commit dd59b8537f6cb53ab863fafad86a5828f1e889a2 upstream
ASYNC_TX: fix dependency chaining
In ASYNC_TX we track the dependencies between the descriptors
using the 'next' pointers of the structures. These pointers are
set to NULL as soon as the corresponding descriptor has been
submitted to the channel (in async_tx_run_dependencies()).
But, the first 'next' in chain still remains set, regardless
the fact, that tx->next is already submitted. This may lead to
multiple submisions of the same descriptor. This patch fixes this.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
commit 516280e735b034216de97eb7ba080ec6acbfc58f upstream.
Its a valid use case to have null associated data in a ccm vector, but
this case isn't being handled properly right now.
The following ccm decryption/verification test vector, using the
rfc4309 implementation regularly triggers a panic, as will any
other vector with null assoc data:
* key: ab2f8a74b71cd2b1ff802e487d82f8b9
* iv: c6fb7d800d13abd8a6b2d8
* Associated Data: [NULL]
* Tag Length: 8
* input: d5e8939fc7892e2b
The resulting panic looks like so:
Unable to handle kernel paging request at ffff810064ddaec0 RIP:
[<ffffffff8864c4d7>] :ccm:get_data_to_compute+0x1a6/0x1d6
PGD 8063 PUD 0
Oops: 0002 [1] SMP
last sysfs file: /module/libata/version
CPU 0
Modules linked in: crypto_tester_kmod(U) seqiv krng ansi_cprng chainiv rng ctr aes_generic aes_x86_64 ccm cryptomgr testmgr_cipher testmgr aead crypto_blkcipher crypto_a
lgapi des ipv6 xfrm_nalgo crypto_api autofs4 hidp l2cap bluetooth nfs lockd fscache nfs_acl sunrpc ip_conntrack_netbios_ns ipt_REJECT xt_state ip_conntrack nfnetlink xt_
tcpudp iptable_filter ip_tables x_tables dm_mirror dm_log dm_multipath scsi_dh dm_mod video hwmon backlight sbs i2c_ec button battery asus_acpi acpi_memhotplug ac lp sg
snd_intel8x0 snd_ac97_codec ac97_bus snd_seq_dummy snd_seq_oss joydev snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss ide_cd snd_pcm floppy parport_p
c shpchp e752x_edac snd_timer e1000 i2c_i801 edac_mc snd soundcore snd_page_alloc i2c_core cdrom parport serio_raw pcspkr ata_piix libata sd_mod scsi_mod ext3 jbd uhci_h
cd ohci_hcd ehci_hcd
Pid: 12844, comm: crypto-tester Tainted: G 2.6.18-128.el5.fips1 #1
RIP: 0010:[<ffffffff8864c4d7>] [<ffffffff8864c4d7>] :ccm:get_data_to_compute+0x1a6/0x1d6
RSP: 0018:ffff8100134434e8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff8100104898b0 RCX: ffffffffab6aea10
RDX: 0000000000000010 RSI: ffff8100104898c0 RDI: ffff810064ddaec0
RBP: 0000000000000000 R08: ffff8100104898b0 R09: 0000000000000000
R10: ffff8100103bac84 R11: ffff8100104898b0 R12: ffff810010489858
R13: ffff8100104898b0 R14: ffff8100103bac00 R15: 0000000000000000
FS: 00002ab881adfd30(0000) GS:ffffffff803ac000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff810064ddaec0 CR3: 0000000012a88000 CR4: 00000000000006e0
Process crypto-tester (pid: 12844, threadinfo ffff810013442000, task ffff81003d165860)
Stack: ffff8100103bac00 ffff8100104898e8 ffff8100134436f8 ffffffff00000000
0000000000000000 ffff8100104898b0 0000000000000000 ffff810010489858
0000000000000000 ffff8100103bac00 ffff8100134436f8 ffffffff8864c634
Call Trace:
[<ffffffff8864c634>] :ccm:crypto_ccm_auth+0x12d/0x140
[<ffffffff8864cf73>] :ccm:crypto_ccm_decrypt+0x161/0x23a
[<ffffffff88633643>] :crypto_tester_kmod:cavs_test_rfc4309_ccm+0x4a5/0x559
The above is from a RHEL5-based kernel, but upstream is susceptible too.
