commit 43f89877f26671c6309cd87d7364b1a3e66e71cf upstream.
In the case of ND_CMD_CALL, we should also check out_obj->type.
The patch uses out_obj->type, which is a short alias to
out_obj->package.type.
Fixes: 31eca76ba2fc ("nfit, libnvdimm: limited/whitelisted dimm command marshaling mechanism")
Cc: <stable@vger.kernel.org>
Signed-off-by: Dexuan Cui <decui@microsoft.com>
commit f16eb8a4b096514ac06fb25bf599dcc792899b3d upstream.
If SSDT overlay is loaded via ConfigFS and then unloaded the device,
we would like to have OF modalias for, already gone. Thus, acpi_get_name()
returns no allocated buffer for such case and kernel crashes afterwards:
ACPI: Host-directed Dynamic ACPI Table Unload
ads7950 spi-PRP0001:00: Dropping the link to regulator.0
BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
#PF error: [normal kernel read fault]
PGD 80000000070d6067 P4D 80000000070d6067 PUD 70d0067 PMD 0
Oops: 0000 [#1] SMP PTI
CPU: 0 PID: 40 Comm: kworker/u4:2 Not tainted 5.0.0+ #96
Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 542 2015.01.21:18.19.48
Workqueue: kacpi_hotplug acpi_device_del_work_fn
RIP: 0010:create_of_modalias.isra.1+0x4c/0x150
Code: 00 00 48 89 44 24 18 31 c0 48 8d 54 24 08 48 c7 44 24 10 00 00 00 00 48 c7 44 24 08 ff ff ff ff e8 7a b0 03 00 48 8b 4c 24 10 <0f> b6 01 84 c0 74 27 48 c7 c7 00 09 f4 a5 0f b6 f0 8d 50 20 f6 04
RSP: 0000:ffffa51040297c10 EFLAGS: 00010246
RAX: 0000000000001001 RBX: 0000000000000785 RCX: 0000000000000000
RDX: 0000000000001001 RSI: 0000000000000286 RDI: ffffa2163dc042e0
RBP: ffffa216062b1196 R08: 0000000000001001 R09: ffffa21639873000
R10: ffffffffa606761d R11: 0000000000000001 R12: ffffa21639873218
R13: ffffa2163deb5060 R14: ffffa216063d1010 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffffa2163e000000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 0000000007114000 CR4: 00000000001006f0
Call Trace:
__acpi_device_uevent_modalias+0xb0/0x100
spi_uevent+0xd/0x40
In order to fix above let create_of_modalias() check the status returned
by acpi_get_name() and bail out in case of failure.
Fixes: 8765c5ba1949 ("ACPI / scan: Rework modalias creation when "compatible" is present")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=201381
Reported-by: Ferry Toth <fntoth@gmail.com>
Tested-by: Ferry Toth<fntoth@gmail.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: 4.1+ <stable@vger.kernel.org> # 4.1+
[ Upstream commit b9ced18acf68dffebe6888c7ec765a2b1db7a039 ]
The addresses of NUMA nodes are not printed correctly on i386-PAE
which is misleading.
