path: root/crypto
2016-04-12X.509: Fix leap year handling againDavid Howells
commit ac4cbedfdf55455b4c447f17f0fa027dbf02b2a6 upstream. There are still a couple of minor issues in the X.509 leap year handling: (1) To avoid doing a modulus-by-400 in addition to a modulus-by-100 when determining whether the year is a leap year or not, I divided the year by 100 after doing the modulus-by-100, thereby letting the compiler do one instruction for both, and then did a modulus-by-4. Unfortunately, I then passed the now-modified year value to mktime64() to construct a time value. Since this isn't a fast path and since mktime64() does a bunch of divisions, just condense down to "% 400". It's also easier to read. (2) The default month length for any February where the year doesn't divide by four exactly is obtained from the month_length[] array where the value is 29, not 28. This is fixed by altering the table. Reported-by: Rudolf Polzer <rpolzer@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12crypto: keywrap - memzero the correct memoryDan Carpenter
commit 2b8b28fd232233c22fb61009dd8b0587390d2875 upstream. We're clearing the wrong memory. The memory corruption is likely harmless because we weren't going to use that stack memory again but not zeroing is a potential information leak. Fixes: e28facde3c39 ('crypto: keywrap - add key wrapping block chaining mode') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Do not set MAY_BACKLOG on the async pathHerbert Xu
commit dad41997063723eaf5f77bc2015606a5a9bce320 upstream. The async path cannot use MAY_BACKLOG because it is not meant to block, which is what MAY_BACKLOG does. On the other hand, both the sync and async paths can make use of MAY_SLEEP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Do not dereference ctx without socket lockHerbert Xu
commit 6454c2b83f719057069777132b13949e4c6b6350 upstream. Any access to non-constant bits of the private context must be done under the socket lock, in particular, this includes ctx->req. This patch moves such accesses under the lock, and fetches the tfm from the parent socket which is guaranteed to be constant, rather than from ctx->req. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Do not assume that req is unchangedHerbert Xu
commit ec69bbfb9902c32a5c1492f2b1b8ad032a66d724 upstream. The async path in algif_skcipher assumes that the crypto completion function will be called with the original request. This is not necessarily the case. In fact there is no need for this anyway since we already embed information into the request with struct skcipher_async_req. This patch adds a pointer to that struct and then passes it as the data to the callback function. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: user - lock crypto_alg_list on alg dumpMathias Krause
commit 63e41ebc6630f39422d87f8a4bade1e793f37a01 upstream. We miss to take the crypto_alg_sem semaphore when traversing the crypto_alg_list for CRYPTO_MSG_GETALG dumps. This allows a race with crypto_unregister_alg() removing algorithms from the list while we're still traversing it, thereby leading to a use-after-free as show below: [ 3482.071639] general protection fault: 0000 [#1] SMP [ 3482.075639] Modules linked in: aes_x86_64 glue_helper lrw ablk_helper cryptd gf128mul ipv6 pcspkr serio_raw virtio_net microcode virtio_pci virtio_ring virtio sr_mod cdrom [last unloaded: aesni_intel] [ 3482.075639] CPU: 1 PID: 11065 Comm: crconf Not tainted 4.3.4-grsec+ #126 [ 3482.075639] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014 [ 3482.075639] task: ffff88001cd41a40 ti: ffff88001cd422c8 task.ti: ffff88001cd422c8 [ 3482.075639] RIP: 0010:[<ffffffff93722bd3>] [<ffffffff93722bd3>] strncpy+0x13/0x30 [ 3482.075639] RSP: 0018:ffff88001f713b60 EFLAGS: 00010202 [ 3482.075639] RAX: ffff88001f6c4430 RBX: ffff88001f6c43a0 RCX: ffff88001f6c4430 [ 3482.075639] RDX: 0000000000000040 RSI: fefefefefefeff16 RDI: ffff88001f6c4430 [ 3482.075639] RBP: ffff88001f713b60 R08: ffff88001f6c4470 R09: ffff88001f6c4480 [ 3482.075639] R10: 0000000000000002 