path: root/drivers/acpi/processor_idle.c
2008-06-11cpuidle acpi driver: fix oops on AC<->DCVenkatesh Pallipadi
cpuidle and acpi driver interaction bug with the way cpuidle_register_driver() is called. Due to this bug, there will be oops on AC<->DC on some systems, where they support C-states in one DC and not in AC. The current code does ON BOOT: Look at CST and other C-state info to see whether more than C1 is supported. If it is, then acpi processor_idle does a cpuidle_register_driver() call, which internally enables the device. ON CST change notification (AC<->DC) and on suspend-resume: acpi driver temporarily disables device, updates the device with any new C-states, and reenables the device. The problem is is on boot, there are no C2, C3 states supported and we skip the register. Later on AC<->DC, we may get a CST notification and we try to reevaluate CST and enabled the device, without actually registering it. This causes breakage as we try to create /sys fs sub directory, without the parent directory which is created at register time. Thanks to Sanjeev for reporting the problem here. http://bugzilla.kernel.org/show_bug.cgi?id=10394 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits) ACPI: Fix acpi_processor_idle and idle= boot parameters interaction acpi: fix section mismatch warning in pnpacpi intel_menlo: fix build warning ACPI: Cleanup: Remove unneeded, multiple local dummy variables ACPI: video - fix permissions on some proc entries ACPI: video - properly handle errors when registering proc elements ACPI: video - do not store invalid entries in attached_array list ACPI: re-name acpi_pm_ops to acpi_suspend_ops ACER_WMI/ASUS_LAPTOP: fix build bug thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed ACPI: check a return value correctly in acpi_power_get_context() #if 0 acpi/bay.c:eject_removable_drive() eeepc-laptop: add hwmon fan control eeepc-laptop: add backlight eeepc-laptop: add base driver ACPI: thinkpad-acpi: bump up version to 0.20 ACPI: thinkpad-acpi: fix selects in Kconfig ACPI: thinkpad-acpi: use a private workqueue ACPI: thinkpad-acpi: fluff really minor fix ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation ... Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c manually.
2008-04-30Merge branches 'release', 'acpica', 'bugzilla-10224', 'bugzilla-9772', ↵Len Brown
'bugzilla-9916', 'ec', 'eeepc', 'idle', 'misc', 'pm-legacy', 'sysfs-links-2.6.26', 'thermal', 'thinkpad' and 'video' into release
2008-04-30ACPI: Fix acpi_processor_idle and idle= boot parameters interactionVenkatesh Pallipadi
acpi_processor_idle and "idle=" boot parameter interaction is broken. The problem is that, at boot time acpi driver is checking for "idle=" boot option and not registering the acpi idle handler. But, when there is a CST changed callback (typically when switching AC <-> battery or suspend-resume) there are no checks for boot_option_idle_override and acpi idle handler tries to get installed with nasty side effects. With CPU_IDLE configured this issue causes results in a nasty oops on CST change callback and without CPU_IDLE there is no oops, but boot option of "idle=" gets ignored and acpi idle handler gets installed. Change the behavior to not do anything in acpi idle handler when there is a "idle=" boot option. Note that the problem is only there when "idle=" boot option is used. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29acpi: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Len Brown <lenb@kernel.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27fix idle (arch, acpi and apm) and lockdepPeter Zijlstra
OK, so 25-mm1 gave a lockdep error which made me look into this. The first thing that I noticed was the horrible mess; the second thing I saw was hacks like: 71e93d15612c61c2e26a169567becf088e71b8ff The problem is that arch idle routines are somewhat inconsitent with their IRQ state handling and instead of fixing _that_, we go paper over the problem. So the thing I've tried to do is set a standard for idle routines and fix them all up to adhere to that. So the rules are: idle routines are entered with IRQs disabled idle routines will exit with IRQs enabled Nearly all already did this in one form or another. Merge the 32 and 64 bit bits so they no longer have different bugs. As for the actual lockdep warning; __sti_mwait() did a plainly un-annotated irq-enable. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-242.6.25 regression: powertop says 120K wakeups/secVenkatesh Pallipadi
Patch to fix huge number of wakeups reported due to recent changes in processor_idle.c. The problem was that the entry_method determination was broken due to one of the recent commits (bc71bec91f987) causing C1 entry to not to go to halt. http://lkml.org/lkml/2008/3/22/124 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-03-26cpuidle: fix 100% C0 statistics regressionVenki Pallipadi
commit 9b12e18cdc1553de62d931e73443c806347cd974 'ACPI: cpuidle: Support C1 idle time accounting' was implicated in a 100% C0 idle regression. http://bugzilla.kernel.org/show_bug.cgi?id=10076 It pointed out a potential problem where the menu governor may get confused by the C-state residency time from poll idle or C1 idle, where this timing info is not accurate. This inaccuracy is due to interrupts being handled before we account for C-state exit. Do not mark TIME_VALID for CO poll state. Mark C1 time as valid only with the MWAIT (CSTATE_FFH) entry method. This makes governors use the timing information only when it is correct and eliminates any wrong policy decisions that may result from invalid timing information. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-03-26ACPI: fix mis-merge -- invoke acpi_unlazy_tlb() only on C3 entryVenki Pallipadi
