commit 78a18fec5258c8df9435399a1ea022d73d3eceb9 upstream.
Set the acpi_device pointer which acpi_bus_get_device() returns-by-
reference to NULL on errors.
We've recently had 2 cases where callers of acpi_bus_get_device()
did not properly error check the return value, so set the returned-
by-reference acpi_device pointer to NULL, because at least some
callers of acpi_bus_get_device() expect that to be done on errors.
[ rjw: This issue was exposed by commit 71da201f38df ("ACPI: scan:
Defer enumeration of devices with _DEP lists") which caused it to
be much more likely to occur on some systems, but the real defect
had been introduced by an earlier commit. ]
Fixes: 40e7fcb19293 ("ACPI: Add _DEP support to fix battery issue on Asus T100TA")
Fixes: bcfcd409d4db ("usb: split code locating ACPI companion into port and device")
Reported-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Tested-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Diagnosed-by: Rafael J. Wysocki <rafael@kernel.org>
Cc: All applicable <stable@vger.kernel.org>
[ rjw: Subject and changelog edits ]
commit 956ad9d98b73f59e442cc119c98ba1e04e94fe6d upstream.
As recently reported, some platforms provide a list of power
resources for device power state D3hot, through the _PR3 object,
but they do not provide a list of power resources for device power
state D0.
Among other things, this causes acpi_device_get_power() to return
D3hot as the current state of the device in question if all of the
D3hot power resources are "on", because it sees the power_resources
flag set and calls acpi_power_get_inferred_state() which finds that
D3hot is the shallowest power state with all of the associated power
resources turned "on", so that's what it returns. Moreover, that
value takes precedence over the acpi_dev_pm_explicit_get() return
value, because it means a deeper power state. The device may very
well be in D0 physically at that point, however.
Moreover, the presence of _PR3 without _PR0 for a given device
means that only one D3-level power state can be supported by it.
Namely, because there are no power resources to turn "off" when
transitioning the device from D0 into D3cold (which should be
supported since _PR3 is present), the evaluation of _PS3 should
be sufficient to put it straight into D3cold, but this means that
the effect of turning "on" the _PR3 power resources is unclear,
so it is better to avoid doing that altogether. Consequently,
there is no practical way do distinguish D3cold from D3hot for
the device in question and the power states of it can be labeled
so that D3hot is the deepest supported one (and Linux assumes
that putting a device into D3hot via ACPI may cause power to be
removed from it anyway, for legacy reasons).
To work around the problem described above modify the ACPI
enumeration of devices so that power resources are only used
for device power management if the list of D0 power resources
is not empty and make it mart D3cold as supported only if that
is the case and the D3hot list of power resources is not empty
too.
Fixes: ef85bdbec444 ("ACPI / scan: Consolidate extraction of power resources lists")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=205057
Link: https://lore.kernel.org/linux-acpi/20200603194659.185757-1-hdegoede@redhat.com/
Reported-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: youling257@gmail.com
Cc: 3.10+ <stable@vger.kernel.org> # 3.10+
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
commit 5331d9cab32ef640b4cd38a43b0858874fbb7168 upstream.
Commit e647b532275b ("ACPI: Add early device probing infrastructure")
introduced code that allows inserting driver specific
struct acpi_probe_entry probe entries into ACPI linker sections
(one per-subsystem, eg irqchip, clocksource) that are then walked
to retrieve the data and function hooks required to probe the
respective kernel components.
Probing for all entries in a section is triggered through
the __acpi_probe_device_table() function, that in turn, according
to the table ID a given probe entry reports parses the table
with the function retrieved from the respective section structures
(ie struct acpi_probe_entry). Owing to the current ACPI table
parsing implementation, the __acpi_probe_device_table() function
has to share global variables with the acpi_match_madt() function, so
in order to guarantee mutual exclusion locking is required
between the two functions.
Current kernel code implements the locking through the acpi_probe_lock
spinlock; this has the side effect of requiring all code called
within the lock (ie struct acpi_probe_entry.probe_{table/subtbl} hooks)
not to sleep.
However, kernel subsystems that make use of the early probing
infrastructure are relying on kernel APIs that may sleep (eg
irq_domain_alloc_fwnode(), among others) in the function calls
pointed at by struct acpi_probe_entry.{probe_table/subtbl} entries
(eg gic_v2_acpi_init()), which is a bug.
