path: root/drivers/acpi/ec.c
2010-08-07Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits) ACPI / ACPICA: Simplify acpi_ev_initialize_gpe_block() ACPI / ACPICA: Fail acpi_gpe_wakeup() if ACPI_GPE_CAN_WAKE is unset ACPI / ACPICA: Do not execute _PRW methods during initialization ACPI: Fix bogus GPE test in acpi_bus_set_run_wake_flags() ACPICA: Update version to 20100702 ACPICA: Fix for Alias references within Package objects ACPICA: Fix lint warning for 64-bit constant ACPICA: Remove obsolete GPE function ACPICA: Update debug output components ACPICA: Add support for WDDT - Watchdog Descriptor Table ACPICA: Drop acpi_set_gpe ACPICA: Use low-level GPE enable during GPE block initialization ACPI / EC: Do not use acpi_set_gpe ACPI / EC: Drop suspend and resume routines ACPICA: Remove wakeup GPE reference counting which is not used ACPICA: Introduce acpi_gpe_wakeup() ACPICA: Rename acpi_hw_gpe_register_bit ACPICA: Update version to 20100528 ACPICA: Add signatures for undefined tables: ATKG, GSCI, IEIT ACPICA: Optimization: Reduce the number of namespace walks ...
2010-08-03acpi ec: Fix possible double io port registrationThomas Renninger
which will result in a harmless but ugly WARN message on some machines. Signed-off-by: Thomas Renninger <trenn@suse.de> CC: mjg59@srcf.ucam.org CC: platform-driver-x86@vger.kernel.org CC: linux-acpi@vger.kernel.org CC: astarikovskiy@suse.de CC: akpm@linux-foundation.org Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-03ACPI: Register EC io ports in /proc/ioportsThomas Renninger
Formerly these have been exposed through /proc/.. Better register them where all IO ports should get registered and scream loud if someone else claims to use them. EC data and command port typically should show up like this then: ... 0060-0060 : keyboard 0062-0062 : EC data 0064-0064 : keyboard 0066-0066 : EC command 0070-0071 : rtc0 ... Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Alexey Starikovskiy <astarikovskiy@suse.de> CC: Len Brown <lenb@kernel.org> CC: linux-kernel@vger.kernel.org CC: linux-acpi@vger.kernel.org CC: Bjorn Helgaas <bjorn.helgaas@hp.com> CC: platform-driver-x86@vger.kernel.org Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-03ACPI: Provide /sys/kernel/debug/ec/...Thomas Renninger
This patch provides the same information through debugfs, which previously was provided through /proc/acpi/embedded_controller/*/info This is the gpe the EC is connected to and whether the global lock gets used. The io ports used are added to /proc/ioports in another patch. Beside the fact that /proc/acpi is deprecated for quite some time, this info is not needed for applications and thus can be moved to debugfs instead of a public interface like /sys. Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Alexey Starikovskiy <astarikovskiy@suse.de> CC: Len Brown <lenb@kernel.org> CC: linux-kernel@vger.kernel.org CC: linux-acpi@vger.kernel.org CC: Bjorn Helgaas <bjorn.helgaas@hp.com> CC: platform-driver-x86@vger.kernel.org Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-03ACPI: Remove /proc/acpi/embedded_controller/..Thomas Renninger
Other patches in this series add the same info to /sys/... and /proc/ioports. The info removed should never have been used in an application, eventually someone read it manually. /proc/acpi is deprecated for more than a year anyway... Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Alexey Starikovskiy <astarikovskiy@suse.de> CC: Len Brown <lenb@kernel.org> CC: linux-kernel@vger.kernel.org CC: linux-acpi@vger.kernel.org CC: platform-driver-x86@vger.kernel.org Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-07-06ACPI / EC: Do not use acpi_set_gpeRafael J. Wysocki
The EC driver is the last user of acpi_set_gpe() and since it is guaranteed that the EC GPE will not be shared, acpi_disable_gpe() and acpi_enable_gpe() may be used for disabling the GPE temporarilty if a GPE storm is detected and re-enabling it during EC transactions. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPI / EC: Drop suspend and resume routinesRafael J. Wysocki
The suspend and resume routines provided by the EC driver are not really necessary, because the handler of the GPE disabled by them is not going to be executed after suspend_device_irqs() and before resume_device_irqs() anyway. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPICA: Remove wakeup GPE reference counting which is not usedRafael J. Wysocki
