path: root/drivers/Makefile
2006-12-04[POWERPC] ps3: Missed renames of CONFIG_PS3 to CONFIG_PPC_PS3Geert Uytterhoeven
When renaming CONFIG_PS3 to CONFIG_PPC_PS3, a few occurrences have been missed. I also fixed up the alignment in arch/powerpc/platforms/Makefile. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2006-12-04[POWERPC] ps3: add ps3 platform system bus supportGeoff Levand
Adds a PS3 system bus driver. This system bus is a virtual bus used to present the PS3 system devices in the LDM. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2006-08-10Move libata to drivers/ata.Jeff Garzik
2006-06-26[PATCH] Time: i386 Clocksource Driversjohn stultz
Implement the time sources for i386 (acpi_pm, cyclone, hpet, pit, and tsc). With this patch, the conversion of the i386 arch to the generic timekeeping code should be complete. The patch should be fairly straight forward, only adding the new clocksources. [hirofumi@mail.parknet.co.jp: acpi_pm cleanup] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[I/OAT]: DMA memcpy subsystemChris Leech
Provides an API for offloading memory copies to DMA devices Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-02Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IB/ipath: kbuild infrastructure IB/ipath: infiniband verbs support IB/ipath: misc infiniband code, part 2 IB/ipath: misc infiniband code, part 1 IB/ipath: infiniband RC protocol support IB/ipath: infiniband UC and UD protocol support IB/ipath: infiniband header files IB/ipath: layering interfaces used by higher-level driver code IB/ipath: support for userspace apps using core driver IB/ipath: sysfs and ipathfs support for core driver IB/ipath: misc driver support code IB/ipath: chip initialisation code, and diag support IB/ipath: support for PCI Express devices IB/ipath: support for HyperTransport devices IB/ipath: core driver header files IB/ipath: core device driver
2006-04-02Manual merge with Linus.Dmitry Torokhov
Conflicts: arch/powerpc/kernel/setup-common.c drivers/input/keyboard/hil_kbd.c drivers/input/mouse/hil_ptr.c
2006-03-31IB/ipath: kbuild infrastructureBryan O'Sullivan
Integrate the ipath core and OpenIB drivers into the kernel build infrastructure. Add entry to MAINTAINERS. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-31[PATCH] LED: add LED classRichard Purdie
Add the foundations of a new LEDs subsystem. This patch adds a class which presents LED devices within sysfs and allows their brightness to be controlled. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC Subsystem: library functionsAlessandro Zummo
RTC and date/time related functions. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-19Input: initialize serio and gameport at subsystem levelDmitry Torokhov
Serio and gameport cores do not depend on other drivers and are used by code living outside of drivers/input/{gameport|serio}. Registering them at subsystem level guarantees that they are fully initialized before anyone tries to use them. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-26[PATCH] drivers/sn/ must be entered for CONFIG_SGI_IOC3Jes Sorensen
Actually I think this is more appropriate so we don't end up with 17 cases that add drivers/sn to the build lib. Include drivers/sn when CONFIG_IA64_SGI_SN2 or CONFIG_IA64_GENERIC is enabled. Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-18[PATCH] EDAC: core EDAC support codeAlan Cox
This is a subset of the bluesmoke project core code, stripped of the NMI work which isn't ready to merge and some of the "interesting" proc functionality that needs reworking or just has no place in kernel. It requires no core kernel changes except the added scrub functions already posted. The goal is to merge further functionality only after the core code is accepted and proven in the base kernel, and only at the point the upstream extras are really ready to merge. From: doug thompson <norsk5@xmission.com> This converts EDAC to sysfs and is the final chunk neccessary before EDAC has a stable user space API and can be considered for submission into the base kernel. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: doug thompson <norsk5@xmission.com> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[PATCH] spi: simple SPI frameworkDavid Brownell
This is the core of a small SPI framework, implementing the model of a queue of messages which complete asynchronously (with thin synchronous wrappers on top). - It's still less than 2KB of ".text" (ARM). If there's got to be a mid-layer for something so simple, that's the right size budget. :) - The guts use board-specific SPI device tables to build the driver model tree. (Hardware probing is rarely an option.) - This version of Kconfig includes no drivers. At this writing there are two known master controller drivers (PXA/SSP, OMAP MicroWire) and three protocol drivers (CS8415a, ADS7846, DataFlash) with LKML mentions of other drivers in development. - No userspace API. There are several implementations to compare. Implement them like any other driver, and bind them with sysfs. The changes from last version posted to LKML (on 11-Nov-2005) are minor, and include: - One bugfix (removes a FIXME), with the visible effect of making device names be "spiB.C" where B is the bus number and C is the chipselect. - The "caller provides DMA mappings" mechanism now has kerneldoc, for DMA drivers that want to be fancy. - Hey, the framework init can be subsys_init. Even though board init logic fires earlier, at arch_init ... since the framework init is for driver support, and the board init support uses static init. - Various additional spec/doc clarifications based on discussions with other folk. It adds a brief "thank you" at the end, for folk who've helped nudge this framework into existence. As I've said before, I think that "protocol tweaking" is the main support that this driver framework will need to evolve. From: Mark Underwood <basicmark@yahoo.com> Update the SPI framework to remove a potential priority inversion case by reverting to kmalloc if the pre-allocated DMA-safe buffer isn't available. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-07[ARM] Move AMBA bus code to drivers/amba/Russell King
