path: root/crypto
2015-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fix from Herbert Xu: "This disables the newly (4.1) added user-space AEAD interface so that we can fix issues in the underlying kernel AEAD interface. Once the new kernel AEAD interface is ready we can then reenable the user-space AEAD interface" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: algif_aead - Disable AEAD user-space for now
2015-05-26crypto: algif_aead - Disable AEAD user-space for nowHerbert Xu
The newly added AEAD user-space isn't quite ready for prime time just yet. In particular it is conflicting with the AEAD single SG list interface change so this patch disables it now. Once the SG list stuff is completely done we can then renable this interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fix from Herbert Xu: "This fixes a the crash in the newly added algif_aead interface when it tries to link SG lists" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: algif_aead - fix invalid sgl linking
2015-05-18crypto: algif_aead - fix invalid sgl linkingTadeusz Struk
This patch fixes it. Also minor updates to comments. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-24Merge tag 'md/4.1' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from Neil Brown: "More updates that usual this time. A few have performance impacts which hould mostly be positive, but RAID5 (in particular) can be very work-load ensitive... We'll have to wait and see. Highlights: - "experimental" code for managing md/raid1 across a cluster using DLM. Code is not ready for general use and triggers a WARNING if used. However it is looking good and mostly done and having in mainline will help co-ordinate development. - RAID5/6 can now batch multiple (4K wide) stripe_heads so as to handle a full (chunk wide) stripe as a single unit. - RAID6 can now perform read-modify-write cycles which should help performance on larger arrays: 6 or more devices. - RAID5/6 stripe cache now grows and shrinks dynamically. The value set is used as a minimum. - Resync is now allowed to go a little faster than the 'mininum' when there is competing IO. How much faster depends on the speed of the devices, so the effective minimum should scale with device speed to some extent" * tag 'md/4.1' of git://neil.brown.name/md: (58 commits) md/raid5: don't do chunk aligned read on degraded array. md/raid5: allow the stripe_cache to grow and shrink. md/raid5: change ->inactive_blocked to a bit-flag. md/raid5: move max_nr_stripes management into grow_one_stripe and drop_one_stripe md/raid5: pass gfp_t arg to grow_one_stripe() md/raid5: introduce configuration option rmw_level md/raid5: activate raid6 rmw feature md/raid6 algorithms: xor_syndrome() for SSE2 md/raid6 algorithms: xor_syndrome() for generic int md/raid6 algorithms: improve test program md/raid6 algorithms: delta syndrome functions raid5: handle expansion/resync case with stripe batching raid5: handle io error of batch list RAID5: batch adjacent full stripe write raid5: track overwrite disk count raid5: add a new flag to track if a stripe can be batched raid5: use flex_array for scribble data md raid0: access mddev->queue (request queue member) conditionally because it is not set when accessed from dm-raid md: allow resync to go faster when there is competing IO. md: remove 'go_faster' option from ->sync_request() ...
