path: root/crypto
2010-10-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits) DMAENGINE: move COH901318 to arch_initcall dma: imx-dma: fix signedness bug dma/timberdale: simplify conditional ste_dma40: remove channel_type ste_dma40: remove enum for endianess ste_dma40: remove TIM_FOR_LINK option ste_dma40: move mode_opt to separate config ste_dma40: move channel mode to a separate field ste_dma40: move priority to separate field ste_dma40: add variable to indicate valid dma_cfg async_tx: make async_tx channel switching opt-in move async raid6 test to lib/Kconfig.debug dmaengine: Add Freescale i.MX1/21/27 DMA driver intel_mid_dma: change the slave interface intel_mid_dma: fix the WARN_ONs intel_mid_dma: Add sg list support to DMA driver intel_mid_dma: Allow DMAC2 to share interrupt intel_mid_dma: Allow IRQ sharing intel_mid_dma: Add runtime PM support DMAENGINE: define a dummy filter function for ste_dma40 ...
2010-10-26mm: strictly nested kmap_atomic()Peter Zijlstra
Ensure kmap_atomic() usage is strictly nested Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: Makefile - replace the use of <module>-objs with <module>-y crypto: hifn_795x - use cancel_delayed_work_sync() crypto: talitos - sparse check endian fixes crypto: talitos - fix checkpatch warning crypto: talitos - fix warning: 'alg' may be used uninitialized in this function crypto: cryptd - Adding the AEAD interface type support to cryptd crypto: n2_crypto - Niagara2 driver needs to depend upon CRYPTO_DES crypto: Kconfig - update broken web addresses crypto: omap-sham - Adjust DMA parameters crypto: fips - FIPS requires algorithm self-tests crypto: omap-aes - OMAP2/3 AES hw accelerator driver crypto: updates to enable omap aes padata: add missing __percpu markup in include/linux/padata.h MAINTAINERS: Add maintainer entries for padata/pcrypt
2010-10-07move async raid6 test to lib/Kconfig.debugDan Williams
The prompt for "Self test for hardware accelerated raid6 recovery" does not belong in the top level configuration menu. All the options in crypto/async_tx/Kconfig are selected and do not depend on CRYPTO. Kconfig.debug seems like a reasonable fit. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-07Blackfin: Rename DES PC2() symbol to avoid collisionDavid Howells
Rename the PC2() symbol in the generic DES crypto module to be prefixed with DES_ to avoid collision with arch code (Blackfin in this case). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-20crypto: cryptd - Adding the AEAD interface type support to cryptdAdrian Hoban
This patch adds AEAD support into the cryptd framework. Having AEAD support in cryptd enables crypto drivers that use the AEAD interface type (such as the patch for AEAD based RFC4106 AES-GCM implementation using Intel New Instructions) to leverage cryptd for asynchronous processing. Signed-off-by: Adrian Hoban <adrian.hoban@intel.com> Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com> Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-09-12crypto: Kconfig - update broken web addressesJustin P. Mattock
Below is a patch to update the broken web addresses, in crypto/* that I could locate. Some are just simple typos that needed to be fixed, and some had a change in location altogether.. let me know if any of them need to be changed and such. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: Revert "hwrng: n2-drv - remove casts from void*" crypto: testmgr - Default to no tests crypto: testmgr - Fix test disabling option crypto: hash - Fix handling of small unaligned buffers
2010-09-03crypto: fips - FIPS requires algorithm self-testsChuck Ebbert
Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-08-09Merge branch 'async' of macbook:git/btrfs-unstableDavid Woodhouse
Conflicts: drivers/md/Makefile lib/raid6/unroll.pl
2010-08-06crypto: testmgr - Default to no testsHerbert Xu
