path: root/drivers/acpi/glue.c
2013-09-09ACPI / bind: Prefer device objects with _STA to those without itRafael J. Wysocki
As reported at https://bugzilla.kernel.org/show_bug.cgi?id=60829, there still are cases in which do_find_child() doesn't choose the ACPI device object it is "expected" to choose if there are more such objects matching one PCI device present. This particular problem may be worked around by making do_find_child() return device obejcts witn _STA whose result indicates that the device is enabled before device objects without _STA if there's more than one device object to choose from. This change doesn't affect the case in which there's only one matching ACPI device object per PCI device. References: https://bugzilla.kernel.org/show_bug.cgi?id=60829 Reported-by: Peter Wu <lekensteyn@gmail.com> Tested-by: Felix Lisczyk <felix.lisczyk@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-09ACPI: Print diagnostic messages if device links cannot be createdRafael J. Wysocki
Although the device links created by acpi_bind_one() are not essential from the kernel functionality point of view, user space may be confused when they are missing, so print diagnostic messages to the kernel log if they can't be created. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com>
2013-08-09ACPI: Drop unnecessary label from acpi_bind_one()Rafael J. Wysocki
The out_free label in acpi_bind_one() is only jumped to from one place, so in fact it is not necessary, because the code below it can be moved to that place directly. Move that code and drop the label. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com>
2013-08-07ACPI: Clean up error code path in acpi_unbind_one()Rafael J. Wysocki
The error code path in acpi_unbind_one() is unnecessarily complicated (in particular, the err label is not really necessary) and the error message printed by it is inaccurate (there's nothing called 'acpi_handle' in that function), so clean up those things. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
2013-08-07ACPI: Use list_for_each_entry() in acpi_unbind_one()Rafael J. Wysocki
Since acpi_unbind_one() walks physical_node_list under the ACPI device object's physical_node_lock mutex and the walk may be terminated as soon as the matching entry has been found, it is not necessary to use list_for_each_safe() for that walk, so use list_for_each_entry() instead and make the code slightly more straightforward. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
2013-08-07ACPI: acpi_bind_one()/acpi_unbind_one() whitespace cleanupsRafael J. Wysocki
Clean up some inconsistent use of whitespace in acpi_bind_one() and acpi_unbind_one(). Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
2013-08-07ACPI: Create symlinks in acpi_bind_one() under physical_node_lockRafael J. Wysocki
Put the creation of symlinks in acpi_bind_one() under the physical_node_lock mutex of the given ACPI device object, because that is part of the binding operation logically (those links are already removed under that mutex too). Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
2013-08-07ACPI: Reduce acpi_bind_one()/acpi_unbind_one() code duplicationRafael J. Wysocki
Move some duplicated code from acpi_bind_one() and acpi_unbind_one() into a separate function and make that function use snprintf() instead of sprintf() for extra safety. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
2013-08-07ACPI: Do not fail acpi_bind_one() if device is already bound correctlyRafael J. Wysocki
Modify acpi_bind_one() so that it doesn't fail if the device represented by its first argument has already been bound to the given ACPI handle (second argument), because that is not a good enough reason for returning an error code. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Lan Tianyu <tianyu.lan@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com>
2013-08-07ACPI: Try harder to resolve _ADR collisions for bridgesRafael J. Wysocki
In theory, under a given ACPI namespace node there should be only one child device object with _ADR whose value matches a given bus address exactly. In practice, however, there are systems in which multiple child device objects under a given parent have _ADR matching exactly the same address. In those cases we use _STA to determine which of the multiple matching devices is enabled, since some systems are known to indicate which ACPI device object to associate with the given physical (usually PCI) device this way. Unfortunately, as it turns out, there are systems in which many device objects under the same parent have _ADR matching exactly the same bus address and none of them has _STA, in which case they all should be regarded as enabled according to the spec. Still, if those device objects are supposed to represent bridges (e.g. this is the case for device objects corresponding to PCIe ports), we can try harder and skip the ones that have no child device objects in the ACPI namespace. With luck, we can avoid using device objects that we are not expected to use this way. Although this only works for bridges whose children also have ACPI namespace representation, it is sufficient to address graphics adapter detection issues on some systems, so rework the code finding a matching device ACPI handle for a given bus address to implement this idea. Introduce a new