path: root/drivers/acpi/processor_idle.c
2007-09-22ACPI: disable lower idle C-states across suspend/resumeThomas Gleixner
device_suspend() calls ACPI suspend functions, which seems to have undesired side effects on lower idle C-states. It took me some time to realize that especially the VAIO BIOSes (both Andrews jinxed UP and my elfstruck SMP one) show this effect. I'm quite sure that other bug reports against suspend/resume about turning the system into a brick have the same root cause. After fishing in the dark for quite some time, I realized that removing the ACPI processor module before suspend (this removes the lower C-state functionality) made the problem disappear. Interestingly enough the propability of having a bricked box is influenced by various factors (interrupts, size of the ram image, ...). Even adding a bunch of printks in the wrong places made the problem go away. The previous periodic tick implementation simply pampered over the problem, which explains why the dyntick / clockevents changes made this more prominent. We avoid complex functionality during the boot process and we have to do the same during suspend/resume. It is a similar scenario and equaly fragile. Add suspend / resume functions to the ACPI processor code and disable the lower idle C-states across suspend/resume. Fall back to the default idle implementation (halt) instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Len Brown <lenb@kernel.org> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-23sched: sched_clock_idle_[sleep|wakeup]_event()Ingo Molnar
construct a more or less wall-clock time out of sched_clock(), by using ACPI-idle's existing knowledge about how much time we spent idling. This allows the rq clock to work around TSC-stops-in-C2, TSC-gets-corrupted-in-C3 type of problems. ( Besides the scheduler's statistics this also benefits blktrace and printk-timestamps as well. ) Furthermore, the precise before-C2/C3-sleep and after-C2/C3-wakeup callbacks allow the scheduler to get out the most of the period where the CPU has a reliable TSC. This results in slightly more precise task statistics. the ACPI bits were acked by Len. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Len Brown <len.brown@intel.com>
2007-08-07ACPI: fix "Time Problems with 2.6.23-rc1-gf695baf2"Venki Pallipadi
Enable C3 without bm control only for CST based C3. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22Pull misc into release branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt
2007-07-20[IA64] Convert to generic timekeeping/clocksourceTony Luck
This is a merge of Peter Keilty's initial patch (which was revived by Bob Picco) for this with Hidetoshi Seto's fixes and scaling improvements. Acked-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-18ACPI: Enable C3 even when PM2_control is zeroVenkatesh Pallipadi
On systems that do not have pm2_control_block, we cannot really use ARB_DISABLE before C3. We used to disable C3 totally on such systems. To be compatible with Windows, we need to enable C3 on such systems now. We just skip ARB_DISABLE step before entering the C3-state and assume hardware is handling things correctly. Also, ACPI spec is not clear about pm2_control is _needed_ for C3 or not. We have atleast one system that need this to enable C3. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-06-23ACPI: fix 2.6.20 SMP boot regressionVenkatesh Pallipadi
Always disable/enable interrupts in the acpi idle routine, even in the error path. This is required as the 2.6.20 change in git commit d331e739f5ad2aaa9... "Fix interrupt race in idle callback" expects the idle handler to enable interrupt before returning. There was a case in acpi idle routine, in which interrupt was not being enabled before return, which caused the system to hang at bootup, while enabling C-states on an SMP system. The signature of the hang was that "processor.nocst" was required to enable boot. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-02[PATCH] x86: Log reason why TSC was marked unstablejohn stultz
Change mark_tsc_unstable() so it takes a string argument, which holds the reason the TSC was marked unstable. This is then displayed the first time mark_tsc_unstable is called. This should help us better debug why the TSC was marked unstable on certain systems and allow us to make sure we're not being overly paranoid when throwing out this troublesome clocksource. Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andi Kleen <ak@suse.de>
