commit e6534aebb26e32fbab14df9c713c65e8507d17e4 upstream.
The algif_aead completion function tries to deduce the aead_request
from the crypto_async_request argument. This is broken because
the API does not guarantee that the same request will be pased to
the completion function. Only the value of req->data can be used
in the completion function.
This patch fixes it by storing a pointer to sk in areq and using
that instead of passing in sk through req->data.
Fixes: 83094e5e9e49 ("crypto: af_alg - add async support to...")
commit 6207119444595d287b1e9e83a2066c17209698f3 upstream.
With this reproducer:
struct sockaddr_alg alg = {
.salg_family = 0x26,
.salg_type = "hash",
.salg_feat = 0xf,
.salg_mask = 0x5,
.salg_name = "digest_null",
int sock, sock2;
sock = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(sock, (struct sockaddr *)&alg, sizeof(alg));
sock2 = accept(sock, NULL, NULL);
setsockopt(sock, SOL_ALG, ALG_SET_KEY, "\x9b\xca", 2);
accept(sock2, NULL, NULL);
==== 8< ======== 8< ======== 8< ======== 8< ====
one can immediatelly see an UBSAN warning:
UBSAN: Undefined behaviour in crypto/algif_hash.c:187:7
variable length array bound value 0 <= 0
CPU: 0 PID: 15949 Comm: syz-executor Tainted: G E 4.4.30-0-default #1
Call Trace:
[<ffffffff81d598fd>] ? __ubsan_handle_vla_bound_not_positive+0x13d/0x188
[<ffffffff81d597c0>] ? __ubsan_handle_out_of_bounds+0x1bc/0x1bc
[<ffffffffa0e2204d>] ? hash_accept+0x5bd/0x7d0 [algif_hash]
[<ffffffffa0e2293f>] ? hash_accept_nokey+0x3f/0x51 [algif_hash]
[<ffffffffa0e206b0>] ? hash_accept_parent_nokey+0x4a0/0x4a0 [algif_hash]
[<ffffffff8235c42b>] ? SyS_accept+0x2b/0x40
It is a correct warning, as hash state is propagated to accept as zero,
but creating a zero-length variable array is not allowed in C.
Fix this as proposed by Herbert -- do "?: 1" on that site. No sizeof or
similar happens in the code there, so we just allocate one byte even
though we do not use the array.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: "David S. Miller" <davem@davemloft.net> (maintainer:CRYPTO API)
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 7d6e9105026788c497f0ab32fa16c82f4ab5ff61 upstream.
An ancient gcc bug (first reported in 2003) has apparently resurfaced
on MIPS, where kernelci.org reports an overly large stack frame in the
whirlpool hash algorithm:
crypto/wp512.c:987:1: warning: the frame size of 1112 bytes is larger than 1024 bytes [-Wframe-larger-than=]
With some testing in different configurations, I'm seeing large
variations in stack frames size up to 1500 bytes for what should have
around 300 bytes at most. I also checked the reference implementation,
which is essentially the same code but also comes with some test and
benchmarking infrastructure.
It seems that recent compiler versions on at least arm, arm64 and powerpc
have a partial fix for this problem, but enabling "-fsched-pressure", but
even with that fix they suffer from the issue to a certain degree. Some
testing on arm64 shows that the time needed to hash a given amount of
data is roughly proportional to the stack frame size here, which makes
sense given that the wp512 implementation is doing lots of loads for
table lookups, and the problem with the overly large stack is a result
of doing a lot more loads and stores for spilled registers (as seen from
inspecting the object code).
Disabling -fschedule-insns consistently fixes the problem for wp512,
in my collection of cross-compilers, the results are consistently better
or identical when comparing the stack sizes in this function, though
some architectures (notable x86) have schedule-insns disabled by
default.
