path: root/crypto
2012-11-26crypto: cryptd - disable softirqs in cryptd_queue_worker to prevent data ↵Jussi Kivilinna
corruption commit 9efade1b3e981f5064f9db9ca971b4dc7557ae42 upstream. cryptd_queue_worker attempts to prevent simultaneous accesses to crypto workqueue by cryptd_enqueue_request using preempt_disable/preempt_enable. However cryptd_enqueue_request might be called from softirq context, so add local_bh_disable/local_bh_enable to prevent data corruption and panics. Bug report at http://marc.info/?l=linux-crypto-vger&m=134858649616319&w=2 v2: - Disable software interrupts instead of hardware interrupts Reported-by: Gurucharan Shetty <gurucharan.shetty@gmail.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: - Locking fix for talitos driver - Fix 64-bit counter overflow in SHA-512 - Build fix for ixp4xx. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: talitos - properly lock access to global talitos registers crypto: ixp4xx - include fix crypto: sha512 - Fix byte counter overflow in SHA-512
2012-04-09um: several x86 hw-dependent crypto modules won't build on umlAl Viro
2012-04-05crypto: sha512 - Fix byte counter overflow in SHA-512Kent Yoder
The current code only increments the upper 64 bits of the SHA-512 byte counter when the number of bytes hashed happens to hit 2^64 exactly. This patch increments the upper 64 bits whenever the lower 64 bits overflows. Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com> Cc: stable@kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: - Fix for CPU hotplug hang in padata. - Avoid using cpu_active inappropriately in pcrypt and padata. - Fix for user-space algorithm lookup hang with IV generators. - Fix for netlink dump of algorithms where stuff went missing due to incorrect calculation of message size. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: user - Fix size of netlink dump message crypto: user - Fix lookup of algorithms with IV generator crypto: pcrypt - Use the online cpumask as the default padata: Fix cpu hotplug padata: Use the online cpumask as the default padata: Add a reference to the api documentation
2012-03-29crypto: user - Fix size of netlink dump messageSteffen Klassert
The default netlink message size limit might be exceeded when dumping a lot of algorithms to userspace. As a result, not all of the instantiated algorithms dumped to userspace. So calculate an upper bound on the message size and call netlink_dump_start() with that value. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-29crypto: user - Fix lookup of algorithms with IV generatorSteffen Klassert
We lookup algorithms with crypto_alg_mod_lookup() when instantiating via crypto_add_alg(). However, algorithms that are wrapped by an IV genearator (e.g. aead or genicv type algorithms) need special care. The userspace process hangs until it gets a timeout when we use crypto_alg_mod_lookup() to lookup these algorithms. So export the lookup functions for these algorithms and use them in crypto_add_alg(). Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-29crypto: pcrypt - Use the online cpumask as the defaultSteffen Klassert
We use the active cpumask to determine the superset of cpus to use for parallelization. However, the active cpumask is for internal usage of the scheduler and therefore not the appropriate cpumask for these purposes. So use the online cpumask instead. Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-23crypto: crc32c should use library implementationDarrick J. Wong
Since lib/crc32.c now provides crc32c, remove the software implementation here and call the library function instead. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Bob Pearson <rpearson@systemfabricworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "* sha512 bug fixes (already in your tree). * SHA224/SHA384 AEAD support in caam. * X86-64 optimised version of Camellia. * Tegra AES support. * Bulk algorithm registration interface to make driver registration easier. * padata race fixes. * Misc fixes." * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits) padata: Fix race on sequence number wrap padata: Fix race in the serialization path crypto: camellia - add assembler implementation for x86_64 crypto: camellia - rename camellia.c to camellia_generic.c crypto: camellia - fix checkpatch warnings crypto: camellia - rename camellia module to camellia_generic crypto: tcrypt - add more camellia tests crypto: testmgr - add more camellia test vectors crypto: camellia - simplify key setup and CAMELLIA_ROUNDSM macro crypto: twofish-x86_64/i586 - set alignmask to zero crypto: blowfish-x86_64 - set alignmask to zero crypto: serpent-sse2 - combine ablk_*_init functions crypto: blowfish-x86_64 - use crypto_[un]register_algs crypto: twofish-x86_64-3way - use crypto_[un]register_algs crypto: serpent-sse2 - use crypto_[un]register_algs crypto: serpent-sse2 - remove dead code from serpent_sse2_glue.c::serpent_sse2_init() crypto: twofish-x86 - Remove dead code from twofish_glue_3way.c::init() crypto: In crypto_add_alg(), 'exact' wants to be initialized to 0 crypto: caam - fix gcc 4.6 warning crypto: Add bulk algorithm registration interface ...