2007-04-25ACPI: remove duplicate includeRay Lee
Thomas's patch for including <asm/apic.h> for x86 UP builds came into Linus's tree from two different directions, both of which were merged. This reverts the latter, yanking out the duplicate #include and comment. Signed-off-by: Ray Lee <ray-lk@madrabbit.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-03-23[PATCH] i386: add command line option "local_apic_timer_c2_ok"Thomas Gleixner
It turned out that it is almost impossible to trust ACPI, BIOS & Co. regarding the C states. This was the reason to switch the local apic timer off in C2 state already. OTOH there are sane and well behaving systems, which get punished by that decision. Allow the user to confirm that the local apic timer is trustworthy in C2 state. This keeps the default behaviour on the safe side. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-23Revert "ACPI: Only use IPI on known broken machines (AMD, ↵Linus Torvalds
Dothan/BaniasPentium M)" This reverts commit 25496caec111481161e7f06bbfa12a533c43cc6f, which broke bootup on at least Ingo's ThinkPad T60. Need to figure out exactly what is wrong before we can re-do the logic. Requested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Thomas Renninger <trenn@suse.de> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-17ACPI: Only use IPI on known broken machines (AMD, Dothan/BaniasPentium M)Thomas Renninger
Use IPI for blacklisted CPUs, add parameter IPI vs LAPIC Currently, Linux disables lapic timer for all machines with C2 and higher C-state support. According to Intel only specific Intel models (Banias/Dothan) are broken in respect of not waking up from C2 with lapic. However, I am not sure about the naming of the parameter and how it could/should get integrated into the dyntick part (CONFIG_GENERIC_CLOCKEVENTS). There, a more fine grained check (TSC still running?, ..) is needed? Does this make sense (always use CLOCK_EVT_NOTIFY_BROADCAST_ON, but use OFF if forced by use_ipi=0: clockevents_notify(use_ipi ? CLOCK_EVT_NOTIFY_BROADCAST_ON : CLOCK_EVT_NOTIFY_BROADCAST_OFF, &pr->id); Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16Pull fluff into release branchLen Brown
Conflicts: arch/x86_64/pci/mmconfig.c drivers/acpi/bay.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16Pull misc-for-upstream into release branchLen Brown
Conflicts: drivers/usb/misc/appledisplay.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16[PATCH] clockevents: i386 driversThomas Gleixner
Add clockevent drivers for i386: lapic (local) and PIT/HPET (global). Update the timer IRQ to call into the PIT/HPET driver's event handler and the lapic-timer IRQ to call into the lapic clockevent driver. The assignement of timer functionality is delegated to the core framework code and replaces the compile and runtime evalution in do_timer_interrupt_hook() Use the clockevents broadcast support and implement the lapic_broadcast function for ACPI. No changes to existing functionality. [ kdump fix from Vivek Goyal <vgoyal@in.ibm.com> ] [ fixes based on review feedback from Arjan van de Ven <arjan@infradead.org> ] Cleanups-from: Adrian Bunk <bunk@stusta.de> Build-fixes-from: Andrew Morton <akpm@osdl.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] ACPI keep track of timer broadcastingThomas Gleixner
This is a preperatory patch for highres/dyntick: - replace the big #ifdef ARCH_APICTIMER_STOPS_ON_C3 hackery by functions - remove the double switch in the power verify function (in the worst case we switched ipi to apic and 20usec later apic to ipi) - keep track of the the state which stops local APIC timer Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Len Brown <len.brown@intel.com> Cc: <linux-acpi@vger.kernel.org> Cc: Andi Kleen <ak@suse.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] ACPI: fix missing include for UPThomas Gleixner
apic.h does not get included on UP compiles. That way the APICTIMER_STOPS_ON_C3 is not there and UP boxen have no support for timer broadcasting. This was never noticed, because the lapic timer is only used for profiling on UP. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Len Brown <len.brown@intel.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-15ACPI: include apic.h in processor driver for benefit of UP kernelsThomas Gleixner