The four columns are:
default: -O2
press: -O2 -fsched-pressure
nopress: -O2 -fschedule-insns -fno-sched-pressure
nosched: -O2 -no-schedule-insns (disables sched-pressure)
default press nopress nosched
alpha-linux-gcc-4.9.3 1136 848 1136 176
am33_2.0-linux-gcc-4.9.3 2100 2076 2100 2104
arm-linux-gnueabi-gcc-4.9.3 848 848 1048 352
cris-linux-gcc-4.9.3 272 272 272 272
frv-linux-gcc-4.9.3 1128 1000 1128 280
hppa64-linux-gcc-4.9.3 1128 336 1128 184
hppa-linux-gcc-4.9.3 644 308 644 276
i386-linux-gcc-4.9.3 352 352 352 352
m32r-linux-gcc-4.9.3 720 656 720 268
microblaze-linux-gcc-4.9.3 1108 604 1108 256
mips64-linux-gcc-4.9.3 1328 592 1328 208
mips-linux-gcc-4.9.3 1096 624 1096 240
powerpc64-linux-gcc-4.9.3 1088 432 1088 160
powerpc-linux-gcc-4.9.3 1080 584 1080 224
s390-linux-gcc-4.9.3 456 456 624 360
sh3-linux-gcc-4.9.3 292 292 292 292
sparc64-linux-gcc-4.9.3 992 240 992 208
sparc-linux-gcc-4.9.3 680 592 680 312
x86_64-linux-gcc-4.9.3 224 240 272 224
xtensa-linux-gcc-4.9.3 1152 704 1152 304
aarch64-linux-gcc-7.0.0 224 224 1104 208
arm-linux-gnueabi-gcc-7.0.1 824 824 1048 352
mips-linux-gcc-7.0.0 1120 648 1120 272
x86_64-linux-gcc-7.0.1 240 240 304 240
arm-linux-gnueabi-gcc-4.4.7 840 392
arm-linux-gnueabi-gcc-4.5.4 784 728 784 320
arm-linux-gnueabi-gcc-4.6.4 736 728 736 304
arm-linux-gnueabi-gcc-4.7.4 944 784 944 352
arm-linux-gnueabi-gcc-4.8.5 464 464 760 352
arm-linux-gnueabi-gcc-5.3.1 824 824 1064 336
arm-linux-gnueabi-gcc-6.1.1 808 808 1056 344
Trying the same test for serpent-generic, the picture is a bit different,
and while -fno-schedule-insns is generally better here than the default,
-fsched-pressure wins overall, so I picked that instead.
alpha-linux-gcc-4.9.3 1392 864 1392 960
am33_2.0-linux-gcc-4.9.3 536 524 536 528
arm-linux-gnueabi-gcc-4.9.3 552 552 776 536
cris-linux-gcc-4.9.3 528 528 528 528
frv-linux-gcc-4.9.3 536 400 536 504
hppa64-linux-gcc-4.9.3 524 208 524 480
hppa-linux-gcc-4.9.3 768 472 768 508
i386-linux-gcc-4.9.3 564 564 564 564
m32r-linux-gcc-4.9.3 712 576 712 532
microblaze-linux-gcc-4.9.3 724 392 724 512
mips64-linux-gcc-4.9.3 720 384 720 496
mips-linux-gcc-4.9.3 728 384 728 496
powerpc64-linux-gcc-4.9.3 704 304 704 480
powerpc-linux-gcc-4.9.3 704 296 704 480
s390-linux-gcc-4.9.3 560 560 592 536
sh3-linux-gcc-4.9.3 540 540 540 540
sparc64-linux-gcc-4.9.3 544 352 544 496
sparc-linux-gcc-4.9.3 544 344 544 496
x86_64-linux-gcc-4.9.3 528 536 576 528
xtensa-linux-gcc-4.9.3 752 544 752 544
aarch64-linux-gcc-7.0.0 432 432 656 480
arm-linux-gnueabi-gcc-7.0.1 616 616 808 536
mips-linux-gcc-7.0.0 720 464 720 488
x86_64-linux-gcc-7.0.1 536 528 600 536
arm-linux-gnueabi-gcc-4.4.7 592 440
arm-linux-gnueabi-gcc-4.5.4 776 448 776 544
arm-linux-gnueabi-gcc-4.6.4 776 448 776 544
arm-linux-gnueabi-gcc-4.7.4 768 448 768 544
arm-linux-gnueabi-gcc-4.8.5 488 488 776 544
arm-linux-gnueabi-gcc-5.3.1 552 552 776 536
arm-linux-gnueabi-gcc-6.1.1 560 560 776 536
I did not do any runtime tests with serpent, so it is possible that stack
frame size does not directly correlate with runtime performance here and
it actually makes things worse, but it's more likely to help here, and
the reduced stack frame size is probably enough reason to apply the patch,
especially given that the crypto code is often used in deep call chains.
Link: https://kernelci.org/build/id/58797d7559b5149efdf6c3a9/logs/
Link: http://www.larc.usp.br/~pbarreto/WhirlpoolPage.html
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=11488
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=79149
commit 1c68bb0f62bf8de8bb30123ea840d5168f25abea upstream.
