[ Upstream commit 5971b0c1594d6c34e257101ed5fdffec65205c50 ]
Since commit 63347db0affa "ACPI / scan: Use acpi_bus_get_status() to
initialize ACPI_TYPE_DEVICE devs" the status field of normal acpi_devices
gets set to 0 by acpi_bus_type_and_status() and filled with its actual
value later when acpi_add_single_object() calls acpi_bus_get_status().
This means that any acpi_match_device_ids() calls in between will always
fail with -ENOENT.
We already have a workaround for this, which temporary forces status to
ACPI_STA_DEFAULT in drivers/acpi/x86/utils.c: acpi_device_always_present()
and the next commit in this series adds another acpi_match_device_ids()
call between status being initialized as 0 and the acpi_bus_get_status()
call.
Rather then adding another workaround, this commit makes
acpi_bus_type_and_status() initialize status to ACPI_STA_DEFAULT, this is
safe to do as the only code looking at status between the initialization
and the acpi_bus_get_status() call is those acpi_match_device_ids() calls.
Note this does mean that we need to (re)set status to 0 in case the
acpi_bus_get_status() call fails.
[ Upstream commit 2c4d6baf1bc4f7729773ffcee9ba2a9781578633 ]
The ec_no_wakeup matcher added for Thinkpad X1 Carbon 6th gen systems
beyond matched only a single DMI model (20KGS3JF01), that didn't cover
my laptop (20KH002JUS). Change to match based on DMI product family to
cover all X1 6th gen systems.
Signed-off-by: Robin H. Johnson <robbat2@gentoo.org>
[ Upstream commit ee6581ceba7f8314b81b2f2a81f1cf3f67c679e2 ]
Incremental patch to fix the unchecked dereference in acpi_nfit_ctl.
Reported by Dan Carpenter:
"acpi/nfit: fix cmd_rc for acpi_nfit_ctl to
always return a value" from Jun 28, 2018, leads to the following
Smatch complaint:
drivers/acpi/nfit/core.c:578 acpi_nfit_ctl()
warn: variable dereferenced before check 'cmd_rc' (see line 411)
410
411 *cmd_rc = -EINVAL;
Patch adds unchecked dereference.
Fixes: c1985cefd844 ("acpi/nfit: fix cmd_rc for acpi_nfit_ctl to always return a value")
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
[ Upstream commit c1985cefd844e26bd19673a6df8d8f0b1918c2db ]
cmd_rc is passed in by reference to the acpi_nfit_ctl() function and the
caller expects a value returned. However, when the package is pass through
via the ND_CMD_CALL command, cmd_rc is not touched. Make sure cmd_rc is
always set.
Fixes: aef253382266 ("libnvdimm, nfit: centralize command status translation")
[ Upstream commit 8195a655e5ce09550aff81b2573d9b015d520cb9 ]
On this system EC interrupt triggers constantly kicking devices out of
low power states and thus blocking power management. The system also has
a PCIe root port hosting Alpine Ridge Thunderbolt controller and it
never gets a chance to go to D3cold because of this.
Since the power button works the same regardless if EC interrupt is
enabled or not during s2idle, add a quirk for this machine that sets
ec_no_wakeup=true preventing spurious wakeups.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit 231f9415001138a000cd0f881c46654b7ea3f8c5 upstream.
Every time I tried to upgrade my laptop from 3.10.x to 4.x I faced an
issue by which the fan would run at full speed upon resume. Bisecting
it showed me the issue was introduced in 3.17 by commit 821d6f0359b0
(ACPI / sleep: Do not save NVS for new machines to accelerate S3). This
code only affects machines built starting as of 2012, but this Asus
1025C laptop was made in 2012 and apparently needs the NVS data to be
saved, otherwise the CPU's thermal state is not properly reported on
resume and the fan runs at full speed upon resume.
Here's a very simple way to check if such a machine is affected :
# cat /sys/class/thermal/thermal_zone0/temp
55000
( now suspend, wait one second and resume )
0
(and after ~15 seconds the fan starts to spin)
Let's apply the same quirk as commit cbc00c13 (ACPI: save NVS memory
for Lenovo G50-45) and reuse the function it provides. Note that this
commit was already backported to 4.9.x but not 4.4.x.
Cc: 3.17+ <stable@vger.kernel.org> # 3.17+: requires cbc00c13
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit 520e18a5080d2c444a03280d99c8a35cb667d321 upstream.
Now that nothing is using the ghes_ioremap_area pages, rip them out.
Signed-off-by: James Morse <james.morse@arm.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Tested-by: Tyler Baicar <tbaicar@codeaurora.org>
Cc: All applicable <stable@vger.kernel.org>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit c975e472ec12392a0c34de1350e634310f8a1dea ]
The Point of View mobii wintab p800w Bay Trail tablet comes with a Crystal
Cove PMIC, yet uses the LPSS PWM for backlight control, rather then the
Crystal Cove's PWM, so we need to call pwm_add_table() to add a
pwm_backlight mapping for the LPSS pwm despite there being an INT33FD
ACPI device present.
On all Bay Trail devices the _HRV object of the INT33FD ACPI device
will normally return 2, to indicate the Bay Trail variant of the CRC
PMIC is present, except on this tablet where _HRV is 0xffff. I guess this
is a hack to make the windows Crystal Cove PWM driver not bind.
Out of the 44 DSTDs with an INT33FD device in there which I have (from
different model devices) only the pov mobii wintab p800w uses 0xffff for
the HRV.
The byt_pwm_setup code calls acpi_dev_present to check for the presence
of a INT33FD ACPI device which indicates that a CRC PMIC is present and
if the INT33FD ACPI device is present then byt_pwm_setup will not add
a pwm_backlight mapping for the LPSS pwm, so that the CRC PWM will get
used instead.
acpi_dev_present has a hrv parameter, this commit make us pass 2 instead
of -1, so that things still match on normal tablets, but on this special
case with its _HRV of 0xffff, the check will now fail so that the
pwm_backlight mapping for the LPSS pwm gets added fixing backlight
brightness control on this device.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
[ Upstream commit 408fec36a1ab3d14273c2116b449ef1e9be3cb8b ]
Currently we request control of native PCIe hotplug unconditionally.