2012-03-21Merge branch 'kmap_atomic' of git://github.com/congwang/linuxLinus Torvalds
Pull kmap_atomic cleanup from Cong Wang. It's been in -next for a long time, and it gets rid of the (no longer used) second argument to k[un]map_atomic(). Fix up a few trivial conflicts in various drivers, and do an "evil merge" to catch some new uses that have come in since Cong's tree. * 'kmap_atomic' of git://github.com/congwang/linux: (59 commits) feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] drbd: remove the second argument of k[un]map_atomic() zcache: remove the second argument of k[un]map_atomic() gma500: remove the second argument of k[un]map_atomic() dm: remove the second argument of k[un]map_atomic() tomoyo: remove the second argument of k[un]map_atomic() sunrpc: remove the second argument of k[un]map_atomic() rds: remove the second argument of k[un]map_atomic() net: remove the second argument of k[un]map_atomic() mm: remove the second argument of k[un]map_atomic() lib: remove the second argument of k[un]map_atomic() power: remove the second argument of k[un]map_atomic() kdb: remove the second argument of k[un]map_atomic() udf: remove the second argument of k[un]map_atomic() ubifs: remove the second argument of k[un]map_atomic() squashfs: remove the second argument of k[un]map_atomic() reiserfs: remove the second argument of k[un]map_atomic() ocfs2: remove the second argument of k[un]map_atomic() ntfs: remove the second argument of k[un]map_atomic() ...
2012-03-20crypto: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-14crypto: camellia - add assembler implementation for x86_64Jussi Kivilinna
Patch adds x86_64 assembler implementation of Camellia block cipher. Two set of functions are provided. First set is regular 'one-block at time' encrypt/decrypt functions. Second is 'two-block at time' functions that gain performance increase on out-of-order CPUs. Performance of 2-way functions should be equal to 1-way functions with in-order CPUs. Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmark results: AMD Phenom II 1055T (fam:16, model:10): camellia-asm vs camellia_generic: 128bit key: (lrw:256bit) (xts:256bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 1.27x 1.22x 1.30x 1.42x 1.30x 1.34x 1.19x 1.05x 1.23x 1.24x 64B 1.74x 1.79x 1.43x 1.87x 1.81x 1.87x 1.48x 1.38x 1.55x 1.62x 256B 1.90x 1.87x 1.43x 1.94x 1.94x 1.95x 1.63x 1.62x 1.67x 1.70x 1024B 1.96x 1.93x 1.43x 1.95x 1.98x 2.01x 1.67x 1.69x 1.74x 1.80x 8192B 1.96x 1.96x 1.39x 1.93x 2.01x 2.03x 1.72x 1.64x 1.71x 1.76x 256bit key: (lrw:384bit) (xts:512bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 1.23x 1.23x 1.33x 1.39x 1.34x 1.38x 1.04x 1.18x 1.21x 1.29x 64B 1.72x 1.69x 1.42x 1.78x 1.81x 1.89x 1.57x 1.52x 1.56x 1.65x 256B 1.85x 1.88x 1.42x 1.86x 1.93x 1.96x 1.69x 1.65x 1.70x 1.75x 1024B 1.88x 1.86x 1.45x 1.95x 1.96x 1.95x 1.77x 1.71x 1.77x 1.78x 8192B 1.91x 1.86x 1.42x 1.91x 2.03x 1.98x 1.73x 1.71x 1.78x 1.76x camellia-asm vs aes-asm (8kB block): 128bit 256bit ecb-enc 1.15x 1.22x ecb-dec 1.16x 1.16x cbc-enc 0.85x 0.90x cbc-dec 1.20x 1.23x ctr-enc 1.28x 1.30x ctr-dec 1.27x 1.28x lrw-enc 1.12x 1.16x lrw-dec 1.08x 1.10x xts-enc 1.11x 1.15x xts-dec 1.14x 1.15x Intel Core2 T8100 (fam:6, model:23, step:6): camellia-asm vs camellia_generic: 128bit key: (lrw:256bit) (xts:256bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 1.10x 1.12x 1.14x 1.16x 1.16x 1.15x 1.02x 1.02x 1.08x 1.08x 64B 1.61x 1.60x 1.17x 1.68x 1.67x 1.66x 1.43x 1.42x 1.44x 1.42x 256B 1.65x 1.73x 1.17x 1.77x 1.81x 1.80x 1.54x 1.53x 1.58x 1.54x 1024B 1.76x 1.74x 1.18x 1.80x 1.85x 1.85x 1.60x 1.59x 1.65x 1.60x 8192B 1.77x 1.75x 1.19x 1.81x 1.85x 1.86x 1.63x 1.61x 1.66x 1.62x 256bit key: (lrw:384bit) (xts:512bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 1.10x 1.07x 1.13x 1.16x 1.11x 1.16x 1.03x 1.02x 1.08x 1.07x 64B 1.61x 1.62x 1.15x 1.66x 1.63x 1.68x 1.47x 1.46x 1.47x 1.44x 256B 1.71x 1.70x 1.16x 1.75x 1.69x 1.79x 1.58x 1.57x 1.59x 1.55x 1024B 1.78x 1.72x 1.17x 1.75x 1.80x 1.80x 1.63x 1.62x 1.65x 1.62x 8192B 1.76x 1.73x 1.17x 1.78x 1.80x 1.81x 1.64x 1.62x 1.68x 1.64x camellia-asm vs aes-asm (8kB block): 128bit 256bit ecb-enc 1.17x 1.21x ecb-dec 1.17x 1.20x cbc-enc 0.80x 0.82x cbc-dec 1.22x 1.24x ctr-enc 1.25x 1.26x ctr-dec 1.25x 1.26x lrw-enc 1.14x 1.18x lrw-dec 1.13x 1.17x xts-enc 1.14x 1.18x xts-dec 1.14x 1.17x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-14crypto: camellia - rename camellia.c to camellia_generic.cJussi Kivilinna
2012-03-14crypto: camellia - fix checkpatch warningsJussi Kivilinna
Fix checkpatch warnings before renaming file. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-14crypto: camellia - rename camellia module to camellia_genericJussi Kivilinna
Rename camellia module to camellia_generic to allow optimized assembler implementations to autoload with module-alias. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-14crypto: tcrypt - add more camellia testsJussi Kivilinna
Add tests for CTR, LRW and XTS modes. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-14crypto: testmgr - add more camellia test vectorsJussi Kivilinna
New ECB, CBC, CTR, LRW and XTS test vectors for camellia. Larger ECB/CBC test vectors needed for parallel 2-way camellia implementation. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-14crypto: camellia - simplify key setup and CAMELLIA_ROUNDSM macroJussi Kivilinna
camellia_setup_tail() applies 'inverse of the last half of P-function' to subkeys, which is unneeded if keys are applied directly to yl/yr in CAMELLIA_ROUNDSM. Patch speeds up key setup and should speed up CAMELLIA_ROUNDSM as applying key to yl/yr early has less register dependencies. Quick tcrypt camellia results: x86_64, AMD Phenom II, ~5% faster x86_64, Intel Core 2, ~0.5% faster i386, Intel Atom N270, ~1% faster Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-02-26netlink: add netlink_dump_control structure for netlink_dump_start()Pablo Neira Ayuso
Davem considers that the argument list of this interface is getting out of control. This patch tries to address this issue following his proposal: struct netlink_dump_control c = { .dump = dump, .done = done, ... }; netlink_dump_start(..., &c); Suggested by David S. Miller. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: sha512 - use standard ror64()
2012-02-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Herbert Xu
Merge crypto tree as it has cherry-picked the ror64 patch from cryptodev.
