There is no need to carry potentially outdated Free Software Foundation
mailing address in file headers since the COPYING file includes it.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
There is no need to have processor_power_dmi_table[] writeable, constify
it.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Pull timer updates from Ingo Molnar:
"The main changes in this cycle were:
- clockevents state machine cleanups and enhancements (Viresh Kumar)
- clockevents broadcast notifier horror to state machine conversion
and related cleanups (Thomas Gleixner, Rafael J Wysocki)
- clocksource and timekeeping core updates (John Stultz)
- clocksource driver updates and fixes (Ben Dooks, Dmitry Osipenko,
Hans de Goede, Laurent Pinchart, Maxime Ripard, Xunlei Pang)
- y2038 fixes (Xunlei Pang, John Stultz)
- NMI-safe ktime_get_raw_fast() and general refactoring of the clock
code, in preparation to perf's per event clock ID support (Peter
Zijlstra)
- generic sched/clock fixes, optimizations and cleanups (Daniel
Thompson)
- clockevents cpu_down() race fix (Preeti U Murthy)"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (94 commits)
timers/PM: Drop unnecessary braces from tick_freeze()
timers/PM: Fix up tick_unfreeze()
timekeeping: Get rid of stale comment
clockevents: Cleanup dead cpu explicitely
clockevents: Make tick handover explicit
clockevents: Remove broadcast oneshot control leftovers
sched/idle: Use explicit broadcast oneshot control function
ARM: Tegra: Use explicit broadcast oneshot control function
ARM: OMAP: Use explicit broadcast oneshot control function
intel_idle: Use explicit broadcast oneshot control function
ACPI/idle: Use explicit broadcast control function
ACPI/PAD: Use explicit broadcast oneshot control function
x86/amd/idle, clockevents: Use explicit broadcast oneshot control functions
clockevents: Provide explicit broadcast oneshot control functions
clockevents: Remove the broadcast control leftovers
ARM: OMAP: Use explicit broadcast control function
intel_idle: Use explicit broadcast control function
cpuidle: Use explicit broadcast control function
ACPI/processor: Use explicit broadcast control function
ACPI/PAD: Use explicit broadcast control function
Fix a bug that leads to showing the name and description of C-state C0
as "<null>" in sysfs after the ACPI C-states changed (e.g. after AC->DC
or DC->AC
transition).
The function poll_idle_init() in drivers/cpuidle/driver.c initializes the
state 0 during cpuidle_register_driver(), so we better do not overwrite it
again with '\0' during acpi_processor_cst_has_changed().
Signed-off-by: Thomas Schlichter <thomas.schlichter@web.de>
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: 3.13+ <stable@vger.kernel.org> # 3.13+
Replace the clockevents_notify() call with an explicit function call.
Link: http://lkml.kernel.org/r/2653377.MSAlfA939I@vostro.rjw.lan
Link: http://lkml.kernel.org/r/25071624.dkenaL3SGT@vostro.rjw.lan
Add an ->enter_freeze callback routine, acpi_idle_enter_freeze(), to
the ACPI cpuidle driver and point ->enter_freeze to it for all the
C2-type and C3-type states that don't need to fall back to C1
(which may be halt-induced and that will re-enable interrupts on
exit from idle, which ->enter_freeze cannot do).
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Introduce a common ->enter callback routine for the ACPI cpuidle
driver, acpi_idle_enter(), which helps to reduce code complexity,
size and duplication and prevents theoretically possible failues that
an incorrect routine may be run to enter the given idle state due to
a firmware bug (eg. when _CST returns a different set of states for
each processor).
acpi_idle_enter_c1() and acpi_idle_enter_simple() are close enough to
each other that they can be merged into one function which reduces
duplication of code quite a bit.
Since acpi_idle_enter_bm() is only used if flags.bm_check is set for
the given acpi_processor object, it doesn't make sense to check that
flag in there.
For this reason, drop flags.bm_check tests (and some code depending
on them) from acpi_idle_enter_bm().
White space in the switch statement in acpi_processor_setup_cpuidle_states()
does not adhere to the kernel coding style and that makes the code
difficult to read. Clean that up.