This original patch http://ussg.iu.edu/hypermail/linux/kernel/0712.2/1451.html was intending to add acpi_unlazy_tlb() to acpi_idle_enter_bm(), which is used for C3 entry. But it was merged incorrectly as commmit bde6f5f59c2b2b48a7a849c129d5b48838fe77ee 'x86: voluntary leave_mm before entering ACPI C3' so the call was instead added to acpi_idle_enter_simple() (which is C2 entry routine), probably due to identical context in that function. Move the call back to acpi_idle_enter_bm(). Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-03-14ACPI: lockdep warning on boot, 2.6.25-rc5Venki Pallipadi
This avoids the harmless WARNING by lockdep in acpi_processor_idle(). The reason for WARNING is because at the depth of idle handling code, some of the idle handlers disable interrupts, some times, while returning from the idle handler. After return, acpi_processor_idle and few other routines in the file did an unconditional local_irq_enable(). With LOCKDEP, enabling irq when it is already enabled generates the below WARNING. > > [ 0.593038] ------------[ cut here ]------------ > > [ 0.593267] WARNING: at kernel/lockdep.c:2035 trace_hardirqs_on+0xa0/0x115() > > [ 0.593596] Modules linked in: > > [ 0.593756] Pid: 0, comm: swapper Not tainted 2.6.25-rc5 #8 > > [ 0.594017] > > [ 0.594017] Call Trace: > > [ 0.594216] [<ffffffff80231663>] warn_on_slowpath+0x58/0x6b > > [ 0.594495] [<ffffffff80495966>] ? _spin_unlock_irqrestore+0x38/0x47 > > [ 0.594809] [<ffffffff80329a86>] ? acpi_os_release_lock+0x9/0xb > > [ 0.595103] [<ffffffff80337840>] ? acpi_set_register+0x161/0x173 > > [ 0.595401] [<ffffffff8034c8d4>] ? acpi_processor_idle+0x1de/0x546 > > [ 0.595706] [<ffffffff8020a23b>] ? default_idle+0x0/0x73 > > [ 0.595970] [<ffffffff8024fc0e>] trace_hardirqs_on+0xa0/0x115 > > [ 0.596049] [<ffffffff8034c6f6>] ? acpi_processor_idle+0x0/0x546 > > [ 0.596346] [<ffffffff8034c8d4>] acpi_processor_idle+0x1de/0x546 > > [ 0.596642] [<ffffffff8020a23b>] ? default_idle+0x0/0x73 > > [ 0.596912] [<ffffffff8034c6f6>] ? acpi_processor_idle+0x0/0x546 > > [ 0.597209] [<ffffffff8020a23b>] ? default_idle+0x0/0x73 > > [ 0.597472] [<ffffffff8020a355>] cpu_idle+0xa7/0xd1 > > [ 0.597717] [<ffffffff80485fa1>] rest_init+0x55/0x57 > > [ 0.597957] [<ffffffff8062fb49>] start_kernel+0x29d/0x2a8 > > [ 0.598215] [<ffffffff8062f1da>] _sinittext+0x1da/0x1e1 > > [ 0.598464] > > [ 0.598546] ---[ end trace 778e504de7e3b1e3 ]--- Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-19ACPI: TSC breaks atkbd suspendPavel Machek
TSC is used even on machines when CONFIG_X86_TSC is not set (X86_TSC means _require_ TSC), but it is not properly disabled when it is unusable, because ACPI code understood the config switch as "may use TSC". This actually fixes suspend problems on my x60. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-14Merge branches 'release', 'dmi', 'idle' and 'misc' into releaseLen Brown
2008-02-14ACPI, cpuidle: Clarify C-state description in sysfsVenkatesh Pallipadi
Add a new sysfs entry under cpuidle states. desc - can be used by driver to communicate to userspace any specific information about the state. This helps in identifying the exact hardware C-states behind the ACPI C-state definition. Idea is to export this through powertop, which will help to map the C-state reported by powertop to actual hardware C-state. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-13ACPI: fix suspend regression due to idle updateVenkatesh Pallipadi
Earlier patch (bc71bec91f9875ef825d12104acf3bf4ca215fa4) broke suspend resume on many laptops. The problem was reported by Carlos R. Mafra and Calvin Walton, who bisected the issue to above patch. The problem was because, C2 and C3 code were calling acpi_idle_enter_c1 directly, with C2 or C3 as state parameter, while suspend/resume was in progress. The patch bc71bec started making use of that state information, assuming that it would always be referring to C1 state. This caused the problem with suspend-resume as we ended up using C2/C3 state indirectly. Fix this by adding acpi_idle_suspend check in enter_c1. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07Merge branches 'release', 'cpuidle-2.6.25' and 'idle' into releaseLen Brown
2008-02-07cpuidle: Add a poll_idle methodvenkatesh.pallipadi@intel.com
Add a default poll idle state with 0 latency. Provides an option to users to use poll_idle by using 0 as the latency requirement. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: cpuidle: Support C1 idle time accountingvenkatesh.pallipadi@intel.com
Show C1 idle time in /sysfs cpuidle interface. C1 idle time may not be entirely accurate in all cases. It includes the time spent in the interrupt handler after wakeup with "hlt" based C1. But, it will be accurate with "mwait" based C1. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: enable MWAIT for C1 idlevenkatesh.pallipadi@intel.com
Add MWAIT idle for C1 state instead of halt, on platforms that support C1 state with MWAIT. Renames cx->space_id to something more appropriate. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: idle: Fix acpi_safe_halt usages and interrupt enabling/disablingvenkatesh.pallipadi@intel.com
acpi_safe_halt() needs interrupts to be disabled for atomic need_resched check and safe halt. Otherwise we may miss an interrupt and go into halt. acpi_safe_halt() also does not enable interrupts on all return paths. So the callers should handle enable and disable interrupts around it. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-05latency.c: use QoS infrastructureMark Gross
Replace latency.c use with pm_qos_params use. Signed-off-by: mark gross <mgross@linux.intel.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Len Brown <lenb@kernel.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86: don't disable TSC in any C states on AMD Fam10hAndi Kleen