apic.h does not get included on UP compiles. That way the APICTIMER_STOPS_ON_C3 is not there and UP boxen have no support for timer broadcasting. This was never noticed, because the lapic timer is only used for profiling on UP. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: delete extra #defines in /drivers/acpi/ driversLen Brown
Cosmetic only. Except in a single case, #define ACPI_*_DRIVER_NAME were invoked 0 or 1 times. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: clean up ACPI_MODULE_NAME() useLen Brown
cosmetic only Make "module name" actually match the file name. Invoke with ';' as leaving it off confuses Lindent and gcc doesn't care. Fix indentation where Lindent did get confused. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: fix gcc build warningsAlexey Starikovskiy
drivers/acpi/namespace/nsparse.c:126: warning: int format, different type arg (arg 7) drivers/acpi/tables/tbfadt.c:224: warning: unsigned int format, different type arg (arg 6) drivers/acpi/utilities/utdebug.c:184: warning: cast from pointer to integer of different size drivers/acpi/utilities/utdebug.c:184: warning: cast from pointer to integer of different size drivers/acpi/utilities/utdebug.c:197: warning: cast from pointer to integer of different size drivers/acpi/processor_idle.c:1093: warning: long long unsigned int format, u64 arg (arg 5) Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: use new ACPI headers.Alexey Starikovskiy
2007-02-02ACPICA: Remove obsolete Flags parameter.Bob Moore
Remove flags parameter for acpi_{get,set}_register(). It is no longer necessary now that these functions use a spinlock for mutual exclusion. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: minimal patch to integrate new tables into LinuxAlexey Starikovskiy
2006-12-22Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (68 commits) ACPI: replace kmalloc+memset with kzalloc ACPI: Add support for acpi_load_table/acpi_unload_table_id fbdev: update after backlight argument change ACPI: video: Add dev argument for backlight_device_register ACPI: Implement acpi_video_get_next_level() ACPI: Kconfig - depend on PM rather than selecting it ACPI: fix NULL check in drivers/acpi/osl.c ACPI: make drivers/acpi/ec.c:ec_ecdt static ACPI: prevent processor module from loading on failures ACPI: fix single linked list manipulation ACPI: ibm_acpi: allow clean removal ACPI: fix git automerge failure ACPI: ibm_acpi: respond to workqueue update ACPI: dock: add uevent to indicate change in device status ACPI: ec: Lindent once again ACPI: ec: Change #define to enums there possible. ACPI: ec: Style changes. ACPI: ec: Acquire Global Lock under EC mutex. ACPI: ec: Drop udelay() from poll mode. Loop by reading status field instead. ACPI: ec: Rename gpe_bit to gpe ...
2006-12-22[PATCH] sched: fix bad missed wakeups in the i386, x86_64, ia64, ACPI and ↵Ingo Molnar
APM idle code Fernando Lopez-Lezcano reported frequent scheduling latencies and audio xruns starting at the 2.6.18-rt kernel, and those problems persisted all until current -rt kernels. The latencies were serious and unjustified by system load, often in the milliseconds range. After a patient and heroic multi-month effort of Fernando, where he tested dozens of kernels, tried various configs, boot options, test-patches of mine and provided latency traces of those incidents, the following 'smoking gun' trace was captured by him: _------=> CPU# / _-----=> irqs-off | / _----=> need-resched || / _---=> hardirq/softirq ||| / _--=> preempt-depth |||| / ||||| delay cmd pid ||||| time | caller \ / ||||| \ | / IRQ_19-1479 1D..1 0us : __trace_start_sched_wakeup (try_to_wake_up) IRQ_19-1479 1D..1 0us : __trace_start_sched_wakeup <<...>-5856> (37 0) IRQ_19-1479 1D..1 0us : __trace_start_sched_wakeup (c01262ba 0 0) IRQ_19-1479 1D..1 0us : resched_task (try_to_wake_up) IRQ_19-1479 1D..1 0us : __spin_unlock_irqrestore (try_to_wake_up) ... <idle>-0 1...1 11us!: default_idle (cpu_idle) ... <idle>-0 0Dn.1 602us : smp_apic_timer_interrupt (c0103baf 1 0) ... <...>-5856 0D..2 618us : __switch_to (__schedule) <...>-5856 0D..2 618us : __schedule <<idle>-0> (20 162) <...>-5856 0D..2 619us : __spin_unlock_irq (__schedule) <...>-5856 0...1 619us : trace_stop_sched_switched (__schedule) <...>-5856 0D..1 619us : trace_stop_sched_switched <<...