[ Upstream commit 12cb3a1c4184f891d965d1f39f8cfcc9ef617647 ]
Since the
commit f1c131b45410a202eb45cc55980a7a9e4e4b4f40
crypto: xts - Convert to skcipher
the XTS mode is based on ECB, so the mode must select
ECB otherwise it can fail to initialize.
Signed-off-by: Milan Broz <gmazyland@gmail.com>
commit b61907bb42409adf9b3120f741af7c57dd7e3db2 upstream.
The shash ahash digest adaptor function may crash if given a
zero-length input together with a null SG list. This is because
it tries to read the SG list before looking at the length.
This patch fixes it by checking the length first.
Reported-by: Stephan Müller<smueller@chronox.de>
Tested-by: Stephan Müller <smueller@chronox.de>
Fixed differently upstream as commit 2d97591ef43d ("crypto: af_alg - consolidation of duplicate code")
The SGL is MAX_SGL_ENTS + 1 in size. The last SG entry is used for the
chaining and is properly updated with the sg_chain invocation. During
the filling-in of the initial SG entries, sg_mark_end is called for each
SG entry. This is appropriate as long as no additional SGL is chained
with the current SGL. However, when a new SGL is chained and the last
SG entry is updated with sg_chain, the last but one entry still contains
the end marker from the sg_mark_end. This end marker must be removed as
otherwise a walk of the chained SGLs will cause a NULL pointer
dereference at the last but one SG entry, because sg_next will return
NULL.
The patch only applies to all kernels up to and including 4.13. The
patch 2d97591ef43d0587be22ad1b0d758d6df4999a0b added to 4.14-rc1
introduced a complete new code base which addresses this bug in
a different way. Yet, that patch is too invasive for stable kernels
and was therefore not marked for stable.
Fixes: 8ff590903d5fc ("crypto: algif_skcipher - User-space interface for skcipher operations")
Signed-off-by: Stephan Mueller <smueller@chronox.de>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit 445a582738de6802669aeed9c33ca406c23c3b1f upstream.
For asynchronous operation, SGs are allocated without a page mapped to
them or with a page that is not used (ref-counted). If the SGL is freed,
the code must only call put_page for an SG if there was a page assigned
and ref-counted in the first place.
This fixes a kernel crash when using io_submit with more than one iocb
using the sendmsg and sendpage (vmsplice/splice) interface.
commit 41cdf7a45389e01991ee31e3301ed83cb3e3f7dc upstream.
When authencesn is used together with digest_null a crash will
occur on the decrypt path. This is because normally we perform
a special setup to preserve the ESN, but this is skipped if there
is no authentication. However, on the post-authentication path
it always expects the preservation to be in place, thus causing
a crash when digest_null is used.
This patch fixes this by also skipping the post-processing when
there is no authentication.
Fixes: 104880a6b470 ("crypto: authencesn - Convert to new AEAD...")
Reported-by: Jan Tluka <jtluka@redhat.com>
commit f3ad587070d6bd961ab942b3fd7a85d00dfc934b upstream.
crypto_gcm_setkey() was using wait_for_completion_interruptible() to
wait for completion of async crypto op but if a signal occurs it
may return before DMA ops of HW crypto provider finish, thus
corrupting the data buffer that is kfree'ed in this case.
Resolve this by using wait_for_completion() instead.
Reported-by: Eric Biggers <ebiggers3@gmail.com>
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
commit 2a2a251f110576b1d89efbd0662677d7e7db21a8 upstream.
Some cipher implementations will crash if you try to use them
without calling setkey first. This patch adds a check so that
the accept(2) call will fail with -ENOKEY if setkey hasn't been
done on the socket yet.
Fixes: 400c40cf78da ("crypto: algif - add AEAD support")
commit abfa7f4357e3640fdee87dfc276fd0f379fb5ae6 upstream.
__test_aead() reads MAX_IVLEN bytes from template[i].iv, but the
actual length of the initialisation vector can be shorter.
The length of the IV is already calculated earlier in the
function. Let's just reuses that. Also the IV length is currently
calculated several time for no reason. Let's fix that too.
This fix an out-of-bound error detected by KASan.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
commit ef0579b64e93188710d48667cb5e014926af9f1b upstream.
The ahash API modifies the request's callback function in order
to clean up after itself in some corner cases (unaligned final
and missing finup).
When the request is complete ahash will restore the original
callback and everything is fine. However, when the request gets
an EBUSY on a full queue, an EINPROGRESS callback is made while
the request is still ongoing.
In this case the ahash API will incorrectly call its own callback.
This patch fixes the problem by creating a temporary request
object on the stack which is used to relay EINPROGRESS back to
the original completion function.
This patch also adds code to preserve the original flags value.
Fixes: ab6bf4e5e5e4 ("crypto: hash - Fix the pointer voodoo in...")
Reported-by: Sabrina Dubroca <sd@queasysnail.net>
Tested-by: Sabrina Dubroca <sd@queasysnail.net>
commit 6207119444595d287b1e9e83a2066c17209698f3 upstream.