Since __acpi_probe_device_table() is called from context
that is allowed to sleep the acpi_probe_lock spinlock can be replaced
with a mutex; this fixes the issue whilst still guaranteeing
mutual exclusion.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Fixes: e647b532275b (ACPI: Add early device probing infrastructure)
* acpi-pci:
PCI: ACPI: Add support for PCI device DMA coherency
PCI: OF: Move of_pci_dma_configure() to pci_dma_configure()
of/pci: Fix pci_get_host_bridge_device leak
device property: ACPI: Remove unused DMA APIs
device property: ACPI: Make use of the new DMA Attribute APIs
device property: Adding DMA Attribute APIs for Generic Devices
ACPI: Adding DMA Attribute APIs for ACPI Device
device property: Introducing enum dev_dma_attr
ACPI: Honor ACPI _CCA attribute setting
drivers/crypto/ccp/ccp-platform.c
Adding acpi_get_dma_attr() to query DMA attributes of ACPI devices.
It returns the enum dev_dma_attr, which communicates DMA information
more clearly. This API replaces the acpi_check_dma(), which will be
removed in subsequent patch.
This patch also provides a convenient function, acpi_dma_supported(),
to check DMA support of the specified ACPI device.
Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
* acpi-init:
clocksource: cosmetic: Drop OF 'dependency' from symbols
clocksource / arm_arch_timer: Convert to ACPI probing
clocksource: Add new CLKSRC_{PROBE,ACPI} config symbols
clocksource / ACPI: Add probing infrastructure for ACPI-based clocksources
irqchip / GIC: Convert the GIC driver to ACPI probing
irqchip / ACPI: Add probing infrastructure for ACPI-based irqchips
* acpi-scan:
ACPI / scan: use kstrdup_const() in acpi_add_id()
ACPI / scan: constify struct acpi_hardware_id::id
ACPI / scan: constify first argument of struct acpi_scan_handler::match
* acpi-tables:
ACPI / tables: test the correct variable
x86, ACPI: Handle apic/x2apic entries in MADT in correct order
ACPI / tables: Add acpi_subtable_proc to ACPI table parsers
* acpi-ec:
ACPI / EC: Fix a race issue in acpi_ec_guard_event()
ACPI / EC: Fix query handler related issues
* acpi-assorted:
ACPI: change acpi_sleep_proc_init() to return void
ACPI: change init_acpi_device_notify() to return void
IRQ controllers and timers are the two types of device the kernel
requires before being able to use the device driver model.
ACPI so far lacks a proper probing infrastructure similar to the one
we have with DT, where we're able to declare IRQ chips and
clocksources inside the driver code, and let the core code pick it up
and call us back on a match. This leads to all kind of really ugly
hacks all over the arm64 code and even in the ACPI layer.
In order to allow some basic probing based on the ACPI tables,
introduce "struct acpi_probe_entry" which contains just enough
data and callbacks to match a table, an optional subtable, and
call a probe function. A driver can, at build time, register itself
and expect being called if the right entry exists in the ACPI
table.
A acpi_probe_device_table() is provided, taking an identifier for
a set of acpi_prove_entries, and iterating over the registered
entries.
Reviewed-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Empirically, acpi_add_id is mostly called with string literals, so
using kstrdup_const for initializing struct acpi_hardware_id::id saves
a little run-time memory and a string copy.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
This is preparation for using kstrdup_const to initialize that member.
Make device_get_next_child_node() work with ACPI data-only subnodes
introduced previously.
Namely, replace acpi_get_next_child() with acpi_get_next_subnode()
that can handle (and return) child device objects as well as child
data-only subnodes of the given device and modify the ACPI part
of the GPIO subsystem to handle data-only subnodes returned by it.
To that end, introduce acpi_node_get_gpiod() taking a struct
fwnode_handle pointer as the first argument. That argument may
point to an ACPI device object as well as to a data-only subnode
and the function should do the right thing (ie. look for the matching
GPIO descriptor correctly) in either case.
Next, modify fwnode_get_named_gpiod() to use acpi_node_get_gpiod()
instead of acpi_get_gpiod_by_index() which automatically causes
devm_get_gpiod_from_child() to work with ACPI data-only subnodes
that may be returned by device_get_next_child_node() which in turn
is required by the users of that function (the gpio_keys_polled
and gpio-leds drivers).
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
drivers/acpi/scan.c
The conflict is resolved by moving the just introduced
acpi_device_is_first_physical_node() to bus.c and using
the existing acpi_companion_match() from there.
There will be an additional commit to combine the two.
Some devices, like MFD subdevices, share a single ACPI companion device so
that they are able to access their resources and children. However,
currently all these subdevices are attached to the ACPI power domain and
this might cause that the power methods for the companion device get called
more than once.