R11: 0000000000000246 R12: ffff88001ce2aa28 [ 3482.075639] R13: ffff880000093700 R14: ffff88001f5e4bf8 R15: 0000000000003b20 [ 3482.075639] FS: 0000033826fa2700(0000) GS:ffff88001e900000(0000) knlGS:0000000000000000 [ 3482.075639] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 3482.075639] CR2: ffffffffff600400 CR3: 00000000139ec000 CR4: 00000000001606f0 [ 3482.075639] Stack: [ 3482.075639] ffff88001f713bd8 ffffffff936ccd00 ffff88001e5c4200 ffff880000093700 [ 3482.075639] ffff88001f713bd0 ffffffff938ef4bf 0000000000000000 0000000000003b20 [ 3482.075639] ffff88001f5e4bf8 ffff88001f5e4848 0000000000000000 0000000000003b20 [ 3482.075639] Call Trace: [ 3482.075639] [<ffffffff936ccd00>] crypto_report_alg+0xc0/0x3e0 [ 3482.075639] [<ffffffff938ef4bf>] ? __alloc_skb+0x16f/0x300 [ 3482.075639] [<ffffffff936cd08a>] crypto_dump_report+0x6a/0x90 [ 3482.075639] [<ffffffff93935707>] netlink_dump+0x147/0x2e0 [ 3482.075639] [<ffffffff93935f99>] __netlink_dump_start+0x159/0x190 [ 3482.075639] [<ffffffff936ccb13>] crypto_user_rcv_msg+0xc3/0x130 [ 3482.075639] [<ffffffff936cd020>] ? crypto_report_alg+0x3e0/0x3e0 [ 3482.075639] [<ffffffff936cc4b0>] ? alg_test_crc32c+0x120/0x120 [ 3482.075639] [<ffffffff93933145>] ? __netlink_lookup+0xd5/0x120 [ 3482.075639] [<ffffffff936cca50>] ? crypto_add_alg+0x1d0/0x1d0 [ 3482.075639] [<ffffffff93938141>] netlink_rcv_skb+0xe1/0x130 [ 3482.075639] [<ffffffff936cc4f8>] crypto_netlink_rcv+0x28/0x40 [ 3482.075639] [<ffffffff939375a8>] netlink_unicast+0x108/0x180 [ 3482.075639] [<ffffffff93937c21>] netlink_sendmsg+0x541/0x770 [ 3482.075639] [<ffffffff938e31e1>] sock_sendmsg+0x21/0x40 [ 3482.075639] [<ffffffff938e4763>] SyS_sendto+0xf3/0x130 [ 3482.075639] [<ffffffff93444203>] ? bad_area_nosemaphore+0x13/0x20 [ 3482.075639] [<ffffffff93444470>] ? __do_page_fault+0x80/0x3a0 [ 3482.075639] [<ffffffff939d80cb>] entry_SYSCALL_64_fastpath+0x12/0x6e [ 3482.075639] Code: 88 4a ff 75 ed 5d 48 0f ba 2c 24 3f c3 66 66 2e 0f 1f 84 00 00 00 00 00 55 48 85 d2 48 89 f8 48 89 f9 4c 8d 04 17 48 89 e5 74 15 <0f> b6 16 80 fa 01 88 11 48 83 de ff 48 83 c1 01 4c 39 c1 75 eb [ 3482.075639] RIP [<ffffffff93722bd3>] strncpy+0x13/0x30 To trigger the race run the following loops simultaneously for a while: $ while : ; do modprobe aesni-intel; rmmod aesni-intel; done $ while : ; do crconf show all > /dev/null; done Fix the race by taking the crypto_alg_sem read lock, thereby preventing crypto_unregister_alg() from modifying the algorithm list during the dump. This bug has been detected by the PaX memory sanitize feature. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: PaX Team <pageexec@freemail.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_hash - wait for crypto_ahash_init() to completeWang, Rui Y
commit fe09786178f9df713a4b2dd6b93c0a722346bf5e upstream. hash_sendmsg/sendpage() need to wait for the completion of crypto_ahash_init() otherwise it can cause panic. Signed-off-by: Rui Wang <rui.y.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: shash - Fix has_key settingHerbert Xu
commit 00420a65fa2beb3206090ead86942484df2275f3 upstream. The has_key logic is wrong for shash algorithms as they always have a setkey function. So we should instead be testing against shash_no_setkey. Fixes: a5596d633278 ("crypto: hash - Add crypto_ahash_has_setkey") Reported-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - sendmsg SG marking is off by oneHerbert Xu
commit 202736d99b7f29279db9da61587f11a08a04a9c6 upstream. We mark the end of the SG list in sendmsg and sendpage and unmark it on the next send call. Unfortunately the unmarking in sendmsg is off-by-one, leading to an SG list that is too short. Fixes: 0f477b655a52 ("crypto: algif - Mark sgl end at the end of data") Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Load TX SG list after waitingHerbert Xu
commit 4f0414e54e4d1893c6f08260693f8ef84c929293 upstream. We need to load the TX SG list in sendmsg(2) after waiting for incoming data, not before. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: crc32c - Fix crc32c soft dependencyJean Delvare