Here is a debian9-32bit with PAE in a QEMU guest having more than 4G
of memory:
qemu-system-i386 \
-hda /var/lib/libvirt/images/debian32.qcow2 \
-m 5G \
-enable-kvm \
-smp 10 \
-numa node,mem=512M,nodeid=0,cpus=0 \
-numa node,mem=512M,nodeid=1,cpus=1 \
-numa node,mem=512M,nodeid=2,cpus=2 \
-numa node,mem=512M,nodeid=3,cpus=3 \
-numa node,mem=512M,nodeid=4,cpus=4 \
-numa node,mem=512M,nodeid=5,cpus=5 \
-numa node,mem=512M,nodeid=6,cpus=6 \
-numa node,mem=512M,nodeid=7,cpus=7 \
-numa node,mem=512M,nodeid=8,cpus=8 \
-numa node,mem=512M,nodeid=9,cpus=9 \
-serial stdio
Because of the wrong value type, it prints as below:
[ 0.021049] ACPI: SRAT Memory (0x0 length 0xa0000) in proximity domain 0 enabled
[ 0.021740] ACPI: SRAT Memory (0x100000 length 0x1ff00000) in proximity domain 0 enabled
[ 0.022425] ACPI: SRAT Memory (0x20000000 length 0x20000000) in proximity domain 1 enabled
[ 0.023092] ACPI: SRAT Memory (0x40000000 length 0x20000000) in proximity domain 2 enabled
[ 0.023764] ACPI: SRAT Memory (0x60000000 length 0x20000000) in proximity domain 3 enabled
[ 0.024431] ACPI: SRAT Memory (0x80000000 length 0x20000000) in proximity domain 4 enabled
[ 0.025104] ACPI: SRAT Memory (0xa0000000 length 0x20000000) in proximity domain 5 enabled
[ 0.025791] ACPI: SRAT Memory (0x0 length 0x20000000) in proximity domain 6 enabled
[ 0.026412] ACPI: SRAT Memory (0x20000000 length 0x20000000) in proximity domain 7 enabled
[ 0.027118] ACPI: SRAT Memory (0x40000000 length 0x20000000) in proximity domain 8 enabled
[ 0.027802] ACPI: SRAT Memory (0x60000000 length 0x20000000) in proximity domain 9 enabled
The upper half of the start address of the NUMA domains between 6
and 9 inclusive was cut, so the printed values are incorrect.
Fix the value type, to get the correct values in the log as follows:
[ 0.023698] ACPI: SRAT Memory (0x0 length 0xa0000) in proximity domain 0 enabled
[ 0.024325] ACPI: SRAT Memory (0x100000 length 0x1ff00000) in proximity domain 0 enabled
[ 0.024981] ACPI: SRAT Memory (0x20000000 length 0x20000000) in proximity domain 1 enabled
[ 0.025659] ACPI: SRAT Memory (0x40000000 length 0x20000000) in proximity domain 2 enabled
[ 0.026317] ACPI: SRAT Memory (0x60000000 length 0x20000000) in proximity domain 3 enabled
[ 0.026980] ACPI: SRAT Memory (0x80000000 length 0x20000000) in proximity domain 4 enabled
[ 0.027635] ACPI: SRAT Memory (0xa0000000 length 0x20000000) in proximity domain 5 enabled
[ 0.028311] ACPI: SRAT Memory (0x100000000 length 0x20000000) in proximity domain 6 enabled
[ 0.028985] ACPI: SRAT Memory (0x120000000 length 0x20000000) in proximity domain 7 enabled
[ 0.029667] ACPI: SRAT Memory (0x140000000 length 0x20000000) in proximity domain 8 enabled
[ 0.030334] ACPI: SRAT Memory (0x160000000 length 0x20000000) in proximity domain 9 enabled
Signed-off-by: Chao Fan <fanc.fnst@cn.fujitsu.com>
[ rjw: Subject & changelog ]
commit 11189c1089da413aa4b5fd6be4c4d47c78968819 upstream.
The _DSM function number validation only happens to succeed when the
generic Linux command number translation corresponds with a
DSM-family-specific function number. This breaks NVDIMM-N
implementations that correctly implement _LSR, _LSW, and _LSI, but do
not happen to publish support for DSM function numbers 4, 5, and 6.
Recall that the support for _LS{I,R,W} family of methods results in the
DIMM being marked as supporting those command numbers at
acpi_nfit_register_dimms() time. The DSM function mask is only used for
ND_CMD_CALL support of non-NVDIMM_FAMILY_INTEL devices.
Fixes: 31eca76ba2fc ("nfit, libnvdimm: limited/whitelisted dimm command...")
Link: https://github.com/pmem/ndctl/issues/78
Reported-by: Sujith Pandel <sujith_pandel@dell.com>
Tested-by: Sujith Pandel <sujith_pandel@dell.com>
Reviewed-by: Vishal Verma <vishal.l.verma@intel.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
commit 5e9e38d0db1d29efed1dd4cf9a70115d33521be7 upstream.
