path: root/drivers/acpi/pci_link.c
2008-02-07ACPI: misc cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - drivers/acpi/bay.c:dev_attr_eject - drivers/acpi/bay.c:dev_attr_present - drivers/acpi/dock.c:dev_attr_docked - drivers/acpi/dock.c:dev_attr_flags - drivers/acpi/dock.c:dev_attr_uid - drivers/acpi/dock.c:dev_attr_undock - drivers/acpi/pci_bind.c:acpi_pci_unbind() - drivers/acpi/pci_link.c:acpi_link_lock - drivers/acpi/sbs.c:acpi_sbs_callback() - drivers/acpi/sbshc.c:acpi_smbus_transaction() - drivers/acpi/sleep/main.c:acpi_sleep_prepare() - #if 0 the following unused global functions: - drivers/acpi/numa.c:acpi_unmap_pxm_to_node() - remove the following unused EXPORT_SYMBOL's: - acpi_register_gsi - acpi_unregister_gsi - acpi_strict - acpi_bus_receive_event - register_acpi_bus_type - unregister_acpi_bus_type - acpi_os_printf - acpi_os_sleep - acpi_os_stall - acpi_os_read_pci_configuration - acpi_os_create_semaphore - acpi_os_delete_semaphore - acpi_os_wait_semaphore - acpi_os_signal_semaphore - acpi_os_signal - acpi_pci_irq_enable - acpi_get_pxm Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-23ACPI: autoload modules - Create __mod_acpi_device_table symbol for all ACPI ↵Thomas Renninger
drivers modpost is going to use these to create e.g. acpi:ACPI0001 in modules.alias. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22ACPI: drivers/acpi/pci_link.c: lower printk severityDan Aloni
Signed-off-by: Dan Aloni <da-x@monatomic.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: delete extra #defines in /drivers/acpi/ driversLen Brown
Cosmetic only. Except in a single case, #define ACPI_*_DRIVER_NAME were invoked 0 or 1 times. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: fix acpi_driver.name usageLen Brown
It was erroneously used as a description rather than a name. ie. turn this: lenb@se7525gp2:/sys> ls bus/acpi/drivers ACPI AC Adapter Driver ACPI Embedded Controller Driver ACPI Power Resource Driver ACPI Battery Driver ACPI Fan Driver ACPI Processor Driver ACPI Button Driver ACPI PCI Interrupt Link Driver ACPI Thermal Zone Driver ACPI container driver ACPI PCI Root Bridge Driver hpet into this: lenb@se7525gp2:~> ls /sys/bus/acpi/drivers ac battery button container ec fan hpet pci_link pci_root power processor thermal Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: clean up ACPI_MODULE_NAME() useLen Brown
cosmetic only Make "module name" actually match the file name. Invoke with ';' as leaving it off confuses Lindent and gcc doesn't care. Fix indentation where Lindent did get confused. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: use new ACPI headers.Alexey Starikovskiy
2007-02-02ACPICA: Remove obsolete Flags parameter.Bob Moore
Remove flags parameter for acpi_{get,set}_register(). It is no longer necessary now that these functions use a spinlock for mutual exclusion. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-20ACPI: replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-16Pull style into test branchLen Brown
Conflicts: drivers/acpi/button.c drivers/acpi/ec.c drivers/acpi/osl.c drivers/acpi/sbs.c
2006-10-14ACPI: acpi_pci_link_set() can allocate with either GFP_ATOMIC or GFP_KERNELJiri Kosina
acpi_pci_link_set() allocates both with interrupts on and with interrupts off (resume-time), so check interrupts and decide on GFP_ATOMIC or GFP_KERNEL at run-time. Signed-off-by: Jiri Kosina <jikos@jikos.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-14ACPI: Remove unnecessary from/to-void* and to-void casts in drivers/acpiJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-07-10ACPI: acpi_os_allocate() fixesLen Brown
Replace acpi_in_resume with a more general hack to check irqs_disabled() on any kmalloc() from ACPI. While setting (system_state != SYSTEM_RUNNING) on resume seemed more general, Andrew Morton preferred this approach. http://bugzilla.kernel.org/show_bug.cgi?id=3469 Make acpi_os_allocate() into an inline function to allow /proc/slab_allocators to work. Delete some memset() that could fault on allocation failure. Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: pci_link: Remove unneeded acpi_handle from driver.Patrick Mochel
Signed-off-by: Patrick Mochel <mochel@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: pci_link: Use acpi_device's handle instead of driver'sPatrick Mochel
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
2006-06-27ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...)Len Brown
2006-06-27ACPI: un-export ACPI_WARNING() -- use printk(KERN_WARNING...)Len Brown
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
2006-06-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (65 commits) ACPI: suppress power button event on S3 resume ACPI: resolve merge conflict between sem2mutex and processor_perflib.c ACPI: use for_each_possible_cpu() instead of for_each_cpu() ACPI: delete newly added debugging macros in processor_perflib.c ACPI: UP build fix for bugzilla-5737 Enable P-state software coordination via _PDC P-state software coordination for speedstep-centrino P-state software coordination for acpi-cpufreq P-state software coordination for ACPI core ACPI: create acpi_thermal_resume() ACPI: create acpi_fan_suspend()/acpi_fan_resume() ACPI: pass pm_message_t from acpi_device_suspend() to root_suspend() ACPI: create acpi_device_suspend()/acpi_device_resume() ACPI: replace spin_lock_irq with mutex for ec poll mode ACPI: Allow a WAN module enable/disable on a Thinkpad X60. sem2mutex: acpi, acpi_link_lock ACPI: delete unused acpi_bus_drivers_lock sem2mutex: drivers/acpi/processor_perflib.c ACPI add ia64 exports to build acpi_memhotplug as a module ACPI: asus_acpi_init(): propagate correct return value ... Manual resolve of conflicts in: arch/i386/kernel/cpu/cpufreq/acpi-cpufreq.c arch/i386/kernel/cpu/cpufreq/speedstep-centrino.c include/acpi/processor.h
