path: root/crypto
2010-05-12raid6: fix recovery performance regressionDan Williams
commit 5157b4aa5b7de8787b6318e61bcc285031bb9088 upstream. The raid6 recovery code should immediately drop back to the optimized synchronous path when a p+q dma resource is not available. Otherwise we run the non-optimized/multi-pass async code in sync mode. Verified with raid6test (NDISKS=255) Applies to kernels >= 2.6.32. Acked-by: NeilBrown <neilb@suse.de> Reported-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: gcm - fix another complete call in complete fuction crypto: padlock-aes - Use the correct mask when checking whether copying is required
2009-11-19async_tx: build-time toggling of async_{syndrome,xor}_val dma supportDan Williams
ioat3.2 does not support asynchronous error notifications which makes the driver experience latencies when non-zero pq validate results are expected. Provide a mechanism for turning off async_xor_val and async_syndrome_val via Kconfig. This approach is generally useful for any driver that specifies ASYNC_TX_DISABLE_CHANNEL_SWITCH and would like to force the async_tx api to fall back to the synchronous path for certain operations. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-11-16crypto: gcm - fix another complete call in complete fuctionHuang Ying
The flow of the complete function (xxx_done) in gcm.c is as follow: void complete(struct crypto_async_request *areq, int err) { struct aead_request *req = areq->data; if (!err) { err = async_next_step(); if (err == -EINPROGRESS || err == -EBUSY) return; } complete_for_next_step(areq, err); } But *areq may be destroyed in async_next_step(), this makes complete_for_next_step() can not work properly. To fix this, one of following methods is used for each complete function. - Add a __complete() for each complete(), which accept struct aead_request *req instead of areq, so avoid using areq after it is destroyed. - Expand complete_for_next_step(). The fixing method is based on the idea of Herbert Xu. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-31Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: async_tx: fix asynchronous raid6 recovery for ddf layouts async_pq: rename scribble page async_pq: kill a stray dma_map() call and other cleanups md/raid6: kill a gcc-4.0.1 'uninitialized variable' warning raid6/async_tx: handle holes in block list in async_syndrome_val md/async: don't pass a memory pointer as a page pointer. md: Fix handling of raid5 array which is being reshaped to fewer devices. md: fix problems with RAID6 calculations for DDF. md/raid456: downlevel multicore operations to raid_run_ops md: drivers/md/unroll.pl replaced with awk analog md: remove clumsy usage of do_sync_mapping_range from bitmap code md: raid1/raid10: handle allocation errors during array setup. md/raid5: initialize conf->device_lock earlier md/raid1/raid10: add a cond_resched Revert "md: do not progress the resync process if the stripe was blocked"
2009-10-19async_tx: fix asynchronous raid6 recovery for ddf layoutsDan Williams
The raid6 recovery code currently requires special handling of the 4-disk and 5-disk recovery scenarios for the native layout. Quoting from commit 0a82a623: In these situations the default N-disk algorithm will present 0-source or 1-source operations to dma devices. To cover for dma devices where the minimum source count is 2 we implement 4-disk and 5-disk handling in the recovery code. The ddf layout presents disks=6 and disks=7 to the recovery code in these situations. Instead of looking at the number of disks count the number of non-zero sources in the list and call the special case code when the number of non-failed sources is 0 or 1. [neilb@suse.de: replace 'ddf' flag with counting good sources] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-19async_pq: rename scribble pageDan Williams
The global scribble page is used as a temporary destination buffer when disabling the P or Q result is requested. The local scribble buffer contains memory for performing address conversions. Rename the global variable to avoid confusion. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-19async_pq: kill a stray dma_map() call and other cleanupsDan Williams
- update the kernel doc for async_syndrome to indicate what NULL in the source list means - whitespace fixups Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-16raid6/async_tx: handle holes in block list in async_syndrome_valNeilBrown
async_syndrome_val check the P and Q blocks used for RAID6 calculations. With DDF raid6, some of the data blocks might be NULL, so this needs to be handled in the same way that async_gen_syndrome handles it. As async_syndrome_val calls async_xor, also enhance async_xor to detect and skip NULL blocks in the list. Signed-off-by: NeilBrown <neilb@suse.de>
