path: root/crypto
2018-04-08crypto: ahash - Fix early termination in hash walkHerbert Xu
commit 900a081f6912a8985dc15380ec912752cb66025a upstream. When we have an unaligned SG list entry where there is no leftover aligned data, the hash walk code will incorrectly return zero as if the entire SG list has been processed. This patch fixes it by moving onto the next page instead. Reported-by: Eli Cooper <elicooper@gmx.com> Cc: <stable@vger.kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28X.509: fix NULL dereference when restricting key with unsupported_sigEric Biggers
commit 4b34968e77ad09628cfb3c4a7daf2adc2cefc6e8 upstream. The asymmetric key type allows an X.509 certificate to be added even if its signature's hash algorithm is not available in the crypto API. In that case 'payload.data[asym_auth]' will be NULL. But the key restriction code failed to check for this case before trying to use the signature, resulting in a NULL pointer dereference in key_or_keyring_common() or in restrict_link_by_signature(). Fix this by returning -ENOPKG when the signature is unsupported. Reproducer when all the CONFIG_CRYPTO_SHA512* options are disabled and keyctl has support for the 'restrict_keyring' command: keyctl new_session keyctl restrict_keyring @s asymmetric builtin_trusted openssl req -new -sha512 -x509 -batch -nodes -outform der \ | keyctl padd asymmetric desc @s Fixes: a511e1af8b12 ("KEYS: Move the point of trust determination to __key_link()") Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28PKCS#7: fix certificate chain verificationEric Biggers
commit 971b42c038dc83e3327872d294fe7131bab152fc upstream. When pkcs7_verify_sig_chain() is building the certificate chain for a SignerInfo using the certificates in the PKCS#7 message, it is passing the wrong arguments to public_key_verify_signature(). Consequently, when the next certificate is supposed to be used to verify the previous certificate, the next certificate is actually used to verify itself. An attacker can use this bug to create a bogus certificate chain that has no cryptographic relationship between the beginning and end. Fortunately I couldn't quite find a way to use this to bypass the overall signature verification, though it comes very close. Here's the reasoning: due to the bug, every certificate in the chain beyond the first actually has to be self-signed (where "self-signed" here refers to the actual key and signature; an attacker might still manipulate the certificate fields such that the self_signed flag doesn't actually get set, and thus the chain doesn't end immediately). But to pass trust validation (pkcs7_validate_trust()), either the SignerInfo or one of the certificates has to actually be signed by a trusted key. Since only self-signed certificates can be added to the chain, the only way for an attacker to introduce a trusted signature is to include a self-signed trusted certificate. But, when pkcs7_validate_trust_one() reaches that certificate, instead of trying to verify the signature on that certificate, it will actually look up the corresponding trusted key, which will succeed, and then try to verify the *previous* certificate, which will fail. Thus, disaster is narrowly averted (as far as I could tell). Fixes: 6c2dc5ae4ab7 ("X.509: Extract signature digest and make self-signed cert checks earlier") Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28X.509: fix BUG_ON() when hash algorithm is unsupportedEric Biggers
commit 437499eea4291ae9621e8763a41df027c110a1ef upstream. The X.509 parser mishandles the case where the certificate's signature's hash algorithm is not available in the crypto API. In this case, x509_get_sig_params() doesn't allocate the cert->sig->digest buffer; this part seems to be intentional. However, public_key_verify_signature() is still called via x509_check_for_self_signed(), which triggers the 'BUG_ON(!sig->digest)'. Fix this by making public_key_verify_signature() return -ENOPKG if the hash buffer has not been allocated. Reproducer when all the CONFIG_CRYPTO_SHA512* options are disabled: openssl req -new -sha512 -x509 -batch -nodes -outform der \ | keyctl padd asymmetric desc @s Fixes: 6c2dc5ae4ab7 ("X.509: Extract signature digest and make self-signed cert checks earlier") Reported-by: Paolo Valente <paolo.valente@linaro.org> Cc: Paolo Valente <paolo.valente@linaro.org> Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25crypto: hash - prevent using keyed hashes without setting keyEric Biggers
commit 9fa68f620041be04720d0cbfb1bd3ddfc6310b24 upstream. Currently, almost none of the keyed hash algorithms check whether a key has been set before proceeding. Some algorithms are okay with this and will effectively just use a key of all 0's or some other bogus default. However, others will severely break, as demonstrated using "hmac(sha3-512-generic)", the unkeyed use of which causes a kernel crash via a (potentially exploitable) stack buffer overflow. A while ago, this problem was solved for AF_ALG by pairing each hash transform with a 'has_key' bool. However, there are still other places in the kernel where userspace can specify an arbitrary hash algorithm by name, and the kernel uses it as unkeyed hash without checking whether it is really unkeyed. Examples of this include: - KEYCTL_DH_COMPUTE, via the KDF extension - dm-verity - dm-crypt, via the ESSIV support - dm-integrity, via the "internal hash" mode with no key given - drbd (Distributed Replicated Block Device) This bug is especially bad for KEYCTL_DH_COMPUTE as that requires no privileges to call. Fix the bug for all users by adding a flag CRYPTO_TFM_NEED_KEY to the ->crt_flags of each hash transform that indicates whether the transform still needs to be keyed or not. Then, make the hash init, import, and digest functions return -ENOKEY if the key is still needed. The new flag also replaces the 'has_key' bool which algif_hash was previously using, thereby simplifying the algif_hash implementation. Reported-by: syzbot <syzkaller@googlegroups.com> Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25crypto: hash - annotate algorithms taking optional keyEric Biggers