On Thu, Aug 05, 2010 at 07:01:21PM -0700, Linus Torvalds wrote: > On Thu, Aug 5, 2010 at 6:40 PM, Herbert Xu <herbert@gondor.hengli.com.au> wrote: > > > > -config CRYPTO_MANAGER_TESTS > > - bool "Run algolithms' self-tests" > > - default y > > - depends on CRYPTO_MANAGER2 > > +config CRYPTO_MANAGER_DISABLE_TESTS > > + bool "Disable run-time self tests" > > + depends on CRYPTO_MANAGER2 && EMBEDDED > > Why do you still want to force-enable those tests? I was going to > complain about the "default y" anyway, now I'm _really_ complaining, > because you've now made it impossible to disable those tests. Why? As requested, this patch sets the default to y and removes the EMBEDDED dependency. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-08-06crypto: testmgr - Fix test disabling optionHerbert Xu
This patch fixes a serious bug in the test disabling patch where it can cause an spurious load of the cryptomgr module even when it's compiled in. It also negates the test disabling option so that its absence causes tests to be enabled. The Kconfig option is also now behind EMBEDDED. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-08-06crypto: hash - Fix handling of small unaligned buffersSzilveszter Ördög
If a scatterwalk chain contains an entry with an unaligned offset then hash_walk_next() will cut off the next step at the next alignment point. However, if the entry ends before the next alignment point then we a loop, which leads to a kernel oops. Fix this by checking whether the next aligment point is before the end of the current entry. Signed-off-by: Szilveszter Ördög <slipszi@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (39 commits) random: Reorder struct entropy_store to remove padding on 64bits padata: update API documentation padata: Remove padata_get_cpumask crypto: pcrypt - Update pcrypt cpumask according to the padata cpumask notifier crypto: pcrypt - Rename pcrypt_instance padata: Pass the padata cpumasks to the cpumask_change_notifier chain padata: Rearrange set_cpumask functions padata: Rename padata_alloc functions crypto: pcrypt - Dont calulate a callback cpu on empty callback cpumask padata: Check for valid cpumasks padata: Allocate cpumask dependend recources in any case padata: Fix cpu index counting crypto: geode_aes - Convert pci_table entries to PCI_VDEVICE (if PCI_ANY_ID is used) pcrypt: Added sysfs interface to pcrypt padata: Added sysfs primitives to padata subsystem padata: Make two separate cpumasks padata: update documentation padata: simplify serialization mechanism padata: make padata_do_parallel to return zero on success padata: Handle empty padata cpumasks ...
2010-07-31crypto: pcrypt - Update pcrypt cpumask according to the padata cpumask notifierSteffen Klassert
The padata cpumask change notifier passes a padata_cpumask to the notifier chain. So we use this cpumask instead of asking padata for the cpumask. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-31crypto: pcrypt - Rename pcrypt_instanceSteffen Klassert
In the crypto-layer an instance refers usually to a crypto instance. The struct pcrypt_instance is not related to a crypto instance. It rather contains the padata informations, so we rename it to padata_pcrypt. The functions that handle this struct are renamed accordingly. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-31padata: Rename padata_alloc functionsSteffen Klassert
We rename padata_alloc to padata_alloc_possible because this function allocates a padata_instance and uses the cpu_possible mask for parallel and serial workers. Also we rename __padata_alloc to padata_alloc to avoid to export underlined functions. Underlined functions are considered to be private to padata. Users are updated accordingly. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-26crypto: pcrypt - Dont calulate a callback cpu on empty callback cpumaskSteffen Klassert
If the callback cpumask is empty, we crash with a division by zero when we try to calculate a callback cpu. So we don't update the callback cpu in pcrypt_do_parallel if the callback cpumask is empty. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-19pcrypt: Added sysfs interface to pcryptDan Kruchinin
