path: root/drivers/acpi/numa.c
2009-08-28ACPI: Move definition of PREFIX from acpi_bus.h to internal..hLen Brown
Linux/ACPI core files using internal.h all PREFIX "ACPI: ", however, not all ACPI drivers use/want it -- and they should not have to #undef PREFIX to define their own. Add GPL commment to internal.h while we are there. This does not change any actual console output, asside from a whitespace fix. Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-03x86, ACPI: add support for x2apic ACPI extensionsSuresh Siddha
All logical processors with APIC ID values of 255 and greater will have their APIC reported through Processor X2APIC structure (type-9 entry type) and all logical processors with APIC ID less than 255 will have their APIC reported through legacy Processor Local APIC (type-0 entry type) only. This is the same case even for NMI structure reporting. The Processor X2APIC Affinity structure provides the association between the X2APIC ID of a logical processor and the proximity domain to which the logical processor belongs. For OSPM, Procssor IDs outside the 0-254 range are to be declared as Device() objects in the ACPI namespace. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-16acpi: check for pxm_to_node_map overflowCyrill Gorcunov
It is hardly (if ever) possible but in case of broken _PXM entry we could reach out of pxm_to_node_map array bounds in acpi_map_pxm_to_node() call. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPI: remove private acpica headers from driver filesLin Ming
External driver files should not include any private acpica headers. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-11ACPI: Change acpi_evaluate_integer to support 64-bit on 32-bit kernelsMatthew Wilcox
As of version 2.0, ACPI can return 64-bit integers. The current acpi_evaluate_integer only supports 64-bit integers on 64-bit platforms. Change the argument to take a pointer to an acpi_integer so we support 64-bit integers on all platforms. lenb: replaced use of "acpi_integer" with "unsigned long long" lenb: fixed bug in acpi_thermal_trips_update() Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16ACPICA: Update DMAR and SRAT table definitionsBob Moore
Synchronized tables with current specifications. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-06-11ACPI: handle invalid ACPI SLIT tableFenghua Yu
This is a SLIT sanity checking patch. It moves slit_valid() function to generic ACPI code and does sanity checking for both x86 and ia64. It sets up node_distance with LOCAL_DISTANCE and REMOTE_DISTANCE when hitting invalid SLIT table on ia64. It also cleans up unused variable localities in acpi_parse_slit() on x86. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: misc cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - drivers/acpi/bay.c:dev_attr_eject - drivers/acpi/bay.c:dev_attr_present - drivers/acpi/dock.c:dev_attr_docked - drivers/acpi/dock.c:dev_attr_flags - drivers/acpi/dock.c:dev_attr_uid - drivers/acpi/dock.c:dev_attr_undock - drivers/acpi/pci_bind.c:acpi_pci_unbind() - drivers/acpi/pci_link.c:acpi_link_lock - drivers/acpi/sbs.c:acpi_sbs_callback() - drivers/acpi/sbshc.c:acpi_smbus_transaction() - drivers/acpi/sleep/main.c:acpi_sleep_prepare() - #if 0 the following unused global functions: - drivers/acpi/numa.c:acpi_unmap_pxm_to_node() - remove the following unused EXPORT_SYMBOL's: - acpi_register_gsi - acpi_unregister_gsi - acpi_strict - acpi_bus_receive_event - register_acpi_bus_type - unregister_acpi_bus_type - acpi_os_printf - acpi_os_sleep - acpi_os_stall - acpi_os_read_pci_configuration - acpi_os_create_semaphore - acpi_os_delete_semaphore - acpi_os_wait_semaphore - acpi_os_signal_semaphore - acpi_os_signal - acpi_pci_irq_enable - acpi_get_pxm Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-12-13ACPI: fix modpost warningsJan Beulich
for sn2_defconfig: WARNING: vmlinux.o(.text+0x4b8601): Section mismatch: reference to .init.data:node_to_pxm_map (between '__acpi_map_pxm_to_node' and 'acpi_get_pxm') WARNING: vmlinux.o(.text+0x4b8741): Section mismatch: reference to .init.data:pxm_to_node_map (between 'acpi_map_pxm_to_node' and 'acpi_get_node') Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21x86_64: fake pxm-to-node mapping for fake numaDavid Rientjes
For NUMA emulation, our SLIT should represent the true NUMA topology of the system but our proximity domain to node ID mapping needs to reflect the emulated state. When NUMA emulation has successfully setup fake nodes on the system, a new function, acpi_fake_nodes() is called. This function determines the proximity domain (_PXM) for each true node found on the system. It then finds which emulated nodes have been allocated on this true node as determined by its starting address. The node ID to PXM mapping is changed so that each fake node ID points to the PXM of the true node that it is located on. If the machine failed to register a SLIT, then we assume there is no special requirement for emulated node affinity so we use the default LOCAL_DISTANCE, which is newly exported to this code, as our measurement if the emulated nodes appear in the same PXM. Otherwise, we use REMOTE_DISTANCE. PXM_INVAL and NID_INVAL are also exported to the ACPI header file so that we can compare node_to_pxm() results in generic code (in this case, the SRAT code). Cc: Len Brown <lenb@kernel.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21x86_64: various cleanups in NUMA scan nodeDavid Rientjes