commit a208fa8f33031b9e0aba44c7d1b7e68eb0cbd29e upstream. We need to consistently enforce that keyed hashes cannot be used without setting the key. To do this we need a reliable way to determine whether a given hash algorithm is keyed or not. AF_ALG currently does this by checking for the presence of a ->setkey() method. However, this is actually slightly broken because the CRC-32 algorithms implement ->setkey() but can also be used without a key. (The CRC-32 "key" is not actually a cryptographic key but rather represents the initial state. If not overridden, then a default initial state is used.) Prepare to fix this by introducing a flag CRYPTO_ALG_OPTIONAL_KEY which indicates that the algorithm has a ->setkey() method, but it is not required to be called. Then set it on all the CRC-32 algorithms. The same also applies to the Adler-32 implementation in Lustre. Also, the cryptd and mcryptd templates have to pass through the flag from their underlying algorithm. Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17crypto: poly1305 - remove ->setkey() methodEric Biggers
commit a16e772e664b9a261424107784804cffc8894977 upstream. Since Poly1305 requires a nonce per invocation, the Linux kernel implementations of Poly1305 don't use the crypto API's keying mechanism and instead expect the key and nonce as the first 32 bytes of the data. But ->setkey() is still defined as a stub returning an error code. This prevents Poly1305 from being used through AF_ALG and will also break it completely once we start enforcing that all crypto API users (not just AF_ALG) call ->setkey() if present. Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17crypto: mcryptd - pass through absence of ->setkey()Eric Biggers
commit fa59b92d299f2787e6bae1ff078ee0982e80211f upstream. When the mcryptd template is used to wrap an unkeyed hash algorithm, don't install a ->setkey() method to the mcryptd instance. This change is necessary for mcryptd to keep working with unkeyed hash algorithms once we start enforcing that ->setkey() is called when present. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17crypto: cryptd - pass through absence of ->setkey()Eric Biggers
commit 841a3ff329713f796a63356fef6e2f72e4a3f6a3 upstream. When the cryptd template is used to wrap an unkeyed hash algorithm, don't install a ->setkey() method to the cryptd instance. This change is necessary for cryptd to keep working with unkeyed hash algorithms once we start enforcing that ->setkey() is called when present. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17crypto: hash - introduce crypto_hash_alg_has_setkey()Eric Biggers
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream. Templates that use an shash spawn can use crypto_shash_alg_has_setkey() to determine whether the underlying algorithm requires a key or not. But there was no corresponding function for ahash spawns. Add it. Note that the new function actually has to support both shash and ahash algorithms, since the ahash API can be used with either. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13crypto: tcrypt - fix S/G table for test_aead_speed()Robert Baronescu
commit 5c6ac1d4f8fbdbed65dbeb8cf149d736409d16a1 upstream. In case buffer length is a multiple of PAGE_SIZE, the S/G table is incorrectly generated. Fix this by handling buflen = k * PAGE_SIZE separately. Signed-off-by: Robert Baronescu <robert.baronescu@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03crypto: af_alg - whitelist mask and typeStephan Mueller
commit bb30b8848c85e18ca7e371d0a869e94b3e383bdf upstream. The user space interface allows specifying the type and mask field used to allocate the cipher. Only a subset of the possible flags are intended for user space. Therefore, white-list the allowed flags. In case the user space caller uses at least one non-allowed flag, EINVAL is returned. Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03crypto: sha3-generic - fixes for alignment and big endian operationArd Biesheuvel
commit c013cee99d5a18aec8c71fee8f5f41369cd12595 upstream. Ensure that the input is byte swabbed before injecting it into the SHA3 transform. Use the get_unaligned() accessor for this so that we don't perform unaligned access inadvertently on architectures that do not support that. Fixes: 53964b9ee63b7075 ("crypto: sha3 - Add SHA-3 hash algorithm") Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03crypto: ecdh - fix typo in KPP dependency of CRYPTO_ECDHHauke Mehrtens
commit b5b9007730ce1d90deaf25d7f678511550744bdc upstream. This fixes a typo in the CRYPTO_KPP dependency of CRYPTO_ECDH. Fixes: 3c4b23901a0c ("crypto: ecdh - Add ECDH software support") Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17crypto: algapi - fix NULL dereference in crypto_remove_spawns()Eric Biggers
commit 9a00674213a3f00394f4e3221b88f2d21fc05789 upstream. syzkaller triggered a NULL pointer dereference in crypto_remove_spawns() via a program that repeatedly and concurrently requests AEADs "authenc(cmac(des3_ede-asm),pcbc-aes-aesni)" and hashes "cmac(des3_ede)" through AF_ALG, where the hashes are requested as "untested" (CRYPTO_ALG_TESTED is set in ->salg_mask but clear in ->salg_feat; this causes the template to be instantiated for every request). Although AF_ALG users really shouldn't be able to request an "untested" algorithm, the NULL pointer dereference is actually caused by a longstanding race condition where crypto_remove_spawns() can encounter an instance which has had spawn(s) "grabbed" but hasn't yet been registered, resulting in ->cra_users still being NULL. We probably should properly initialize ->cra_users earlier, but that would require updating many templates individually. For now just fix the bug in a simple way that can easily be backported: make crypto_remove_spawns() treat a NULL ->cra_users list as empty. Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10crypto: pcrypt - fix freeing pcrypt instancesEric Biggers
commit d76c68109f37cb85b243a1cf0f40313afd2bae68 upstream. pcrypt is using the old way of freeing instances, where the ->free() method specified in the 'struct crypto_template' is passed a pointer to the 'struct crypto_instance'. But the crypto_instance is being kfree()'d directly, which is incorrect because the memory was actually allocated as an aead_instance, which contains the crypto_instance at a nonzero offset. Thus, the wrong pointer was being kfree()'d. Fix it by switching to the new way to free aead_instance's where the ->free() method is specified in the aead_instance itself. Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: 0496f56065e0 ("crypto: pcrypt - Add support for new AEAD interface") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10crypto: chacha20poly1305 - validate the digest sizeEric Biggers