With this reproducer:
struct sockaddr_alg alg = {
.salg_family = 0x26,
.salg_type = "hash",
.salg_feat = 0xf,
.salg_mask = 0x5,
.salg_name = "digest_null",
int sock, sock2;
sock = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(sock, (struct sockaddr *)&alg, sizeof(alg));
sock2 = accept(sock, NULL, NULL);
setsockopt(sock, SOL_ALG, ALG_SET_KEY, "\x9b\xca", 2);
accept(sock2, NULL, NULL);
==== 8< ======== 8< ======== 8< ======== 8< ====
one can immediatelly see an UBSAN warning:
UBSAN: Undefined behaviour in crypto/algif_hash.c:187:7
variable length array bound value 0 <= 0
CPU: 0 PID: 15949 Comm: syz-executor Tainted: G E 4.4.30-0-default #1
Call Trace:
[<ffffffff81d598fd>] ? __ubsan_handle_vla_bound_not_positive+0x13d/0x188
[<ffffffff81d597c0>] ? __ubsan_handle_out_of_bounds+0x1bc/0x1bc
[<ffffffffa0e2204d>] ? hash_accept+0x5bd/0x7d0 [algif_hash]
[<ffffffffa0e2293f>] ? hash_accept_nokey+0x3f/0x51 [algif_hash]
[<ffffffffa0e206b0>] ? hash_accept_parent_nokey+0x4a0/0x4a0 [algif_hash]
[<ffffffff8235c42b>] ? SyS_accept+0x2b/0x40
It is a correct warning, as hash state is propagated to accept as zero,
but creating a zero-length variable array is not allowed in C.
Fix this as proposed by Herbert -- do "?: 1" on that site. No sizeof or
similar happens in the code there, so we just allocate one byte even
though we do not use the array.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: "David S. Miller" <davem@davemloft.net> (maintainer:CRYPTO API)
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit ddef482420b1ba8ec45e6123a7e8d3f67b21e5e3 upstream.
mcryptd_create_hash() fails by returning -EINVAL, causing any
driver using mcryptd to fail to load. It is because it needs
to set its statesize properly.
Signed-off-by: Rui Wang <rui.y.wang@intel.com>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
commit 1a07834024dfca5c4bed5de8f8714306e0a11836 upstream.
cryptd_create_hash() fails by returning -EINVAL. It is because after
8996eafdc ("crypto: ahash - ensure statesize is non-zero") all ahash
drivers must have a non-zero statesize.
This patch fixes the problem by properly assigning the statesize.
commit 7d6e9105026788c497f0ab32fa16c82f4ab5ff61 upstream.
An ancient gcc bug (first reported in 2003) has apparently resurfaced
on MIPS, where kernelci.org reports an overly large stack frame in the
whirlpool hash algorithm:
crypto/wp512.c:987:1: warning: the frame size of 1112 bytes is larger than 1024 bytes [-Wframe-larger-than=]
With some testing in different configurations, I'm seeing large
variations in stack frames size up to 1500 bytes for what should have
around 300 bytes at most. I also checked the reference implementation,
which is essentially the same code but also comes with some test and
benchmarking infrastructure.
It seems that recent compiler versions on at least arm, arm64 and powerpc
have a partial fix for this problem, but enabling "-fsched-pressure", but
even with that fix they suffer from the issue to a certain degree. Some
testing on arm64 shows that the time needed to hash a given amount of
data is roughly proportional to the stack frame size here, which makes
sense given that the wp512 implementation is doing lots of loads for
table lookups, and the problem with the overly large stack is a result
of doing a lot more loads and stores for spilled registers (as seen from
inspecting the object code).
Disabling -fschedule-insns consistently fixes the problem for wp512,
in my collection of cross-compilers, the results are consistently better
or identical when comparing the stack sizes in this function, though
some architectures (notable x86) have schedule-insns disabled by
default.