In preparation for using function number 0 as an error value, prevent it
from being considered a valid function value by acpi_nfit_ctl().
Cc: stuart hayes <stuart.w.hayes@gmail.com>
Fixes: e02fb7264d8a ("nfit: add Microsoft NVDIMM DSM command set...")
Reported-by: Jeff Moyer <jmoyer@redhat.com>
commit 7d7b467cb95bf29597b417d4990160d4ea6d69b9 upstream.
Some ACPI tables contain duplicate power resource references like this:
Name (_PR0, Package (0x04) // _PR0: Power Resources for D0
P28P,
P18P,
P18P,
CLK4
This causes a WARN_ON in sysfs_add_link_to_group() because we end up
adding a link to the same acpi_device twice:
sysfs: cannot create duplicate filename '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/OVTI2680:00/power_resources_D0/LNXPOWER:0a'
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.12-301.fc29.x86_64 #1
Hardware name: Insyde CherryTrail/Type2 - Board Product Name, BIOS jumperx.T87.KFBNEEA02 04/13/2016
Call Trace:
dump_stack+0x5c/0x80
sysfs_warn_dup.cold.3+0x17/0x2a
sysfs_do_create_link_sd.isra.2+0xa9/0xb0
sysfs_add_link_to_group+0x30/0x50
acpi_power_expose_list+0x74/0xa0
acpi_power_add_remove_device+0x50/0xa0
acpi_add_single_object+0x26b/0x5f0
acpi_bus_check_add+0xc4/0x250
To address this issue, make acpi_extract_power_resources() check for
duplicates and simply skip them when found.
Cc: All applicable <stable@vger.kernel.org>
[ rjw: Subject & changelog, comments ]
commit 2bbb5fa37475d7aa5fa62f34db1623f3da2dfdfa upstream.
Many HP AMD based laptops contain an SMB0001 device like this:
Device (SMBD)
Name (_HID, "SMB0001") // _HID: Hardware ID
Name (_CRS, ResourceTemplate () // _CRS: Current Resource Settings
IO (Decode16,
0x0B20, // Range Minimum
0x0B20, // Range Maximum
0x20, // Alignment
0x20, // Length
IRQ (Level, ActiveLow, Shared, )
{7}
The legacy style IRQ resource here causes acpi_dev_get_irqresource() to
be called with legacy=true and this message to show in dmesg:
ACPI: IRQ 7 override to edge, high
This causes issues when later on the AMD0030 GPIO device gets enumerated:
Device (GPIO)
Name (_HID, "AMDI0030") // _HID: Hardware ID
Name (_CID, "AMDI0030") // _CID: Compatible ID
Name (_UID, Zero) // _UID: Unique ID
Method (_CRS, 0, NotSerialized) // _CRS: Current Resource Settings
Name (RBUF, ResourceTemplate ()
Interrupt (ResourceConsumer, Level, ActiveLow, Shared, ,, )
0x00000007,
Memory32Fixed (ReadWrite,
0xFED81500, // Address Base
0x00000400, // Address Length
Return (RBUF) /* \_SB_.GPIO._CRS.RBUF */
Now acpi_dev_get_irqresource() gets called with legacy=false, but because
of the earlier override of the trigger-type acpi_register_gsi() returns
-EBUSY (because we try to register the same interrupt with a different
trigger-type) and we end up setting IORESOURCE_DISABLED in the flags.
The setting of IORESOURCE_DISABLED causes platform_get_irq() to call
acpi_irq_get() which is not implemented on x86 and returns -EINVAL.
resulting in the following in dmesg:
amd_gpio AMDI0030:00: Failed to get gpio IRQ: -22
amd_gpio: probe of AMDI0030:00 failed with error -22
The SMB0001 is a "virtual" device in the sense that the only way the OS
interacts with it is through calling a couple of methods to do SMBus
transfers. As such it is weird that it has IO and IRQ resources at all,
because the driver for it is not expected to ever access the hardware
directly.