>-5856> (37 0) what is visible in this trace is that CPU#1 ran try_to_wake_up() for PID:5856, it placed PID:5856 on CPU#0's runqueue and ran resched_task() for CPU#0. But it decided to not send an IPI that no CPU - due to TS_POLLING. But CPU#0 never woke up after its NEED_RESCHED bit was set, and only rescheduled to PID:5856 upon the next lapic timer IRQ. The result was a 600+ usecs latency and a missed wakeup! the bug turned out to be an idle-wakeup bug introduced into the mainline kernel this summer via an optimization in the x86_64 tree: commit 495ab9c045e1b0e5c82951b762257fe1c9d81564 Author: Andi Kleen <ak@suse.de> Date: Mon Jun 26 13:59:11 2006 +0200 [PATCH] i386/x86-64/ia64: Move polling flag into thread_info_status During some profiling I noticed that default_idle causes a lot of memory traffic. I think that is caused by the atomic operations to clear/set the polling flag in thread_info. There is actually no reason to make this atomic - only the idle thread does it to itself, other CPUs only read it. So I moved it into ti->status. the problem is this type of change: if (!hlt_counter && boot_cpu_data.hlt_works_ok) { - clear_thread_flag(TIF_POLLING_NRFLAG); + current_thread_info()->status &= ~TS_POLLING; smp_mb__after_clear_bit(); while (!need_resched()) { local_irq_disable(); this changes clear_thread_flag() to an explicit clearing of TS_POLLING. clear_thread_flag() is defined as: clear_bit(flag, &ti->flags); and clear_bit() is a LOCK-ed atomic instruction on all x86 platforms: static inline void clear_bit(int nr, volatile unsigned long * addr) { __asm__ __volatile__( LOCK_PREFIX "btrl %1,%0" hence smp_mb__after_clear_bit() is defined as a simple compile barrier: #define smp_mb__after_clear_bit() barrier() but the explicit TS_POLLING clearing introduced by the patch: + current_thread_info()->status &= ~TS_POLLING; is not an atomic op! So the clearing of the TS_POLLING bit is freely reorderable with the reading of the NEED_RESCHED bit - and both now reside in different memory addresses. CPU idle wakeup very much depends on ordered memory ops, the clearing of the TS_POLLING flag must always be done before we test need_resched() and hit the idle instruction(s). [Symmetrically, the wakeup code needs to set NEED_RESCHED before it tests the TS_POLLING flag, so memory ordering is paramount.] Fernando's dual-core Athlon64 system has a sufficiently advanced memory ordering model so that it triggered this scenario very often. ( And it also turned out that the reason why these latencies never triggered on my testsystems is that i routinely use idle=poll, which was the only idle variant not affected by this bug. ) The fix is to change the smp_mb__after_clear_bit() to an smp_mb(), to act as an absolute barrier between the TS_POLLING write and the NEED_RESCHED read. This affects almost all idling methods (default, ACPI, APM), on all 3 x86 architectures: i386, x86_64, ia64. Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Fernando Lopez-Lezcano <nando@ccrma.Stanford.EDU> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-16Pull style into test branchLen Brown
Conflicts: drivers/acpi/button.c drivers/acpi/ec.c drivers/acpi/osl.c drivers/acpi/sbs.c
2006-10-20[PATCH] fix "ACPI: Processor native C-states using MWAIT"Darrick J. Wong
This patch breaks C-state discovery on my IBM IntelliStation Z30 because the return value of acpi_processor_get_power_info_fadt is not assigned to "result" in the case that acpi_processor_get_power_info_cst returns -ENODEV. Thus, if ACPI provides C-state data via the FADT and not _CST (as is the case on this machine), we incorrectly exit the function with -ENODEV after reading the FADT. The attached patch sets the value of result so that we don't exit early. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Acked-by: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] acpi_processor_latency_notifier(): UP warning fixAndrew Morton
drivers/acpi/processor_idle.c:1112: warning: 'smp_callback' defined but not used Cc: Len Brown <lenb@kernel.org> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-14Pull trivial into test branchLen Brown
2006-10-14ACPI: fix section for CPU init functionsPierre Ossman
The ACPI processor init functions should be marked as __cpuinit as they use structures marked with __cpuinitdata. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-14ACPI: Remove unnecessary from/to-void* and to-void casts in drivers/acpiJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-14ACPI: Processor native C-states using MWAITVenkatesh Pallipadi
