path: root/drivers/acpi/button.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22ACPI / PM: Add more run-time wake-up fieldsRafael J. Wysocki
Use the run_wake flag to mark all devices for which run-time wake-up events may be generated by the platform. Introduce a new wake-up flag, always_enabled, for marking devices that should be permanently enabled to generate run-time events. Also, introduce a reference counter for run-wake devices and a function that will initialize all of the run-time wake-up fields for given device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22ACPI: Use GPE reference counting to support shared GPEsRafael J. Wysocki
ACPI GPEs may map to multiple devices. The current GPE interface only provides a mechanism for enabling and disabling GPEs, making it difficult to change the state of GPEs at runtime without extensive cooperation between devices. Add an API to allow devices to indicate whether or not they want their device's GPE to be enabled for both runtime and wakeup events. Remove the old GPE type handling entirely, which gets rid of various quirks, like the implicit disabling with GPE type setting. This requires a small amount of rework in order to ensure that non-wake GPEs are enabled by default to preserve existing behaviour. Based on patches from Matthew Garrett <mjg@redhat.com>. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-12-16ACPI: Use the return result of ACPI lid notifier chain correctlyZhao Yakui
On some laptops it will return NOTIFY_OK(non-zero) when calling the ACPI LID notifier. Then it is used as the result of ACPI LID resume function, which will complain the following warning message in course of suspend/resume: >PM: Device PNP0C0D:00 failed to resume: error 1 This patch is to eliminate the above warning message. http://bugzilla.kernel.org/show_bug.cgi?id=14782 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-13ACPI button: don't try to use a non-existent lid deviceJesse Barnes
If a call comes in to check the lid state but there's no lid device present, we should return -ENODEV. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-24Merge branch 'drm-intel-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: (57 commits) drm/i915: Handle ERESTARTSYS during page fault drm/i915: Warn before mmaping a purgeable buffer. drm/i915: Track purged state. drm/i915: Remove eviction debug spam drm/i915: Immediately discard any backing storage for uneeded objects drm/i915: Do not mis-classify clean objects as purgeable drm/i915: Whitespace correction for madv drm/i915: BUG_ON page refleak during unbind drm/i915: Search harder for a reusable object drm/i915: Clean up evict from list. drm/i915: Add tracepoints drm/i915: framebuffer compression for GM45+ drm/i915: split display functions by chip type drm/i915: Skip the sanity checks if the current relocation is valid drm/i915: Check that the relocation points to within the target drm/i915: correct FBC update when pipe base update occurs drm/i915: blacklist Acer AspireOne lid status ACPI: make ACPI button funcs no-ops if not built in drm/i915: prevent FIFO calculation overflows on 32 bits with high dotclocks drm/i915: intel_display.c handle latency variable efficiently ... Fix up trivial conflicts in drivers/gpu/drm/i915/{i915_dma.c|i915_drv.h}
2009-09-10ACPI button: provide lid status functionsJesse Barnes
Some drivers need to know when a lid event occurs and get the current status. This can be useful for when a platform firmware clobbers some hardware state at lid time, and a driver needs to restore things when the lid is opened again. Acked-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net>
2009-08-28ACPI: Move definition of PREFIX from acpi_bus.h to internal..hLen Brown
Linux/ACPI core files using internal.h all PREFIX "ACPI: ", however, not all ACPI drivers use/want it -- and they should not have to #undef PREFIX to define their own. Add GPL commment to internal.h while we are there. This does not change any actual console output, asside from a whitespace fix. Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-11ACPI: button: remove control method/fixed hardware distinctionsBjorn Helgaas
This patch removes the driver distinction between control method (CM) and fixed hardware (FF) buttons. We previously needed that so we could install either a fixed event handler or a notify handler, but the Linux/ACPI code now handles that for us, so we don't need to worry about it. Note that this removes the FF/CM annotation from the "info" files in /proc. For example, /proc/acpi/button/PWRF/info: -type: Power Button (FF) +type: Power Button I don't think there's anything meaningful user-space can do by knowing whether a button is a control method or a fixed hardware button, so nobody should be looking at the FF/CM. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-11ACPI: button: remove button->device pointerBjorn Helgaas
We no longer need a pointer from struct acpi_button back to the struct acpi_device. Everywhere we used that pointer, we either already have, or can easily get, the acpi_device pointer without using the copy from acpi_button. So this patch removes the structure element. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-11ACPI: button: cache hid/name/class pointersBjorn Helgaas
This patch adds temporaries to cache the acpi_device_hid(), acpi_device_name(), and acpi_device_class() pointers so we don't have to clutter the code with so many uses of those interfaces. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-11ACPI: button: use Linux style for getting driver_dataBjorn Helgaas
It's typical and slightly more compact to look up the driver_data structure by initializing the automatic variable at its definition. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-11ACPI: button: remove unnecessary null pointer checksBjorn Helgaas
Better to oops and learn about a bug than to silently cover it up. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-11ACPI: button: whitespace changesBjorn Helgaas
This patch changes a bit of whitespace to follow Linux conventions. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05ACPI: button: use .notify method instead of installing handler directlyBjorn Helgaas
This patch adds a .notify() method. The presence of .notify() causes Linux/ACPI to manage event handlers and notify handlers on our behalf, so we don't have to install and remove them ourselves. Note that events from fixed hardware buttons now show up as a special notify event, so to preserve user-space backward compatibility, we convert that back to ACPI_BUTTON_NOTIFY_STATUS. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> CC: Alexey Starikovskiy <alexey.y.starikovskiy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-11-11Merge branch 'ec' into releaseLen Brown