The ACPI code currently disables TSC use in any C2 and C3 states. But the AMD Fam10h BKDG documents that the TSC will never stop in any C states when the CONSTANT_TSC bit is set. Make this disabling conditional on CONSTANT_TSC not set on AMD. I actually think this is true on Intel too for C2 states on CPUs with p-state invariant TSC, but this needs further discussions with Len to really confirm :-) So far it is only enabled on AMD. Cc: lenb@kernel.org Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: voluntary leave_mm before entering ACPI C3Venki Pallipadi
Aviod TLB flush IPIs during C3 states by voluntary leave_mm() before entering C3. The performance impact of TLB flush on C3 should not be significant with respect to C3 wakeup latency. Also, CPUs tend to flush TLB in hardware while in C3 anyways. On a 8 logical CPU system, running make -j2, the number of tlbflush IPIs goes down from 40 per second to ~ 0. Total number of interrupts during the run of this workload was ~1200 per second, which makes it ~3% savings in wakeups. There was no measurable performance or power impact however. [ akpm@linux-foundation.org: symbol export fixes. ] Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-07ACPI: Reintroduce run time configurable max_cstate for !CPU_IDLE caseVenki Pallipadi
This was writeable in 2.6.23 but the cpuidle merge made it read-only. But some people's scripts (ie: Mark's) were writing to it. As an unhappy compromise, make max_cstate writeable again if the kernel was configured without CONFIG_CPU_IDLE. http://bugzilla.kernel.org/show_bug.cgi?id=9683 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Mark Lord <lkml@rtr.ca> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-12-14cpuidle: default processor.latency_factor=2Len Brown
More aggressively request deep C-states. Note that the job of the OS is to minimize latency impact to expected break events such as interrupts. It is not the job of the OS to try to calculate if the C-state will reach energy break-even. The platform doesn't give the OS enough information for it to make that calculation. Thus, it is up to the platform to decide if it is worth it to go as deep as the OS requested it to, or if it should internally demote to a more shallow C-state. But the converse is not true. The platform can not promote into a deeper C-state than the OS requested else it may violate latency constraints. So it is important that the OS be aggressive in giving the platform permission to enter deep C-states. Signed-off-by: Len Brown <len.brown@intel.com>
2007-12-14cpuidle: create processor.latency_factor tunableLen Brown
Start with default value of 6, so by default, there is no functional change in this patch. Signed-off-by: Len Brown <len.brown@intel.com>
2007-12-07ACPI: move timer broadcast before busmaster disableThomas Gleixner
The timer broadcast code might access HPET, which should not be accessed after the busmaster disable. In acpi_idle_enter_simple() this change also prevents, that we modify the busmaster state without going actually idle. This might leave the ACPI bm state in a stale state, when we leave the function early in the need_resched() check. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
2007-11-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: fix APIC related bootup crash on Athlon XP CPUs time: add ADJ_OFFSET_SS_READ x86: export the symbol empty_zero_page on the 32-bit x86 architecture x86: fix kprobes_64.c inlining borkage pci: use pci=bfsort for HP DL385 G2, DL585 G2 x86: correctly set UTS_MACHINE for "make ARCH=x86" lockdep: annotate do_debug() trap handler x86: turn off iommu merge by default x86: fix ACPI compile for LOCAL_APIC=n x86: printk kernel version in WARN_ON and other dump_stack users ACPI: Set max_cstate to 1 for early Opterons. x86: fix NMI watchdog & 'stopped time' problem
2007-11-26ACPI: Set max_cstate to 1 for early Opterons.Alexey Starikovskiy
AMD Opteron processors before CG revision don't like C-states > 1. This solves the long standing bugzilla #5303 and probably some more on affected machines: http://bugzilla.kernel.org/show_bug.cgi?id=5303 [ tglx@linutronix.de: reworked the patch so it does not wreck ia64 ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-11-20Pull cpuidle into release branchLen Brown
2007-11-19cpuidle: fix HP nx6125 regressionVenkatesh Pallipadi
Fix for http://bugzilla.kernel.org/show_bug.cgi?id=9355 cpuidle always used to fallback to C2 if there is some bm activity while entering C3. But, presence of C2 is not always guaranteed. Change cpuidle algorithm to detect a safe_state to fallback in case of bm_activity and use that state instead of C2. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-11-19cpuidle: add sched_clock_idle_[sleep|wakeup]_event() hooksVenkatesh Pallipadi
Port 2aa44d0567ed21b47b87d68819415d48194cb923 (sched: sched_clock_idle_[sleep|wakeup]_event()) to cpuidle. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-11-19cpuidle: fix C3 for no bus-master control caseVenkatesh Pallipadi
Port 18eab8550397f1f3d4b8b2c5257c88dae25d58ed (Enable C3 even when PM2_control is zero) to cpuidle. Without this patch, some systems will notice a regression when enabling CPU_IDLE -- C3 would no longer be available. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-19Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (41 commits) ACPICA: hw: Don't carry spinlock over suspend ACPICA: hw: remove use_lock flag from acpi_hw_register_{read, write} ACPI: cpuidle: port idle timer suspend/resume workaround to cpuidle ACPI: clean up acpi_enter_sleep_state_prep Hibernation: Make sure that ACPI is enabled in acpi_hibernation_finish ACPI: suppress uninitialized var warning cpuidle: consolidate 2.6.22 cpuidle branch into one patch ACPI: thinkpad-acpi: skip blanks before the data when parsing sysfs ACPI: AC: Add sysfs interface ACPI: SBS: Add sysfs alarm ACPI: SBS: Add ACPI_PROCFS around procfs handling code. ACPI: SBS: Add support for power_supply class (and sysfs) ACPI: SBS: Make SBS reads table-driven. ACPI: SBS: Simplify data structures in SBS ACPI: SBS: Split host controller (ACPI0001) from SBS driver (ACPI0002) ACPI: EC: Add new query handler to list head. ACPI: Add acpi_bus_generate_event4() function ACPI: Battery: add sysfs alarm ACPI: Battery: Add sysfs support ACPI: Battery: Misc clean-ups, no functional changes ... Fix up conflicts in drivers/misc/thinkpad_acpi.[ch] manually