commit fd7f6727102a1ccf6b4c1dfcc631f9b546526b26 upstream. I don't think it makes sense for a module to have a soft dependency on itself. This seems quite cyclic by nature and I can't see what purpose it could serve. OTOH libcrc32c calls crypto_alloc_shash("crc32c", 0, 0) so it pretty much assumes that some incarnation of the "crc32c" hash algorithm has been loaded. Therefore it makes sense to have the soft dependency there (as crc-t10dif does.) Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Fix race condition in skcipher_check_keyHerbert Xu
commit 1822793a523e5d5730b19cc21160ff1717421bc8 upstream. We need to lock the child socket in skcipher_check_key as otherwise two simultaneous calls can cause the parent socket to be freed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_hash - Fix race condition in hash_check_keyHerbert Xu
commit ad46d7e33219218605ea619e32553daf4f346b9f upstream. We need to lock the child socket in hash_check_key as otherwise two simultaneous calls can cause the parent socket to be freed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Forbid bind(2) when nokey child sockets are presentHerbert Xu
commit a6a48c565f6f112c6983e2a02b1602189ed6e26e upstream. This patch forbids the calling of bind(2) when there are child sockets created by accept(2) in existence, even if they are created on the nokey path. This is needed as those child sockets have references to the tfm object which bind(2) will destroy. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Remove custom release parent functionHerbert Xu
commit d7b65aee1e7b4c87922b0232eaba56a8a143a4a0 upstream. This patch removes the custom release parent function as the generic af_alg_release_parent now works for nokey sockets too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_hash - Remove custom release parent functionHerbert Xu
commit f1d84af1835846a5a2b827382c5848faf2bb0e75 upstream. This patch removes the custom release parent function as the generic af_alg_release_parent now works for nokey sockets too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Allow af_af_alg_release_parent to be called on nokey pathHerbert Xu
commit 6a935170a980024dd29199e9dbb5c4da4767a1b9 upstream. This patch allows af_alg_release_parent to be called even for nokey sockets. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Add key check exception for cipher_nullHerbert Xu
commit 6e8d8ecf438792ecf7a3207488fb4eebc4edb040 upstream. This patch adds an exception to the key check so that cipher_null users may continue to use algif_skcipher without setting a key. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: skcipher - Add crypto_skcipher_has_setkeyHerbert Xu
commit a1383cd86a062fc798899ab20f0ec2116cce39cb upstream. This patch adds a way for skcipher users to determine whether a key is required by a transform. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_hash - Require setkey before accept(2)Herbert Xu
commit 6de62f15b581f920ade22d758f4c338311c2f0d4 upstream. Hash implementations that require a key may crash if you use them without setting a key. This patch adds the necessary checks so that if you do attempt to use them without a key that we return -ENOKEY instead of proceeding. This patch also adds a compatibility path to support old applications that do acept(2) before setkey. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: hash - Add crypto_ahash_has_setkeyHerbert Xu
commit a5596d6332787fd383b3b5427b41f94254430827 upstream. This patch adds a way for ahash users to determine whether a key is required by a crypto_ahash transform. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Add nokey compatibility pathHerbert Xu
commit a0fa2d037129a9849918a92d91b79ed6c7bd2818 upstream. This patch adds a compatibility path to support old applications that do acept(2) before setkey. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Add nokey compatibility pathHerbert Xu