2008-11-11ACPICA: Use spinlock for acpi_{en|dis}able_gpeAlexey Starikovskiy
Disabling gpe might interfere with gpe detection/handling, thus producing "interrupt not handled" errors. Ironically, disabling of GPE from interrupt context is already under spinlock, so only userspace needs to start using it. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-07ACPI: consolidate ACPI_*_COMPONENT definitions in acpi_drivers.hBjorn Helgaas
Move all the component definitions for drivers to a single shared place, include/acpi/acpi_drivers.h. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-25ACPI: Always report a sync event after a lid state changeGuillem Jover
Currently not always an EV_SYN event is reported to userland after the EV_SW SW_LID event has been sent. This is easy to verify by using “input-events” from input-utils and just closing and opening the lid. Signed-off-by: Guillem Jover <guillem.jover@nokia.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22Merge branch 'ull' into testLen Brown
Conflicts: drivers/acpi/bay.c drivers/acpi/dock.c drivers/ata/libata-acpi.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-11ACPI: Change acpi_evaluate_integer to support 64-bit on 32-bit kernelsMatthew Wilcox
As of version 2.0, ACPI can return 64-bit integers. The current acpi_evaluate_integer only supports 64-bit integers on 64-bit platforms. Change the argument to take a pointer to an acpi_integer so we support 64-bit integers on all platforms. lenb: replaced use of "acpi_integer" with "unsigned long long" lenb: fixed bug in acpi_thermal_trips_update() Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-10ACPI: catch calls of acpi_driver_data on pointer of wrong typePavel Machek
Catch attempts to use of acpi_driver_data on pointers of wrong type. akpm: rewritten to use proper C typechecking and remove the "function"-used-as-lvalue thing. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29acpi: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Len Brown <lenb@kernel.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-11ACPI: button: make real parent for input devices in device treeAndrey Borzenkov
Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-25ACPI: button: send initial lid state after add and resumeAlexey Starikovskiy
Input layer should know about initial state of lid switch, even before first notify. Reference: https://bugzilla.novell.com/show_bug.cgi?id=326814 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-23ACPI: Schedule /proc/acpi/event for removalLen Brown
Schedule /proc/acpi/event for removal in 6 months. Re-name acpi_bus_generate_event() to acpi_bus_generate_proc_event() to make sure there is no confusion that it is for /proc/acpi/event only. Add CONFIG_ACPI_PROC_EVENT to allow removal of /proc/acpi/event. There is no functional change if CONFIG_ACPI_PROC_EVENT=y Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-23ACPI: autoload modules - Create __mod_acpi_device_table symbol for all ACPI ↵Thomas Renninger
drivers modpost is going to use these to create e.g. acpi:ACPI0001 in modules.alias. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: delete extra #defines in /drivers/acpi/ driversLen Brown
Cosmetic only. Except in a single case, #define ACPI_*_DRIVER_NAME were invoked 0 or 1 times. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: fix acpi_driver.name usageLen Brown
It was erroneously used as a description rather than a name. ie. turn this: lenb@se7525gp2:/sys> ls bus/acpi/drivers ACPI AC Adapter Driver ACPI Embedded Controller Driver ACPI Power Resource Driver ACPI Battery Driver ACPI Fan Driver ACPI Processor Driver ACPI Button Driver ACPI PCI Interrupt Link Driver ACPI Thermal Zone Driver ACPI container driver ACPI PCI Root Bridge Driver hpet into this: lenb@se7525gp2:~> ls /sys/bus/acpi/drivers ac battery button container ec fan hpet pci_link pci_root power processor thermal Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: clean up ACPI_MODULE_NAME() useLen Brown
cosmetic only Make "module name" actually match the file name. Invoke with ';' as leaving it off confuses Lindent and gcc doesn't care. Fix indentation where Lindent did get confused. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03Pull sysfs into test branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt include/acpi/acpi_drivers.h Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-01ACPI: correct id for fixed buttonsAlexey Starikovskiy
ACPI_BUTTON_HID_POWERF was changed, but this change was not propogated to button.c, thus breaking detection of fixed power and sleep buttons. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-11-09ACPI: button: register with input layerDmitry Torokhov
In addition to signalling button/lid events through /proc/acpi/event, create separate input devices and report KEY_POWER, KEY_SLEEP and SW_LID through input layer. Also remove unnecessary casts and variable initializations, clean up formatting. Sleep button may autorepeat but userspace will have to filter duplicate sleep requests anyway (and discard unprocessed events right after wakeup). Unlike /proc/acpi/event interface input device corresponding to LID switch reports true lid state instead of just a counter. SW_LID is active when lid is closed. The driver now depends on CONFIG_INPUT. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Len Brown <len.brown@intel.com>
2006-07-10ACPI: add 'const' to several ACPI file_operationsArjan van de Ven
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: button: Remove unneeded acpi_handle from driver.Patrick Mochel
Signed-off-by: Patrick Mochel <mochel@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: button: Use acpi_device's handle instead of driver'sPatrick Mochel
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
2006-06-27ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...)Len Brown
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-08-03[ACPI] restore /proc/acpi/button/ (ala 2.6.12)Alexey Starikovskiy
Signed-off-by Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by Len Brown <len.brown@intel.com>
2005-07-11[ACPI] Allow simultaneous Fixed Feature and Control Method buttonsAlexey Starikovskiy
delete /proc/acpi/button http://bugzilla.kernel.org/show_bug.cgi?id=1920 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