The comment about bus master disable in acpi_idle_enter_simple() is
irrelevant, because the function doesn't disable bus mastering, so
drop it.
acpi_idle_enter_simple() and acpi_idle_enter_bm() both check
if C2/C3 type entry is supported on MP in the same way, so move
those checks to a separate function and call it from both
places (and it doesn't need to check if the state type is not
C1, because the functions in question won't be called otherwise).
While at it, use IS_ENABLED() for the CONFIG_HOTPLUG_CPU check.
acpi_idle_enter_simple() and acpi_idle_enter_bm() don't need to
call sched_clock_idle_sleep/wakeup_event(), because that's taken
care of by the core already. Namely, sched_clock_idle_sleep_event()
is called by tick_nohz_start_idle() called by __tick_nohz_idle_enter()
which in turn is called by tick_nohz_idle_enter() and that is called
by cpu_idle_loop(). Analogously for sched_clock_idle_wakeup_event().
For this reason, drop those calls from the ACPI cpuidle driver's
->enter callback routines.
Since the cpuidle core calls stop_critical_timings() and
start_critical_timings() around the execution of ->enter callbacks,
acpi_idle_do_entry() doesn't need to do that (and really shouldn't).
Also using "inline" on it is pointless and the kerneldoc entry does
not reflect the actual situation any more.
Fix all of the above.
* pm-cpufreq:
cpufreq: fix a NULL pointer dereference in __cpufreq_governor()
cpufreq-dt: defer probing if OPP table is not ready
* pm-cpuidle:
cpuidle / ACPI: remove unused CPUIDLE_FLAG_TIME_INVALID
cpuidle: ladder: Better idle duration measurement without using CPUIDLE_FLAG_TIME_INVALID
cpuidle: menu: Better idle duration measurement without using CPUIDLE_FLAG_TIME_INVALID
CPUIDLE_FLAG_TIME_INVALID is no longer checked
by menu or ladder cpuidle governors, so don't
bother setting or defining it.
It was originally invented to account for the fact that
acpi_safe_halt() enables interrupts to invoke HLT.
That would allow interrupt service routines to be included
in the last_idle duration measurements made in cpuidle_enter_state(),
potentially returning a duration much larger than reality.
But menu and ladder can gracefully handle erroneously large duration
intervals without checking for CPUIDLE_FLAG_TIME_INVALID.
Further, if they don't check CPUIDLE_FLAG_TIME_INVALID, they
can also benefit from the instances when the duration interval
is not erroneously large.
Signed-off-by: Len Brown <len.brown@intel.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
* pm-cpuidle:
cpuidle: add MAINTAINERS entry for ARM Exynos cpuidle driver
drivers: cpuidle: Remove cpuidle-arm64 duplicate error messages
drivers: cpuidle: Add idle-state-name description to ARM idle states
drivers: cpuidle: Add status property to ARM idle states
cpuidle: Invert CPUIDLE_FLAG_TIME_VALID logic
It's incorrect to assign a signed value to an unsigned acpi_status
variable. This patch fixes it by using a signed integer to return
error values.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
The only place where the time is invalid is when the ACPI_CSTATE_FFH entry
method is not set. Otherwise for all the drivers, the time can be correctly
measured.
Instead of duplicating the CPUIDLE_FLAG_TIME_VALID flag in all the drivers
for all the states, just invert the logic by replacing it by the flag
CPUIDLE_FLAG_TIME_INVALID, hence we can set this flag only for the acpi idle
driver, remove the former flag from all the drivers and invert the logic with
this flag in the different governor.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
There is a following AB-BA dependency between cpu_hotplug.lock and
cpuidle_lock:
1) cpu_hotplug.lock -> cpuidle_lock
enable_nonboot_cpus()
_cpu_up()
cpu_hotplug_begin()
LOCK(cpu_hotplug.lock)
cpu_notify()
acpi_processor_hotplug()
cpuidle_pause_and_lock()
LOCK(cpuidle_lock)
2) cpuidle_lock -> cpu_hotplug.lock
acpi_os_execute_deferred() workqueue
LOCK(cpuidle_lock)
get_online_cpus()
Fix this by reversing the order acpi_processor_cst_has_changed() does
thigs -- let it first execute the protection against CPU hotplug by
calling get_online_cpus() and obtain the cpuidle lock only after that (and
perform the symmentric change when allowing CPUs hotplug again and
dropping cpuidle lock).
