path: root/crypto
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-05raid6: fix recovery performance regressionDan Williams
The raid6 recovery code should immediately drop back to the optimized synchronous path when a p+q dma resource is not available. Otherwise we run the non-optimized/multi-pass async code in sync mode. Verified with raid6test (NDISKS=255) Applies to kernels >= 2.6.32. Cc: <stable@kernel.org> Acked-by: NeilBrown <neilb@suse.de> Reported-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: authenc - Add EINPROGRESS check
2010-04-26crypto: authenc - Add EINPROGRESS checkHerbert Xu
When Steffen originally wrote the authenc async hash patch, he correctly had EINPROGRESS checks in place so that we did not invoke the original completion handler with it. Unfortuantely I told him to remove it before the patch was applied. As only MAY_BACKLOG request completion handlers are required to handle EINPROGRESS completions, those checks are really needed. This patch restores them. Reported-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29Fix comment and Kconfig typos for 'require' and 'fragment'Gilles Espinasse
Signed-off-by: Gilles Espinasse <g.esp@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: padata: Allocate the cpumask for the padata instance crypto: authenc - Move saved IV in front of the ablkcipher request crypto: hash - Fix handling of unaligned buffers crypto: authenc - Use correct ahash complete functions crypto: md5 - Set statesize
2010-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: add __percpu sparse annotations to what's left percpu: add __percpu sparse annotations to fs percpu: add __percpu sparse annotations to core kernel subsystems local_t: Remove leftover local.h this_cpu: Remove pageset_notifier this_cpu: Page allocator conversion percpu, x86: Generic inc / dec percpu instructions local_t: Move local.h include to ringbuffer.c and ring_buffer_benchmark.c module: Use this_cpu_xx to dynamically allocate counters local_t: Remove cpu_local_xx macros percpu: refactor the code in pcpu_[de]populate_chunk() percpu: remove compile warnings caused by __verify_pcpu_ptr() percpu: make accessors check for percpu pointer in sparse percpu: add __percpu for sparse. percpu: make access macros universal percpu: remove per_cpu__ prefix.
2010-03-03crypto: authenc - Move saved IV in front of the ablkcipher requestSteffen Klassert
In crypto_authenc_encrypt() we save the IV behind the ablkcipher request. To save space on the request, we overwrite the ablkcipher request with a ahash request after encryption. So the IV may be overwritten by the ahash request. This patch fixes this by placing the IV in front of the ablkcipher/ahash request. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-03crypto: hash - Fix handling of unaligned buffersSzilveszter Ördög
The correct way to calculate the start of the aligned part of an unaligned buffer is: offset = ALIGN(offset, alignmask + 1); However, crypto_hash_walk_done() has: offset += alignmask - 1; offset = ALIGN(offset, alignmask + 1); which actually skips a whole block unless offset % (alignmask + 1) == 1. This patch fixes the problem. Signed-off-by: Szilveszter Ördög <slipszi@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-02crypto: authenc - Use correct ahash complete functionsSteffen Klassert
We accidentally assigned the ahash update complete function to the wrong function pointer in crypto_authenc_verify. This patch fixes this. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-02crypto: md5 - Set statesizeHerbert Xu
As md5 now has export/import functions, it must set the attribute statesize. Otherwise anything that relies on import/export may fail as they will see a zero statesize. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits) crypto: aes_generic - Fix checkpatch errors crypto: fcrypt - Fix checkpatch errors crypto: ecb - Fix checkpatch errors crypto: des_generic - Fix checkpatch errors crypto: deflate - Fix checkpatch errors crypto: crypto_null - Fix checkpatch errors crypto: cipher - Fix checkpatch errors crypto: crc32 - Fix checkpatch errors crypto: compress - Fix checkpatch errors crypto: cast6 - Fix checkpatch errors crypto: cast5 - Fix checkpatch errors crypto: camellia - Fix checkpatch errors crypto: authenc - Fix checkpatch errors crypto: api - Fix checkpatch errors crypto: anubis - Fix checkpatch errors crypto: algapi - Fix checkpatch errors crypto: blowfish - Fix checkpatch errors crypto: aead - Fix checkpatch errors crypto: ablkcipher - Fix checkpatch errors crypto: pcrypt - call the complete function on error ...
