/start AES device between Encrypt operations
crypto: crct10dif - Use PTR_RET
crypto: ux500 - Cocci spatch "resource_size.spatch"
crypto: sha256_ssse3 - add sha224 support
crypto: sha512_ssse3 - add sha384 support
There have never been any real users of MEMSET operations since they
have been introduced in January 2007 by commit 7405f74badf4 ("dmaengine:
refactor dmaengine around dma_async_tx_descriptor"). Therefore remove
support for them for now, it can be always brought back when needed.
[sebastian.hesselbarth@gmail.com: fix drivers/dma/mv_xor]
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Acked-by: Dan Williams <djbw@fb.com>
Cc: Tomasz Figa <t.figa@samsung.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Olof Johansson <olof@lixom.net>
Cc: Kevin Hilman <khilman@linaro.org>
For the workqueue creation interfaces that do not expect format strings,
make sure they cannot accidently be parsed that way. Additionally, clean
up calls made with a single parameter that would be handled as a format
string. Many callers are passing potentially dynamic string content, so
use "%s" in those cases to avoid any potential accidents.
The template lookup interface does not provide a way to use format
strings, so make sure that the interface cannot be abused accidentally.
Cc: <stable@vger.kernel.org>
On Thu, Jun 20, 2013 at 10:00:21AM +0200, Daniel Borkmann wrote:
> After having fixed a NULL pointer dereference in SCTP 1abd165e ("net:
> sctp: fix NULL pointer dereference in socket destruction"), I ran into
> the following NULL pointer dereference in the crypto subsystem with
> the same reproducer, easily hit each time:
> BUG: unable to handle kernel NULL pointer dereference at (null)
> IP: [<ffffffff81070321>] __wake_up_common+0x31/0x90
> PGD 0
> Oops: 0000 [#1] SMP
> Modules linked in: padlock_sha(F-) sha256_generic(F) sctp(F) libcrc32c(F) [..]
> CPU: 6 PID: 3326 Comm: cryptomgr_probe Tainted: GF 3.10.0-rc5+ #1
> Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011
> task: ffff88007b6cf4e0 ti: ffff88007b7cc000 task.ti: ffff88007b7cc000
> RIP: 0010:[<ffffffff81070321>] [<ffffffff81070321>] __wake_up_common+0x31/0x90
> RSP: 0018:ffff88007b7cde08 EFLAGS: 00010082
> RAX: ffffffffffffffe8 RBX: ffff88003756c130 RCX: 0000000000000000
> RDX: 0000000000000000 RSI: 0000000000000003 RDI: ffff88003756c130
> RBP: ffff88007b7cde48 R08: 0000000000000000 R09: ffff88012b173200
> R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000282
> R13: ffff88003756c138 R14: 0000000000000000 R15: 0000000000000000
> FS: 0000000000000000(0000) GS:ffff88012fc60000(0000) knlGS:0000000000000000
> CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
> CR2: 0000000000000000 CR3: 0000000001a0b000 CR4: 00000000000007e0
> DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
> DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
> Stack:
> ffff88007b7cde28 0000000300000000 ffff88007b7cde28 ffff88003756c130
> 0000000000000282 ffff88003756c128 ffffffff81227670 0000000000000000
> ffff88007b7cde78 ffffffff810722b7 ffff88007cdcf000 ffffffff81a90540
> Call Trace:
> [<ffffffff81227670>] ? crypto_alloc_pcomp+0x20/0x20
> [<ffffffff810722b7>] complete_all+0x47/0x60
> [<ffffffff81227708>] cryptomgr_probe+0x98/0xc0
> [<ffffffff8106760e>] kthread+0xce/0xe0
> [<ffffffff81067540>] ? kthread_freezable_should_stop+0x70/0x70
> [<ffffffff815450dc>] ret_from_fork+0x7c/0xb0
> Code: 41 56 41 55 41 54 53 48 83 ec 18 66 66 66 66 90 89 75 cc 89 55 c8
> 4c 8d 6f 08 48 8b 57 08 41 89 cf 4d 89 c6 48 8d 42 e
> RIP [<ffffffff81070321>] __wake_up_common+0x31/0x90
> RSP <ffff88007b7cde08>
> ---[ end trace b495b19270a4d37e ]---
> My assumption is that the following is happening: the minimal SCTP
> tool runs under ``echo 1 > /proc/sys/net/sctp/auth_enable'', hence
> it's making use of crypto_alloc_hash() via sctp_auth_init_hmacs().
> It forks itself, heavily allocates, binds, listens and waits in
> accept on sctp sockets, and then randomly kills some of them (no
> need for an actual client in this case to hit this). Then, again,
> allocating, binding, etc, and then killing child processes.