Spotted by lockdep.
Cc: All applicable <stable@vger.kernel.org>
Pull ACPI and power management updates from Rafael Wysocki:
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
* pm-cpuidle:
intel_idle: remove superfluous dev->state_count initialization
intel_idle: do C1E promotion disable quirk for hotplugged CPUs
ACPI / cpuidle: remove dev->state_count setting
ACPI / cpuidle: fix max idle state handling with hotplug CPU support
POWERPC: pseries: cpuidle: use the common cpuidle_[un]register() routines
POWERPC: pseries: cpuidle: remove superfluous dev->state_count initialization
ARM: EXYNOS: cpuidle: fix AFTR mode check
dev->state_count is now always equal to drv->state_count and
drv->state_count no longer can change during driver's lifetime so
the default dev->state_count initialization in cpuidle_enable_device()
(called from cpuidle_register_device()) can be used instead.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Len Brown <lenb@kernel.org>
acpi_processor_hotplug() calls acpi_processor_setup_cpuidle_cx()
without calling acpi_processor_setup_cpuidle_states() first so it
is possible that dev->state_count becomes different from
drv->state_count (in case of SMP system with unsupported C2/C3
states + enabled CPU hotplug and num_online_cpus() becoming > 1).
The driver code assumes that cpuidle core will handle such cases
but currently this is untrue (dev->state_count is used only for
handling cpuidle state sysfs entries and drv->state_count is used
for all other cases) and will not be fixed in the future as
dev->state_count is planned to be removed.
Fix the issue by checking for the max supported idle state in
C2/C3 state's ->enter handler (acpi_idle_enter_simple() for C2/C3
and acpi_idle_enter_bm() for C3 + bm_check flag set) and setting
the C1 state (instead of higher states) when needed.
Also remove no longer needed max idle state checks from
acpi_processor_setup_cpuidle_[states,cx]().
People seem to delight in writing wrong and broken mwait idle routines;
collapse the lot.
This leaves mwait_play_dead() the sole remaining user of __mwait() and
new __mwait() users are probably doing it wrong.
Also remove __sti_mwait() as its unused.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Jacob Jun Pan <jacob.jun.pan@linux.intel.com>
Cc: Mike Galbraith <bitbucket@online.de>
Cc: Rui Zhang <rui.zhang@intel.com>
Acked-by: Rafael Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20131212141654.616820819@infradead.org
In acpi_processor_resume(), the variable resumed_bm_rld is being
used without being initialized, so initialize it.
Signed-off-by: Al Stone <al.stone@linaro.org>
Minor cleanup: remove some extra trailing white space.
Replace direct inclusions of <acpi/acpi.h>, <acpi/acpi_bus.h> and
<acpi/acpi_drivers.h>, which are incorrect, with <linux/acpi.h>
inclusions and remove some inclusions of those files that aren't
necessary.
First of all, <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h>
should not be included directly from any files that are built for
CONFIG_ACPI unset, because that generally leads to build warnings about
undefined symbols in !CONFIG_ACPI builds. For CONFIG_ACPI set,
<linux/acpi.h> includes those files and for CONFIG_ACPI unset it
provides stub ACPI symbols to be used in that case.
Second, there are ordering dependencies between those files that always
have to be met. Namely, it is required that <acpi/acpi_bus.h> be included
prior to <acpi/acpi_drivers.h> so that the acpi_pci_root declarations the
latter depends on are always there. And <acpi/acpi.h> which provides
basic ACPICA type declarations should always be included prior to any other
ACPI headers in CONFIG_ACPI builds. That also is taken care of including
<linux/acpi.h> as appropriate.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Acked-by: Bjorn Helgaas <bhelgaas@google.com> (drivers/pci stuff)
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> (Xen stuff)
Pull ACPI and power management updates from Rafael J Wysocki:
- New power capping framework and the the Intel Running Average Power
Limit (RAPL) driver using it from Srinivas Pandruvada and Jacob Pan.