commit 37766586c965d63758ad542325a96d5384f4a8c9 upstream. This patch adds a compatibility path to support old applications that do acept(2) before setkey. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Fix socket double-free when accept failsHerbert Xu
commit a383292c86663bbc31ac62cc0c04fc77504636a6 upstream. When we fail an accept(2) call we will end up freeing the socket twice, once due to the direct sk_free call and once again through newsock. This patch fixes this by removing the sk_free call. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Disallow bind/setkey/... after accept(2)Herbert Xu
commit c840ac6af3f8713a71b4d2363419145760bd6044 upstream. Each af_alg parent socket obtained by socket(2) corresponds to a tfm object once bind(2) has succeeded. An accept(2) call on that parent socket creates a context which then uses the tfm object. Therefore as long as any child sockets created by accept(2) exist the parent socket must not be modified or freed. This patch guarantees this by using locks and a reference count on the parent socket. Any attempt to modify the parent socket will fail with EBUSY. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Require setkey before accept(2)Herbert Xu
commit dd504589577d8e8e70f51f997ad487a4cb6c026f upstream. Some cipher implementations will crash if you try to use them without calling setkey first. This patch adds a check so that the accept(2) call will fail with -ENOKEY if setkey hasn't been done on the socket yet. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-07async_tx: use GFP_NOWAIT rather than GFP_IONeilBrown
These async_XX functions are called from md/raid5 in an atomic section, between get_cpu() and put_cpu(), so they must not sleep. So use GFP_NOWAIT rather than GFP_IO. Dan Williams writes: Longer term async_tx needs to be merged into md directly as we can allocate this unmap data statically per-stripe rather than per request. Fixed: 7476bd79fc01 ("async_pq: convert to dmaengine_unmap_data") Cc: stable@vger.kernel.org (v3.13+) Reported-and-tested-by: Stanislav Samsonov <slava@annapurnalabs.com> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-12-28Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fix from Herbert Xu: "This fixes a bug in the algif_skcipher interface that can trigger a kernel WARN_ON from user-space. It does so by using the new skcipher interface which unlike the previous ablkcipher does not need to create extra geniv objects which is what was used to trigger the WARN_ON" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: algif_skcipher - Use new skcipher interface
2015-12-22crypto: algif_skcipher - Use new skcipher interfaceHerbert Xu
This patch replaces uses of ablkcipher with the new skcipher interface. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: <smueller@chronox.de>
2015-12-15Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fix from Herbert Xu: "This fixes a boundary condition in the blkcipher SG walking code that can lead to a crash when used with the new chacha20 algorithm" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: skcipher - Copy iv from desc even for 0-len walks
2015-12-09crypto: skcipher - Copy iv from desc even for 0-len walksJason A. Donenfeld
Some ciphers actually support encrypting zero length plaintexts. For example, many AEAD modes support this. The resulting ciphertext for those winds up being only the authentication tag, which is a result of the key, the iv, the additional data, and the fact that the plaintext had zero length. The blkcipher constructors won't copy the IV to the right place, however, when using a zero length input, resulting in some significant problems when ciphers call their initialization routines, only to find that the ->iv parameter is uninitialized. One such example of this would be using chacha20poly1305 with a zero length input, which then calls chacha20, which calls the key setup routine, which eventually OOPSes due to the uninitialized ->iv member. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Cc: <stable@vger.kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-12-01net: rename SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATAEric Dumazet
