path: root/crypto
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-09[CRYPTO] cipher: Set alignmask for multi-byte loadsHerbert Xu
Many cipher implementations use 4-byte/8-byte loads/stores which require alignment on some architectures. This patch explicitly sets the alignment requirements for them. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] api: Require block size to be less than PAGE_SIZE/8Herbert Xu
The cipher code path may allocate up to two blocks of data on the stack. Therefore we need to place limits on the maximum block size. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] sha1: Fixed off-by-64 bug in sha1_updateHerbert Xu
After a partial update, the done pointer is off to the right by 64 bytes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] cipher: Align temporary buffer in cbc_process_decryptHerbert Xu
Since the temporary buffer is used as an argument to cia_decrypt, it must be aligned by cra_alignmask. This bug was found by linux@horizon.com. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] sha1: Avoid shifting count left and rightNicolas Pitre
This patch avoids shifting the count left and right needlessly for each call to sha1_update(). It instead can be done only once at the end in sha1_final(). Keeping the previous test example (sha1_update() successively called with len=64), a 1.3% performance increase can be observed on i386, or 0.2% on ARM. The generated code is also smaller on ARM. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] sha1: Rename i/j to done/partialNicolas Pitre
This patch gives more descriptive names to the variables i and j. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] sha1: Avoid useless memcpy()Nicolas Pitre
The current code unconditionally copy the first block for every call to sha1_update(). This can be avoided if there is no pending partial block. This is always the case on the first call to sha1_update() (if the length is >= 64 of course. Furthermore, temp does need to be called if sha_transform is never invoked. Also consolidate the sha_transform calls into one to reduce code size. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] Allow AES C/ASM implementations to coexistHerbert Xu
As the Crypto API now allows multiple implementations to be registered for the same algorithm, we no longer have to play tricks with Kconfig to select the right AES implementation. This patch sets the driver name and priority for all the AES implementations and removes the Kconfig conditions on the C implementation for AES. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] Allow multiple implementations of the same algorithmHerbert Xu
This is the first step on the road towards asynchronous support in the Crypto API. It adds support for having multiple crypto_alg objects for the same algorithm registered in the system. For example, each device driver would register a crypto_alg object for each algorithm that it supports. While at the same time the user may load software implementations of those same algorithms. Users of the Crypto API may then select a specific implementation by name, or choose any implementation for a given algorithm with the highest priority. The priority field is a 32-bit signed integer. In future it will be possible to modify it from user-space. This also provides a solution to the problem of selecting amongst various AES implementations, that is, aes vs. aes-i586 vs. aes-padlock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] Use standard byte order macros wherever possibleHerbert Xu
A lot of crypto code needs to read/write a 32-bit/64-bit words in a specific gender. Many of them open code them by reading/writing one byte at a time. This patch converts all the applicable usages over to use the standard byte order macros. This is based on a previous patch by Denis Vlasenko. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: in-kernel crypto test vectorsJan Glauber
Add new test vectors to the AES test suite for AES CBC and AES with plaintext larger than AES blocksize. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: aes supportJan Glauber
Add support for the hardware accelerated AES crypto algorithm. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: sha256 supportJan Glauber
Add support for the hardware accelerated sha256 crypto algorithm. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: in-kernel crypto renameJan Glauber
Replace all references to z990 by s390 in the in-kernel crypto files in arch/s390/crypto. The code is not specific to a particular machine (z990) but to the s390 platform. Big diff, does nothing.. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[CRYPTO] Check cra_alignmask against cra_blocksizeHerbert Xu