The four columns are:
default: -O2
press: -O2 -fsched-pressure
nopress: -O2 -fschedule-insns -fno-sched-pressure
nosched: -O2 -no-schedule-insns (disables sched-pressure)
default press nopress nosched
alpha-linux-gcc-4.9.3 1136 848 1136 176
am33_2.0-linux-gcc-4.9.3 2100 2076 2100 2104
arm-linux-gnueabi-gcc-4.9.3 848 848 1048 352
cris-linux-gcc-4.9.3 272 272 272 272
frv-linux-gcc-4.9.3 1128 1000 1128 280
hppa64-linux-gcc-4.9.3 1128 336 1128 184
hppa-linux-gcc-4.9.3 644 308 644 276
i386-linux-gcc-4.9.3 352 352 352 352
m32r-linux-gcc-4.9.3 720 656 720 268
microblaze-linux-gcc-4.9.3 1108 604 1108 256
mips64-linux-gcc-4.9.3 1328 592 1328 208
mips-linux-gcc-4.9.3 1096 624 1096 240
powerpc64-linux-gcc-4.9.3 1088 432 1088 160
powerpc-linux-gcc-4.9.3 1080 584 1080 224
s390-linux-gcc-4.9.3 456 456 624 360
sh3-linux-gcc-4.9.3 292 292 292 292
sparc64-linux-gcc-4.9.3 992 240 992 208
sparc-linux-gcc-4.9.3 680 592 680 312
x86_64-linux-gcc-4.9.3 224 240 272 224
xtensa-linux-gcc-4.9.3 1152 704 1152 304
aarch64-linux-gcc-7.0.0 224 224 1104 208
arm-linux-gnueabi-gcc-7.0.1 824 824 1048 352
mips-linux-gcc-7.0.0 1120 648 1120 272
x86_64-linux-gcc-7.0.1 240 240 304 240
arm-linux-gnueabi-gcc-4.4.7 840 392
arm-linux-gnueabi-gcc-4.5.4 784 728 784 320
arm-linux-gnueabi-gcc-4.6.4 736 728 736 304
arm-linux-gnueabi-gcc-4.7.4 944 784 944 352
arm-linux-gnueabi-gcc-4.8.5 464 464 760 352
arm-linux-gnueabi-gcc-5.3.1 824 824 1064 336
arm-linux-gnueabi-gcc-6.1.1 808 808 1056 344
Trying the same test for serpent-generic, the picture is a bit different,
and while -fno-schedule-insns is generally better here than the default,
-fsched-pressure wins overall, so I picked that instead.
alpha-linux-gcc-4.9.3 1392 864 1392 960
am33_2.0-linux-gcc-4.9.3 536 524 536 528
arm-linux-gnueabi-gcc-4.9.3 552 552 776 536
cris-linux-gcc-4.9.3 528 528 528 528
frv-linux-gcc-4.9.3 536 400 536 504
hppa64-linux-gcc-4.9.3 524 208 524 480
hppa-linux-gcc-4.9.3 768 472 768 508
i386-linux-gcc-4.9.3 564 564 564 564
m32r-linux-gcc-4.9.3 712 576 712 532
microblaze-linux-gcc-4.9.3 724 392 724 512
mips64-linux-gcc-4.9.3 720 384 720 496
mips-linux-gcc-4.9.3 728 384 728 496
powerpc64-linux-gcc-4.9.3 704 304 704 480
powerpc-linux-gcc-4.9.3 704 296 704 480
s390-linux-gcc-4.9.3 560 560 592 536
sh3-linux-gcc-4.9.3 540 540 540 540
sparc64-linux-gcc-4.9.3 544 352 544 496
sparc-linux-gcc-4.9.3 544 344 544 496
x86_64-linux-gcc-4.9.3 528 536 576 528
xtensa-linux-gcc-4.9.3 752 544 752 544
aarch64-linux-gcc-7.0.0 432 432 656 480
arm-linux-gnueabi-gcc-7.0.1 616 616 808 536
mips-linux-gcc-7.0.0 720 464 720 488
x86_64-linux-gcc-7.0.1 536 528 600 536
arm-linux-gnueabi-gcc-4.4.7 592 440
arm-linux-gnueabi-gcc-4.5.4 776 448 776 544
arm-linux-gnueabi-gcc-4.6.4 776 448 776 544
arm-linux-gnueabi-gcc-4.7.4 768 448 768 544
arm-linux-gnueabi-gcc-4.8.5 488 488 776 544
arm-linux-gnueabi-gcc-5.3.1 552 552 776 536
arm-linux-gnueabi-gcc-6.1.1 560 560 776 536
I did not do any runtime tests with serpent, so it is possible that stack
frame size does not directly correlate with runtime performance here and
it actually makes things worse, but it's more likely to help here, and
the reduced stack frame size is probably enough reason to apply the patch,
especially given that the crypto code is often used in deep call chains.
Link: https://kernelci.org/build/id/58797d7559b5149efdf6c3a9/logs/
Link: http://www.larc.usp.br/~pbarreto/WhirlpoolPage.html
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=11488
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=79149
commit 1c68bb0f62bf8de8bb30123ea840d5168f25abea upstream.