This patch is a cleanup to make following patch easier to review. Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA from (struct socket)->flags to a (struct socket_wq)->flags to benefit from RCU protection in sock_wake_async() To ease backports, we rename both constants. Two new helpers, sk_set_bit(int nr, struct sock *sk) and sk_clear_bit(int net, struct sock *sk) are added so that following patch can change their implementation. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-12X.509: Fix the time validation [ver #2]David Howells
This fixes CVE-2015-5327. It affects kernels from 4.3-rc1 onwards. Fix the X.509 time validation to use month number-1 when looking up the number of days in that month. Also put the month number validation before doing the lookup so as not to risk overrunning the array. This can be tested by doing the following: cat <<EOF | openssl x509 -outform DER | keyctl padd asymmetric "" @s -----BEGIN CERTIFICATE----- MIIDbjCCAlagAwIBAgIJAN/lUld+VR4hMA0GCSqGSIb3DQEBCwUAMCkxETAPBgNV BAoMCGxvY2FsLWNhMRQwEgYDVQQDDAtzaWduaW5nIGtleTAeFw0xNTA5MDEyMTMw MThaFw0xNjA4MzEyMTMwMThaMCkxETAPBgNVBAoMCGxvY2FsLWNhMRQwEgYDVQQD DAtzaWduaW5nIGtleTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBANrn crcMfMeG67nagX4+m02Xk9rkmsMKI5XTUxbikROe7GSUVJ27sPVPZp4mgzoWlvhh jfK8CC/qhEhwep8Pgg4EJZyWOjhZb7R97ckGvLIoUC6IO3FC2ZnR7WtmWDgo2Jcj VlXwJdHhKU1VZwulh81O61N8IBKqz2r/kDhIWiicUCUkI/Do/RMRfKAoDBcSh86m gOeIAGfq62vbiZhVsX5dOE8Oo2TK5weAvwUIOR7OuGBl5AqwFlPnXQolewiHzKry THg9e44HfzG4Mi6wUvcJxVaQT1h5SrKD779Z5+8+wf1JLaooetcEUArvWyuxCU59 qxA4lsTjBwl4cmEki+cCAwEAAaOBmDCBlTAMBgNVHRMEBTADAQH/MAsGA1UdDwQE AwIHgDAdBgNVHQ4EFgQUyND/eKUis7ep/hXMJ8iZMdUhI+IwWQYDVR0jBFIwUIAU yND/eKUis7ep/hXMJ8iZMdUhI+KhLaQrMCkxETAPBgNVBAoMCGxvY2FsLWNhMRQw EgYDVQQDDAtzaWduaW5nIGtleYIJAN/lUld+VR4hMA0GCSqGSIb3DQEBCwUAA4IB AQAMqm1N1yD5pimUELLhT5eO2lRdGUfTozljRxc7e2QT3RLk2TtGhg65JFFN6eml XS58AEPVcAsSLDlR6WpOpOLB2giM0+fV/eYFHHmh22yqTJl4YgkdUwyzPdCHNOZL hmSKeY9xliHb6PNrNWWtZwhYYvRaO2DX4GXOMR0Oa2O4vaYu6/qGlZOZv3U6qZLY wwHEJSrqeBDyMuwN+eANHpoSpiBzD77S4e+7hUDJnql4j6xzJ65+nWJ89fCrQypR 4sN5R3aGeIh3QAQUIKpHilwek0CtEaYERgc5m+jGyKSc1rezJW62hWRTaitOc+d5 G5hh+9YpnYcxQHEKnZ7rFNKJ -----END CERTIFICATE----- EOF If it works, it emit a key ID; if it fails, it should give a bad message error. Reported-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-11-11Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fix from Herbert Xu: "This fixes a bug in the algif_hash interface that may lead to crashes when used with certain algorithms such as HMAC" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: algif_hash - Only export and import on sockets with data
2015-11-05Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem update from James Morris: "This is mostly maintenance updates across the subsystem, with a notable update for TPM 2.0, and addition of Jarkko Sakkinen as a maintainer of that" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (40 commits) apparmor: clarify CRYPTO dependency selinux: Use a kmem_cache for allocation struct file_security_struct selinux: ioctl_has_perm should be static selinux: use sprintf return value selinux: use kstrdup() in security_get_bools() selinux: use kmemdup in security_sid_to_context_core() selinux: remove pointless cast in selinux_inode_setsecurity() selinux: introduce security_context_str_to_sid selinux: do not check open perm on ftruncate call selinux: change CONFIG_SECURITY_SELINUX_CHECKREQPROT_VALUE default KEYS: Merge the type-specific data with the payload data KEYS: Provide a script to extract a module signature KEYS: Provide a script to extract the sys cert list from a vmlinux file keys: Be more consistent in selection of union members used certs: add .gitignore to stop git nagging about x509_certificate_list KEYS: use kvfree() in add_key Smack: limited capability for changing process label TPM: remove unnecessary little endian conversion vTPM: support little endian guests char: Drop owner assignment from i2c_driver ...