- Addition of the in-kernel switching feature to the arm_big_little
cpufreq driver from Viresh Kumar and Nicolas Pitre.
- cpufreq support for iMac G5 from Aaro Koskinen.
- Baytrail processors support for intel_pstate from Dirk Brandewie.
- cpufreq support for Midway/ECX-2000 from Mark Langsdorf.
- ARM vexpress/TC2 cpufreq support from Sudeep KarkadaNagesha.
- ACPI power management support for the I2C and SPI bus types from Mika
Westerberg and Lv Zheng.
- cpufreq core fixes and cleanups from Viresh Kumar, Srivatsa S Bhat,
Stratos Karafotis, Xiaoguang Chen, Lan Tianyu.
- cpufreq drivers updates (mostly fixes and cleanups) from Viresh
Kumar, Aaro Koskinen, Jungseok Lee, Sudeep KarkadaNagesha, Lukasz
Majewski, Manish Badarkhe, Hans-Christian Egtvedt, Evgeny Kapaev.
- intel_pstate updates from Dirk Brandewie and Adrian Huang.
- ACPICA update to version 20130927 includig fixes and cleanups and
some reduction of divergences between the ACPICA code in the kernel
and ACPICA upstream in order to improve the automatic ACPICA patch
generation process. From Bob Moore, Lv Zheng, Tomasz Nowicki, Naresh
Bhat, Bjorn Helgaas, David E Box.
- ACPI IPMI driver fixes and cleanups from Lv Zheng.
- ACPI hotplug fixes and cleanups from Bjorn Helgaas, Toshi Kani, Zhang
Yanfei, Rafael J Wysocki.
- Conversion of the ACPI AC driver to the platform bus type and
multiple driver fixes and cleanups related to ACPI from Zhang Rui.
- ACPI processor driver fixes and cleanups from Hanjun Guo, Jiang Liu,
Bartlomiej Zolnierkiewicz, Mathieu Rhéaume, Rafael J Wysocki.
- Fixes and cleanups and new blacklist entries related to the ACPI
video support from Aaron Lu, Felipe Contreras, Lennart Poettering,
Kirill Tkhai.
- cpuidle core cleanups from Viresh Kumar and Lorenzo Pieralisi.
- cpuidle drivers fixes and cleanups from Daniel Lezcano, Jingoo Han,
Bartlomiej Zolnierkiewicz, Prarit Bhargava.
- devfreq updates from Sachin Kamat, Dan Carpenter, Manish Badarkhe.
- Operation Performance Points (OPP) core updates from Nishanth Menon.
- Runtime power management core fix from Rafael J Wysocki and update
from Ulf Hansson.
- Hibernation fixes from Aaron Lu and Rafael J Wysocki.
- Device suspend/resume lockup detection mechanism from Benoit Goby.
- Removal of unused proc directories created for various ACPI drivers
from Lan Tianyu.
- ACPI LPSS driver fix and new device IDs for the ACPI platform scan
handler from Heikki Krogerus and Jarkko Nikula.
- New ACPI _OSI blacklist entry for Toshiba NB100 from Levente Kurusa.
- Assorted fixes and cleanups related to ACPI from Andy Shevchenko, Al
Stone, Bartlomiej Zolnierkiewicz, Colin Ian King, Dan Carpenter,
Felipe Contreras, Jianguo Wu, Lan Tianyu, Yinghai Lu, Mathias Krause,
Liu Chuansheng.
- Assorted PM fixes and cleanups from Andy Shevchenko, Thierry Reding,
Jean-Christophe Plagniol-Villard.
