path: root/drivers/acpi/numa.c
2006-07-01ACPI: remove function tracing macros from drivers/acpi/*.cLen Brown
a few invocations appeared due to the SBS and other patches. Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-27[PATCH] pgdat allocation for new node add (get node id by acpi)Yasunori Goto
This is to find node id from acpi's handle of memory_device in DSDT. _PXM for the new node can be found by acpi_get_pxm() by using new memory's handle. So, node id can be found by pxm_to_nid_map[]. This patch becomes simpler than v2 of node hot-add patch. Because old add_memory() function doesn't have node id parameter. So, kernel must find its handle by physical address via DSDT again. But, v3 just give node id to add_memory() now. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Unify pxm_to_node() and node_to_pxm()Yasunori Goto
Consolidate the various arch-specific implementations of pxm_to_node() and node_to_pxm() into a single generic version. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