Native PCIe hotplug events are handled by the pciehp driver, and if it is
not enabled those events will be lost.
Request control of native PCIe hotplug only if the pciehp driver is
enabled, so we will actually handle native PCIe hotplug events.
Suggested-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
commit d2d2e3c46be5d6dd8001d0eebdf7cafb9bc7006b upstream.
Sometimes memory resource may be overlapping with
SystemMemory Operation Region by design, for example if the
memory region is used as a mailbox for communication with a
firmware in the system. One occasion of such mailboxes is
USB Type-C Connector System Software Interface (UCSI).
With regions like that, it is important that the driver is
able to map the memory with the requirements it has. For
example, the driver should be allowed to map the memory as
non-cached memory. However, if the operation region has been
accessed before the driver has mapped the memory, the memory
has been marked as write-back by the time the driver is
loaded. That means the driver will fail to map the memory
if it expects non-cached memory.
To work around the problem, introducing helper that the
drivers can use to temporarily deactivate (unmap)
SystemMemory Operation Regions that overlap with their
IO memory.
Fixes: 8243edf44152 ("usb: typec: ucsi: Add ACPI driver")
Cc: stable@vger.kernel.org
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
commit fdcb613d49321b5bf5d5a1bd0fba8e7c241dcc70 upstream.
The LPSS PWM device on on Bay Trail and Cherry Trail devices has a set
of private registers at offset 0x800, the current lpss_device_desc for
them already sets the LPSS_SAVE_CTX flag to have these saved/restored
over device-suspend, but the current lpss_device_desc was not setting
the prv_offset field, leading to the regular device registers getting
saved/restored instead.
This is causing the PWM controller to no longer work, resulting in a black
screen, after a suspend/resume on systems where the firmware clears the
APB clock and reset bits at offset 0x804.
This commit fixes this by properly setting prv_offset to 0x800 for
the PWM devices.
Fixes: e1c748179754 ("ACPI / LPSS: Add Intel BayTrail ACPI mode PWM")
Fixes: 1bfbd8eb8a7f ("ACPI / LPSS: Add ACPI IDs for Intel Braswell")
Acked-by: Rafael J . Wysocki <rjw@rjwysocki.net>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
[ Upstream commit a0a37862a4e1844793d39aca9ccb8fecbdcb8659 ]
WDAT table on Lenovo Z50-70 is using RTC SRAM (ports 0x70 and 0x71) to
store state of the timer. This conflicts with Linux RTC driver
(rtc-cmos.c) who fails to reserve those ports for itself preventing RTC
from functioning. In addition the WDAT table seems not to be fully
functional because it does not reset the system when the watchdog times
out.
On this system iTCO_wdt works just fine so we simply prefer to use it
instead of WDAT. This makes RTC working again and also results working
watchdog via iTCO_wdt.
Reported-by: Peter Milley <pbmilley@gmail.com>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=199033
[ Upstream commit 855c1c2fce8bdbd796cba1d1456ca8f0e876c2f1 ]
ThinkPad X1 Tablet(2016) is reported to have issues with
the Low Power S0 Idle _DSM interface and since this machine
model generally can do ACPI S3 just fine, and user would
like to use S3 as default sleep model, add a blacklist
entry to disable that interface for ThinkPad X1 Tablet(2016).
Link: https://bugzilla.kernel.org/show_bug.cgi?id=199057
Reported-and-tested-by: Robin Lee <robinlee.sysu@gmail.com>
Signed-off-by: Chen Yu <yu.c.chen@intel.com>
[ Upstream commit 97f3c0a4b0579b646b6b10ae5a3d59f0441cc12c ]
I found an ACPI cache leak in ACPI early termination and boot continuing case.
When early termination occurs due to malicious ACPI table, Linux kernel
terminates ACPI function and continues to boot process. While kernel terminates
ACPI function, kmem_cache_destroy() reports Acpi-Operand cache leak.
Boot log of ACPI operand cache leak is as follows:
>[ 0.464168] ACPI: Added _OSI(Module Device)
>[ 0.467022] ACPI: Added _OSI(Processor Device)
>[ 0.469376] ACPI: Added _OSI(3.0 _SCP Extensions)
>[ 0.471647] ACPI: Added _OSI(Processor Aggregator Device)
>[ 0.477997] ACPI Error: Null stack entry at ffff880215c0aad8 (20170303/exresop-174)
>[ 0.482706] ACPI Exception: AE_AML_INTERNAL, While resolving operands for [opcode_name unavailable] (20170303/dswexec-461)
>[ 0.487503] ACPI Error: Method parse/execution failed [\DBG] (Node ffff88021710ab40), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.492136] ACPI Error: Method parse/execution failed [\_SB._INI] (Node ffff88021710a618), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.497683] ACPI: Interpreter enabled
>[ 0.499385] ACPI: (supports S0)
>[ 0.501151] ACPI: Using IOAPIC for interrupt routing
>[ 0.503342] ACPI Error: Null stack entry at ffff880215c0aad8 (20170303/exresop-174)
>[ 0.506522] ACPI Exception: AE_AML_INTERNAL, While resolving operands for [opcode_name unavailable] (20170303/dswexec-461)
>[ 0.510463] ACPI Error: Method parse/execution failed [\DBG] (Node ffff88021710ab40), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.514477] ACPI Error: Method parse/execution failed [\_PIC] (Node ffff88021710ab18), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.518867] ACPI Exception: AE_AML_INTERNAL, Evaluating _PIC (20170303/bus-991)
>[ 0.522384] kmem_cache_destroy Acpi-Operand: Slab cache still has objects
>[ 0.524597] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.12.0-rc5 #26
>[ 0.526795] Hardware name: innotek gmb_h virtual_box/virtual_box, BIOS virtual_box 12/01/2006
>[ 0.529668] Call Trace:
>[ 0.530811] ? dump_stack+0x5c/0x81
>[ 0.532240] ? kmem_cache_destroy+0x1aa/0x1c0
>[ 0.533905] ? acpi_os_delete_cache+0xa/0x10
>[ 0.535497] ? acpi_ut_delete_caches+0x3f/0x7b
>[ 0.537237] ? acpi_terminate+0xa/0x14
>[ 0.538701] ? acpi_init+0x2af/0x34f
>[ 0.540008] ? acpi_sleep_proc_init+0x27/0x27
>[ 0.541593] ? do_one_initcall+0x4e/0x1a0
>[ 0.543008] ? kernel_init_freeable+0x19e/0x21f
>[ 0.546202] ? rest_init+0x80/0x80
>[ 0.547513] ? kernel_init+0xa/0x100
>[ 0.548817] ? ret_from_fork+0x25/0x30
>[ 0.550587] vgaarb: loaded
>[ 0.551716] EDAC MC: Ver: 3.0.0
>[ 0.553744] PCI: Probing PCI hardware
>[ 0.555038] PCI host bridge to bus 0000:00
> ... Continue to boot and log is omitted ...
