path: root/drivers/Kconfig
2011-10-26Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1519 commits) staging: et131x: Remove redundant check and return statement staging: et131x: Mainly whitespace changes to appease checkpatch staging: et131x: Remove last of the forward declarations staging: et131x: Remove even more forward declarations staging: et131x: Remove yet more forward declarations staging: et131x: Remove more forward declarations staging: et131x: Remove forward declaration of et131x_adapter_setup staging: et131x: Remove some forward declarations staging: et131x: Remove unused rx_ring.recv_packet_pool staging: et131x: Remove call to find pci pm capability staging: et131x: Remove redundant et131x_reset_recv() call staging: et131x: Remove unused rx_ring.recv_buffer_pool Staging: bcm: Fix three initialization errors in InterfaceDld.c Staging: bcm: Fix coding style issues in InterfaceDld.c staging:iio:dac: Add AD5360 driver staging:iio:trigger:bfin-timer: Fix compile error Staging: vt6655: add some range checks before memcpy() Staging: vt6655: whitespace fixes to iotcl.c Staging: vt6656: add some range checks before memcpy() Staging: vt6656: whitespace cleanups in ioctl.c ... Fix up conflicts in: - drivers/{Kconfig,Makefile}, drivers/staging/{Kconfig,Makefile}: vg driver movement - drivers/staging/brcm80211/brcmfmac/{dhd_linux.c,mac80211_if.c}: driver removal vs now stale changes - drivers/staging/rtl8192e/r8192E_core.c: driver removal vs now stale changes - drivers/staging/et131x/et131*: driver consolidation into one file, tried to do fixups
2011-10-25Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (63 commits) PM / Clocks: Remove redundant NULL checks before kfree() PM / Documentation: Update docs about suspend and CPU hotplug ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist. ARM: mach-shmobile: sh7372 A4R support (v4) ARM: mach-shmobile: sh7372 A3SP support (v4) PM / Sleep: Mark devices involved in wakeup signaling during suspend PM / Hibernate: Improve performance of LZO/plain hibernation, checksum image PM / Hibernate: Do not initialize static and extern variables to 0 PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too PM / Hibernate: Add resumedelay kernel param in addition to resumewait MAINTAINERS: Update linux-pm list address PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvs PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvs PM / Hibernate: Add resumewait param to support MMC-like devices as resume file PM / Hibernate: Fix typo in a kerneldoc comment PM / Hibernate: Freeze kernel threads after preallocating memory PM: Update the policy on default wakeup settings PM / VT: Cleanup #if defined uglyness and fix compile error PM / Suspend: Off by one in pm_suspend() PM / Hibernate: Include storage keys in hibernation image on s390 ...
2011-10-13drivers: create a pin control subsystemLinus Walleij
This creates a subsystem for handling of pin control devices. These are devices that control different aspects of package pins. Currently it handles pinmuxing, i.e. assigning electronic functions to groups of pins on primarily PGA and BGA type of chip packages which are common in embedded systems. The plan is to also handle other I/O pin control aspects such as biasing, driving, input properties such as schmitt-triggering, load capacitance etc within this subsystem, to remove a lot of ARM arch code as well as feature-creepy GPIO drivers which are implementing the same thing over and over again. This is being done to depopulate the arch/arm/* directory of such custom drivers and try to abstract the infrastructure they all need. See the Documentation/pinctrl.txt file that is part of this patch for more details. ChangeLog v1->v2: - Various minor fixes from Joe's and Stephens review comments - Added a pinmux_config() that can invoke custom configuration with arbitrary data passed in or out to/from the pinmux driver ChangeLog v2->v3: - Renamed subsystem folder to "pinctrl" since we will likely want to keep other pin control such as biasing in this subsystem too, so let us keep to something generic even though we're mainly doing pinmux now. - As a consequence, register pins as an abstract entity separate from the pinmux. The muxing functions will claim pins out of the pin pool and make sure they do not collide. Pins can now be named by the pinctrl core. - Converted the pin lookup from a static array into a radix tree, I agreed with Grant Likely to try to avoid any static allocation (which is crap for device tree stuff) so I just rewrote this to be dynamic, just like irq number descriptors. The platform-wide definition of number of pins goes away - this is now just the sum total of the pins registered to the subsystem. - Make sure mappings with only a function name and no device works properly. ChangeLog v3->v4: - Define a number space per controller instead of globally, Stephen and Grant requested the same thing so now maps need to define target controller, and the radix