2015-04-22md/raid5: activate raid6 rmw featureMarkus Stockhausen
Glue it altogehter. The raid6 rmw path should work the same as the already existing raid5 logic. So emulate the prexor handling/flags and split functions as needed. 1) Enable xor_syndrome() in the async layer. 2) Split ops_run_prexor() into RAID4/5 and RAID6 logic. Xor the syndrome at the start of a rmw run as we did it before for the single parity. 3) Take care of rmw run in ops_run_reconstruct6(). Again process only the changed pages to get syndrome back into sync. 4) Enhance set_syndrome_sources() to fill NULL pages if we are in a rmw run. The lower layers will calculate start & end pages from that and call the xor_syndrome() correspondingly. 5) Adapt the several places where we ignored Q handling up to now. Performance numbers for a single E5630 system with a mix of 10 7200k desktop/server disks. 300 seconds random write with 8 threads onto a 3,2TB (10*400GB) RAID6 64K chunk without spare (group_thread_cnt=4) bsize rmw_level=1 rmw_level=0 rmw_level=1 rmw_level=0 skip_copy=1 skip_copy=1 skip_copy=0 skip_copy=0 4K 115 KB/s 141 KB/s 165 KB/s 140 KB/s 8K 225 KB/s 275 KB/s 324 KB/s 274 KB/s 16K 434 KB/s 536 KB/s 640 KB/s 534 KB/s 32K 751 KB/s 1,051 KB/s 1,234 KB/s 1,045 KB/s 64K 1,339 KB/s 1,958 KB/s 2,282 KB/s 1,962 KB/s 128K 2,673 KB/s 3,862 KB/s 4,113 KB/s 3,898 KB/s 256K 7,685 KB/s 7,539 KB/s 7,557 KB/s 7,638 KB/s 512K 19,556 KB/s 19,558 KB/s 19,652 KB/s 19,688 Kb/s Signed-off-by: Markus Stockhausen <stockhausen@collogia.de> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-15crypto: fix broken crypto_register_instance() module handlingHerbert Xu
Commit 9c521a200bc3 ("crypto: api - remove instance when test failed") tried to grab a module reference count before the module was even set. Worse, it then goes on to free the module reference count after it is set so you quickly end up with a negative module reference count which prevents people from using any instances belonging to that module. This patch moves the module initialisation before the reference count. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15crypto: fix mis-merge with the networking mergeLinus Torvalds
The networking updates from David Miller removed the iocb argument from sendmsg and recvmsg (in commit 1b784140474e: "net: Remove iocb argument from sendmsg and recvmsg"), but the crypto code had added new instances of them. When I pulled the crypto update, it was a silent semantic mis-merge, and I overlooked the new warning messages in my test-build. I try to fix those in the merge itself, but that relies on me noticing. Oh well. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 4.1: New interfaces: - user-space interface for AEAD - user-space interface for RNG (i.e., pseudo RNG) New hashes: - ARMv8 SHA1/256 - ARMv8 AES - ARMv8 GHASH - ARM assembler and NEON SHA256 - MIPS OCTEON SHA1/256/512 - MIPS img-hash SHA1/256 and MD5 - Power 8 VMX AES/CBC/CTR/GHASH - PPC assembler AES, SHA1/256 and MD5 - Broadcom IPROC RNG driver Cleanups/fixes: - prevent internal helper algos from being exposed to user-space - merge common code from assembly/C SHA implementations - misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (169 commits) crypto: arm - workaround for building with old binutils crypto: arm/sha256 - avoid sha256 code on ARMv7-M crypto: x86/sha512_ssse3 - move SHA-384/512 SSSE3 implementation to base layer crypto: x86/sha256_ssse3 - move SHA-224/256 SSSE3 implementation to base layer crypto: x86/sha1_ssse3 - move SHA-1 SSSE3 implementation to base layer crypto: arm64/sha2-ce - move SHA-224/256 ARMv8 implementation to base layer crypto: arm64/sha1-ce - move SHA-1 ARMv8 implementation to base layer crypto: arm/sha2-ce - move SHA-224/256 ARMv8 implementation to base layer crypto: arm/sha256 - move SHA-224/256 ASM/NEON implementation to base layer crypto: arm/sha1-ce - move SHA-1 ARMv8 implementation to base layer crypto: arm/sha1_neon - move SHA-1 NEON implementation to base layer crypto: arm/sha1 - move SHA-1 ARM asm implementation to base layer crypto: sha512-generic - move to generic glue implementation crypto: sha256-generic - move to generic glue implementation crypto: sha1-generic - move to generic glue implementation crypto: sha512 - implement base layer for SHA-512 crypto: sha256 - implement base layer for SHA-256 crypto: sha1 - implement base layer for SHA-1 crypto: api - remove instance when test failed crypto: api - Move alg ref count init to crypto_check_alg ...