Added sysfs interface to pcrypt. Now pcrypt subsystem creates two sysfs directories with corresponding padata sysfs objects: /sys/kernel/pcrypt/[pencrypt|pdecrypt] Signed-off-by: Dan Kruchinin <dkruchinin@acm.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-19padata: Make two separate cpumasksDan Kruchinin
The aim of this patch is to make two separate cpumasks for padata parallel and serial workers respectively. It allows user to make more thin and sophisticated configurations of padata framework. For example user may bind parallel and serial workers to non-intersecting CPU groups to gain better performance. Also each padata instance has notifiers chain for its cpumasks now. If either parallel or serial or both masks were changed all interested subsystems will get notification about that. It's especially useful if padata user uses algorithm for callback CPU selection according to serial cpumask. Signed-off-by: Dan Kruchinin <dkruchinin@acm.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-14padata: make padata_do_parallel to return zero on successSteffen Klassert
To return -EINPROGRESS on success in padata_do_parallel was considered to be odd. This patch changes this to return zero on success. Also the only user of padata, pcrypt is adapted to convert a return of zero to -EINPROGRESS within the crypto layer. This also removes the pcrypt fallback if padata_do_parallel was called on a not running padata instance as we can't handle it anymore. This fallback was unused, so it's save to remove it. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-14padata: Check for valid padata instance on startSteffen Klassert
This patch introduces the PADATA_INVALID flag which is checked on padata start. This will be used to mark a padata instance as invalid, if the padata cpumask does not intersect with the active cpumask. we change padata_start to return an error if the PADATA_INVALID is set. Also we adapt the only padata user, pcrypt to this change. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-06-23crypto: skcipher - avoid NULL dereferenceJiri Slaby
Stanse found a potential NULL dereference in ablkcipher_next_slow. Even though kmalloc fails, its retval is dereferenced later. Return from that function properly earlier. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-06-03crypto: twofish: Rename twofish to twofish_generic and add an aliasJoachim Fritschi
This fixes the broken autoloading of the corresponding twofish assembler ciphers on x86 and x86_64 if they are available. The module name of the generic implementation was in conflict with the alias in the assembler modules. The generic twofish c implementation is renamed to twofish_generic according to the other algorithms with assembler implementations and an module alias is added for 'twofish'. You can now load 'twofish' giving you the best implementation by priority, 'twofish-generic' to get the c implementation or 'twofish-asm' to get the assembler version of cipher. Signed-off-by: Joachim Fritschi <jfritschi@freenet.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-06-03crypto: testmgr - add an option to disable cryptoalgos' self-testsAlexander Shishkin
By default, CONFIG_CRYPTO_MANAGER_TESTS will be enabled and thus self-tests will still run, but it is now possible to disable them to gain some time during bootup. Signed-off-by: Alexander Shishkin <virtuoso@slind.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-06-03crypto: pcomp - Fix illegal Kconfig configurationHerbert Xu
The PCOMP Kconfig entry current allows the following combination which is illegal: ZLIB=y PCOMP=y ALGAPI=m ALGAPI2=y MANAGER=m MANAGER2=m This patch fixes this by adding PCOMP2 so that PCOMP can select ALGAPI to propagate the setting to MANAGER2. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/crypto-2.6Herbert Xu
2010-05-26crypto: Use ERR_CASTJulia Lawall