2012-02-16crypto: sha512 - use standard ror64()Alexey Dobriyan
Use standard ror64() instead of hand-written. There is no standard ror64, so create it. The difference is shift value being "unsigned int" instead of uint64_t (for which there is no reason). gcc starts to emit native ROR instructions which it doesn't do for some reason currently. This should make the code faster. Patch survives in-tree crypto test and ping flood with hmac(sha512) on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-02-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
This updates the sha512 fix so that it doesn't cause excessive stack usage on i386. This is done by reverting to the original code, and avoiding the W duplication by moving its initialisation into the loop. As the underlying code is in fact the one that we have used for years, I'm pushing this now instead of postponing to the next cycle. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: sha512 - Avoid stack bloat on i386 crypto: sha512 - Use binary and instead of modulus
2012-02-05crypto: In crypto_add_alg(), 'exact' wants to be initialized to 0Jesper Juhl
We declare 'exact' without initializing it and then do: [...] if (strlen(p->cru_driver_name)) exact = 1; if (priority && !exact) return -EINVAL; [...] If the first 'if' is not true, then the second will test an uninitialized 'exact'. As far as I can tell, what we want is for 'exact' to be initialized to 0 (zero/false). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-02-05crypto: sha512 - Avoid stack bloat on i386Herbert Xu
Unfortunately in reducing W from 80 to 16 we ended up unrolling the loop twice. As gcc has issues dealing with 64-bit ops on i386 this means that we end up using even more stack space (>1K). This patch solves the W reduction by moving LOAD_OP/BLEND_OP into the loop itself, thus avoiding the need to duplicate it. While the stack space still isn't great (>0.5K) it is at least in the same ball park as the amount of stack used for our C sha1 implementation. Note that this patch basically reverts to the original code so the diff looks bigger than it really is. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-26crypto: sha512 - Use binary and instead of modulusHerbert Xu
The previous patch used the modulus operator over a power of 2 unnecessarily which may produce suboptimal binary code. This patch changes changes them to binary ands instead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: sha512 - reduce stack usage to safe number crypto: sha512 - make it work, undo percpu message schedule
2012-01-26crypto: Add bulk algorithm registration interfaceMark Brown
Hardware crypto engines frequently need to register a selection of different algorithms with the core. Simplify their code slightly, especially the error handling, by providing functions to register a number of algorithms in a single call. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-14Merge branch 'for-linus' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security: capabilities: remove __cap_full_set definition security: remove the security_netlink_recv hook as it is equivalent to capable() ptrace: do not audit capability check when outputing /proc/pid/stat capabilities: remove task_ns_* functions capabitlies: ns_capable can use the cap helpers rather than lsm call capabilities: style only - move capable below ns_capable capabilites: introduce new has_ns_capabilities_noaudit capabilities: call has_ns_capability from has_capability capabilities: remove all _real_ interfaces capabilities: introduce security_capable_noaudit capabilities: reverse arguments to security_capable capabilities: remove the task from capable LSM hook entirely selinux: sparse fix: fix several warnings in the security server cod selinux: sparse fix: fix warnings in netlink code selinux: sparse fix: eliminate warnings for selinuxfs selinux: sparse fix: declare selinux_disable() in security.h selinux: sparse fix: move selinux_complete_init selinux: sparse fix: make selinux_secmark_refcount static SELinux: Fix RCU deref check warning in sel_netport_insert() Manually fix up a semantic mis-merge wrt security_netlink_recv(): - the interface was removed in commit fd7784615248 ("security: remove the security_netlink_recv hook as it is equivalent to capable()") - a new user of it appeared in commit a38f7907b926 ("crypto: Add userspace configuration API") causing no automatic merge conflict, but Eric Paris pointed out the issue.