The Linux driver for the SMB0001 device directly binds to the acpi_device
through the acpi_bus, so we do not need to instantiate a platform_device
for this ACPI device. This commit adds the SMB0001 HID to the
forbidden_id_list, avoiding the instantiating of a platform_device for it.
Not instantiating a platform_device means we will no longer call
acpi_dev_get_irqresource() for the legacy IRQ resource fixing the probe of
the AMDI0030 device failing.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1644013
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=198715
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=199523
Reported-by: Lukas Kahnert <openproggerfreak@gmail.com>
Tested-by: Marc <suaefar@googlemail.com>
[ Upstream commit 5a802a7a285c8877ca872e44eeb0f06afcb5212f ]
After we added quirk for Lenovo Z50-70 it turns out there are at least
two more systems where WDAT table includes instructions accessing RTC
SRAM. Instead of quirking each system separately, look for such
instructions in the table and automatically prefer iTCO_wdt if found.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=199033
Reported-by: Arnold Guy <aurnoldg@gmail.com>
Reported-by: Alois Nespor <nespor@fssp.cz>
Reported-by: Yury Pakin <zxwarior@gmail.com>
Reported-by: Ihor Chyhin <ihorchyhin@ukr.net>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Guenter Roeck <linux@roeck-us.net>
[ Upstream commit a0a37862a4e1844793d39aca9ccb8fecbdcb8659 ]
WDAT table on Lenovo Z50-70 is using RTC SRAM (ports 0x70 and 0x71) to
store state of the timer. This conflicts with Linux RTC driver
(rtc-cmos.c) who fails to reserve those ports for itself preventing RTC
from functioning. In addition the WDAT table seems not to be fully
functional because it does not reset the system when the watchdog times
out.
On this system iTCO_wdt works just fine so we simply prefer to use it
instead of WDAT. This makes RTC working again and also results working
watchdog via iTCO_wdt.
Reported-by: Peter Milley <pbmilley@gmail.com>
[ Upstream commit 240714061c58e6b1abfb3322398a7634151c06cb ]
Bay and Cherry Trail DSTDs represent a different set of devices depending
on which OS the device think it is booting. One set of decices for Windows
and another set of devices for Android which targets the Android-x86 Linux
kernel fork (which e.g. used to have its own display driver instead of
using the i915 driver).
Which set of devices we are actually going to get is out of our control,
this is controlled by the ACPI OSID variable, which gets either set through
an EFI setup option, or sometimes is autodetected. So we need to support
both.
This commit adds support for the 80862286 and 808622C0 ACPI HIDs which we
get for the first resp. second DMA controller on Cherry Trail devices when
OSID is set to Android.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
[ Upstream commit 0f27cff8597d86f881ea8274b49b63b678c14a3c ]
The acpi_mask_gpe= kernel parameter documentation states that the range
of mask is 128 GPEs (0x00 to 0x7F). The acpi_masked_gpes mask is a u64 so
only 64 GPEs (0x00 to 0x3F) can really be masked.
Use a bitmap of size 0xFF instead of a u64 for the GPE mask so 256
GPEs can be masked.
Fixes: 9c4aa1eecb48 (ACPI / sysfs: Provide quirk mechanism to prevent GPE flooding)
Signed-off-by: Prarit Bharava <prarit@redhat.com>
[ Upstream commit 5971b0c1594d6c34e257101ed5fdffec65205c50 ]
Since commit 63347db0affa "ACPI / scan: Use acpi_bus_get_status() to
initialize ACPI_TYPE_DEVICE devs" the status field of normal acpi_devices
gets set to 0 by acpi_bus_type_and_status() and filled with its actual
value later when acpi_add_single_object() calls acpi_bus_get_status().
This means that any acpi_match_device_ids() calls in between will always
fail with -ENOENT.
We already have a workaround for this, which temporary forces status to
ACPI_STA_DEFAULT in drivers/acpi/x86/utils.c: acpi_device_always_present()
and the next commit in this series adds another acpi_match_device_ids()
call between status being initialized as 0 and the acpi_bus_get_status()
call.