The fix is trivial: in crypto/ccm.c:crypto_ccm_auth(), pctx->ilen contains
whatever was in memory when pctx was allocated if assoclen is 0. The tested
fix is to simply add an else clause setting pctx->ilen to 0 for the
assoclen == 0 case, so that get_data_to_compute() doesn't try doing
things its not supposed to.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
commit 29b37f42127f7da511560a40ea74f5047da40c13 upstream.
As it is if an algorithm with a zero-length IV is used (e.g.,
NULL encryption) with authenc, authenc may generate an SG entry
of length zero, which will trigger a BUG check in the hash layer.
This patch fixes it by skipping the IV SG generation if the IV
size is zero.
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
async_xor: dma_map destination DMA_BIDIRECTIONAL
dmaengine: protect 'id' from concurrent registrations
ioat: wait for self-test completion
If we have at least one algorithm built-in then it no longer makes
sense to have the testing framework, and hence cryptomgr to be a
module. It should be either on or off, i.e., built-in or disabled.
This just happens to stop a potential runaway modprobe loop that
seems to trigger on at least one distro.
With fixes from Evgeniy Polyakov.
Mapping the destination multiple times is a misuse of the dma-api.
Since the destination may be reused as a source, ensure that it is only
mapped once and that it is mapped bidirectionally. This appears to add
ugliness on the unmap side in that it always reads back the destination
address from the descriptor, but gcc can determine that dma_unmap is a
nop and not emit the code that calculates its arguments.
Cc: <stable@kernel.org>
Cc: Saeed Bishara <saeed@marvell.com>
Acked-by: Yuri Tikhonov <yur@emcraft.com>
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
fsldma: allow Freescale Elo DMA driver to be compiled as a module
fsldma: remove internal self-test from Freescale Elo DMA driver
drivers/dma/dmatest.c: switch a GFP_ATOMIC to GFP_KERNEL
dmatest: properly handle duplicate DMA channels
drivers/dma/ioat_dma.c: drop code after return
async_tx: make async_tx_run_dependencies() easier to read
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: skcipher - Use RNG interface instead of get_random_bytes
crypto: rng - RNG interface and implementation
crypto: api - Add fips_enable flag
crypto: skcipher - Move IV generators into their own modules
crypto: cryptomgr - Test ciphers using ECB
crypto: api - Use test infrastructure
crypto: cryptomgr - Add test infrastructure
crypto: tcrypt - Add alg_test interface
crypto: tcrypt - Abort and only log if there is an error
crypto: crc32c - Use Intel CRC32 instruction
crypto: tcrypt - Avoid using contiguous pages
crypto: api - Display larval objects properly
crypto: api - Export crypto_alg_lookup instead of __crypto_alg_lookup
crypto: Kconfig - Replace leading spaces with tabs
* Rename 'next' to 'dep'
* Move the channel switch check inside the loop to simplify
termination
Acked-by: Ilya Yanok <yanok@emcraft.com>
This reverts commit bd699f2df6dbc2f4cba528fe598bd63a4d3702c5,
which causes camellia to fail the included self-test vectors.
It has also been confirmed that it breaks existing encrypted
disks using camellia.
Should clear the next pointer of the TX if we are sure that the
next TX (say NXT) will be submitted to the channel too. Overwise,
we break the chain of descriptors, because we lose the information
about the next descriptor to run. So next time, when invoke
async_tx_run_dependencies() with TX, it's TX->next will be NULL, and
NXT will be never submitted.
Cc: <stable@kernel.org> [2.6.26]
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This patch makes the IV generators use the new RNG interface so
that the user can pick an RNG other than the default get_random_bytes.
This patch adds a random number generator interface as well as a
cryptographic pseudo-random number generator based on AES. It is
meant to be used in cases where a deterministic CPRNG is required.
One of the first applications will be as an input in the IPsec IV
generation process.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Add the ability to turn FIPS-compliant mode on or off at boot
In order to be FIPS compliant, several check may need to be preformed that may
be construed as unusefull in a non-compliant mode. This patch allows us to set
a kernel flag incating that we are running in a fips-compliant mode from boot
up. It also exports that mode information to user space via a sysctl
(/proc/sys/crypto/fips_enabled).
Tested successfully by me.
This patch moves the default IV generators into their own modules
in order to break a dependency loop between cryptomgr, rng, and
blkcipher.
As it is we only test ciphers when combined with a mode. That means
users that do not invoke a mode of operations may get an untested
cipher.
This patch tests all ciphers using the ECB mode so that simple cipher
users such as ansi-cprng are also protected.