commit e57121d08c38dabec15cf3e1e2ad46721af30cae upstream. If the rfc7539 template was instantiated with a hash algorithm with digest size larger than 16 bytes (POLY1305_DIGEST_SIZE), then the digest overran the 'tag' buffer in 'struct chachapoly_req_ctx', corrupting the subsequent memory, including 'cryptlen'. This caused a crash during crypto_skcipher_decrypt(). Fix it by, when instantiating the template, requiring that the underlying hash algorithm has the digest size expected for Poly1305. Reproducer: #include <linux/if_alg.h> #include <sys/socket.h> #include <unistd.h> int main() { int algfd, reqfd; struct sockaddr_alg addr = { .salg_type = "aead", .salg_name = "rfc7539(chacha20,sha256)", }; unsigned char buf[32] = { 0 }; algfd = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(algfd, (void *)&addr, sizeof(addr)); setsockopt(algfd, SOL_ALG, ALG_SET_KEY, buf, sizeof(buf)); reqfd = accept(algfd, 0, 0); write(reqfd, buf, 16); read(reqfd, buf, 16); } Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: 71ebc4d1b27d ("crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29crypto: mcryptd - protect the per-CPU queue with a lockSebastian Andrzej Siewior
commit 9abffc6f2efe46c3564c04312e52e07622d40e51 upstream. mcryptd_enqueue_request() grabs the per-CPU queue struct and protects access to it with disabled preemption. Then it schedules a worker on the same CPU. The worker in mcryptd_queue_worker() guards access to the same per-CPU variable with disabled preemption. If we take CPU-hotplug into account then it is possible that between queue_work_on() and the actual invocation of the worker the CPU goes down and the worker will be scheduled on _another_ CPU. And here the preempt_disable() protection does not work anymore. The easiest thing is to add a spin_lock() to guard access to the list. Another detail: mcryptd_queue_worker() is not processing more than MCRYPTD_BATCH invocation in a row. If there are still items left, then it will invoke queue_work() to proceed with more later. *I* would suggest to simply drop that check because it does not use a system workqueue and the workqueue is already marked as "CPU_INTENSIVE". And if preemption is required then the scheduler should do it. However if queue_work() is used then the work item is marked as CPU unbound. That means it will try to run on the local CPU but it may run on another CPU as well. Especially with CONFIG_DEBUG_WQ_FORCE_RR_CPU=y. Again, the preempt_disable() won't work here but lock which was introduced will help. In order to keep work-item on the local CPU (and avoid RR) I changed it to queue_work_on(). Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20crypto: tcrypt - fix buffer lengths in test_aead_speed()Robert Baronescu
[ Upstream commit 7aacbfcb331ceff3ac43096d563a1f93ed46e35e ] Fix the way the length of the buffers used for encryption / decryption are computed. For e.g. in case of encryption, input buffer does not contain an authentication tag. Signed-off-by: Robert Baronescu <robert.baronescu@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20crypto: salsa20 - fix blkcipher_walk API usageEric Biggers
commit ecaaab5649781c5a0effdaf298a925063020500e upstream. When asked to encrypt or decrypt 0 bytes, both the generic and x86 implementations of Salsa20 crash in blkcipher_walk_done(), either when doing 'kfree(walk->buffer)' or 'free_page((unsigned long)walk->page)', because walk->buffer and walk->page have not been initialized. The bug is that Salsa20 is calling blkcipher_walk_done() even when nothing is in 'walk.nbytes'. But blkcipher_walk_done() is only meant to be called when a nonzero number of bytes have been provided. The broken code is part of an optimization that tries to make only one call to salsa20_encrypt_bytes() to process inputs that are not evenly divisible by 64 bytes. To fix the bug, just remove this "optimization" and use the blkcipher_walk API the same way all the other users do. Reproducer: #include <linux/if_alg.h> #include <sys/socket.h> #include <unistd.h> int main() { int algfd, reqfd; struct sockaddr_alg addr = { .salg_type = "skcipher", .salg_name = "salsa20", }; char key[16] = { 0 }; algfd = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(algfd, (void *)&addr, sizeof(addr)); reqfd = accept(algfd, 0, 0); setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key)); read(reqfd, key, sizeof(key)); } Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: eb6f13eb9f81 ("[CRYPTO] salsa20_generic: Fix multi-page processing") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20crypto: hmac - require that the underlying hash algorithm is unkeyedEric Biggers
commit af3ff8045bbf3e32f1a448542e73abb4c8ceb6f1 upstream. Because the HMAC template didn't check that its underlying hash algorithm is unkeyed, trying to use "hmac(hmac(sha3-512-generic))" through AF_ALG or through KEYCTL_DH_COMPUTE resulted in the inner HMAC being used without having been keyed, resulting in sha3_update() being called without sha3_init(), causing a stack buffer overflow. This is a very old bug, but it seems to have only started causing real problems when SHA-3 support was added (requires CONFIG_CRYPTO_SHA3) because the innermost hash's state is ->import()ed from a zeroed buffer, and it just so happens that other hash algorithms are fine with that, but SHA-3 is not. However, there could be arch or hardware-dependent hash algorithms also affected; I couldn't test everything. Fix the bug by introducing a function crypto_shash_alg_has_setkey() which tests whether a shash algorithm is keyed. Then update the HMAC template to require that its underlying hash algorithm is unkeyed. Here is a reproducer: #include <linux/if_alg.h> #include <sys/socket.h> int main() { int algfd; struct sockaddr_alg addr = { .salg_type = "hash", .salg_name = "hmac(hmac(sha3-512-generic))", }; char key[4096] = { 0 }; algfd = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(algfd, (const struct sockaddr *)&addr, sizeof(addr)); setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key)); } Here was the KASAN report from syzbot: BUG: KASAN: stack-out-of-bounds in memcpy include/linux/string.h:341 [inline] BUG: KASAN: stack-out-of-bounds in sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161 Write of size 4096 at addr ffff8801cca07c40 by task syzkaller076574/3044 CPU: 1 PID: 3044 Comm: syzkaller076574 Not