serpent-sse2 uses functions from LRW and XTS modules, so selecting would appear
to be better option than using #ifdefs in serpent_sse2_glue.c to enable/disable
LRW and XTS features.
This also fixes build problem when serpent-sse2 would be build into kernel but
XTS/LRW are build as modules.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
twofish-x86_64-3way uses functions from LRW and XTS modules, so selecting would
appear to be better option than using #ifdefs in twofish_glue_3way.c to
enable/disable LRW and XTS features.
This also fixes build problem when twofish-x86_64-3way would be build into
kernel but XTS/LRW are build as modules.
XTS has been EXPERIMENTAL since it was introduced in 2007. I'd say by now
it has seen enough testing to justify removal of EXPERIMENTAL tag.
CC: Rik Snel <rsnel@cube.dyndns.org>
LRW has been EXPERIMENTAL since it was introduced in 2006. I'd say by now
Since serpent_sse2_glue.c uses cryptd, CRYPTO_SERPENT_SSE2_X86_64 and
CRYPTO_SERPENT_SSE2_586 should be selecting CRYPTO_CRYPTD.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Now that serpent.c has been cleaned from checkpatch warnings,
we can do clean rename.
Do checkpatch fixes before rename to keep rename patch simple and clean.
Patch adds LRW support for serpent-sse2 by using lrw_crypt(). Patch has been
tested with tcrypt and automated filesystem tests.
Tcrypt benchmarks results (serpent-sse2/serpent_generic speed ratios):
Benchmark results with tcrypt:
Intel Celeron T1600 (x86_64) (fam:6, model:15, step:13):
size lrw-enc lrw-dec
16B 1.00x 0.96x
64B 1.01x 1.01x
256B 3.01x 2.97x
1024B 3.39x 3.33x
8192B 3.35x 3.33x
AMD Phenom II 1055T (x86_64) (fam:16, model:10):
16B 0.98x 1.03x
64B 1.01x 1.04x
256B 2.10x 2.14x
1024B 2.28x 2.33x
8192B 2.30x 2.33x
Intel Atom N270 (i586):
16B 0.97x 0.97x
64B 1.47x 1.50x
256B 1.72x 1.69x
1024B 1.88x 1.81x
8192B 1.84x 1.79x
Patch adds i586/SSE2 assembler implementation of serpent cipher. Assembler
functions crypt data in four block chunks.
Patch has been tested with tcrypt and automated filesystem tests.
Intel Atom N270:
size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec
16 0.95x 1.12x 1.02x 1.07x 0.97x 0.98x
64 1.73x 1.82x 1.08x 1.82x 1.72x 1.73x
256 2.08x 2.00x 1.04x 2.07x 1.99x 2.01x
1024 2.28x 2.18x 1.05x 2.23x 2.17x 2.20x
8192 2.28x 2.13x 1.05x 2.23x 2.18x 2.20x
Full output:
http://koti.mbnet.fi/axh/kernel/crypto/atom-n270/serpent-generic.txt
http://koti.mbnet.fi/axh/kernel/crypto/atom-n270/serpent-sse2.txt
Userspace test results:
Encryption/decryption of sse2-i586 vs generic on Intel Atom N270:
encrypt: 2.35x
decrypt: 2.54x
Encryption/decryption of sse2-i586 vs generic on AMD Phenom II:
encrypt: 1.82x
decrypt: 2.51x
Encryption/decryption of sse2-i586 vs generic on Intel Xeon E7330:
encrypt: 2.99x
decrypt: 3.48x
Patch adds x86_64/SSE2 assembler implementation of serpent cipher. Assembler
functions crypt data in eigth block chunks (two 4 block chunk SSE2 operations
in parallel to improve performance on out-of-order CPUs). Glue code is based
on one from AES-NI implementation, so requests from irq context are redirected
to cryptd.
v2:
- add missing include of linux/module.h
(appearently crypto.h used to include module.h, which changed for 3.2 by
commit 7c926402a7e8c9b279968fd94efec8700ba3859e)
AMD Phenom II 1055T (fam:16, model:10):
16B 1.03x 1.01x 1.03x 1.05x 1.00x 0.99x
64B 1.00x 1.01x 1.02x 1.04x 1.02x 1.01x
256B 2.34x 2.41x 0.99x 2.43x 2.39x 2.40x
1024B 2.51x 2.57x 1.00x 2.59x 2.56x 2.56x
8192B 2.50x 2.54x 1.00x 2.55x 2.57x 2.57x
Intel Celeron T1600 (fam:6, model:15, step:13):
16B 0.97x 0.97x 1.01x 1.01x 1.01x 1.02x
64B 1.00x 1.00x 1.00x 1.02x 1.01x 1.01x
256B 3.41x 3.35x 1.00x 3.39x 3.42x 3.44x
1024B 3.75x 3.72x 0.99x 3.74x 3.75x 3.75x
8192B 3.70x 3.68x 0.99x 3.68x 3.69x 3.69x
Full output:
http://koti.mbnet.fi/axh/kernel/crypto/phenom-ii-1055t/serpent-generic.txt
http://koti.mbnet.fi/axh/kernel/crypto/phenom-ii-1055t/serpent-sse2.txt
http://koti.mbnet.fi/axh/kernel/crypto/celeron-t1600/serpent-generic.txt
http://koti.mbnet.fi/axh/kernel/crypto/celeron-t1600/serpent-sse2.txt
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver
in the config and Makefile") as I have patch depending on that one.
