commit 72a763d805a48ac8c0bf48fdb510e84c12de51fe upstream.
The current code does not set the msg_namelen member to 0 and therefore
makes net/socket.c leak the local sockaddr_storage variable to userland
-- 128 bytes of kernel stack memory. Fix that.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit d3dde52209ab571e4e2ec26c66f85ad1355f7475 upstream.
rfc4543(gcm(*)) code for GMAC assumes that assoc scatterlist always contains
only one segment and only makes use of this first segment. However ipsec passes
assoc with three segments when using 'extended sequence number' thus in this
case rfc4543(gcm(*)) fails to function correctly. Patch fixes this issue.
Reported-by: Chaoxing Lin <Chaoxing.Lin@ultra-3eti.com>
Tested-by: Chaoxing Lin <Chaoxing.Lin@ultra-3eti.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
commit 9a5467bf7b6e9e02ec9c3da4e23747c05faeaac6 upstream.
Three errors resulting in kernel memory disclosure:
1/ The structures used for the netlink based crypto algorithm report API
are located on the stack. As snprintf() does not fill the remainder of
the buffer with null bytes, those stack bytes will be disclosed to users
of the API. Switch to strncpy() to fix this.
2/ crypto_report_one() does not initialize all field of struct
crypto_user_alg. Fix this to fix the heap info leak.
3/ For the module name we should copy only as many bytes as
module_name() returns -- not as much as the destination buffer could
hold. But the current code does not and therefore copies random data
from behind the end of the module name, as the module name is always
shorter than CRYPTO_MAX_ALG_NAME.
Also switch to use strncpy() to copy the algorithm's name and
driver_name. They are strings, after all.
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Pull crypto update from Herbert Xu:
- Added aesni/avx/x86_64 implementations for camellia.
- Optimised AVX code for cast5/serpent/twofish/cast6.
- Fixed vmac bug with unaligned input.
- Allow compression algorithms in FIPS mode.
- Optimised crc32c implementation for Intel.
- Misc fixes.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (32 commits)
crypto: caam - Updated SEC-4.0 device tree binding for ERA information.
crypto: testmgr - remove superfluous initializers for xts(aes)
crypto: testmgr - allow compression algs in fips mode
crypto: testmgr - add larger crc32c test vector to test FPU path in crc32c_intel
crypto: testmgr - clean alg_test_null entries in alg_test_descs[]
crypto: testmgr - remove fips_allowed flag from camellia-aesni null-tests
crypto: cast5/cast6 - move lookup tables to shared module
padata: use __this_cpu_read per-cpu helper
crypto: s5p-sss - Fix compilation error
crypto: picoxcell - Add terminating entry for platform_device_id table
crypto: omap-aes - select BLKCIPHER2
crypto: camellia - add AES-NI/AVX/x86_64 assembler implementation of camellia cipher
crypto: camellia-x86_64 - share common functions and move structures and function definitions to header file
crypto: tcrypt - add async speed test for camellia cipher
crypto: tegra-aes - fix error-valued pointer dereference
crypto: tegra - fix missing unlock on error case
crypto: cast5/avx - avoid using temporary stack buffers
crypto: serpent/avx - avoid using temporary stack buffers
crypto: twofish/avx - avoid using temporary stack buffers
crypto: cast6/avx - avoid using temporary stack buffers
The test vectors for 'xts(aes)' contain superfluous initializers.
Remove them.
Cc: Jarod Wilson <jarod@redhat.com>
When in fips mode, compression algoritms fails to initialize,
e.g. modprobe ubifs returns
UBIFS error: compr_init: cannot initialize compressor lzo, error -2
FIPS mode should not care about compression algoritms at all.
Patch just set fips_enabled flag to 1 to all compression algorithms
managed by testmgr.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Currently alg_test_null entries set .suite values to zero, which is unneeded.
So perform clean-up of null test entries.
Remove incorrect fips_allowed from camellia null-test entries. Caused by
incorrect copy-paste of aes-aesni null-tests into camellia-aesni null-tests.
CAST5 and CAST6 both use same lookup tables, which can be moved shared module
'cast_common'.
camellia cipher
This patch adds AES-NI/AVX/x86_64 assembler implementation of Camellia block
cipher. Implementation process data in sixteen block chunks, which are
byte-sliced and AES SubBytes is reused for Camellia s-box with help of pre-
and post-filtering.