In order to solve this we attach the ACPI power domain only to the first
physical device that is bound to the ACPI companion device. In case of MFD
devices, this is the parent MFD device itself.
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Move the registration of the ACPI bus type to acpi_bus_init() and
avoid using ACPI going forward if it fails (too many things depend on
the presence of the ACPI bus type).
To reduce the size of scan.c and improve the readability of it, move
code related to device notification, the definitions of the ACPI bus
operations and the driver management code to drivers/acpi/bus.c.
code related device matching into drivers/acpi/bus.c.
all code related to device sysfs, modalias creation etc. to a new
file called device_sysfs.c.
Device drivers typically use ACPI _HIDs/_CIDs listed in struct device_driver
acpi_match_table to match devices. However, for generic drivers, we do not
want to list _HID for all supported devices. Also, certain classes of devices
do not have _CID (e.g. SATA, USB). Instead, we can leverage ACPI _CLS,
which specifies PCI-defined class code (i.e. base-class, subclass and
programming interface). This patch adds support for matching ACPI devices using
the _CLS method.
To support loadable module, current design uses _HID or _CID to match device's
modalias. With the new way of matching with _CLS this would requires modification
to the current ACPI modalias key to include _CLS. This patch appends PCI-defined
class-code to the existing ACPI modalias as following.
acpi:<HID>:<CID1>:<CID2>:..:<CIDn>:<bbsspp>:
E.g:
# cat /sys/devices/platform/AMDI0600:00/modalias
acpi:AMDI0600:010601:
where bb is th base-class code, ss is te sub-class code, and pp is the
programming interface code
Since there would not be _HID/_CID in the ACPI matching table of the driver,
this patch adds a field to acpi_device_id to specify the matching _CLS.
static const struct acpi_device_id ahci_acpi_match[] = {
{ ACPI_DEVICE_CLASS(PCI_CLASS_STORAGE_SATA_AHCI, 0xffffff) },
In this case, the corresponded entry in modules.alias file would be:
alias acpi*:010601:* ahci_platform
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
* acpi-cca:
ufs: fix TRUE and FALSE re-define build error
megaraid_sas: fix TRUE and FALSE re-define build error
amd-xgbe: Unify coherency checking logic with device_dma_is_coherent()
crypto: ccp - Unify coherency checking logic with device_dma_is_coherent()
device property: Introduces device_dma_is_coherent()
arm64 : Introduce support for ACPI _CCA object
ACPI / scan: Parse _CCA and setup device coherency
* acpi-video: (38 commits)
ACPI / video: Make acpi_video_unregister_backlight() private
acpi-video-detect: Remove old API
toshiba-acpi: Port to new backlight interface selection API
thinkpad-acpi: Port to new backlight interface selection API
sony-laptop: Port to new backlight interface selection API
samsung-laptop: Port to new backlight interface selection API
msi-wmi: Port to new backlight interface selection API
msi-laptop: Port to new backlight interface selection API
intel-oaktrail: Port to new backlight interface selection API
ideapad-laptop: Port to new backlight interface selection API
fujitsu-laptop: Port to new backlight interface selection API
eeepc-laptop: Port to new backlight interface selection API
dell-wmi: Port to new backlight interface selection API
dell-laptop: Port to new backlight interface selection API
compal-laptop: Port to new backlight interface selection API
asus-wmi: Port to new backlight interface selection API
asus-laptop: Port to new backlight interface selection API
apple-gmux: Port to new backlight interface selection API
acer-wmi: Port to new backlight interface selection API
ACPI / video: Fix acpi_video _register vs _unregister_backlight race
* acpi-pm:
ACPI / PM: Add missing pm_generic_complete() invocation
ACPI / PM: Turn power resources on and off in the right order during resume
ACPI / PM: Rework device power management to follow ACPI 6
ACPI / PM: Drop stale comment from acpi_power_transition()
* acpi-apei:
GHES: Make NMI handler have a single reader
GHES: Elliminate double-loop in the NMI handler
GHES: Panic right after detection
GHES: Carve out the panic functionality
GHES: Carve out error queueing in a separate function
* acpi-osl:
ACPI / osl: use same type for acpi_predefined_names values as in definition
* acpi-pci:
ACPI / PCI: remove stale list_head in struct acpi_prt_entry
This allows video_detect.c to be build as a module, this is a preparation
patch for the backlight interface selection logic cleanup.