Running with KASAN and crypto tests currently gives
BUG: KASAN: global-out-of-bounds in __test_aead+0x9d9/0x2200 at addr ffffffff8212fca0
Read of size 16 by task cryptomgr_test/1107
Address belongs to variable 0xffffffff8212fca0
CPU: 0 PID: 1107 Comm: cryptomgr_test Not tainted 4.10.0+ #45
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014
Call Trace:
dump_stack+0x63/0x8a
kasan_report.part.1+0x4a7/0x4e0
? __test_aead+0x9d9/0x2200
? crypto_ccm_init_crypt+0x218/0x3c0 [ccm]
kasan_report+0x20/0x30
check_memory_region+0x13c/0x1a0
memcpy+0x23/0x50
? kasan_unpoison_shadow+0x35/0x50
? alg_test_akcipher+0xf0/0xf0
? crypto_skcipher_init_tfm+0x2e3/0x310
? crypto_spawn_tfm2+0x37/0x60
? crypto_ccm_init_tfm+0xa9/0xd0 [ccm]
? crypto_aead_init_tfm+0x7b/0x90
? crypto_alloc_tfm+0xc4/0x190
test_aead+0x28/0xc0
alg_test_aead+0x54/0xd0
alg_test+0x1eb/0x3d0
? alg_find_test+0x90/0x90
? __sched_text_start+0x8/0x8
? __wake_up_common+0x70/0xb0
cryptomgr_test+0x4d/0x60
kthread+0x173/0x1c0
? crypto_acomp_scomp_free_ctx+0x60/0x60
? kthread_create_on_node+0xa0/0xa0
ret_from_fork+0x2c/0x40
Memory state around the buggy address:
ffffffff8212fb80: 00 00 00 00 01 fa fa fa fa fa fa fa 00 00 00 00
ffffffff8212fc00: 00 01 fa fa fa fa fa fa 00 00 00 00 01 fa fa fa
>ffffffff8212fc80: fa fa fa fa 00 05 fa fa fa fa fa fa 00 00 00 00
ffffffff8212fd00: 01 fa fa fa fa fa fa fa 00 00 00 00 01 fa fa fa
ffffffff8212fd80: fa fa fa fa 00 00 00 00 00 05 fa fa fa fa fa fa
This always happens on the same IV which is less than 16 bytes.
Per Ard,
"CCM IVs are 16 bytes, but due to the way they are constructed
internally, the final couple of bytes of input IV are dont-cares.
Apparently, we do read all 16 bytes, which triggers the KASAN errors."
Fix this by padding the IV with null bytes to be at least 16 bytes.
Fixes: 0bc5a6c5c79a ("crypto: testmgr - Disable rfc4309 test and convert test vectors")
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Laura Abbott <labbott@redhat.com>
commit 0b529f143e8baad441a5aac9ad55ec2434d8fb46 upstream.
Kernel panics when userspace program try to access AEAD interface.
Remove node from Linked List before freeing its memory.
Signed-off-by: Harsh Jain <harsh@chelsio.com>
Reviewed-by: Stephan Müller <smueller@chronox.de>
commit d6040764adcb5cb6de1489422411d701c158bb69 upstream.
Make sure CRYPTO_ALG_DEAD bit is cleared before proceeding with
the algorithm registration. This fixes qat-dh registration when
driver is restarted
Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto fixes from Herbert Xu:
"This fixes the following issues:
- Fix pointer size when caam is used with AArch64 boot loader on
AArch32 kernel.
- Fix ahash state corruption in marvell driver.
- Fix buggy algif_aed tag handling.
- Prevent mcryptd from being used with incompatible algorithms which
can cause crashes"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: algif_aead - fix uninitialized variable warning
crypto: mcryptd - Check mcryptd algorithm compatibility
crypto: algif_aead - fix AEAD tag memory handling
crypto: caam - fix pointer size for AArch64 boot loader, AArch32 kernel
crypto: marvell - Don't corrupt state of an STD req for re-stepped ahash
crypto: marvell - Don't copy hash operation twice into the SRAM
In case the user provided insufficient data, the code may return
prematurely without any operation. In this case, the processed
data indicated with outlen is zero.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
Algorithms not compatible with mcryptd could be spawned by mcryptd
with a direct crypto_alloc_tfm invocation using a "mcryptd(alg)" name
construct. This causes mcryptd to crash the kernel if an arbitrary
"alg" is incompatible and not intended to be used with mcryptd. It is
an issue if AF_ALG tries to spawn mcryptd(alg) to expose it externally.