tainted 4.14.0-mm1+ #25 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:53 print_address_description+0x73/0x250 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x25b/0x340 mm/kasan/report.c:409 check_memory_region_inline mm/kasan/kasan.c:260 [inline] check_memory_region+0x137/0x190 mm/kasan/kasan.c:267 memcpy+0x37/0x50 mm/kasan/kasan.c:303 memcpy include/linux/string.h:341 [inline] sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161 crypto_shash_update+0xcb/0x220 crypto/shash.c:109 shash_finup_unaligned+0x2a/0x60 crypto/shash.c:151 crypto_shash_finup+0xc4/0x120 crypto/shash.c:165 hmac_finup+0x182/0x330 crypto/hmac.c:152 crypto_shash_finup+0xc4/0x120 crypto/shash.c:165 shash_digest_unaligned+0x9e/0xd0 crypto/shash.c:172 crypto_shash_digest+0xc4/0x120 crypto/shash.c:186 hmac_setkey+0x36a/0x690 crypto/hmac.c:66 crypto_shash_setkey+0xad/0x190 crypto/shash.c:64 shash_async_setkey+0x47/0x60 crypto/shash.c:207 crypto_ahash_setkey+0xaf/0x180 crypto/ahash.c:200 hash_setkey+0x40/0x90 crypto/algif_hash.c:446 alg_setkey crypto/af_alg.c:221 [inline] alg_setsockopt+0x2a1/0x350 crypto/af_alg.c:254 SYSC_setsockopt net/socket.c:1851 [inline] SyS_setsockopt+0x189/0x360 net/socket.c:1830 entry_SYSCALL_64_fastpath+0x1f/0x96 Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20crypto: rsa - fix buffer overread when stripping leading zeroesEric Biggers
commit d2890c3778b164fde587bc16583f3a1c87233ec5 upstream. In rsa_get_n(), if the buffer contained all 0's and "FIPS mode" is enabled, we would read one byte past the end of the buffer while scanning the leading zeroes. Fix it by checking 'n_sz' before '!*ptr'. This bug was reachable by adding a specially crafted key of type "asymmetric" (requires CONFIG_RSA and CONFIG_X509_CERTIFICATE_PARSER). KASAN report: BUG: KASAN: slab-out-of-bounds in rsa_get_n+0x19e/0x1d0 crypto/rsa_helper.c:33 Read of size 1 at addr ffff88003501a708 by task keyctl/196 CPU: 1 PID: 196 Comm: keyctl Not tainted 4.14.0-09238-g1d3b78bbc6e9 #26 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014 Call Trace: rsa_get_n+0x19e/0x1d0 crypto/rsa_helper.c:33 asn1_ber_decoder+0x82a/0x1fd0 lib/asn1_decoder.c:328 rsa_set_pub_key+0xd3/0x320 crypto/rsa.c:278 crypto_akcipher_set_pub_key ./include/crypto/akcipher.h:364 [inline] pkcs1pad_set_pub_key+0xae/0x200 crypto/rsa-pkcs1pad.c:117 crypto_akcipher_set_pub_key ./include/crypto/akcipher.h:364 [inline] public_key_verify_signature+0x270/0x9d0 crypto/asymmetric_keys/public_key.c:106 x509_check_for_self_signed+0x2ea/0x480 crypto/asymmetric_keys/x509_public_key.c:141 x509_cert_parse+0x46a/0x620 crypto/asymmetric_keys/x509_cert_parser.c:129 x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174 asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388 key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0x96 Allocated by task 196: __do_kmalloc mm/slab.c:3711 [inline] __kmalloc_track_caller+0x118/0x2e0 mm/slab.c:3726 kmemdup+0x17/0x40 mm/util.c:118 kmemdup ./include/linux/string.h:414 [inline] x509_cert_parse+0x2cb/0x620 crypto/asymmetric_keys/x509_cert_parser.c:106 x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174 asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388 key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0x96 Fixes: 5a7de97309f5 ("crypto: rsa - return raw integers for the ASN.1 parser") Cc: Tudor Ambarus <tudor-dan.ambarus@nxp.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Reviewed-by: David Howells <dhowells@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14X.509: fix comparisons of ->pkey_algoEric Biggers
commit 54c1fb39fe0495f846539ab765925b008f86801c upstream. ->pkey_algo used to be an enum, but was changed to a string by commit 4e8ae72a75aa ("X.509: Make algo identifiers text instead of enum"). But two comparisons were not updated. Fix them to use strcmp(). This bug broke signature verification in certain configurations, depending on whether the string constants were deduplicated or not. Fixes: 4e8ae72a75aa ("X.509: Make algo identifiers text instead of enum") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14X.509: reject invalid BIT STRING for subjectPublicKeyEric Biggers
commit 0f30cbea005bd3077bd98cd29277d7fc2699c1da upstream. Adding a specially crafted X.509 certificate whose subjectPublicKey ASN.1 value is zero-length caused x509_extract_key_data() to set the public key size to SIZE_MAX, as it subtracted the nonexistent BIT STRING metadata byte. Then, x509_cert_parse() called kmemdup() with that bogus size, triggering the WARN_ON_ONCE() in kmalloc_slab(). This appears to be harmless, but it still must be fixed since WARNs are never supposed to be user-triggerable. Fix it by updating x509_cert_parse() to validate that the value has a BIT STRING metadata byte, and that the byte is 0 which indicates that the number of bits in the bitstring is a multiple of 8. It would be nice to handle the metadata byte in asn1_ber_decoder() instead. But that would be tricky because in the general case a BIT STRING could be implicitly tagged, and/or could legitimately have a length that is not a whole number of bytes. Here was the WARN (cleaned up slightly): WARNING: CPU: 1 PID: 202 at mm/slab_common.c:971 kmalloc_slab+0x5d/0x70 mm/slab_common.c:971 Modules linked in: CPU: 1 PID: 202 Comm: keyctl Tainted: G B 4.14.0-09238-g1d3b78bbc6e9 #26 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014 task: ffff880033014180 task.stack: ffff8800305c8000 Call Trace: __do_kmalloc mm/slab.c:3706 [inline] __kmalloc_track_caller+0x22/0x2e0 mm/slab.c:3726 kmemdup+0x17/0x40 mm/util.c:118 kmemdup include/linux/string.h:414 [inline] x509_cert_parse+0x2cb/0x620 crypto/asymmetric_keys/x509_cert_parser.c:106 x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174 asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388 key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0x96 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-24crypto: dh - Fix double free of ctx->pEric Biggers