I analyzed this memory leak in detail and found acpi_ns_evaluate() function
only removes Info->return_object in AE_CTRL_RETURN_VALUE case. But, when errors
occur, the status value is not AE_CTRL_RETURN_VALUE, and Info->return_object is
also not null. Therefore, this causes acpi operand memory leak.
This cache leak causes a security threat because an old kernel (<= 4.9) shows
memory locations of kernel functions in stack dump. Some malicious users
could use this information to neutralize kernel ASLR.
I made a patch to fix ACPI operand cache leak.
Signed-off-by: Seunghun Han <kkamagui@gmail.com>
Signed-off-by: Erik Schmauss <erik.schmauss@intel.com>
[ Upstream commit 1c29c372b2d1d2415601041532745ce859f24126 ]
Fixes a single-object memory leak on a store-to-reference method
invocation. ACPICA BZ 1439.
Signed-off-by: Bob Moore <robert.moore@intel.com>
[ Upstream commit b4c0de312613ca676db5bd7e696a44b56795612a ]
This ensures that acpi_ev_fixed_event_detect() does not use fixed_status
and and fixed_enable as uninitialized variables.
[ Upstream commit 8b29d29abc484d638213dd79a18a95ae7e5bb402 ]
Fix once per second (round_robin_time) memory leak of about 1 KB in
each acpi_pad kernel idling thread that is activated.
Found by testing with kmemleak.
Signed-off-by: Lenny Szubowicz <lszubowi@redhat.com>
commit ac1e55b1fdb27c1b07a0a6fe519f1291ff1e7d40 upstream.
Modules such as nouveau.ko and i915.ko have a link time dependency on
acpi_lid_open(), and due to its use of acpi_bus_register_driver(),
the button.ko module that provides it is only loadable when booted in
ACPI mode. However, the ACPI button driver can be built into the core
kernel as well, in which case the dependency can always be satisfied,
and the dependent modules can be loaded regardless of whether the
system was booted in ACPI mode or not.
So let's fix this asymmetry by making the ACPI button driver loadable
as a module even if not booted in ACPI mode, so it can provide the
acpi_lid_open() symbol in the same way as when built into the kernel.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[ rjw: Minor adjustments of comments, whitespace and names. ]
commit 53fa1f6e8a5958da698a31edf366ffe90596b490 upstream.
Commit 5928c281524f (ACPI / video: Default lcd_only to true on Win8-ready
and newer machines) made only_lcd default to true on all machines where
acpi_osi_is_win8() returns true, including laptops.
The purpose of this is to avoid the bogus / non-working acpi backlight
interface which many newer BIOS-es define on desktop machines.
But this is causing a regression on some laptops, specifically on the
Dell XPS 13 2013 model, which does not have the LCD flag set for its
fully functional ACPI backlight interface.
Rather then DMI quirking our way out of this, this commits changes the
logic for setting only_lcd to true, to only do this on machines with
a desktop (or server) dmi chassis-type.
Note that we cannot simply only check the chassis-type and not register
the backlight interface based on that as there are some laptops and
tablets which have their chassis-type set to "3" aka desktop. Hopefully
the combination of checking the LCD flag, but only on devices with
a desktop(ish) chassis-type will avoid the needs for DMI quirks for this,
or at least limit the amount of DMI quirks which we need to a minimum.
Fixes: 5928c281524f (ACPI / video: Default lcd_only to true on Win8-ready and newer machines)
Reported-and-tested-by: James Hogan <jhogan@kernel.org>
Cc: 4.15+ <stable@vger.kernel.org> # 4.15+
[ Upstream commit 3cd091a773936c54344a519f7ee1379ccb620bee ]
Commit 662591461c4b (ACPI / EC: Drop EC noirq hooks to fix a
regression) modified the ACPI EC driver so that it doesn't switch
over to busy polling mode during noirq stages of system suspend and
resume in an attempt to fix an issue resulting from that behavior.
However, that modification introduced a system resume regression on
Thinkpad X240, so make the EC driver switch over to the polling mode
during noirq stages of system suspend and resume again, which
effectively reverts the problematic commit.
Fixes: 662591461c4b (ACPI / EC: Drop EC noirq hooks to fix a regression)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=197863
Reported-by: Markus Demleitner <m@tfiu.de>
Tested-by: Markus Demleitner <m@tfiu.de>
[ Upstream commit 63347db0affadcbccd5613116ea8431c70139b3e ]
The acpi_get_bus_status wrapper for acpi_bus_get_status_handle has some
code to handle certain device quirks, in some cases we also need this
quirk handling for the initial _STA call.
Specifically on some devices calling _STA before all _DEP dependencies
are met results in errors like these:
[ 0.123579] ACPI Error: No handler for Region [ECRM] (00000000ba9edc4c)
[GenericSerialBus] (20170831/evregion-166)
[ 0.123601] ACPI Error: Region GenericSerialBus (ID=9) has no handler
(20170831/exfldio-299)
[ 0.123618] ACPI Error: Method parse/execution failed
\_SB.I2C1.BAT1._STA, AE_NOT_EXIST (20170831/psparse-550)
acpi_get_bus_status already has code to avoid this, so by using it we
also silence these errors from the initial _STA call.
