path: root/drivers/acpi/processor_thermal.c
2015-07-08ACPI: Remove FSF mailing addressesJarkko Nikula
There is no need to carry potentially outdated Free Software Foundation mailing address in file headers since the COPYING file includes it. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-12-07ACPI: correct minor typosAl Stone
Correct "coolign" to "cooling" and "*_ptg" to "*_pctg" as intended. This changes comment text only. Signed-off-by: Al Stone <al.stone@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-12-07ACPI: Clean up inclusions of ACPI header filesLv Zheng
Replace direct inclusions of <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h>, which are incorrect, with <linux/acpi.h> inclusions and remove some inclusions of those files that aren't necessary. First of all, <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h> should not be included directly from any files that are built for CONFIG_ACPI unset, because that generally leads to build warnings about undefined symbols in !CONFIG_ACPI builds. For CONFIG_ACPI set, <linux/acpi.h> includes those files and for CONFIG_ACPI unset it provides stub ACPI symbols to be used in that case. Second, there are ordering dependencies between those files that always have to be met. Namely, it is required that <acpi/acpi_bus.h> be included prior to <acpi/acpi_drivers.h> so that the acpi_pci_root declarations the latter depends on are always there. And <acpi/acpi.h> which provides basic ACPICA type declarations should always be included prior to any other ACPI headers in CONFIG_ACPI builds. That also is taken care of including <linux/acpi.h> as appropriate. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Tony Luck <tony.luck@intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> (drivers/pci stuff) Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> (Xen stuff) Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-13ACPI / processor: Remove acpi_processor_get_limit_info()Lan Tianyu
acpi_processor_get_limit_info() is only called in the __acpi_processor_start() and what it does actually is just to check pr->flags.throttling and set limit. The pr pointer has been checked in the __acpi_processor_start() before acpi_processor_get_limit_info() being called. It doesn't make sense still to keep it as a function. So move code to __acpi_processor_start() and remove acpi_processor_get_limit_info(). Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-25ACPI / processor_thermal: avoid null pointer deference errorColin Ian King
Fix a null pointer deference by acpi_driver_data() if device is null. We should only set pr and check this is OK after we are sure device is not null. Smatch analysis: drivers/acpi/processor_thermal.c:223 processor_get_max_state() warn: variable dereferenced before check 'device' (see line 221) drivers/acpi/processor_thermal.c:237 processor_get_cur_state() warn: variable dereferenced before check 'device' (see line 235) drivers/acpi/processor_thermal.c:255 processor_set_cur_state() warn: variable dereferenced before check 'device' (see line 251) Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-03-22ACPI: Do cpufreq clamping for throttling per package v2Andi Kleen
On Intel CPUs the processor typically uses the highest frequency set by any logical CPU. When the system overheats Linux first forces the frequency to the lowest available one to lower the temperature. However this was done only per logical CPU, which means all logical CPUs in a package would need to go through this before the frequency is actually lowered. Worse this delay actually prevents real throttling, because the real throttle code only proceeds when the lowest frequency is already reached. So when a throttle event happens force the lowest frequency for all CPUs in the package where it happened. The per CPU state is now kept per package, not per logical CPU. An alternative would be to do it per cpufreq unit, but since we want to bring down the temperature of the complete chip it's better to do it for all. In principle it may even make sense to do it for all CPUs, but I kept it on the package for now. With this change the frequency is actually lowered, which in terms also allows real throttling to proceed. I also removed an unnecessary per cpu variable initialization. v2: Fix package mapping Cc: <stable@vger.kernel.org> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-12-21cpu: convert 'cpu' and 'machinecheck' sysdev_class to a regular subsystemKay Sievers
This moves the 'cpu sysdev_class' over to a regular 'cpu' subsystem and converts the devices to regular devices. The sysdev drivers are implemented as subsystem interfaces now. After all sysdev classes are ported to regular driver core entities, the sysdev implementation will be entirely removed from the kernel. Userspace relies on events and generic sysfs subsystem infrastructure from sysdev devices, which are made available with this conversion. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Borislav Petkov <bp@amd64.org> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Cc: Len Brown <lenb@kernel.org> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Dave Jones <davej@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-16ACPI: constify ops structsVasiliy Kulikov
Structs battery_file, acpi_dock_ops, file_operations, thermal_cooling_device_ops, thermal_zone_device_ops, kernel_param_ops are not changed in runtime. It is safe to make them const. register_hotplug_dock_device() was altered to take const "ops" argument to respect acpi_dock_ops' const notion. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-11ACPI thermal: remove two unused functionsZhang Rui
When CONFIG_CPU_FREQ=n ... drivers/acpi/processor_thermal.c:159:12: warning: ‘acpi_thermal_cpufreq_increase’ defined but not used drivers/acpi/processor_thermal.c:163:12: warning: ‘acpi_thermal_cpufreq_decrease’ defined but not used Remove unused declaration of ‘acpi_thermal_cpufreq_increase’ and ‘acpi_thermal_cpufreq_decrease’ Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-19ACPI: thermal: remove unused limit codeLen Brown
acpi_processor_apply_limit() acpi_thermal_cpufreq_increase() acpi_thermal_cpufreq_decrease() Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-19ACPI: remove dead codeStephen Hemminger
Found by running make namespacecheck on linux-next Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI processor: remove deprecated ACPI procfs I/FZhang Rui
Remove deprecated ACPI processor procfs I/F, including: /proc/acpi/processor/CPUX/power /proc/acpi/processor/CPUX/limit /proc/acpi/processor/CPUX/info /proc/acpi/processor/CPUX/throttling still exists, as we don't have sysfs I/F available for now. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-15ACPI: Remove unnecessary cast.H Hartley Sweeten