In acpi_scan_nodes(), we immediately return -1 if acpi_numa <= 0, meaning we haven't detected any underlying ACPI topology or we have explicitly disabled its use from the command-line with numa=noacpi. acpi_table_print_srat_entry() and acpi_table_parse_srat() are only referenced within drivers/acpi/numa.c, so we can mark them as static and remove their prototypes from the header file. Likewise, pxm_to_node_map[] and node_to_pxm_map[] are only used within drivers/acpi/numa.c, so we mark them as static and remove their externs from the header file. The automatic 'result' variable is unused in acpi_numa_init(), so it's removed. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-02ACPI: Section mismatch ... acpi_map_pxm_to_nodeLuck, Tony
Last of the "Section mismatch" errors from ia64 builds! acpi_map_pxm_to_node() is defined with attribute __cpuinit, but is called by "normal" kernel functions acpi_getnode() and acpi_map_cpu2node(). Commit f363d16fbb9374c0bd7f2757d412c287169094c9 moved the data structures on which this routine operates from __cpuinitdata to regular memory, so this routine can also move out of init space. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-17acpi: fix potential call to a freed memory section.Aaron Durbin
Strip __cpuinit[data] from Node <-> PXM routines and supporting data structures. Also make pxm_to_node_map and node_to_pxm_map local to the numa acpi module. This fixes a bug triggered by the following conditions: - boot on a machine with a SLIT table defined - kernel is configured w/ CONFIG_HOTPLUG_CPU=n - cat /sys/devices/system/node/node*/distance This will cause an oops by calling into a freed memory section. In particular, on x86_64, __node_distance calls node_to_pxm(). Signed-off-by: Aaron Durbin <adurbin@google.com> Cc: Len Brown <lenb@kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix unnecesary meminitYasunori Goto
This is to fix unnecessary __meminit definition. These are exported for kernel modules. I compiled on ia64/x86-64 with memory hotplug on/off. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix section mismatch of memory hotplug related code.Yasunori Goto
This is to fix many section mismatches of code related to memory hotplug. I checked compile with memory hotplug on/off on ia64 and x86-64 box. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13ACPI: acpi_table_parse_madt_family() is not MADT specificLen Brown
acpi_table_parse_madt_family() is also used to parse SRAT entries. So re-name it to acpi_table_parse_entries(), and re-name the madt-specific variables within it accordingly. cosmetic only. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-13ACPI: acpi_madt_entry_handler() is not MADT specificLen Brown
acpi_madt_entry_handler() is also used for the SRAT, so re-name it acpi_table_entry_handler(). cosmetic only. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-13ACPI: acpi_table_parse() now returns success/fail, not countLen Brown
Returning count for tables that are supposed to be unique was useless and confusing. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: clean up ACPI_MODULE_NAME() useLen Brown
cosmetic only Make "module name" actually match the file name. Invoke with ';' as leaving it off confuses Lindent and gcc doesn't care. Fix indentation where Lindent did get confused. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Remove duplicate table definitions (non-conflicting), contAlexey Starikovskiy
2006-10-14ACPI: Remove unnecessary from/to-void* and to-void casts in drivers/acpiJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-07-01ACPI: remove function tracing macros from drivers/acpi/*.cLen Brown
a few invocations appeared due to the SBS and other patches. Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-27[PATCH] pgdat allocation for new node add (get node id by acpi)Yasunori Goto
This is to find node id from acpi's handle of memory_device in DSDT. _PXM for the new node can be found by acpi_get_pxm() by using new memory's handle. So, node id can be found by pxm_to_nid_map[]. This patch becomes simpler than v2 of node hot-add patch. Because old add_memory() function doesn't have node id parameter. So, kernel must find its handle by physical address via DSDT again. But, v3 just give node id to add_memory() now. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Unify pxm_to_node() and node_to_pxm()Yasunori Goto
Consolidate the various arch-specific implementations of pxm_to_node() and node_to_pxm() into a single generic version. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