2015-04-11new helper: msg_data_left()Al Viro
convert open-coded instances Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-10crypto: sha512-generic - move to generic glue implementationArd Biesheuvel
This updated the generic SHA-512 implementation to use the generic shared SHA-512 glue code. It also implements a .finup hook crypto_sha512_finup() and exports it to other modules. The import and export() functions and the .statesize member are dropped, since the default implementation is perfectly suitable for this module. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-10crypto: sha256-generic - move to generic glue implementationArd Biesheuvel
This updates the generic SHA-256 implementation to use the new shared SHA-256 glue code. It also implements a .finup hook crypto_sha256_finup() and exports it to other modules. The import and export() functions and the .statesize member are dropped, since the default implementation is perfectly suitable for this module. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-10crypto: sha1-generic - move to generic glue implementationArd Biesheuvel
This updated the generic SHA-1 implementation to use the generic shared SHA-1 glue code. It also implements a .finup hook crypto_sha1_finup() and exports it to other modules. The import and export() functions and the .statesize member are dropped, since the default implementation is perfectly suitable for this module. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-10crypto: api - remove instance when test failedStephan Mueller
A cipher instance is added to the list of instances unconditionally regardless of whether the associated test failed. However, a failed test implies that during another lookup, the cipher instance will be added to the list again as it will not be found by the lookup code. That means that the list can be filled up with instances whose tests failed. Note: tests only fail in reality in FIPS mode when a cipher is not marked as fips_allowed=1. This can be seen with cmac(des3_ede) that does not have a fips_allowed=1. When allocating the cipher, the allocation fails with -ENOENT due to the missing fips_allowed=1 flag (which causes the testmgr to return EINVAL). Yet, the instance of cmac(des3_ede) is shown in /proc/crypto. Allocating the cipher again fails again, but a 2nd instance is listed in /proc/crypto. The patch simply de-registers the instance when the testing failed. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-10crypto: api - Move alg ref count init to crypto_check_algHerbert Xu
We currently initialise the crypto_alg ref count in the function __crypto_register_alg. As one of the callers of that function crypto_register_instance needs to obtain a ref count before it calls __crypto_register_alg, we need to move the initialisation out of there. Since both callers of __crypto_register_alg call crypto_check_alg, this is the logical place to perform the initialisation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Stephan Mueller <smueller@chronox.de>
2015-04-09Merge branch 'iocb' into for-davemAl Viro
trivial conflict in net/socket.c and non-trivial one in crypto - that one had evaded aio_complete() removal. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-08crypto: user - Fix crypto_alg_match raceHerbert Xu
The function crypto_alg_match returns an algorithm without taking any references on it. This means that the algorithm can be freed at any time, therefore all users of crypto_alg_match are buggy. This patch fixes this by taking a reference count on the algorithm to prevent such races. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-07crypto: serpent_sse2 - Fix a typo in KconfigMasanari Iida
This patch fix a spelling typo in crypto/Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-03crypto: api - Change crypto_unregister_instance argument typeHerbert Xu
This patch makes crypto_unregister_instance take a crypto_instance instead of a crypto_alg. This allows us to remove a duplicate CRYPTO_ALG_INSTANCE check in crypto_unregister_instance. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-03crypto: api - Fix races in crypto_unregister_instanceHerbert Xu
There are multiple problems in crypto_unregister_instance: 1) The cra_refcnt BUG_ON check is racy and can cause crashes. 2) The cra_refcnt check shouldn't exist at all. 3) There is no reference on tmpl to protect the tmpl->free call. This patch rewrites the function using crypto_remove_spawn which now morphs into crypto_remove_instance. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-01crypto: algif - explicitly mark end of datatadeusz.struk@intel.com
After the TX sgl is expanded we need to explicitly mark end of data at the last buffer that contains data. Changes in v2 - use type 'bool' and true/false for 'mark'. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-01crypto: algif - use kmalloc instead of kzallocTadeusz Struk
