switch: Export symbol switch_set_state.
Signed-off-by: Mike Lockwood <lockwood@android.com>
switch: gpio: Don't call request_irq with interrupts disabled
Signed-off-by: Arve Hjønnevåg <arve@android.com>
switch: Use device_create instead of device_create_drvdata.
device_create_drvdata is obsolete.
switch_gpio: Add missing #include <linux/interrupt.h>
Change-Id: I6c397e41bbe1457162cc69e31a29db5d9f76fccb
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits)
drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c
powerpc/85xx: fix mpic configuration in CAMP mode
powerpc: Copy back TIF flags on return from softirq stack
powerpc/64: Make server perfmon only built on ppc64 server devices
powerpc/pseries: Fix hvc_vio.c build due to recent changes
powerpc: Exporting boot_cpuid_phys
powerpc: Add CFAR to oops output
hvc_console: Add kdb support
powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon
powerpc/irq: Quieten irq mapping printks
powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs
powerpc: Add mpt2sas driver to pseries and ppc64 defconfig
powerpc: Disable IRQs off tracer in ppc64 defconfig
powerpc: Sync pseries and ppc64 defconfigs
powerpc/pseries/hvconsole: Fix dropped console output
hvc_console: Improve tty/console put_chars handling
powerpc/kdump: Fix timeout in crash_kexec_wait_realmode
powerpc/mm: Fix output of total_ram.
powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards
powerpc: Correct annotations of pmu registration functions
Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and
drivers/cpufreq
virtio has been so far used only in the context of virtualization,
and the virtio Kconfig was sourced directly by the relevant arch
Kconfigs when VIRTUALIZATION was selected.
Now that we start using virtio for inter-processor communications,
we need to source the virtio Kconfig outside of the virtualization
scope too.
Moreover, some architectures might use virtio for both virtualization
and inter-processor communications, so directly sourcing virtio
might yield unexpected results due to conflicting selections.
The simple solution offered by this patch is to always source virtio's
Kconfig in drivers/Kconfig, and remove it from the appropriate arch
Kconfigs. Additionally, a virtio menu entry has been added so virtio
drivers don't show up in the general drivers menu.
This way anyone can use virtio, though it's arguably less accessible
(and neat!) for virtualization users now.
Note: some architectures (mips and sh) seem to have a VIRTUALIZATION
menu merely for sourcing virtio's Kconfig, so that menu is removed too.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
* 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
iommu/core: Fix build with INTR_REMAP=y && CONFIG_DMAR=n
iommu/amd: Don't use MSI address range for DMA addresses
iommu/amd: Move missing parts to drivers/iommu
iommu: Move iommu Kconfig entries to submenu
x86/ia64: intel-iommu: move to drivers/iommu/
x86: amd_iommu: move to drivers/iommu/
msm: iommu: move to drivers/iommu/
drivers: iommu: move to a dedicated folder
x86/amd-iommu: Store device alias as dev_data pointer
x86/amd-iommu: Search for existind dev_data before allocting a new one
x86/amd-iommu: Allow dev_data->alias to be NULL
x86/amd-iommu: Use only dev_data in low-level domain attach/detach functions
x86/amd-iommu: Use only dev_data for dte and iotlb flushing routines
x86/amd-iommu: Store ATS state in dev_data
x86/amd-iommu: Store devid in dev_data
x86/amd-iommu: Introduce global dev_data_list
x86/amd-iommu: Remove redundant device_flush_dte() calls
iommu-api: Add missing header file
Fix up trivial conflicts (independent additions close to each other) in
drivers/Makefile and include/linux/pci.h
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Add the drivers/virt directory, which houses drivers that support
virtualization environments, and add the Freescale hypervisor management
driver.
The Freescale hypervisor management driver provides several services to
drivers and applications related to the Freescale hypervisor:
1. An ioctl interface for querying and managing partitions
2. A file interface to reading incoming doorbells
3. An interrupt handler for shutting down the partition upon receiving the
shutdown doorbell from a manager partition
4. A kernel interface for receiving callbacks when a managed partition
shuts down.
The NFC subsystem core is responsible for providing the device driver
interface. It is also responsible for providing an interface to the control
operations and data exchange.
Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org>
Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org>
Create a dedicated folder for iommu drivers, and move the base
iommu implementation over there.
Grouping the various iommu drivers in a single location will help
finding similar problems shared by different platforms, so they
could be solved once, in the iommu framework, instead of solved
differently (or duplicated) in each driver.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
This patch adds an infrastructure for hardware clocks that implement
IEEE 1588, the Precision Time Protocol (PTP). A class driver offers a
registration method to particular hardware clock drivers. Each clock is
presented as a standard POSIX clock.