2012-01-15crypto: sha512 - use standard ror64()Alexey Dobriyan
2012-01-15crypto: sha512 - reduce stack usage to safe numberAlexey Dobriyan
For rounds 16--79, W[i] only depends on W[i - 2], W[i - 7], W[i - 15] and W[i - 16]. Consequently, keeping all W[80] array on stack is unnecessary, only 16 values are really needed. Using W[16] instead of W[80] greatly reduces stack usage (~750 bytes to ~340 bytes on x86_64). Line by line explanation: * BLEND_OP array is "circular" now, all indexes have to be modulo 16. Round number is positive, so remainder operation should be without surprises. * initial full message scheduling is trimmed to first 16 values which come from data block, the rest is calculated before it's needed. * original loop body is unrolled version of new SHA512_0_15 and SHA512_16_79 macros, unrolling was done to not do explicit variable renaming. Otherwise it's the very same code after preprocessing. See sha1_transform() code which does the same trick. Patch survives in-tree crypto test and original bugreport test (ping flood with hmac(sha512). See FIPS 180-2 for SHA-512 definition http://csrc.nist.gov/publications/fips/fips180-2/fips180-2withchangenotice.pdf Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-15crypto: sha512 - make it work, undo percpu message scheduleAlexey Dobriyan
commit f9e2bca6c22d75a289a349f869701214d63b5060 aka "crypto: sha512 - Move message schedule W[80] to static percpu area" created global message schedule area. If sha512_update will ever be entered twice, hash will be silently calculated incorrectly. Probably the easiest way to notice incorrect hashes being calculated is to run 2 ping floods over AH with hmac(sha512): #!/usr/sbin/setkey -f flush; spdflush; add IP1 IP2 ah 25 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000025; add IP2 IP1 ah 52 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000052; spdadd IP1 IP2 any -P out ipsec ah/transport//require; spdadd IP2 IP1 any -P in ipsec ah/transport//require; XfrmInStateProtoError will start ticking with -EBADMSG being returned from ah_input(). This never happens with, say, hmac(sha1). With patch applied (on BOTH sides), XfrmInStateProtoError does not tick with multiple bidirectional ping flood streams like it doesn't tick with SHA-1. After this patch sha512_transform() will start using ~750 bytes of stack on x86_64. This is OK for simple loads, for something more heavy, stack reduction will be done separatedly. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (54 commits) crypto: gf128mul - remove leftover "(EXPERIMENTAL)" in Kconfig crypto: serpent-sse2 - remove unneeded LRW/XTS #ifdefs crypto: serpent-sse2 - select LRW and XTS crypto: twofish-x86_64-3way - remove unneeded LRW/XTS #ifdefs crypto: twofish-x86_64-3way - select LRW and XTS crypto: xts - remove dependency on EXPERIMENTAL crypto: lrw - remove dependency on EXPERIMENTAL crypto: picoxcell - fix boolean and / or confusion crypto: caam - remove DECO access initialization code crypto: caam - fix polarity of "propagate error" logic crypto: caam - more desc.h cleanups crypto: caam - desc.h - convert spaces to tabs crypto: talitos - convert talitos_error to struct device crypto: talitos - remove NO_IRQ references crypto: talitos - fix bad kfree crypto: convert drivers/crypto/* to use module_platform_driver() char: hw_random: convert drivers/char/hw_random/* to use module_platform_driver() crypto: serpent-sse2 - should select CRYPTO_CRYPTD crypto: serpent - rename serpent.c to serpent_generic.c crypto: serpent - cleanup checkpatch errors and warnings ...