Running with KASAN and crypto tests currently gives
BUG: KASAN: global-out-of-bounds in __test_aead+0x9d9/0x2200 at addr ffffffff8212fca0
Read of size 16 by task cryptomgr_test/1107
Address belongs to variable 0xffffffff8212fca0
CPU: 0 PID: 1107 Comm: cryptomgr_test Not tainted 4.10.0+ #45
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014
Call Trace:
dump_stack+0x63/0x8a
kasan_report.part.1+0x4a7/0x4e0
? __test_aead+0x9d9/0x2200
? crypto_ccm_init_crypt+0x218/0x3c0 [ccm]
kasan_report+0x20/0x30
check_memory_region+0x13c/0x1a0
memcpy+0x23/0x50
? kasan_unpoison_shadow+0x35/0x50
? alg_test_akcipher+0xf0/0xf0
? crypto_skcipher_init_tfm+0x2e3/0x310
? crypto_spawn_tfm2+0x37/0x60
? crypto_ccm_init_tfm+0xa9/0xd0 [ccm]
? crypto_aead_init_tfm+0x7b/0x90
? crypto_alloc_tfm+0xc4/0x190
test_aead+0x28/0xc0
alg_test_aead+0x54/0xd0
alg_test+0x1eb/0x3d0
? alg_find_test+0x90/0x90
? __sched_text_start+0x8/0x8
? __wake_up_common+0x70/0xb0
cryptomgr_test+0x4d/0x60
kthread+0x173/0x1c0
? crypto_acomp_scomp_free_ctx+0x60/0x60
? kthread_create_on_node+0xa0/0xa0
ret_from_fork+0x2c/0x40
Memory state around the buggy address:
ffffffff8212fb80: 00 00 00 00 01 fa fa fa fa fa fa fa 00 00 00 00
ffffffff8212fc00: 00 01 fa fa fa fa fa fa 00 00 00 00 01 fa fa fa
>ffffffff8212fc80: fa fa fa fa 00 05 fa fa fa fa fa fa 00 00 00 00
ffffffff8212fd00: 01 fa fa fa fa fa fa fa 00 00 00 00 01 fa fa fa
ffffffff8212fd80: fa fa fa fa 00 00 00 00 00 05 fa fa fa fa fa fa
This always happens on the same IV which is less than 16 bytes.
Per Ard,
"CCM IVs are 16 bytes, but due to the way they are constructed
internally, the final couple of bytes of input IV are dont-cares.
Apparently, we do read all 16 bytes, which triggers the KASAN errors."
Fix this by padding the IV with null bytes to be at least 16 bytes.
Fixes: 0bc5a6c5c79a ("crypto: testmgr - Disable rfc4309 test and convert test vectors")
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Laura Abbott <labbott@redhat.com>
commit d6040764adcb5cb6de1489422411d701c158bb69 upstream.
Make sure CRYPTO_ALG_DEAD bit is cleared before proceeding with
the algorithm registration. This fixes qat-dh registration when
driver is restarted
Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
commit 57891633eeef60e732e045731cf20e50ee80acb4 upstream.
Both asn1 headers are included by rsa_helper.c, so rsa_helper.o
should explicitly depend on them.
Signed-off-by: David Michael <david.michael@coreos.com>
Cc: Tuomas Tynkkynen <tuomas@tuxera.com>
commit 48a992727d82cb7db076fa15d372178743b1f4cd upstream.
Algorithms not compatible with mcryptd could be spawned by mcryptd
with a direct crypto_alloc_tfm invocation using a "mcryptd(alg)" name
construct. This causes mcryptd to crash the kernel if an arbitrary
"alg" is incompatible and not intended to be used with mcryptd. It is
an issue if AF_ALG tries to spawn mcryptd(alg) to expose it externally.
But such algorithms must be used internally and not be exposed.
We added a check to enforce that only internal algorithms are allowed
with mcryptd at the time mcryptd is spawning an algorithm.
Link: http://marc.info/?l=linux-crypto-vger&m=148063683310477&w=2
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
commit 50d2e6dc1f83db0563c7d6603967bf9585ce934b upstream.
The cipher block size for GCM is 16 bytes, and thus the CTR transform
used in crypto_gcm_setkey() will also expect a 16-byte IV. However,
the code currently reserves only 8 bytes for the IV, causing
an out-of-bounds access in the CTR transform. This patch fixes
the issue by setting the size of the IV buffer to 16 bytes.
Fixes: 84c911523020 ("[CRYPTO] gcm: Add support for async ciphers")
Signed-off-by: Ondrej Mosnacek <omosnacek@gmail.com>
commit 7ee7014d0eb6bcac679c0bd5fe9ce65bc4325648 upstream.
Dave Young reported:
> Hi,
> I saw the warning "Missing required AuthAttr" when testing kexec,
> known issue? Idea about how to fix it?
> The kernel is latest linus tree plus sevral patches from Toshi to
> cleanup io resource structure.
> in function pkcs7_sig_note_set_of_authattrs():
> if (!test_bit(sinfo_has_content_type, &sinfo->aa_set) ||
> !test_bit(sinfo_has_message_digest, &sinfo->aa_set) ||
> (ctx->msg->data_type == OID_msIndirectData &&
> !test_bit(sinfo_has_ms_opus_info, &sinfo->aa_set))) {
> pr_warn("Missing required AuthAttr\n");
> return -EBADMSG;
> The third condition below is true:
> I signed the kernel with redhat test key like below:
> pesign -c 'Red Hat Test Certificate' -i arch/x86/boot/bzImage -o /boot/vmlinuz-4.4.0-rc8+ -s --force
And right he is! The Authenticode specification is a paragon amongst
technical documents, and has this pearl of wisdom to offer:
Authenticode-Specific SignerInfo UnauthenticatedAttributes Structures
The following Authenticode-specific data structures are present in
SignerInfo authenticated attributes.