function, acpi_find_child(), taking three arguments: the ACPI handle of the device's parent, a bus address suitable for the device's bus type and a bool indicating if the device is a bridge and make it work as outlined above. Reimplement the function currently used for this purpose, acpi_get_child(), as a call to acpi_find_child() with the last argument set to 'false' and make the PCI subsystem use acpi_find_child() with the bridge information passed as the last argument to it. [Lan Tianyu notices that it is not sufficient to use pci_is_bridge() for that, because the device's subordinate pointer hasn't been set yet at this point, so use hdr_type instead.] This change fixes a regression introduced inadvertently by commit 33f767d (ACPI: Rework acpi_get_child() to be more efficient) which overlooked the fact that for acpi_walk_namespace() "post-order" means "after all children have been visited" rather than "on the way back", so for device objects without children and for namespace walks of depth 1, as in the acpi_get_child() case, the "post-order" callbacks ordering is actually the same as the ordering of "pre-order" ones. Since that commit changed the namespace walk in acpi_get_child() to terminate after finding the first matching object instead of going through all of them and returning the last one, it effectively changed the result returned by that function in some rare cases and that led to problems (the switch from a "pre-order" to a "post-order" callback was supposed to prevent that from happening, but it was ineffective). As it turns out, the systems where the change made by commit 33f767d actually matters are those where there are multiple ACPI device objects representing the same PCIe port (which effectively is a bridge). Moreover, only one of them, and the one we are expected to use, has child device objects in the ACPI namespace, so the regression can be addressed as described above. References: https://bugzilla.kernel.org/show_bug.cgi?id=60561 Reported-by: Peter Wu <lekensteyn@gmail.com> Tested-by: Vladimir Lalov <mail@vlalov.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Cc: 3.9+ <stable@vger.kernel.org> # 3.9+
2013-08-06ACPI: Drop physical_node_id_bitmap from struct acpi_deviceRafael J. Wysocki
The physical_node_id_bitmap in struct acpi_device is only used for looking up the first currently unused dependent phyiscal node ID by acpi_bind_one(). It is not really necessary, however, because acpi_bind_one() walks the entire physical_node_list of the given device object for sanity checking anyway and if that list is always sorted by node_id, it is straightforward to find the first gap between the currently used node IDs and use that number as the ID of the new list node. This also removes the artificial limit of the maximum number of dependent physical devices per ACPI device object, which now depends only on the capacity of unsigend int. As a result, it fixes a regression introduced by commit e2ff394 (ACPI / memhotplug: Bind removable memory blocks to ACPI device nodes) that caused acpi_memory_enable_device() to fail when the number of 128 MB blocks within one removable memory module was greater than 32. Reported-and-tested-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
2013-06-28Merge branch 'acpi-assorted'Rafael J. Wysocki
* acpi-assorted: ACPI / EC: Add HP Folio 13 to ec_dmi_table in order to skip DSDT scan ACPI: Add CMOS RTC Operation Region handler support ACPI: Remove unused flags in acpi_device_flags ACPI: Remove useless initializers ACPI / battery: Make sure all spaces are in correct places ACPI: add _STA evaluation at do_acpi_find_child() ACPI / EC: access user space with get_user()/put_user()
2013-06-19ACPI: add _STA evaluation at do_acpi_find_child()Jeff Wu
Once do_acpi_find_child() has found the first matching handle, it makes the acpi_get_child() loop stop and return that handle. On some platforms, though, there are multiple devices with the same value of "_ADR" in the same namespace scope, and if one of them is enabled, the others will be disabled. For example: Address : 0x1FFFF ; path : SB_PCI0.SATA.DEV0 Address : 0x1FFFF ; path : SB_PCI0.SATA.DEV1 Address : 0x1FFFF ; path : SB_PCI0.SATA.DEV2 If DEV0 and DEV1 are disabled and DEV2 is enabled, the handle of DEV2 should be returned, but actually the function always returns the handle of DEV0. To address that issue, make do_acpi_find_child() evaluate _STA to check the device status. If a matching device object exists, but is disabled, acpi_get_child() will continue to walk the namespace in the hope of finding an enabled one. If one is found, its handle will be returned, but otherwise the function will return the handle of the disabled object found before (in case it is enabled going forward). [rjw: Changelog] Signed-off-by: Jeff Wu <zlinuxkernel@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-05-12ACPI / processor: Use common hotplug infrastructureRafael J. Wysocki