tree of pin descriptors is a property on each pin controller device. - Add a compulsory pinctrl device entry to the pinctrl mapping table. This must match the pinctrl device, like "pinctrl.0" - Split the file core.c in two: core.c and pinmux.c where the latter carry all pinmux stuff, the core is for generic pin control, and use local headers to access functionality between files. It is now possible to implement a "blank" pin controller without pinmux capabilities. This split will make new additions like pindrive.c, pinbias.c etc possible for combined drivers and chunks of functionality which is a GoodThing(TM). - Rewrite the interaction with the GPIO subsystem - the pin controller descriptor now handles this by defining an offset into the GPIO numberspace for its handled pin range. This is used to look up the apropriate pin controller for a GPIO pin. Then that specific GPIO range is matched 1-1 for the target controller instance. - Fixed a number of review comments from Joe Perches. - Broke out a header file pinctrl.h for the core pin handling stuff that will be reused by other stuff than pinmux. - Fixed some erroneous EXPORT() stuff. - Remove mispatched U300 Kconfig and Makefile entries - Fixed a number of review comments from Stephen Warren, not all of them - still WIP. But I think the new mapping that will specify which function goes to which pin mux controller address 50% of your concerns (else beat me up). ChangeLog v4->v5: - Defined a "position" for each function, so the pin controller now tracks a function in a certain position, and the pinmux maps define what position you want the function in. (Feedback from Stephen Warren and Sascha Hauer). - Since we now need to request a combined function+position from the machine mapping table that connect mux settings to drivers, it was extended with a position field and a name field. The name field is now used if you e.g. need to switch between two mux map settings at runtime. - Switched from a class device to using struct bus_type for this subsystem. Verified sysfs functionality: seems to work fine. (Feedback from Arnd Bergmann and Greg Kroah-Hartman) - Define a per pincontroller list of GPIO ranges from the GPIO pin space that can be handled by the pin controller. These can be added one by one at runtime. (Feedback from Barry Song) - Expanded documentation of regulator_[get|enable|disable|put] semantics. - Fixed a number of review comments from Barry Song. (Thanks!) ChangeLog v5->v6: - Create an abstract pin group concept that can sort pins into named and enumerated groups no matter what the use of these groups may be, one possible usecase is a group of pins being muxed in or so. The intention is however to also use these groups for other pin control activities. - Make it compulsory for pinmux functions to associate with at least one group, so the abstract pin group concept is used to define the groups of pins affected by a pinmux function. The pinmux driver interface has been altered so as to enforce a function to list applicable groups per function. - Provide an optional .group entry in the pinmux machine map so the map can select beteween different available groups to be used with a certain function. - Consequent changes all over the place so that e.g. debugfs present reasonable information about the world. - Drop the per-pin mux (*config) function in the pinmux_ops struct - I was afraid that this would start to be used for things totally unrelated to muxing, we can introduce that to the generic struct pinctrl_ops if needed. I want to keep muxing orthogonal to other pin control subjects and not mix these things up. ChangeLog v6->v7: - Make it possible to have several map entries matching the same device, pin controller and function, but using a different group, and alter the semantics so that pinmux_get() will pick all matching map entries, and store the associated groups in a list. The list will then be iterated over at pinmux_enable()/pinmux_disable() and corresponding driver functions called for each defined group. Notice that you're only allowed to map multiple *groups* to the same { device, pin controller, function } triplet, attempts to map the same device to multiple pin controllers will for example fail. This is hopefully the crucial feature requested by Stephen Warren. - Add a pinmux hogging field to the pinmux mapping entries, and enable the pinmux core to hog pinmux map entries. This currently only works for pinmuxes without assigned devices as it looks now, but with device trees we can look up the corresponding struct device * entries when we register the pinmux driver, and have it hog each pinmux map in turn, for a simple approach to non-dynamic pin muxing. This addresses an issue from Grant Likely that the machine should take care of as much of the pinmux setup as possible, not the devices. By supplying a list of hogs, it can now instruct the core to take care of any static mappings. - Switch pinmux group retrieveal function to grab