The ancillary clock features are exposed in two different ways, via
the sysfs and by a character device.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Signed-off-by: John Stultz <john.stultz@linaro.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
This is based upon both arch/arm/mach-footbridge/isa-timer.c and
arch/x86/kernel/i8253.c.
Acked-by: John Stultz <john.stultz@linaro.org>
Broadcom has released cards based on a new AMBA-based bus type. From a
programming point of view, this new bus type differs from AMBA and does
not use AMBA common registers. It also differs enough from SSB. We
decided that a new bus driver is needed to keep the code clean.
In its current form, the driver detects devices present on the bus and
registers them in the system. It allows registering BCMA drivers for
specified bus devices and provides them basic operations. The bus driver
itself includes two important bus managing drivers: ChipCommon core
driver and PCI(c) core driver. They are early used to allow correct
initialization.
Currently code is limited to supporting buses on PCI(e) devices, however
the driver is designed to be used also on other hosts. The host
abstraction layer is implemented and already used for PCI(e).
Support for PCI(e) hosts is working and seems to be stable (access to
80211 core was tested successfully on a few devices). We can still
optimize it by using some fixed windows, but this can be done later
without affecting any external code. Windows are just ranges in MMIO
used for accessing cores on the bus.
Cc: Greg KH <greg@kroah.com>
Cc: Michael Büsch <mb@bu3sch.de>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: George Kashperko <george@znau.edu.ua>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: Andy Botting <andy@andybotting.com>
Cc: linuxdriverproject <devel@linuxdriverproject.org>
Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Add a platform-independent hwspinlock framework.
Hardware spinlock devices are needed, e.g., in order to access data
that is shared between remote processors, that otherwise have no
alternative mechanism to accomplish synchronization and mutual exclusion
operations.
Cc: Hari Kanigeri <h-kanigeri2@ti.com>
Cc: Benoit Cousson <b-cousson@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Paul Walmsley <paul@pwsan.com>
LIO target is a full featured in-kernel target framework with the
following feature set:
High-performance, non-blocking, multithreaded architecture with SIMD
support.
Advanced SCSI feature set:
* Persistent Reservations (PRs)
* Asymmetric Logical Unit Assignment (ALUA)
* Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S)
* Full Error Recovery (ERL=0,1,2)
* Active/active task migration and session continuation (ERL=2)
* Thin LUN provisioning (UNMAP and WRITE_SAMExx)
Multiprotocol target plugins
Storage media independence:
* Virtualization of all storage media; transparent mapping of IO to LUNs
* No hard limits on number of LUNs per Target; maximum LUN size ~750 TB
* Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc.
Standards compliance:
* Full compliance with IETF (RFC 3720)
* Full implementation of SPC-4 PRs and ALUA
Significant code cleanups done by Christoph Hellwig.
[jejb: fix up for new block bdev exclusive interface. Minor fixes from
Randy Dunlap and Dan Carpenter.]
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Creates a new "Near Field Communication" subsystem in drivers/nfc.
http://en.wikipedia.org/wiki/Near_Field_Communication is useful ;)
This is a driver for the pn544 NFC device. The driver transfers
ETSI messages between the device and the user space.
Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com>
factorise some generic infrastructure to assist looking up struct clks
for the ARM & SH architecture.
as the code is identical at 99%
put the arch specific code for allocation as example in asm/clkdev.h
Acked-by: Paul Mundt <lethal@linux-sh.org>
Move the CS5535 MFGPT hrtimer kconfig option to be with the other MFGPT
options. This makes it easier to find and also removes it from the main
"Device Drivers" menu, where it should not have been.
Acked-by: Andres Salomon <dilinger@collabora.co.uk>
Update the Kconfig help texts of both stacks to encourage a general move
from the older to the newer drivers. However, do not label ieee1394 as
"Obsolete" yet, as the newer drivers have not been deployed as default
stack in the majority of Linux distributions yet, and those who start
doing so now may still want to install the old drivers as fallback for
unforeseen issues.
Since Linux 2.6.32, FireWire audio devices can be driven by the newer
firewire driver stack too, hence remove an outdated comment about audio
devices. Also remove comments about library versions since the 2nd
generation of libraw1394 and libdc1394 is now in common use; details on
library versions can be read at the wiki link from the help texts.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
This is based on the old code in arch/x86/kernel/mfgpt_32.c, but is
modular and not Geode-specific. There's no reason why the clock event
device needs to be registered so early at boot; the clockevent code is
perfectly capable of dynamic switching.