Split the ACPI processor driver into two parts, one that is non-modular, resides in the ACPI core and handles the enumeration and hotplug of processors and one that implements the rest of the existing processor driver functionality. The non-modular part uses an ACPI scan handler object to enumerate processors on the basis of information provided by the ACPI namespace and to hook up with the common ACPI hotplug infrastructure. It also populates the ACPI handle of each processor device having a corresponding object in the ACPI namespace, which allows the driver proper to bind to those devices, and makes the driver bind to them if it is readily available (i.e. loaded) when the scan handler's .attach() routine is running. There are a few reasons to make this change. First, switching the ACPI processor driver to using the common ACPI hotplug infrastructure reduces code duplication and size considerably, even though a new file is created along with a header comment etc. Second, since the common hotplug code attempts to offline devices before starting the (non-reversible) removal procedure, it will abort (and possibly roll back) hot-remove operations involving processors if cpu_down() returns an error code for one of them instead of continuing them blindly (if /sys/firmware/acpi/hotplug/force_remove is unset). That is a more desirable behavior than what the current code does. Finally, the separation of the scan/hotplug part from the driver proper makes it possible to simplify the driver's .remove() routine, because it doesn't need to worry about the possible cleanup related to processor removal any more (the scan/hotplug part is responsible for that now) and can handle device removal and driver removal symmetricaly (i.e. as appropriate). Some user-visible changes in sysfs are made (for example, the 'sysdev' link from the ACPI device node to the processor device's directory is gone and a 'physical_node' link is present instead and a corresponding 'firmware_node' is present in the processor device's directory, the processor driver is now visible under /sys/bus/cpu/drivers/ and bound to the processor device), but that shouldn't affect the functionality that users care about (frequency scaling, C-states and thermal management). Tested on my venerable Toshiba Portege R500. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Toshi Kani <toshi.kani@hp.com>
2013-03-04ACPI / glue: Drop .find_bridge() callback from struct acpi_bus_typeRafael J. Wysocki
After PCI and USB have stopped using the .find_bridge() callback in struct acpi_bus_type, the only remaining user of it is SATA, but SATA only pretends to be a user, because it points that callback to a stub always returning -ENODEV. For this reason, drop the SATA's dummy .find_bridge() callback and remove .find_bridge(), which is not used any more, from struct acpi_bus_type entirely. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2013-03-04ACPI / glue: Add .match() callback to struct acpi_bus_typeRafael J. Wysocki
USB uses the .find_bridge() callback from struct acpi_bus_type incorrectly, because as a result of the way it is used by USB every device in the system that doesn't have a bus type or parent is passed to usb_acpi_find_device() for inspection. What USB actually needs, though, is to call usb_acpi_find_device() for USB ports that don't have a bus type defined, but have usb_port_device_type as their device type, as well as for USB devices. To fix that replace the struct bus_type pointer in struct acpi_bus_type used for matching devices to specific subsystems with a .match() callback to be used for this purpose and update the users of struct acpi_bus_type, including USB, accordingly. Define the .match() callback routine for USB, usb_acpi_bus_match(), in such a way that it will cover both USB devices and USB ports and remove the now redundant .find_bridge() callback pointer from usb_acpi_bus. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2013-02-15Merge branch 'acpi-assorted'Rafael J. Wysocki
* acpi-assorted: ACPI: Add DMI entry for Sony VGN-FW41E_H ACPI: fix obsolete comment in custom_method.c ACPI / thermal: Use mode to enable/disable kernel thermal processing ACPI thermal: remove unnecessary newline from exception message ACPI sysfs: remove unnecessary newline from exception ACPI video: remove unnecessary newline from error messages ACPI: SRAT: report non-volatile memory in debug ACPI: Rework acpi_get_child() to be more efficient
2013-02-11Merge branch 'acpi-scan'Rafael J. Wysocki
* acpi-scan: (30 commits) ACPI / scan: Fix acpi_bus_get_device() check in acpi_match_device() ACPI / scan: Make namespace scanning and trimming mutually exclusive ACPI / scan: Make it clear that acpi_bus_trim() cannot fail ACPI / scan: Drop acpi_bus_add() and use acpi_bus_scan() instead ACPI: update ej_event interface to take acpi_device ACPI / scan: Add second pass to acpi_bus_trim() ACPI / scan: Change the implementation of acpi_bus_trim() ACPI / scan: Drop the second argument of acpi_bus_trim() ACPI / scan: Drop the second argument of acpi_device_unregister() ACPI: Remove the ops field from struct acpi_device ACPI: remove unused acpi_op_bind and acpi_op_unbind ACPI / scan: Fix check of device_attach() return value. ACPI / scan: Treat power resources in a special way ACPI: Remove unused struct acpi_pci_root.id member ACPI: Drop ACPI device .bind() and .unbind() callbacks ACPI / PCI: Move the _PRT setup and cleanup code to pci-acpi.c ACPI / PCI: Rework the setup and cleanup of device wakeup ACPI: Add .setup() and .cleanup() callbacks to struct acpi_bus_type ACPI: Make acpi_bus_scan() and acpi_bus_add() take only one argument ACPI: Replace ACPI device add_type field with a match_driver flag ...