commit 12d41a023efb01b846457ccdbbcbe2b65a87d530 upstream. When setting the secret with the software Diffie-Hellman implementation, if allocating 'g' failed (e.g. if it was longer than MAX_EXTERN_MPI_BITS), then 'p' was freed twice: once immediately, and once later when the crypto_kpp tfm was destroyed. Fix it by using dh_free_ctx() (renamed to dh_clear_ctx()) in the error paths, as that correctly sets the pointers to NULL. KASAN report: MPI: mpi too large (32760 bits) ================================================================== BUG: KASAN: use-after-free in mpi_free+0x131/0x170 Read of size 4 at addr ffff88006c7cdf90 by task reproduce_doubl/367 CPU: 1 PID: 367 Comm: reproduce_doubl Not tainted 4.14.0-rc7-00040-g05298abde6fe #7 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: dump_stack+0xb3/0x10b ? mpi_free+0x131/0x170 print_address_description+0x79/0x2a0 ? mpi_free+0x131/0x170 kasan_report+0x236/0x340 ? akcipher_register_instance+0x90/0x90 __asan_report_load4_noabort+0x14/0x20 mpi_free+0x131/0x170 ? akcipher_register_instance+0x90/0x90 dh_exit_tfm+0x3d/0x140 crypto_kpp_exit_tfm+0x52/0x70 crypto_destroy_tfm+0xb3/0x250 __keyctl_dh_compute+0x640/0xe90 ? kasan_slab_free+0x12f/0x180 ? dh_data_from_key+0x240/0x240 ? key_create_or_update+0x1ee/0xb20 ? key_instantiate_and_link+0x440/0x440 ? lock_contended+0xee0/0xee0 ? kfree+0xcf/0x210 ? SyS_add_key+0x268/0x340 keyctl_dh_compute+0xb3/0xf1 ? __keyctl_dh_compute+0xe90/0xe90 ? SyS_add_key+0x26d/0x340 ? entry_SYSCALL_64_fastpath+0x5/0xbe ? trace_hardirqs_on_caller+0x3f4/0x560 SyS_keyctl+0x72/0x2c0 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x43ccf9 RSP: 002b:00007ffeeec96158 EFLAGS: 00000246 ORIG_RAX: 00000000000000fa RAX: ffffffffffffffda RBX: 000000000248b9b9 RCX: 000000000043ccf9 RDX: 00007ffeeec96170 RSI: 00007ffeeec96160 RDI: 0000000000000017 RBP: 0000000000000046 R08: 0000000000000000 R09: 0248b9b9143dc936 R10: 0000000000001000 R11: 0000000000000246 R12: 0000000000000000 R13: 0000000000409670 R14: 0000000000409700 R15: 0000000000000000 Allocated by task 367: save_stack_trace+0x16/0x20 kasan_kmalloc+0xeb/0x180 kmem_cache_alloc_trace+0x114/0x300 mpi_alloc+0x4b/0x230 mpi_read_raw_data+0xbe/0x360 dh_set_secret+0x1dc/0x460 __keyctl_dh_compute+0x623/0xe90 keyctl_dh_compute+0xb3/0xf1 SyS_keyctl+0x72/0x2c0 entry_SYSCALL_64_fastpath+0x1f/0xbe Freed by task 367: save_stack_trace+0x16/0x20 kasan_slab_free+0xab/0x180 kfree+0xb5/0x210 mpi_free+0xcb/0x170 dh_set_secret+0x2d7/0x460 __keyctl_dh_compute+0x623/0xe90 keyctl_dh_compute+0xb3/0xf1 SyS_keyctl+0x72/0x2c0 entry_SYSCALL_64_fastpath+0x1f/0xbe Fixes: 802c7f1c84e4 ("crypto: dh - Add DH software implementation") Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-24crypto: dh - fix memleak in setkeyTudor-Dan Ambarus
commit ee34e2644a78e2561742bea8c4bdcf83cabf90a7 upstream. setkey can be called multiple times during the existence of the transformation object. In case of multiple setkey calls, the old key was not freed and we leaked memory. Free the old MPI key if any. Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21crypto: dh - Don't permit 'key' or 'g' size longer than 'p'Eric Biggers
commit ccd9888f14a8019c0bbdeeae758aba1f58693712 upstream. The "qat-dh" DH implementation assumes that 'key' and 'g' can be copied into a buffer with size 'p_size'. However it was never checked that that was actually the case, which most likely allowed users to cause a buffer underflow via KEYCTL_DH_COMPUTE. Fix this by updating crypto_dh_decode_key() to verify this precondition for all DH implementations. Fixes: c9839143ebbf ("crypto: qat - Add DH support") Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21crypto: dh - Don't permit 'p' to be 0Eric Biggers
commit 199512b1234f09e44d592153ec82b44212b2f0c4 upstream. If 'p' is 0 for the software Diffie-Hellman implementation, then dh_max_size() returns 0. In the case of KEYCTL_DH_COMPUTE, this causes ZERO_SIZE_PTR to be passed to sg_init_one(), which with CONFIG_DEBUG_SG=y triggers the 'BUG_ON(!virt_addr_valid(buf));' in sg_set_buf(). Fix this by making crypto_dh_decode_key() reject 0 for 'p'. p=0 makes no sense for any DH implementation because 'p' is supposed to be a prime number. Moreover, 'mod 0' is not mathematically defined. Bug report: kernel BUG at ./include/linux/scatterlist.h:140! invalid opcode: 0000 [#1] SMP KASAN CPU: 0 PID: 27112 Comm: syz-executor2 Not tainted 4.14.0-rc7-00010-gf5dbb5d0ce32-dirty #7 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.3-20171021_125229-anatol 04/01/2014 task: ffff88006caac0c0 task.stack: ffff88006c7c8000 RIP: 0010:sg_set_buf include/linux/scatterlist.h:140 [inline] RIP: 0010:sg_init_one+0x1b3/0x240 lib/scatterlist.c:156 RSP: 0018:ffff88006c7cfb08 EFLAGS: 00010216 RAX: 0000000000010000 RBX: ffff88006c7cfe30 RCX: 00000000000064ee RDX: ffffffff81cf64c3 RSI: ffffc90000d72000 RDI: ffffffff92e937e0 RBP: ffff88006c7cfb30 R08: ffffed000d8f9fab R09: ffff88006c7cfd30 R10: 0000000000000005 R11: ffffed000d8f9faa R12: ffff88006c7cfd30 R13: 0000000000000000 R14: 0000000000000010 R15: ffff88006c7cfc50 FS: 00007fce190fa700(0000) GS:ffff88003ea00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007fffc6b33db8 CR3: 000000003cf64000 CR4: 00000000000006f0 Call Trace: __keyctl_dh_compute+0xa95/0x19b0 security/keys/dh.c:360 keyctl_dh_compute+0xac/0x100 security/keys/dh.c:434 SYSC_keyctl security/keys/keyctl.c:1745 [inline] SyS_keyctl+0x72/0x2c0 security/keys/keyctl.c:1641 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x4585c9 RSP: 002b:00007fce190f9bd8 EFLAGS: 00000216 ORIG_RAX: 00000000000000fa RAX: ffffffffffffffda RBX: 0000000000738020 RCX: 00000000004585c9 RDX: 000000002000d000 RSI: 0000000020000ff4 RDI: 0000000000000017 RBP: 0000000000000046 R08: 0000000020008000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000216 R12: 00007fff6e610cde R13: 00007fff6e610cdf R14: 00007fce190fa700 R15: 0000000000000000 Code: 03 0f b6 14 02 48 89 f8 83 e0 07 83 c0 03 38 d0 7c 04 84 d2 75 33 5b 45 89 6c 24 14 41 5c 41 5d 41 5e 41 5f 5d c3 e8 fd 8f 68 ff <0f> 0b e8 f6 8f 68 ff 0f 0b e8 ef 8f 68 ff 0f 0b e8 e8 8f 68 ff 20 RIP: sg_set_buf include/linux/scatterlist.h:140 [inline] RSP: ffff88006c7cfb08 RIP: sg_init_one+0x1b3/0x240 lib/scatterlist.c:156 RSP: ffff88006c7cfb08 Fixes: 802c7f1c84e4 ("crypto: dh - Add DH software implementation") Reviewed-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21Revert "crypto: xts - Add ECB dependency"Sasha Levin
This reverts commit 6145171a6bc0abdc3eca7a4b795ede467d2ba569. The commit fixes a bug that was only introduced in 4.10, thus is irrelevant for <=4.9. Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15crypto: ccm - preserve the IV bufferRomain Izard