The cipher code relies on the fact that the block size is a multiple of the required alignment. So we should check this at the time of algorith registration. We also ensure that the block size is bounded by the page size. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-30[CRYPTO] Simplify one-member scatterlist expressionsHerbert Xu
This patch rewrites various occurences of &sg[0] where sg is an array of length one to simply sg. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-30[PATCH] Use sg_set_buf/sg_init_one where applicableDavid Hardeman
This patch uses sg_set_buf/sg_init_one in some places where it was duplicated. Signed-off-by: David Hardeman <david@2gen.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-09-06[CRYPTO] Fix boundary check in standard multi-block cipher processorsHerbert Xu
The boundary check in the standard multi-block cipher processors are broken when nbytes is not a multiple of bsize. In those cases it will always process an extra block. This patch corrects the check so that it processes at most nbytes of data. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01[CRYPTO]: Added CRYPTO_TFM_REQ_MAY_SLEEP flagHerbert Xu
The crypto layer currently uses in_atomic() to determine whether it is allowed to sleep. This is incorrect since spin locks don't always cause in_atomic() to return true. Instead of that, this patch returns to an earlier idea of a per-tfm flag which determines whether sleeping is allowed. Unlike the earlier version, the default is to not allow sleeping. This ensures that no existing code can break. As usual, this flag may either be set through crypto_alloc_tfm(), or just before a specific crypto operation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01[CRYPTO]: Fix XTEA implementationAaron Grothe
The XTEA implementation was incorrect due to a misinterpretation of operator precedence. Because of the wide-spread nature of this error, the erroneous implementation will be kept, albeit under the new name of XETA. Signed-off-by: Aaron Grothe <ajgrothe@yahoo.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-15[CRYPTO]: Fix zero-extension bug on 64-bit architectures.Herbert Xu
Noticed by Ken-ichirou MATSUZAWA. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Add faster DES code from Dag Arne OsvikDag Arne Osvik
I've made a new implementation of DES to replace the old one in the kernel. It provides faster encryption on all tested processors apart from the original Pentium, and key setup is many times faster. Speed relative to old kernel implementation Processor des_setkey des_encrypt des3_ede_setkey des3_ede_encrypt Pentium 120Mhz 6.8 0.82 7.2 0.86 Pentium III 1.266Ghz 5.6 1.19 5.8 1.34 Pentium M 1.3Ghz 5.7 1.15 6.0 1.31 Pentium 4 2.266Ghz 5.8 1.24 6.0 1.40 Pentium 4E 3Ghz 5.4 1.27 5.5 1.48 StrongARM 1110 206Mhz 4.3 1.03 4.4 1.14 Athlon XP 2Ghz 7.8 1.44 8.1 1.61 Athlon 64 2Ghz 7.8 1.34 8.3 1.49 Signed-off-by: Dag Arne Osvik <da@osvik.no> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Remove unused iv field from context structureHerbert Xu
The iv field in des_ctx/des3_ede_ctx/serpent_ctx has never been used. This was noticed by Dag Arne Osvik. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Add x86_64 asm AESAndreas Steinmetz
Implementation: =============== The encrypt/decrypt code is based on an x86 implementation I did a while ago which I never published. This unpublished implementation does include an assembler based key schedule and precomputed tables. For simplicity and best acceptance, however, I took Gladman's in-kernel code for table generation and key schedule for the kernel port of my assembler code and modified this code to produce the key schedule as required by my assembler implementation. File locations and Kconfig are kept similar to the i586 AES assembler implementation. It may seem a little bit strange to use 32 bit I/O and registers in the assembler implementation but this gives the best code size. My implementation takes one instruction more per round compared to Gladman's x86 assembler but it doesn't require any stack for local variables or saved registers and it is less serialized than Gladman's code. Note that all comparisons to Gladman's code were done after my code was implemented. I did only use FIPS PUB 197 for the implementation so my implementation is independent work. If anybody has a better assembler solution for x86_64 I'll be pleased to have my code replaced with the better solution. Testing: ======== The implementation passes the in-kernel crypto testing module and I'm running it without any problems on my laptop where it is mainly used for dm-crypt. Microbenchmark: =============== The microbenchmark was done in userspace with similar compile flags as used during kernel