2013-01-26ACPI: Rework acpi_get_child() to be more efficientRafael J. Wysocki
Observe that acpi_get_child() doesn't need to use the helper struct acpi_find_child structure and change it to work without it. Also, using acpi_get_object_info() to get the output of _ADR for the given device is overkill, because that function does much more than just evaluating _ADR (let alone the additional memory allocation done by it). Moreover, acpi_get_child() doesn't need to loop any more once it has found a matching handle, so make it stop in that case. To prevent the results from changing, make it use do_acpi_find_child() as a post-order callback. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-12ACPI / glue: Fix build with ACPI_GLUE_DEBUG setYinghai Lu
If ACPI_GLUE_DEBUG is different from 0 (setting this requires a manual change of glue.c), build breaks because of a leftover reference to dev->acpi_handle in acpi_platform_notify(). Fix this by using ACPI_HANDLE(dev) instead as appropriate. [rjw: Subject and changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-03ACPI / glue: Update DBG macro to include KERN_DEBUGJoe Perches
Currently these DBG statements are emitted at KERN_DEFAULT. Change the macro to emit at KERN_DEBUG. This can help avoid unexpected message interleaving. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-03ACPI: Add .setup() and .cleanup() callbacks to struct acpi_bus_typeRafael J. Wysocki
Add two new callbacks,.setup() and .cleanup(), struct acpi_bus_type and modify acpi_platform_notify() to call .setup() after executing acpi_bind_one() successfully and acpi_platform_notify_remove() to call .cleanup() before running acpi_unbind_one(). This will allow the users of struct acpi_bus_type, PCI in particular, to specify operations to be executed right after the given device has been associated with a companion struct acpi_device and right before it's going to be detached from that companion, respectively. The main motivation is to be able to get rid of acpi_pci_bind() and acpi_pci_unbind(), which are horrible horrible stuff. [In short, there are three problems with them: The way they populate the .bind() and .unbind() callbacks of ACPI devices is rather less than straightforward, they require special hotplug-specific paths to be present in the ACPI namespace scanning code and by the time acpi_pci_unbind() is called the PCI device object in question may not exist any more.] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Toshi Kani <toshi.kani@hp.com>
2012-11-21ACPI / driver core: Introduce struct acpi_dev_node and related macrosRafael J. Wysocki
To avoid adding an ACPI handle pointer to struct device on architectures that don't use ACPI, or generally when CONFIG_ACPI is not set, in which cases that pointer is useless, define struct acpi_dev_node that will contain the handle pointer if CONFIG_ACPI is set and will be empty otherwise and use it to represent the ACPI device node field in struct device. In addition to that define macros for reading and setting the ACPI handle of a device that don't generate code when CONFIG_ACPI is unset. Modify the ACPI subsystem to use those macros instead of referring to the given device's ACPI handle directly. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21ACPI: Allow ACPI handles of devices to be initialized in advanceRafael J. Wysocki
Currently, the ACPI handles of devices are initialized from within device_add(), by acpi_bind_one() called from acpi_platform_notify() which first uses the .find_device() routine provided by the device's bus type to find the matching device node in the ACPI namespace. This is a source of some computational overhead and, moreover, the correctness of the result depends on the implementation of .find_device() which is known to fail occasionally for some bus types (e.g. PCI). In some cases, however, the corresponding ACPI device node is known already before calling device_add() for the given struct device object and the whole .find_device() dance in acpi_platform_notify() is then simply unnecessary. For this reason, make it possible to initialize the ACPI handles of devices before calling device_add() for them. Modify acpi_platform_notify() to call acpi_bind_one() in advance to check the device's existing ACPI handle and skip the .find_device() search if that is successful. Change acpi_bind_one() accordingly. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
2012-11-15driver core / ACPI: Move ACPI support to core device and driver typesMika Westerberg