Note this commit also causes acpi_is_video_device() to always be build
indepedent of CONFIG_ACPI_VIDEO, as there is no reason to make its
building depend on CONFIG_ACPI_VIDEO.
Acked-by: Darren Hart <dvhart@linux.intel.com>
This patch implements support for ACPI _CCA object, which is introduced in
ACPIv5.1, can be used for specifying device DMA coherency attribute.
The parsing logic traverses device namespace to parse coherency
information, and stores it in acpi_device_flags. Then uses it to call
arch_setup_dma_ops() when creating each device enumerated in DSDT
during ACPI scan.
This patch also introduces acpi_dma_is_coherent(), which provides
an interface for device drivers to check the coherency information
similarly to the of_dma_is_coherent().
Signed-off-by: Mark Salter <msalter@redhat.com>
Make the button ACPI device ID array static const. Safes us a little bit
of code.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Use a #defined symbol ACPI_DT_NAMESPACE_HID instead of the PRP0001
string.
The ACPI 6 specification has made some changes in the device power
management area. In particular:
* The D3hot power state is now supposed to be always available
(instead of D3cold) and D3cold is only regarded as valid if the
_PR3 object is present for the given device.
* The required ordering of transitions into power states deeper than
D0 is now such that for a transition into state Dx the _PSx method
is supposed to be executed first, if present, and the states of
the power resources the device depends on are supposed to be
changed after that.
* It is now explicitly forbidden to transition devices from
lower-power (deeper) into higher-power (shallower) power states
other than D0.
Those changes have been made so the specification reflects the
Windows' device power management code that the vast majority of
systems using ACPI is validated against.
To avoid artificial differences in ACPI device power management
between Windows and Linux, modify the ACPI device power management
code to follow the new specification. Add comments explaining the
code flow in some unclear places.
This only may affect some real corner cases in which the OS behavior
expected by the firmware is different from the Windows one, but that's
quite unlikely. The transition ordering change affects transitions
to D1 and D2 which are rarely used (if at all) and into D3hot and
D3cold for devices actually having _PR3, but those are likely to
be validated against Windows anyway. The other changes may affect
code calling acpi_device_get_power() or acpi_device_update_power()
where ACPI_STATE_D3_HOT may be returned instead of ACPI_STATE_D3_COLD
(that's why the ACPI fan driver needs to be updated too) and since
transitions into ACPI_STATE_D3_HOT may remove power now, it is better
to avoid this one in acpi_pm_device_sleep_state() if the "no power
off" PM QoS flag is set.
The only existing user of acpi_device_can_poweroff() really cares
about the case when _PR3 is present, so the change in that function
should not cause any problems to happen too.
A plus is that PCI_D3hot can be mapped to ACPI_STATE_D3_HOT
now and the compatibility with older systems should be covered
automatically.
In any case, if any real problems result from this, it still will
be better to follow the Windows' behavior (which now is reflected
by the specification too) in general and handle the cases when it
doesn't work via quirks.
If the special PRP0001 device ID is present in the given device's list
of ACPI/PNP IDs and the device has a valid "compatible" property in
the _DSD, it should be enumerated using the default mechanism,
unless some scan handlers match the IDs preceding PRP0001 in the
device's list of ACPI/PNP IDs. In addition to that, no scan handlers
matching the IDs following PRP0001 in that list should be attached
to the device.
To make that happen, define a scan handler that will match PRP0001
and trigger the default enumeration for the matching devices if the
"compatible" property is present for them.
Since that requires the check for platform_id and device->handler
to be removed from acpi_default_enumeration(), move the fallback
invocation of acpi_default_enumeration() to acpi_bus_attach()
(after it's checked if there's a matching ACPI driver for the
device), which is a better place to call it, and do the platform_id
check in there too (device->handler is guaranteed to be unset at
the point where the function is looking for a matching ACPI driver).
acpi_scan_is_offline() may be called under the physical_node_lock
lock of the given device object's parent, so prevent lockdep from
complaining about that by annotating that instance with
SINGLE_DEPTH_NESTING.
Fixes: caa73ea158de (ACPI / hotplug / driver core: Handle containers in a special way)
Reported-and-tested-by: Xie XiuQi <xiexiuqi@huawei.com>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Cc: 3.14+ <stable@vger.kernel.org> # 3.14+
Commit e1acdeb0e770 "ACPI / scan: Simplify acpi_match_device()"
introduced code that may lead to a NULL pointer dereference when
trying to unlock a mutex. Fix that.