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more clear what is the purpose of the operation, which otherwise looks like a no-op. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ type T; T x; identifier f; @@ T f (...) { <+... - ERR_PTR(PTR_ERR(x)) + x ...+> } @@ expression x; @@ - ERR_PTR(PTR_ERR(x)) + ERR_CAST(x) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: DMAENGINE: extend the control command to include an arg async_tx: trim dma_async_tx_descriptor in 'no channel switch' case DMAENGINE: DMA40 fix for allocation of logical channel 0 DMAENGINE: DMA40 support paused channel status dmaengine: mpc512x: Use resource_size DMA ENGINE: Do not reset 'private' of channel ioat: Remove duplicated devm_kzalloc() calls for ioatdma_device ioat3: disable cacheline-unaligned transfers for raid operations ioat2,3: convert to producer/consumer locking ioat: convert to circ_buf DMAENGINE: Support for ST-Ericssons DMA40 block v3 async_tx: use of kzalloc/kfree requires the include of slab.h dmaengine: provide helper for setting txstate DMAENGINE: generic channel status v2 DMAENGINE: generic slave control v2 dma: timb-dma: Update comment and fix compiler warning dma: Add timb-dma DMAENGINE: COH 901 318 fix bytesleft DMAENGINE: COH 901 318 rename confusing vars
2010-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits) random: simplify fips mode crypto: authenc - Fix cryptlen calculation crypto: talitos - add support for sha224 crypto: talitos - add hash algorithms crypto: talitos - second prepare step for adding ahash algorithms crypto: talitos - prepare for adding ahash algorithms crypto: n2 - Add Niagara2 crypto driver crypto: skcipher - Add ablkcipher_walk interfaces crypto: testmgr - Add testing for async hashing and update/final crypto: tcrypt - Add speed tests for async hashing crypto: scatterwalk - Fix scatterwalk_done() test crypto: hifn_795x - Rename ablkcipher_walk to hifn_cipher_walk padata: Use get_online_cpus/put_online_cpus in padata_free padata: Add some code comments padata: Flush the padata queues actively padata: Use a timer to handle remaining objects in the reorder queues crypto: shash - Remove usage of CRYPTO_MINALIGN crypto: mv_cesa - Use resource_size crypto: omap - OMAP macros corrected padata: Use get_online_cpus/put_online_cpus ... Fix up conflicts in arch/arm/mach-omap2/devices.c
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-20crypto: authenc - Fix cryptlen calculationShikhar Khattar
This patch (applied against 2.6.34) fixes the calculation of the length of the ABLKCIPHER decrypt request ("cryptlen") after an asynchronous hash request has been completed in the AUTHENC interface. Signed-off-by: Shikhar Khattar <shikhark@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-19crypto: skcipher - Add ablkcipher_walk interfacesDavid S. Miller
These are akin to the blkcipher_walk helpers. The main differences in the async variant are: 1) Only physical walking is supported. We can't hold on to kmap mappings across the async operation to support virtual ablkcipher_walk operations anyways. 2) Bounce buffers used for async more need to be persistent and freed at a later point in time when the async op completes. Therefore we maintain a list of writeback buffers and require that the ablkcipher_walk user call the 'complete' operation so we can copy the bounce buffers out to the real buffers and free up the bounce buffer chunks. These interfaces will be used by the new Niagara2 crypto driver. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-19crypto: testmgr - Add testing for async hashing and update/finalDavid S. Miller
Extend testmgr such that it tests async hash algorithms, and that for both sync and async hashes it tests both ->digest() and ->update()/->final() sequences. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-19crypto: tcrypt - Add speed tests for async hashingDavid S. Miller