But such algorithms must be used internally and not be exposed.
We added a check to enforce that only internal algorithms are allowed
with mcryptd at the time mcryptd is spawning an algorithm.
Link: http://marc.info/?l=linux-crypto-vger&m=148063683310477&w=2
Cc: stable@vger.kernel.org
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
For encryption, the AEAD ciphers require AAD || PT as input and generate
AAD || CT || Tag as output and vice versa for decryption. Prior to this
patch, the AF_ALG interface for AEAD ciphers requires the buffer to be
present as input for encryption. Similarly, the output buffer for
decryption required the presence of the tag buffer too. This implies
that the kernel reads / writes data buffers from/to kernel space
even though this operation is not required.
This patch changes the AF_ALG AEAD interface to be consistent with the
in-kernel AEAD cipher requirements.
Due to this handling, he changes are transparent to user space with one
exception: the return code of recv indicates the mount of output buffer.
That output buffer has a different size compared to before the patch
which implies that the return code of recv will also be different.
For example, a decryption operation uses 16 bytes AAD, 16 bytes CT and
16 bytes tag, the AF_ALG AEAD interface before showed a recv return
code of 48 (bytes) whereas after this patch, the return code is 32
since the tag is not returned any more.
Reported-by: Mat Martineau <mathew.j.martineau@linux.intel.com>
- Intermittent build failure in RSA
- Memory corruption in chelsio crypto driver
- Regression in DRBG due to vmalloced stack"
crypto: rsa - Add Makefile dependencies to fix parallel builds
crypto: chcr - Fix memory corruption
crypto: drbg - prevent invalid SG mappings
Both asn1 headers are included by rsa_helper.c, so rsa_helper.o
should explicitly depend on them.
Signed-off-by: David Michael <david.michael@coreos.com>
When using SGs, only heap memory (memory that is valid as per
virt_addr_valid) is allowed to be referenced. The CTR DRBG used to
reference the caller-provided memory directly in an SG. In case the
caller provided stack memory pointers, the SG mapping is not considered
to be valid. In some cases, this would even cause a paging fault.
The change adds a new scratch buffer that is used unconditionally to
catch the cases where the caller-provided buffer is not suitable for
use in an SG. The crypto operation of the CTR DRBG produces its output
with that scratch buffer and finally copies the content of the
scratch buffer to the caller's buffer.
The scratch buffer is allocated during allocation time of the CTR DRBG
as its access is protected with the DRBG mutex.
We shouldn't free cert->pub->key in x509_cert_parse() because
x509_free_certificate() also does this:
BUG: Double free or freeing an invalid pointer
Call Trace:
[<ffffffff81896c20>] dump_stack+0x63/0x83
[<ffffffff81356571>] kasan_object_err+0x21/0x70
[<ffffffff81356ed9>] kasan_report_double_free+0x49/0x60
[<ffffffff813561ad>] kasan_slab_free+0x9d/0xc0
[<ffffffff81350b7a>] kfree+0x8a/0x1a0
[<ffffffff81844fbf>] public_key_free+0x1f/0x30
[<ffffffff818455d4>] x509_free_certificate+0x24/0x90
[<ffffffff818460bc>] x509_cert_parse+0x2bc/0x300
[<ffffffff81846cae>] x509_key_preparse+0x3e/0x330
[<ffffffff818444cf>] asymmetric_key_preparse+0x6f/0x100
[<ffffffff8178bec0>] key_create_or_update+0x260/0x5f0
[<ffffffff8178e6d9>] SyS_add_key+0x199/0x2a0
[<ffffffff821d823b>] entry_SYSCALL_64_fastpath+0x1e/0xad
Object at ffff880110bd1900, in cache kmalloc-512 size: 512
Freed:
PID = 2579
[<ffffffff8104283b>] save_stack_trace+0x1b/0x20
[<ffffffff813558f6>] save_stack+0x46/0xd0
[<ffffffff81356183>] kasan_slab_free+0x73/0xc0
[<ffffffff818460a3>] x509_cert_parse+0x2a3/0x300
Fixes: db6c43bd2132 ("crypto: KEYS: convert public key and digsig asym to the akcipher api")
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: James Morris <james.l.morris@oracle.com>
The aliasing check in map_and_copy is no longer necessary because
the IPsec ESP code no longer provides an IV that points into the
actual request data. As this check is now triggering BUG checks
due to the vmalloced stack code, I'm removing it.