an array of strings representing the groups rather than an array of unsigned and rewrite accordingly. - Alter debugfs to show the grouplist handled by each pinmux. Also add a list of hogs. - Dynamically allocate a struct pinmux at pinmux_get() and free it at pinmux_put(), then add these to the global list of pinmuxes active as we go along. - Go over the list of pinmux maps at pinmux_get() time and repeatedly apply matches. - Retrieve applicable groups per function from the driver as a string array rather than a unsigned array, then lookup the enumerators. - Make the device to pinmux map a singleton - only allow the mapping table to be registered once and even tag the registration function with __init so it surely won't be abused. - Create a separate debugfs file to view the pinmux map at runtime. - Introduce a spin lock to the pin descriptor struct, lock it when modifying pin status entries. Reported by Stijn Devriendt. - Fix up the documentation after review from Stephen Warren. - Let the GPIO ranges give names as const char * instead of some fixed-length string. - add a function to unregister GPIO ranges to mirror the registration function. - Privatized the struct pinctrl_device and removed it from the <linux/pinctrl/pinctrl.h> API, the drivers do not need to know the members of this struct. It is now in the local header "core.h". - Rename the concept of "anonymous" mux maps to "system" muxes and add convenience macros and documentation. ChangeLog v7->v8: - Delete the leftover pinmux_config() function from the <linux/pinctrl/pinmux.h> header. - Fix a race condition found by Stijn Devriendt in pin_request() ChangeLog v8->v9: - Drop the bus_type and the sysfs attributes and all, we're not on the clear about how this should be used for e.g. userspace interfaces so let us save this for the future. - Use the right name in MAINTAINERS, PIN CONTROL rather than PINMUX - Don't kfree() the device state holder, let the .remove() callback handle this. - Fix up numerous kerneldoc headers to have one line for the function description and more verbose documentation below the parameters ChangeLog v9->v10: - pinctrl: EXPORT_SYMBOL needs export.h, folded in a patch from Steven Rothwell - fix pinctrl_register error handling, folded in a patch from Axel Lin - Various fixes to documentation text so that it's consistent. - Removed pointless comment from drivers/Kconfig - Removed dependency on SYSFS since we removed the bus in v9. - Renamed hopelessly abbreviated pctldev_* functions to the more verbose pinctrl_dev_* - Drop mutex properly when looking up GPIO ranges - Return NULL instead of ERR_PTR() errors on registration of pin controllers, using cast pointers is fragile. We can live without the detailed error codes for sure. Cc: Stijn Devriendt <highguy@gmail.com> Cc: Joe Perches <joe@perches.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Barry Song <21cnbao@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-10-10Staging: hv: move hyperv code out of staging directoryGreg Kroah-Hartman
After many years wandering the desert, it is finally time for the Microsoft HyperV code to move out of the staging directory. Or at least the core hyperv bus code, and the utility driver, the rest still have some review to get through by the various subsystem maintainers. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
2011-10-02PM: Introduce devfreq: generic DVFS framework with device-specific OPPsMyungJoo Ham
With OPPs, a device may have multiple operable frequency and voltage sets. However, there can be multiple possible operable sets and a system will need to choose one from them. In order to reduce the power consumption (by reducing frequency and voltage) without affecting the performance too much, a Dynamic Voltage and Frequency Scaling (DVFS) scheme may be used. This patch introduces the DVFS capability to non-CPU devices with OPPs. DVFS is a techique whereby the frequency and supplied voltage of a device is adjusted on-the-fly. DVFS usually sets the frequency as low as possible with given conditions (such as QoS assurance) and adjusts voltage according to the chosen frequency in order to reduce power consumption and heat dissipation. The generic DVFS for devices, devfreq, may appear quite similar with /drivers/cpufreq. However, cpufreq does not allow to have multiple devices registered and is not suitable to have multiple heterogenous devices with different (but simple) governors. Normally, DVFS mechanism controls frequency based on the demand for the device, and then, chooses voltage based on the chosen frequency. devfreq also controls the frequency based on the governor's frequency recommendation and let OPP pick up the pair of frequency and voltage based on the recommended frequency. Then, the chosen OPP is passed to device driver's "target" callback. When PM QoS is going to be used with the devfreq device, the device driver should enable OPPs that are appropriate with the current PM QoS requests. In order to do so, the device driver may call opp_enable and opp_disable at the notifier callback of PM QoS so that PM QoS's update_target() call enables the appropriate OPPs. Note that at least one of OPPs should be enabled at any time; be careful when there is a transition. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mike Turquette <mturquette@ti.com> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-23virtio: expose for non-virtualization users tooOhad Ben-Cohen
