path: root/drivers/acpi/thermal.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-14Merge branches 'battery-2.6.34', 'bugzilla-10805', 'bugzilla-14668', ↵Len Brown
'bugzilla-531916-power-state', 'ht-warn-2.6.34', 'pnp', 'processor-rename', 'sony-2.6.34', 'suse-bugzilla-531547', 'tz-check', 'video' and 'misc-2.6.34' into release
2010-02-23ACPI thermal: Don't invalidate thermal zone if critical trip point is badThomas Renninger
V2: Corrected integer/long conversion. Some BIOSes return a negative value for the critical trip point. Especially since Windows 2006... We currently invalidate the whole thermal zone in this case. But it may still be needed for cooling, also without critical trip point. This patch invalidates the critical trip point if no _CRT function is found or if it returns negative values, but does not invalidate the whole thermal zone in this case. Reference: http://bugzilla.novell.com/show_bug.cgi?id=531547 Signed-off-by: Thomas Renninger <trenn@suse.de> Tested-by: clarkt@cnsp.com Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-02-19ACPI thermal: Check for thermal zone requirementThomas Renninger
ACPI spec says (11.5 Thermal Zone Interface Requirements): A thermal zone must contain at least one trip point (critical, near critical, active, or passive) Check this once at init time. Signed-off-by: Thomas Renninger <trenn@suse.de> Tested-by: clarkt@cnsp.com Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05acpi: thermal: display forced passive trip points in procFrans Pop
Users can force a passive trip point for a thermal zone that does not have _PSV defined in ACPI by setting the passive attribute in sysfs. It's useful to display such trip points in /proc/acpi/thermal_zone. .../TZ1/cooling_mode:<setting not supported> .../TZ1/polling_frequency:polling frequency: 10 seconds .../TZ1/state:state: ok .../TZ1/temperature:temperature: 53 C .../TZ1/trip_points:critical (S5): 110 C .../TZ1/trip_points:passive (forced): 95 C And if not set (passive is 0): .../TZ1/trip_points:passive (forced):<not set> Signed-off-by: Frans Pop <elendil@planet.nl> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28ACPI: Move definition of PREFIX from acpi_bus.h to internal..hLen Brown
Linux/ACPI core files using internal.h all PREFIX "ACPI: ", however, not all ACPI drivers use/want it -- and they should not have to #undef PREFIX to define their own. Add GPL commment to internal.h while we are there. This does not change any actual console output, asside from a whitespace fix. Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-18thermal: Fix polling frequency for systems without passive coolingMatthew Garrett
The polling interval (in deciseconds) was accidently interpreted as being in milliseconds in one codepath, resulting in excessively frequent polling. Ensure that the conversion is performed. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-07Merge branches 'release', 'APERF', 'ARAT', 'misc', 'kelvin', 'device-lock' ↵Len Brown
and 'bjorn.notify' into release
2009-04-07ACPI: thermal: use .notify method instead of installing handler directlyBjorn Helgaas
This patch adds a .notify() method. The presence of .notify() causes Linux/ACPI to manage event handlers and notify handlers on our behalf, so we don't have to install and remove them ourselves. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> CC: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-07ACPI: Adjust Kelvin offset to match local implementationJean Delvare
The exact offset between Kelvin and degree Celsius is 273.15. However ACPI handles temperature values with a single decimal place. As a consequence, some implementations use an offset of 273.1 and others use an offset of 273.2. Try to find out which one is being used, to present the most accurate and visually appealing number. Tested on a Sony Vaio PGC-GR214EP (which uses 273.1) and a Lenovo Thinkpad T60p (which uses 273.2). Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/cpu/cpufreq/longhaul.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-30trivial: Fix misspelling of "Celsius".Adam Buchbinder
A few comments say "Celcius"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-27ACPI: update thermal for bus_id removalStephen Rothwell
> drivers/acpi/thermal.c: In function 'thermal_notify': > drivers/acpi/thermal.c:768: error: 'struct device' has no member named 'bus_id' > > Caused by commit b1569e99c795bf83b4ddf41c4f1c42761ab7f75e ("ACPI: move > thermal trip handling to generic thermal layer") interacting with commit > d4a078fca590911cdf87a8eaffee1b6e643c2558 ("driver core: get rid of struct > device's bus_id string array"). > Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-20ACPI: move thermal trip handling to generic thermal layerMatthew Garrett
The ACPI code currently carries its own thermal trip handling, meaning that any other thermal implementation will need to reimplement it. Move the code to the generic thermal layer. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-20thermal: use integers rather than strings for thermal valuesMatthew Garrett