No need to use kzalloc to allocate sgls as the structure is initialized anyway. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-01crypto: af_alg - make exports consistantTadeusz Struk
Use EXPORT_SYMBOL_GPL instead of EXPORT_SYMBOL. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31crypto: mcryptd - process CRYPTO_ALG_INTERNALStephan Mueller
The mcryptd is used as a wrapper around internal ciphers. Therefore, the mcryptd must process the internal cipher by marking mcryptd as internal if the underlying cipher is an internal cipher. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-31crypto: proc - identify internal ciphersStephan Mueller
With ciphers that now cannot be accessed via the kernel crypto API, callers shall be able to identify the ciphers that are not callable. The /proc/crypto file is added a boolean field identifying that such internal ciphers. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-31crypto: cryptd - process CRYPTO_ALG_INTERNALStephan Mueller
The cryptd is used as a wrapper around internal ciphers. Therefore, the cryptd must process the internal cipher by marking cryptd as internal if the underlying cipher is an internal cipher. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-31crypto: testmgr - use CRYPTO_ALG_INTERNALStephan Mueller
Allocate the ciphers irrespectively if they are marked as internal or not. As all ciphers, including the internal ciphers will be processed by the testmgr, it needs to be able to allocate those ciphers. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-31crypto: api - prevent helper ciphers from being usedStephan Mueller
Several hardware related cipher implementations are implemented as follows: a "helper" cipher implementation is registered with the kernel crypto API. Such helper ciphers are never intended to be called by normal users. In some cases, calling them via the normal crypto API may even cause failures including kernel crashes. In a normal case, the "wrapping" ciphers that use the helpers ensure that these helpers are invoked such that they cannot cause any calamity. Considering the AF_ALG user space interface, unprivileged users can call all ciphers registered with the crypto API, including these helper ciphers that are not intended to be called directly. That means, with AF_ALG user space may invoke these helper ciphers and may cause undefined states or side effects. To avoid any potential side effects with such helpers, the patch prevents the helpers to be called directly. A new cipher type flag is added: CRYPTO_ALG_INTERNAL. This flag shall be used to mark helper ciphers. These ciphers can only be used if the caller invoke the cipher with CRYPTO_ALG_INTERNAL in the type and mask field. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-25crypto: algif - fix warn: unsigned 'used' is never less than zerotadeusz.struk@intel.com
Change type from unsigned long to int to fix an issue reported by kbuild robot: crypto/algif_skcipher.c:596 skcipher_recvmsg_async() warn: unsigned 'used' is never less than zero. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23crypto: algif - change algif_skcipher to be asynchronousTadeusz Struk
The way the algif_skcipher works currently is that on sendmsg/sendpage it builds an sgl for the input data and then on read/recvmsg it sends the job for encryption putting the user to sleep till the data is processed. This way it can only handle one job at a given time. This patch changes it to be asynchronous by adding AIO support. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23crypto: af_alg - Allow to link sglTadeusz Struk
Allow to link af_alg sgls. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-16crypto: algif_rng - zeroize buffer with random dataStephan Mueller
Due to the change to RNGs to always return zero in success case, the RNG interface must zeroize the buffer with the length provided by the caller. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-13crypto: testmgr - fix RNG return code enforcementStephan Mueller
Due to the change to RNGs to always return zero in success case, the invocation of the RNGs in the test manager must be updated as otherwise the RNG self tests are not properly executed any more. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Alexander Bergmann <abergmann@suse.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-12crypto: arm - move ARM specific Kconfig definitions to a dedicated fileArd Biesheuvel
This moves all Kconfig symbols defined in crypto/Kconfig that depend on CONFIG_ARM to a dedicated Kconfig file in arch/arm/crypto, which is where the code that implements those features resides as well. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-12crypto: tcrypt - fix uninit sg entries in test_acipher_speedHoria Geant?