Reported-by: Eric Biggers <ebiggers@google.com>
Recently an init call was added to hash_recvmsg so as to reset
the hash state in case a sendmsg call was never made.
Unfortunately this ended up clobbering the result if the previous
sendmsg was done with a MSG_MORE flag. This patch fixes it by
excluding that case when we make the init call.
Fixes: a8348bca2944 ("algif_hash - Fix NULL hash crash with shash")
Reported-by: Patrick Steinhardt <ps@pks.im>
Recently algif_hash has been changed to allow null hashes. This
triggers a bug when used with an shash algorithm whereby it will
cause a crash during the digest operation.
This patch fixes it by avoiding the digest operation and instead
doing an init followed by a final which avoids the buggy code in
shash.
This patch also ensures that the result buffer is freed after an
error so that it is not returned as a genuine hash result on the
next recv call.
The shash/ahash wrapper code will be fixed later to handle this
case correctly.
Fixes: 493b2ed3f760 ("crypto: algif_hash - Handle NULL hashes correctly")
Tested-by: Laura Abbott <labbott@redhat.com>
A good practice is to prefix the names of functions by the name
of the subsystem.
The kthread worker API is a mix of classic kthreads and workqueues. Each
worker has a dedicated kthread. It runs a generic function that process
queued works. It is implemented as part of the kthread subsystem.
This patch renames the existing kthread worker API to use
the corresponding name from the workqueues API prefixed by
kthread_:
__init_kthread_worker() -> __kthread_init_worker()
init_kthread_worker() -> kthread_init_worker()
init_kthread_work() -> kthread_init_work()
insert_kthread_work() -> kthread_insert_work()
queue_kthread_work() -> kthread_queue_work()
flush_kthread_work() -> kthread_flush_work()
flush_kthread_worker() -> kthread_flush_worker()
Note that the names of DEFINE_KTHREAD_WORK*() macros stay
as they are. It is common that the "DEFINE_" prefix has
precedence over the subsystem names.
Note that INIT() macros and init() functions use different
naming scheme. There is no good solution. There are several
reasons for this solution:
+ "init" in the function names stands for the verb "initialize"
aka "initialize worker". While "INIT" in the macro names
stands for the noun "INITIALIZER" aka "worker initializer".
+ INIT() macros are used only in DEFINE() macros
+ init() functions are used close to the other kthread()
functions. It looks much better if all the functions
use the same scheme.
+ There will be also kthread_destroy_worker() that will
be used close to kthread_cancel_work(). It is related
to the init() function. Again it looks better if all
functions use the same naming scheme.
+ there are several precedents for such init() function
names, e.g. amd_iommu_init_device(), free_area_init_node(),
jump_label_init_type(), regmap_init_mmio_clk(),
+ It is not an argument but it was inconsistent even before.
[arnd@arndb.de: fix linux-next merge conflict]
Link: http://lkml.kernel.org/r/20160908135724.1311726-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/1470754545-17632-3-git-send-email-pmladek@suse.com
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Petr Mladek <pmladek@suse.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Borislav Petkov <bp@suse.de>
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 4.9:
API:
- The crypto engine code now supports hashes.
Algorithms:
- Allow keys >= 2048 bits in FIPS mode for RSA.
Drivers:
- Memory overwrite fix for vmx ghash.
- Add support for building ARM sha1-neon in Thumb2 mode.
- Reenable ARM ghash-ce code by adding import/export.
- Reenable img-hash by adding import/export.
- Add support for multiple cores in omap-aes.
- Add little-endian support for sha1-powerpc.