commit 441f99c90497e15aa3ad1dbabd56187e29614348 upstream. The IV buffer used during CCM operations is used twice, during both the hashing step and the ciphering step. When using a hardware accelerator that updates the contents of the IV buffer at the end of ciphering operations, the value will be modified. In the decryption case, the subsequent setup of the hashing algorithm will interpret the updated IV instead of the original value, which can lead to out-of-bounds writes. Reuse the idata buffer, only used in the hashing step, to preserve the IV's value during the ciphering step in the decryption case. Signed-off-by: Romain Izard <romain.izard.pro@gmail.com> Reviewed-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27pkcs7: Prevent NULL pointer dereference, since sinfo is not always set.Eric Sesterhenn
commit 68a1fdbbf8bd3378325e45c19e167a165f9ffc3a upstream. The ASN.1 parser does not necessarily set the sinfo field, this patch prevents a NULL pointer dereference on broken input. Fixes: 99db44350672 ("PKCS#7: Appropriately restrict authenticated attributes and content type") Signed-off-by: Eric Sesterhenn <eric.sesterhenn@x41-dsec.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21crypto: xts - Add ECB dependencyMilan Broz
[ Upstream commit 12cb3a1c4184f891d965d1f39f8cfcc9ef617647 ] Since the commit f1c131b45410a202eb45cc55980a7a9e4e4b4f40 crypto: xts - Convert to skcipher the XTS mode is based on ECB, so the mode must select ECB otherwise it can fail to initialize. Signed-off-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18crypto: shash - Fix zero-length shash ahash digest crashHerbert Xu
commit b61907bb42409adf9b3120f741af7c57dd7e3db2 upstream. The shash ahash digest adaptor function may crash if given a zero-length input together with a null SG list. This is because it tries to read the SG list before looking at the length. This patch fixes it by checking the length first. Reported-by: Stephan Müller<smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Stephan Müller <smueller@chronox.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05crypto: drbg - fix freeing of resourcesStephan Mueller
commit bd6227a150fdb56e7bb734976ef6e53a2c1cb334 upstream. During the change to use aligned buffers, the deallocation code path was not updated correctly. The current code tries to free the aligned buffer pointer and not the original buffer pointer as it is supposed to. Thus, the code is updated to free the original buffer pointer and set the aligned buffer pointer that is used throughout the code to NULL. Fixes: 3cfc3b9721123 ("crypto: drbg - use aligned buffers") CC: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27crypto: AF_ALG - remove SGL terminator indicator when chainingStephan Mueller
Fixed differently upstream as commit 2d97591ef43d ("crypto: af_alg - consolidation of duplicate code") The SGL is MAX_SGL_ENTS + 1 in size. The last SG entry is used for the chaining and is properly updated with the sg_chain invocation. During the filling-in of the initial SG entries, sg_mark_end is called for each SG entry. This is appropriate as long as no additional SGL is chained with the current SGL. However, when a new SGL is chained and the last SG entry is updated with sg_chain, the last but one entry still contains the end marker from the sg_mark_end. This end marker must be removed as otherwise a walk of the chained SGLs will cause a NULL pointer dereference at the last but one SG entry, because sg_next will return NULL. The patch only applies to all kernels up to and including 4.13. The patch 2d97591ef43d0587be22ad1b0d758d6df4999a0b added to 4.14-rc1 introduced a complete new code base which addresses this bug in a different way. Yet, that patch is too invasive for stable kernels and was therefore not marked for stable. Fixes: 8ff590903d5fc ("crypto: algif_skcipher - User-space interface for skcipher operations") Signed-off-by: Stephan Mueller <smueller@chronox.de> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07crypto: algif_skcipher - only call put_page on referenced and used pagesStephan Mueller
commit 445a582738de6802669aeed9c33ca406c23c3b1f upstream. For asynchronous operation, SGs are allocated without a page mapped to them or with a page that is not used (ref-counted). If the SGL is freed, the code must only call put_page for an SG if there was a page assigned and ref-counted in the first place. This fixes a kernel crash when using io_submit with more than one iocb using the sendmsg and sendpage (vmsplice/splice) interface. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06crypto: authencesn - Fix digest_null crashHerbert Xu
commit 41cdf7a45389e01991ee31e3301ed83cb3e3f7dc upstream. When authencesn is used together with digest_null a crash will occur on the decrypt path. This is because normally we perform a special setup to preserve the ESN, but this is skipped if there is no authentication. However, on the post-authentication path it always expects the preservation to be in place, thus causing a crash when digest_null is used. This patch fixes this by also skipping the post-processing when there is no authentication. Fixes: 104880a6b470 ("crypto: authencesn - Convert to new AEAD...") Reported-by: Jan Tluka <jtluka@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15crypto: rsa-pkcs1pad - use constant time memory comparison for MACsJason A. Donenfeld
commit fec17cb2231733174e039ad9054fa16bb358e2ec upstream. Otherwise, we enable all sorts of forgeries via timing attack. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Suggested-by: Stephan Müller <smueller@chronox.de> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: linux-crypto@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-12crypto: drbg - Fixes panic in wait_for_completion callStephan Mueller
commit b61929c654f2e725644935737c4c1ea9c741e2f8 upstream. Initialise ctr_completion variable before use. Cc: <stable@vger.kernel.org> Signed-off-by: Harsh Jain <harshjain.prof@gmail.com> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14crypto: gcm - wait for crypto op not signal safeGilad Ben-Yossef
commit f3ad587070d6bd961ab942b3fd7a85d00dfc934b upstream. crypto_gcm_setkey() was using wait_for_completion_interruptible() to wait for completion of async crypto op but if a signal occurs it may return before DMA ops of HW crypto provider finish, thus corrupting the data buffer that is kfree'ed in this case. Resolve this by using wait_for_completion() instead. Reported-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14crypto: drbg - wait for crypto op not signal safeGilad Ben-Yossef