[akpm@linux-foundation.org: add linux/irq.h include]
Signed-off-by: Andres Salomon <dilinger@collabora.co.uk>
Cc: Jordan Crouse <jordan@cosmicpenguin.net>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Chris Ball <cjb@laptop.org>
Additionally, some excessive newlines removed.
Signed-off-by: Michael Roth <mroth@nessie.de>
This patch adds the kernel side of the PPS support currently named
"LinuxPPS".
PPS means "pulse per second" and a PPS source is just a device which
provides a high precision signal each second so that an application can
use it to adjust system clock time.
Common use is the combination of the NTPD as userland program with a GPS
receiver as PPS source to obtain a wallclock-time with sub-millisecond
synchronisation to UTC.
To obtain this goal the userland programs shoud use the PPS API
specification (RFC 2783 - Pulse-Per-Second API for UNIX-like Operating
Systems, Version 1.0) which in part is implemented by this patch. It
provides a set of chars devices, one per PPS source, which can be used to
get the time signal. The RFC's functions can be implemented by accessing
to these char devices.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Add support for the TI VLYNQ high-speed, serial and packetized bus.
This bus allows external devices to be connected to the System-on-Chip and
appear in the main system memory just like any memory mapped peripheral.
It is widely used in TI's networking and multimedia SoC, including the AR7
SoC.
Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Move x86 platform specific drivers from drivers/misc/
to a new home under drivers/platform/x86/.
The community has been maintaining x86 vendor-specific
platform specific drivers under /drivers/misc/ for a few years.
The oldest ones started life under drivers/acpi.
They moved out of drivers/acpi/ because they don't actually
implement the ACPI specification, but either simply
use ACPI, or implement vendor-specific ACPI extensions.
In the future we anticipate...
drivers/misc/ will go away.
other architectures will create drivers/platform/<arch>
Signed-off-by: Len Brown <len.brown@intel.com>
When the regulator API was merged it was added to the separate Kconfig
which ARM uses for drivers but not the generic one in drivers/. Since
there is nothing ARM-specific about the API add it there too.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Documentation/ABI/testing/sysfs-bus-usb
drivers/Makefile
This hooks up the drivers/staging directory to the build system
The Kbuild and Kconfig files.
Signed-off-by: David Vrabel <david.vrabel@csr.com>
This adds a minimalistic braille screen reader support. This is meant to
be used by blind people e.g. on boot failures or when / cannot be mounted
etc and thus the userland screen readers can not work.
[akpm@linux-foundation.org: fix exports]
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Jiri Kosina <jikos@jikos.cz>
Cc: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Alan Cox <alan@redhat.com>
The balloon driver allows memory to be dynamically added or removed from the domain,
in order to allow host memory to be balanced between multiple domains.
This patch introduces the Xen balloon driver, though it currently only
allows a domain to be shrunk from its initial size (and re-grown back to
that size). A later patch will add the ability to grow a domain beyond
its initial size.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Sony MemoryStick cards are used in many products manufactured by Sony.
They are available both as storage and as IO expansion cards. Currently,
only MemoryStick Pro storage cards are supported via TI FlashMedia
MemoryStick interface.
[mboton@gmail.com: biuld fix]
[akpm@linux-foundation.org: build fix]
Signed-off-by: Alex Dubov <oakad@yahoo.com>
Signed-off-by: Miguel Boton <mboton@gmail.co>
drivers/acpi/video.c
Add an empty drivers/gpio directory for gpiolib infrastructure and GPIO
expanders. It will be populated by later patches.
This won't be the only place to hold such gpio_chip code. Many external chips
add a few GPIOs as secondary functionality (such as MFD drivers) and platform
code frequently needs to closely integrate GPIO and IRQ support.
This is placed *early* in the build/link sequence since it's common for other
drivers to depend on GPIOs to do their work, so they must be initialized early
in the device_initcall() sequence.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Jean Delvare <khali@linux-fr.org>
Cc: Eric Miao <eric.miao@marvell.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Ben Gardner <bgardner@wabtec.com>
This patch moves virtio under the virtualization menu and changes virtio
devices to not claim to only be for lguest.
Signed-off-by: Anthony Liguori <aliguori@us.ibm.com>
The Generic Thermal sysfs driver for thermal management.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: Thomas Sujith <sujith.thomas@intel.com>
This paves the way for multiple architecture support. Note that while
ioapic.c could potentially be shared with ia64, it is also moved.