Patch has been tested with tcrypt and automated filesystem tests.
tcrypt test results:
Intel Core i5-2450M:
camellia-aesni-avx vs camellia-asm-x86_64-2way:
128bit key: (lrw:256bit) (xts:256bit)
size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec
16B 0.98x 0.96x 0.99x 0.96x 0.96x 0.95x 0.95x 0.94x 0.97x 0.98x
64B 0.99x 0.98x 1.00x 0.98x 0.98x 0.99x 0.98x 0.93x 0.99x 0.98x
256B 2.28x 2.28x 1.01x 2.29x 2.25x 2.24x 1.96x 1.97x 1.91x 1.90x
1024B 2.57x 2.56x 1.00x 2.57x 2.51x 2.53x 2.19x 2.17x 2.19x 2.22x
8192B 2.49x 2.49x 1.00x 2.53x 2.48x 2.49x 2.17x 2.17x 2.22x 2.22x
256bit key: (lrw:384bit) (xts:512bit)
16B 0.97x 0.98x 0.99x 0.97x 0.97x 0.96x 0.97x 0.98x 0.98x 0.99x
64B 1.00x 1.00x 1.01x 0.99x 0.98x 0.99x 0.99x 0.99x 0.99x 0.99x
256B 2.37x 2.37x 1.01x 2.39x 2.35x 2.33x 2.10x 2.11x 1.99x 2.02x
1024B 2.58x 2.60x 1.00x 2.58x 2.56x 2.56x 2.28x 2.29x 2.28x 2.29x
8192B 2.50x 2.52x 1.00x 2.56x 2.51x 2.51x 2.24x 2.25x 2.26x 2.29x
corruption
cryptd_queue_worker attempts to prevent simultaneous accesses to crypto
workqueue by cryptd_enqueue_request using preempt_disable/preempt_enable.
However cryptd_enqueue_request might be called from softirq context,
so add local_bh_disable/local_bh_enable to prevent data corruption and
panics.
Bug report at http://marc.info/?l=linux-crypto-vger&m=134858649616319&w=2
v2:
- Disable software interrupts instead of hardware interrupts
Cc: stable@vger.kernel.org
Reported-by: Gurucharan Shetty <gurucharan.shetty@gmail.com>
Most DES3_EDE testvectors are short and do not test parallelised codepaths
well. Add larger testvectors to test large crypto operations and to test
multi-page crypto with DES3_EDE.
Most DES testvectors are short and do not test parallelised codepaths
multi-page crypto with DES.
Most AES testvectors are short and do not test parallelised codepaths
multi-page crypto with AES.
AVX2 implementation of serpent cipher processes 16 blocks parallel, so
we need to make test vectors larger to check parallel code paths.
AVX2 implementation of blowfish cipher processes 32 blocks parallel, so
AVX/AES-NI implementation of camellia cipher processes 16 blocks
parallel, so we need to make test vectors larger to check parallel
code paths.
VMAC implementation, as it is, does not work with blocks that
are not multiples of 128-bytes. Furthermore, this is a problem
when using the implementation on scatterlists, even
when the complete plain text is 128-byte multiple, as the pieces
that get passed to vmac_update can be pretty much any size.
I also added test cases for unaligned blocks.
Signed-off-by: Salman Qazi <sqazi@google.com>
This patch adds a test case in tcrypt to perform speed test for
crc32c checksum calculation.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
This patch adds the crc_pcl function that calculates CRC32C checksum using the
PCLMULQDQ instruction on processors that support this feature. This will
provide speedup over using CRC32 instruction only.
The usage of PCLMULQDQ necessitate the invocation of kernel_fpu_begin and
kernel_fpu_end and incur some overhead. So the new crc_pcl function is only
invoked for buffer size of 512 bytes or more. Larger sized
buffers will expect to see greater speedup. This feature is best used coupled
with eager_fpu which reduces the kernel_fpu_begin/end overhead. For
buffer size of 1K the speedup is around 1.6x and for buffer size greater than
4K, the speedup is around 3x compared to original implementation in crc32c-intel
module. Test was performed on Sandy Bridge based platform with constant frequency
set for cpu.
A white paper detailing the algorithm can be found here:
http://download.intel.com/design/intarch/papers/323405.pdf
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module signing support from Rusty Russell:
"module signing is the highlight, but it's an all-over David Howells frenzy..."
Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG.
* 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits)
X.509: Fix indefinite length element skip error handling
X.509: Convert some printk calls to pr_devel
asymmetric keys: fix printk format warning
MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking
MODSIGN: Make mrproper should remove generated files.
MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs
MODSIGN: Use the same digest for the autogen key sig as for the module sig
MODSIGN: Sign modules during the build process
MODSIGN: Provide a script for generating a key ID from an X.509 cert
MODSIGN: Implement module signature checking
MODSIGN: Provide module signing public keys to the kernel
MODSIGN: Automatically generate module signing keys if missing
MODSIGN: Provide Kconfig options
MODSIGN: Provide gitignore and make clean rules for extra files
MODSIGN: Add FIPS policy
module: signature checking hook
X.509: Add a crypto key parser for binary (DER) X.509 certificates
MPILIB: Provide a function to read raw data into an MPI
X.509: Add an ASN.1 decoder
X.509: Add simple ASN.1 grammar compiler
Pull md updates from NeilBrown:
- "discard" support, some dm-raid improvements and other assorted bits
and pieces.
* tag 'md-3.7' of git://neil.brown.name/md: (29 commits)
md: refine reporting of resync/reshape delays.
md/raid5: be careful not to resize_stripes too big.
md: make sure manual changes to recovery checkpoint are saved.
md/raid10: use correct limit variable
md: writing to sync_action should clear the read-auto state.
Subject: [PATCH] md:change resync_mismatches to atomic64_t to avoid races
md/raid5: make sure to_read and to_write never go negative.
md: When RAID5 is dirty, force reconstruct-write instead of read-modify-write.
md/raid5: protect debug message against NULL derefernce.
md/raid5: add some missing locking in handle_failed_stripe.
MD: raid5 avoid unnecessary zero page for trim
MD: raid5 trim support
md/bitmap:Don't use IS_ERR to judge alloc_page().
md/raid1: Don't release reference to device while handling read error.
raid: replace list_for_each_continue_rcu with new interface
add further __init annotations to crypto/xor.c
DM RAID: Fix for "sync" directive ineffectiveness
DM RAID: Fix comparison of index and quantity for "rebuild" parameter
DM RAID: Add rebuild capability for RAID10
DM RAID: Move 'rebuild' checking code to its own function
Allow particularly do_xor_speed() to be discarded post-init.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Some debugging printk() calls should've been converted to pr_devel() calls.
Do that now.
Fix printk format warning in x509_cert_parser.c:
crypto/asymmetric_keys/x509_cert_parser.c: In function 'x509_note_OID':
crypto/asymmetric_keys/x509_cert_parser.c:113:3: warning: format '%zu' expects type 'size_t', but argument 2 has type 'long unsigned int'
Builds cleanly on i386 and x86_64.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: linux-crypto@vger.kernel.org
The current choice of lifetime for the autogenerated X.509 of 100 years,
putting the validTo date in 2112, causes problems on 32-bit systems where a
32-bit time_t wraps in 2106. 64-bit x86_64 systems seem to be unaffected.
This can result in something like:
Loading module verification certificates
X.509: Cert 6e03943da0f3b015ba6ed7f5e0cac4fe48680994 has expired
MODSIGN: Problem loading in-kernel X.509 certificate (-127)
Or:
X.509: Cert 6e03943da0f3b015ba6ed7f5e0cac4fe48680994 is not yet valid
MODSIGN: Problem loading in-kernel X.509 certificate (-129)
Instead of turning the dates into time_t values and comparing, turn the system
clock and the ASN.1 dates into tm structs and compare those piecemeal instead.
Reported-by: Rusty Russell <rusty@rustcorp.com.au>
Acked-by: Josh Boyer <jwboyer@redhat.com>
Add a crypto key parser for binary (DER) encoded X.509 certificates. The
certificate is parsed and, if possible, the signature is verified.
An X.509 key can be added like this:
# keyctl padd crypto bar @s </tmp/x509.cert
15768135
and displayed like this:
# cat /proc/keys
00f09a47 I--Q--- 1 perm 39390000 0 0 asymmetri bar: X509.RSA e9fd6d08 []
Note that this only works with binary certificates. PEM encoded certificates
are ignored by the parser.
Note also that the X.509 key ID is not congruent with the PGP key ID, but for
the moment, they will match.
If a NULL or "" name is given to add_key(), then the parser will generate a key
description from the CertificateSerialNumber and Name fields of the
TBSCertificate:
00aefc4e I--Q--- 1 perm 39390000 0 0 asymmetri bfbc0cd76d050ea4:/C=GB/L=Cambridge/O=Red Hat/CN=kernel key: X509.RSA 0c688c7b []
gpg can produce a signature file where length of signature is less than the
modulus size because the amount of space an MPI takes up is kept as low as
possible by discarding leading zeros. This regularly happens for several
modules during the build.
Fix it by relaxing check in RSA verification code.
Thanks to Tomas Mraz and Miloslav Trmac for help.
Implement RSA public key cryptography [PKCS#1 / RFC3447]. At this time, only
the signature verification algorithm is supported. This uses the asymmetric
public key subtype to hold its key data.