Commits 2cdc6899a8 ("crypto: ghash - Add GHASH digest algorithm for
GCM") and 0e1227d356 ("crypto: ghash - Add PCLMULQDQ accelerated
implementation") added "select CRYPTO_SHASH" to two entries. That
Kconfig symbol doesn't exist. These two selects are nops. Drop them.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
* git://github.com/herbertx/crypto:
crypto: algapi - Fix build problem with NET disabled
crypto: user - Fix rwsem leak in crypto_user
The report functions use NLA_PUT so we need to ensure that NET
is enabled.
Reported-by: Luis Henriques <henrix@camandro.org>
Fix a typo in the Kconfig file help text.
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
We leak the crypto instance when we unregister an instance with
crypto_del_alg(). Therefore we introduce crypto_unregister_instance()
to unlink the crypto instance from the template's instances list and
to free the recources of the instance properly.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Apparently, NIST is tightening up its requirements for FIPS validation
with respect to RNGs. Its always been required that in fips mode, the
ansi cprng not be fed key and seed material that was identical, but
they're now interpreting FIPS 140-2, section AS07.09 as requiring that
the implementation itself must enforce the requirement. Easy fix, we
just do a memcmp of key and seed in fips_cprng_reset and call it a day.
v2: Per Neil's advice, ensure slen is sufficiently long before we
compare key and seed to avoid looking at potentially unallocated mem.
CC: Stephan Mueller <smueller@atsec.com>
CC: Steve Grubb <sgrubb@redhat.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Add test vectors for xts(twofish). These are generated from xts(twofish) test vectors.
Add test vectors for xts(serpent). These are generated from xts(aes) test vectors.
Add xts_crypt() function that can be used by cipher implementations that can
benefit from parallelized cipher operations.
XTS has fixed blocksize of 16. Define XTS_BLOCK_SIZE and use in place of
crypto_cipher_blocksize().
Patch adds LRW support for twofish-x86_64-3way by using lrw_crypt(). Patch has
Tcrypt benchmarks results (twofish-3way/twofish-asm speed ratios):
16B 0.99x 1.00x
64B 1.17x 1.17x
256B 1.26x 1.27x
1024B 1.30x 1.31x
8192B 1.31x 1.32x
16B 1.06x 1.01x
64B 1.08x 1.14x
256B 1.19x 1.20x
1024B 1.21x 1.22x
8192B 1.23x 1.24x
Add test vectors for lrw(twofish). These are generated from lrw(aes) test vectors.
Add test vectors for lrw(serpent). These are generated from lrw(aes) test vectors.
Export gf128mul table initialization routines and add lrw_crypt() function
that can be used by cipher implementations that can benefit from parallelized
cipher operations.
Split gf128mul initialization from setkey so that it can be used outside
lrw-module.
LRW has fixed blocksize of 16. Define LRW_BLOCK_SIZE and use in place of
LRW module leaks child cipher memory when init_tfm() fails because of child
block size not being 16.
Rename module from serpent.ko to serpent_generic.ko and add module alias. This
is to allow assembler implementation to autoload on 'modprobe serpent'. Also
add driver_name and priority for serpent cipher.
CC: Dag Arne Osvik <osvik@ii.uib.no>
implementations
Serpent SSE2 assembler implementations only provide 4-way/8-way parallel
functions and need setkey and one-block encrypt/decrypt functions.
Add test_acipher_speed for testing async block ciphers.
Also include tests for aes/des/des3/ede as these appear to have ablk_cipher
implementations available.
Add new serpent tests for serpent_sse2 x86_64/i586 8-way/4-way code paths.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
The list_empty case in crypto_alg_match() will return without calling
up_read() on crypto_alg_sem. We could do the "goto out" routine, but the
function will clearly do the right thing with that test simply removed.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
* git://github.com/herbertx/crypto: (48 commits)
crypto: user - Depend on NET instead of selecting it
crypto: user - Add dependency on NET
crypto: talitos - handle descriptor not found in error path
crypto: user - Initialise match in crypto_alg_match
crypto: testmgr - add twofish tests
crypto: testmgr - add blowfish test-vectors
crypto: Make hifn_795x build depend on !ARCH_DMA_ADDR_T_64BIT
crypto: twofish-x86_64-3way - fix ctr blocksize to 1
crypto: blowfish-x86_64 - fix ctr blocksize to 1
crypto: whirlpool - count rounds from 0
crypto: Add userspace report for compress type algorithms
crypto: Add userspace report for cipher type algorithms
crypto: Add userspace report for rng type algorithms
crypto: Add userspace report for pcompress type algorithms
crypto: Add userspace report for nivaead type algorithms
crypto: Add userspace report for aead type algorithms
crypto: Add userspace report for givcipher type algorithms
crypto: Add userspace report for ablkcipher type algorithms
crypto: Add userspace report for blkcipher type algorithms
crypto: Add userspace report for ahash type algorithms
Selecting NET causes all sorts of issues, including a dependency
loop involving bluetooth. This patch makes it a dependency instead.
Part of the include cleanups means that the implicit
inclusion of module.h via device.h is going away. So
fix things up in advance.
Since the configuration interface relies on netlink we need to
select NET.
We need to default match to 0 as otherwise it may lead to a false
positive.
Add tests for parallel twofish-x86_64-3way code paths.
Add tests for parallel blowfish-x86_64 code paths.
rc[0] is unused because rounds are counted from 1.
Save an u64!