The thermal API currently uses strings to pass values to userspace. This makes it difficult to use from within the kernel. Change the interface to use integers and fix up the consumers. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16thermal fixup for broken BIOS which has invalid trip points.Zhang Rui
ACPI thermal driver only re-evaluate VALID trip points. For the broken BIOS show in http://bugzilla.kernel.org/show_bug.cgi?id=8544 the active[0] is set to invalid at boot time and it will not be re-evaluated again. We can still get a single warning message at boot time. http://marc.info/?l=linux-kernel&m=120496222629983&w=2 http://bugzilla.kernel.org/show_bug.cgi?id=12203 Signed-off-by: Zhang Rui<rui.zhang@intel.com> Tested-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-11Merge branch 'sysfs' into releaseLen Brown
2008-11-07ACPI: consolidate ACPI_*_COMPONENT definitions in acpi_drivers.hBjorn Helgaas
Move all the component definitions for drivers to a single shared place, include/acpi/acpi_drivers.h. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-06ACPI: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
This patch is part of a larger patch series which will remove the "char bus_id[20]" name string from struct device. The device name is managed in the kobject anyway, and without any size limitation, and just needlessly copied into "struct device". To set and read the device name dev_name(dev) and dev_set_name(dev) must be used. If your code uses static kobjects, which it shouldn't do, "const char *init_name" can be used to statically provide the name the registered device should have. At registration time, the init_name field is cleared, to enforce the use of dev_name(dev) to access the device name at a later time. We need to get rid of all occurrences of bus_id in the entire tree to be able to enable the new interface. Please apply this patch, and possibly convert any remaining remaining occurrences of bus_id. We want to submit a patch to -next, which will remove bus_id from "struct device", to find the remaining pieces to convert, and finally switch over to the new api, which will remove the 20 bytes array and does no longer have a size limitation. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22Merge branch 'ull' into testLen Brown
Conflicts: drivers/acpi/bay.c drivers/acpi/dock.c drivers/ata/libata-acpi.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22Merge branch 'misc' into testLen Brown
2008-10-22ACPI: replace ACPI_DEBUG_PRINT((ACPI_DB_ERROR, ...) with printkLin Ming
ACPI_DB_ERROR and ACPI_DB_WARN were removed from ACPICA core. So replace ACPI_DEBUG_PRINT((ACPI_DB_ERROR, ...) with printk(KERN_ERR PREFIX ...) and ACPI_DEBUG_PRINT((ACPI_DB_WARN, ...) with printk(KERN_WARNING PREFIX ...) We do not use ACPI_ERROR/ACPI_WARNING since they're not exported, see ------------------------------------------------------------- commit 6468463abd7051fcc29f3ee7c931f9bbbb26f5a4 Author: Len Brown <len.brown@intel.com> Date: Mon Jun 26 23:41:38 2006 -0400 ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...) Signed-off-by: Len Brown <len.brown@intel.com> ------------------------------------------------------------- Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-17ACPI: Allow overriding to higher critical trip point.Zhang Rui
http://bugzilla.kernel.org/show_bug.cgi?id=9129 lenb: Note that overriding a critical trip point may simply fool the user into thinking that they have control that they do not actually have. For it is EC firmware that decides when the EC sends Linux temperature change events, and the EC may or may not decide to send Linux these events anywhere in the neighborhood of the fake override trip points. Beware. note also that thermal.nocrt is already available to disable crtical trip point actios, and thermal.crt=-1 is already available to disabled critical trip points entirely. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-11ACPI: Change acpi_evaluate_integer to support 64-bit on 32-bit kernelsMatthew Wilcox
As of version 2.0, ACPI can return 64-bit integers. The current acpi_evaluate_integer only supports 64-bit integers on 64-bit platforms. Change the argument to take a pointer to an acpi_integer so we support 64-bit integers on all platforms. lenb: replaced use of "acpi_integer" with "unsigned long long" lenb: fixed bug in acpi_thermal_trips_update() Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-10ACPI: catch calls of acpi_driver_data on pointer of wrong typePavel Machek
Catch attempts to use of acpi_driver_data on pointers of wrong type. akpm: rewritten to use proper C typechecking and remove the "function"-used-as-lvalue thing. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-24Merge branch 'release-2.6.27' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6 * 'release-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6: acpi: fix crash in core ACPI code, triggered by CONFIG_ACPI_PCI_SLOT=y ACPI: thinkpad-acpi: don't misdetect in get_thinkpad_model_data() on -ENOMEM ACPI: thinkpad-acpi: bump up version to 0.21 ACPI: thinkpad-acpi: add bluetooth and WWAN rfkill support ACPI: thinkpad-acpi: WLSW overrides other rfkill switches ACPI: thinkpad-acpi: prepare for bluetooth and wwan rfkill support ACPI: thinkpad-acpi: consolidate wlsw notification function ACPI: thinkpad-acpi: minor refactor on radio switch init Revert "ACPI: don't walk tables if ACPI was disabled" Revert "dock: bay: Don't call acpi_walk_namespace() when ACPI is disabled." Revert "Fix FADT parsing" ACPI : Set FAN device to correct state in boot phase ACPI: Ignore _BQC object when registering backlight device ACPI: stop complaints about interrupt link End Tags and blank IRQ descriptors