Note that in order for the acpi_get_bus_status handling for this to work,
we initialize dep_unmet to 1 until acpi_device_dep_initialize gets called,
this means that battery devices will be instantiated with an initial
status of 0. This is not a problem, acpi_bus_attach will get called soon
after the instantiation anyways and it will update the status as first
point of order.
[ Upstream commit 54ddce7062242036402242242c07c60c0b505f84 ]
The battery code uses acpi_device->dep_unmet to check for unmet deps and
if there are unmet deps it does not bind to the device to avoid errors
about missing OpRegions when calling ACPI methods on the device.
The missing OpRegions when there are unmet deps problem also applies to
the _STA method of some battery devices and calling it too early results
This commit fixes these errors happening when acpi_get_bus_status gets
called by checking dep_unmet for battery devices and reporting a status
of 0 until all dependencies are met.
[ Upstream commit ba1edb9a5125a617d612f98eead14b9b84e75c3a ]
The following warning was triggered after resumed from S3 -
if all the nonboot CPUs were put offline before suspend:
[ 1840.329515] unchecked MSR access error: RDMSR from 0x771 at rIP: 0xffffffff86061e3a (native_read_msr+0xa/0x30)
[ 1840.329516] Call Trace:
[ 1840.329521] __rdmsr_on_cpu+0x33/0x50
[ 1840.329525] generic_exec_single+0x81/0xb0
[ 1840.329527] smp_call_function_single+0xd2/0x100
[ 1840.329530] ? acpi_ds_result_pop+0xdd/0xf2
[ 1840.329532] ? acpi_ds_create_operand+0x215/0x23c
[ 1840.329534] rdmsrl_on_cpu+0x57/0x80
[ 1840.329536] ? cpumask_next+0x1b/0x20
[ 1840.329538] ? rdmsrl_on_cpu+0x57/0x80
[ 1840.329541] intel_pstate_update_perf_limits+0xf3/0x220
[ 1840.329544] ? notifier_call_chain+0x4a/0x70
[ 1840.329546] intel_pstate_set_policy+0x4e/0x150
[ 1840.329548] cpufreq_set_policy+0xcd/0x2f0
[ 1840.329550] cpufreq_update_policy+0xb2/0x130
[ 1840.329552] ? cpufreq_update_policy+0x130/0x130
[ 1840.329556] acpi_processor_ppc_has_changed+0x65/0x80
[ 1840.329558] acpi_processor_notify+0x80/0x100
[ 1840.329561] acpi_ev_notify_dispatch+0x44/0x5c
[ 1840.329563] acpi_os_execute_deferred+0x14/0x20
[ 1840.329565] process_one_work+0x193/0x3c0
[ 1840.329567] worker_thread+0x35/0x3b0
[ 1840.329569] kthread+0x125/0x140
[ 1840.329571] ? process_one_work+0x3c0/0x3c0
[ 1840.329572] ? kthread_park+0x60/0x60
[ 1840.329575] ? do_syscall_64+0x67/0x180
[ 1840.329577] ret_from_fork+0x25/0x30
[ 1840.329585] unchecked MSR access error: WRMSR to 0x774 (tried to write 0x0000000000000000) at rIP: 0xffffffff86061f78 (native_write_msr+0x8/0x30)
[ 1840.329586] Call Trace:
[ 1840.329587] __wrmsr_on_cpu+0x37/0x40
[ 1840.329589] generic_exec_single+0x81/0xb0
[ 1840.329592] smp_call_function_single+0xd2/0x100
[ 1840.329594] ? acpi_ds_create_operand+0x215/0x23c
[ 1840.329595] ? cpumask_next+0x1b/0x20
[ 1840.329597] wrmsrl_on_cpu+0x57/0x70
[ 1840.329598] ? rdmsrl_on_cpu+0x57/0x80
[ 1840.329599] ? wrmsrl_on_cpu+0x57/0x70
[ 1840.329602] intel_pstate_hwp_set+0xd3/0x150
[ 1840.329604] intel_pstate_set_policy+0x119/0x150
[ 1840.329606] cpufreq_set_policy+0xcd/0x2f0
[ 1840.329607] cpufreq_update_policy+0xb2/0x130
[ 1840.329610] ? cpufreq_update_policy+0x130/0x130
[ 1840.329613] acpi_processor_ppc_has_changed+0x65/0x80
[ 1840.329615] acpi_processor_notify+0x80/0x100
[ 1840.329617] acpi_ev_notify_dispatch+0x44/0x5c
[ 1840.329619] acpi_os_execute_deferred+0x14/0x20
[ 1840.329620] process_one_work+0x193/0x3c0
[ 1840.329622] worker_thread+0x35/0x3b0
[ 1840.329624] kthread+0x125/0x140
[ 1840.329625] ? process_one_work+0x3c0/0x3c0
[ 1840.329626] ? kthread_park+0x60/0x60
[ 1840.329628] ? do_syscall_64+0x67/0x180
[ 1840.329631] ret_from_fork+0x25/0x30
This is because if there's only one online CPU, the MSR_PM_ENABLE
(package wide)can not be enabled after resumed, due to
intel_pstate_hwp_enable() will only be invoked on AP's online
process after resumed - if there's no AP online, the HWP remains
disabled after resumed (BIOS has disabled it in S3). Then if
there comes a _PPC change notification which touches HWP register
during this stage, the warning is triggered.
Since we don't call acpi_processor_register_performance() when
HWP is enabled, the pr->performance will be NULL. When this is
NULL we don't need to do _PPC change notification.
Reported-by: Doug Smythies <dsmythies@telus.net>
Suggested-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Signed-off-by: Yu Chen <yu.c.chen@intel.com>
[ Upstream commit e1681599345b8466786b6e54a2db2a00a068a3f3 ]
acpi_lpss_create_device() skips handling LPSS devices which do not have
a mmio resources in their resource list (typically these devices are
disabled by the firmware). But since the LPSS code does not bind to the
device, acpi_bus_attach() ends up still creating a platform device for
it and the regular platform_driver for the ACPI HID still tries to bind
to it.