SpcSpOpusInfo
SpcSpOpusInfo is identified by SPC_SP_OPUS_INFO_OBJID
(1.3.6.1.4.1.311.2.1.12) and is defined as follows:
SpcSpOpusInfo ::= SEQUENCE {
programName [0] EXPLICIT SpcString OPTIONAL,
moreInfo [1] EXPLICIT SpcLink OPTIONAL,
} --#public--
SpcSpOpusInfo has two fields:
programName
This field contains the program description:
If publisher chooses not to specify a description, the SpcString
structure contains a zero-length program name.
If the publisher chooses to specify a
description, the SpcString structure contains a Unicode string.
moreInfo
This field is set to an SPCLink structure that contains a URL for
a Web site with more information about the signer. The URL is an
ASCII string.
Which is to say that this is an optional *unauthenticated* field which
may be present in the Authenticated Attribute list. This is not how
pkcs7 is supposed to work, so when David implemented this, he didn't
appreciate the subtlety the original spec author was working with, and
missed the part of the sublime prose that says this Authenticated
Attribute is an Unauthenticated Attribute. As a result, the code in
question simply takes as given that the Authenticated Attributes should
be authenticated.
But this one should not, individually. Because it says it's not
authenticated.
It still has to hash right so the TBS digest is correct. So it is both
authenticated and unauthenticated, all at once. Truly, a wonder of
technical accomplishment.
Additionally, pesign's implementation has always attempted to be
compatible with the signatures emitted from contemporary versions of
Microsoft's signtool.exe. During the initial implementation, Microsoft
signatures always produced the same values for SpcSpOpusInfo -
{U"Microsoft Windows", "http://www.microsoft.com"} - without regard to
who the signer was.
Sometime between Windows 8 and Windows 8.1 they stopped including the
field in their signatures altogether, and as such pesign stopped
producing them in commits c0c4da6 and d79cb0c, sometime around June of
2012. The theory here is that anything that breaks with
pesign signatures would also be breaking with signtool.exe sigs as well,
and that'll be a more noticed problem for firmwares parsing it, so it'll
get fixed. The fact that we've done exactly this bug in Linux code is
first class, grade A irony.
So anyway, we should not be checking this field for presence or any
particular value: if the field exists, it should be at the right place,
but aside from that, as long as the hash matches the field is good.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
commit a397ba829d7f8aff4c90af3704573a28ccd61a59 upstream.
Move common values and types used by ghash-generic to a new header file
so drivers can directly use ghash-generic as a fallback implementation.
Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module")
Signed-off-by: Marcelo Cerri <marcelo.cerri@canonical.com>
commit c84750906b4818d4929fbf73a4ae6c113b94f52b upstream.
Add missing dmaengine_unmap_put(), so we don't OOM during RAID6 sync.
Fixes: 1786b943dad0 ("async_pq_val: convert to dmaengine_unmap_data")
Signed-off-by: Justin Maggard <jmaggard@netgear.com>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 53a5d5ddccf849dbc27a8c1bba0b43c3a45fb792 upstream.
The current implementation uses a global per-cpu array to store
data which are used to derive the next IV. This is insecure as
the attacker may change the stored data.
This patch removes all traces of chaining and replaces it with
multiplication of the salt and the sequence number.
Fixes: a10f554fa7e0 ("crypto: echainiv - Add encrypted chain IV...")
Reported-by: Mathias Krause <minipli@googlemail.com>
commit acdb04d0b36769b3e05990c488dc74d8b7ac8060 upstream.
When we need to allocate a temporary blkcipher_walk_next and it
fails, the code is supposed to take the slow path of processing
the data block by block. However, due to an unrelated change
we instead end up dereferencing the NULL pointer.
This patch fixes it by moving the unrelated bsize setting out
of the way so that we enter the slow path as inteded.
Fixes: 7607bd8ff03b ("[CRYPTO] blkcipher: Added blkcipher_walk_virt_block")
Reported-by: xiakaixu <xiakaixu@huawei.com>
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 0bd2223594a4dcddc1e34b15774a3a4776f7749e upstream.
When calling .import() on a cryptd ahash_request, the structure members
that describe the child transform in the shash_desc need to be initialized
like they are when calling .init()
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 5f070e81bee35f1b7bd1477bb223a873ff657803 upstream.
When there is more data to be processed, the current test in
scatterwalk_done may prevent us from calling pagedone even when
we should.
In particular, if we're on an SG entry spanning multiple pages
where the last page is not a full page, we will incorrectly skip
calling pagedone on the second last page.
This patch fixes this by adding a separate test for whether we've
reached the end of a page.
commit b30bdfa86431afbafe15284a3ad5ac19b49b88e3 upstream.