2009-10-16md/async: don't pass a memory pointer as a page pointer.NeilBrown
md/raid6 passes a list of 'struct page *' to the async_tx routines, which then either DMA map them for offload, or take the page_address for CPU based calculations. For RAID6 we sometime leave 'blanks' in the list of pages. For CPU based calcs, we want to treat theses as a page of zeros. For offloaded calculations, we simply don't pass a page to the hardware. Currently the 'blanks' are encoded as a pointer to raid6_empty_zero_page. This is a 4096 byte memory region, not a 'struct page'. This is mostly handled correctly but is rather ugly. So change the code to pass and expect a NULL pointer for the blanks. When taking page_address of a page, we need to check for a NULL and in that case use raid6_empty_zero_page. Signed-off-by: NeilBrown <neilb@suse.de>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-23Merge branch 'next' of ↵NeilBrown
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx into for-linus
2009-09-21async_tx/raid6: add missing dma_unmap calls to the async fail caseDan Williams
If we are unable to offload async_mult() or async_sum_product(), then unmap the buffers before falling through to the synchronous path. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-16raid6test: fix stack overflowDan Williams
Testing on x86_64 with NDISKS=255 yields: do_IRQ: modprobe near stack overflow (cur:ffff88007d19c000,sp:ffff88007d19c128) ...and eventually general protection fault: 0000 [#1] Moving the scribble buffers off the stack allows the test to complete successfully. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (102 commits) crypto: sha-s390 - Fix warnings in import function crypto: vmac - New hash algorithm for intel_txt support crypto: api - Do not displace newly registered algorithms crypto: ansi_cprng - Fix module initialization crypto: xcbc - Fix alignment calculation of xcbc_tfm_ctx crypto: fips - Depend on ansi_cprng crypto: blkcipher - Do not use eseqiv on stream ciphers crypto: ctr - Use chainiv on raw counter mode Revert crypto: fips - Select CPRNG crypto: rng - Fix typo crypto: talitos - add support for 36 bit addressing crypto: talitos - align locks on cache lines crypto: talitos - simplify hmac data size calculation crypto: mv_cesa - Add support for Orion5X crypto engine crypto: cryptd - Add support to access underlaying shash crypto: gcm - Use GHASH digest algorithm crypto: ghash - Add GHASH digest algorithm for GCM crypto: authenc - Convert to ahash crypto: api - Fix aligned ctx helper crypto: hmac - Prehash ipad/opad ...
2009-09-08Merge branch 'dmaengine' into async-tx-nextDan Williams
Conflicts: crypto/async_tx/async_xor.c drivers/dma/ioat/dma_v2.h drivers/dma/ioat/pci.c drivers/md/raid5.c
2009-09-08dmaengine, async_tx: support alignment checksDan Williams
Some engines have transfer size and address alignment restrictions. Add a per-operation alignment property to struct dma_device that the async routines and dmatest can use to check alignment capabilities. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08dmaengine, async_tx: add a "no channel switch" allocatorDan Williams
Channel switching is problematic for some dmaengine drivers as the architecture precludes separating the ->prep from ->submit. In these cases the driver can select ASYNC_TX_DISABLE_CHANNEL_SWITCH to modify the async_tx allocator to only return channels that support all of the required asynchronous operations. For example MD_RAID456=y selects support for asynchronous xor, xor validate, pq, pq validate, and memcpy. When ASYNC_TX_DISABLE_CHANNEL_SWITCH=y any channel with all these capabilities is marked DMA_ASYNC_TX allowing async_tx_find_channel() to quickly locate compatible channels with the guarantee that dependency chains will remain on one channel. When ASYNC_TX_DISABLE_CHANNEL_SWITCH=n async_tx_find_channel() may select channels that lead to operation chains that need to cross channel boundaries using the async_tx channel switch capability. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08dmaengine: add fence supportDan Williams
Some engines optimize operation by reading ahead in the descriptor chain such that descriptor2 may start execution before descriptor1 completes. If descriptor2 depends on the result from descriptor1 then a fence is required (on descriptor2) to disable this optimization. The async_tx api could implicitly identify dependencies via the 'depend_tx' parameter, but that would constrain cases where the dependency chain only specifies a completion order rather than a data dependency. So, provide an ASYNC_TX_FENCE to explicitly identify data dependencies. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08Merge branch 'md-raid6-accel' into ioat3.2Dan Williams