Rather then adding another workaround, this commit makes
acpi_bus_type_and_status() initialize status to ACPI_STA_DEFAULT, this is
safe to do as the only code looking at status between the initialization
and the acpi_bus_get_status() call is those acpi_match_device_ids() calls.
Note this does mean that we need to (re)set status to 0 in case the
acpi_bus_get_status() call fails.
[ Upstream commit ee6581ceba7f8314b81b2f2a81f1cf3f67c679e2 ]
Incremental patch to fix the unchecked dereference in acpi_nfit_ctl.
Reported by Dan Carpenter:
"acpi/nfit: fix cmd_rc for acpi_nfit_ctl to
always return a value" from Jun 28, 2018, leads to the following
Smatch complaint:
drivers/acpi/nfit/core.c:578 acpi_nfit_ctl()
warn: variable dereferenced before check 'cmd_rc' (see line 411)
410
411 *cmd_rc = -EINVAL;
Patch adds unchecked dereference.
Fixes: c1985cefd844 ("acpi/nfit: fix cmd_rc for acpi_nfit_ctl to always return a value")
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
[ Upstream commit c1985cefd844e26bd19673a6df8d8f0b1918c2db ]
cmd_rc is passed in by reference to the acpi_nfit_ctl() function and the
caller expects a value returned. However, when the package is pass through
via the ND_CMD_CALL command, cmd_rc is not touched. Make sure cmd_rc is
always set.
Fixes: aef253382266 ("libnvdimm, nfit: centralize command status translation")
commit 231f9415001138a000cd0f881c46654b7ea3f8c5 upstream.
Every time I tried to upgrade my laptop from 3.10.x to 4.x I faced an
issue by which the fan would run at full speed upon resume. Bisecting
it showed me the issue was introduced in 3.17 by commit 821d6f0359b0
(ACPI / sleep: Do not save NVS for new machines to accelerate S3). This
code only affects machines built starting as of 2012, but this Asus
1025C laptop was made in 2012 and apparently needs the NVS data to be
saved, otherwise the CPU's thermal state is not properly reported on
resume and the fan runs at full speed upon resume.
Here's a very simple way to check if such a machine is affected :
# cat /sys/class/thermal/thermal_zone0/temp
55000
( now suspend, wait one second and resume )
0
(and after ~15 seconds the fan starts to spin)
Let's apply the same quirk as commit cbc00c13 (ACPI: save NVS memory
for Lenovo G50-45) and reuse the function it provides. Note that this
commit was already backported to 4.9.x but not 4.4.x.
Cc: 3.17+ <stable@vger.kernel.org> # 3.17+: requires cbc00c13
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit fdcb613d49321b5bf5d5a1bd0fba8e7c241dcc70 upstream.
The LPSS PWM device on on Bay Trail and Cherry Trail devices has a set
of private registers at offset 0x800, the current lpss_device_desc for
them already sets the LPSS_SAVE_CTX flag to have these saved/restored
over device-suspend, but the current lpss_device_desc was not setting
the prv_offset field, leading to the regular device registers getting
saved/restored instead.
This is causing the PWM controller to no longer work, resulting in a black
screen, after a suspend/resume on systems where the firmware clears the
APB clock and reset bits at offset 0x804.
This commit fixes this by properly setting prv_offset to 0x800 for
the PWM devices.
Cc: stable@vger.kernel.org
Fixes: e1c748179754 ("ACPI / LPSS: Add Intel BayTrail ACPI mode PWM")
Fixes: 1bfbd8eb8a7f ("ACPI / LPSS: Add ACPI IDs for Intel Braswell")
Acked-by: Rafael J . Wysocki <rjw@rjwysocki.net>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit 408fec36a1ab3d14273c2116b449ef1e9be3cb8b ]
Currently we request control of native PCIe hotplug unconditionally.
Native PCIe hotplug events are handled by the pciehp driver, and if it is
not enabled those events will be lost.