2007-10-12ACPI: remove the now unused ifdef codeThomas Gleixner
The conversion of x86-64 to clock events makes the #ifdef CONFIG_GENERIC_CLOCKEVENTS n the timer broadcast functions useless. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2007-10-10ACPI: cpuidle: port idle timer suspend/resume workaround to cpuidleLen Brown
Some timers stop during C2 and C3, and so there are various generations of timer broadcast workarounds to deal with that. But that (already complex) code gets confused during suspend. As it is unlikely that deep C-states would save much power during the actual suspend/resume process anyway, deep C-states were disabled via the addition of .suspend/.resume hooks in to the ACPI processor driver. Here that workaround is ported to the cpuidle version of the ACPI idle loop. Technically, ACPI could un-register itself from cpuidle on .suspend, but that code path is currently quite cumbersome. So instead, we simply invoke C1 from the C2 and C3 handlers for the duration of .suspend/.resume. Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-10cpuidle: consolidate 2.6.22 cpuidle branch into one patchLen Brown
commit e5a16b1f9eec0af7cfa0830304b41c1c0833cf9f Author: Len Brown <len.brown@intel.com> Date: Tue Oct 2 23:44:44 2007 -0400 cpuidle: shrink diff processor_idle.c | 440 +++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 429 insertions(+), 11 deletions(-) Signed-off-by: Len Brown <len.brown@intel.com> commit dfbb9d5aedfb18848a3e0d6f6e3e4969febb209c Author: Len Brown <len.brown@intel.com> Date: Wed Sep 26 02:17:55 2007 -0400 cpuidle: reduce diff size Reduces the cpuidle processor_idle.c diff vs 2.6.22 from this processor_idle.c | 2006 ++++++++++++++++++++++++++----------------- 1 file changed, 1219 insertions(+), 787 deletions(-) to this: processor_idle.c | 502 +++++++++++++++++++++++++++++++++++++++---- 1 file changed, 458 insertions(+), 44 deletions(-) ...for the purpose of making the cpuilde patch less invasive and easier to review. no functional changes. build tested only. Signed-off-by: Len Brown <len.brown@intel.com> commit 889172fc915f5a7fe20f35b133cbd205ce69bf6c Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Sep 13 13:40:05 2007 -0700 cpuidle: Retain old ACPI policy for !CONFIG_CPU_IDLE Retain the old policy in processor_idle, so that when CPU_IDLE is not configured, old C-state policy will still be used. This provides a clean gradual migration path from old ACPI policy to new cpuidle based policy. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 9544a8181edc7ecc33b3bfd69271571f98ed08bc Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Sep 13 13:39:17 2007 -0700 cpuidle: Configure governors by default Quoting Len "Do not give an option to users to shoot themselves in the foot". Remove the configurability of ladder and menu governors as they are needed for default policy of cpuidle. That way users will not be able to have cpuidle without any policy loosing all C-state power savings. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 8975059a2c1e56cfe83d1bcf031bcf4cb39be743 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:27:07 2007 -0400 CPUIDLE: load ACPI properly when CPUIDLE is disabled Change the registration return codes for when CPUIDLE support is not compiled into the kernel. As a result, the ACPI processor driver will load properly even if CPUIDLE is unavailable. However, it may be possible to cleanup the ACPI processor driver further and eliminate some dead code paths. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit e0322e2b58dd1b12ec669bf84693efe0dc2414a8 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:26:06 2007 -0400 CPUIDLE: remove cpuidle_get_bm_activity() Remove cpuidle_get_bm_activity() and updates governors accordingly. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 18a6e770d5c82ba26653e53d240caa617e09e9ab Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:25:58 2007 -0400 CPUIDLE: max_cstate fix Currently max_cstate is limited to 0, resulting in no idle processor power management on ACPI platforms. This patch restores the value to the array size. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 1fdc0887286179b40ce24bcdbde663172e205ef0 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:25:40 2007 -0400 CPUIDLE: handle BM detection inside the ACPI Processor driver Update the ACPI processor driver to detect BM activity and limit state entry depth internally, rather than exposing such requirements to CPUIDLE. As a result, CPUIDLE can drop this ACPI-specific interface and become more platform independent. BM activity is now handled much more aggressively than it was in the original implementation, so some testing coverage may be needed to verify that this doesn't introduce any DMA buffer under-run issues. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 0ef38840db666f48e3cdd2b769da676c57228dd9 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:25:14 2007 -0400 CPUIDLE: menu governor updates Tweak the menu governor to more effectively handle non-timer break events. Non-timer break events are detected by comparing the actual sleep time to the expected sleep time. In future revisions, it may be more reliable to use the timer data structures directly. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit bb4d74fca63fa96cf3ace644b15ae0f12b7df5a1 Author: Adam Belay <abelay@novell.com> Date: Tue Aug 21 18:24:40 2007 -0400 CPUIDLE: fix 'current_governor' sysfs entry Allow the "current_governor" sysfs entry to properly handle input terminated with '\n'. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit df3c71559bb69b125f1a48971bf0d17f78bbdf47 Author: Len Brown <len.brown@intel.com> Date: Sun Aug 12 02:00:45 2007 -0400 cpuidle: fix IA64 build (again) Signed-off-by: Len Brown <len.brown@intel.com> commit a02064579e3f9530fd31baae16b1fc46b5a7bca8 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Sun Aug 12 01:39:27 2007 -0400 cpuidle: Remove support for runtime changing of max_cstate Remove support for runtime changeability of max_cstate. Drivers can use use latency APIs. max_cstate can still be used as a boot time option and dmi override. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 0912a44b13adf22f5e3f607d263aed23b4910d7e Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Sun Aug 12 01:39:16 2007 -0400 cpuidle: Remove ACPI cstate_limit calls from ipw2100 ipw2100 already has code to use accetable_latency interfaces to limit the C-state. Remove the calls to acpi_set_cstate_limit and acpi_get_cstate_limit as they are redundant. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit c649a76e76be6bff1fd770d0a775798813a3f6e0 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Sun Aug 12 01:35:39 2007 -0400 cpuidle: compile fix for pause and resume functions Fix the compilation failure when cpuidle is not compiled in. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Acked-by: Adam Belay <adam.belay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 2305a5920fb8ee6ccec1c62ade05aa8351091d71 Author: Adam Belay <abelay@novell.com> Date: Thu Jul 19 00:49:00 2007 -0400 cpuidle: re-write Some portions have been rewritten to make the code cleaner and lighter weight. The following is a list of changes: 1.) the state name is now included in the sysfs interface 2.) detection, hotplug, and available state modifications are handled by CPUIDLE drivers directly 3.) the CPUIDLE idle handler is only ever installed when at least one cpuidle_device is enabled and ready 4.) the menu governor BM code no longer overflows 5.) the sysfs attributes are now printed as unsigned integers, avoiding negative values 6.) a variety of other small cleanups Also, Idle drivers are no longer swappable during runtime through the CPUIDLE sysfs inteface. On i386 and x86_64 most idle handlers (e.g. poll, mwait, halt, etc.) don't benefit from an infrastructure that supports multiple states, so I think using a more general case idle handler selection mechanism would be cleaner. Signed-off-by: Adam Belay <abelay@novell.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Acked-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit df25b6b56955714e6e24b574d88d1fd11f0c3ee5 Author: Len Brown <len.brown@intel.com> Date: Tue Jul 24 17:08:21 2007 -0400 cpuidle: fix IA64 buid Signed-off-by: Len Brown <len.brown@intel.com> commit fd6ada4c14488755ff7068860078c437431fbccd Author: Adrian Bunk <bunk@stusta.de> Date: Mon Jul 9 11:33:13 2007 -0700 cpuidle: static make cpuidle_replace_governor() static Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit c1d4a2cebcadf2429c0c72e1d29aa2a9684c32e0 Author: Adrian Bunk <bunk@stusta.de> Date: Tue Jul 3 00:54:40 2007 -0400 cpuidle: static This patch makes the needlessly global struct menu_governor static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit dbf8780c6e8d572c2c273da97ed1cca7608fd999 Author: Andrew Morton <akpm@linux-foundation.org> Date: Tue Jul 3 00:49:14 2007 -0400 export symbol tick_nohz_get_sleep_length ERROR: "tick_nohz_get_sleep_length" [drivers/cpuidle/governors/menu.ko] undefined! ERROR: "tick_nohz_get_idle_jiffies" [drivers/cpuidle/governors/menu.ko] undefined! And please be sure to get your changes to core kernel suitably reviewed. Cc: Adam Belay <abelay@novell.com> Cc: Venki Pallipadi <venkatesh.pallipadi@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 29f0e248e7017be15f99febf9143a2cef00b2961 Author: Andrew Morton <akpm@linux-foundation.org> Date: Tue Jul 3 00:43:04 2007 -0400 tick.h needs hrtimer.h It uses hrtimers. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit e40cede7d63a029e92712a3fe02faee60cc38fb4 Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:40:34 2007 -0400 cpuidle: first round of documentation updates Documentation changes based on Pavel's feedback. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 83b42be2efece386976507555c29e7773a0dfcd1 Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:39:25 2007 -0400 cpuidle: add rating to the governors and pick the one with highest rating by default Introduce a governor rating scheme to pick the right governor by default. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit d2a74b8c5e8f22def4709330d4bfc4a29209b71c Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:38:08 2007 -0400 cpuidle: make cpuidle sysfs driver governor switch off by default Make default cpuidle sysfs to show current_governor and current_driver in read-only mode. More elaborate available_governors and available_drivers with writeable current_governor and current_driver interface only appear with "cpuidle_sysfs_switch" boot parameter. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 1f60a0e80bf83cf6b55c8845bbe5596ed8f6307b Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:37:00 2007 -0400 cpuidle: menu governor: change the early break condition Change the C-state early break out algorithm in menu governor. We only look at early breakouts that result in wakeups shorter than idle state's target_residency. If such a breakout is frequent enough, eliminate the particular idle state upto a timeout period. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 45a42095cf64b003b4a69be3ce7f434f97d7af51 Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:35:38 2007 -0400 cpuidle: fix uninitialized variable in sysfs routine Fix the uninitialized usage of ret. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 80dca7cdba3e6ee13eae277660873ab9584eb3be Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:34:16 2007 -0400 cpuidle: reenable /proc/acpi//power interface for the time being Keep /proc/acpi/processor/CPU*/power around for a while as powertop depends on it. It will be marked deprecated and removed in future. powertop can use cpuidle interfaces instead. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 589c37c2646c5e3813a51255a5ee1159cb4c33fc Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Jul 3 00:32:37 2007 -0400 cpuidle: menu governor and hrtimer compile fix Compile fix for menu governor. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 0ba80bd9ab3ed304cb4f19b722e4cc6740588b5e Author: Len Brown <len.brown@intel.com> Date: Thu May 31 22:51:43 2007 -0400 cpuidle: build fix - cpuidle vs ipw2100 module ERROR: "acpi_set_cstate_limit" [drivers/net/wireless/ipw2100.ko] undefined! Signed-off-by: Len Brown <len.brown@intel.com> commit d7d8fa7f96a7f7682be7c6cc0cc53fa7a18c3b58 Author: Adam Belay <abelay@novell.com> Date: Sat Mar 24 03:47:07 2007 -0400 cpuidle: add the 'menu' governor Here is my first take at implementing an idle PM governor that takes full advantage of NO_HZ. I call it the 'menu' governor because it considers the full list of idle states before each entry. I've kept the implementation fairly simple. It attempts to guess the next residency time and then chooses a state that would meet at least the break-even point between power savings and entry cost. To this end, it selects the deepest idle state that satisfies the following constraints: 1. If the idle time elapsed since bus master activity was detected is below a threshold (currently 20 ms), then limit the selection to C2-type or above. 2. Do not choose a state with a break-even residency that exceeds the expected time remaining until the next timer interrupt. 3. Do not choose a state with a break-even residency that exceeds the elapsed time between the last pair of break events, excluding timer interrupts. This governor has an advantage over "ladder" governor because it proactively checks how much time remains until the next timer interrupt using the tick infrastructure. Also, it handles device interrupt activity more intelligently by not including timer interrupts in break event calculations. Finally, it doesn't make policy decisions using the number of state entries, which can have variable residency times (NO_HZ makes these potentially very large), and instead only considers sleep time deltas. The menu governor can be selected during runtime using the cpuidle sysfs interface like so: "echo "menu" > /sys/devices/system/cpu/cpuidle/current_governor" Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit a4bec7e65aa3b7488b879d971651cc99a6c410fe Author: Adam Belay <abelay@novell.com> Date: Sat Mar 24 03:47:03 2007 -0400 cpuidle: export time until next timer interrupt using NO_HZ Expose information about the time remaining until the next timer interrupt expires by utilizing the dynticks infrastructure. Also modify the main idle loop to allow dynticks to handle non-interrupt break events (e.g. DMA). Finally, expose sleep ticks information to external code. Thomas Gleixner is responsible for much of the code in this patch. However, I've made some additional changes, so I'm probably responsible if there are any bugs or oversights :) Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 2929d8996fbc77f41a5ff86bb67cdde3ca7d2d72 Author: Adam Belay <abelay@novell.com> Date: Sat Mar 24 03:46:58 2007 -0400 cpuidle: governor API changes This patch prepares cpuidle for the menu governor. It adds an optional stage after idle state entry to give the governor an opportunity to check why the state was exited. Also it makes sure the idle loop returns after each state entry, allowing the appropriate dynticks code to run. Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 3a7fd42f9825c3b03e364ca59baa751bb350775f Author: Venki Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Apr 26 00:03:59 2007 -0700 cpuidle: hang fix Prevent hang on x86-64, when ACPI processor driver is added as a module on a system that does not support C-states. x86-64 expects all idle handlers to enable interrupts before returning from idle handler. This is due to enter_idle(), exit_idle() races. Make cpuidle_idle_call() confirm to this when there is no pm_idle_old. Also, cpuidle look at the return values of attch_driver() and set current_driver to NULL if attach fails on all CPUs. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 4893339a142afbd5b7c01ffadfd53d14746e858e Author: Shaohua Li <shaohua.li@intel.com> Date: Thu Apr 26 10:40:09 2007 +0800 cpuidle: add support for max_cstate limit With CPUIDLE framework, the max_cstate (to limit max cpu c-state) parameter is ingored. Some systems require it to ignore C2/C3 and some drivers like ipw require it too. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 43bbbbe1cb998cbd2df656f55bb3bfe30f30e7d1 Author: Shaohua Li <shaohua.li@intel.com> Date: Thu Apr 26 10:40:13 2007 +0800 cpuidle: add cpuidle_fore_redetect_devices API add cpuidle_force_redetect_devices API, which forces all CPU redetect idle states. Next patch will use it. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit d1edadd608f24836def5ec483d2edccfb37b1d19 Author: Shaohua Li <shaohua.li@intel.com> Date: Thu Apr 26 10:40:01 2007 +0800 cpuidle: fix sysfs related issue Fix the cpuidle sysfs issue. a. make kobject dynamicaly allocated b. fixed sysfs init issue to avoid suspend/resume issue Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 7169a5cc0d67b263978859672e86c13c23a5570d Author: Randy Dunlap <randy.dunlap@oracle.com> Date: Wed Mar 28 22:52:53 2007 -0400 cpuidle: 1-bit field must be unsigned A 1-bit bitfield has no room for a sign bit. drivers/cpuidle/governors/ladder.c:54:16: error: dubious bitfield without explicit `signed' or `unsigned' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 4658620158dc2fbd9e4bcb213c5b6fb5d05ba7d4 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Wed Mar 28 22:52:41 2007 -0400 cpuidle: fix boot hang Patch for cpuidle boot hang reported by Larry Finger here. http://www.ussg.iu.edu/hypermail/linux/kernel/0703.2/2025.html Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Larry Finger <larry.finger@lwfinger.