2008-07-21driver core: fix a lot of printk usages of bus_idGreg Kroah-Hartman
We have the dev_printk() variants for this kind of thing, use them instead of directly trying to access the bus_id field of struct device. This is done in order to remove bus_id entirely. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-18ACPI : Set FAN device to correct state in boot phaseZhao Yakui
Subject:ACPI: Set FAN device to correct state in boot phase From: Zhao Yakui <yakui.zhao@intel.com> On some laptops when ACPI FAN driver is loaded, maybe the FAN device will be turned on. But if the temperature is below the threshold, the corresponding FAN device should be turned off in the course of loading thermal driver. So it is necessary to set the FAN device to the correct state in course of loading the thermal driver. http://bugzilla.kernel.org/show_bug.cgi?id=8049 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-06-11ACPI: Reject below-freezing temperatures as invalid critical temperaturesArjan van de Ven
My laptop thinks that it's a good idea to give -73C as the critical CPU temperature.... which isn't the best thing since it causes a shutdown right at bootup. Temperatures below freezing are clearly invalid critical thresholds so just reject these as such. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits) ACPI: Fix acpi_processor_idle and idle= boot parameters interaction acpi: fix section mismatch warning in pnpacpi intel_menlo: fix build warning ACPI: Cleanup: Remove unneeded, multiple local dummy variables ACPI: video - fix permissions on some proc entries ACPI: video - properly handle errors when registering proc elements ACPI: video - do not store invalid entries in attached_array list ACPI: re-name acpi_pm_ops to acpi_suspend_ops ACER_WMI/ASUS_LAPTOP: fix build bug thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed ACPI: check a return value correctly in acpi_power_get_context() #if 0 acpi/bay.c:eject_removable_drive() eeepc-laptop: add hwmon fan control eeepc-laptop: add backlight eeepc-laptop: add base driver ACPI: thinkpad-acpi: bump up version to 0.20 ACPI: thinkpad-acpi: fix selects in Kconfig ACPI: thinkpad-acpi: use a private workqueue ACPI: thinkpad-acpi: fluff really minor fix ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation ... Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c manually.
2008-04-29acpi: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Len Brown <lenb@kernel.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ACPI: update thermal temperatureZhang, Rui
Fix the problem that thermal_get_temp returns the cached value, which causes the temperature in generic thermal never updates. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29thermal: update the documentationZhang Rui
Update the documentation for the thermal driver hwmon sys I/F. Change the ACPI thermal zone type to be consistent with hwmon. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29thermal: add new get_crit_temp callbackZhang, Rui
Add a new callback so that the generic thermal can get the critical trip point info of a thermal zone, which is needed for building the tempX_crit hwmon sysfs attribute. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-28drivers/acpi/thermal.c: fix build with CONFIG_DMI=nAndrew Morton
drivers/acpi/thermal.c: In function 'acpi_thermal_init': drivers/acpi/thermal.c:1794: error: 'thermal_dmi_table' undeclared (first use in this function) drivers/acpi/thermal.c:1794: error: (Each undeclared identifier is reported only once drivers/acpi/thermal.c:1794: error: for each function it appears in.) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-08acpi thermal: fix result checkKrzysztof Helt
thermal_zone_device_register() uses the ERR_PTR macro on its return values. A correct check is to use the IS_ERR() macro. The 2.6.25 kernels panic on Compaq AP550 without this patch as it has more then 10 (THERMAL_MAX_TRIPS) trip points (there are 12). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Len Brown <lenb@kernel.org> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-13ACPI: thermal: show temperature in millidegree CelsiusZhang, Rui
as now required by the generic thermal I/F Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07Merge branches 'release' and 'menlo' into releaseLen Brown
Conflicts: drivers/acpi/video.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01ACPI: thermal fixupZhang Rui
The alias name may be used in _PSL, _ALx and _TZD, so we bind the cooling device only if the acpi_device node matches. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01ACPI: CELSIUS_TO_KELVIN fixupZhang Rui
Fix an imprecision in CELSIUS_TO_KELVIN and move these two macroes to a proper place. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01ACPI: attach thermal zone infoZhang Rui