With ACPI 5 we are starting to see devices that don't natively support discovery but can be enumerated with the help of the ACPI namespace. Typically, these devices can be represented in the Linux device driver model as platform devices or some serial bus devices, like SPI or I2C devices. Since we want to re-use existing drivers for those devices, we need a way for drivers to specify the ACPI IDs of supported devices, so that they can be matched against device nodes in the ACPI namespace. To this end, it is sufficient to add a pointer to an array of supported ACPI device IDs, that can be provided by the driver, to struct device. Moreover, things like ACPI power management need to have access to the ACPI handle of each supported device, because that handle is used to invoke AML methods associated with the corresponding ACPI device node. The ACPI handles of devices are now stored in the archdata member structure of struct device whose definition depends on the architecture and includes the ACPI handle only on x86 and ia64. Since the pointer to an array of supported ACPI IDs is added to struct device_driver in an architecture-independent way, it is logical to move the ACPI handle from archdata to struct device itself at the same time. This also makes code more straightforward in some places and follows the example of Device Trees that have a poiter to struct device_node in there too. This changeset is based on Mika Westerberg's work. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-10-23ACPI: Fix memory leak in acpi_bind_one()Jesper Juhl
Memory is allocated with kzalloc() and assigned to 'physical_node'. Then 'physical_node->node_id' is initialized with a call to 'find_first_zero_bit()', if that results in a value greater than ACPI_MAX_PHYSICAL_NODE we'll end up jumping to the 'err:' label and there leave the function and let 'physical_node' go out of scope and leak the memory we allocated. This patch fixes the leak by simply freeing the unused/unneeded memory pointed to by 'physical_node' just before we jump to 'err:'. [rjw: The problem has been introduced by commit 1033f90 (ACPI: Allow ACPI binding with USB-3.0 hub), which is new in 3.7-rc.] Signed-off-by: Jesper Juhl <jj@chaosbits.net> Reviewed-by: Toshi Kani <toshi.kani@hp.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-09-21ACPI: Allow ACPI binding with USB-3.0 hubLan Tianyu
A USB port's position and connectability can't be identified on some boards via USB hub registers. ACPI _UPC and _PLD can help to resolve this issue and so it is necessary to bind USB with ACPI. This patch is to allow ACPI binding with USB-3.0 hub. Current ACPI only can bind one struct-device to one ACPI device node. This can not work with USB-3.0 hub, because the USB-3.0 hub has two logical devices. Each works for USB-2.0 and USB-3.0 devices. In the Linux USB subsystem, those two logical hubs are treated as two seperate devices that have two struct devices. But in the ACPI DSDT, these two logical hubs share one ACPI device node. So there is a requirement to bind multi struct-devices to one ACPI device node. This patch is to resolve such problem. Following is the ACPI device nodes' description under xhci hcd. Device (XHC) Device (RHUB) Device (HSP1) Device (HSP2) Device (HSP3) Device (HSP4) Device (SSP1) Device (SSP2) Device (SSP3) Device (SSP4) Topology in the Linux device XHC USB-2.0 logical hub USB-3.0 logical hub HSP1 SSP1 HSP2 SSP2 HSP3 SSP3 HSP4 SSP4 This patch also modifies the output of /proc/acpi/wakeup. One ACPI node can be associated with multiple devices: XHC S4 *enabled pci:0000:00:14.0 RHUB S0 disabled usb:usb1 disabled usb:usb2 Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-07-25drivers/acpi/glue: revert accidental license-related 6b66d95895c bitsJeff Garzik
Commit 6b66d95895c149cbc04d4fac5a2f5477c543a8ae should not have changed EXPORT_SYMBOL_GPL to EXPORT_SYMBOL. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-06-29libata: bind the Linux device tree to the ACPI device treeMatthew Garrett
Associate the ACPI device tree and libata devices. This patch uses the generic ACPI glue framework to do so. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Holger Macht <holger@homac.de> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-05-11ACPI: Add stubs for (un)register_acpi_bus_typeMatthew Garrett
It's unreasonable to have CONFIG_ACPI for these in drivers, so add some stub functions. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-10-31acpi: add export.h to files using THIS_MODULE/EXPORT_SYMBOLPaul Gortmaker
These files were relying on module.h to come in via the path in an include/acpi header file, but we don't want to have instances of module.h being included from include/* files if it can be avoided. Have the files include export.h instead. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-07ACPI / PM: Drop special ACPI wakeup flagsRafael J. Wysocki