- Add Cavium HWRNG driver for ThunderX SoC"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (137 commits)
crypto: caam - treat SGT address pointer as u64
crypto: ccp - Make syslog errors human-readable
crypto: ccp - clean up data structure
crypto: vmx - Ensure ghash-generic is enabled
crypto: testmgr - add guard to dst buffer for ahash_export
crypto: caam - Unmap region obtained by of_iomap
crypto: sha1-powerpc - little-endian support
crypto: gcm - Fix IV buffer size in crypto_gcm_setkey
crypto: vmx - Fix memory corruption caused by p8_ghash
crypto: ghash-generic - move common definitions to a new header file
crypto: caam - fix sg dump
hwrng: omap - Only fail if pm_runtime_get_sync returns < 0
crypto: omap-sham - shrink the internal buffer size
crypto: omap-sham - add support for export/import
crypto: omap-sham - convert driver logic to use sgs for data xmit
crypto: omap-sham - change the DMA threshold value to a define
crypto: omap-sham - add support functions for sg based data handling
crypto: omap-sham - rename sgl to sgl_tmp for deprecation
crypto: omap-sham - align algorithms on word offset
crypto: omap-sham - add context export/import stubs
Merge the crypto tree to pull in vmx ghash fix.
Pull dmaengine updates from Vinod Koul:
"This is bit large pile of code which bring in some nice additions:
- Error reporting: we have added a new mechanism for users of
dmaenegine to register a callback_result which tells them the
result of the dma transaction. Right now only one user (ntb) is
using it.
- As we discussed on KS mailing list and pointed out NO_IRQ has no
place in kernel, this also remove NO_IRQ from dmaengine subsystem
(both arm and ppc users)
- Support for IOMMU slave transfers and its implementation for arm.
- To get better build coverage, enable COMPILE_TEST for bunch of
driver, and fix the warning and sparse complaints on these.
- Apart from above, usual updates spread across drivers"
* tag 'dmaengine-4.9-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (169 commits)
async_pq_val: fix DMA memory leak
dmaengine: virt-dma: move function declarations
dmaengine: omap-dma: Enable burst and data pack for SG
DT: dmaengine: rcar-dmac: document R8A7743/5 support
dmaengine: fsldma: Unmap region obtained by of_iomap
dmaengine: jz4780: fix resource leaks on error exit return
dma-debug: fix ia64 build, use PHYS_PFN
dmaengine: coh901318: fix integer overflow when shifting more than 32 places
dmaengine: edma: avoid uninitialized variable use
dma-mapping: fix m32r build warning
dma-mapping: fix ia64 build, use PHYS_PFN
dmaengine: ti-dma-crossbar: enable COMPILE_TEST
dmaengine: omap-dma: enable COMPILE_TEST
dmaengine: edma: enable COMPILE_TEST
dmaengine: ti-dma-crossbar: Fix of_device_id data parameter usage
dmaengine: ti-dma-crossbar: Correct type for of_find_property() third parameter
dmaengine/ARM: omap-dma: Fix the DMAengine compile test on non OMAP configs
dmaengine: edma: Rename set_bits and remove unused clear_bits helper
dmaengine: edma: Use correct type for of_find_property() third parameter
dmaengine: edma: Fix of_device_id data parameter usage (legacy vs TPCC)
Add missing dmaengine_unmap_put(), so we don't OOM during RAID6 sync.
Fixes: 1786b943dad0 ("async_pq_val: convert to dmaengine_unmap_data")
Signed-off-by: Justin Maggard <jmaggard@netgear.com>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Add a guard to 'state' buffer and warn if its consistency after
call to crypto_ahash_export() changes, so that any write that
goes beyond advertised statesize (and thus causing potential
memory corruption [1]) is more visible.
[1] https://marc.info/?l=linux-crypto-vger&m=147467656516085
Signed-off-by: Jan Stancek <jstancek@redhat.com>
Cc: Marcelo Cerri <marcelo.cerri@canonical.com>
The cipher block size for GCM is 16 bytes, and thus the CTR transform
used in crypto_gcm_setkey() will also expect a 16-byte IV. However,
the code currently reserves only 8 bytes for the IV, causing
an out-of-bounds access in the CTR transform. This patch fixes
the issue by setting the size of the IV buffer to 16 bytes.
Fixes: 84c911523020 ("[CRYPTO] gcm: Add support for async ciphers")
Signed-off-by: Ondrej Mosnacek <omosnacek@gmail.com>
Move common values and types used by ghash-generic to a new header file
so drivers can directly use ghash-generic as a fallback implementation.
Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module")
Signed-off-by: Marcelo Cerri <marcelo.cerri@canonical.com>
As the software RSA implementation now produces fixed-length
output, we need to eliminate leading zeros in the calling code
instead.
This patch does just that for pkcs1pad decryption while signature
verification was fixed in an earlier patch.
Fixes: 9b45b7bba3d2 ("crypto: rsa - Generate fixed-length output")
Remove unneeded variables and assignments.