Intel menlow driver needs to get the pointer of themal_zone_device structure of an ACPI thermal zone. Attach this to each ACPI thermal zone device object. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01ACPI: ACPI thermal zone handle notification correctlyZhang Rui
Change the ACPI thermal action upon notification 0x81 and 0x82. According to the ACPI spec, we should: re-evaluate _PSV and _ACx methods upon notification 0x81 re-evaluate _PSL and _ALx and _TZD upon notificaiton 0x82. But the current code re-evaluates all the trip points for 0x81 while only re-evaluates _TZD for 0x82. Fix this violation of ACPI spec. TODO: devices in _PSL, _ALx and _TZD may change after a notification 0x82. At this time, we need to re-bind the cooling devices with the thermal zone. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01ACPI: register ACPI thermal zone as generic thermal zone devicesZhang Rui
Register ACPI thermal zone as thermal zone device. the new sys I/F for ACPI thermal zone will be like this: /sys/class/thermal: |thermal_zone1: |-----type: "ACPI thermal zone". RO |-----temp: the current temperature. RO |-----mode: the current working mode. RW. the default value is "kernel" which means thermal management is done by ACPI thermal driver. "echo user > mode" prevents all the ACPI thermal driver actions upon any trip points. |-----trip_point_0_temp: the threshold of trip point 0. RO. |-----trip_point_0_type: "critical". RO. the type of trip point 0 This may be one of critical/hot/passive/active[x] for an ACPI thermal zone. ... |-----trip_point_3_temp: |-----trip_point_3_type: "active[1]" Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-12-06export thermal notification to userspace when nocrt is setZhang Rui
module parameter is used to prevent the thermal_zone action upon critical trip points. But exporting this notification to userspace is still useful. By setting nocrt with this patch applied, ACPI will take no action but exporting the events to userspace upon critical/hot trip points. http://bugzilla.kernel.org/show_bug.cgi?id=9139 Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-19Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (41 commits) ACPICA: hw: Don't carry spinlock over suspend ACPICA: hw: remove use_lock flag from acpi_hw_register_{read, write} ACPI: cpuidle: port idle timer suspend/resume workaround to cpuidle ACPI: clean up acpi_enter_sleep_state_prep Hibernation: Make sure that ACPI is enabled in acpi_hibernation_finish ACPI: suppress uninitialized var warning cpuidle: consolidate 2.6.22 cpuidle branch into one patch ACPI: thinkpad-acpi: skip blanks before the data when parsing sysfs ACPI: AC: Add sysfs interface ACPI: SBS: Add sysfs alarm ACPI: SBS: Add ACPI_PROCFS around procfs handling code. ACPI: SBS: Add support for power_supply class (and sysfs) ACPI: SBS: Make SBS reads table-driven. ACPI: SBS: Simplify data structures in SBS ACPI: SBS: Split host controller (ACPI0001) from SBS driver (ACPI0002) ACPI: EC: Add new query handler to list head. ACPI: Add acpi_bus_generate_event4() function ACPI: Battery: add sysfs alarm ACPI: Battery: Add sysfs support ACPI: Battery: Misc clean-ups, no functional changes ... Fix up conflicts in drivers/misc/thinkpad_acpi.[ch] manually
2007-10-09drivers/firmware: const-ify DMI API and internalsJeff Garzik
Three main sets of changes: 1) dmi_get_system_info() return value should have been marked const, since callers should not be changing that data. 2) const-ify DMI internals, since DMI firmware tables should, whenever possible, be marked const to ensure we never ever write to that data area. 3) const-ify DMI API, to enable marking tables const where possible in low-level drivers. And if we're really lucky, this might enable some additional optimizations on the part of the compiler. The bulk of the changes are #2 and #3, which are interrelated. #1 could have been a separate patch, but it was so small compared to the others, it was easier to roll it into this changeset. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-09-05ACPI: Thermal: Drop concurrent thermal checksAlexey Starikovskiy
Fix for #3686, where get_temperature() may cause thermal notify, which causes one more get_temperature(). Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-09-04ACPI: thermal: use round_jiffies when thermal zone polling is enabledLen Brown
Properly functioning systems do not use thermal zone polling, they use event-based notification. However, some users enable periodic thermal zone polling to work around bugs on their platforms, and at least one platform exists with a real _TZP that requests polling. While thermal zone polling (_TZP) is specified in units to 0.1 seconds, it actually has a maximum granularity of 1 second. Thus, we can safely round up the _TZP timeout to occur on the next 1-second boundary. This will batch it with other 1-second-granularity timers in the system and thus potentially extend processor idle duration. Note that the same timer is used both for _TZP and for passive processor thermal throttling. We can not round up the timeout when it is used for passive thermal throttling. Also, we can not make this a deferrable timer, as temperature is just as relevant during idle as it is during non-idle. Signed-off-by: Len Brown <len.brown@intel.com>