This patch makes use of the new testing infrastructure by requiring
algorithms to pass a run-time test before they're made available to
users.
This patch moves the newly created alg_test infrastructure into
cryptomgr. This shall allow us to use it for testing at algorithm
registrations.
This patch creates a new interface algorithm testing. A test can
be requested for a particular implementation of an algorithm. This
is achieved by taking both the name of the algorithm and that of
the implementation.
The all-inclusive test has also been rewritten to no longer require
a duplicate listing of all algorithms with tests. In that process
a number of missing tests have also been discovered and rectified.
The info printed is a complete waste of space when there is no error
since it doesn't tell us anything that we don't already know. If there
is an error, we can also be more verbose.
In case that there is an error, this patch also aborts the test and
returns the error to the caller. In future this will be used to
algorithms at registration time.
From NHM processor onward, Intel processors can support hardware accelerated
CRC32c algorithm with the new CRC32 instruction in SSE 4.2 instruction set.
The patch detects the availability of the feature, and chooses the most proper
way to calculate CRC32c checksum.
Byte code instructions are used for compiler compatibility.
No MMX / XMM registers is involved in the implementation.
Signed-off-by: Austin Zhang <austin.zhang@intel.com>
Signed-off-by: Kent Liu <kent.liu@intel.com>
If tcrypt is to be used as a run-time integrity test, it needs to be
more resilient in a hostile environment. For a start allocating 32K
of physically contiguous memory is definitely out.
This patch teaches it to use separate pages instead.
Rather than displaying larval objects as real objects, this patch
makes them show up under /proc/crypto as of type larval.
Since the only user of __crypto_alg_lookup is doing exactly what
crypto_alg_lookup does, we can now the latter in lieu of the former.
Instead of tabs there were two spaces.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Authenc works in two stages for encryption, it first encrypts and
then computes an ICV. The context memory of the request is used
by both operations. The problem is that when an asynchronous
encryption completes, we will compute the ICV and then reread the
context memory of the encryption to get the original request.
It just happens that we have a buffer of 16 bytes in front of the
request pointer, so ICVs of 16 bytes (such as SHA1) do not trigger
the bug. However, any attempt to uses a larger ICV instantly kills
the machine when the first asynchronous encryption is completed.
This patch fixes this by saving the request pointer before we start
the ICV computation.
The changeset ca786dc738f4f583b57b1bba7a335b5e8233f4b0
crypto: hash - Fixed digest size check
missed one spot for the digest type. This patch corrects that
error.
My changeset 4b22f0ddb6564210c9ded7ba25b2a1007733e784
crypto: tcrpyt - Remove unnecessary kmap/kunmap calls
introduced a typo that broke AEAD chunk testing. In particular,
axbuf should really be xbuf.
There is also an issue with testing the last segment when encrypting.
The additional part produced by AEAD wasn't tested. Similarly, on
decryption the additional part of the AEAD input is mistaken for
corruption.
Found-by: Yuri Tikhonov <yur@emcraft.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (24 commits)
I/OAT: I/OAT version 3.0 support
I/OAT: tcp_dma_copybreak default value dependent on I/OAT version
I/OAT: Add watchdog/reset functionality to ioatdma
iop_adma: cleanup iop_chan_xor_slot_count
iop_adma: document how to calculate the minimum descriptor pool size
iop_adma: directly reclaim descriptors on allocation failure
async_tx: make async_tx_test_ack a boolean routine
async_tx: remove depend_tx from async_tx_sync_epilog
async_tx: export async_tx_quiesce
async_tx: fix handling of the "out of descriptor" condition in async_xor
async_tx: ensure the xor destination buffer remains dma-mapped
async_tx: list_for_each_entry_rcu() cleanup
dmaengine: Driver for the Synopsys DesignWare DMA controller
dmaengine: Add slave DMA interface
dmaengine: add DMA_COMPL_SKIP_{SRC,DEST}_UNMAP flags to control dma unmap
dmaengine: Add dma_client parameter to device_alloc_chan_resources
dmatest: Simple DMA memcpy test client
dmaengine: DMA engine driver for Marvell XOR engine
iop-adma: fix platform driver hotplug/coldplug
dmaengine: track the number of clients using a channel
Fixed up conflict in drivers/dca/dca-sysfs.c manually
All callers of async_tx_sync_epilog have called async_tx_quiesce on the
depend_tx, so async_tx_sync_epilog need only call the callback to
complete the operation.