2015-11-04Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto update from Herbert Xu: "API: - Add support for cipher output IVs in testmgr - Add missing crypto_ahash_blocksize helper - Mark authenc and des ciphers as not allowed under FIPS. Algorithms: - Add CRC support to 842 compression - Add keywrap algorithm - A number of changes to the akcipher interface: + Separate functions for setting public/private keys. + Use SG lists. Drivers: - Add Intel SHA Extension optimised SHA1 and SHA256 - Use dma_map_sg instead of custom functions in crypto drivers - Add support for STM32 RNG - Add support for ST RNG - Add Device Tree support to exynos RNG driver - Add support for mxs-dcp crypto device on MX6SL - Add xts(aes) support to caam - Add ctr(aes) and xts(aes) support to qat - A large set of fixes from Russell King for the marvell/cesa driver" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (115 commits) crypto: asymmetric_keys - Fix unaligned access in x509_get_sig_params() crypto: akcipher - Don't #include crypto/public_key.h as the contents aren't used hwrng: exynos - Add Device Tree support hwrng: exynos - Fix missing configuration after suspend to RAM hwrng: exynos - Add timeout for waiting on init done dt-bindings: rng: Describe Exynos4 PRNG bindings crypto: marvell/cesa - use __le32 for hardware descriptors crypto: marvell/cesa - fix missing cpu_to_le32() in mv_cesa_dma_add_op() crypto: marvell/cesa - use memcpy_fromio()/memcpy_toio() crypto: marvell/cesa - use gfp_t for gfp flags crypto: marvell/cesa - use dma_addr_t for cur_dma crypto: marvell/cesa - use readl_relaxed()/writel_relaxed() crypto: caam - fix indentation of close braces crypto: caam - only export the state we really need to export crypto: caam - fix non-block aligned hash calculation crypto: caam - avoid needlessly saving and restoring caam_hash_ctx crypto: caam - print errno code when hash registration fails crypto: marvell/cesa - fix memory leak crypto: marvell/cesa - fix first-fragment handling in mv_cesa_ahash_dma_last_req() crypto: marvell/cesa - rearrange handling for sw padded hashes ...
2015-11-02crypto: algif_hash - Only export and import on sockets with dataHerbert Xu
The hash_accept call fails to work on sockets that have not received any data. For some algorithm implementations it may cause crashes. This patch fixes this by ensuring that we only export and import on sockets that have received data. Cc: stable@vger.kernel.org Reported-by: Harsh Jain <harshjain.prof@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Stephan Mueller <smueller@chronox.de>
2015-10-28Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fix from Herbert Xu: "This fixes a problem in the Crypto API that may cause spurious errors when signals are received by the process that made the orignal system call into the kernel" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: api - Only abort operations on fatal signal
2015-10-21KEYS: Merge the type-specific data with the payload dataDavid Howells
Merge the type-specific data with the payload data into one four-word chunk as it seems pointless to keep them separate. Use user_key_payload() for accessing the payloads of overloaded user-defined keys. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-cifs@vger.kernel.org cc: ecryptfs@vger.kernel.org cc: linux-ext4@vger.kernel.org cc: linux-f2fs-devel@lists.sourceforge.net cc: linux-nfs@vger.kernel.org cc: ceph-devel@vger.kernel.org cc: linux-ima-devel@lists.sourceforge.net
2015-10-20crypto: asymmetric_keys - Fix unaligned access in x509_get_sig_params()Sowmini Varadhan
x509_get_sig_params() has the same code pattern as the one in pkcs7_verify() that is fixed by commit 62f57d05e287 ("crypto: pkcs7 - Fix unaligned access in pkcs7_verify()") so apply a similar fix here: make sure that desc is pointing at an algined value past the digest_size, and take alignment values into consideration when doing kzalloc() Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-20crypto: akcipher - Don't #include crypto/public_key.h as the contents aren't ↵David Howells
used Don't #include crypto/public_key.h in akcipher as the contents of the header aren't used and changes in a future patch cause it to fail to compile if CONFIG_KEYS=n. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-20crypto: api - Only abort operations on fatal signalHerbert Xu
