path: root/drivers/acpi/dispatcher/dswstate.c
2008-04-23ACPICA: update Intel copyrightLen Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Cosmetic changes only, no functional changesBob Moore
Lint changes, fix compiler warnings, etc. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Several fixes for internal method result stackBob Moore
fixes STACK_OVERFLOW exception on nested method calls. internal bugzilla 262 and 275. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-09ACPICA: LindentLen Brown
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060526Bob Moore
Restructured, flattened, and simplified the internal interfaces for namespace object evaluation - resulting in smaller code, less CPU stack use, and fewer interfaces. (With assistance from Mikhail Kouzmich) Fixed a problem with the CopyObject operator where the first parameter was not typed correctly for the parser, interpreter, compiler, and disassembler. Caused various errors and unexpected behavior. Fixed a problem where a ShiftLeft or ShiftRight of more than 64 bits produced incorrect results with some C compilers. Since the behavior of C compilers when the shift value is larger than the datatype width is apparently not well defined, the interpreter now detects this condition and simply returns zero as expected in all such cases. (BZ 395) Fixed problem reports (Valery Podrezov) integrated: - Update String-to-Integer conversion to match ACPI 3.0A spec http://bugzilla.kernel.org/show_bug.cgi?id=5329 Allow interpreter to handle nested method declarations http://bugzilla.kernel.org/show_bug.cgi?id=5361 Fixed problem reports (Fiodor Suietov) integrated: - acpi_terminate() doesn't free debug memory allocation list objects (BZ 355) - After Core Subsystem shutdown, acpi_subsystem_status() returns AE_OK (BZ 356) - acpi_os_unmap_memory() for RSDP can be invoked inconsistently (BZ 357) - Resource Manager should return AE_TYPE for non-device objects (BZ 358) - Incomplete cleanup branch in AcpiNsEvaluateRelative (BZ 359) - Use acpi_os_free() instead of ACPI_FREE in acpi_rs_set_srs_method_data (BZ 360) - Incomplete cleanup branch in acpi_ps_parse_aml (BZ 361) - Incomplete cleanup branch in acpi_ds_delete_walk_state (BZ 362) - acpi_get_table_header returns AE_NO_ACPI_TABLES until DSDT is loaded (BZ 365) - Status of the Global Initialization Handler call not used (BZ 366) - Incorrect object parameter to Global Initialization Handler (BZ 367) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060421Bob Moore
Removed a device initialization optimization introduced in 20051216 where the _STA method was not run unless an _INI was also present for the same device. This optimization could cause problems because it could allow _INI methods to be run within a not-present device subtree (If a not-present device had no _INI, _STA would not be run, the not-present status would not be discovered, and the children of the device would be incorrectly traversed.) Implemented a new _STA optimization where namespace subtrees that do not contain _INI are identified and ignored during device initialization. Selectively running _STA can significantly improve boot time on large machines (with assistance from Len Brown.) Implemented support for the device initialization case where the returned _STA flags indicate a device not-present but functioning. In this case, _INI is not run, but the device children are examined for presence, as per the ACPI specification. Implemented an additional change to the IndexField support in order to conform to MS behavior. The value written to the Index Register is not simply a byte offset, it is a byte offset in units of the access width of the parent Index Field. (Fiodor Suietov) Defined and deployed a new OSL interface, acpi_os_validate_address(). This interface is called during the creation of all AML operation regions, and allows the host OS to exert control over what addresses it will allow the AML code to access. Operation Regions whose addresses are disallowed will cause a runtime exception when they are actually accessed (will not affect or abort table loading.) Defined and deployed a new OSL interface, acpi_os_validate_interface(). This interface allows the host OS to match the various "optional" interface/behavior strings for the _OSI predefined control method as appropriate (with assistance from Bjorn Helgaas.) Restructured and corrected various problems in the exception handling code paths within DsCallControlMethod and DsTerminateControlMethod in dsmethod (with assistance from Takayoshi Kochi.) Modified the Linux source converter to ignore quoted string literals while converting identifiers from mixed to lower case. This will correct problems with the disassembler and other areas where such strings must not be modified. The ACPI_FUNCTION_* macros no longer require quotes around the function name. This allows the Linux source converter to convert the names, now that the converter ignores quoted strings. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14[ACPI] ACPICA 20060317Bob Moore