Request control of native PCIe hotplug only if the pciehp driver is
enabled, so we will actually handle native PCIe hotplug events.
Suggested-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
[ Upstream commit 97f3c0a4b0579b646b6b10ae5a3d59f0441cc12c ]
I found an ACPI cache leak in ACPI early termination and boot continuing case.
When early termination occurs due to malicious ACPI table, Linux kernel
terminates ACPI function and continues to boot process. While kernel terminates
ACPI function, kmem_cache_destroy() reports Acpi-Operand cache leak.
Boot log of ACPI operand cache leak is as follows:
>[ 0.464168] ACPI: Added _OSI(Module Device)
>[ 0.467022] ACPI: Added _OSI(Processor Device)
>[ 0.469376] ACPI: Added _OSI(3.0 _SCP Extensions)
>[ 0.471647] ACPI: Added _OSI(Processor Aggregator Device)
>[ 0.477997] ACPI Error: Null stack entry at ffff880215c0aad8 (20170303/exresop-174)
>[ 0.482706] ACPI Exception: AE_AML_INTERNAL, While resolving operands for [opcode_name unavailable] (20170303/dswexec-461)
>[ 0.487503] ACPI Error: Method parse/execution failed [\DBG] (Node ffff88021710ab40), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.492136] ACPI Error: Method parse/execution failed [\_SB._INI] (Node ffff88021710a618), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.497683] ACPI: Interpreter enabled
>[ 0.499385] ACPI: (supports S0)
>[ 0.501151] ACPI: Using IOAPIC for interrupt routing
>[ 0.503342] ACPI Error: Null stack entry at ffff880215c0aad8 (20170303/exresop-174)
>[ 0.506522] ACPI Exception: AE_AML_INTERNAL, While resolving operands for [opcode_name unavailable] (20170303/dswexec-461)
>[ 0.510463] ACPI Error: Method parse/execution failed [\DBG] (Node ffff88021710ab40), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.514477] ACPI Error: Method parse/execution failed [\_PIC] (Node ffff88021710ab18), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.518867] ACPI Exception: AE_AML_INTERNAL, Evaluating _PIC (20170303/bus-991)
>[ 0.522384] kmem_cache_destroy Acpi-Operand: Slab cache still has objects
>[ 0.524597] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.12.0-rc5 #26
>[ 0.526795] Hardware name: innotek gmb_h virtual_box/virtual_box, BIOS virtual_box 12/01/2006
>[ 0.529668] Call Trace:
>[ 0.530811] ? dump_stack+0x5c/0x81
>[ 0.532240] ? kmem_cache_destroy+0x1aa/0x1c0
>[ 0.533905] ? acpi_os_delete_cache+0xa/0x10
>[ 0.535497] ? acpi_ut_delete_caches+0x3f/0x7b
>[ 0.537237] ? acpi_terminate+0xa/0x14
>[ 0.538701] ? acpi_init+0x2af/0x34f
>[ 0.540008] ? acpi_sleep_proc_init+0x27/0x27
>[ 0.541593] ? do_one_initcall+0x4e/0x1a0
>[ 0.543008] ? kernel_init_freeable+0x19e/0x21f
>[ 0.546202] ? rest_init+0x80/0x80
>[ 0.547513] ? kernel_init+0xa/0x100
>[ 0.548817] ? ret_from_fork+0x25/0x30
>[ 0.550587] vgaarb: loaded
>[ 0.551716] EDAC MC: Ver: 3.0.0
>[ 0.553744] PCI: Probing PCI hardware
>[ 0.555038] PCI host bridge to bus 0000:00
> ... Continue to boot and log is omitted ...
I analyzed this memory leak in detail and found acpi_ns_evaluate() function
only removes Info->return_object in AE_CTRL_RETURN_VALUE case. But, when errors
occur, the status value is not AE_CTRL_RETURN_VALUE, and Info->return_object is
also not null. Therefore, this causes acpi operand memory leak.