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit c17e168aa6e5fe3851baaae8df2fbc1cf11443a9 Author: Len Brown <len.brown@intel.com> Date: Wed Mar 7 04:37:53 2007 -0500 cpuidle: ladder does not depend on ACPI build fix for CONFIG_ACPI=n In file included from drivers/cpuidle/governors/ladder.c:21: include/acpi/processor.h:88: error: expected specifier-qualifier-list before ‘acpi_integer’ include/acpi/processor.h:106: error: expected specifier-qualifier-list before ‘acpi_integer’ include/acpi/processor.h:168: error: expected specifier-qualifier-list before ‘acpi_handle’ Signed-off-by: Len Brown <len.brown@intel.com> commit 8c91d958246bde68db0c3f0c57b535962ce861cb Author: Adrian Bunk <bunk@stusta.de> Date: Tue Mar 6 02:29:40 2007 -0800 cpuidle: make code static This patch makes the following needlessly global code static: - driver.c: __cpuidle_find_driver() - governor.c: __cpuidle_find_governor() - ladder.c: struct ladder_governor Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Adam Belay <abelay@novell.com> Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 0c39dc3187094c72c33ab65a64d2017b21f372d2 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Wed Mar 7 02:38:22 2007 -0500 cpu_idle: fix build break This patch fixes a build breakage with !CONFIG_HOTPLUG_CPU and CONFIG_CPU_IDLE. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 8112e3b115659b07df340ef170515799c0105f82 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Tue Mar 6 02:29:39 2007 -0800 cpuidle: build fix for !CPU_IDLE Fix the compile issues when CPU_IDLE is not configured. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Adam Belay <abelay@novell.com> Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> commit 1eb4431e9599cd25e0d9872f3c2c8986821839dd Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Feb 22 13:54:57 2007 -0800 cpuidle take2: Basic documentation for cpuidle Documentation for cpuidle infrastructure Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> commit ef5f15a8b79123a047285ec2e3899108661df779 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Feb 22 13:54:03 2007 -0800 cpuidle take2: Hookup ACPI C-states driver with cpuidle Hookup ACPI C-states onto generic cpuidle infrastructure. drivers/acpi/procesor_idle.c is now a ACPI C-states driver that registers as a driver in cpuidle infrastructure and the policy part is removed from drivers/acpi/processor_idle.c. We use governor in cpuidle instead. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com> commit 987196fa82d4db52c407e8c9d5dec884ba602183 Author: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Date: Thu Feb 22 13:52:57 2007 -0800 cpuidle take2: Core cpuidle infrastructure Announcing 'cpuidle', a new CPU power management infrastructure to manage idle CPUs in a clean and efficient manner. cpuidle separates out the drivers that can provide support for multiple types of idle states and policy governors that decide on what idle state to use at run time. A cpuidle driver can support multiple idle states based on parameters like varying power consumption, wakeup latency, etc (ACPI C-states for example). A cpuidle governor can be usage model specific (laptop, server, laptop on battery etc). Main advantage of the infrastructure being, it allows independent development of drivers and governors and allows for better CPU power management. A huge thanks to Adam Belay and Shaohua Li who were part of this mini-project since its beginning and are greatly responsible for this patchset. This patch: Core cpuidle infrastructure. Introduces a new abstraction layer for cpuidle: * which manages drivers that can support multiple idles states. Drivers can be generic or particular to specific hardware/platform * allows pluging in multiple policy governors that can take idle state policy decision * The core also has a set of sysfs interfaces with which administrato can know about supported drivers and governors and switch them at run time. Signed-off-by: Adam Belay <abelay@novell.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-09drivers/firmware: const-ify DMI API and internalsJeff Garzik
Three main sets of changes: 1) dmi_get_system_info() return value should have been marked const, since callers should not be changing that data. 2) const-ify DMI internals, since DMI firmware tables should, whenever possible, be marked const to ensure we never ever write to that data area. 3) const-ify DMI API, to enable marking tables const where possible in low-level drivers. And if we're really lucky, this might enable some additional optimizations on the part of the compiler. The bulk of the changes are #2 and #3, which are interrelated. #1 could have been a separate patch, but it was so small compared to the others, it was easier to roll it into this changeset. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-09-22ACPI: disable lower idle C-states across suspend/resumeThomas Gleixner
device_suspend() calls ACPI suspend functions, which seems to have undesired side effects on lower idle C-states. It took me some time to realize that especially the VAIO BIOSes (both Andrews jinxed UP and my elfstruck SMP one) show this effect. I'm quite sure that other bug reports against suspend/resume about turning the system into a brick have the same root cause. After fishing in the dark for quite some time, I realized that removing the ACPI processor module before suspend (this removes the lower C-state functionality) made the problem disappear. Interestingly enough the propability of having a bricked box is influenced by various factors (interrupts, size of the ram image, ...). Even adding a bunch of printks in the wrong places made the problem go away. The previous periodic tick implementation simply pampered over the problem, which explains why the dyntick / clockevents changes made this more prominent. We avoid complex functionality during the boot process and we have to do the same during suspend/resume. It is a similar scenario and equaly fragile. Add suspend / resume functions to the ACPI processor code and disable the lower idle C-states across suspend/resume. Fall back to the default idle implementation (halt) instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Len Brown <lenb@kernel.org> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-23sched: sched_clock_idle_[sleep|wakeup]_event()Ingo Molnar