Currently a number of Crypto API operations may fail when a signal occurs. This causes nasty problems as the caller of those operations are often not in a good position to restart the operation. In fact there is currently no need for those operations to be interrupted by user signals at all. All we need is for them to be killable. This patch replaces the relevant calls of signal_pending with fatal_signal_pending, and wait_for_completion_interruptible with wait_for_completion_killable, respectively. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-15crypto: keywrap - add testmgr supportStephan Mueller
The testmanager code for symmetric ciphers is extended to allow verification of the IV after a cipher operation. In addition, test vectors for kw(aes) for encryption and decryption are added. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-15crypto: keywrap - enable compilationStephan Mueller
Hook keywrap source code into Kconfig and Makefile Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-15crypto: keywrap - add key wrapping block chaining modeStephan Mueller
This patch implements the AES key wrapping as specified in NIST SP800-38F and RFC3394. The implementation covers key wrapping without padding. IV handling: The caller does not provide an IV for encryption, but must obtain the IV after encryption which would serve as the first semblock in the ciphertext structure defined by SP800-38F. Conversely, for decryption, the caller must provide the first semiblock of the data as the IV and the following blocks as ciphertext. The key wrapping is an authenticated decryption operation. The caller will receive EBADMSG during decryption if the authentication failed. Albeit the standards define the key wrapping for AES only, the template can be used with any other block cipher that has a block size of 16 bytes. During initialization of the template, that condition is checked. Any cipher not having a block size of 16 bytes will cause the initialization to fail. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-15crypto: testmgr - test IV value after a cipher operationBoris BREZILLON
The crypto drivers are supposed to update the IV passed to the crypto request before calling the completion callback. Test for the IV value before considering the test as successful. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-14crypto: pkcs7 - Fix unaligned access in pkcs7_verify()Sowmini Varadhan
On sparc, we see unaligned access messages on each modprobe[-r]: Kernel unaligned access at TPC[6ad9b4] pkcs7_verify [..] Kernel unaligned access at TPC[6a5484] crypto_shash_finup [..] Kernel unaligned access at TPC[6a5390] crypto_shash_update [..] Kernel unaligned access at TPC[10150308] sha1_sparc64_update [..] Kernel unaligned access at TPC[101501ac] __sha1_sparc64_update [..] These ware triggered by mod_verify_sig() invocations of pkcs_verify(), and are are being caused by an unaligned desc at (sha1, digest_size is 0x14) desc = digest + digest_size; To fix this, pkcs7_verify needs to make sure that desc is pointing at an aligned value past the digest_size, and kzalloc appropriately, taking alignment values into consideration. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-14crypto: jitterentropy - remove unnecessary information from a commentAlexander Kuleshov
The clocksource does not provide clocksource_register() function since f893598 commit (clocksource: Mostly kill clocksource_register()), so let's remove unnecessary information about this function from a comment. Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com> Suggested-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-14crypto: akcipher - Changes to asymmetric key APITadeusz Struk
Setkey function has been split into set_priv_key and set_pub_key. Akcipher requests takes sgl for src and dst instead of void *. Users of the API i.e. two existing RSA implementation and test mgr code have been updated accordingly. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: "This fixes the following issues: - Fix AVX detection to prevent use of non-existent AESNI. - Some SPARC ciphers did not set their IV size which may lead to memory corruption" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: ahash - ensure statesize is non-zero crypto: camellia_aesni_avx - Fix CPU feature checks crypto: sparc - initialize blkcipher.ivsize