Commit 5be4d4c94b1f ("crypto: replace scatterwalk_sg_next with sg_next") did not consider the fact that scatterwalk_sg_next() was looking at sg entry length, while sg_next() looks at the "chained" sg bit. This should have no effect in theory. However in practice, there are cases where the sg table is initialized to a number of entries and some of them are not properly configured. While scatterwalk_sg_next() would have returned NULL (since sg length = 0 and sg page_link = 0), sg_next() happily returns the next unconfigured sg entry. insmod tcrypt.ko mode=500 sec=1 testing speed of async cbc(aes) (cbc-aes-talitos) encryption test 0 (128 bit key, 16 byte blocks): Unable to handle kernel paging request for data at address 0x00000000 Faulting instruction address: 0xc00d79e4 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=8 P1022 DS Modules linked in: tcrypt(+) talitos CPU: 0 PID: 2670 Comm: insmod Not tainted 4.0.0-rc1-QorIQ-SDK-V1.6+g904f1ca82209 #1 task: e8de3200 ti: e70bc000 task.ti: e70bc000 NIP: c00d79e4 LR: f92d223c CTR: c00d79c8 REGS: e70bda00 TRAP: 0300 Not tainted (4.0.0-rc1-QorIQ-SDK-V1.6+g904f1ca82209) MSR: 00029000 <CE,EE,ME> CR: 84428f22 XER: 00000000 DEAR: 00000000 ESR: 00000000 GPR00: f92d223c e70bdab0 e8de3200 00000000 e70bdbb8 00000001 00000000 00000000 GPR08: 00000000 00000000 c08b0380 27282010 c00d79c8 1003a634 00000000 e70bdf1c GPR16: e70bdef0 00000020 00000000 c08c0000 00000010 00000000 e70bdbb8 00000010 GPR24: e976d3a8 00000010 00000000 e70bdbd8 e8961010 00000001 c086e560 00000000 NIP [c00d79e4] page_address+0x1c/0x110 LR [f92d223c] talitos_map_sg+0x130/0x184 [talitos] Call Trace: [e70bdab0] [00000010] 0x10 (unreliable) [e70bdad0] [f92d223c] talitos_map_sg+0x130/0x184 [talitos] [e70bdb00] [f92d30d8] common_nonsnoop.constprop.13+0xc0/0x304 [talitos] [e70bdb30] [f933fd90] test_acipher_speed+0x434/0x7dc [tcrypt] [e70bdcc0] [f934318c] do_test+0x2478/0x306c [tcrypt] [e70bdd80] [f11fe058] tcrypt_mod_init+0x58/0x100 [tcrypt] [e70bdda0] [c0002354] do_one_initcall+0x90/0x1f4 [e70bde10] [c061fe00] do_init_module+0x60/0x1ac [e70bde30] [c00a79f0] load_module+0x185c/0x1f88 [e70bdee0] [c00a82b0] SyS_finit_module+0x7c/0x98 [e70bdf40] [c000e8b0] ret_from_syscall+0x0/0x3c Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-10crypto: octeon - enable OCTEON SHA1/256/512 module selectionAaro Koskinen
Enable user to select OCTEON SHA1/256/512 modules. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-09crypto: rng - RNGs must return 0 in success caseStephan Mueller
Change the RNGs to always return 0 in success case. This patch ensures that seqiv.c works with RNGs other than krng. seqiv expects that any return code other than 0 is an error. Without the patch, rfc4106(gcm(aes)) will not work when using a DRBG or an ANSI X9.31 RNG. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-04crypto: drbg - remove superflowous memsetsStephan Mueller
The DRBG code contains memset(0) calls to initialize a varaible that are not necessary as the variable is always overwritten by the processing. This patch increases the CTR and Hash DRBGs by about 5%. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-04crypto: drbg - use single block cipher APIStephan Mueller
The CTR DRBG only encrypts one single block at a time. Thus, use the single block crypto API to avoid additional overhead from the block chaining modes. With the patch, the speed of the DRBG increases between 30% and 40%. The DRBG still passes the CTR DRBG CAVS test. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-04crypto: powerpc/md5 - kernel configMarkus Stockhausen
Integrate the module into the kernel config tree. Signed-off-by: Markus Stockhausen <stockhausen@collogia.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-04crypto: algif - enable AEAD interface compilationStephan Mueller
Enable compilation of the AEAD AF_ALG support and provide a Kconfig option to compile the AEAD AF_ALG support. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-04crypto: algif - add AEAD supportStephan Mueller