This happens e.g. on some boards which do not use the pwm-controller
and have an empty or invalid resource-table for it. Currently this causes
these error messages to get logged:
[ 3.281966] pwm-lpss 80862288:00: invalid resource
[ 3.287098] pwm-lpss: probe of 80862288:00 failed with error -22
This commit stops the undesirable creation of a platform_device for
disabled LPSS devices by setting pnp.type.platform_id to 0. Note that
acpi_scan_attach_handler() also sets pnp.type.platform_id to 0 when there
is a matching handler for the device and that handler has no attach
callback, so we simply behave as a handler without an attach function
in this case.
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit 0731de476a37c33485af82d64041c9d193208df8 upstream.
Per the ACPI specification the only functional purpose for a DIMM
Control Region to be mapped into the system physical address space, from
an OSPM perspective, is to support block-apertures. However, there are
some BIOSen that publish DIMM Control Region SPA entries for pre-boot
environment consumption. Undo the kernel policy of generating disabled
'ndblk' regions when this configuration is detected.
Cc: <stable@vger.kernel.org>
Fixes: 1f7df6f88b92 ("libnvdimm, nfit: regions (block-data-window...)")
Reviewed-by: Toshi Kani <toshi.kani@hpe.com>
commit 78727137fdf49edf9f731bde79d7189067b4047a upstream.
There is a small window whereby ARS scan requests can schedule work that
userspace will miss when polling scrub_show. Hold the init_mutex lock
over calls to report the status to close this potential escape. Also,
make sure that requests to cancel the ARS workqueue are treated as an
idle event.
Cc: Vishal Verma <vishal.l.verma@intel.com>
Fixes: 37b137ff8c83 ("nfit, libnvdimm: allow an ARS scrub...")
Reviewed-by: Dave Jiang <dave.jiang@intel.com>
commit bbf038618a24d72e2efc19146ef421bb1e1eda1a upstream.
Just like many other Samsung models, the 670Z5E needs to use the acpi-video
backlight interface rather then the native one for backlight control to
work, add a quirk for this.
Buglink: https://bugzilla.redhat.com/show_bug.cgi?id=1557060
commit 8d0d8ed3356aa9ed43b819aaedd39b08ca453007 upstream.
Commit 1cf03c00e7c1 "nfit: scrub and register regions in a workqueue"
mistakenly attempts to register a region per BLK aperture. There is
nothing to register for individual apertures as they belong as a set to
a BLK aperture group that are registered with a corresponding
DIMM-control-region. Filter them for registration to prevent some
needless devm_kzalloc() allocations.
Fixes: 1cf03c00e7c1 ("nfit: scrub and register regions in a workqueue")
[ Upstream commit 3522f867c13b63cf62acdf1b8ca5664c549a716a ]
acpi_ec.gpe is "unsigned long", hence treating it as "u32" would expose
the wrong half on big-endian 64-bit systems. Fix this by changing its
type to "u32" and removing the cast, as all other code already uses u32
or sometimes even only u8.
Fixes: 1195a098168fcacf (ACPI: Provide /sys/kernel/debug/ec/...)
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit 5928c281524fe451114e04f1dfa11246a37e859f ]
We're seeing a lot of bogus backlight interfaces on newer machines without
a LCD such as desktops, servers and HDMI sticks. This causes userspace to
show a non-functional brightness slider in e.g. the GNOME3 system menu,
which is undesirable. And, in general, we should simply just not register
a non functional backlight interface.
Checking the LCD flag causes the bogus acpi_video backlight interfaces to
go away (on the machines this was tested on).
This change sets the lcd_only option by default on any machines which
are Win8-ready, to fix this.
This is not entirely without a risk of regressions, but video_detect.c
already prefers native-backlight interfaces over the acpi_video one
on Win8-ready machines, calling acpi_video_unregister_backlight() as soon
as a native interface shows up. This is done because the ACPI backlight
interface often is broken on Win8-ready machines, because win8 does not
seem to actually use it.
So in practice we already end up not registering the ACPI backlight
interface on (most) Win8-ready machines with a LCD panel, thus this
change does not change anything for (most) machines with a LCD panel
and on machines without a LCD panel we actually don't want to register
any backlight interfaces.
This has been tested on the following machines and fixes a bogus backlight
interface showing up there:
- Desktop with an Asrock B150M Pro4S/D3 m.b. using i5-6500 builtin gfx
- Intel Compute Stick STK1AW32SC
- Meegopad T08 HDMI stick
Bogus backlight interfaces have also been reported on:
- Desktop with Asus H87I-Plus m.b.
- Desktop with ASRock B75M-ITX m.b.
- Desktop with Gigabyte Z87-D3HP m.b.
- Dell PowerEdge T20 desktop
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1097436
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1133327
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1133329
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1133646
commit b1abf6fc49829d89660c961fafe3f90f3d843c55 upstream.
The resource allocation in WDAT watchdog has off-one-by error, it sets
one byte more than the actual end address. This may eventually lead
to unexpected resource conflicts.
Fixes: 058dfc767008 (ACPI / watchdog: Add support for WDAT hardware watchdog)
Cc: 4.9+ <stable@vger.kernel.org> # 4.9+
Acked-by: Guenter Roeck <linux@roeck-us.net>
commit dc9e0a9347e932e3fd3cd03e7ff241022ed6ea8a upstream.
Commit 99759869faf1 "acpi: Add acpi_map_pxm_to_online_node()" added
support for mapping a given proximity to its nearest, by SLIT distance,
online node. However, it sometimes returns unexpected results due to the
fact that it switches from comparing the PXM node to the last node that
was closer than the current max.
for_each_online_node(n) {
dist = node_distance(node, n);
if (dist < min_dist) {
min_dist = dist;
node = n; <---- from this point we're using the
wrong node for node_distance()
Fixes: 99759869faf1 ("acpi: Add acpi_map_pxm_to_online_node()")
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>>
commit 36904703aeeeb6cd31993f1353c8325006229f9a upstream.
The i2c touchpad on Dell XPS 9570 and Precision M5530 doesn't work out
of box.
The touchpad relies on its _INI method to update its _HID value from
XXXX0000 to SYNA2393.
Also, the _STA relies on value of I2CN to report correct status.
Set acpi_gbl_parse_table_as_term_list so the value of I2CN can be
correctly set up, and _INI can get run. The ACPI table in this machine
is designed to get parsed this way.