Replace open coded "wait and acknowledge" instances with async_tx_quiesce.
Ensure forward progress is made when a dmaengine driver is unable to
allocate an xor descriptor by breaking the dependency chain with
async_tx_quisce() and issue any pending descriptors.
Tested with iop-adma by setting device->max_xor = 2 to force multiple
calls to device_prep_dma_xor for each call to async_xor and limiting the
descriptor slot pool to 5. Discovered that the minimum descriptor pool
size for iop-adma is 2 * iop_chan_xor_slot_cnt(device->max_xor) + 1.
When the number of source buffers for an xor operation exceeds the hardware
channel maximum async_xor creates a chain of dependent operations. The result
of one operation is reused as an input to the next to continue the xor
calculation. The destination buffer should remain mapped for the duration of
the entire chain. To provide this guarantee the code must no longer be allowed
to fallback to the synchronous path as this will preclude the buffer from being
unmapped, i.e. the dma-driver will potentially miss the descriptor with
!DMA_COMPL_SKIP_DEST_UNMAP.
Cc: Neil Brown <neilb@suse.de>
In the rcu update side, don't use list_for_each_entry_rcu().
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Revert crypto: prng - Deterministic CPRNG
This patch is clearly not ready yet for prime time.
include/linux/rculist.h
kernel/rcupreempt.c
All new crypto interfaces should go into individual files as much
as possible in order to ensure that crypto.h does not collapse under
its own weight.
This patch moves the ahash code into crypto/hash.h and crypto/internal/hash.h
respectively.
This patch reimplements crc32c using the ahash interface. This
allows one tfm to be used by an unlimited number of users provided
that they all use the same key (which all current crc32c users do).
This patch adds the walking helpers for hash algorithms akin to
those of block ciphers. This is a necessary step before we can
reimplement existing hash algorithms using the new ahash interface.
This patch adds a cryptographic pseudo-random number generator
based on CTR(AES-128). It is meant to be used in cases where a
generation process.
The base field in ahash_tfm appears to have been cut-n-pasted from
ablkcipher. It isn't needed here at all. Similarly, the info field
in ahash_request also appears to have originated from its cipher
counter-part and is vestigial.
The digest size check on hash algorithms is incorrect. It's
perfectly valid for hash algorithms to have a digest length
longer than their block size. For example crc32c has a block
size of 1 and a digest size of 4. Rather than having it lie
about its block size, this patch fixes the checks to do what
they really should which is to bound the digest size so that
code placing the digest on the stack continue to work.
HMAC however still needs to check this as it's only defined
for such algorithms.
Similar to the rmd128.c annotations, significantly cuts down on the
noise.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Remove the private implementation of 32-bit rotation and unaligned
access with byteswapping.
As a bonus, fixes sparse warnings:
crypto/camellia.c:602:2: warning: cast to restricted __be32
crypto/camellia.c:603:2: warning: cast to restricted __be32
crypto/camellia.c:604:2: warning: cast to restricted __be32
crypto/camellia.c:605:2: warning: cast to restricted __be32
crypto/camellia.c:710:2: warning: cast to restricted __be32
crypto/camellia.c:711:2: warning: cast to restricted __be32
crypto/camellia.c:712:2: warning: cast to restricted __be32
crypto/camellia.c:713:2: warning: cast to restricted __be32
crypto/camellia.c:714:2: warning: cast to restricted __be32
crypto/camellia.c:715:2: warning: cast to restricted __be32
crypto/camellia.c:716:2: warning: cast to restricted __be32
crypto/camellia.c:717:2: warning: cast to restricted __be32
Noticed by Neil Horman: we are doing unnecessary kmap/kunmap calls
on kmalloced memory. This patch removes them. For the purposes of
testing SG construction, the underlying crypto code already does plenty
of kmap/kunmap calls anyway.
Patch to add checking of DES3 test vectors using CBC mode. FIPS-140-2
compliance mandates that any supported mode of operation must include a self
test. This satisfies that requirement for cbc(des3_ede). The included test
vector was generated by me using openssl. Key/IV was generated with the
following command:
openssl enc -des_ede_cbc -P
input and output values were generated by repeating the string "Too many
secrets" a few times over, truncating it to 128 bytes, and encrypting it with
openssl using the aformentioned key. Tested successfully by myself
Acked-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch>