commit a5dfefb1c3f3db81662556393fd9283511e08430 upstream. drbg_kcapi_sym_ctr() was using wait_for_completion_interruptible() to wait for completion of async crypto op but if a signal occurs it may return before DMA ops of HW crypto provider finish, thus corrupting the output buffer. Resolve this by using wait_for_completion() instead. Reported-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14crypto: asymmetric_keys - handle EBUSY due to backlog correctlyGilad Ben-Yossef
commit e68368aed56324e2e38d4f6b044bb8cf82077fc2 upstream. public_key_verify_signature() was passing the CRYPTO_TFM_REQ_MAY_BACKLOG flag to akcipher_request_set_callback() but was not handling correctly the case where a -EBUSY error could be returned from the call to crypto_akcipher_verify() if backlog was used, possibly casuing data corruption due to use-after-free of buffers. Resolve this by handling -EBUSY correctly. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07crypto: skcipher - Add missing API setkey checksHerbert Xu
commit 9933e113c2e87a9f46a40fde8dafbf801dca1ab9 upstream. The API setkey checks for key sizes and alignment went AWOL during the skcipher conversion. This patch restores them. Fixes: 4e6c3df4d729 ("crypto: skcipher - Add low-level skcipher...") Reported-by: Baozeng <sploving1@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20crypto: algif_aead - Require setkey before accept(2)Stephan Mueller
commit 2a2a251f110576b1d89efbd0662677d7e7db21a8 upstream. Some cipher implementations will crash if you try to use them without calling setkey first. This patch adds a check so that the accept(2) call will fail with -ENOKEY if setkey hasn't been done on the socket yet. Fixes: 400c40cf78da ("crypto: algif - add AEAD support") Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21crypto: ahash - Fix EINPROGRESS notification callbackHerbert Xu
commit ef0579b64e93188710d48667cb5e014926af9f1b upstream. The ahash API modifies the request's callback function in order to clean up after itself in some corner cases (unaligned final and missing finup). When the request is complete ahash will restore the original callback and everything is fine. However, when the request gets an EBUSY on a full queue, an EINPROGRESS callback is made while the request is still ongoing. In this case the ahash API will incorrectly call its own callback. This patch fixes the problem by creating a temporary request object on the stack which is used to relay EINPROGRESS back to the original completion function. This patch also adds code to preserve the original flags value. Fixes: ab6bf4e5e5e4 ("crypto: hash - Fix the pointer voodoo in...") Reported-by: Sabrina Dubroca <sd@queasysnail.net> Tested-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21crypto: algif_aead - Fix bogus request dereference in completion functionHerbert Xu
commit e6534aebb26e32fbab14df9c713c65e8507d17e4 upstream. The algif_aead completion function tries to deduce the aead_request from the crypto_async_request argument. This is broken because the API does not guarantee that the same request will be pased to the completion function. Only the value of req->data can be used in the completion function. This patch fixes it by storing a pointer to sk in areq and using that instead of passing in sk through req->data. Fixes: 83094e5e9e49 ("crypto: af_alg - add async support to...") Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30crypto: algif_hash - avoid zero-sized arrayJiri Slaby
commit 6207119444595d287b1e9e83a2066c17209698f3 upstream. With this reproducer: struct sockaddr_alg alg = { .salg_family = 0x26, .salg_type = "hash", .salg_feat = 0xf, .salg_mask = 0x5, .salg_name = "digest_null", }; int sock, sock2; sock = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(sock, (struct sockaddr *)&alg, sizeof(alg)); sock2 = accept(sock, NULL, NULL); setsockopt(sock, SOL_ALG, ALG_SET_KEY, "\x9b\xca", 2); accept(sock2, NULL, NULL); ==== 8< ======== 8< ======== 8< ======== 8< ==== one can immediatelly see an UBSAN warning: UBSAN: Undefined behaviour in crypto/algif_hash.c:187:7 variable length array bound value 0 <= 0 CPU: 0 PID: 15949 Comm: syz-executor Tainted: G E 4.4.30-0-default #1 ... Call Trace: ... [<ffffffff81d598fd>] ? __ubsan_handle_vla_bound_not_positive+0x13d/0x188 [<ffffffff81d597c0>] ? __ubsan_handle_out_of_bounds+0x1bc/0x1bc [<ffffffffa0e2204d>] ? hash_accept+0x5bd/0x7d0 [algif_hash] [<ffffffffa0e2293f>] ? hash_accept_nokey+0x3f/0x51 [algif_hash] [<ffffffffa0e206b0>] ? hash_accept_parent_nokey+0x4a0/0x4a0 [algif_hash] [<ffffffff8235c42b>] ? SyS_accept+0x2b/0x40 It is a correct warning, as hash state is propagated to accept as zero, but creating a zero-length variable array is not allowed in C. Fix this as proposed by Herbert -- do "?: 1" on that site. No sizeof or similar happens in the code there, so we just allocate one byte even though we do not use the array. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> (maintainer:CRYPTO API) Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-18crypto: improve gcc optimization flags for serpent and wp512Arnd Bergmann
commit 7d6e9105026788c497f0ab32fa16c82f4ab5ff61 upstream. An ancient gcc bug (first reported in 2003) has apparently resurfaced on MIPS, where kernelci.org reports an overly large stack frame in the whirlpool hash algorithm: crypto/wp512.c:987:1: warning: the frame size of 1112 bytes is larger than 1024 bytes [-Wframe-larger-than=] With some testing in different configurations, I'm seeing large variations in stack frames size up to 1500 bytes for what should have around 300 bytes at most. I also checked the reference implementation, which is essentially the same code but also comes with some test and benchmarking infrastructure. It seems that recent compiler versions on at least arm, arm64 and powerpc have a partial fix for this problem, but enabling "-fsched-pressure", but even with that fix they suffer from the issue to a certain degree. Some testing on arm64 shows that the time needed to hash a given amount of data is roughly proportional to the stack frame size here, which makes sense given that the wp512 implementation is doing lots of loads for table lookups, and the problem with the overly large stack is a result of doing a lot more loads and stores for spilled registers (as seen from inspecting the object code). Disabling -fschedule-insns consistently fixes the problem for wp512, in my collection of