Provide signature verification using an asymmetric-type key to indicate the
public key to be used.
The API is a single function that can be found in crypto/public_key.h:
int verify_signature(const struct key *key,
const struct public_key_signature *sig)
The first argument is the appropriate key to be used and the second argument
is the parsed signature data:
struct public_key_signature {
u8 *digest;
u16 digest_size;
enum pkey_hash_algo pkey_hash_algo : 8;
union {
MPI mpi[2];
struct {
MPI s; /* m^d mod n */
} rsa;
struct {
MPI r;
MPI s;
} dsa;
This should be filled in prior to calling the function. The hash algorithm
should already have been called and the hash finalised and the output should
be in a buffer pointed to by the 'digest' member.
Any extra data to be added to the hash by the hash format (eg. PGP) should
have been added by the caller prior to finalising the hash.
It is assumed that the signature is made up of a number of MPI values. If an
algorithm becomes available for which this is not the case, the above structure
will have to change.
It is also assumed that it will have been checked that the signature algorithm
matches the key algorithm.
Add a subtype for supporting asymmetric public-key encryption algorithms such
as DSA (FIPS-186) and RSA (PKCS#1 / RFC1337).
The instantiation data passed to the asymmetric key type are expected to be
formatted in some way, and there are several possible standard ways to format
the data.
The two obvious standards are OpenPGP keys and X.509 certificates. The latter
is especially useful when dealing with UEFI, and the former might be useful
when dealing with, say, eCryptfs.
Further, it might be desirable to provide formatted blobs that indicate
hardware is to be accessed to retrieve the keys or that the keys live
unretrievably in a hardware store, but that the keys can be used by means of
the hardware.
From userspace, the keys can be loaded using the keyctl command, for example,
an X.509 binary certificate:
keyctl padd asymmetric foo @s <dhowells.pem
or a PGP key:
keyctl padd asymmetric bar @s <dhowells.pub
or a pointer into the contents of the TPM:
keyctl add asymmetric zebra "TPM:04982390582905f8" @s
Inside the kernel, pluggable parsers register themselves and then get to
examine the payload data to see if they can handle it. If they can, they get
to:
(1) Propose a name for the key, to be used it the name is "" or NULL.
(2) Specify the key subtype.
(3) Provide the data for the subtype.
The key type asks the parser to do its stuff before a key is allocated and thus
before the name is set. If successful, the parser stores the suggested data
into the key_preparsed_payload struct, which will be either used (if the key is
successfully created and instantiated or updated) or discarded.
Create a key type that can be used to represent an asymmetric key type for use
in appropriate cryptographic operations, such as encryption, decryption,
signature generation and signature verification.
The key type is "asymmetric" and can provide access to a variety of
cryptographic algorithms.
Possibly, this would be better as "public_key" - but that has the disadvantage
that "public key" is an overloaded term.
- Optimised AES/SHA1 for ARM.
- IPsec ESN support in talitos and caam.
- x86_64/avx implementation of cast5/cast6.
- Add/use multi-algorithm registration helpers where possible.
- Added IBM Power7+ in-Nest support.
- Misc fixes.
Fix up trivial conflicts in crypto/Kconfig due to the sparc64 crypto
config options being added next to the new ARM ones.
[ Side note: cut-and-paste duplicate help texts make those conflicts
harder to read than necessary, thanks to git being smart about
minimizing conflicts and maximizing the common parts... ]
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (71 commits)
crypto: x86/glue_helper - fix storing of new IV in CBC encryption
crypto: cast5/avx - fix storing of new IV in CBC encryption
crypto: tcrypt - add missing tests for camellia and ghash
crypto: testmgr - make test_aead also test 'dst != src' code paths
crypto: testmgr - make test_skcipher also test 'dst != src' code paths
crypto: testmgr - add test vectors for CTR mode IV increasement
crypto: testmgr - add test vectors for partial ctr(cast5) and ctr(cast6)
crypto: testmgr - allow non-multi page and multi page skcipher tests from same test template
crypto: caam - increase TRNG clocks per sample
crypto, tcrypt: remove local_bh_disable/enable() around local_irq_disable/enable()
crypto: tegra-aes - fix error return code
crypto: crypto4xx - fix error return code
crypto: hifn_795x - fix error return code
crypto: ux500 - fix error return code
crypto: caam - fix error IDs for SEC v5.x RNG4
hwrng: mxc-rnga - Access data via structure
hwrng: mxc-rnga - Adapt clocks to new i.mx clock framework
crypto: caam - add IPsec ESN support
crypto: 842 - remove .cra_list initialization
Revert "[CRYPTO] cast6: inline bloat--"
Asking for this option on x86 seems a bit pointless.