Conflicts: include/linux/dmaengine.h
2009-09-08Merge commit 'v2.6.31-rc1' into dmaengineDan Williams
2009-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: skcipher - Fix skcipher_dequeue_givcrypt NULL test
2009-09-02crypto: vmac - New hash algorithm for intel_txt supportShane Wang
This patch adds VMAC (a fast MAC) support into crypto framework. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-31crypto: api - Do not displace newly registered algorithmsHerbert Xu
We have a mechanism where newly registered algorithms of a higher priority can displace existing instances that use a different implementation of the same algorithm with a lower priority. Unfortunately the same mechanism can cause a newly registered algorithm to displace itself if it depends on an existing version of the same algorithm. This patch fixes this by keeping all algorithms that the newly reigstered algorithm depends on, thus protecting them from being removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-29async_tx: raid6 recovery self testDan Williams
Port drivers/md/raid6test/test.c to use the async raid6 recovery routines. This is meant as a unit test for raid6 acceleration drivers. In addition to the 16-drive test case this implements tests for the 4-disk and 5-disk special cases (dma devices can not generically handle less than 2 sources), and adds a test for the D+Q case. Reviewed-by: Andre Noll <maan@systemlinux.org> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-08-29async_tx: add support for asynchronous RAID6 recovery operationsDan Williams
async_raid6_2data_recov() recovers two data disk failures async_raid6_datap_recov() recovers a data disk and the P disk These routines are a port of the synchronous versions found in drivers/md/raid6recov.c. The primary difference is breaking out the xor operations into separate calls to async_xor. Two helper routines are introduced to perform scalar multiplication where needed. async_sum_product() multiplies two sources by scalar coefficients and then sums (xor) the result. async_mult() simply multiplies a single source by a scalar. This implemention also includes, in contrast to the original synchronous-only code, special case handling for the 4-disk and 5-disk array cases. In these situations the default N-disk algorithm will present 0-source or 1-source operations to dma devices. To cover for dma devices where the minimum source count is 2 we implement 4-disk and 5-disk handling in the recovery code. [ Impact: asynchronous raid6 recovery routines for 2data and datap cases ] Cc: Yuri Tikhonov <yur@emcraft.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: David Woodhouse <David.Woodhouse@intel.com> Reviewed-by: Andre Noll <maan@systemlinux.org> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-08-29async_tx: add support for asynchronous GF multiplicationDan Williams
[ Based on an original patch by Yuri Tikhonov ] This adds support for doing asynchronous GF multiplication by adding two additional functions to the async_tx API: async_gen_syndrome() does simultaneous XOR and Galois field multiplication of sources. async_syndrome_val() validates the given source buffers against known P and Q values. When a request is made to run async_pq against more than the hardware maximum number of supported sources we need to reuse the previous generated P and Q values as sources into the next operation. Care must be taken to remove Q from P' and P from Q'. For example to perform a 5 source pq op with hardware that only supports 4 sources at a time the following approach is taken: p, q = PQ(src0, src1, src2, src3, COEF({01}, {02}, {04}, {08})) p', q' = PQ(p, q, q, src4, COEF({00}, {01}, {00}, {10})) p' = p + q + q + src4 = p + src4 q' = {00}*p + {01}*q + {00}*q + {10}*src4 = q + {10}*src4 Note: 4 is the minimum acceptable maxpq otherwise we punt to synchronous-software path. The DMA_PREP_CONTINUE flag indicates to the driver to reuse p and q as sources (in the above manner) and fill the remaining slots up to maxpq with the new sources/coefficients. Note1: Some devices have native support for P+Q continuation and can skip this extra work. Devices with this capability can advertise it with dma_set_maxpq. It is up to each driver how to handle the DMA_PREP_CONTINUE flag. Note2: The api supports disabling the generation of P when generating Q, this is ignored by the synchronous path but is implemented by some dma devices to save unnecessary writes. In this case the continuation algorithm is simplified to only reuse Q as a source. Cc: H. Peter Anvin <hpa@zytor.com> Cc: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com> Reviewed-by: Andre Noll <maan@systemlinux.org> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-08-29async_tx: remove walk of tx->parent chain in dma_wait_for_async_txDan Williams