When we need to allocate a temporary blkcipher_walk_next and it
fails, the code is supposed to take the slow path of processing
the data block by block. However, due to an unrelated change
we instead end up dereferencing the NULL pointer.
This patch fixes it by moving the unrelated bsize setting out
of the way so that we enter the slow path as inteded.
Fixes: 7607bd8ff03b ("[CRYPTO] blkcipher: Added blkcipher_walk_virt_block")
Reported-by: xiakaixu <xiakaixu@huawei.com>
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
The current implementation uses a global per-cpu array to store
data which are used to derive the next IV. This is insecure as
the attacker may change the stored data.
This patch removes all traces of chaining and replaces it with
multiplication of the salt and the sequence number.
Fixes: a10f554fa7e0 ("crypto: echainiv - Add encrypted chain IV...")
Reported-by: Mathias Krause <minipli@googlemail.com>
Right now attempting to read an empty hash simply returns zeroed
bytes, this patch corrects this by calling the digest function
using an empty input.
Reported-by: Russell King - ARM Linux <linux@armlinux.org.uk>
The current crypto engine allow only ablkcipher_request to be enqueued.
Thus denying any use of it for hardware that also handle hash algo.
This patch modify the API for allowing to enqueue ciphers and hash.
Since omap-aes/omap-des are the only users, this patch also convert them
to the new cryptoengine API.
Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com>
This patch move the whole crypto engine API to its own header
crypto/engine.h.
When calling .import() on a cryptd ahash_request, the structure members
that describe the child transform in the shash_desc need to be initialized
like they are when calling .init()
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
In FIPS mode, additional restrictions may apply. If these restrictions
are violated, the kernel will panic(). This patch allows test vectors
for symmetric ciphers to be marked as to be skipped in FIPS mode.
Together with the patch, the XTS test vectors where the AES key is
identical to the tweak key is disabled in FIPS mode. This test vector
violates the FIPS requirement that both keys must be different.
Reported-by: Tapas Sarangi <TSarangi@trustwave.com>
This patch fixes an unused label warning triggered when the macro
XOR_SELECT_TEMPLATE is not set.
Fixes: 39457acda913 ("crypto: xor - skip speed test if the xor...")
Suggested-by: Stephen Rothwell <sfr@canb.auug.org.au>
The AEAD code path incorrectly uses the child tfm to track the
cryptd refcnt, and then potentially frees the child tfm.
Fixes: 81760ea6a95a ("crypto: cryptd - Add helpers to check...")
Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
With a public notification, NIST now allows the use of RSA keys with a
modulus >= 2048 bits. The new rule allows any modulus size >= 2048 bits
provided that either 2048 or 3072 bits are supported at least so that
the entire RSA implementation can be CAVS tested.
This patch fixes the inability to boot the kernel in FIPS mode, because
certs/x509.genkey defines a 4096 bit RSA key per default. This key causes
the RSA signature verification to fail in FIPS mode without the patch
below.
Fix to return a negative error code from the error handling
case instead of 0.
Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com>
Acked-by: Stephan Mueller <smueller@chronox.de>
If the architecture selected the xor function with XOR_SELECT_TEMPLATE
the speed result of the do_xor_speed benchmark is of limited value.
The speed measurement increases the bootup time a little, which can
makes a difference for kernels used in container like virtual machines.
When calling the DRBG health test in FIPS mode, the Jitter RNG is not
yet present in the kernel crypto API which will cause the instantiation
to fail and thus the health test to fail.
As the health tests cover the enforcement of various thresholds, invoke
the functions that are supposed to enforce the thresholds directly.
This patch also saves precious seed.
The sentence 'Based on' is misspelled, respell it.
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
"if (!ret == template[i].fail)" is confusing to compilers (gcc5):
crypto/testmgr.c: In function '__test_aead':
crypto/testmgr.c:531:12: warning: logical not is only applied to the
left hand side of comparison [-Wlogical-not-parentheses]
if (!ret == template[i].fail) {
Let there be 'if (template[i].fail == !ret) '.
Signed-off-by: Yanjiang Jin <yanjiang.jin@windriver.com>
The optimised crc32c implementation depends on VMX (aka. Altivec)
instructions, so the kernel must be built with Altivec support in order
for the crc32c code to build.