Signed-off-by: Dave Jones <davej@redhat.com>
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
Pull sparc updates from David Miller:
"Largely this is simply adding support for the Niagara 4 cpu.
Major areas are perf events (chip now supports 4 counters and can
monitor any event on each counter), crypto (opcodes are availble for
sha1, sha256, sha512, md5, crc32c, AES, DES, CAMELLIA, and Kasumi
although the last is unsupported since we lack a generic crypto layer
Kasumi implementation), and an optimized memcpy.
Finally some cleanups by Peter Senna Tschudin."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next: (47 commits)
sparc64: Fix trailing whitespace in NG4 memcpy.
sparc64: Fix comment type in NG4 copy from user.
sparc64: Add SPARC-T4 optimized memcpy.
drivers/sbus/char: removes unnecessary semicolon
arch/sparc/kernel/pci_sun4v.c: removes unnecessary semicolon
sparc64: Fix function argument comment in camellia_sparc64_key_expand asm.
sparc64: Fix IV handling bug in des_sparc64_cbc_decrypt
sparc64: Add auto-loading mechanism to crypto-opcode drivers.
sparc64: Add missing pr_fmt define to crypto opcode drivers.
sparc64: Adjust crypto priorities.
sparc64: Use cpu_pgsz_mask for linear kernel mapping config.
sparc64: Probe cpu page size support more portably.
sparc64: Support 2GB and 16GB page sizes for kernel linear mappings.
sparc64: Fix bugs in unrolled 256-bit loops.
sparc64: Avoid code duplication in crypto assembler.
sparc64: Unroll CTR crypt loops in AES driver.
sparc64: Unroll ECB decryption loops in AES driver.
sparc64: Unroll ECB encryption loops in AES driver.
sparc64: Add ctr mode support to AES driver.
sparc64: Move AES driver over to a methods based implementation.
Add missing tests for ctr(camellia), lrw(camellia), xts(camellia) and ghash,
as these have test vectors available.
Currrently test_aead uses same buffer for destination and source. However
in any places, 'dst != src' take different path than 'dst == src' case.
Therefore make test_aead also run tests with destination buffer being
different than source buffer.
Currrently test_skcipher uses same buffer for destination and source. However
Therefore make test_skcipher also run tests with destination buffer being
More precisely, test 'long word' and 'long long word' overflow and carry
handling.
same test template
Allow non-multi page and multi page skcipher tests to be run on same test template, to avoid
duplicating data.
Ran into this while looking at some new crypto code using FPU
hitting a WARN_ON_ONCE(!irq_fpu_usable()) in the kernel_fpu_begin()
on a x86 kernel that uses the new eagerfpu model. In short, current eagerfpu
changes return 0 for interrupted_kernel_fpu_idle() and the in_interrupt()
thinks it is in the interrupt context because of the local_bh_disable().
Thus resulting in the WARN_ON().
Remove the local_bh_disable/enable() calls around the existing
local_irq_disable/enable() calls. local_irq_disable/enable() already
disables the BH.
[ If there are any other legitimate users calling kernel_fpu_begin() from
the process context but with BH disabled, then we can look into fixing the
irq_fpu_usable() in future. ]
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
net/netfilter/nfnetlink_log.c
net/netfilter/xt_LOG.c
Rather easy conflict resolution, the 'net' tree had bug fixes to make
sure we checked if a socket is a time-wait one or not and elide the
logging code if so.
Whereas on the 'net-next' side we are calculating the UID and GID from
the creds using different interfaces due to the user namespace changes
The authenc code doesn't deal with zero-length associated data
correctly and ends up constructing a zero-length sg entry which
causes a crash when it's fed into the crypto system.
This patch fixes this by avoiding the code-path that triggers
the SG construction if we have no associated data.
This isn't the most optimal fix as it means that we'll end up
using the fallback code-path even when we could still execute
the digest function. However, this isn't a big deal as nobody
but the test path would supply zero-length associated data.
Reported-by: Romain Francoise <romain@orebokech.com>
Tested-by: Romain Francoise <romain@orebokech.com>
It is a frequent mistake to confuse the netlink port identifier with a
process identifier. Try to reduce this confusion by renaming fields
that hold port identifiers portid instead of pid.
I have carefully avoided changing the structures exported to
userspace to avoid changing the userspace API.
I have successfully built an allyesconfig kernel with this change.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
This patch defines netlink_kernel_create as a wrapper function of
__netlink_kernel_create to hide the struct module *me parameter
(which seems to be THIS_MODULE in all existing netlink subsystems).
Suggested by David S. Miller.