After the previous patch that introduced acpi_gpe_wakeup() and modified the ACPI suspend and wakeup code to use it, the third argument of acpi_{enable|disable}_gpe() and the GPE wakeup reference counter are not necessary any more. Remove them and modify all of the users of acpi_{enable|disable}_gpe() accordingly. Also drop GPE type constants that aren't used any more. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-01Merge branches 'bugzilla-14668' and 'misc-2.6.35' into releaseLen Brown
2010-05-28ACPI / EC / PM: Fix names of functions that block/unblock EC transactionsRafael J. Wysocki
The names of the functions used for blocking/unblocking EC transactions during suspend/hibernation suggest that the transactions are suspended and resumed by them, while in fact they are disabled and enabled. Rename the functions (and the flag used by them) to better reflect what they really do. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-28ACPI / EC / PM: Fix race between EC transactions and system suspendRafael J. Wysocki
There still is a race that may result in suspending the system in the middle of an EC transaction in progress, which leads to problems (like the kernel thinking that the ACPI global lock is held during resume while in fact it's not). To remove the race condition, modify the ACPI platform suspend and hibernate callbacks so that EC transactions are blocked right after executing the _PTS global control method and are allowed to happen again right after the low-level wakeup. Introduce acpi_pm_freeze() that will disable GPEs, wait until the event queues are empty and block EC transactions. Use it wherever GPEs are disabled in preparation for switching local interrupts off. Introduce acpi_pm_thaw() that will allow EC transactions to happen again and enable runtime GPEs. Use it to balance acpi_pm_freeze() wherever necessary. In addition to that use acpi_ec_resume_transactions_early() to unblock EC transactions as early as reasonably possible during resume. Also unblock EC transactions in acpi_hibernation_finish() and in the analogous suspend routine to make sure that the EC transactions are enabled in all error paths. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=14668 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-20ACPI: EC: Use kmemdupJulia Lawall
Use kmemdup when some other buffer is immediately copied into the allocated region. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; statement S; @@ - to = \(kmalloc\|kzalloc\)(size,flag); + to = kmemdup(from,size,flag); if (to==NULL || ...) S - memcpy(to, from, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-06Merge branches 'battery', 'bugzilla-14667', 'bugzilla-15096', ↵Len Brown
'bugzilla-15480', 'bugzilla-15521', 'bugzilla-15605', 'gpe-reference-counters', 'misc', 'pxm-fix' and 'video-random-key' into release
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-17ACPI: EC: Allow multibyte access to ECAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=14667 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-14Merge branches 'battery-2.6.34', 'bugzilla-10805', 'bugzilla-14668', ↵Len Brown
'bugzilla-531916-power-state', 'ht-warn-2.6.34', 'pnp', 'processor-rename', 'sony-2.6.34', 'suse-bugzilla-531547', 'tz-check', 'video' and 'misc-2.6.34' into release
2010-03-08ACPI / EC / PM: Close race between EC and resume from hibernationRafael J. Wysocki
There is a race between resume from hibernation and the EC driver that may result in restoring the hibernation image in the middle of an EC transaction in progress, which in turn may lead to unpredictable behavior of the platform. To remove that race condition, add a helpers for suspending and resuming EC transactions in a safe way to be executed by the ACPI platform hibernate pre-restore and restore cleanup callbacks. http://bugzilla.kernel.org/show_bug.cgi?id=14668 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-01Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: replace acpi_integer by u64 ACPICA: Update version to 20100121. ACPICA: Remove unused uint32_struct type ACPICA: Disassembler: Remove obsolete "Integer64" field in parse object ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) type ACPICA: Predefined name repair: fix NULL package elements ACPICA: AcpiGetDevices: Eliminate unnecessary _STA calls ACPICA: Update all ACPICA copyrights and signons to 2010 ACPICA: Update for new gcc-4 warning options
2010-02-24ACPI: Use GPE reference counting to support shared GPEsRafael J. Wysocki