compile. Encrypt/decrypt is about 35% faster than the generic C implementation. As the generic C as well as my assembler implementation are both table I don't really expect that there is much room for further improvements though I'll be glad to be corrected here. The key schedule is about 5% slower than the generic C implementation. This is due to the fact that some more work has to be done in the key schedule routine to fit the schedule to the assembler implementation. Code Size: ========== Encrypt and decrypt are together about 2.1 Kbytes smaller than the generic C implementation which is important with regard to L1 cache usage. The key schedule routine is about 100 bytes larger than the generic C implementation. Data Size: ========== There's no difference in data size requirements between the assembler implementation and the generic C implementation. License: ======== Gladmans's code is dual BSD/GPL whereas my assembler code is GPLv2 only (I'm not going to change the license for my code). So I had to change the module license for the x86_64 aes module from 'Dual BSD/GPL' to 'GPL' to reflect the most restrictive license within the module. Signed-off-by: Andreas Steinmetz <ast@domdv.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Add null short circuit to crypto_free_tfmJesper Juhl
As far as I'm aware there's a general concensus that functions that are responsible for freeing resources should be able to cope with being passed a NULL pointer. This makes sense as it removes the need for all callers to check for NULL, thus elliminating the bugs that happen when some forget (safer to just check centrally in the freeing function) and it also makes for smaller code all over due to the lack of all those NULL checks. This patch makes it safe to pass the crypto_free_tfm() function a NULL pointer. Once this patch is applied we can start removing the NULL checks from the callers. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Handle unaligned iv from encrypt_iv/decrypt_ivHerbert Xu
Even though cit_iv is now always aligned, the user can still supply an unaligned iv through crypto_cipher_encrypt_iv/crypto_cipher_decrypt_iv. This patch will check the alignment of the user-supplied iv and copy it if necessary. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Ensure cit_iv is aligned correctlyHerbert Xu
This patch ensures that cit_iv is aligned according to cra_alignmask by allocating it as part of the tfm structure. As a side effect the crypto layer will also guarantee that the tfm ctx area has enough space to be aligned by cra_alignmask. This allows us to remove the extra space reservation from the Padlock driver. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Make crypto_alg_lookup staticAdrian Bunk
This patch makes a needlessly global function static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Add alignmask for low-level cipher implementationsHerbert Xu
The VIA Padlock device requires the input and output buffers to be aligned on 16-byte boundaries. This patch adds the alignmask attribute for low-level cipher implementations to indicate their alignment requirements. The mid-level crypt() function will copy the input/output buffers if they are not aligned correctly before they are passed to the low-level implementation. Strictly speaking, some of the software implementations require the buffers to be aligned on 4-byte boundaries as they do 32-bit loads. However, it is not clear whether it is better to copy the buffers or pay the penalty for unaligned loads/stores. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Add support for low-level multi-block operationsHerbert Xu
This patch adds hooks for cipher algorithms to implement multi-block ECB/CBC operations directly. This is expected to provide significant performance boots to the VIA Padlock. It could also be used for improving software implementations such as AES where operating on multiple blocks at a time may enable certain optimisations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Add plumbing for multi-block operationsHerbert Xu
The VIA Padlock device is able to perform much better when multiple blocks are fed to it at once. As this device offers an exceptional throughput rate it is worthwhile to optimise the infrastructure specifically for it. We shift the existing page-sized fast path down to the CBC/ECB functions. We can then replace the CBC/ECB functions with functions provided by the underlying algorithm that performs the multi-block operations. As a side-effect this improves the performance of large cipher operations for all existing algorithm implementations. I've measured the gain to be around 5% for 3DES and 15% for AES. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Don't check for NULL before kfree()Jesper Juhl