Signed-off-by: Avi Kivity <avi@qumranet.com>
This attempts to implement a "virtual I/O" layer which should allow
common drivers to be efficiently used across most virtual I/O
mechanisms. It will no-doubt need further enhancement.
The virtio drivers add buffers to virtio queues; as the buffers are consumed
the driver "interrupt" callbacks are invoked.
There is also a generic implementation of config space which drivers can query
to get setup information from the host.
Cc: Dor Laor <dor.laor@qumranet.com>
Move lguest under the virtualization menu.
Cc: Avi Kivity <avi@qumranet.com>
move watchdog tree from drivers/char/watchdog to drivers/watchdog.
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Direct Cache Access (DCA) is a method for warming the CPU cache before data
is used, with the intent of lessening the impact of cache misses. This
patch adds a manager and interface for matching up client requests for DCA
services with devices that offer DCA services.
In order to use DCA, a module must do bus writes with the appropriate tag
bits set to trigger a cache read for a specific CPU. However, different
CPUs and chipsets can require different sets of tag bits, and the methods
for determining the correct bits may be simple hardcoding or may be a
hardware specific magic incantation. This interface is a way for DCA
clients to find the correct tag bits for the targeted CPU without needing
to know the specifics.
[Dave Miller] use DEFINE_SPINLOCK()
Signed-off-by: Shannon Nelson <shannon.nelson@intel.com>
SSB is an SoC bus used in a number of embedded devices. The most
well-known of these devices is probably the Linksys WRT54G, but there
are others as well. The bus is also used internally on the BCM43xx
and BCM44xx devices from Broadcom.
This patch also includes support for SSB ID tables in modules, so
that SSB drivers can be loaded automatically.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
This moves all the common parts for the Sparc, Sparc64 and PowerPC
of_device.c files into drivers/of/device.c.
Apart from the simple move, Sparc gains of_match_node() and a call to
of_node_put in of_release_dev(). PowerPC gains better recovery if
device_create_file() fails in of_device_register().
Acked-by: Paul Mackerras <paulus@samba.org>
This is the Kconfig and Makefile to allow lguest to actually be
compiled.
Cc: Andi Kleen <ak@suse.de>
This interface allows the ability to write the majority of a driver in
userspace with only a very small shell of a driver in the kernel itself.
It uses a char device and sysfs to interact with a userspace process to
process interrupts and control memory accesses.
See the docbook documentation for more details on how to use this
interface.
Cc: Benedikt Spranger <b.spranger@linutronix.de>
* git://git.infradead.org/~dwmw2/battery-2.6:
[BATTERY] ds2760 W1 slave
[BATTERY] One Laptop Per Child power/battery driver
[BATTERY] Apple PMU driver
[BATTERY] 1-Wire ds2760 chip battery driver
[BATTERY] APM emulation driver for class batteries
[BATTERY] pda_power platform driver
[BATTERY] Universal power supply class (was: battery class)
This class is result of "external power" and "battery" classes merge,
as suggested by David Woodhouse. He also implemented uevent support.
Here how userspace seeing it now:
# ls /sys/class/power\ supply/
ac main-battery usb
# cat /sys/class/power\ supply/ac/type
AC
# cat /sys/class/power\ supply/usb/type
USB
# cat /sys/class/power\ supply/main-battery/type
Battery
# cat /sys/class/power\ supply/ac/online
1
# cat /sys/class/power\ supply/usb/online
0
# cat /sys/class/power\ supply/main-battery/status
Charging
# cat /sys/class/leds/h5400\:red-left/trigger
none h5400-radio timer hwtimer ac-online usb-online
main-battery-charging-or-full [main-battery-charging]
main-battery-full
Signed-off-by: Anton Vorontsov <cbou@mail.ru>
They are all broken beyond repair. Given that nobody has complained
about them (most haven't worked in 2.6 AT ALL), remove them from the
tree.
A new mitsumi driver that actually works is in progress, it'll get
added when completed.
Add support for auxiliary displays, the ks0108 LCD controller, the
cfag12864b LCD and adds a framebuffer device: cfag12864bfb.
- Add a "auxdisplay/" folder in "drivers/" for auxiliary display
drivers.
- Add support for the ks0108 LCD Controller as a device driver. (uses
parport interface)
- Add support for the cfag12864b LCD as a device driver. (uses ks0108
LCD Controller driver)
- Add a framebuffer device called cfag12864bfb. (uses cfag12864b LCD
driver)
- Add the usual Documentation, includes, Makefiles, Kconfigs,
MAINTAINERS, CREDITS...