This cache leak causes a security threat because an old kernel (<= 4.9) shows
memory locations of kernel functions in stack dump. Some malicious users
could use this information to neutralize kernel ASLR.
I made a patch to fix ACPI operand cache leak.
Signed-off-by: Seunghun Han <kkamagui@gmail.com>
Signed-off-by: Erik Schmauss <erik.schmauss@intel.com>
[ Upstream commit b4c0de312613ca676db5bd7e696a44b56795612a ]
This ensures that acpi_ev_fixed_event_detect() does not use fixed_status
and and fixed_enable as uninitialized variables.
[ Upstream commit 8b29d29abc484d638213dd79a18a95ae7e5bb402 ]
Fix once per second (round_robin_time) memory leak of about 1 KB in
each acpi_pad kernel idling thread that is activated.
Found by testing with kmemleak.
Signed-off-by: Lenny Szubowicz <lszubowi@redhat.com>
[ Upstream commit 63347db0affadcbccd5613116ea8431c70139b3e ]
The acpi_get_bus_status wrapper for acpi_bus_get_status_handle has some
code to handle certain device quirks, in some cases we also need this
quirk handling for the initial _STA call.
Specifically on some devices calling _STA before all _DEP dependencies
are met results in errors like these:
[ 0.123579] ACPI Error: No handler for Region [ECRM] (00000000ba9edc4c)
[GenericSerialBus] (20170831/evregion-166)
[ 0.123601] ACPI Error: Region GenericSerialBus (ID=9) has no handler
(20170831/exfldio-299)
[ 0.123618] ACPI Error: Method parse/execution failed
\_SB.I2C1.BAT1._STA, AE_NOT_EXIST (20170831/psparse-550)
acpi_get_bus_status already has code to avoid this, so by using it we
also silence these errors from the initial _STA call.
Note that in order for the acpi_get_bus_status handling for this to work,
we initialize dep_unmet to 1 until acpi_device_dep_initialize gets called,
this means that battery devices will be instantiated with an initial
status of 0. This is not a problem, acpi_bus_attach will get called soon
after the instantiation anyways and it will update the status as first
point of order.
[ Upstream commit ba1edb9a5125a617d612f98eead14b9b84e75c3a ]
The following warning was triggered after resumed from S3 -
if all the nonboot CPUs were put offline before suspend:
[ 1840.329515] unchecked MSR access error: RDMSR from 0x771 at rIP: 0xffffffff86061e3a (native_read_msr+0xa/0x30)
[ 1840.329516] Call Trace:
[ 1840.329521] __rdmsr_on_cpu+0x33/0x50
[ 1840.329525] generic_exec_single+0x81/0xb0
[ 1840.329527] smp_call_function_single+0xd2/0x100
[ 1840.329530] ? acpi_ds_result_pop+0xdd/0xf2
[ 1840.329532] ? acpi_ds_create_operand+0x215/0x23c
[ 1840.329534] rdmsrl_on_cpu+0x57/0x80
[ 1840.329536] ? cpumask_next+0x1b/0x20
[ 1840.329538] ? rdmsrl_on_cpu+0x57/0x80
[ 1840.329541] intel_pstate_update_perf_limits+0xf3/0x220
[ 1840.329544] ? notifier_call_chain+0x4a/0x70
[ 1840.329546] intel_pstate_set_policy+0x4e/0x150
[ 1840.329548] cpufreq_set_policy+0xcd/0x2f0
[ 1840.329550] cpufreq_update_policy+0xb2/0x130
[ 1840.329552] ? cpufreq_update_policy+0x130/0x130
[ 1840.329556] acpi_processor_ppc_has_changed+0x65/0x80
[ 1840.329558] acpi_processor_notify+0x80/0x100
[ 1840.329561] acpi_ev_notify_dispatch+0x44/0x5c
[ 1840.329563] acpi_os_execute_deferred+0x14/0x20
[ 1840.329565] process_one_work+0x193/0x3c0
[ 1840.329567] worker_thread+0x35/0x3b0
[ 1840.329569] kthread+0x125/0x140
[ 1840.329571] ? process_one_work+0x3c0/0x3c0