virtio has been so far used only in the context of virtualization, and the virtio Kconfig was sourced directly by the relevant arch Kconfigs when VIRTUALIZATION was selected. Now that we start using virtio for inter-processor communications, we need to source the virtio Kconfig outside of the virtualization scope too. Moreover, some architectures might use virtio for both virtualization and inter-processor communications, so directly sourcing virtio might yield unexpected results due to conflicting selections. The simple solution offered by this patch is to always source virtio's Kconfig in drivers/Kconfig, and remove it from the appropriate arch Kconfigs. Additionally, a virtio menu entry has been added so virtio drivers don't show up in the general drivers menu. This way anyone can use virtio, though it's arguably less accessible (and neat!) for virtualization users now. Note: some architectures (mips and sh) seem to have a VIRTUALIZATION menu merely for sourcing virtio's Kconfig, so that menu is removed too. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22Merge branch 'core-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: iommu/core: Fix build with INTR_REMAP=y && CONFIG_DMAR=n iommu/amd: Don't use MSI address range for DMA addresses iommu/amd: Move missing parts to drivers/iommu iommu: Move iommu Kconfig entries to submenu x86/ia64: intel-iommu: move to drivers/iommu/ x86: amd_iommu: move to drivers/iommu/ msm: iommu: move to drivers/iommu/ drivers: iommu: move to a dedicated folder x86/amd-iommu: Store device alias as dev_data pointer x86/amd-iommu: Search for existind dev_data before allocting a new one x86/amd-iommu: Allow dev_data->alias to be NULL x86/amd-iommu: Use only dev_data in low-level domain attach/detach functions x86/amd-iommu: Use only dev_data for dte and iotlb flushing routines x86/amd-iommu: Store ATS state in dev_data x86/amd-iommu: Store devid in dev_data x86/amd-iommu: Introduce global dev_data_list x86/amd-iommu: Remove redundant device_flush_dte() calls iommu-api: Add missing header file Fix up trivial conflicts (independent additions close to each other) in drivers/Makefile and include/linux/pci.h
2011-07-08Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-07-08drivers/virt: introduce Freescale hypervisor management driverTimur Tabi
Add the drivers/virt directory, which houses drivers that support virtualization environments, and add the Freescale hypervisor management driver. The Freescale hypervisor management driver provides several services to drivers and applications related to the Freescale hypervisor: 1. An ioctl interface for querying and managing partitions 2. A file interface to reading incoming doorbells 3. An interrupt handler for shutting down the partition upon receiving the shutdown doorbell from a manager partition 4. A kernel interface for receiving callbacks when a managed partition shuts down. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-05NFC: add nfc subsystem coreLauro Ramos Venancio
The NFC subsystem core is responsible for providing the device driver interface. It is also responsible for providing an interface to the control operations and data exchange. Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-14drivers: iommu: move to a dedicated folderOhad Ben-Cohen
Create a dedicated folder for iommu drivers, and move the base iommu implementation over there. Grouping the various iommu drivers in a single location will help finding similar problems shared by different platforms, so they could be solved once, in the iommu framework, instead of solved differently (or duplicated) in each driver. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-05-23ptp: Added a brand new class driver for ptp clocks.Richard Cochran
This patch adds an infrastructure for hardware clocks that implement IEEE 1588, the Precision Time Protocol (PTP). A class driver offers a registration method to particular hardware clock drivers. Each clock is presented as a standard POSIX clock. The ancillary clock features are exposed in two different ways, via the sysfs and by a character device. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-14clocksource: add common i8253 PIT clocksourceRussell King
This is based upon both arch/arm/mach-footbridge/isa-timer.c and arch/x86/kernel/i8253.c. Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-10bcma: add Broadcom specific AMBA bus driverRafał Miłecki