* tag 'pm+acpi-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (386 commits)
cpufreq: conservative: fix requested_freq reduction issue
ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines
PM / runtime: Use pm_runtime_put_sync() in __device_release_driver()
ACPI / event: remove unneeded NULL pointer check
Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1"
ACPI / video: Quirk initial backlight level 0
ACPI / video: Fix initial level validity test
intel_pstate: skip the driver if ACPI has power mgmt option
PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
ACPI / hotplug: Do not execute "insert in progress" _OST
ACPI / hotplug: Carry out PCI root eject directly
ACPI / hotplug: Merge device hot-removal routines
ACPI / hotplug: Make acpi_bus_hot_remove_device() internal
ACPI / hotplug: Simplify device ejection routines
ACPI / hotplug: Fix handle_root_bridge_removal()
ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug
ACPI / scan: Start matching drivers after trying scan handlers
ACPI: Remove acpi_pci_slot_init() headers from internal.h
ACPI / blacklist: fix name of ThinkPad Edge E530
PowerCap: Fix build error with option -Werror=format-security
arch/arm/mach-omap2/opp.c
drivers/Kconfig
drivers/spi/spi.c
Mike reported that commit 7d1a9417 ("x86: Use generic idle loop")
regressed several workloads and caused excessive reschedule
interrupts.
The patch in question failed to notice that the x86 code had an
inverted sense of the polling state versus the new generic code (x86:
default polling, generic: default !polling).
Fix the two prominent x86 mwait based idle drivers and introduce a few
new generic polling helpers (fixing the wrong smp_mb__after_clear_bit
usage).
Also switch the idle routines to using tif_need_resched() which is an
immediate TIF_NEED_RESCHED test as opposed to need_resched which will
end up being slightly different.
Reported-by: Mike Galbraith <bitbucket@online.de>
Cc: lenb@kernel.org
Cc: tglx@linutronix.de
Link: http://lkml.kernel.org/n/tip-nc03imb0etuefmzybzj7sprf@git.kernel.org
The only acpi_processor_get_power_info_fadt() user
(acpi_processor_get_power_info()) dereferences pr before calling
the function.
The only acpi_processor_hotplug() user (acpi_cpu_soft_notify())
checks for pr == NULL before calling the function.
The only acpi_processor_cst_has_changed() user (acpi_processor_notify())
The only acpi_processor_power_init() user (__acpi_processor_start())
dereferences pr before calling the function.
Thus remove superfluous pr == NULL checks from affected functions.
Also:
While at it remove redundant brackets from acpi_processor_hotplug().
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
This removes all the drivers/acpi uses of the __cpuinit macros
from all C files.
[1] https://lkml.org/lkml/2013/5/20/589
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: linux-acpi@vger.kernel.org
Since acpi_processor_suspend() and acpi_processor_resume() need not
be visible outside of the file they are defined in, make them
static.
[rjw: Changelog]
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
The system suspend routine of the ACPI processor driver saves
the BUS_MASTER_RLD register and its resume routine restores it.
However, there can be only one such register in the system and it
really should be saved after non-boot CPUs have been offlined and
restored before they are put back online during resume.
For this reason, move the saving and restoration of BUS_MASTER_RLD
to syscore suspend and syscore resume, respectively, and drop the no
longer necessary suspend/resume callbacks from the ACPI processor
driver.
The en_core_tk_irqen flag is set in all the cpuidle driver which
means it is not necessary to specify this flag.
Remove the flag and the code related to it.
Acked-by: Kevin Hilman <khilman@linaro.org> # for mach-omap2/*
Commit ac3ebafa81af76d6 "ACPI / idle: remove usage of the statedata"
changed the percpu processor cstate to a unified cstate in ACPI idle.
That caused all our NHM boxes to boot hang or panic.
2178751 Task dump for CPU 1:
2178752 swapper/1 R running task 6736 0 1 0x00000000
2178753 ffff8801e8029dc8 ffffffff8101cf96 ffff8801e8029e28 ffffffff813d294b
2178754 0000000000000f99 0000000000000003 00000000003cf654 0000000025c17d03
2178755 ffff8801e8029e38 ffff8801e74fc000 00000002590dc5c4 ffffffff8163cdb0
2178756 Call Trace:
2178757 [<ffffffff8101cf96>] ? acpi_processor_ffh_cstate_enter+0x2d/0x2f
2178758 [<ffffffff813d294b>] acpi_idle_enter_bm+0x1b1/0x236
2178759 [<ffffffff8163cdb0>] ? disable_cpuidle+0x10/0x10
2178760 [<ffffffff8163cdc2>] cpuidle_enter+0x12/0x14
2178761 [<ffffffff8163d286>] cpuidle_wrap_enter+0x2f/0x6d
2178762 [<ffffffff8163d2d4>] cpuidle_enter_tk+0x10/0x12
2178763 [<ffffffff8163cdd6>] cpuidle_enter_state+0x12/0x3a
2178764 [<ffffffff8163d4a7>] cpuidle_idle_call+0xe8/0x161
2178765 [<ffffffff81008d99>] cpu_idle+0x5e/0xa4
2178766 [<ffffffff8174c6c1>] start_secondary+0x1a9/0x1ad
2178767 Task dump for CPU 2:
In fact, the ACPI idle is based on the assumption of difference percpu
cstate structures that are necessary for the implementation to work
cprrectly. A unique acpi_processor_cx is not sifficient by far.