Implemented the use of a cache object for all internal namespace nodes. Since there are about 1000 static nodes in a typical system, this will decrease memory use for cache implementations that minimize per-allocation overhead (such as a slab allocator.) Removed the reference count mechanism for internal namespace nodes, since it was deemed unnecessary. This reduces the size of each namespace node by about 5%-10% on all platforms. Nodes are now 20 bytes for the 32-bit case, and 32 bytes for the 64-bit case. Optimized several internal data structures to reduce object size on 64-bit platforms by packing data within the 64-bit alignment. This includes the frequently used ACPI_OPERAND_OBJECT, of which there can be ~1000 static instances corresponding to the namespace objects. Added two new strings for the predefined _OSI method: "Windows 2001.1 SP1" and "Windows 2006". Split the allocation tracking mechanism out to a separate file, from utalloc.c to uttrack.c. This mechanism appears to be only useful for application-level code. Kernels may wish to not include uttrack.c in distributions. Removed all remnants of the obsolete ACPI_REPORT_* macros and the associated code. (These macros have been replaced by the ACPI_ERROR and ACPI_WARNING macros.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-04-01ACPI: ACPICA 20060310Bob Moore
Tagged all external interfaces to the subsystem with the new ACPI_EXPORT_SYMBOL macro. This macro can be defined as necessary to assist kernel integration. For Linux, the macro resolves to the EXPORT_SYMBOL macro. The default definition is NULL. Added the ACPI_THREAD_ID type for the return value from acpi_os_get_thread_id(). This allows the host to define this as necessary to simplify kernel integration. The default definition is ACPI_NATIVE_UINT. Valery Podrezov fixed two interpreter problems related to error processing, the deletion of objects, and placing invalid pointers onto the internal operator result stack. http://bugzilla.kernel.org/show_bug.cgi?id=6028 http://bugzilla.kernel.org/show_bug.cgi?id=6151 Increased the reference count threshold where a warning is emitted for large reference counts in order to eliminate unnecessary warnings on systems with large namespaces (especially 64-bit.) Increased the value from 0x400 to 0x800. Due to universal disagreement as to the meaning of the 'c' in the calloc() function, the ACPI_MEM_CALLOCATE macro has been renamed to ACPI_ALLOCATE_ZEROED so that the purpose of the interface is 'clear'. ACPI_MEM_ALLOCATE and ACPI_MEM_FREE are renamed to ACPI_ALLOCATE and ACPI_FREE. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-31[ACPI] ACPICA 20060210Bob Moore
Removed a couple of extraneous ACPI_ERROR messages that appeared during normal execution. These became apparent after the conversion from ACPI_DEBUG_PRINT. Fixed a problem where the CreateField operator could hang if the BitIndex or NumBits parameter referred to a named object. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5359 Fixed a problem where a DeRefOf operation on a buffer object incorrectly failed with an exception. This also fixes a couple of related RefOf and DeRefOf issues. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5360 http://bugzilla.kernel.org/show_bug.cgi?id=5387 http://bugzilla.kernel.org/show_bug.cgi?id=5392 Fixed a problem where the AE_BUFFER_LIMIT exception was returned instead of AE_STRING_LIMIT on an out-of-bounds Index() operation. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5480 Implemented a memory cleanup at the end of the execution of each iteration of an AML While() loop, preventing the accumulation of outstanding objects. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5427 Eliminated a chunk of duplicate code in the object resolution code. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5336 Fixed several warnings during the 64-bit code generation. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-31[ACPI] ACPICA 20060127Bob Moore
Implemented support in the Resource Manager to allow unresolved namestring references within resource package objects for the _PRT method. This support is in addition to the previously implemented unresolved reference support within the AML parser. If the interpreter slack mode is enabled (true on Linux unless acpi=strict), these unresolved references will be passed through to the caller as a NULL package entry. http://bugzilla.kernel.org/show_bug.cgi?id=5741 Implemented and deployed new macros and functions for error and warning messages across the subsystem. These macros are simpler and generate less code than their predecessors. The new macros ACPI_ERROR, ACPI_EXCEPTION, ACPI_WARNING, and ACPI_INFO replace the ACPI_REPORT_* macros. Implemented the acpi_cpu_flags type to simplify host OS integration of the Acquire/Release Lock OSL interfaces. Suggested by Steven Rostedt and Andrew Morton. Fixed a problem where Alias ASL operators are sometimes not correctly resolved. causing AE_AML_INTERNAL http://bugzilla.kernel.org/show_bug.cgi?id=5189 http://bugzilla.kernel.org/show_bug.cgi?id=5674 Fixed several problems with the implementation of the ConcatenateResTemplate ASL operator. As per the ACPI specification, zero length buffers are now treated as a single EndTag. One-length buffers always cause a fatal exception. Non-zero length buffers that do not end with a full 2-byte EndTag cause a fatal exception. Fixed a possible structure overwrite in the AcpiGetObjectInfo external interface. (With assistance from Thomas Renninger) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-20[ACPI] ACPICA 20060113Bob Moore