Also, change the quirk table to a more generic name.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=198515
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit 23fbd7c70aec7600e3227eb24259fc55bf6e4881 upstream.
A NULL pointer reference kernel bug was observed when
acpi_nfit_add_dimm() called in acpi_nfit_register_dimms() failed. This
error path does not set nfit_mem->nvdimm, but the 2nd
list_for_each_entry() loop in the function assumes it's always set. Add
a check to nfit_mem->nvdimm.
Fixes: ba9c8dd3c222 ("acpi, nfit: add dimm device notification support")
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
commit 43cdd1b716b26f6af16da4e145b6578f98798bf6 upstream.
There's no need to be printing a raw kernel pointer to the kernel log at
every boot. So just remove it, and change the whole message to use the
correct dev_info() call at the same time.
Reported-by: Wang Qize <wang_qize@venustech.com.cn>
[ Upstream commit 10809bb976648ac58194a629e3d7af99e7400297 ]
Most Bay and Cherry Trail devices use a generic DSDT with all possible
peripheral devices present in the DSDT, with their _STA returning 0x00 or
0x0f based on AML variables which describe what is actually present on
the board.
Since ACPI device objects with a 0x00 status (not present) still get an
entry under /sys/bus/acpi/devices, and those entry had an acpi:PNPID
modalias, userspace would end up loading modules for non present hardware.
This commit fixes this by leaving the modalias empty for non present
devices. This results in 10 modules less being loaded with a generic
distro kernel config on my Cherry Trail test-device (a GPD pocket).
commit adf6895754e2503d994a765535fd1813f8834674 upstream.
Integration testing with a BIOS that generates injected health event
notifications fails to communicate those events to userspace. The nfit
driver neglects to link the ACPI DIMM device with the necessary driver
data so acpi_nvdimm_notify() fails this lookup:
nfit_mem = dev_get_drvdata(dev);
if (nfit_mem && nfit_mem->flags_attr)
sysfs_notify_dirent(nfit_mem->flags_attr);
Add the necessary linkage when installing the notification handler and
clean it up when the nfit driver instance is torn down.
Cc: Toshi Kani <toshi.kani@hpe.com>
Reported-by: Daniel Osawa <daniel.k.osawa@intel.com>
Tested-by: Daniel Osawa <daniel.k.osawa@intel.com>
commit bb82e0b4a7e96494f0c1004ce50cec3d7b5fb3d1 upstream.
The commit f6f828513290 ("pstore: pass allocated memory region back to
caller") changed the check of the return value from erst_read() in
erst_reader() in the following way:
if (len == -ENOENT)
goto skip;
- else if (len < 0) {
- rc = -1;
+ else if (len < sizeof(*rcd)) {
+ rc = -EIO;
goto out;
This introduced another bug: since the comparison with sizeof() is
cast to unsigned, a negative len value doesn't hit any longer.
As a result, when an error is returned from erst_read(), the code
falls through, and it may eventually lead to some weird thing like
memory corruption.
This patch adds the negative error value check more explicitly for
addressing the issue.
Fixes: f6f828513290 (pstore: pass allocated memory region back to caller)
Tested-by: Jerry Tang <jtang@suse.com>
commit 4f89fa286f6729312e227e7c2d764e8e7b9d340e upstream.
Replace ghes_io{re,un}map_pfn_{nmi,irq}()s use of ioremap_page_range()
with __set_fixmap() as ioremap_page_range() may sleep to allocate a new
level of page-table, even if its passed an existing final-address to
use in the mapping.
The GHES driver can only be enabled for architectures that select
HAVE_ACPI_APEI: Add fixmap entries to both x86 and arm64.
clear_fixmap() does the TLB invalidation in __set_fixmap() for arm64
and __set_pte_vaddr() for x86. In each case its the same as the
respective arch_apei_flush_tlb_one().
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Tested-by: Toshi Kani <toshi.kani@hpe.com>
[ For the arm64 bits: ]
Acked-by: Will Deacon <will.deacon@arm.com>
[ For the x86 bits: ]
Acked-by: Ingo Molnar <mingo@kernel.org>
commit c49870e89f4d2c21c76ebe90568246bb0f3572b7 upstream.
For the SEA notification, the two functions ghes_sea_add() and
ghes_sea_remove() are only called when CONFIG_ACPI_APEI_SEA
is defined. If not, it will return errors in the ghes_probe()
and not continue. If the probe is failed, the ghes_sea_remove()
also has no chance to be called. Hence, remove the unnecessary
handling when CONFIG_ACPI_APEI_SEA is not defined.
For the NMI notification, it has the same issue as SEA notification,
so also remove the unused dead-code for it.
Signed-off-by: Dongjiu Geng <gengdongjiu@huawei.com>
commit 095f613c6b386a1704b73a549e9ba66c1d5381ae upstream.
Match up with what 7edda0886b ("acpi: apei: handle SEA notification
type for ARMv8") did for ghes_ioremap_pfn_nmi().
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit a64a62ce9a380213dc9e192f762266d70c9b40ec upstream.
On platforms (ASUS X550ZE and possibly all ASUS X series) with valid ECDT
EC but invalid DSDT EC, EC PM ops won't be invoked as ECDT EC is not an
ACPI device. Thus the following commit actually removed post-resume
acpi_ec_enable_event() invocation for such platforms, and triggered a
regression on them that after being resumed, EC (actually should be ECDT)
driver stops handling EC events:
Commit: c2b46d679b30c5c0d7eb47a21085943242bdd8dc
Subject: ACPI / EC: Add PM operations to improve event handling for resume process
Notice that the root cause actually is "ECDT is not an ACPI device" rather
than "the timing of acpi_ec_enable_event() invocation", this patch fixes
this issue by enumerating ECDT EC as an ACPI device. Due to the existence
of the noirq stage, the ability of tuning the timing of
acpi_ec_enable_event() invocation is still meaningful.
This patch is a little bit different from the posted fix by moving
acpi_config_boot_ec() from acpi_ec_ecdt_start() to acpi_ec_add() to make
sure that EC event handling won't be stopped as long as the ACPI EC driver
is bound. Thus the following sequence shouldn't disable EC event handling:
unbind,suspend,resume,bind.