Intel processors starting with the Core Duo support support processor native C-state using the MWAIT instruction. Refer: Intel Architecture Software Developer's Manual http://www.intel.com/design/Pentium4/manuals/253668.htm Platform firmware exports the support for Native C-state to OS using ACPI _PDC and _CST methods. Refer: Intel Processor Vendor-Specific ACPI: Interface Specification http://www.intel.com/technology/iapc/acpi/downloads/302223.htm With Processor Native C-state, we use 'MWAIT' instruction on the processor to enter different C-states (C1, C2, C3). We won't use the special IO ports to enter C-state and no SMM mode etc required to enter C-state. Overall this will mean better C-state support. One major advantage of using MWAIT for all C-states is, with this and "treat interrupt as break event" feature of MWAIT, we can now get accurate timing for the time spent in C1, C2, .. states. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-01[PATCH] maximum latency tracking infrastructureArjan van de Ven
Add infrastructure to track "maximum allowable latency" for power saving policies. The reason for adding this infrastructure is that power management in the idle loop needs to make a tradeoff between latency and power savings (deeper power save modes have a longer latency to running code again). The code that today makes this tradeoff just does a rather simple algorithm; however this is not good enough: There are devices and use cases where a lower latency is required than that the higher power saving states provide. An example would be audio playback, but another example is the ipw2100 wireless driver that right now has a very direct and ugly acpi hook to disable some higher power states randomly when it gets certain types of error. The proposed solution is to have an interface where drivers can * announce the maximum latency (in microseconds) that they can deal with * modify this latency * give up their constraint and a function where the code that decides on power saving strategy can query the current global desired maximum. This patch has a user of each side: on the consumer side, ACPI is patched to use this, on the producer side the ipw2100 driver is patched. A generic maximum latency is also registered of 2 timer ticks (more and you lose accurate time tracking after all). While the existing users of the patch are x86 specific, the infrastructure is not. I'd like to ask the arch maintainers of other architectures if the infrastructure is generic enough for their use (assuming the architecture has such a tradeoff as concept at all), and the sound/multimedia driver owners to look at the driver facing API to see if this is something they can use. [akpm@osdl.org: cleanups] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jesse Barnes <jesse.barnes@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10ACPI: add 'const' to several ACPI file_operationsArjan van de Ven
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: delete acpi_os_free(), use kfree() directlyLen Brown
2006-06-29Pull c-states into release branchLen Brown
2006-06-28ACPI: additional blacklist entry for ThinkPad R40eBartlomiej Swiercz
2006-06-28ACPI: restore comment justifying 'extra' P_LVLx accessAndreas Mohr
While trying to look for superfluous I/O accesses that can be optimized away, I stumbled upon this ACPI sleep I/O access and couldn't figure out why the hell this dummy op was necessary. After more than one hour of internet research, I had collected a sufficient number of documents (among those very old kernel versions) that finally told me what this dummy read was about: STPCLK# doesn't get asserted in time on (some) chipsets, which is why we need to have a dummy I/O read to delay further instruction processing until the CPU is fully stopped. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-28ACPI: C-States: only demote on current bus mastering activityDominik Brodowski
Only if bus master activity is going on at the present, we should avoid entering C3-type sleep, as it might be a faulty transition. As long as the bm_activity bitmask was based on the number of calls to the ACPI idle function, looking at previous moments made sense. Now, with it being based on what happened this jiffy, looking at this jiffy should be sufficient. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-28ACPI: C-States: bm_activity improvementsDominik Brodowski