Added 2006 copyright. At SuSE's suggestion, enabled all error messages without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros, respectively. This preserves all error and warning messages in the non-debug version of the ACPICA code (this has been referred to as the "debug lite" option.) Over 200 cases were converted to create a total of over 380 error/warning messages across the ACPICA code. This increases the code and data size of the default non-debug version by about 13K. Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages. The size of the debug version remains about the same. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-07-30[ACPI] ACPICA 20050729 from Bob MooreRobert Moore
Implemented support to ignore an attempt to install/load a particular ACPI table more than once. Apparently there exists BIOS code that repeatedly attempts to load the same SSDT upon certain events. Thanks to Venkatesh Pallipadi. Restructured the main interface to the AML parser in order to correctly handle all exceptional conditions. This will prevent leakage of the OwnerId resource and should eliminate the AE_OWNER_ID_LIMIT exceptions seen on some machines. Thanks to Alexey Starikovskiy. Support for "module level code" has been disabled in this version due to a number of issues that have appeared on various machines. The support can be enabled by defining ACPI_ENABLE_MODULE_LEVEL_CODE during subsystem compilation. When the issues are fully resolved, the code will be enabled by default again. Modified the internal functions for debug print support to define the FunctionName parameter as a (const char *) for compatibility with compiler built-in macros such as __FUNCTION__, etc. Linted the entire ACPICA source tree for both 32-bit and 64-bit. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-13ACPICA 20050617-0624 from Bob Moore <robert.moore@intel.com>Robert Moore
ACPICA 20050617: Moved the object cache operations into the OS interface layer (OSL) to allow the host OS to handle these operations if desired (for example, the Linux OSL will invoke the slab allocator). This support is optional; the compile time define ACPI_USE_LOCAL_CACHE may be used to utilize the original cache code in the ACPI CA core. The new OSL interfaces are shown below. See utalloc.c for an example implementation, and acpiosxf.h for the exact interface definitions. Thanks to Alexey Starikovskiy. acpi_os_create_cache acpi_os_delete_cache acpi_os_purge_cache acpi_os_acquire_object acpi_os_release_object Modified the interfaces to acpi_os_acquire_lock and acpi_os_release_lock to return and restore a flags parameter. This fits better with many OS lock models. Note: the current execution state (interrupt handler or not) is no longer passed to these interfaces. If necessary, the OSL must determine this state by itself, a simple and fast operation. Thanks to Alexey Starikovskiy. Fixed a problem in the ACPI table handling where a valid XSDT was assumed present if the revision of the RSDP was 2 or greater. According to the ACPI specification, the XSDT is optional in all cases, and the table manager therefore now checks for both an RSDP >=2 and a valid XSDT pointer. Otherwise, the RSDT pointer is used. Some ACPI 2.0 compliant BIOSs contain only the RSDT. Fixed an interpreter problem with the Mid() operator in the case of an input string where the resulting output string is of zero length. It now correctly returns a valid, null terminated string object instead of a string object with a null pointer. Fixed a problem with the control method argument handling to allow a store to an Arg object that already contains an object of type Device. The Device object is now correctly overwritten. Previously, an error was returned. ACPICA 20050624: Modified the new OSL cache interfaces to use ACPI_CACHE_T as the type for the host-defined cache object. This allows the OSL implementation to define and type this object in any manner desired, simplifying the OSL implementation. For example, ACPI_CACHE_T is defined as kmem_cache_t for Linux, and should be defined in the OS-specific header file for other operating systems as required. Changed the interface to AcpiOsAcquireObject to directly return the requested object as the function return (instead of ACPI_STATUS.) This change was made for performance reasons, since this is the purpose of the interface in the first place. acpi_os_acquire_object is now similar to the acpi_os_allocate interface. Thanks to Alexey Starikovskiy. Modified the initialization sequence in acpi_initialize_subsystem to call the OSL interface acpi_osl_initialize first, before any local initialization. This change was required because the global initialization now calls OSL interfaces. Restructured the code base to split some files because of size and/or because the code logically belonged in a separate file. New files are listed below. utilities/utcache.c /* Local cache interfaces */ utilities/utmutex.c /* Local mutex support */ utilities/utstate.c /* State object support */ parser/psloop.c /* Main AML parse loop */ Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-13ACPICA 20050526 from Bob Moore <robert.moore@intel.com>Robert Moore