Broadcom has released cards based on a new AMBA-based bus type. From a programming point of view, this new bus type differs from AMBA and does not use AMBA common registers. It also differs enough from SSB. We decided that a new bus driver is needed to keep the code clean. In its current form, the driver detects devices present on the bus and registers them in the system. It allows registering BCMA drivers for specified bus devices and provides them basic operations. The bus driver itself includes two important bus managing drivers: ChipCommon core driver and PCI(c) core driver. They are early used to allow correct initialization. Currently code is limited to supporting buses on PCI(e) devices, however the driver is designed to be used also on other hosts. The host abstraction layer is implemented and already used for PCI(e). Support for PCI(e) hosts is working and seems to be stable (access to 80211 core was tested successfully on a few devices). We can still optimize it by using some fixed windows, but this can be done later without affecting any external code. Windows are just ranges in MMIO used for accessing cores on the bus. Cc: Greg KH <greg@kroah.com> Cc: Michael Büsch <mb@bu3sch.de> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: George Kashperko <george@znau.edu.ua> Cc: Arend van Spriel <arend@broadcom.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andy Botting <andy@andybotting.com> Cc: linuxdriverproject <devel@linuxdriverproject.org> Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-17drivers: hwspinlock: add frameworkOhad Ben-Cohen
Add a platform-independent hwspinlock framework. Hardware spinlock devices are needed, e.g., in order to access data that is shared between remote processors, that otherwise have no alternative mechanism to accomplish synchronization and mutual exclusion operations. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Cc: Hari Kanigeri <h-kanigeri2@ti.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@ti.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Walmsley <paul@pwsan.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-13NFC: Driver for NXP Semiconductors PN544 NFC chip.Matti J. Aaltonen
Creates a new "Near Field Communication" subsystem in drivers/nfc. http://en.wikipedia.org/wiki/Near_Field_Communication is useful ;) This is a driver for the pn544 NFC device. The driver transfers ETSI messages between the device and the user space. Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-06MFGPT: move clocksource menuRandy Dunlap
Move the CS5535 MFGPT hrtimer kconfig option to be with the other MFGPT options. This makes it easier to find and also removes it from the main "Device Drivers" menu, where it should not have been. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Andres Salomon <dilinger@collabora.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-29firewire, ieee1394: update Kconfig helpStefan Richter
Update the Kconfig help texts of both stacks to encourage a general move from the older to the newer drivers. However, do not label ieee1394 as "Obsolete" yet, as the newer drivers have not been deployed as default stack in the majority of Linux distributions yet, and those who start doing so now may still want to install the old drivers as fallback for unforeseen issues. Since Linux 2.6.32, FireWire audio devices can be driven by the newer firewire driver stack too, hence remove an outdated comment about audio devices. Also remove comments about library versions since the 2nd generation of libraw1394 and libdc1394 is now in common use; details on library versions can be read at the wiki link from the help texts. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-12-15cs5535: add a generic clock event MFGPT driverAndres Salomon
This is based on the old code in arch/x86/kernel/mfgpt_32.c, but is modular and not Geode-specific. There's no reason why the clock event device needs to be registered so early at boot; the clockevent code is perfectly capable of dynamic switching. [akpm@linux-foundation.org: add linux/irq.h include] Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-09Kconfig: Remove useless and sometimes wrong commentsMichael Roth
Additionally, some excessive newlines removed. Signed-off-by: Michael Roth <mroth@nessie.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-18LinuxPPS: core supportRodolfo Giometti
This patch adds the kernel side of the PPS support currently named "LinuxPPS". PPS means "pulse per second" and a PPS source is just a device which provides a high precision signal each second so that an application can use it to adjust system clock time. Common use is the combination of the NTPD as userland program with a GPS receiver as PPS source to obtain a wallclock-time with sub-millisecond synchronisation to UTC. To obtain this goal the userland programs shoud use the PPS API specification (RFC 2783 - Pulse-Per-Second API for UNIX-like Operating Systems, Version 1.0) which in part is implemented by this patch. It provides a set of chars devices, one per PPS source, which can be used to get the time signal. The RFC's functions can be implemented by accessing to these char devices. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16drivers: add support for the TI VLYNQ busFlorian Fainelli