Fixes: e1acdeb0e770 "ACPI / scan: Simplify acpi_match_device()"
Currently, the ACPI modalias creation covers two mutually exclusive
cases: If the PRP0001 device ID is present in the device's list of
ACPI/PNP IDs and the "compatible" property is present in _DSD, the
created modalias will follow the OF rules of modalias creation.
Otherwise, ACPI rules are used.
However, that is not really desirable, because the presence of PRP0001
in the list of device IDs generally does not preclude using other
ACPI/PNP IDs with that device and those other IDs may be of higher
priority. In those cases, the other IDs should take preference over
PRP0001 and therefore they also should be present in the modalias.
For this reason, rework the modalias creation for ACPI so that it
shows both the ACPI-style and OF-style modalias strings if the
device has a non-empty list of ACPI/PNP IDs (other than PRP0001)
and a valid "compatible" property at the same time.
If the special PRP0001 device ID is present in a device's _CID list,
it should not prevent any ACPI/PNP IDs preceding it in the device's
list of identifiers from being matched first. That is, only if none
of the IDs preceding PRP0001 in the device's PNP/ACPI IDs list
matches the IDs recognized by the driver, the driver's list of
"compatible" IDs should be matched against the device's "compatible"
property, if present.
In addition to that, drivers can provide both acpi_match_table and
of_match_table at the same time and the of_compatible matching
should be used in that case too if PRP0001 is present in the
device's list of identifiers.
To make that happen, rework acpi_driver_match_device() to do the
"compatible" property check in addition to matching the driver's
list of ACPI IDs against the device's one.
Redefine acpi_companion_match() to return an ACPI device object
pointer instead of a bool and use it to remove some redundant code
from acpi_match_device().
Redefine the function used for matching the device's "compatible"
property against a given list of "compatible" strings to take
a pointer to that list instead of a driver object pointer to
make it more general.
The fixed event handler should return a value that is either 0 or 1
meanning if the event is handled or not, instead of an acpi_status to
mean if the handler runs well or not.
Suggested-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
This new feature is to interpret AMD specific ACPI device to
platform device such as I2C, UART, GPIO found on AMD CZ and
later chipsets. It based on example intel LPSS. Now, it can
support AMD I2C, UART and GPIO.
Signed-off-by: Ken Xue <Ken.Xue@amd.com>
If an ACPI device object whose _STA returns 0 (not present and not
functional) has _PR0 or _PS0, its power_manageable flag will be set
and acpi_bus_init_power() will return 0 for it. Consequently, if
such a device object is passed to the ACPI device PM functions, they
will attempt to carry out the requested operation on the device,
although they should not do that for devices that are not present.
To fix that problem make acpi_bus_init_power() return an error code
for devices that are not present which will cause power_manageable to
be cleared for them as appropriate in acpi_bus_get_power_flags().
However, the lists of power resources should not be freed for the
device in that case, so modify acpi_bus_get_power_flags() to keep
those lists even if acpi_bus_init_power() returns an error.
Accordingly, when deciding whether or not the lists of power
resources need to be freed, acpi_free_power_resources_lists()
should check the power.flags.power_resources flag instead of
flags.power_manageable, so make that change too.
Furthermore, if acpi_bus_attach() sees that flags.initialized is
unset for the given device, it should reset the power management
settings of the device and re-initialize them from scratch instead
of relying on the previous settings (the device may have appeared
after being not present previously, for example), so make it use
the 'valid' flag of the D0 power state as the initial value of
flags.power_manageable for it and call acpi_bus_init_power() to
discover its current power state.
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
* acpi-scan:
ACPI / scan: Change the level of _DEP-related messages to KERN_DEBUG
* acpi-utils:
ACPI / utils: Drop error messages from acpi_evaluate_reference()
* acpi-pm:
ACPI / PM: Do not disable wakeup GPEs that have not been enabled
Two _DEP-related failure messages are printed as dev_err() which is
unnecessary and annoying. Use dev_dbg() to print them.
While at it, one of the messages should actually say it is related
to _DEP, so modify it to that effect.
Fixes: 40e7fcb19293 (ACPI: Add _DEP support to fix battery issue on Asus T100TA)
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
* acpi-scan:
* acpi-pm:
ACPI / sleep: Drain outstanding events after disabling multiple GPEs
ACPI / PM: Fixed a typo in a comment
* acpi-lpss:
dmaengine: dw: enable runtime PM
ACPI / LPSS: introduce a 'proxy' device to power on LPSS for DMA
ACPI / LPSS: allow to use specific PM domain during ->probe()
ACPI / LPSS: add all LPSS devices to the specific power domain
* acpi-processor:
ACPI / cpuidle: avoid assigning signed errno to acpi_status
ACPI / processor: remove unused variabled from acpi_processor_power structure
ACPI / processor: Update the comments in processor.h
ACPI 5.0 introduces _DEP (Operation Region Dependencies) to designate
device objects that OSPM should assign a higher priority in start
ordering due to future operation region accesses.