Drop special ACPI wakeup flags, wakeup.state.enabled and wakeup.flags.always_enabled, that aren't necessary any more after we've started to use standard device wakeup flags for handling ACPI wakeup devices. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-26ACPI: Add the check of ADR flag in course of finding ACPI handle for PCI deviceZhao Yakui
The _ADR object is used to provide OSPM with the address of one device on its parent bus. In course of finding ACPI handle for the corresponding PCI device, we will firstly evaluate the _ADR object and then compare the two addresses to see whether it is the target ACPI device. But for one PCI device(0000:00:00.0) under the PCI root bridge, the corresponding address will be constructed as zero.In such case maybe the ACPI device without _ADR object will be misdetected and then be used to create the relationship between PCI device and ACPI device. https://bugzilla.kernel.org/show_bug.cgi?id=16422 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-28ACPI: replace acpi_integer by u64Lin Ming
acpi_integer is now obsolete and removed from the ACPICA code base, replaced by u64. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Add post-order callback to acpi_walk_namespaceLin Ming
The existing interface only has a pre-order callback. This change adds an additional parameter for a post-order callback which will be more useful for bus scans. ACPICA BZ 779. Also update the external calls to acpi_walk_namespace. http://www.acpica.org/bugzilla/show_bug.cgi?id=779 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19Merge branch 'acpica' into releaseLen Brown
2009-08-28ACPI: Move definition of PREFIX from acpi_bus.h to internal..hLen Brown
Linux/ACPI core files using internal.h all PREFIX "ACPI: ", however, not all ACPI drivers use/want it -- and they should not have to #undef PREFIX to define their own. Add GPL commment to internal.h while we are there. This does not change any actual console output, asside from a whitespace fix. Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: Fix several acpi_attach_data problemsBob Moore
Handler was never invoked. Now invoked if/when host node is deleted. Data object was not automatically deleted when host node was deleted. Interface to handler had an unused parameter, removed it. ACPICA BZ 778. http://acpica.org/bugzilla/show_bug.cgi?id=778 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: Major update for acpi_get_object_info external interfaceBob Moore
Completed a major update for the acpi_get_object_info external interface. Changes include: - Support for variable, unlimited length HID, UID, and CID strings - Support Processor objects the same as Devices (HID,UID,CID,ADR,STA, etc.) - Call the _SxW power methods on behalf of a device object - Determine if a device is a PCI root bridge - Change the ACPI_BUFFER parameter to ACPI_DEVICE_INFO. These changes will require an update to all callers of this interface. See the ACPICA Programmer Reference for details. Also, update all invocations of acpi_get_object_info interface Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-17ACPI: kill acpi_get_physical_pci_device()Alexander Chiang
acpi_get_pci_dev() is (hopefully) better, and all callers have been converted, so let's get rid of this duplicated functionality. Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPI: call init_acpi_device_notify() explicitly rather than as initcallBjorn Helgaas
This patch makes acpi_init() call init_acpi_device_notify() directly. Previously, init_acpi_device_notify() was an arch_initcall (sequence 3), so it was called before acpi_init() (a subsys_initcall at sequence 4). init_acpi_device_notify() sets the platform_notify and platform_notify_remove function pointers. These pointers are not used until acpi_init() enumerates ACPI devices in this path: acpi_init() acpi_scan_init() acpi_bus_scan() acpi_add_single_object() acpi_device_register() device_add() <use platform_notify> So it is sufficient to have acpi_init() call init_acpi_device_notify() directly before it enumerates devices. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-07ACPI: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-07ACPI: video: Ignore devices that aren't present in hardwareThomas Renninger