Add support for the TI VLYNQ high-speed, serial and packetized bus. This bus allows external devices to be connected to the System-on-Chip and appear in the main system memory just like any memory mapped peripheral. It is widely used in TI's networking and multimedia SoC, including the AR7 SoC. Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru> Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-19create drivers/platform/x86/ from drivers/misc/Len Brown
Move x86 platform specific drivers from drivers/misc/ to a new home under drivers/platform/x86/. The community has been maintaining x86 vendor-specific platform specific drivers under /drivers/misc/ for a few years. The oldest ones started life under drivers/acpi. They moved out of drivers/acpi/ because they don't actually implement the ACPI specification, but either simply use ACPI, or implement vendor-specific ACPI extensions. In the future we anticipate... drivers/misc/ will go away. other architectures will create drivers/platform/<arch> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-28regulator: Build on non-ARM platformsMark Brown
When the regulator API was merged it was added to the separate Kconfig which ARM uses for drivers but not the generic one in drivers/. Since there is nothing ARM-specific about the API add it there too. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-10-20Merge branch 'master' into for-upstreamDavid Vrabel
Conflicts: Documentation/ABI/testing/sysfs-bus-usb drivers/Makefile
2008-10-10Staging: add Kconfig entries and Makefile infrastructureGreg Kroah-Hartman
This hooks up the drivers/staging directory to the build system Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-17uwb: add the UWB stack (build system)Greg Kroah-Hartman
The Kbuild and Kconfig files. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-04-30Basic braille screen reader supportSamuel Thibault
This adds a minimalistic braille screen reader support. This is meant to be used by blind people e.g. on boot failures or when / cannot be mounted etc and thus the userland screen readers can not work. [akpm@linux-foundation.org: fix exports] Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Jiri Kosina <jikos@jikos.cz> Cc: Dmitry Torokhov <dtor@mail.ru> Acked-by: Alan Cox <alan@redhat.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24xen: add balloon driverJeremy Fitzhardinge
The balloon driver allows memory to be dynamically added or removed from the domain, in order to allow host memory to be balanced between multiple domains. This patch introduces the Xen balloon driver, though it currently only allows a domain to be shrunk from its initial size (and re-grown back to that size). A later patch will add the ability to grow a domain beyond its initial size. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-09memstick: initial commit for Sony MemoryStick supportAlex Dubov
Sony MemoryStick cards are used in many products manufactured by Sony. They are available both as storage and as IO expansion cards. Currently, only MemoryStick Pro storage cards are supported via TI FlashMedia MemoryStick interface. [mboton@gmail.com: biuld fix] [akpm@linux-foundation.org: build fix] Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Miguel Boton <mboton@gmail.co> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Merge branches 'release' and 'menlo' into releaseLen Brown
Conflicts: drivers/acpi/video.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-05gpiolib: add drivers/gpio directoryDavid Brownell
Add an empty drivers/gpio directory for gpiolib infrastructure and GPIO expanders. It will be populated by later patches. This won't be the only place to hold such gpio_chip code. Many external chips add a few GPIOs as secondary functionality (such as MFD drivers) and platform code frequently needs to closely integrate GPIO and IRQ support. This is placed *early* in the build/link sequence since it's common for other drivers to depend on GPIOs to do their work, so they must be initialized early in the device_initcall() sequence. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Eric Miao <eric.miao@marvell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04virtio: Put the virtio under the virtualization menuAnthony Liguori
This patch moves virtio under the virtualization menu and changes virtio devices to not claim to only be for lguest. Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-01the generic thermal sysfs driverZhang Rui
The Generic Thermal sysfs driver for thermal management. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-01-30KVM: Move arch dependent files to new directory arch/x86/kvm/Avi Kivity
This paves the way for multiple architecture support. Note that while ioapic.c could potentially be shared with ia64, it is also moved. Signed-off-by: Avi Kivity <avi@qumranet.com>