On Asus T100TA, ACPI battery info are read from a I2C slave device via
I2C operation region. Before I2C operation region handler is installed,
battery _STA always returns 0. There is a _DEP method of designating
start order under battery device node.
This patch is to implement _DEP feature to fix battery issue on the
Asus T100TA. Introducing acpi_dep_list and adding dep_unmet count
in struct acpi_device. During ACPI namespace scan, create struct
acpi_dep_data for a valid pair of master (device pointed to by _DEP)/
slave(device with _DEP), record master's and slave's ACPI handle in
it and put it into acpi_dep_list. The dep_unmet count will increase
by one if there is a device under its _DEP. Driver's probe() should
return EPROBE_DEFER when find dep_unmet is larger than 0. When I2C
operation region handler is installed, remove all struct acpi_dep_data
on the acpi_dep_list whose master is pointed to I2C host controller
and decrease slave's dep_unmet. When dep_unmet decreases to 0, all
_DEP conditions are met and then do acpi_bus_attach() for the device
in order to resolve battery _STA issue on the Asus T100TA.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=69011
Tested-by: Jan-Michael Brummer <jan.brummer@tabos.org>
Tested-by: Adam Williamson <adamw@happyassassin.net>
Tested-by: Michael Shigorin <shigorin@gmail.com>
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
Add new generic routines are provided for retrieving properties from
device description objects in the platform firmware in case there are
no struct device objects for them (either those objects have not been
created yet or they do not exist at all).
The following functions are provided:
fwnode_property_present()
fwnode_property_read_u8()
fwnode_property_read_u16()
fwnode_property_read_u32()
fwnode_property_read_u64()
fwnode_property_read_string()
fwnode_property_read_u8_array()
fwnode_property_read_u16_array()
fwnode_property_read_u32_array()
fwnode_property_read_u64_array()
fwnode_property_read_string_array()
in analogy with the corresponding functions for struct device added
previously. For all of them, the first argument is a pointer to struct
fwnode_handle (new type) that allows a device description object
(depending on what platform firmware interface is in use) to be
obtained.
Add a new macro device_for_each_child_node() for iterating over the
children of the device description object associated with a given
device and a new function device_get_child_node_count() returning the
number of a given device's child nodes.
The interface covers both ACPI and Device Trees.
Suggested-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Grant Likely <grant.likely@linaro.org>
We have lots of existing Device Tree enabled drivers and allocating
separate _HID for each is not feasible. Instead we allocate special _HID
"PRP0001" that means that the match should be done using Device Tree
compatible property using driver's .of_match_table instead if the driver
is missing .acpi_match_table.
If there is a need to distinguish from where the device is enumerated
(DT/ACPI) driver can check dev->of_node or ACPI_COMPATION(dev).
Device Tree is used in many embedded systems to describe the system
configuration to the OS. It supports attaching properties or name-value
pairs to the devices it describe. With these properties one can pass
additional information to the drivers that would not be available
otherwise.
ACPI is another configuration mechanism (among other things) typically
seen, but not limited to, x86 machines. ACPI allows passing arbitrary
data from methods but there has not been mechanism equivalent to Device
Tree until the introduction of _DSD in the recent publication of the
ACPI 5.1 specification.
In order to facilitate ACPI usage in systems where Device Tree is
typically used, it would be beneficial to standardize a way to retrieve
Device Tree style properties from ACPI devices, which is what we do in
this patch.
If a given device described in ACPI namespace wants to export properties it
must implement _DSD method (Device Specific Data, introduced with ACPI 5.1)
that returns the properties in a package of packages. For example:
Name (_DSD, Package () {
ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"),
Package () {
Package () {"name1", <VALUE1>},
Package () {"name2", <VALUE2>},
The UUID reserved for properties is daffd814-6eba-4d8c-8a91-bc9bbf4aa301
and is documented in the ACPI 5.1 companion document called "_DSD
Implementation Guide" [1], [2].
We add several helper functions that can be used to extract these
properties and convert them to different Linux data types.
The ultimate goal is that we only have one device property API that
retrieves the requested properties from Device Tree or from ACPI
transparent to the caller.