This patch is just a quick fix re-introducing the percpu cstates.
If someone really wants to unify the ACPI cstates, please make sure
that the whole software infrastructure is changed and take hardware
as well as many different kinds of BIOS settings into account.
[rjw: Changelog]
Reported-by: LKP project <lkp@linux.intel.com>
Reported-by: Xie ChanglongX <changlongx.xie@intel.com>
Tested-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Alex Shi <alex.shi@intel.com>
arch/x86/kernel/process.c
mwait_idle() is a C1-only idle loop intended to be more efficient
than HLT, starting on Pentium-4 HT-enabled processors.
But mwait_idle() has been replaced by the more general
mwait_idle_with_hints(), which handles both C1 and deeper C-states.
ACPI processor_idle and intel_idle use only mwait_idle_with_hints(),
and no longer use mwait_idle().
Here we simplify the x86 native idle code by removing mwait_idle(),
and the "idle=mwait" bootparam used to invoke it.
Since Linux 3.0 there has been a boot-time warning when "idle=mwait"
was invoked saying it would be removed in 2012. This removal
was also noted in the (now removed:-) feature-removal-schedule.txt.
After this change, kernels configured with
(CONFIG_ACPI=n && CONFIG_INTEL_IDLE=n) when run on hardware
that supports MWAIT will simply use HLT. If MWAIT is desired
on those systems, cpuidle and the cpuidle drivers above
can be enabled.
Cc: x86@kernel.org
Len Brown sent a patch to remove this field in the intel_idle driver.
The other user of this field is the davinci cpuidle driver and a
patch has been sent to remove the usage of it.
This patch removes the last user of this field.
The cpuidle_device is retrieved in the function by using directly
the global variable. But the caller of this function already have
this device and it can be passed as a parameter. That is one small
step to encapsulate the code more.
These different headers are not needed.
The different definitions are not used anywhere in the code.
acpi_processor_get_power_info() has to be called before
acpi_processor_setup_cpuidle_states() to have the latest
information available. This fixes the missing C-state information
after AC-->DC transition.
Cc: <stable@vger.kernel.org>
If cpuidle is disabled, that means that:
per_cpu(acpi_cpuidle_device, pr->id)
is set to NULL as the acpi_processor_power_init ends up failing at
retval = cpuidle_register_driver(&acpi_idle_driver)
(in acpi_processor_power_init) and never sets the per_cpu idle
device. So when acpi_processor_hotplug on CPU online notification
tries to reference said device it crashes:
cpu 3 spinlock event irq 62
BUG: unable to handle kernel NULL pointer dereference at 0000000000000004
IP: [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105
PGD a259b067 PUD ab38b067 PMD 0
Oops: 0002 [#1] SMP
odules linked in: dm_multipath dm_mod xen_evtchn iscsi_boot_sysfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi libcrc32c crc32c nouveau mxm_wmi wmi radeon ttm sg sr_mod sd_mod cdrom ata_generic ata_piix libata crc32c_intel scsi_mod atl1c i915 fbcon tileblit font bitblit softcursor drm_kms_helper video xen_blkfront xen_netfront fb_sys_fops sysimgblt sysfillrect syscopyarea xenfs xen_privcmd mperf
CPU 1
Pid: 3047, comm: bash Not tainted 3.8.0-rc3upstream-00250-g165c029 #1 MSI MS-7680/H61M-P23 (MS-7680)
RIP: e030:[<ffffffff81381013>] [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105
RSP: e02b:ffff88001742dca8 EFLAGS: 00010202
RAX: 0000000000010be9 RBX: ffff8800a0a61800 RCX: ffff880105380000
RDX: 0000000000000003 RSI: 0000000000000200 RDI: ffff8800a0a61800
RBP: ffff88001742dce8 R08: ffffffff81812360 R09: 0000000000000200
R10: aaaaaaaaaaaaaaaa R11: 0000000000000001 R12: ffff8800a0a61800