Make the AMBA bus code visible to other architectures. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-03Link USB drivers later in the kernelLinus Torvalds
We want to link the "regular" SCSI drivers before the USB storage driver, since historically we've always detected internal SCSI disks before the external USB storage modules. The link order matters for initcall ordering, and this got broken by mistake by commit 7586269c0b52970f60bb69fcb86e765fc1d72309 which moved the USB host controller PCI quirk handling around. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] RapidIO support: core baseMatt Porter
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect used in higher-end embedded applications. The curious can look at the specs over at http://www.rapidio.org The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. There's a lot more to do to take advantages of all the hardware features. However, this should provide a good base for folks with RIO hardware to start contributing. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] sh: Re-add sh to drivers/MakefilePaul Mundt
drivers/sh/ got dropped from drivers/Makefile, so add it back in.. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] USB: move handoff codeDavid Brownell
This moves the PCI quirk handling for USB host controllers from the PCI directory to the USB directory. Follow-on patches will need to: (a) merge these copies with the originals in the HCD reset methods. they don't wholly agree, despite doing the very same thing; and (b) eventually change it so "usb-handoff" is the default, to help get more robust USB/BIOS/input/... interactions. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/Makefile | 2 drivers/pci/quirks.c | 253 --------------------------------------- drivers/usb/Makefile | 1 drivers/usb/host/Makefile | 5 drivers/usb/host/pci-quirks.c | 272 ++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 280 insertions(+), 253 deletions(-)
2005-09-11[NET]: Add netlink connector.Evgeniy Polyakov
Kernel connector - new userspace <-> kernel space easy to use communication module which implements easy to use bidirectional message bus using netlink as it's backend. Connector was created to eliminate complex skb handling both in send and receive message bus direction. Connector driver adds possibility to connect various agents using as one of it's backends netlink based network. One must register callback and identifier. When driver receives special netlink message with appropriate identifier, appropriate callback will be called. From the userspace point of view it's quite straightforward: socket(); bind(); send(); recv(); But if kernelspace want to use full power of such connections, driver writer must create special sockets, must know about struct sk_buff handling... Connector allows any kernelspace agents to use netlink based networking for inter-process communication in a significantly easier way: int cn_add_callback(struct cb_id *id, char *name, void (*callback) (void *)); void cn_netlink_send(struct cn_msg *msg, u32 __groups, int gfp_mask); struct cb_id { __u32 idx; __u32 val; }; idx and val are unique identifiers which must be registered in connector.h for in-kernel usage. void (*callback) (void *) - is a callback function which will be called when message with above idx.val will be received by connector core. Using connector completely hides low-level transport layer from it's users. Connector uses new netlink ability to have many groups in one socket. [ Incorporating many cleanups and fixes by myself and Andrew Morton -DaveM ] Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29Auto-update from upstreamLen Brown
2005-08-24[ACPI] delete CONFIG_ACPI_BOOTLen Brown
it has been a synonym for CONFIG_ACPI since 2.6.12 Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-18[MFD] Add multimedia communication port core supportRussell King
Add support for the core of the multimedia communication port framework. This is a port used to communicate with devices with two DMA paths and a control path. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-11[PATCH] I2C: Move hwmon drivers (1/3)Jean Delvare
Part 1: Configuration files and Makefiles. From: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] ioc4: CONFIG splitBrent Casavant
The SGI IOC4 I/O controller chip drivers are currently all configured by CONFIG_BLK_DEV_SGIIOC4. This is undesirable as not all IOC4 hardware features are needed by all systems. This patch adds two configuration variables, CONFIG_SGI_IOC4 for core IOC4 driver support (see patch 1/3 in this series for further explanation) and CONFIG_SERIAL_SGI_IOC4 to independently enable serial port support. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Acked-by: Pat Gefre <pfg@sgi.com> Acked-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