[1] http://www.uefi.org/sites/default/files/resources/_DSD-implementation-guide-toplevel.htm
[2] http://www.uefi.org/sites/default/files/resources/_DSD-device-properties-UUID.pdf
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Reviewed-by: Grant Likely <grant.likely@linaro.org>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
Commit 6ab3430129e2 ("mfd: Add ACPI support") made the MFD subdevices
share the parent MFD ACPI companion if no _HID/_CID is specified for
the subdevice in mfd_cell description. However, since all the subdevices
share the ACPI companion, the match and modalias generation logic started
to use the ACPI companion as well resulting this:
# cat /sys/bus/platform/devices/HID-SENSOR-200041.6.auto/modalias
acpi:INT33D1:PNP0C50:
instead of the expected one
platform:HID-SENSOR-200041
In other words the subdevice modalias is overwritten by the one taken from
ACPI companion. This causes udev not to load the driver anymore.
It is useful to be able to share the ACPI companion so that MFD subdevices
(and possibly other devices as well) can access the ACPI resources even if
they do not have ACPI representation in the namespace themselves.
An example where this is used is Minnowboard LPC driver that creates GPIO
as a subdevice among other things. Without the ACPI companion gpiolib is
not able to lookup the corresponding GPIO controller from ACPI GpioIo
resource.
To fix this, restrict the match and modalias logic to be limited to the
first (primary) physical device associated with the given ACPI comapnion.
The secondary devices will still be able to access the ACPI companion,
but they will be matched in a different way.
Fixes: 6ab3430129e2 (mfd: Add ACPI support)
Reported-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Pull ACPI and power management updates from Rafael Wysocki:
"This is material that didn't make it to my 3.18-rc1 pull request for
various reasons, mostly related to timing and travel (LinuxCon EU /
LPC) plus a couple of fixes for recent bugs.
The only really new thing here is the PM QoS class for memory
bandwidth, but it is simple enough and users of it will be added in
the next cycle. One major change in behavior is that platform devices
enumerated by ACPI will use 32-bit DMA mask by default. Also included
is an ACPICA update to a new upstream release, but that's mostly
cleanups, changes in tools and similar. The rest is fixes and
cleanups mostly.
Specifics:
- Fix for a recent PCI power management change that overlooked the
fact that some IRQ chips might not be able to configure PCIe PME
for system wakeup from Lucas Stach.
- Fix for a bug introduced in 3.17 where acpi_device_wakeup() is
called with a wrong ordering of arguments from Zhang Rui.
- A bunch of intel_pstate driver fixes (all -stable candidates) from
Dirk Brandewie, Gabriele Mazzotta and Pali Rohár.
- Fixes for a rather long-standing problem with the OOM killer and
the freezer that frozen processes killed by the OOM do not actually
release any memory until they are thawed, so OOM-killing them is
rather pointless, with a couple of cleanups on top (Michal Hocko,
Cong Wang, Rafael J Wysocki).
- ACPICA update to upstream release 20140926, inlcuding mostly
cleanups reducing differences between the upstream ACPICA and the
kernel code, tools changes (acpidump, acpiexec) and support for the
_DDN object (Bob Moore, Lv Zheng).
- New PM QoS class for memory bandwidth from Tomeu Vizoso.
- Default 32-bit DMA mask for platform devices enumerated by ACPI
(this change is mostly needed for some drivers development in
progress targeted at 3.19) from Heikki Krogerus.
- ACPI EC driver cleanups, mostly related to debugging, from Lv
Zheng.
- cpufreq-dt driver updates from Thomas Petazzoni.
- powernv cpuidle driver update from Preeti U Murthy"
* tag 'pm+acpi-3.18-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (34 commits)
intel_pstate: Correct BYT VID values.
intel_pstate: Fix BYT frequency reporting
intel_pstate: Don't lose sysfs settings during cpu offline
cpufreq: intel_pstate: Reflect current no_turbo state correctly
cpufreq: expose scaling_cur_freq sysfs file for set_policy() drivers
cpufreq: intel_pstate: Fix setting max_perf_pct in performance policy
PCI / PM: handle failure to enable wakeup on PCIe PME
ACPI: invoke acpi_device_wakeup() with correct parameters
PM / freezer: Clean up code after recent fixes
PM: convert do_each_thread to for_each_process_thread
OOM, PM: OOM killed task shouldn't escape PM suspend
freezer: remove obsolete comments in __thaw_task()
freezer: Do not freeze tasks killed by OOM killer
ACPI / platform: provide default DMA mask
cpuidle: powernv: Populate cpuidle state details by querying the device-tree
cpufreq: cpufreq-dt: adjust message related to regulators
cpufreq: cpufreq-dt: extend with platform_data
cpufreq: allow driver-specific data
ACPI / EC: Cleanup coding style.