Implemented support to execute Type 1 and Type 2 AML opcodes appearing at the module level (not within a control method.) These opcodes are executed exactly once at the time the table is loaded. This type of code was legal up until the release of ACPI 2.0B (2002) and is now supported within ACPI CA in order to provide backwards compatibility with earlier BIOS implementations. This eliminates the "Encountered executable code at module level" warning that was previously generated upon detection of such code. Fixed a problem in the interpreter where an AE_NOT_FOUND exception could inadvertently be generated during the lookup of namespace objects in the second pass parse of ACPI tables and control methods. It appears that this problem could occur during the resolution of forward references to namespace objects. Added the ACPI_MUTEX_DEBUG #ifdef to the acpi_ut_release_mutex function, corresponding to the same the deadlock detection debug code to be compiled out in the normal case, improving mutex performance (and overall subsystem performance) considerably. As suggested by Alexey Starikovskiy. Implemented a handful of miscellaneous fixes for possible memory leaks on error conditions and error handling control paths. These fixes were suggested by FreeBSD and the Coverity Prevent source code analysis tool. Added a check for a null RSDT pointer in acpi_get_firmware_table (tbxfroot.c) to prevent a fault in this error case. Signed-off-by Len Brown <len.brown@intel.com>
2005-07-13ACPICA from Bob Moore <robert.moore@intel.com>Robert Moore
Implemented support for PCI Express root bridges -- added support for device PNP0A08 in the root bridge search within AcpiEvPciConfigRegionSetup. acpi_ev_pci_config_region_setup(). The interpreter now automatically truncates incoming 64-bit constants to 32 bits if currently executing out of a 32-bit ACPI table (Revision < 2). This also affects the iASL compiler constant folding. (Note: as per below, the iASL compiler no longer allows 64-bit constants within 32-bit tables.) Fixed a problem where string and buffer objects with "static" pointers (pointers to initialization data within an ACPI table) were not handled consistently. The internal object copy operation now always copies the data to a newly allocated buffer, regardless of whether the source object is static or not. Fixed a problem with the FromBCD operator where an implicit result conversion was improperly performed while storing the result to the target operand. Since this is an "explicit conversion" operator, the implicit conversion should never be performed on the output. Fixed a problem with the CopyObject operator where a copy to an existing named object did not always completely overwrite the existing object stored at name. Specifically, a buffer-to-buffer copy did not delete the existing buffer. Replaced "interrupt_level" with "interrupt_number" in all GPE interfaces and structs for consistency. Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12ACPICA 20050408 from Bob MooreRobert Moore
Fixed three cases in the interpreter where an "index" argument to an ASL function was still (internally) 32 bits instead of the required 64 bits. This was the Index argument to the Index, Mid, and Match operators. The "strupr" function is now permanently local (acpi_ut_strupr), since this is not a POSIX-defined function and not present in most kernel-level C libraries. References to the C library strupr function have been removed from the headers. Completed the deployment of static functions/prototypes. All prototypes with the static attribute have been moved from the headers to the owning C file. ACPICA 20050329 from Bob Moore An error is now generated if an attempt is made to create a Buffer Field of length zero (A CreateField with a length operand of zero.) The interpreter now issues a warning whenever executable code at the module level is detected during ACPI table load. This will give some idea of the prevalence of this type of code. Implemented support for references to named objects (other than control methods) within package objects. Enhanced package object output for the debug object. Package objects are now completely dumped, showing all elements. Enhanced miscellaneous object output for the debug object. Any object can now be written to the debug object (for example, a device object can be written, and the type of the object will be displayed.) The "static" qualifier has been added to all local functions across the core subsystem. The number of "long" lines (> 80 chars) within the source has been significantly reduced, by about 1/3. Cleaned up all header files to ensure that all CA/iASL functions are prototyped (even static functions) and the formatting is consistent. Two new header files have been added, acopcode.h and acnames.h. Removed several obsolete functions that were no longer used. Signed-off-by: Len Brown <len.brown@intel.com>