As it is if you ask for a sync gcm you may actually end up with
an async one because it does not filter out async implementations
of ghash.
This patch fixes this by adding the necessary filter when looking
for ghash.
commit 055ddaace03580455a7b7dbea8e93d62acee61fc upstream.
Commit 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG")
accidentally removed the minimum size check for CRYPTO_MSG_GETALG
netlink messages. This allows userland to send a truncated
CRYPTO_MSG_GETALG message as short as a netlink header only making
crypto_report() operate on uninitialized memory by accessing data
beyond the end of the netlink message.
Fix this be re-adding the minimum required size of CRYPTO_MSG_GETALG
messages to the crypto_msg_min[] array.
Fixes: 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
commit bad6a185b4d6f81d0ed2b6e4c16307969f160b95 upstream.
In some rare randconfig builds, we can end up with
ASYMMETRIC_PUBLIC_KEY_SUBTYPE enabled but CRYPTO_AKCIPHER disabled,
which fails to link because of the reference to crypto_alloc_akcipher:
crypto/built-in.o: In function `public_key_verify_signature':
:(.text+0x110e4): undefined reference to `crypto_alloc_akcipher'
This adds a Kconfig 'select' statement to ensure the dependency
is always there.
commit df27b26f04ed388ff4cc2b5d8cfdb5d97678816f upstream.
As akcipher uses an SG interface, you must not use vmalloc memory
as input for it. This patch fixes testmgr to copy the vmalloc
test vectors to kmalloc memory before running the test.
This patch also removes a superfluous sg_virt call in do_test_rsa.
Reported-by: Anatoly Pugachev <matorola@gmail.com>
commit 13f4bb78cf6a312bbdec367ba3da044b09bf0e29 upstream.
The crypto hash walk code is broken when supplied with an offset
greater than or equal to PAGE_SIZE. This patch fixes it by adjusting
walk->pg and walk->offset when this happens.
Reported-by: Steffen Klassert <steffen.klassert@secunet.com>
commit e54358915d0a00399c11c2c23ae1be674cba188a upstream.
Despite what the DocBook comment to pkcs7_validate_trust() says, the
*_trusted argument is never set to false.
pkcs7_validate_trust() only positively sets *_trusted upon encountering
a trusted PKCS#7 SignedInfo block.
This is quite unfortunate since its callers, system_verify_data() for
example, depend on pkcs7_validate_trust() clearing *_trusted on non-trust.
Indeed, UBSAN splats when attempting to load the uninitialized local
variable 'trusted' from system_verify_data() in pkcs7_validate_trust():
UBSAN: Undefined behaviour in crypto/asymmetric_keys/pkcs7_trust.c:194:14
load of value 82 is not a valid value for type '_Bool'
Call Trace:
[<ffffffff818c4d35>] dump_stack+0xbc/0x117
[<ffffffff818c4c79>] ? _atomic_dec_and_lock+0x169/0x169
[<ffffffff8194113b>] ubsan_epilogue+0xd/0x4e
[<ffffffff819419fa>] __ubsan_handle_load_invalid_value+0x111/0x158
[<ffffffff819418e9>] ? val_to_string.constprop.12+0xcf/0xcf
[<ffffffff818334a4>] ? x509_request_asymmetric_key+0x114/0x370
[<ffffffff814b83f0>] ? kfree+0x220/0x370
[<ffffffff818312c2>] ? public_key_verify_signature_2+0x32/0x50
[<ffffffff81835e04>] pkcs7_validate_trust+0x524/0x5f0
[<ffffffff813c391a>] system_verify_data+0xca/0x170
[<ffffffff813c3850>] ? top_trace_array+0x9b/0x9b
[<ffffffff81510b29>] ? __vfs_read+0x279/0x3d0
[<ffffffff8129372f>] mod_verify_sig+0x1ff/0x290
The implication is that pkcs7_validate_trust() effectively grants trust
when it really shouldn't have.
Fix this by explicitly setting *_trusted to false at the very beginning
of pkcs7_validate_trust().
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
commit ac4cbedfdf55455b4c447f17f0fa027dbf02b2a6 upstream.
There are still a couple of minor issues in the X.509 leap year handling:
(1) To avoid doing a modulus-by-400 in addition to a modulus-by-100 when
determining whether the year is a leap year or not, I divided the year
by 100 after doing the modulus-by-100, thereby letting the compiler do
one instruction for both, and then did a modulus-by-4.
Unfortunately, I then passed the now-modified year value to mktime64()
to construct a time value.
Since this isn't a fast path and since mktime64() does a bunch of
divisions, just condense down to "% 400". It's also easier to read.
(2) The default month length for any February where the year doesn't
divide by four exactly is obtained from the month_length[] array where
the value is 29, not 28.
This is fixed by altering the table.
Reported-by: Rudolf Polzer <rpolzer@google.com>
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
commit 2b8b28fd232233c22fb61009dd8b0587390d2875 upstream.