R13: 00000000ffffff01 R14: 0000000000000000 R15: ffffffff81a907a0
FS: 00007fd6942f7700(0000) GS:ffff880105280000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 0000000000000004 CR3: 00000000a6773000 CR4: 0000000000042660
Process bash (pid: 3047, threadinfo ffff88001742c000, task ffff880017944000)
Stack:
0000000000000150 ffff880100f59e00 ffff88001742dcd8 ffff8800a0a61800
0000000000000000 00000000ffffff01 0000000000000000 ffffffff81a907a0
ffff88001742dd18 ffffffff813815b1 ffff88001742dd08 ffffffff810ae336
Call Trace:
[<ffffffff813815b1>] acpi_processor_hotplug+0x7c/0x9f
[<ffffffff810ae336>] ? schedule_delayed_work_on+0x16/0x20
[<ffffffff8137ee8f>] acpi_cpu_soft_notify+0x90/0xca
[<ffffffff8166023d>] notifier_call_chain+0x4d/0x70
[<ffffffff810bc369>] __raw_notifier_call_chain+0x9/0x10
[<ffffffff81094a4b>] __cpu_notify+0x1b/0x30
[<ffffffff81652cf7>] _cpu_up+0x103/0x14b
[<ffffffff81652e18>] cpu_up+0xd9/0xec
[<ffffffff8164a254>] store_online+0x94/0xd0
[<ffffffff814122fb>] dev_attr_store+0x1b/0x20
[<ffffffff81216404>] sysfs_write_file+0xf4/0x170
This patch fixes it.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Many cpuidle drivers measure their time spent in an idle state by
reading the wallclock time before and after idling and calculating the
difference. This leads to erroneous results when the wallclock time gets
updated by another processor in the meantime, adding that clock
adjustment to the idle state's time counter.
If the clock adjustment was negative, the result is even worse due to an
erroneous cast from int to unsigned long long of the last_residency
variable. The negative 32 bit integer will zero-extend and result in a
forward time jump of roughly four billion milliseconds or 1.3 hours on
the idle state residency counter.
This patch changes all affected cpuidle drivers to either use the
monotonic clock for their measurements or make use of the generic time
measurement wrapper in cpuidle.c, which was already working correctly.
Some superfluous CLIs/STIs in the ACPI code are removed (interrupts
should always already be disabled before entering the idle function, and
not get reenabled until the generic wrapper has performed its second
measurement). It also removes the erroneous cast, making sure that
negative residency values are applied correctly even though they should
not appear anymore.
Signed-off-by: Julius Werner <jwerner@chromium.org>
Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Tested-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Len Brown <len.brown@intel.com>
The dereference should be moved below the NULL test.
dpatch engine is used to auto generate this patch.
(https://github.com/weiyj/dpatch)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
structure
Currently we have the cpuidle_device field in the acpi_processor_power structure.
This adds a dependency between processor.h and cpuidle.h
Although it is not a real problem, removing this dependency has the benefit of
separating a bit more the cpuidle code from the rest of the acpi code.
Also, the compilation should be a bit improved because we do no longer
include cpuidle.h in processor.h. The preprocessor was generating 30418 loc
and with this patch it generates 30256 loc for processor_thermal.c, a file
which is not concerned at all by cpuidle, like processor_perflib.c and
processor_throttling.c.
That may sound ridiculous, but "small streams make big rivers" :P
This patch moves this field into a static global per cpu variable like what is
done in the intel_idle driver.
The 'device' parameter is not used neither in acpi_processor_power_init
and acpi_processor_power_exit. This patch removes it.
Remove the unused power field from struct struct acpi_processor_cx.
[rjw: Modified changelog.]