Checking a pointer for NULL before calling kfree() on it is redundant. This patch removes such checks from crypto/ Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Use CPU cycle counters in tcryptHerbert Xu
After using this facility for a while to test my changes to the cipher crypt() layer, I realised that I should've listend to Dave and made this thing use CPU cycle counters :) As it is it's too jittery for me to feel safe about relying on the results. So here is a patch to make it use CPU cycles by default but fall back to jiffies if the user specifies a non-zero sec value. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Use template keys for speed tests if possibleHerbert Xu
The existing keys used in the speed tests do not pass the 3DES quality check. This patch makes it use the template keys instead. Other algorithms can supply template keys through the same interface if needed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Add cipher speed testsHarald Welte
From: Reyk Floeter <reyk@vantronix.net> I recently had the requirement to do some benchmarking on cryptoapi, and I found reyk's very useful performance test patch [1]. However, I could not find any discussion on why that extension (or something providing a similar feature but different implementation) was not merged into mainline. If there was such a discussion, can someone please point me to the archive[s]? I've now merged the old patch into 2.6.12-rc1, the result can be found attached to this email. [1] http://lists.logix.cz/pipermail/padlock/2004/000010.html Signed-off-by: Harald Welte <laforge@gnumonks.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Kill unnecessary strncpy from tcryptHerbert Xu
It seems that bad code tends to get copied (see test_cipher_speed). So let's kill this idiom before it spreads any further. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: White space and coding style clean up in tcryptHerbert Xu
2005-05-23[CRYPTO]: Only reschedule if !in_atomic()Herbert Xu
The netlink gfp_any() problem made me double-check the uses of in_softirq() in crypto/*. It seems to me that we should be checking in_atomic() instead of in_softirq() in crypto_yield. Otherwise people calling the crypto ops with spin locks held or preemption disabled will get burnt, right? Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-17[PATCH] crypto: fix null encryption/compressionPatrick McHardy
null_encrypt() needs to copy the data in case src and dst are disjunct, null_compress() needs to copy the data in any case as far as I can tell. I joined compress/decompress and encrypt/decrypt to avoid duplicating code. Without this patch ESP null_enc packets look like this: IP (tos 0x0, ttl 64, id 23130, offset 0, flags [DF], length: 128) 10.0.0.1 > 10.0.0.2: ESP(spi=0x0f9ca149,seq=0x4) 0x0000: 4500 0080 5a5a 4000 4032 cbef 0a00 0001 E...ZZ@.@2...... 0x0010: 0a00 0002 0f9c a149 0000 0004 0000 0000 .......I........ 0x0020: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0030: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0040: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0050: 0000 .. IP (tos 0x0, ttl 64, id 256, offset 0, flags [DF], length: 128) 10.0.0.2 > 10.0.0.1: ESP(spi=0x0e4f7b51,seq=0x2) 0x0000: 4500 0080 0100 4000 4032 254a 0a00 0002 E.....@.@2%J.... 0x0010: 0a00 0001 0e4f 7b51 0000 0002 a8a8 a8a8 .....O{Q........ 0x0020: a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 ................ 0x0030: a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 ................ 0x0040: a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 ................ 0x0050: a8a8 .. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] uml: support AES i586 crypto driverPaolo 'Blaisorblade' Giarrusso
We want to make possible, for the user, to enable the i586 AES implementation. This requires a restructure. - Add a CONFIG_UML_X86 to notify that we are building a UML for i386. - Rename CONFIG_64_BIT to CONFIG_64BIT as is used for all other archs - Tell crypto/Kconfig that UML_X86 is as good as X86 - Tell it that it must exclude not X86_64 but 64BIT, which will give the same results. - Tell kbuild to descend down into arch/i386/crypto/ to build what's needed. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] crypto: call zlib end functions on deflate exit pathArtem B. Bityuckiy
In the deflate_[compress|uncompress|pcompress] functions we call the zlib_[in|de]flateReset function at the beginning. This is OK. But when we unload the deflate module we don't call zlib_[in|de]flateEnd to free all the zlib internal data. It looks like a bug for me. Please, consider the attached patch. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