These are invoked in the 'mode' range of 400 to 499. The cost of async vs. sync for the software algorithm implementations varies. It can be as low as 16 cycles but as much as a couple hundred. Here two runs of md5 testing, async then sync: testing speed of async md5 test 0 ( 16 byte blocks, 16 bytes per update, 1 updates): 2448 cycles/operation, 153 cycles/byte test 1 ( 64 byte blocks, 16 bytes per update, 4 updates): 4992 cycles/operation, 78 cycles/byte test 2 ( 64 byte blocks, 64 bytes per update, 1 updates): 3808 cycles/operation, 59 cycles/byte test 3 ( 256 byte blocks, 16 bytes per update, 16 updates): 14000 cycles/operation, 54 cycles/byte test 4 ( 256 byte blocks, 64 bytes per update, 4 updates): 8480 cycles/operation, 33 cycles/byte test 5 ( 256 byte blocks, 256 bytes per update, 1 updates): 7280 cycles/operation, 28 cycles/byte test 6 ( 1024 byte blocks, 16 bytes per update, 64 updates): 50016 cycles/operation, 48 cycles/byte test 7 ( 1024 byte blocks, 256 bytes per update, 4 updates): 22496 cycles/operation, 21 cycles/byte test 8 ( 1024 byte blocks, 1024 bytes per update, 1 updates): 21232 cycles/operation, 20 cycles/byte test 9 ( 2048 byte blocks, 16 bytes per update, 128 updates): 117184 cycles/operation, 57 cycles/byte test 10 ( 2048 byte blocks, 256 bytes per update, 8 updates): 43008 cycles/operation, 21 cycles/byte test 11 ( 2048 byte blocks, 1024 bytes per update, 2 updates): 40176 cycles/operation, 19 cycles/byte test 12 ( 2048 byte blocks, 2048 bytes per update, 1 updates): 39888 cycles/operation, 19 cycles/byte test 13 ( 4096 byte blocks, 16 bytes per update, 256 updates): 194176 cycles/operation, 47 cycles/byte test 14 ( 4096 byte blocks, 256 bytes per update, 16 updates): 84096 cycles/operation, 20 cycles/byte test 15 ( 4096 byte blocks, 1024 bytes per update, 4 updates): 78336 cycles/operation, 19 cycles/byte test 16 ( 4096 byte blocks, 4096 bytes per update, 1 updates): 77120 cycles/operation, 18 cycles/byte test 17 ( 8192 byte blocks, 16 bytes per update, 512 updates): 403056 cycles/operation, 49 cycles/byte test 18 ( 8192 byte blocks, 256 bytes per update, 32 updates): 166112 cycles/operation, 20 cycles/byte test 19 ( 8192 byte blocks, 1024 bytes per update, 8 updates): 154768 cycles/operation, 18 cycles/byte test 20 ( 8192 byte blocks, 4096 bytes per update, 2 updates): 151904 cycles/operation, 18 cycles/byte test 21 ( 8192 byte blocks, 8192 bytes per update, 1 updates): 155456 cycles/operation, 18 cycles/byte testing speed of md5 test 0 ( 16 byte blocks, 16 bytes per update, 1 updates): 2208 cycles/operation, 138 cycles/byte test 1 ( 64 byte blocks, 16 bytes per update, 4 updates): 5008 cycles/operation, 78 cycles/byte test 2 ( 64 byte blocks, 64 bytes per update, 1 updates): 3600 cycles/operation, 56 cycles/byte test 3 ( 256 byte blocks, 16 bytes per update, 16 updates): 14080 cycles/operation, 55 cycles/byte test 4 ( 256 byte blocks, 64 bytes per update, 4 updates): 8560 cycles/operation, 33 cycles/byte test 5 ( 256 byte blocks, 256 bytes per update, 1 updates): 7040 cycles/operation, 27 cycles/byte test 6 ( 1024 byte blocks, 16 bytes per update, 64 updates): 50592 cycles/operation, 49 cycles/byte test 7 ( 1024 byte blocks, 256 bytes per update, 4 updates): 22736 cycles/operation, 22 cycles/byte test 8 ( 1024 byte blocks, 1024 bytes per update, 1 updates): 24960 cycles/operation, 24 cycles/byte test 9 ( 2048 byte blocks, 16 bytes per update, 128 updates): 99312 cycles/operation, 48 cycles/byte test 10 ( 2048 byte blocks, 256 bytes per update, 8 updates): 43520 cycles/operation, 21 cycles/byte test 11 ( 2048 byte blocks, 1024 bytes per update, 2 updates): 40704 cycles/operation, 19 cycles/byte test 12 ( 2048 byte blocks, 2048 bytes per update, 1 updates): 39552 cycles/operation, 19 cycles/byte test 13 ( 4096 byte blocks, 16 bytes per update, 256 updates): 196720 cycles/operation, 48 cycles/byte test 14 ( 4096 byte blocks, 256 bytes per update, 16 updates): 85152 cycles/operation, 20 cycles/byte test 15 ( 4096 byte blocks, 1024 bytes per update, 4 updates): 79408 cycles/operation, 19 cycles/byte test 16 ( 4096 byte blocks, 4096 bytes per update, 1 updates): 76816 cycles/operation, 18 cycles/byte test 17 ( 8192 byte blocks, 16 bytes per update, 512 updates): 391520 cycles/operation, 47 cycles/byte test 18 ( 8192 byte blocks, 256 bytes per update, 32 updates): 168464 cycles/operation, 20 cycles/byte test 19 ( 8192 byte blocks, 1024 bytes per update, 8 updates): 156912 cycles/operation, 19 cycles/byte test 20 ( 8192 byte blocks, 4096 bytes per update, 2 updates): 154016 cycles/operation, 18 cycles/byte test 21 ( 8192 byte blocks, 8192 bytes per update, 1 updates): 153856 cycles/operation, 18 cycles/byte We can ditch the sync hash code at some point if we feel that makes sense. For now I've left it there. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-19crypto: scatterwalk - Fix scatterwalk_done() testDavid S. Miller
We are done with the scattergather entry when the walk offset goes past sg->offset + sg->length, not when it crosses a page boundary. There is a similarly queer test in the second half of scatterwalk_pagedone() that probably needs some scrutiny. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-19crypto: shash - Remove usage of CRYPTO_MINALIGNHerbert Xu
The macro CRYPTO_MINALIGN is not meant to be used directly. This patch replaces it with crypto_tfm_ctx_alignment. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-17async_tx: trim dma_async_tx_descriptor in 'no channel switch' caseDan Williams
Saves 24 bytes per descriptor (64-bit) when the channel-switching capabilities of async_tx are not required. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-05raid6: fix recovery performance regressionDan Williams
The raid6 recovery code should immediately drop back to the optimized synchronous path when a p+q dma resource is not available. Otherwise we run the non-optimized/multi-pass async code in sync mode. Verified with raid6test (NDISKS=255) Applies to kernels >= 2.6.32. Cc: <stable@kernel.org> Acked-by: NeilBrown <neilb@suse.de> Reported-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Herbert Xu
2010-05-03crypto: algapi - Remove unneeded null checkDan Carpenter
We don't check "frontend" consistently in crypto_init_spawn2(). We check it at the start of the function but then we dereference it unconditionally in the parameter list when we call crypto_init_spawn(). I looked at the places that call crypto_init_spawn2() and "frontend" is always a valid pointer so I removed the check for null. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-04-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: authenc - Add EINPROGRESS check
2010-04-26crypto: authenc - Add EINPROGRESS checkHerbert Xu
When Steffen originally wrote the authenc async hash patch, he correctly had EINPROGRESS checks in place so that we did not invoke the original completion handler with it. Unfortuantely I told him to remove it before the patch was applied. As only MAY_BACKLOG request completion handlers are required to handle EINPROGRESS completions, those checks are really needed. This patch restores them. Reported-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29Fix comment and Kconfig typos for 'require' and 'fragment'Gilles Espinasse
Signed-off-by: Gilles Espinasse <g.esp@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-24crypto: pcrypt - Handle crypto_get_attr_type errorsDan Carpenter
I was concerned about the error handling for crypto_get_attr_type() in pcrypt_alloc_aead(). Steffen Klassert pointed out that we could simply avoid calling crypto_get_attr_type() if we passed the type and mask as a parameters. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-18crypto: vmac - Fix big-endian supportShane Wang
This patch is to fix the vmac algorithm, add more test cases for vmac, and fix the test failure on some big endian system like s390. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-10crypto: tcrypt - Speed testing support for ghashHuang Ying
Because ghash needs setkey, the setkey and keysize template support for test_hash_speed is added. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-10crypto: internal - Fix checkpatch errorsRichard Hartmann
Signed-off-by: Richard Hartmann <richih.mailinglist@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