2011-12-20crypto: gf128mul - remove leftover "(EXPERIMENTAL)" in KconfigJussi Kivilinna
CRYPTO_GF128MUL does not select EXPERIMENTAL anymore so remove the "(EXPERIMENTAL)" from its name. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-12-20crypto: serpent-sse2 - select LRW and XTSJussi Kivilinna
serpent-sse2 uses functions from LRW and XTS modules, so selecting would appear to be better option than using #ifdefs in serpent_sse2_glue.c to enable/disable LRW and XTS features. This also fixes build problem when serpent-sse2 would be build into kernel but XTS/LRW are build as modules. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-12-20crypto: twofish-x86_64-3way - select LRW and XTSJussi Kivilinna
twofish-x86_64-3way uses functions from LRW and XTS modules, so selecting would appear to be better option than using #ifdefs in twofish_glue_3way.c to enable/disable LRW and XTS features. This also fixes build problem when twofish-x86_64-3way would be build into kernel but XTS/LRW are build as modules. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-12-20crypto: xts - remove dependency on EXPERIMENTALJussi Kivilinna
XTS has been EXPERIMENTAL since it was introduced in 2007. I'd say by now it has seen enough testing to justify removal of EXPERIMENTAL tag. CC: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-12-20crypto: lrw - remove dependency on EXPERIMENTALJussi Kivilinna
LRW has been EXPERIMENTAL since it was introduced in 2006. I'd say by now it has seen enough testing to justify removal of EXPERIMENTAL tag. CC: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-30crypto: serpent-sse2 - should select CRYPTO_CRYPTDJussi Kivilinna
Since serpent_sse2_glue.c uses cryptd, CRYPTO_SERPENT_SSE2_X86_64 and CRYPTO_SERPENT_SSE2_586 should be selecting CRYPTO_CRYPTD. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-30crypto: serpent - rename serpent.c to serpent_generic.cJussi Kivilinna
Now that serpent.c has been cleaned from checkpatch warnings, we can do clean rename. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-30crypto: serpent - cleanup checkpatch errors and warningsJussi Kivilinna
Do checkpatch fixes before rename to keep rename patch simple and clean. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-21crypto: serpent-sse2 - add lrw supportJussi Kivilinna
Patch adds LRW support for serpent-sse2 by using lrw_crypt(). Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmarks results (serpent-sse2/serpent_generic speed ratios): Benchmark results with tcrypt: Intel Celeron T1600 (x86_64) (fam:6, model:15, step:13): size lrw-enc lrw-dec 16B 1.00x 0.96x 64B 1.01x 1.01x 256B 3.01x 2.97x 1024B 3.39x 3.33x 8192B 3.35x 3.33x AMD Phenom II 1055T (x86_64) (fam:16, model:10): size lrw-enc lrw-dec 16B 0.98x 1.03x 64B 1.01x 1.04x 256B 2.10x 2.14x 1024B 2.28x 2.33x 8192B 2.30x 2.33x Intel Atom N270 (i586): size lrw-enc lrw-dec 16B 0.97x 0.97x 64B 1.47x 1.50x 256B 1.72x 1.69x 1024B 1.88x 1.81x 8192B 1.84x 1.79x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-21crypto: serpent - add 4-way parallel i586/SSE2 assembler implementationJussi Kivilinna