construct a more or less wall-clock time out of sched_clock(), by using ACPI-idle's existing knowledge about how much time we spent idling. This allows the rq clock to work around TSC-stops-in-C2, TSC-gets-corrupted-in-C3 type of problems. ( Besides the scheduler's statistics this also benefits blktrace and printk-timestamps as well. ) Furthermore, the precise before-C2/C3-sleep and after-C2/C3-wakeup callbacks allow the scheduler to get out the most of the period where the CPU has a reliable TSC. This results in slightly more precise task statistics. the ACPI bits were acked by Len. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Len Brown <len.brown@intel.com>
2007-08-07ACPI: fix "Time Problems with 2.6.23-rc1-gf695baf2"Venki Pallipadi
Enable C3 without bm control only for CST based C3. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22Pull misc into release branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt
2007-07-20[IA64] Convert to generic timekeeping/clocksourceTony Luck
This is a merge of Peter Keilty's initial patch (which was revived by Bob Picco) for this with Hidetoshi Seto's fixes and scaling improvements. Acked-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-18ACPI: Enable C3 even when PM2_control is zeroVenkatesh Pallipadi
On systems that do not have pm2_control_block, we cannot really use ARB_DISABLE before C3. We used to disable C3 totally on such systems. To be compatible with Windows, we need to enable C3 on such systems now. We just skip ARB_DISABLE step before entering the C3-state and assume hardware is handling things correctly. Also, ACPI spec is not clear about pm2_control is _needed_ for C3 or not. We have atleast one system that need this to enable C3. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-06-23ACPI: fix 2.6.20 SMP boot regressionVenkatesh Pallipadi
Always disable/enable interrupts in the acpi idle routine, even in the error path. This is required as the 2.6.20 change in git commit d331e739f5ad2aaa9... "Fix interrupt race in idle callback" expects the idle handler to enable interrupt before returning. There was a case in acpi idle routine, in which interrupt was not being enabled before return, which caused the system to hang at bootup, while enabling C-states on an SMP system. The signature of the hang was that "processor.nocst" was required to enable boot. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-02[PATCH] x86: Log reason why TSC was marked unstablejohn stultz
Change mark_tsc_unstable() so it takes a string argument, which holds the reason the TSC was marked unstable. This is then displayed the first time mark_tsc_unstable is called. This should help us better debug why the TSC was marked unstable on certain systems and allow us to make sure we're not being overly paranoid when throwing out this troublesome clocksource. Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andi Kleen <ak@suse.de>
2007-04-25ACPI: remove duplicate includeRay Lee
Thomas's patch for including <asm/apic.h> for x86 UP builds came into Linus's tree from two different directions, both of which were merged. This reverts the latter, yanking out the duplicate #include and comment. Signed-off-by: Ray Lee <ray-lk@madrabbit.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-03-23[PATCH] i386: add command line option "local_apic_timer_c2_ok"Thomas Gleixner
It turned out that it is almost impossible to trust ACPI, BIOS & Co. regarding the C states. This was the reason to switch the local apic timer off in C2 state already. OTOH there are sane and well behaving systems, which get punished by that decision. Allow the user to confirm that the local apic timer is trustworthy in C2 state. This keeps the default behaviour on the safe side. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-23Revert "ACPI: Only use IPI on known broken machines (AMD, ↵Linus Torvalds
Dothan/BaniasPentium M)" This reverts commit 25496caec111481161e7f06bbfa12a533c43cc6f, which broke bootup on at least Ingo's ThinkPad T60. Need to figure out exactly what is wrong before we can re-do the logic. Requested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Thomas Renninger <trenn@suse.de> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-17ACPI: Only use IPI on known broken machines (AMD, Dothan/BaniasPentium M)Thomas Renninger
Use IPI for blacklisted CPUs, add parameter IPI vs LAPIC Currently, Linux disables lapic timer for all machines with C2 and higher C-state support. According to Intel only specific Intel models (Banias/Dothan) are broken in respect of not waking up from C2 with lapic. However, I am not sure about the naming of the parameter and how it could/should get integrated into the dyntick part (CONFIG_GENERIC_CLOCKEVENTS). There, a more fine grained check (TSC still running?, ..) is needed? Does this make sense (always use CLOCK_EVT_NOTIFY_BROADCAST_ON, but use OFF if forced by use_ipi=0: clockevents_notify(use_ipi ? CLOCK_EVT_NOTIFY_BROADCAST_ON : CLOCK_EVT_NOTIFY_BROADCAST_OFF, &pr->id); Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16Pull fluff into release branchLen Brown
Conflicts: arch/x86_64/pci/mmconfig.c drivers/acpi/bay.c Signed-off-by: Len Brown <len.brown@intel.com>