We currently walk the parent chain when waiting for a given tx to complete however this walk may race with the driver cleanup routine. The routines in async_raid6_recov.c may fall back to the synchronous path at any point so we need to be prepared to call async_tx_quiesce() (which calls dma_wait_for_async_tx). To remove the ->parent walk we guarantee that every time a dependency is attached ->issue_pending() is invoked, then we can simply poll the initial descriptor until completion. This also allows for a lighter weight 'issue pending' implementation as there is no longer a requirement to iterate through all the channels' ->issue_pending() routines as long as operations have been submitted in an ordered chain. async_tx_issue_pending() is added for this case. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-08-29async_tx: kill needless module_{init|exit}Dan Williams
If module_init and module_exit are nops then neither need to be defined. [ Impact: pure cleanup ] Reviewed-by: Andre Noll <maan@systemlinux.org> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-08-29async_tx: add sum check flagsDan Williams
Replace the flat zero_sum_result with a collection of flags to contain the P (xor) zero-sum result, and the soon to be utilized Q (raid6 reed solomon syndrome) zero-sum result. Use the SUM_CHECK_ namespace instead of DMA_ since these flags will be used on non-dma-zero-sum enabled platforms. Reviewed-by: Andre Noll <maan@systemlinux.org> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-08-29crypto: skcipher - Fix skcipher_dequeue_givcrypt NULL testHerbert Xu
As struct skcipher_givcrypt_request includes struct crypto_request at a non-zero offset, testing for NULL after converting the pointer returned by crypto_dequeue_request does not work. This can result in IPsec crashes when the queue is depleted. This patch fixes it by doing the pointer conversion only when the return value is non-NULL. In particular, we create a new function __crypto_dequeue_request that does the pointer conversion. Reported-by: Brad Bosch <bradbosch@comcast.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-29crypto: ansi_cprng - Fix module initializationSteffen Klassert
Return the value we got from crypto_register_alg() instead of returning 0 in any case. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-20crypto: xcbc - Fix alignment calculation of xcbc_tfm_ctxSteffen Klassert
The alignment calculation of xcbc_tfm_ctx uses alg->cra_alignmask and not alg->cra_alignmask + 1 as it should. This led to frequent crashes during the selftest of xcbc(aes-asm) on x86_64 machines. This patch fixes this. Also we use the alignmask of xcbc and not the alignmask of the underlying algorithm for the alignmnent calculation in xcbc_create now. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-20crypto: fips - Depend on ansi_cprngNeil Horman
What about something like this? It defaults the CPRNG to m and makes FIPS dependent on the CPRNG. That way you get a module build by default, but you can change it to y manually during config and still satisfy the dependency, and if you select N it disables FIPS as well. I rather like that better than making FIPS a tristate. I just tested it out here and it seems to work well. Let me know what you think Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-14crypto: blkcipher - Do not use eseqiv on stream ciphersHerbert Xu
Recently we switched to using eseqiv on SMP machines in preference over chainiv. However, eseqiv does not support stream ciphers so they should still default to chainiv. This patch applies the same check as done by eseqiv to weed out the stream ciphers. In particular, all algorithms where the IV size is not equal to the block size will now default to chainiv. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-13crypto: ctr - Use chainiv on raw counter modeHerbert Xu
Raw counter mode only works with chainiv, which is no longer the default IV generator on SMP machines. This broke raw counter mode as it can no longer instantiate as a givcipher. This patch fixes it by always picking chainiv on raw counter mode. This is based on the diagnosis and a patch by Huang Ying. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-13Revert crypto: fips - Select CPRNGHerbert Xu
This reverts commit 215ccd6f55a2144bd553e0a3d12e1386f02309fd. It causes CPRNG and everything selected by it to be built-in whenever FIPS is enabled. The problem is that it is selecting a tristate from a bool, which is usually not what is intended. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-13crypto: rng - Fix typoChristian Kujau