ACPI / EC: Refine event/query debugging messages.
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management updates from Zhang Rui:
"Sorry that I missed the merge window as there is a bug found in the
last minute, and I have to fix it and wait for the code to be tested
in linux-next tree for a few days. Now the buggy patch has been
dropped entirely from my next branch. Thus I hope those changes can
still be merged in 3.18-rc2 as most of them are platform thermal
driver changes.
Specifics:
- introduce ACPI INT340X thermal drivers.
Newer laptops and tablets may have thermal sensors and other
devices with thermal control capabilities that are exposed for the
OS to use via the ACPI INT340x device objects. Several drivers are
introduced to expose the temperature information and cooling
ability from these objects to user-space via the normal thermal
framework.
From: Lu Aaron, Lan Tianyu, Jacob Pan and Zhang Rui.
- introduce a new thermal governor, which just uses a hysteresis to
switch abruptly on/off a cooling device. This governor can be used
to control certain fan devices that can not be throttled but just
switched on or off. From: Peter Feuerer.
- introduce support for some new thermal interrupt functions on
i.MX6SX, in IMX thermal driver. From: Anson, Huang.
- introduce tracing support on thermal framework. From: Punit
Agrawal.
- small fixes in OF thermal and thermal step_wise governor"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (25 commits)
Thermal: int340x thermal: select ACPI fan driver
Thermal: int3400_thermal: use acpi_thermal_rel parsing APIs
Thermal: int340x_thermal: expose acpi thermal relationship tables
Thermal: introduce int3403 thermal driver
Thermal: introduce INT3402 thermal driver
Thermal: move the KELVIN_TO_MILLICELSIUS macro to thermal.h
ACPI / Fan: support INT3404 thermal device
ACPI / Fan: add ACPI 4.0 style fan support
ACPI / fan: convert to platform driver
ACPI / fan: use acpi_device_xxx_power instead of acpi_bus equivelant
ACPI / fan: remove no need check for device pointer
ACPI / fan: remove unused macro
Thermal: int3400 thermal: register to thermal framework
Thermal: int3400 thermal: add capability to detect supporting UUIDs
Thermal: introduce int3400 thermal driver
ACPI: add ACPI_TYPE_LOCAL_REFERENCE support to acpi_extract_package()
ACPI: make acpi_create_platform_device() an external API
thermal: step_wise: fix: Prevent from binary overflow when trend is dropping
ACPI: introduce ACPI int340x thermal scan handler
thermal: Added Bang-bang thermal governor
renaming.
This patch is partial linuxized result of the following ACPICA commit:
ACPICA commit: a73b66c6aa1846d055bb6390d9c9b9902f7d804d
Subject: Add "has handler" flag to event/gpe status interfaces.
This change adds a new flag, ACPI_EVENT_FLAGS_HAS_HANDLER to the
acpi_get_event_status and acpi_get_gpe_status external interfaces. It
is set if the event/gpe currently has a handler associated with it.
This patch contains the code to rename ACPI_EVENT_FLAG_HANDLE to
ACPI_EVENT_FLAG_HAS_HANDLER, and the corresponding updates of its usages.
Link: https://github.com/acpica/acpica/commit/a73b66c6
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
'acpi-video'
* acpi-hotplug:
ACPI / hotplug: Generate online uevents for ACPI containers
* acpi-scan:
ACPI / scan: Correct error return value of create_modalias()
* acpi-lpss:
ACPI / platform / LPSS: disable async suspend/resume of LPSS devices
* acpi-gpio:
gpio / ACPI: Use pin index and bit length
ACPICA: Update to GPIO region handler interface.
* acpi-video:
ACPI / video: disable native backlight for ThinkPad X201s
There is a typo, it should be negative -errno instead.
Commit 46394fd01 (ACPI / hotplug: Move container-specific code out of
the core) removed the generation of "online" uevents for containers,
because "add" uevents are now generated for them automatically when
container system devices are registered. However, there are user
space tools that need to be notified when the container and all of
its children have been enumerated, which doesn't happen any more.
For this reason, add a mechanism allowing "online" uevents to be
generated for ACPI containers after enumerating the container along
with all of its children.
Fixes: 46394fd01 (ACPI / hotplug: Move container-specific code out of the core)
Reported-and-tested-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