To fix a bug and address the reviewers' comments regarding the ACPI GPE refcounting patch, do the following additional changes: o Remove the second argument of acpi_ev_enable_gpe(), 'write_to_hardware', because it is not necessary any more. o Add the "bad parameter" test against 'type' in acpi_enable_gpe() and acpi_disable_gpe(). o Make acpi_enable_gpe() only check 'status' for runtime GPEs if acpi_ev_enable_gpe() was actually called. o Make acpi_disable_gpe() return 'status' returned by acpi_ev_disable_gpe() and fix a bug where ACPI_GPE_TYPE_WAKE and ACPI_GPE_TYPE_RUNTIME were exchanged by mistake. o Add comments explaining why acpi_set_gpe() is used by the ACPI EC driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22ACPI: Use GPE reference counting to support shared GPEsRafael J. Wysocki
ACPI GPEs may map to multiple devices. The current GPE interface only provides a mechanism for enabling and disabling GPEs, making it difficult to change the state of GPEs at runtime without extensive cooperation between devices. Add an API to allow devices to indicate whether or not they want their device's GPE to be enabled for both runtime and wakeup events. Remove the old GPE type handling entirely, which gets rid of various quirks, like the implicit disabling with GPE type setting. This requires a small amount of rework in order to ensure that non-wake GPEs are enabled by default to preserve existing behaviour. Based on patches from Matthew Garrett <mjg@redhat.com>. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-01-28ACPI: replace acpi_integer by u64Lin Ming
acpi_integer is now obsolete and removed from the ACPICA code base, replaced by u64. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-15ACPI: EC: Add wait for irq stormAlexey Starikovskiy
Merge of poll and irq modes accelerated EC transaction, so that keyboard starts to suffer again. Add msleep(1) into transaction path for the storm to allow keyboard controller to do its job. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14747 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-15ACPI: SBS: Move SBS HC callback to faster Notify queueAlexey Starikovskiy
SBS transactions should happen in Notify work queue, to not create a dead lock with GPE execution accessing SBS devices. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-24ACPI: EC: Accelerate query executionAlexey Starikovskiy
Split EC query handling into acknowledge and execution phase. This allows much smaller pending query lattency and lowers chances of EC going "wild" and losing events. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14858 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-24Merge branches 'bugzilla-14446', 'bugzilla-14753' and 'bugzilla-14824' into ↵Len Brown
release
2009-12-22ACPI: EC: Fix MSI DMI detectionAlexey Starikovskiy
MSI strings should be ORed, not ANDed. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14446 cc: stable@kernel.org Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Add post-order callback to acpi_walk_namespaceLin Ming
The existing interface only has a pre-order callback. This change adds an additional parameter for a post-order callback which will be more useful for bus scans. ACPICA BZ 779. Also update the external calls to acpi_walk_namespace. http://www.acpica.org/bugzilla/show_bug.cgi?id=779 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-03Merge branch 'bugzilla-14081' into releaseLen Brown
2009-10-03ACPI: EC: Don't parse DSDT for EC early init on CompalAlexey Starikovskiy
Compal DSDT breaks if scanned early, while we need early scan for almost all ASUS machines. Safest workaround seems to be to continue do an early scan for all machines, but this Compal model. http://bugzilla.kernel.org/show_bug.cgi?id=14086 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-03ACPI: EC: Rewrite DMI checksAlexey Starikovskiy
Use dmi_check_system() for DMI matching. Don't use string "Notebook" for matching MSI hardware. http://bugzilla.kernel.org/show_bug.cgi?id=14081 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-02ACPI: EC: Restart command even if no interrupts from ECAlexey Starikovskiy
EC may forget a command without sending any "reset" interrupt, thus we need to lessen the requirement for transaction restart. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14247 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19Merge branch 'misc-2.6.32' into releaseLen Brown
Conflicts: drivers/pci/dmar.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19Merge branch 'ec' into releaseLen Brown