2007-10-23Virtio interfaceRusty Russell
This attempts to implement a "virtual I/O" layer which should allow common drivers to be efficiently used across most virtual I/O mechanisms. It will no-doubt need further enhancement. The virtio drivers add buffers to virtio queues; as the buffers are consumed the driver "interrupt" callbacks are invoked. There is also a generic implementation of config space which drivers can query to get setup information from the host. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dor Laor <dor.laor@qumranet.com> Cc: Arnd Bergmann <arnd@arndb.de>
2007-10-23Consolidate host virtualization support under Virtualization menuRusty Russell
Move lguest under the virtualization menu. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Avi Kivity <avi@qumranet.com>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-10-16DCA: Add Direct Cache Access driverShannon Nelson
Direct Cache Access (DCA) is a method for warming the CPU cache before data is used, with the intent of lessening the impact of cache misses. This patch adds a manager and interface for matching up client requests for DCA services with devices that offer DCA services. In order to use DCA, a module must do bus writes with the appropriate tag bits set to trigger a cache read for a specific CPU. However, different CPUs and chipsets can require different sets of tag bits, and the methods for determining the correct bits may be simple hardcoding or may be a hardware specific magic incantation. This interface is a way for DCA clients to find the correct tag bits for the targeted CPU without needing to know the specifics. [Dave Miller] use DEFINE_SPINLOCK() Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[SSB]: add Sonics Silicon Backplane bus supportMichael Buesch
SSB is an SoC bus used in a number of embedded devices. The most well-known of these devices is probably the Linksys WRT54G, but there are others as well. The bus is also used internally on the BCM43xx and BCM44xx devices from Broadcom. This patch also includes support for SSB ID tables in modules, so that SSB drivers can be loaded automatically. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-20Begin to consolidate of_device.cStephen Rothwell
This moves all the common parts for the Sparc, Sparc64 and PowerPC of_device.c files into drivers/of/device.c. Apart from the simple move, Sparc gains of_match_node() and a call to of_node_put in of_release_dev(). PowerPC gains better recovery if device_create_file() fails in of_device_register(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
2007-07-19lguest: the Makefile and KconfigRusty Russell
This is the Kconfig and Makefile to allow lguest to actually be compiled. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18UIO: Add the User IO core codeHans J. Koch
This interface allows the ability to write the majority of a driver in userspace with only a very small shell of a driver in the kernel itself. It uses a char device and sysfs to interact with a userspace process to process interrupts and control memory accesses. See the docbook documentation for more details on how to use this interface. From: Hans J. Koch <hjk@linutronix.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Benedikt Spranger <b.spranger@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-10Merge git://git.infradead.org/~dwmw2/battery-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/battery-2.6: [BATTERY] ds2760 W1 slave [BATTERY] One Laptop Per Child power/battery driver [BATTERY] Apple PMU driver [BATTERY] 1-Wire ds2760 chip battery driver [BATTERY] APM emulation driver for class batteries [BATTERY] pda_power platform driver [BATTERY] Universal power supply class (was: battery class)
2007-07-10[BATTERY] Universal power supply class (was: battery class)Anton Vorontsov
This class is result of "external power" and "battery" classes merge, as suggested by David Woodhouse. He also implemented uevent support. Here how userspace seeing it now: # ls /sys/class/power\ supply/ ac main-battery usb # cat /sys/class/power\ supply/ac/type AC # cat /sys/class/power\ supply/usb/type USB # cat /sys/class/power\ supply/main-battery/type Battery # cat /sys/class/power\ supply/ac/online 1 # cat /sys/class/power\ supply/usb/online 0 # cat /sys/class/power\ supply/main-battery/status Charging # cat /sys/class/leds/h5400\:red-left/trigger none h5400-radio timer hwtimer ac-online usb-online main-battery-charging-or-full [main-battery-charging] main-battery-full Signed-off-by: Anton Vorontsov <cbou@mail.ru> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-07-10Remove legacy CDROM driversJens Axboe
They are all broken beyond repair. Given that nobody has complained about them (most haven't worked in 2.6 AT ALL), remove them from the tree. A new mitsumi driver that actually works is in progress, it'll get added when completed. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