Patch adds i586/SSE2 assembler implementation of serpent cipher. Assembler functions crypt data in four block chunks. Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmarks results (serpent-sse2/serpent_generic speed ratios): Intel Atom N270: size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec 16 0.95x 1.12x 1.02x 1.07x 0.97x 0.98x 64 1.73x 1.82x 1.08x 1.82x 1.72x 1.73x 256 2.08x 2.00x 1.04x 2.07x 1.99x 2.01x 1024 2.28x 2.18x 1.05x 2.23x 2.17x 2.20x 8192 2.28x 2.13x 1.05x 2.23x 2.18x 2.20x Full output: http://koti.mbnet.fi/axh/kernel/crypto/atom-n270/serpent-generic.txt http://koti.mbnet.fi/axh/kernel/crypto/atom-n270/serpent-sse2.txt Userspace test results: Encryption/decryption of sse2-i586 vs generic on Intel Atom N270: encrypt: 2.35x decrypt: 2.54x Encryption/decryption of sse2-i586 vs generic on AMD Phenom II: encrypt: 1.82x decrypt: 2.51x Encryption/decryption of sse2-i586 vs generic on Intel Xeon E7330: encrypt: 2.99x decrypt: 3.48x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-21crypto: serpent - add 8-way parallel x86_64/SSE2 assembler implementationJussi Kivilinna
Patch adds x86_64/SSE2 assembler implementation of serpent cipher. Assembler functions crypt data in eigth block chunks (two 4 block chunk SSE2 operations in parallel to improve performance on out-of-order CPUs). Glue code is based on one from AES-NI implementation, so requests from irq context are redirected to cryptd. v2: - add missing include of linux/module.h (appearently crypto.h used to include module.h, which changed for 3.2 by commit 7c926402a7e8c9b279968fd94efec8700ba3859e) Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmarks results (serpent-sse2/serpent_generic speed ratios): AMD Phenom II 1055T (fam:16, model:10): size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec 16B 1.03x 1.01x 1.03x 1.05x 1.00x 0.99x 64B 1.00x 1.01x 1.02x 1.04x 1.02x 1.01x 256B 2.34x 2.41x 0.99x 2.43x 2.39x 2.40x 1024B 2.51x 2.57x 1.00x 2.59x 2.56x 2.56x 8192B 2.50x 2.54x 1.00x 2.55x 2.57x 2.57x Intel Celeron T1600 (fam:6, model:15, step:13): size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec 16B 0.97x 0.97x 1.01x 1.01x 1.01x 1.02x 64B 1.00x 1.00x 1.00x 1.02x 1.01x 1.01x 256B 3.41x 3.35x 1.00x 3.39x 3.42x 3.44x 1024B 3.75x 3.72x 0.99x 3.74x 3.75x 3.75x 8192B 3.70x 3.68x 0.99x 3.68x 3.69x 3.69x Full output: http://koti.mbnet.fi/axh/kernel/crypto/phenom-ii-1055t/serpent-generic.txt http://koti.mbnet.fi/axh/kernel/crypto/phenom-ii-1055t/serpent-sse2.txt http://koti.mbnet.fi/axh/kernel/crypto/celeron-t1600/serpent-generic.txt http://koti.mbnet.fi/axh/kernel/crypto/celeron-t1600/serpent-sse2.txt Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-13Merge branch 'master' into for-nextJiri Kosina
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver in the config and Makefile") as I have patch depending on that one.
2011-11-13crypto: drop selects of bogus Kconfig symbolPaul Bolle
Commits 2cdc6899a8 ("crypto: ghash - Add GHASH digest algorithm for GCM") and 0e1227d356 ("crypto: ghash - Add PCLMULQDQ accelerated implementation") added "select CRYPTO_SHASH" to two entries. That Kconfig symbol doesn't exist. These two selects are nops. Drop them. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-11Merge git://github.com/herbertx/cryptoLinus Torvalds
* git://github.com/herbertx/crypto: crypto: algapi - Fix build problem with NET disabled crypto: user - Fix rwsem leak in crypto_user
2011-11-11crypto: algapi - Fix build problem with NET disabledHerbert Xu
The report functions use NLA_PUT so we need to ensure that NET is enabled. Reported-by: Luis Henriques <henrix@camandro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: fix typo in crypto/KconfigValdis.Kletnieks@vt.edu
Fix a typo in the Kconfig file help text. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