Correct a typo in crypto/rng.c Signed-off-by: Christian Kujau <lists@nerdbynature.de> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: cryptd - Add support to access underlaying shashHuang Ying
cryptd_alloc_ahash() will allocate a cryptd-ed ahash for specified algorithm name. The new allocated one is guaranteed to be cryptd-ed ahash, so the shash underlying can be gotten via cryptd_ahash_child(). Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: gcm - Use GHASH digest algorithmHuang Ying
Remove the dedicated GHASH implementation in GCM, and uses the GHASH digest algorithm instead. This will make GCM uses hardware accelerated GHASH implementation automatically if available. ahash instead of shash interface is used, because some hardware accelerated GHASH implementation needs asynchronous interface. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: ghash - Add GHASH digest algorithm for GCMHuang Ying
GHASH is implemented as a shash algorithm. The actual implementation is copied from gcm.c. This makes it possible to add architecture/hardware accelerated GHASH implementation. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-05crypto: authenc - Convert to ahashSteffen Klassert
This patch converts authenc to the new ahash interface. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-30Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: dmaengine: at_hdmac: add DMA slave transfers dmaengine: at_hdmac: new driver for the Atmel AHB DMA Controller dmaengine: dmatest: correct thread_count while using multiple thread per channel dmaengine: dmatest: add a maximum number of test iterations drivers/dma: Remove unnecessary semicolons drivers/dma/fsldma.c: Remove unnecessary semicolons dmaengine: move HIGHMEM64G restriction to ASYNC_TX_DMA fsldma: do not clear bandwidth control bits on the 83xx controller fsldma: enable external start for the 83xx controller fsldma: use PCI Read Multiple command
2009-07-24crypto: hmac - Prehash ipad/opadHerbert Xu
This patch uses crypto_shash_export/crypto_shash_import to prehash ipad/opad to speed up hmac. This is partly based on a similar patch by Steffen Klassert. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-24crypto: aes - Undefined behaviour in crypto_aes_expand_keyPhil Carmody
It's undefined behaviour in C to write outside the bounds of an array. The key expansion routine takes a shortcut of creating 8 words at a time, but this creates 4 additional words which don't fit in the array. As everyone is hopefully now aware, GCC is at liberty to make any assumptions and optimisations it likes in situations where it can detect that UB has occured, up to and including nasal demons, and as the indices being accessed in the array are trivially calculable, it's rash to invite gcc to do take any liberties at all. Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-24crypto: shash - Test for the algorithms import function before exporting itSteffen Klassert
crypto_init_shash_ops_async() tests for setkey and not for import before exporting the algorithms import function to ahash. This patch fixes this. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-24crypto: ahash - Use GFP_KERNEL on allocation if the request can sleepSteffen Klassert
ahash_op_unaligned() and ahash_def_finup() allocate memory atomically, regardless whether the request can sleep or not. This patch changes this to use GFP_KERNEL if the request can sleep. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: shash - Require all algorithms to support export/importHerbert Xu
This patch provides a default export/import function for all shash algorithms. It simply copies the descriptor context as is done by sha1_generic. This in essence means that all existing shash algorithms now support export/import. This is something that will be depended upon in implementations such as hmac. Therefore all new shash and ahash implementations must support export/import. For those that cannot obtain a partial result, padlock-sha's fallback model should be used so that a partial result is always available. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: sha512_generic - Use 64-bit countersHerbert Xu
This patch replaces the 32-bit counters in sha512_generic with 64-bit counters. It also switches the bit count to the simpler byte count. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: sha512 - Export struct sha512_stateHerbert Xu
This patch renames struct sha512_ctx and exports it as struct sha512_state so that other sha512 implementations can use it as the reference structure for exporting their state. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