The struct seq_file 'private' member is a void *, the cast is not needed. Also, remove an extra whitespace line. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19Merge branch 'processor-procfs-2.6.32' into releaseLen Brown
2009-08-28ACPI: Move definition of PREFIX from acpi_bus.h to internal..hLen Brown
Linux/ACPI core files using internal.h all PREFIX "ACPI: ", however, not all ACPI drivers use/want it -- and they should not have to #undef PREFIX to define their own. Add GPL commment to internal.h while we are there. This does not change any actual console output, asside from a whitespace fix. Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-26ACPI processor: force throttling state when BIOS returns incorrect valueFrans Pop
If the BIOS reports an invalid throttling state (which seems to be fairly common after system boot), a reset is done to state T0. Because of a check in acpi_processor_get_throttling_ptc(), the reset never actually gets executed, which results in the error reoccurring on every access of for example /proc/acpi/processor/CPU0/throttling. Add a 'force' option to acpi_processor_set_throttling() to ensure the reset really takes effect. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13389 This patch, together with the next one, fixes a regression introduced in 2.6.30, listed on the regression list. They have been available for 2.5 months now in bugzilla, but have not been picked up, despite various reminders and without any reason given. Google shows that numerous people are hitting this issue. The issue is in itself relatively minor, but the bug in the code is clear. The patches have been in all my kernels and today testing has shown that throttling works correctly with the patches applied when the system overheats (http://bugzilla.kernel.org/show_bug.cgi?id=13918#c14). Signed-off-by: Frans Pop <elendil@planet.nl> Acked-by: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24ACPI: Make ACPI processor proc I/F depend on the ACPI_PROCFSZhao Yakui
Now whether the ACPI processor proc I/F is registered depends on the CONFIG_PROC. It had better depend on the CONFIG_ACPI_PROCFS. When the CONFIG_ACPI_PROCFS is unset in kernel configuration, the ACPI processor proc I/F won't be registered. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'constify' into releaseLen Brown
2009-04-03ACPI: constify VFTs (1/2)Jan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-20thermal: use integers rather than strings for thermal valuesMatthew Garrett
The thermal API currently uses strings to pass values to userspace. This makes it difficult to use from within the kernel. Change the interface to use integers and fix up the consumers. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-07ACPI: consolidate ACPI_*_COMPONENT definitions in acpi_drivers.hBjorn Helgaas
Move all the component definitions for drivers to a single shared place, include/acpi/acpi_drivers.h. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29acpi: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Len Brown <lenb@kernel.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28[CPUFREQ] change cpu freq tables to per_cpu variablesMike Travis
Change cpufreq tables from arrays to per_cpu variables in drivers/acpi/processor_thermal.c Based on git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git Cc: Len Brown <len.brown@intel.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Dave Jones <davej@codemonkey.org.uk>
2008-02-01ACPI: register ACPI Processor as generic thermal cooling deviceZhang Rui
Register ACPI processor as thermal cooling devices. A combination of processor T-state and P-state are used for thermal throttling. the processor will reduce the frequency first and then set the T-state. we use cpufreq_thermal_reduction_pctg to calculate the cpufreq limit, and call cpufreq_verify_with_limit to set the cpufreq limit. if cpufreq driver is loaded, then we have four cooling state for cpufreq control. cooling state 0: cpufreq limit == max_freq cooling state 1: cpufreq limit == max_freq * 80% cooling state 2: cpufreq limit == max_freq * 60% cooling state 3: cpufreq limit == max_freq * 40% after the cpufreq limit is set to 40 percentage of the max_freq, we use T-state for cooling. eg. a processor has P-state support, and it has 8 T-state (T0-T7), the max_state of the proceesor is 10: state cpufreq-limit T-state 0: max_freq T0 1: max_freq * 80% T0 2: max_freq * 60% T0 3: max_freq * 40% T0 4: max_freq * 40% T1 5: max_freq * 40% T2 6: max_freq * 40% T3 7: max_freq * 40% T4 8: max_freq * 40% T5 9: max_freq * 40% T6 10: max_freq * 40% T7 Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: delete extra #defines in /drivers/acpi/ driversLen Brown
Cosmetic only. Except in a single case, #define ACPI_*_DRIVER_NAME were invoked 0 or 1 times. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: clean up ACPI_MODULE_NAME() useLen Brown
cosmetic only Make "module name" actually match the file name. Invoke with ';' as leaving it off confuses Lindent and gcc doesn't care. Fix indentation where Lindent did get confused. Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-14ACPI: Remove unnecessary from/to-void* and to-void casts in drivers/acpiJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
2006-06-27ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...)Len Brown
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-08[ACPI] make two processor functions staticAdrian Bunk
acpi_processor_write_throttling() acpi_processor_write_limit() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-07[ACPI] move some run-time structure inits to compile timeArjan van de Ven
acpi_processor_limit_fops.write was written at run time, but can be initiailized at compile-time instead. Similar for acpi_video_bus_POST_fops.write and friends, but keep doing those at runtime to avoid prototype-hell. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-22[ACPI] fix passive cooling regressionThomas Renninger
Return logic was inverted. Going for changing the return value to not return zero as it is makes more sense regarding the naming of the function (cpu_has_cpufreq()). http://bugzilla.kernel.org/show_bug.cgi?id=3410 Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-30[ACPI] Allow return to active cooling mode once passive mode is enteredThomas Renninger
http://bugzilla.kernel.org/show_bug.cgi?id=3410 https://bugzilla.novell.com/show_bug.cgi?id=131543 Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Konstantin Karasyov <konstantin.a.karasyov@intel.com> Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Yu Luming <luming.yu@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