Conflicts: drivers/acpi/ec.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19Merge branch 'bjorn-start-stop-2.6.32' into releaseLen Brown
2009-09-19ACPI: linux/acpi.h should not include linux/dmi.hLen Brown
users of acpi.h that need dmi.h should include it directly. Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-29ACPI: EC: Drop orphan commentAlexey Starikovskiy
2009-08-29ACPI: EC: use BURST mode only for MSI notebooksAlexey Starikovskiy
2009-08-29ACPI: EC: Merge IRQ and POLL modesAlexey Starikovskiy
In general, EC transaction should complete in less than 1ms, thus it is possible to merge wait for 1ms in poll mode and 1ms of interrupt transaction timeout. Still, driver will wait 500ms for EC to complete transaction. This significantly simplifies driver and makes it immune to problematic EC interrupt implementations. It also may lessen kernel start-up time by 500ms. References: http://bugzilla.kernel.org/show_bug.cgi?id=12949 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28ACPI: Move definition of PREFIX from acpi_bus.h to internal..hLen Brown
Linux/ACPI core files using internal.h all PREFIX "ACPI: ", however, not all ACPI drivers use/want it -- and they should not have to #undef PREFIX to define their own. Add GPL commment to internal.h while we are there. This does not change any actual console output, asside from a whitespace fix. Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-25ACPI: EC: remove .stop() methodBjorn Helgaas
This patch folds the .stop() method into .remove(). acpi_ec_stop() is only called via acpi_device_probe() and acpi_device_remove(), and in both cases it is called immediately before acpi_ec_remove(), so there's no need to have it be a separate method. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> CC: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-25ACPI: EC: remove .start() methodBjorn Helgaas
This patch folds the .start() method into .add(). acpi_ec_start() is always called immediately after acpi_ec_add(), so there's no need to have it be a separate method. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> CC: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-25ACPI: EC: move acpi_ec_start() after acpi_ec_add()Bjorn Helgaas
This patch rearranges ec_install_handlers() and acpi_ec_start() so acpi_ec_start() ends up just after acpi_ec_add(). A subsequent patch will merge them. Code movement only; no functional change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> CC: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-23ACPI: EC: Fix ACPI EC resume non-query interrupt messageAlmer S. Tigelaar
When resuming from standby (on a laptop) I see the following message in my kernel.log: "ACPI: EC: non-query interrupt received, switching to interrupt mode" This apparently prevented sony-laptop to properly restore the brightness level on resume. The cause: In drivers/acpi/ec.c the acpi_ec_suspend function clears the GPE mode bit, but this is not restored in acpi_ec_resume (the function below it). The patch below fixes this by properly restoring the GPE_MODE bit. Tested and confirmed to work. Signed-off-by: Almer S. Tigelaar <almer@gnome.org> Signed-off-by: Mattia Dongili <malattia@linux.it> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'constify' into releaseLen Brown
2009-04-05Merge branches 'bugzilla-12461' and 'bugzilla-9998' into releaseLen Brown
2009-04-03ACPI: constify VFTs (1/2)Jan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-01ACPI: EC: Always parse EC deviceAlexey Starikovskiy
If ECDT info is not valid, we have last chance to configure EC driver properly at this point, don't miss it. http://bugzilla.kernel.org/show_bug.cgi?id=12461 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-01ACPI: EC: Separate delays for MSI hardwareAlexey Starikovskiy
MSI notebooks require very strict delays, while all others are happy with msleep(). References: http://bugzilla.kernel.org/show_bug.cgi?id=9998 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPI: call acpi_ec_init() explicitly rather than as initcallBjorn Helgaas
This patch makes acpi_init() call acpi_ec_init() directly. Previously, both were subsys_initcalls. acpi_ec_init() must happen after acpi_init(), and it's better to call it explicitly rather than rely on link ordering. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> CC: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-21ACPI: EC: Add delay for slow MSI controllerAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=12011 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