- Miguel Ojeda will maintain all the stuff above.
[rdunlap@xenotime.net: workqueue fixups]
[akpm@osdl.org: kconfig fix]
Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com>
Acked-by: Paulo Marques <pmarques@grupopie.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
web site: http://kvm.sourceforge.net
mailing list: kvm-devel@lists.sourceforge.net
(http://lists.sourceforge.net/lists/listinfo/kvm-devel)
The following patchset adds a driver for Intel's hardware virtualization
extensions to the x86 architecture. The driver adds a character device
(/dev/kvm) that exposes the virtualization capabilities to userspace. Using
this driver, a process can run a virtual machine (a "guest") in a fully
virtualized PC containing its own virtual hard disks, network adapters, and
display.
Using this driver, one can start multiple virtual machines on a host.
Each virtual machine is a process on the host; a virtual cpu is a thread in
that process. kill(1), nice(1), top(1) work as expected. In effect, the
driver adds a third execution mode to the existing two: we now have kernel
mode, user mode, and guest mode. Guest mode has its own address space mapping
guest physical memory (which is accessible to user mode by mmap()ing
/dev/kvm). Guest mode has no access to any I/O devices; any such access is
intercepted and directed to user mode for emulation.
The driver supports i386 and x86_64 hosts and guests. All combinations are
allowed except x86_64 guest on i386 host. For i386 guests and hosts, both pae
and non-pae paging modes are supported.
SMP hosts and UP guests are supported. At the moment only Intel
hardware is supported, but AMD virtualization support is being worked on.
Performance currently is non-stellar due to the naive implementation of the
mmu virtualization, which throws away most of the shadow page table entries
every context switch. We plan to address this in two ways:
- cache shadow page tables across tlb flushes
- wait until AMD and Intel release processors with nested page tables
Currently a virtual desktop is responsive but consumes a lot of CPU. Under
Windows I tried playing pinball and watching a few flash movies; with a recent
CPU one can hardly feel the virtualization. Linux/X is slower, probably due
to X being in a separate process.
In addition to the driver, you need a slightly modified qemu to provide I/O
device emulation and the BIOS.
Caveats (akpm: might no longer be true):
- The Windows install currently bluescreens due to a problem with the
virtual APIC. We are working on a fix. A temporary workaround is to
use an existing image or install through qemu
- Windows 64-bit does not work. That's also true for qemu, so it's
probably a problem with the device model.
[bero@arklinux.org: build fix]
[simon.kagstrom@bth.se: build fix, other fixes]
[uril@qumranet.com: KVM: Expose interrupt bitmap]
[akpm@osdl.org: i386 build fix]
[mingo@elte.hu: i386 fixes]
[rdreier@cisco.com: add log levels to all printks]
[randy.dunlap@oracle.com: Fix sparse NULL and C99 struct init warnings]
[anthony@codemonkey.ws: KVM: AMD SVM: 32-bit host support]
Signed-off-by: Yaniv Kamay <yaniv@qumranet.com>
Cc: Simon Kagstrom <simon.kagstrom@bth.se>
Cc: Bernhard Rosenkraenzer <bero@arklinux.org>
Signed-off-by: Uri Lublin <uril@qumranet.com>
Cc: Roland Dreier <rolandd@cisco.com>
Signed-off-by: Anthony Liguori <anthony@codemonkey.ws>
This modifies Makefiles and Kconfigs to properly reflect the creation of
generic HID layer.
It also removes the dependency of BROKEN, which was introduced by the
first patch in series (see the comment). Also updates credits.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
The SGI PCI-RT card, based on the SGI IOC4 chip, will be made available on
Altix XE (x86_64) platforms in the near future. As such it is now a
misnomer for the IOC4 base device driver to live under drivers/sn, and
would complicate builds for non-SN2.
This patch moves the IOC4 base driver code from drivers/sn to drivers/misc,
and updates the associated Makefiles and Kconfig files to allow building on
non-SN2 configs. Due to the resulting change in link order, it is now
necessary to use late_initcall() for IOC4 subdriver initialization.
[akpm@osdl.org: __udivdi3 fix]
[akpm@osdl.org: fix default in Kconfig]
Acked-by: Pat Gefre <pfg@sgi.com>
Acked-by: Jeremy Higdon <jeremy@sgi.com>
Signed-off-by: Brent Casavant <bcasavan@sgi.com>