We're clearing the wrong memory. The memory corruption is likely
harmless because we weren't going to use that stack memory again but not
zeroing is a potential information leak.
Fixes: e28facde3c39 ('crypto: keywrap - add key wrapping block chaining mode')
Acked-by: Stephan Mueller <smueller@chronox.de>
commit dad41997063723eaf5f77bc2015606a5a9bce320 upstream.
The async path cannot use MAY_BACKLOG because it is not meant to
block, which is what MAY_BACKLOG does. On the other hand, both
the sync and async paths can make use of MAY_SLEEP.
commit 6454c2b83f719057069777132b13949e4c6b6350 upstream.
Any access to non-constant bits of the private context must be
done under the socket lock, in particular, this includes ctx->req.
This patch moves such accesses under the lock, and fetches the
tfm from the parent socket which is guaranteed to be constant,
rather than from ctx->req.
commit ec69bbfb9902c32a5c1492f2b1b8ad032a66d724 upstream.
The async path in algif_skcipher assumes that the crypto completion
function will be called with the original request. This is not
necessarily the case. In fact there is no need for this anyway
since we already embed information into the request with struct
skcipher_async_req.
This patch adds a pointer to that struct and then passes it as
the data to the callback function.
Tested-by: Tadeusz Struk <tadeusz.struk@intel.com>
commit 63e41ebc6630f39422d87f8a4bade1e793f37a01 upstream.
We miss to take the crypto_alg_sem semaphore when traversing the
crypto_alg_list for CRYPTO_MSG_GETALG dumps. This allows a race with
crypto_unregister_alg() removing algorithms from the list while we're
still traversing it, thereby leading to a use-after-free as show below:
[ 3482.071639] general protection fault: 0000 [#1] SMP
[ 3482.075639] Modules linked in: aes_x86_64 glue_helper lrw ablk_helper cryptd gf128mul ipv6 pcspkr serio_raw virtio_net microcode virtio_pci virtio_ring virtio sr_mod cdrom [last unloaded: aesni_intel]
[ 3482.075639] CPU: 1 PID: 11065 Comm: crconf Not tainted 4.3.4-grsec+ #126
[ 3482.075639] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 3482.075639] task: ffff88001cd41a40 ti: ffff88001cd422c8 task.ti: ffff88001cd422c8
[ 3482.075639] RIP: 0010:[<ffffffff93722bd3>] [<ffffffff93722bd3>] strncpy+0x13/0x30
[ 3482.075639] RSP: 0018:ffff88001f713b60 EFLAGS: 00010202
[ 3482.075639] RAX: ffff88001f6c4430 RBX: ffff88001f6c43a0 RCX: ffff88001f6c4430
[ 3482.075639] RDX: 0000000000000040 RSI: fefefefefefeff16 RDI: ffff88001f6c4430
[ 3482.075639] RBP: ffff88001f713b60 R08: ffff88001f6c4470 R09: ffff88001f6c4480
[ 3482.075639] R10: 0000000000000002 R11: 0000000000000246 R12: ffff88001ce2aa28
[ 3482.075639] R13: ffff880000093700 R14: ffff88001f5e4bf8 R15: 0000000000003b20
[ 3482.075639] FS: 0000033826fa2700(0000) GS:ffff88001e900000(0000) knlGS:0000000000000000
[ 3482.075639] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3482.075639] CR2: ffffffffff600400 CR3: 00000000139ec000 CR4: 00000000001606f0
[ 3482.075639] Stack:
[ 3482.075639] ffff88001f713bd8 ffffffff936ccd00 ffff88001e5c4200 ffff880000093700
[ 3482.075639] ffff88001f713bd0 ffffffff938ef4bf 0000000000000000 0000000000003b20
[ 3482.075639] ffff88001f5e4bf8 ffff88001f5e4848 0000000000000000 0000000000003b20
[ 3482.075639] Call Trace:
[ 3482.075639] [<ffffffff936ccd00>] crypto_report_alg+0xc0/0x3e0
[ 3482.075639] [<ffffffff938ef4bf>] ? __alloc_skb+0x16f/0x300
[ 3482.075639] [<ffffffff936cd08a>] crypto_dump_report+0x6a/0x90
[ 3482.075639] [<ffffffff93935707>] netlink_dump+0x147/0x2e0
[ 3482.075639] [<ffffffff93935f99>] __netlink_dump_start+0x159/0x190
[ 3482.075639] [<ffffffff936ccb13>] crypto_user_rcv_msg+0xc3/0x130
[ 3482.075639] [<ffffffff936cd020>] ? crypto_report_alg+0x3e0/0x3e0
[ 3482.075639] [<ffffffff936cc4b0>] ? alg_test_crc32c+0x120/0x120
[ 3482.075639] [<ffffffff93933145>] ? __netlink_lookup+0xd5/0x120
[ 3482.075639] [<ffffffff936cca50>] ? crypto_add_alg+0x1d0/0x1d0
[ 3482.075639] [<ffffffff93938141>] netlink_rcv_skb+0xe1/0x130
[ 3482.075639] [<ffffffff936cc4f8>] crypto_netlink_rcv+0x28/0x40