> The problem that might be happening here is that cryptomgr requests
> the module to probe/load through cryptomgr_schedule_probe(), but
> before the thread handler cryptomgr_probe() returns, we return from
> the wait_for_completion_interruptible() function and probably already
> have cleared up larval, thus we run into a NULL pointer dereference
> when in cryptomgr_probe() complete_all() is being called.
> If we wait with wait_for_completion() instead, this panic will not
> occur anymore. This is valid, because in case a signal is pending,
> cryptomgr_probe() returns from probing anyway with properly calling
> complete_all().
The use of wait_for_completion_interruptible is intentional so that
we don't lock up the thread if a bug causes us to never wake up.
This bug is caused by the helper thread using the larval without
holding a reference count on it. If the helper thread completes
after the original thread requesting for help has gone away and
destroyed the larval, then we get the crash above.
So the fix is to hold a reference count on the larval.
Cc: <stable@vger.kernel.org> # 3.6+
Reported-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Daniel Borkmann <dborkman@redhat.com>
This patch adds unaligned buffer tests for hashes.
The first new test is with one byte offset and the second test checks if
cra_alignmask for driver is big enough; for example, for testing a case
where cra_alignmask is set to 7, but driver really needs buffers to be
aligned to 16 bytes.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
This patch adds unaligned buffer tests for AEADs.
This patch adds unaligned buffer tests for blkciphers.
Patch adds check for alg_test_descs list order, so that accidentically
misplaced entries are found quicker. Duplicate entries are also checked for.
twofish cipher"
This reverts commit cf1521a1a5e21fd1e79a458605c4282fbfbbeee2.
Instruction (vpgatherdd) that this implementation relied on turned out to be
slow performer on real hardware (i5-4570). The previous 8-way twofish/AVX
implementation is therefore faster and this implementation should be removed.
Converting this implementation to use the same method as in twofish/AVX for
table look-ups would give additional ~3% speed up vs twofish/AVX, but would
hardly be worth of the added code and binary size.
This reverts commit 604880107010a1e5794552d184cd5471ea31b973.
slow performer on real hardware (i5-4570). The previous 4-way blowfish
It appears that the performance of 'vpgatherdd' is suboptimal for this kind of
workload (tested on Core i5-4570) and causes blowfish-avx2 to be significantly
slower than blowfish-amd64. So disable the AVX2 implementation to avoid
performance regressions.
workload (tested on Core i5-4570) and causes twofish_avx2 to be significantly
slower than twofish_avx. So disable the AVX2 implementation to avoid
'sha512_generic' should set driver name now that there is alternative sha512
provider (sha512_ssse3).
These are simple tests to do sanity check of CRC T10 DIF hash. The
correctness of the transform can be checked with the command
modprobe tcrypt mode=47
The speed of the transform can be evaluated with the command
modprobe tcrypt mode=320
Set the cpu frequency to constant and turn turbo off when running the
speed test so the frequency governor will not tweak the frequency and
affects the measurements.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
crypto transform
Glue code that plugs the PCLMULQDQ accelerated CRC T10 DIF hash into the
crypto framework. The config CRYPTO_CRCT10DIF_PCLMUL should be turned
on to enable the feature. The crc_t10dif crypto library function will
use this faster algorithm when crct10dif_pclmul module is loaded.
framework
When CRC T10 DIF is calculated using the crypto transform framework, we
wrap the crc_t10dif function call to utilize it. This allows us to
take advantage of any accelerated CRC T10 DIF transform that is
plugged into the crypto framework.
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull mudule updates from Rusty Russell:
"We get rid of the general module prefix confusion with a binary config
option, fix a remove/insert race which Never Happens, and (my
favorite) handle the case when we have too many modules for a single
commandline. Seriously, the kernel is full, please go away!"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modpost: fix unwanted VMLINUX_SYMBOL_STR expansion
X.509: Support parse long form of length octets in Authority Key Identifier
module: don't unlink the module until we've removed all exposure.
kernel: kallsyms: memory override issue, need check destination buffer length
MODSIGN: do not send garbage to stderr when enabling modules signature
modpost: handle huge numbers of modules.
modpost: add -T option to read module names from file/stdin.
modpost: minor cleanup.
genksyms: pass symbol-prefix instead of arch
module: fix symbol versioning with symbol prefixes
CONFIG_SYMBOL_PREFIX: cleanup.