This patch adds the AEAD support for AF_ALG. The implementation is based on algif_skcipher, but contains heavy modifications to streamline the interface for AEAD uses. To use AEAD, the user space consumer has to use the salg_type named "aead". The AEAD implementation includes some overhead to calculate the size of the ciphertext, because the AEAD implementation of the kernel crypto API makes implied assumption on the location of the authentication tag. When performing an encryption, the tag will be added to the created ciphertext (note, the tag is placed adjacent to the ciphertext). For decryption, the caller must hand in the ciphertext with the tag appended to the ciphertext. Therefore, the selection of the used memory needs to add/subtract the tag size from the source/destination buffers depending on the encryption type. The code is provided with comments explaining when and how that operation is performed. A fully working example using all aspects of AEAD is provided at http://www.chronox.de/libkcapi.html Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-02net: Remove iocb argument from sendmsg and recvmsgYing Xue
After TIPC doesn't depend on iocb argument in its internal implementations of sendmsg() and recvmsg() hooks defined in proto structure, no any user is using iocb argument in them at all now. Then we can drop the redundant iocb argument completely from kinds of implementations of both sendmsg() and recvmsg() in the entire networking stack. Cc: Christoph Hellwig <hch@lst.de> Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02crypto: powerpc/sha1 - kernel configMarkus Stockhausen
2015-03-01crypto: powerpc/aes - kernel configMarkus Stockhausen
Integrate the module into the kernel configuration Signed-off-by: Markus Stockhausen <stockhausen@collogia.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-02-27crypto: ppc/sha256 - kernel configMarkus Stockhausen
2015-02-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 3.20: - Added 192/256-bit key support to aesni GCM. - Added MIPS OCTEON MD5 support. - Fixed hwrng starvation and race conditions. - Added note that memzero_explicit is not a subsitute for memset. - Added user-space interface for crypto_rng. - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (71 commits) crypto: tcrypt - do not allocate iv on stack for aead speed tests crypto: testmgr - limit IV copy length in aead tests crypto: tcrypt - fix buflen reminder calculation crypto: testmgr - mark rfc4106(gcm(aes)) as fips_allowed crypto: caam - fix resource clean-up on error path for caam_jr_init crypto: caam - pair irq map and dispose in the same function crypto: ccp - terminate ccp_support array with empty element crypto: caam - remove unused local variable crypto: caam - remove dead code crypto: caam - don't emit ICV check failures to dmesg hwrng: virtio - drop extra empty line crypto: replace scatterwalk_sg_next with sg_next crypto: atmel - Free memory in error path crypto: doc - remove colons in comments crypto: seqiv - Ensure that IV size is at least 8 bytes crypto: cts - Weed out non-CBC algorithms MAINTAINERS: add linux-crypto to hw random crypto: cts - Remove bogus use of seqiv crypto: qat - don't need qat_auth_state struct crypto: algif_rng - fix sparse non static symbol warning ...
2015-02-10crypto: fix af_alg_make_sg() conversion to iov_iterLinus Torvalds
Commit 1d10eb2f156f ("crypto: switch af_alg_make_sg() to iov_iter") broke af_alg_make_sg() and skcipher_recvmsg() in the process of moving them to the iov_iter interfaces. The 'npages' calculation in the formar calculated the number of *bytes* in the pages, and in the latter case the conversion didn't re-read the value of 'ctx->used' after waiting for it to become non-zero. This reverts to the original code for both these cases. Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-04crypto: tcrypt - do not allocate iv on stack for aead speed testsCristian Stoica
See also: 9bac019dad8098a77cce555d929f678e22111783 Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-02-04crypto: testmgr - limit IV copy length in aead testsCristian Stoica
The working copy of IV is the same size as the transformation's IV. It is not necessary to copy more than that from the template since iv_len is usually less than MAX_IVLEN and the rest of the copied data is garbage. Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