cross-compilers, the results are consistently better or identical when comparing the stack sizes in this function, though some architectures (notable x86) have schedule-insns disabled by default. The four columns are: default: -O2 press: -O2 -fsched-pressure nopress: -O2 -fschedule-insns -fno-sched-pressure nosched: -O2 -no-schedule-insns (disables sched-pressure) default press nopress nosched alpha-linux-gcc-4.9.3 1136 848 1136 176 am33_2.0-linux-gcc-4.9.3 2100 2076 2100 2104 arm-linux-gnueabi-gcc-4.9.3 848 848 1048 352 cris-linux-gcc-4.9.3 272 272 272 272 frv-linux-gcc-4.9.3 1128 1000 1128 280 hppa64-linux-gcc-4.9.3 1128 336 1128 184 hppa-linux-gcc-4.9.3 644 308 644 276 i386-linux-gcc-4.9.3 352 352 352 352 m32r-linux-gcc-4.9.3 720 656 720 268 microblaze-linux-gcc-4.9.3 1108 604 1108 256 mips64-linux-gcc-4.9.3 1328 592 1328 208 mips-linux-gcc-4.9.3 1096 624 1096 240 powerpc64-linux-gcc-4.9.3 1088 432 1088 160 powerpc-linux-gcc-4.9.3 1080 584 1080 224 s390-linux-gcc-4.9.3 456 456 624 360 sh3-linux-gcc-4.9.3 292 292 292 292 sparc64-linux-gcc-4.9.3 992 240 992 208 sparc-linux-gcc-4.9.3 680 592 680 312 x86_64-linux-gcc-4.9.3 224 240 272 224 xtensa-linux-gcc-4.9.3 1152 704 1152 304 aarch64-linux-gcc-7.0.0 224 224 1104 208 arm-linux-gnueabi-gcc-7.0.1 824 824 1048 352 mips-linux-gcc-7.0.0 1120 648 1120 272 x86_64-linux-gcc-7.0.1 240 240 304 240 arm-linux-gnueabi-gcc-4.4.7 840 392 arm-linux-gnueabi-gcc-4.5.4 784 728 784 320 arm-linux-gnueabi-gcc-4.6.4 736 728 736 304 arm-linux-gnueabi-gcc-4.7.4 944 784 944 352 arm-linux-gnueabi-gcc-4.8.5 464 464 760 352 arm-linux-gnueabi-gcc-4.9.3 848 848 1048 352 arm-linux-gnueabi-gcc-5.3.1 824 824 1064 336 arm-linux-gnueabi-gcc-6.1.1 808 808 1056 344 arm-linux-gnueabi-gcc-7.0.1 824 824 1048 352 Trying the same test for serpent-generic, the picture is a bit different, and while -fno-schedule-insns is generally better here than the default, -fsched-pressure wins overall, so I picked that instead. default press nopress nosched alpha-linux-gcc-4.9.3 1392 864 1392 960 am33_2.0-linux-gcc-4.9.3 536 524 536 528 arm-linux-gnueabi-gcc-4.9.3 552 552 776 536 cris-linux-gcc-4.9.3 528 528 528 528 frv-linux-gcc-4.9.3 536 400 536 504 hppa64-linux-gcc-4.9.3 524 208 524 480 hppa-linux-gcc-4.9.3 768 472 768 508 i386-linux-gcc-4.9.3 564 564 564 564 m32r-linux-gcc-4.9.3 712 576 712 532 microblaze-linux-gcc-4.9.3 724 392 724 512 mips64-linux-gcc-4.9.3 720 384 720 496 mips-linux-gcc-4.9.3 728 384 728 496 powerpc64-linux-gcc-4.9.3 704 304 704 480 powerpc-linux-gcc-4.9.3 704 296 704 480 s390-linux-gcc-4.9.3 560 560 592 536 sh3-linux-gcc-4.9.3 540 540 540 540 sparc64-linux-gcc-4.9.3 544 352 544 496 sparc-linux-gcc-4.9.3 544 344 544 496 x86_64-linux-gcc-4.9.3 528 536 576 528 xtensa-linux-gcc-4.9.3 752 544 752 544 aarch64-linux-gcc-7.0.0 432 432 656 480 arm-linux-gnueabi-gcc-7.0.1 616 616 808 536 mips-linux-gcc-7.0.0 720 464 720 488 x86_64-linux-gcc-7.0.1 536 528 600 536 arm-linux-gnueabi-gcc-4.4.7 592 440 arm-linux-gnueabi-gcc-4.5.4 776 448 776 544 arm-linux-gnueabi-gcc-4.6.4 776 448 776 544 arm-linux-gnueabi-gcc-4.7.4 768 448 768 544 arm-linux-gnueabi-gcc-4.8.5 488 488 776 544 arm-linux-gnueabi-gcc-4.9.3 552 552 776 536 arm-linux-gnueabi-gcc-5.3.1 552 552 776 536 arm-linux-gnueabi-gcc-6.1.1 560 560 776 536 arm-linux-gnueabi-gcc-7.0.1 616 616 808 536 I did not do any runtime tests with serpent, so it is possible that stack frame size does not directly correlate with runtime performance here and it actually makes things worse, but it's more likely to help here, and the reduced stack frame size is probably enough reason to apply the patch, especially given that the crypto code is often used in deep call chains. Link: https://kernelci.org/build/id/58797d7559b5149efdf6c3a9/logs/ Link: http://www.larc.usp.br/~pbarreto/WhirlpoolPage.html Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=11488 Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=79149 Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12crypto: testmgr - Pad aes_ccm_enc_tv_template vectorLaura Abbott
commit 1c68bb0f62bf8de8bb30123ea840d5168f25abea upstream. Running with KASAN and crypto tests currently gives BUG: KASAN: global-out-of-bounds in __test_aead+0x9d9/0x2200 at addr ffffffff8212fca0 Read of size 16 by task cryptomgr_test/1107 Address belongs to variable 0xffffffff8212fca0 CPU: 0 PID: 1107 Comm: cryptomgr_test Not tainted 4.10.0+ #45 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014 Call Trace: dump_stack+0x63/0x8a kasan_report.part.1+0x4a7/0x4e0 ? __test_aead+0x9d9/0x2200 ? crypto_ccm_init_crypt+0x218/0x3c0 [ccm] kasan_report+0x20/0x30 check_memory_region+0x13c/0x1a0 memcpy+0x23/0x50 __test_aead+0x9d9/0x2200 ? kasan_unpoison_shadow+0x35/0x50 ? alg_test_akcipher+0xf0/0xf0 ? crypto_skcipher_init_tfm+0x2e3/0x310 ? crypto_spawn_tfm2+0x37/0x60 ? crypto_ccm_init_tfm+0xa9/0xd0 [ccm] ? crypto_aead_init_tfm+0x7b/0x90 ? crypto_alloc_tfm+0xc4/0x190 test_aead+0x28/0xc0 alg_test_aead+0x54/0xd0 alg_test+0x1eb/0x3d0 ? alg_find_test+0x90/0x90 ? __sched_text_start+0x8/0x8 ? __wake_up_common+0x70/0xb0 cryptomgr_test+0x4d/0x60 kthread+0x173/0x1c0 ? crypto_acomp_scomp_free_ctx+0x60/0x60 ? kthread_create_on_node+0xa0/0xa0 ret_from_fork+0x2c/0x40 Memory state around the buggy address: ffffffff8212fb80: 00 00 00 00 01 fa fa fa fa fa fa fa 00 00 00 00 ffffffff8212fc00: 00 01 fa fa fa fa fa fa 00 00 00 00 01 fa fa fa >ffffffff8212fc80: fa fa fa fa 00 05 fa fa fa fa fa fa 00 00 00 00 ^ ffffffff8212fd00: 01 fa fa fa fa fa fa fa 00 00 00 00 01 fa fa fa ffffffff8212fd80: fa fa fa fa 00 00 00 00 00 05 fa fa fa fa fa fa This always happens on the same IV which is less than 16 bytes. Per Ard, "CCM IVs are 16 bytes, but due to the way they are constructed internally, the final couple of bytes of input IV are dont-cares. Apparently, we do read all 16 bytes, which triggers the KASAN errors." Fix this by padding the IV with null bytes to be at least 16 bytes. Fixes: 0bc5a6c5c79a ("crypto: testmgr - Disable rfc4309 test and convert test vectors") Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14crypto: algif_aead - Fix kernel panic on list_delHarsh Jain
commit 0b529f143e8baad441a5aac9ad55ec2434d8fb46 upstream. Kernel panics when userspace program try to access AEAD interface. Remove node from Linked List before freeing its memory. Signed-off-by: Harsh Jain <harsh@chelsio.com> Reviewed-by: Stephan Müller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