2006-06-19Make sure to re-enable SCI after an ACPI suspendLinus Torvalds
According to the ACPI spec, it should be enabled on return from suspend, but bugs happen. Apparently especially on the Apple Intel Macs. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-13sem2mutex: acpi, acpi_link_lockIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-26[ACPI] remove "Resource isn't an IRQ" warningLen Brown
In the case where a (broken) BIOS gives us a blank _CRS for a PCI Interrupt Link Device, the acpi_walk_resources() will not terminate, but will then give the callback the resource end tag. Ignore the end tag. Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-07Pull pnpacpi into acpica branchLen Brown
2005-12-12[PATCH] ACPI: fix sleeping whilst atomic warnings on resumeDave Jones
This has been broken for months. On resume, we call acpi_pci_link_set() with interrupts off, so we get a warning when we try to do a kmalloc of non atomic memory. The actual allocation is just 2 long's (plus extra byte for some reason I can't fathom), so a simple conversion to GFP_ATOMIC is probably the safest way to fix this. The error looks like this.. Debug: sleeping function called from invalid context at mm/slab.c:2486 in_atomic():0, irqs_disabled():1 [<c0143f6c>] kmem_cache_alloc+0x40/0x56 [<c0206a2e>] acpi_pci_link_set+0x3f/0x17f [<c0206f96>] irqrouter_resume+0x1e/0x3c [<c0239bca>] __sysdev_resume+0x11/0x6b [<c0239e88>] sysdev_resume+0x34/0x52 [<c023de21>] device_power_up+0x5/0xa Signed-off-by: Dave Jones <davej@redhat.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-10[ACPI] ACPICA 20050930Bob Moore
Completed a major overhaul of the Resource Manager code - specifically, optimizations in the area of the AML/internal resource conversion code. The code has been optimized to simplify and eliminate duplicated code, CPU stack use has been decreased by optimizing function parameters and local variables, and naming conventions across the manager have been standardized for clarity and ease of maintenance (this includes function, parameter, variable, and struct/typedef names.) All Resource Manager dispatch and information tables have been moved to a single location for clarity and ease of maintenance. One new file was created, named "rsinfo.c". The ACPI return macros (return_ACPI_STATUS, etc.) have been modified to guarantee that the argument is not evaluated twice, making them less prone to macro side-effects. However, since there exists the possibility of additional stack use if a particular compiler cannot optimize them (such as in the debug generation case), the original macros are optionally available. Note that some invocations of the return_VALUE macro may now cause size mismatch warnings; the return_UINT8 and return_UINT32 macros are provided to eliminate these. (From Randy Dunlap) Implemented a new mechanism to enable debug tracing for individual control methods. A new external interface, acpi_debug_trace(), is provided to enable this mechanism. The intent is to allow the host OS to easily enable and disable tracing for problematic control methods. This interface can be easily exposed to a user or debugger interface if desired. See the file psxface.c for details. acpi_ut_callocate() will now return a valid pointer if a length of zero is specified - a length of one is used and a warning is issued. This matches the behavior of acpi_ut_allocate(). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-09-22[ACPI] handle ACPICA 20050916's acpi_resource.type renameLen Brown
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-08-05[ACPI] whitespacePavel Machek
Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Merge acpi-2.6.12 branch into 2.6.13-rc3Len Brown
2005-08-04[ACPI] lint: irqrouter_suspend() takes a pm_message_t, not a u32Andrew Morton
2005-08-03[ACPI] S3 resume: avoid kmalloc() might_sleep oops symptomDavid Shaohua Li
ACPI now uses kmalloc(...,GPF_ATOMIC) during suspend/resume. http://bugzilla.kernel.org/show_bug.cgi?id=3469 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-03/home/lenb/src/to-linus branch 'acpi-2.6.12'Len Brown
2005-08-03[ACPI] PCI interrupt link suspend/resume - revert to 2.6.12 behaviourDavid Shaohua Li
This patch disables the PCI Interrupt Link refernece counts, which should not co-exist with the 2.6.12 irq_router.resume method or else a double acpi_pci_link_set() could result on resume. Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-01Revert ACPI interrupt resume changesLinus Torvalds
If there are devices that use interrupts over a suspend event, ACPI must restore the PCI interrupt links on resume. Anything else breaks any device that hasn't been converted to the new (dubious) PM rules. Drivers that need the irq free/re-aquire sequence can be done one by one independently of this one.
2005-07-29[ACPI] suspend/resume ACPI PCI Interrupt LinksDavid Shaohua Li
Add reference count and disable ACPI PCI Interrupt Link when no device still uses it. Warn when drivers have not released Link at suspend time. http://bugzilla.kernel.org/show_bug.cgi?id=3469 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[ACPI] PNPACPI vs sound IRQDavid Shaohua Li
http://bugme.osdl.org/show_bug.cgi?id=4016 Written-by: David Shaohua Li <shaohua.li@intel.com> Acked-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] S3 Suspend to RAM: interrupt resume fixDavid Shaohua Li
Delete PCI Interrupt Link Device .resume method -- it is the device driver's job to request interrupts, not the Link's job to remember what the devices want. This addresses the issue of attempting to run the ACPI interpreter too early in resume, when interrupts are still disabled. http://bugzilla.kernel.org/show_bug.cgi?id=3469 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