Do not assume there was bus mastering activity if the idle handler didn't get called, as there's only reason to not enter C3-type sleep if there is bus master activity going on. Only for the "promotion" into C3-type sleep bus mastering activity is taken into account, and there only current bus mastering activity, and not pure guessing should lead to the decision on whether to enter C3-type sleep or not. Also, as bm_activity is a jiffy-based bitmask (bit 0: bus mastering activity during this juffy, bit 31: bus mastering activity 31 jiffies ago), fix the setting of bit 0, as it might be called multiple times within one jiffy. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-28ACPI: C-States: accounting of sleep statesDominik Brodowski
Track the actual time spent in C-States (C2 upwards, we can't determine this for C1), not only the number of invocations. This is especially useful for dynamic ticks / "tickless systems", but is also of interest on normal systems, as any interrupt activity leads to C-States being exited, not only the timer interrupt. The time is being measured in PM timer ticks, so an increase by one equals 279 nanoseconds. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
2006-06-27ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...)Len Brown
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
2006-06-26Merge branch 'x86-64'Linus Torvalds
* x86-64: (83 commits) [PATCH] x86_64: x86_64 stack usage debugging [PATCH] x86_64: (resend) x86_64 stack overflow debugging [PATCH] x86_64: msi_apic.c build fix [PATCH] x86_64: i386/x86-64 Add nmi watchdog support for new Intel CPUs [PATCH] x86_64: Avoid broadcasting NMI IPIs [PATCH] x86_64: fix apic error on bootup [PATCH] x86_64: enlarge window for stack growth [PATCH] x86_64: Minor string functions optimizations [PATCH] x86_64: Move export symbols to their C functions [PATCH] x86_64: Standardize i386/x86_64 handling of NMI_VECTOR [PATCH] x86_64: Fix modular pc speaker [PATCH] x86_64: remove sys32_ni_syscall() [PATCH] x86_64: Do not use -ffunction-sections for modules [PATCH] x86_64: Add cpu_relax to apic_wait_icr_idle [PATCH] x86_64: adjust kstack_depth_to_print default [PATCH] i386/x86-64: adjust /proc/interrupts column headings [PATCH] x86_64: Fix race in cpu_local_* on preemptible kernels [PATCH] x86_64: Fix fast check in safe_smp_processor_id [PATCH] x86_64: x86_64 setup.c - printing cmp related boottime information [PATCH] i386/x86-64/ia64: Move polling flag into thread_info_status ... Manual resolve of trivial conflict in arch/i386/kernel/Makefile
2006-06-26[PATCH] i386/x86-64/ia64: Move polling flag into thread_info_statusAndi Kleen
During some profiling I noticed that default_idle causes a lot of memory traffic. I think that is caused by the atomic operations to clear/set the polling flag in thread_info. There is actually no reason to make this atomic - only the idle thread does it to itself, other CPUs only read it. So I moved it into ti->status. Converted i386/x86-64/ia64 for now because that was the easiest way to fix ACPI which also manipulates these flags in its idle function. Cc: Nick Piggin <npiggin@novell.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: i386 Conversion - part 2: Rework TSC Supportjohn stultz
As part of the i386 conversion to the generic timekeeping infrastructure, this introduces a new tsc.c file. The code in this file replaces the TSC initialization, management and access code currently in timer_tsc.c (which will be removed) that we want to preserve. The code also introduces the following functionality: o tsc_khz: like cpu_khz but stores the TSC frequency on systems that do not change TSC frequency w/ CPU frequency o check/mark_tsc_unstable: accessor/modifier flag for TSC timekeeping usability o minor cleanups to calibration math. This patch also includes a one line __cpuinitdata fix from Zwane Mwaikambo. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-14ACPI: apply "__read_mostly" to processor_idle.c loop module parameters and ↵Andreas Mohr
friends make pm_idle_save, nocst and bm_history __read_mostly remove initializer from static 'first_run'. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-25[PATCH] Fix compilation of processor_idle.c on IA64Andi Kleen
Broken earlier by me by a x86-64 patch. The code was optimized away, but the compiler still complained about an undeclared function. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