Fixes: c2b46d679b30 (ACPI / EC: Add PM operations to improve event handling for resume process)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196847
Reported-by: Luya Tshimbalanga <luya@fedoraproject.org>
Tested-by: Luya Tshimbalanga <luya@fedoraproject.org>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
commit 53c5eaabaea9a1b7a96f95ccc486d2ad721d95bb upstream.
Originally the Samsung quirks removed by commit 4c237371 can be covered
by commit e923e8e7 and ec_freeze_events=Y mode. But commit 9c40f956
changed ec_freeze_events=Y back to N, making this problem re-surface.
Actually, if commit e923e8e7 is robust enough, we can freely change
ec_freeze_events mode, so this patch fixes the issue by improving
commit e923e8e7.
Related commits listed in the merged order:
Commit: e923e8e79e18fd6be9162f1be6b99a002e9df2cb
Subject: ACPI / EC: Fix an issue that SCI_EVT cannot be detected
after event is enabled
Commit: 4c237371f290d1ed3b2071dd43554362137b1cce
Subject: ACPI / EC: Remove old CLEAR_ON_RESUME quirk
Commit: 9c40f956ce9b331493347d1b3cb7e384f7dc0581
Subject: Revert "ACPI / EC: Enable event freeze mode..." to fix
a regression
This patch not only fixes the reported post-resume EC event triggering
source issue, but also fixes an unreported similar issue related to the
driver bind by adding EC event triggering source in ec_install_handlers().
Fixes: e923e8e79e18 (ACPI / EC: Fix an issue that SCI_EVT cannot be detected after event is enabled)
Fixes: 4c237371f290 (ACPI / EC: Remove old CLEAR_ON_RESUME quirk)
Fixes: 9c40f956ce9b (Revert "ACPI / EC: Enable event freeze mode..." to fix a regression)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196833
Reported-by: Alistair Hamilton <ahpatent@gmail.com>
Tested-by: Alistair Hamilton <ahpatent@gmail.com>
commit ff1656790b3a4caca94505c52fd0250f981ea187 upstream.
acpi_remove_pm_notifier() ends up calling flush_workqueue() while
holding acpi_pm_notifier_lock, and that same lock is taken by
by the work via acpi_pm_notify_handler(). This can deadlock.
To fix the problem let's split the single lock into two: one to
protect the dev->wakeup between the work vs. add/remove, and
another one to handle notifier installation vs. removal.
After commit a1d14934ea4b "workqueue/lockdep: 'Fix' flush_work()
annotation" I was able to kill the machine (Intel Braswell)
very easily with 'powertop --auto-tune', runtime suspending i915,
and trying to wake it up via the USB keyboard. The cases when
it didn't die are presumably explained by lockdep getting disabled
by something else (cpu hotplug locking issues usually).
Fortunately I still got a lockdep report over netconsole
(trickling in very slowly), even though the machine was
otherwise practically dead:
[ 112.179806] ======================================================
[ 114.670858] WARNING: possible circular locking dependency detected
[ 117.155663] 4.13.0-rc6-bsw-bisect-00169-ga1d14934ea4b #119 Not tainted
[ 119.658101] ------------------------------------------------------
[ 121.310242] xhci_hcd 0000:00:14.0: xHCI host not responding to stop endpoint command.
[ 121.313294] xhci_hcd 0000:00:14.0: xHCI host controller not responding, assume dead
[ 121.313346] xhci_hcd 0000:00:14.0: HC died; cleaning up
[ 121.313485] usb 1-6: USB disconnect, device number 3
[ 121.313501] usb 1-6.2: USB disconnect, device number 4
[ 134.747383] kworker/0:2/47 is trying to acquire lock:
[ 137.220790] (acpi_pm_notifier_lock){+.+.}, at: [<ffffffff813cafdf>] acpi_pm_notify_handler+0x2f/0x80
[ 139.721524]
[ 139.721524] but task is already holding lock:
[ 144.672922] ((&dpc->work)){+.+.}, at: [<ffffffff8109ce90>] process_one_work+0x160/0x720
[ 147.184450]
[ 147.184450] which lock already depends on the new lock.
[ 147.184450]
[ 154.604711]
[ 154.604711] the existing dependency chain (in reverse order) is:
[ 159.447888]
[ 159.447888] -> #2 ((&dpc->work)){+.+.}:
[ 164.183486] __lock_acquire+0x1255/0x13f0
[ 166.504313] lock_acquire+0xb5/0x210
[ 168.778973] process_one_work+0x1b9/0x720
[ 171.030316] worker_thread+0x4c/0x440
[ 173.257184] kthread+0x154/0x190
[ 175.456143] ret_from_fork+0x27/0x40
[ 177.624348]
[ 177.624348] -> #1 ("kacpi_notify"){+.+.}:
[ 181.850351] __lock_acquire+0x1255/0x13f0
[ 183.941695] lock_acquire+0xb5/0x210
[ 186.046115] flush_workqueue+0xdd/0x510
[ 190.408153] acpi_os_wait_events_complete+0x31/0x40
[ 192.625303] acpi_remove_notify_handler+0x133/0x188
[ 194.820829] acpi_remove_pm_notifier+0x56/0x90
[ 196.989068] acpi_dev_pm_detach+0x5f/0xa0
[ 199.145866] dev_pm_domain_detach+0x27/0x30
[ 201.285614] i2c_device_probe+0x100/0x210
[ 203.411118] driver_probe_device+0x23e/0x310
[ 205.522425] __driver_attach+0xa3/0xb0
[ 207.634268] bus_for_each_dev+0x69/0xa0
[ 209.714797] driver_attach+0x1e/0x20
[ 211.778258] bus_add_driver+0x1bc/0x230
[ 213.837162] driver_register+0x60/0xe0
[ 215.868162] i2c_register_driver+0x42/0x70
[ 217.869551] 0xffffffffa0172017
[ 219.863009] do_one_initcall+0x45/0x170
[ 221.843863] do_init_module+0x5f/0x204
[ 223.817915] load_module+0x225b/0x29b0
[ 225.757234] SyS_finit_module+0xc6/0xd0
[ 227.661851] do_syscall_64+0x5c/0x120
[ 229.536819] return_from_SYSCALL_64+0x0/0x7a
[ 231.392444]
[ 231.392444] -> #0 (acpi_pm_notifier_lock){+.+.}:
[ 235.124914] check_prev_add+0x44e/0x8a0
[ 237.024795] __lock_acquire+0x1255/0x13f0
[ 238.937351] lock_acquire+0xb5/0x210
[ 240.840799] __mutex_lock+0x75/0x940
[ 242.709517] mutex_lock_nested+0x1c/0x20