- XTS mode optimisation for twofish/cast6/camellia/aes on x86
- AVX2/x86_64 implementation for blowfish/twofish/serpent/camellia
- SSSE3/AVX/AVX2 optimisations for sha256/sha512
- Added driver for SAHARA2 crypto accelerator
- Fix for GMAC when used in non-IPsec secnarios
- Added generic CMAC implementation (including IPsec glue)
- IP update for crypto/atmel
- Support for more than one device in hwrng/timeriomem
- Added Broadcom BCM2835 RNG driver
- Misc fixes
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (59 commits)
crypto: caam - fix job ring cleanup code
crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of camellia cipher
crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipher
crypto: tcrypt - add async cipher speed tests for blowfish
crypto: testmgr - extend camellia test-vectors for camellia-aesni/avx2
crypto: aesni_intel - fix Kconfig problem with CRYPTO_GLUE_HELPER_X86
crypto: aesni_intel - add more optimized XTS mode for x86-64
crypto: x86/camellia-aesni-avx - add more optimized XTS code
crypto: cast6-avx: use new optimized XTS code
crypto: x86/twofish-avx - use optimized XTS code
crypto: x86 - add more optimized XTS-mode for serpent-avx
xfrm: add rfc4494 AES-CMAC-96 support
crypto: add CMAC support to CryptoAPI
crypto: testmgr - add empty test vectors for null ciphers
crypto: testmgr - add AES GMAC test vectors
crypto: gcm - fix rfc4543 to handle async crypto correctly
crypto: gcm - make GMAC work when dst and src are different
hwrng: timeriomem - added devicetree hooks
Use prandom_bytes() to generate random bytes for test data.
Cc: Dan Williams <djbw@fb.com>
camellia cipher
Patch adds AVX2/AES-NI/x86-64 implementation of Camellia cipher, requiring
32 parallel blocks for input (512 bytes). Compared to AVX implementation, this
version is extended to use the 256-bit wide YMM registers. For AES-NI
instructions data is split to two 128-bit registers and merged afterwards.
Even with this additional handling, performance should be higher compared
to the AES-NI/AVX implementation.
Patch adds AVX2/x86-64 implementation of Serpent cipher, requiring 16 parallel
blocks for input (256 bytes). Implementation is based on the AVX implementation
and extends to use the 256-bit wide YMM registers. Since serpent does not use
table look-ups, this implementation should be close to two times faster than
the AVX implementation.
Patch adds AVX2/x86-64 implementation of Twofish cipher, requiring 16 parallel
blocks for input (256 bytes). Table look-ups are performed using vpgatherdd
instruction directly from vector registers and thus should be faster than
earlier implementations. Implementation also uses 256-bit wide YMM registers,
which should give additional speed up compared to the AVX implementation.
Patch adds AVX2/x86-64 implementation of Blowfish cipher, requiring 32 parallel
The Kconfig setting for glue helper module is CRYPTO_GLUE_HELPER_X86, but
recent change for aesni_intel used CRYPTO_GLUE_HELPER instead. Patch corrects
this issue.
Cc: kbuild-all@01.org
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Add more optimized XTS code for aesni_intel in 64-bit mode, for smaller stack
usage and boost for speed.
tcrypt results, with Intel i5-2450M:
256-bit key
enc dec
16B 0.98x 0.99x
64B 0.64x 0.63x
256B 1.29x 1.32x
1024B 1.54x 1.58x
8192B 1.57x 1.60x
512-bit key
enc dec
16B 0.98x 0.99x
64B 0.60x 0.59x
256B 1.24x 1.25x
1024B 1.39x 1.42x
8192B 1.38x 1.42x
I chose not to optimize smaller than block size of 256 bytes, since XTS is
practically always used with data blocks of size 512 bytes. This is why
performance is reduced in tcrypt for 64 byte long blocks.
Cc: Huang Ying <ying.huang@intel.com>
Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI.
This work is based on Tom St Denis' earlier patch,
http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2
Cc: Tom St Denis <tstdenis@elliptictech.com>
Without these, kernel log shows:
[ 5.984881] alg: No test for cipher_null (cipher_null-generic)
[ 5.985096] alg: No test for ecb(cipher_null) (ecb-cipher_null)
[ 5.985170] alg: No test for compress_null (compress_null-generic)
[ 5.985297] alg: No test for digest_null (digest_null-generic)
If the gcm cipher used by rfc4543 does not complete request immediately,
the authentication tag is not copied to destination buffer. Patch adds
correct async logic for this case.
The GMAC code assumes that dst==src, which causes problems when trying to add
rfc4543(gcm(aes)) test vectors.
So fix this code to work when source and destination buffer are different.
SSSE3, AVX or AVX2 instructions.
We added glue code and config options to create crypto
module that uses SSE/AVX/AVX2 optimized SHA512 x86_64 assembly routines.
