path: root/drivers/acpi/acpica/tbfadt.c
2009-09-20x86: Trivial whitespace cleanupsFelipe Contreras
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Vegard Nossum <vegardno@ifi.uio.no> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alok N Kataria <akataria@vmware.com> Cc: "Tan Wei Chong" <wei.chong.tan@intel.com> Cc: Len Brown <len.brown@intel.com> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Bob Moore <robert.moore@intel.com> LKML-Reference: <1253137123-18047-2-git-send-email-felipe.contreras@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-27ACPICA: Miscellaneous lint changesBob Moore
Unused variables/headers, casting, etc. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-05-27ACPICA: Fix printf format warnings for 64-bit buildBob Moore
Fix warnings caused by size_t and ACPI_SIZE changing to 64 bits. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPICA: FADT: Favor 32-bit FACS and DSDT addressesBob Moore
If both the 32-bit and 64-bit addresses are non-null, use the 32-bit address. Provides Windows compatibility. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPICA: FADT: Favor 32-bit register addresses for compatibilityBob Moore
Use the 32-bit register addresses whenever they are non-zero. This means that the 32-bit addresses are favored over the 64-bit (GAS) addresses. The 64-bit addresses are only used if the 32-bit addresses are zero. This change provides compatibility with all versions of Windows. The worst case that this solves is when both the 32-bit and 64-bit addresses are non-zero, but only the 32-bit addresses are actually valid. This appears to happen in some BIOSes because in this case, Windows uses the 32-bit addresses. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPICA: FADT: Fix extraneous length mismatch warningBob Moore
Incorrect register length mismatch between the 32 and 64 bit registers in some cases. Code was was checking the wrong pointer for non-zero, should be looking at the address within the GAS structure. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Formatting update - no functional changesBob Moore
Split some long lines. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Check for non-zero address before being converted to GASLin Ming
Reported-by: FreeBSD community Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Split out PM1 status registers from the FADTBob Moore
Add new globals for the PM1 status registers (A/B), similar to the way the PM1 enable registers are handled. Instead of overloading the FADT Event Register blocks. This makes the code clearer and less prone to error. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Remove extraneous parameter in table managerBob Moore
Removed the Flags parameter from several internal functions since it was not being used. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09ACPICA: hide private headersLen Brown
2009-01-09ACPICA: create acpica/ directoryLen Brown
also, delete sleep/ and delete ACPI_CFLAGS from Makefile Signed-off-by: Len Brown <len.brown@intel.com>