[ 3482.075639] [<ffffffff939375a8>] netlink_unicast+0x108/0x180
[ 3482.075639] [<ffffffff93937c21>] netlink_sendmsg+0x541/0x770
[ 3482.075639] [<ffffffff938e31e1>] sock_sendmsg+0x21/0x40
[ 3482.075639] [<ffffffff938e4763>] SyS_sendto+0xf3/0x130
[ 3482.075639] [<ffffffff93444203>] ? bad_area_nosemaphore+0x13/0x20
[ 3482.075639] [<ffffffff93444470>] ? __do_page_fault+0x80/0x3a0
[ 3482.075639] [<ffffffff939d80cb>] entry_SYSCALL_64_fastpath+0x12/0x6e
[ 3482.075639] Code: 88 4a ff 75 ed 5d 48 0f ba 2c 24 3f c3 66 66 2e 0f 1f 84 00 00 00 00 00 55 48 85 d2 48 89 f8 48 89 f9 4c 8d 04 17 48 89 e5 74 15 <0f> b6 16 80 fa 01 88 11 48 83 de ff 48 83 c1 01 4c 39 c1 75 eb
[ 3482.075639] RIP [<ffffffff93722bd3>] strncpy+0x13/0x30
To trigger the race run the following loops simultaneously for a while:
$ while : ; do modprobe aesni-intel; rmmod aesni-intel; done
$ while : ; do crconf show all > /dev/null; done
Fix the race by taking the crypto_alg_sem read lock, thereby preventing
crypto_unregister_alg() from modifying the algorithm list during the
dump.
This bug has been detected by the PaX memory sanitize feature.
Cc: PaX Team <pageexec@freemail.hu>
commit fe09786178f9df713a4b2dd6b93c0a722346bf5e upstream.
hash_sendmsg/sendpage() need to wait for the completion
of crypto_ahash_init() otherwise it can cause panic.
commit 00420a65fa2beb3206090ead86942484df2275f3 upstream.
The has_key logic is wrong for shash algorithms as they always
have a setkey function. So we should instead be testing against
shash_no_setkey.
Fixes: a5596d633278 ("crypto: hash - Add crypto_ahash_has_setkey")
Reported-by: Stephan Mueller <smueller@chronox.de>
Tested-by: Stephan Mueller <smueller@chronox.de>
commit 202736d99b7f29279db9da61587f11a08a04a9c6 upstream.
We mark the end of the SG list in sendmsg and sendpage and unmark
it on the next send call. Unfortunately the unmarking in sendmsg
is off-by-one, leading to an SG list that is too short.
Fixes: 0f477b655a52 ("crypto: algif - Mark sgl end at the end of data")
commit 4f0414e54e4d1893c6f08260693f8ef84c929293 upstream.
We need to load the TX SG list in sendmsg(2) after waiting for
incoming data, not before.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
commit fd7f6727102a1ccf6b4c1dfcc631f9b546526b26 upstream.
I don't think it makes sense for a module to have a soft dependency
on itself. This seems quite cyclic by nature and I can't see what
purpose it could serve.
OTOH libcrc32c calls crypto_alloc_shash("crc32c", 0, 0) so it pretty
much assumes that some incarnation of the "crc32c" hash algorithm has
been loaded. Therefore it makes sense to have the soft dependency
there (as crc-t10dif does.)
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
commit 1822793a523e5d5730b19cc21160ff1717421bc8 upstream.
We need to lock the child socket in skcipher_check_key as otherwise
two simultaneous calls can cause the parent socket to be freed.
commit ad46d7e33219218605ea619e32553daf4f346b9f upstream.
We need to lock the child socket in hash_check_key as otherwise
commit a6a48c565f6f112c6983e2a02b1602189ed6e26e upstream.
This patch forbids the calling of bind(2) when there are child
sockets created by accept(2) in existence, even if they are created
on the nokey path.
This is needed as those child sockets have references to the tfm
object which bind(2) will destroy.
commit d7b65aee1e7b4c87922b0232eaba56a8a143a4a0 upstream.
This patch removes the custom release parent function as the
generic af_alg_release_parent now works for nokey sockets too.
commit f1d84af1835846a5a2b827382c5848faf2bb0e75 upstream.
commit 6a935170a980024dd29199e9dbb5c4da4767a1b9 upstream.
This patch allows af_alg_release_parent to be called even for
nokey sockets.
commit 6e8d8ecf438792ecf7a3207488fb4eebc4edb040 upstream.
This patch adds an exception to the key check so that cipher_null
users may continue to use algif_skcipher without setting a key.
commit a1383cd86a062fc798899ab20f0ec2116cce39cb upstream.
This patch adds a way for skcipher users to determine whether a key
is required by a transform.