Fixes: 6dd7a82cc54e ("crypto: powerpc - Add POWER8 optimised crc32c")
Acked-by: Anton Blanchard <anton@samba.org>
On 32-bit (e.g. with m68k-linux-gnu-gcc-4.1):
crypto/sha3_generic.c:27: warning: integer constant is too large for ‘long’ type
crypto/sha3_generic.c:28: warning: integer constant is too large for ‘long’ type
crypto/sha3_generic.c:29: warning: integer constant is too large for ‘long’ type
crypto/sha3_generic.c:31: warning: integer constant is too large for ‘long’ type
crypto/sha3_generic.c:32: warning: integer constant is too large for ‘long’ type
crypto/sha3_generic.c:33: warning: integer constant is too large for ‘long’ type
crypto/sha3_generic.c:34: warning: integer constant is too large for ‘long’ type
Fixes: 53964b9ee63b7075 ("crypto: sha3 - Add SHA-3 hash algorithm")
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull random driver updates from Ted Ts'o:
"A number of improvements for the /dev/random driver; the most
important is the use of a ChaCha20-based CRNG for /dev/urandom, which
is faster, more efficient, and easier to make scalable for
silly/abusive userspace programs that want to read from /dev/urandom
in a tight loop on NUMA systems.
This set of patches also improves entropy gathering on VM's running on
Microsoft Azure, and will take advantage of a hw random number
generator (if present) to initialize the /dev/urandom pool"
(It turns out that the random tree hadn't been in linux-next this time
around, because it had been dropped earlier as being too quiet. Oh
well).
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random:
random: strengthen input validation for RNDADDTOENTCNT
random: add backtracking protection to the CRNG
random: make /dev/urandom scalable for silly userspace programs
random: replace non-blocking pool with a Chacha20-based CRNG
random: properly align get_random_int_hash
random: add interrupt callback to VMBus IRQ handler
random: print a warning for the first ten uninitialized random users
random: initialize the non-blocking pool via add_hwgenerator_randomness()
"Here is the crypto update for 4.8:
API:
- first part of skcipher low-level conversions
- add KPP (Key-agreement Protocol Primitives) interface.
Algorithms:
- fix IPsec/cryptd reordering issues that affects aesni
- RSA no longer does explicit leading zero removal
- add SHA3
- add DH
- add ECDH
- improve DRBG performance by not doing CTR by hand
Drivers:
- add x86 AVX2 multibuffer SHA256/512
- add POWER8 optimised crc32c
- add xts support to vmx
- add DH support to qat
- add RSA support to caam
- add Layerscape support to caam
- add SEC1 AEAD support to talitos
- improve performance by chaining requests in marvell/cesa
- add support for Araneus Alea I USB RNG
- add support for Broadcom BCM5301 RNG
- add support for Amlogic Meson RNG
- add support Broadcom NSP SoC RNG"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (180 commits)
crypto: vmx - Fix aes_p8_xts_decrypt build failure
crypto: vmx - Ignore generated files
crypto: vmx - Adding support for XTS
crypto: vmx - Adding asm subroutines for XTS
crypto: skcipher - add comment for skcipher_alg->base
crypto: testmgr - Print akcipher algorithm name
crypto: marvell - Fix wrong flag used for GFP in mv_cesa_dma_add_iv_op
crypto: nx - off by one bug in nx_of_update_msc()
crypto: rsa-pkcs1pad - fix rsa-pkcs1pad request struct
crypto: scatterwalk - Inline start/map/done
crypto: scatterwalk - Remove unnecessary BUG in scatterwalk_start
crypto: scatterwalk - Remove unnecessary advance in scatterwalk_pagedone
crypto: scatterwalk - Fix test in scatterwalk_done
crypto: api - Optimise away crypto_yield when hard preemption is on
crypto: scatterwalk - add no-copy support to copychunks
crypto: scatterwalk - Remove scatterwalk_bytes_sglen
crypto: omap - Stop using crypto scatterwalk_bytes_sglen
crypto: skcipher - Remove top-level givcipher interface
crypto: user - Remove crypto_lookup_skcipher call
crypto: cts - Convert to skcipher
"This fixes a sporadic build failure in the qat driver as well as a
memory corruption bug in rsa-pkcs1pad"
crypto: qat - make qat_asym_algs.o depend on asn1 headers
To allow for child request context the struct akcipher_request child_req
needs to be at the end of the structure.
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Merge the crypto tree to resolve conflict in qat Makefile.
When an akcipher test fails, we don't know which algorithm failed
because the name is not printed. This patch fixes this.