This is a reimplemention of commit 0119509c4fbc9adcef1472817fda295334612976 from Matthew Garrett <mjg59@srcf.ucam.org> This patch got removed because of a regression: ThinkPads with a Intel graphics card and an Integrated Graphics Device BIOS implementation stopped working. In fact, they only worked because the ACPI device of the discrete, the wrong one, got used (via int10). So ACPI functions were poking on the wrong hardware used which is a sever bug. The next patch provides support for above ThinkPads to be able to switch brightness via the legacy thinkpad_acpi driver and automatically detect when to use it. Original commit message from Matthew Garrett: Vendors often ship machines with a choice of integrated or discrete graphics, and use the same DSDT for both. As a result, the ACPI video module will locate devices that may not exist on this specific platform. Attempt to determine whether the device exists or not, and abort the device creation if it doesn't. http://bugzilla.kernel.org/show_bug.cgi?id=9614 Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-14rtc-cmos: move wake setup from ACPI glue into RTC driverBjorn Helgaas
Move rtc_wake_setup() from drivers/acpi/glue.c into the RTC driver in drivers/rtc/rtc-cmos.c. This removes the ordering constraint between the module_init(acpi_rtc_init) and the cmos_do_probe() code that depends on it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-12Fix RTC wakealarm sysfs interface breakage.Linus Torvalds
Commit ed458df4d2470adc02762a87a9ad665d0b1a2bd4 ("PnP: move pnpacpi/pnpbios_init to after PCI init") moved the PnP RTC discovery later, and now the ACPI RTC glue code doesn't find it any more, breaking the RTC wakealarm sysfs interfaces, as reported by Rafael. This really is fairly messy, and we have several annoying ordering constraints here - the PnP code that sets up the RTC resources wants to run after the PCI resources have to be registered, which in turn needs to run after ACPI has at least enumerated the root PCI buses etc. Our initcall ordering is not fine-grained enough to make this all painless. So this moves the ACPI RTC glue ("acpi_rtc_init()") down to a regular module call, which fixes the problem Rafael has. The reason this isn't wonderful is that we really should do acpi_rtc_init before we do the rtc_cmos init, and now those two are in the same module_init() section. Which happens to work, but only because drivers/rtc is linked after drivers/acpi. In other words, we still have a very subtle ordering issue here. Grr. Reported-and-tested-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-03ACPI: Make /proc/acpi/wakeup interface handle PCI devices (again)Rafael J. Wysocki
Make the ACPI /proc/acpi/wakeup interface set the appropriate wake-up bits of physical devices corresponding to the ACPI devices and make those bits be set initially for devices that are enabled to wake up by default. This is needed to restore the 2.6.26 and earlier behavior for the PCI devices that were previously handled correctly with the help of the /proc/acpi/wakeup interface. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21driver core: fix a lot of printk usages of bus_idGreg Kroah-Hartman
We have the dev_printk() variants for this kind of thing, use them instead of directly trying to access the bus_id field of struct device. This is done in order to remove bus_id entirely. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-20APCI: revert another duplicated patchThomas Gleixner
commit d1857056904d5f313f11184fcfa624652ff9620a ("ACPI: don't walk tables if ACPI was disabled") is another superfluous duplicate commit caused by git -> quilt -> git conversion. Revert it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (72 commits) Revert "x86/PCI: ACPI based PCI gap calculation" PCI: remove unnecessary volatile in PCIe hotplug struct controller x86/PCI: ACPI based PCI gap calculation PCI: include linux/pm_wakeup.h for device_set_wakeup_capable PCI PM: Fix pci_prepare_to_sleep x86/PCI: Fix PCI config space for domains > 0 Fix acpi_pm_device_sleep_wake() by providing a stub for CONFIG_PM_SLEEP=n PCI: Simplify PCI device PM code PCI PM: Introduce pci_prepare_to_sleep and pci_back_from_sleep PCI ACPI: Rework PCI handling of wake-up ACPI: Introduce new device wakeup flag 'prepared' ACPI: Introduce acpi_device_sleep_wake function PCI: rework pci_set_power_state function to call platform first PCI: Introduce platform_pci_power_manageable function ACPI: Introduce acpi_bus_power_manageable function PCI: make pci_name use dev_name PCI: handle pci_name() being const PCI: add stub for pci_set_consistent_dma_mask() PCI: remove unused arch pcibios_update_resource() functions PCI: fix pci_setup_device()'s sprinting into a const buffer ... Fixed up conflicts in various files (arch/x86/kernel/setup_64.c, arch/x86/pci/irq.c, arch/x86/pci/pci.h, drivers/acpi/sleep/main.c, drivers/pci/pci.c, drivers/pci/pci.h, include/acpi/acpi_bus.h) from x86 and ACPI updates manually.