[ 244.551478] acpi_pm_notify_handler+0x2f/0x80
[ 246.382052] acpi_ev_notify_dispatch+0x44/0x5c
[ 248.194412] acpi_os_execute_deferred+0x14/0x30
[ 250.003925] process_one_work+0x1ec/0x720
[ 251.803191] worker_thread+0x4c/0x440
[ 253.605307] kthread+0x154/0x190
[ 255.387498] ret_from_fork+0x27/0x40
[ 257.153175]
[ 257.153175] other info that might help us debug this:
[ 257.153175]
[ 262.324392] Chain exists of:
[ 262.324392] acpi_pm_notifier_lock --> "kacpi_notify" --> (&dpc->work)
[ 262.324392]
[ 267.391997] Possible unsafe locking scenario:
[ 267.391997]
[ 270.758262] CPU0 CPU1
[ 272.431713] ---- ----
[ 274.060756] lock((&dpc->work));
[ 275.646532] lock("kacpi_notify");
[ 277.260772] lock((&dpc->work));
[ 278.839146] lock(acpi_pm_notifier_lock);
[ 280.391902]
[ 280.391902] *** DEADLOCK ***
[ 280.391902]
[ 284.986385] 2 locks held by kworker/0:2/47:
[ 286.524895] #0: ("kacpi_notify"){+.+.}, at: [<ffffffff8109ce90>] process_one_work+0x160/0x720
[ 288.112927] #1: ((&dpc->work)){+.+.}, at: [<ffffffff8109ce90>] process_one_work+0x160/0x720
[ 289.727725]
Fixes: c072530f391e (ACPI / PM: Revork the handling of ACPI device wakeup notifications)
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
At least one Dell XPS13 9360 is reported to have serious issues with
the Low Power S0 Idle _DSM interface and since this machine model
generally can do ACPI S3 just fine, add a blacklist entry to disable
that interface for Dell XPS13 9360.
Fixes: 8110dd281e15 (ACPI / sleep: EC-based wakeup from suspend-to-idle on recent systems)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196907
Reported-by: Paul Menzel <pmenzel@molgen.mpg.de>
Tested-by: Paul Menzel <pmenzel@molgen.mpg.de>
Cc: 4.13+ <stable@vger.kernel.org> # 4.13+
Pull x86 fixes from Ingo Molnar:
"Two fixes:
- A PCID related revert that fixes power management and performance
regressions.
- The module loader robustization and sanity check commit is rather
fresh, but it looked like a good idea to apply because of the
hidden data corruption problem such invalid modules could cause"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/module: Detect and skip invalid relocations
Revert "x86/mm: Stop calling leave_mm() in idle code"
This reverts commit 43858b4f25cf0adc5c2ca9cf5ce5fdf2532941e5.
The reason I removed the leave_mm() calls in question is because the
heuristic wasn't needed after that patch. With the original version
of my PCID series, we never flushed a "lazy cpu" (i.e. a CPU running
kernel thread) due a flush on the loaded mm.
Unfortunately, that caused architectural issues, so now I've
reinstated these flushes on non-PCID systems in:
commit b956575bed91 ("x86/mm: Flush more aggressively in lazy TLB mode").
That, in turn, gives us a power management and occasionally
performance regression as compared to old kernels: a process that
goes into a deep idle state on a given CPU and gets its mm flushed
due to activity on a different CPU will wake the idle CPU.
Reinstate the old ugly heuristic: if a CPU goes into ACPI C3 or an
intel_idle state that is likely to cause a TLB flush gets its mm
switched to init_mm before going idle.
FWIW, this heuristic is lousy. Whether we should change CR3 before
idle isn't a good hint except insofar as the performance hit is a bit
lower if the TLB is getting flushed by the idle code anyway. What we
really want to know is whether we anticipate being idle long enough
that the mm is likely to be flushed before we wake up. This is more a
matter of the expected latency than the idle state that gets chosen.
This heuristic also completely fails on systems that don't know
whether the TLB will be flushed (e.g. AMD systems?). OTOH it may be a
bit obsolete anyway -- PCID systems don't presently benefit from this
heuristic at all.
We also shouldn't do this callback from innermost bit of the idle code
due to the RCU nastiness it causes. All the information need is
available before rcu_idle_enter() needs to happen.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Borislav Petkov <bpetkov@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Fixes: 43858b4f25cf "x86/mm: Stop calling leave_mm() in idle code"
Link: http://lkml.kernel.org/r/c513bbd4e653747213e05bc7062de000bf0202a5.1509793738.git.luto@kernel.org
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Fix more return codes for device property: Align return codes of
__acpi_node_get_property_reference().
In particular, what was missed previously:
-EPROTO could be returned in certain cases, now -EINVAL;
-EINVAL was returned if the property was not found, now -ENOENT;
-EINVAL was returned also if the index was higher than the number of
entries in a package, now -ENOENT.
Reported-by: Hyungwoo Yang <hyungwoo.yang@intel.com>
Fixes: 3e3119d3088f (device property: Introduce fwnode_property_get_reference_args)
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Tested-by: Hyungwoo Yang <hyungwoo.yang@intel.com>
acpi_fwnode_get_reference_args(), the function implementing ACPI
support for fwnode_property_get_reference_args(), returns directly
error codes from __acpi_node_get_property_reference(). The latter
uses different error codes than the OF implementation. In particular,
the OF implementation uses -ENOENT to indicate that the property is
not found, a reference entry is empty and there are no more
references.
Document and align the error codes for property for
fwnode_property_get_reference_args() so that they match with
of_parse_phandle_with_args().
