path: root/drivers/acpi/bay.c
2008-06-11bay: exit if notify handler cannot be installedHolger Macht
If acpi_install_notify_handler() for a bay device fails, the bay driver is superfluous. Most likely, another driver (like libata) is already caring about this device anyway. Furthermore, register_hotplug_dock_device(acpi_handle) from the dock driver must not be called twice with the same handler. This would result in an endless loop consuming 100% of CPU. So clean up and exit. Signed-off-by: Holger Macht <hmacht@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29#if 0 acpi/bay.c:eject_removable_drive()Adrian Bunk
This patch #if 0's the unused eject_removable_drive(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07Merge branches 'release' and 'fluff' into releaseLen Brown
Conflicts: drivers/acpi/scan.c include/linux/acpi.h Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: misc cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - drivers/acpi/bay.c:dev_attr_eject - drivers/acpi/bay.c:dev_attr_present - drivers/acpi/dock.c:dev_attr_docked - drivers/acpi/dock.c:dev_attr_flags - drivers/acpi/dock.c:dev_attr_uid - drivers/acpi/dock.c:dev_attr_undock - drivers/acpi/pci_bind.c:acpi_pci_unbind() - drivers/acpi/pci_link.c:acpi_link_lock - drivers/acpi/sbs.c:acpi_sbs_callback() - drivers/acpi/sbshc.c:acpi_smbus_transaction() - drivers/acpi/sleep/main.c:acpi_sleep_prepare() - #if 0 the following unused global functions: - drivers/acpi/numa.c:acpi_unmap_pxm_to_node() - remove the following unused EXPORT_SYMBOL's: - acpi_register_gsi - acpi_unregister_gsi - acpi_strict - acpi_bus_receive_event - register_acpi_bus_type - unregister_acpi_bus_type - acpi_os_printf - acpi_os_sleep - acpi_os_stall - acpi_os_read_pci_configuration - acpi_os_create_semaphore - acpi_os_delete_semaphore - acpi_os_wait_semaphore - acpi_os_signal_semaphore - acpi_os_signal - acpi_pci_irq_enable - acpi_get_pxm Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-12-08ACPI: Also autoload the bay driver, was forgotten...Thomas Renninger
Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-08-11ACPI: bay: send envp with uevent - fixStephan Berberig
There must not be a new-line character in the uevent. Otherwise, udev gets confused. Thanks to Kay Sievers for pointing it out. Signed-off-by: Stephan Berberig <s.berberig@arcor.de> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-06-02ACPI: bay: send envp with ueventKristen Carlson Accardi
Make the bay driver send env information on bay events. Upon any bay event, we will send the string "BAY_EVENT=%d" along with the KOBJ_CHANGE, and report the event number. What the event number means will be platform specific. Event 3 is always an eject request, but an insert may be either event 1, or it may be event 0. Event 1 may also be a remove request. It would be best if you check the number of your event with udevmonitor before writing any udev scripts for inserting and removing drive bays. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Stephan Berberig <s.berberig@arcor.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-10ACPI: bay: unsuppress ueventsKristen Carlson Accardi
Since platform devices seem to get uevents suppressed by default, manually unsuppress for the bay device since we want to be able to send uevents. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16Pull fluff into release branchLen Brown
Conflicts: arch/x86_64/pci/mmconfig.c drivers/acpi/bay.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16ACPI: bay: use IS_ERR for return of register_platform_device_simpleHenrique de Moraes Holschuh
register_platform_device_simple returns ERR_PTR(foo), so test it with IS_ERR(foo). Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: delete extra #defines in /drivers/acpi/ driversLen Brown
Cosmetic only. Except in a single case, #define ACPI_*_DRIVER_NAME were invoked 0 or 1 times. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: fix acpi_driver.name usageLen Brown
It was erroneously used as a description rather than a name. ie. turn this: lenb@se7525gp2:/sys> ls bus/acpi/drivers ACPI AC Adapter Driver ACPI Embedded Controller Driver ACPI Power Resource Driver ACPI Battery Driver ACPI Fan Driver ACPI Processor Driver ACPI Button Driver ACPI PCI Interrupt Link Driver ACPI Thermal Zone Driver ACPI container driver ACPI PCI Root Bridge Driver hpet into this: lenb@se7525gp2:~> ls /sys/bus/acpi/drivers ac battery button container ec fan hpet pci_link pci_root power processor thermal Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: clean up ACPI_MODULE_NAME() useLen Brown
cosmetic only Make "module name" actually match the file name. Invoke with ';' as leaving it off confuses Lindent and gcc doesn't care. Fix indentation where Lindent did get confused. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-09ACPI: bay: fix wrong order of kzalloc argumentsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-09[PATCH] wrong order of kzalloc argumentsAl Viro
2007-02-09ACPI: bay: remove ACPI driver structKristen Carlson Accardi
The bay driver is a platform driver, and doesn't need to also be an acpi driver. Remove the acpi driver related structures and callbacks, they didn't do anything anyway. Switch to uevent for user space event notification. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03ACPI: bay: Convert ACPI Bay driver to be compatible with sysfs update.Zhang Rui
Set fake hid for ejectable drive bay. Match bay devices by checking the hid. Remove .match method of Bay driver. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03ACPI: bay: make drive_bays staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03ACPI: bay: make bay a platform driverKristen Carlson Accardi
Convert the bay driver to be a platform driver, so that we can have sysfs entries. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03ACPI: bay: remove prototype procfs codeKristen Carlson Accardi
Remove all the procfs related code. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03ACPI: bay: delete unused variableLen Brown
drivers/acpi/bay.c: In function ‘bay_notify’: drivers/acpi/bay.c:491: warning: unused variable ‘bay’ Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03ACPI: bay: new driver adding removable drive bay supportKristen Carlson Accardi
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