2010-02-17percpu: add __percpu sparse annotations to what's leftTejun Heo
Add __percpu sparse annotations to places which didn't make it in one of the previous patches. All converions are trivial. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Neil Brown <neilb@suse.de>
2010-02-16crypto: aes_generic - Fix checkpatch errorsRichard Hartmann
Signed-off-by: Richard Hartmann <richih.mailinglist@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-16crypto: fcrypt - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: ecb - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: des_generic - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: deflate - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: crypto_null - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: cipher - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: crc32 - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: compress - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: cast6 - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: cast5 - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: camellia - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: authenc - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: api - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: anubis - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: algapi - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: blowfish - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: aead - Fix checkpatch errorsRichard Hartmann
2010-02-16crypto: ablkcipher - Fix checkpatch errorsRichard Hartmann
2010-02-05crypto: fix typo in Kconfig help textJiri Kosina
Reported-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-04crypto: pcrypt - call the complete function on errorSteffen Klassert
This fixes three forgotten calls to the complete function in the error case. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-17crypto: md5 - Add export supportMax Vozeler
This patch adds export/import support to md5. The exported type is defined by struct md5_state. This is modeled after the equivalent change to sha1_generic. Signed-off-by: Max Vozeler <max@hinterhof.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-17crypto: gcm - Add RFC4543 wrapper for GCMTobias Brunner
This patch adds the RFC4543 (GMAC) wrapper for GCM similar to the existing RFC4106 wrapper. The main differences between GCM and GMAC are the contents of the AAD and that the plaintext is empty for the latter. Signed-off-by: Tobias Brunner <tobias@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-07crypto: pcrypt - Add pcrypt crypto parallelization wrapperSteffen Klassert
This patch adds a parallel crypto template that takes a crypto algorithm and converts it to process the crypto transforms in parallel. For the moment only aead algorithms are supported. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-12-30Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: drivers/dma: Correct use after free drivers/dma: drop unnecesary memset ioat2,3: put channel hardware in known state at init async_tx: expand async raid6 test to cover ioatdma corner case ioat3: fix p-disabled q-continuation sh: fix DMA driver's descriptor chaining and cookie assignment dma: at_hdmac: correct incompatible type for argument 1 of 'spin_lock_bh'
2009-12-23crypto: testmgr - Fix complain about lack test for internal used algorithmYouquan, Song
When load aesni-intel and ghash_clmulni-intel driver,kernel will complain no test for some internal used algorithm. The strange information as following: alg: No test for __aes-aesni (__driver-aes-aesni) alg: No test for __ecb-aes-aesni (__driver-ecb-aes-aesni) alg: No test for __cbc-aes-aesni (__driver-cbc-aes-aesni) alg: No test for __ecb-aes-aesni (cryptd(__driver-ecb-aes-aesni) alg: No test for __ghash (__ghash-pclmulqdqni) alg: No test for __ghash (cryptd(__ghash-pclmulqdqni)) This patch add NULL test entries for these algorithm and driver. Signed-off-by: Youquan, Song <youquan.song@intel.com> Signed-off-by: Ying, Huang <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-12-17async_tx: expand async raid6 test to cover ioatdma corner caseDan Williams
Add explicit 11 and 12 disks cases to exercise the 0 < src_cnt % 8 < 3 corner case in the ioatdma driver. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: hwrng: core - Prevent too-small buffer sizes hwrng: virtio-rng - Convert to new API hwrng: core - Replace u32 in driver API with byte array crypto: ansi_cprng - Move FIPS functions under CONFIG_CRYPTO_FIPS crypto: testmgr - Add ghash algorithm test before provide to users crypto: ghash-clmulni-intel - Put proper .data section in place crypto: ghash-clmulni-intel - Use gas macro for PCLMULQDQ-NI and PSHUFB crypto: aesni-intel - Use gas macro for AES-NI instructions x86: Generate .byte code for some new instructions via gas macro crypto: ghash-intel - Fix irq_fpu_usable usage crypto: ghash-intel - Add PSHUFB macros crypto: ghash-intel - Hard-code pshufb crypto: ghash-intel - Fix building failure on x86_32 crypto: testmgr - Fix warning crypto: ansi_cprng - Fix test in get_prng_bytes crypto: hash - Remove cra_u.{digest,hash} crypto: api - Remove digest case from procfs show handler crypto: hash - Remove legacy hash/digest code crypto: ansi_cprng - Add FIPS wrapper crypto: ghash - Add PCLMULQDQ accelerated implementation
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
2009-12-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Herbert Xu
2009-11-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: gcm - fix another complete call in complete fuction crypto: padlock-aes - Use the correct mask when checking whether copying is required
2009-11-23crypto: ansi_cprng - Move FIPS functions under CONFIG_CRYPTO_FIPSJaswinder Singh Rajput
fips_cprng_get_random and fips_cprng_reset is used only by CONFIG_CRYPTO_FIPS. This also fixes compilation warnings: crypto/ansi_cprng.c:360: warning: ‘fips_cprng_get_random’ defined but not used crypto/ansi_cprng.c:393: warning: ‘fips_cprng_reset’ defined but not used Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-11-23crypto: testmgr - Add ghash algorithm test before provide to usersYouquan, Song
Add ghash algorithm test before provide it to users Signed-off-by: Youquan, Song <youquan.song@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