[ 1840.329572] ? kthread_park+0x60/0x60
[ 1840.329575] ? do_syscall_64+0x67/0x180
[ 1840.329577] ret_from_fork+0x25/0x30
[ 1840.329585] unchecked MSR access error: WRMSR to 0x774 (tried to write 0x0000000000000000) at rIP: 0xffffffff86061f78 (native_write_msr+0x8/0x30)
[ 1840.329586] Call Trace:
[ 1840.329587] __wrmsr_on_cpu+0x37/0x40
[ 1840.329589] generic_exec_single+0x81/0xb0
[ 1840.329592] smp_call_function_single+0xd2/0x100
[ 1840.329594] ? acpi_ds_create_operand+0x215/0x23c
[ 1840.329595] ? cpumask_next+0x1b/0x20
[ 1840.329597] wrmsrl_on_cpu+0x57/0x70
[ 1840.329598] ? rdmsrl_on_cpu+0x57/0x80
[ 1840.329599] ? wrmsrl_on_cpu+0x57/0x70
[ 1840.329602] intel_pstate_hwp_set+0xd3/0x150
[ 1840.329604] intel_pstate_set_policy+0x119/0x150
[ 1840.329606] cpufreq_set_policy+0xcd/0x2f0
[ 1840.329607] cpufreq_update_policy+0xb2/0x130
[ 1840.329610] ? cpufreq_update_policy+0x130/0x130
[ 1840.329613] acpi_processor_ppc_has_changed+0x65/0x80
[ 1840.329615] acpi_processor_notify+0x80/0x100
[ 1840.329617] acpi_ev_notify_dispatch+0x44/0x5c
[ 1840.329619] acpi_os_execute_deferred+0x14/0x20
[ 1840.329620] process_one_work+0x193/0x3c0
[ 1840.329622] worker_thread+0x35/0x3b0
[ 1840.329624] kthread+0x125/0x140
[ 1840.329625] ? process_one_work+0x3c0/0x3c0
[ 1840.329626] ? kthread_park+0x60/0x60
[ 1840.329628] ? do_syscall_64+0x67/0x180
[ 1840.329631] ret_from_fork+0x25/0x30
This is because if there's only one online CPU, the MSR_PM_ENABLE
(package wide)can not be enabled after resumed, due to
intel_pstate_hwp_enable() will only be invoked on AP's online
process after resumed - if there's no AP online, the HWP remains
disabled after resumed (BIOS has disabled it in S3). Then if
there comes a _PPC change notification which touches HWP register
during this stage, the warning is triggered.
Since we don't call acpi_processor_register_performance() when
HWP is enabled, the pr->performance will be NULL. When this is
NULL we don't need to do _PPC change notification.
Reported-by: Doug Smythies <dsmythies@telus.net>
Suggested-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Signed-off-by: Yu Chen <yu.c.chen@intel.com>
commit 53fa1f6e8a5958da698a31edf366ffe90596b490 upstream.
Commit 5928c281524f (ACPI / video: Default lcd_only to true on Win8-ready
and newer machines) made only_lcd default to true on all machines where
acpi_osi_is_win8() returns true, including laptops.
The purpose of this is to avoid the bogus / non-working acpi backlight
interface which many newer BIOS-es define on desktop machines.
But this is causing a regression on some laptops, specifically on the
Dell XPS 13 2013 model, which does not have the LCD flag set for its
fully functional ACPI backlight interface.
Rather then DMI quirking our way out of this, this commits changes the
logic for setting only_lcd to true, to only do this on machines with
a desktop (or server) dmi chassis-type.
Note that we cannot simply only check the chassis-type and not register
the backlight interface based on that as there are some laptops and
tablets which have their chassis-type set to "3" aka desktop. Hopefully
the combination of checking the LCD flag, but only on devices with
a desktop(ish) chassis-type will avoid the needs for DMI quirks for this,
or at least limit the amount of DMI quirks which we need to a minimum.
Fixes: 5928c281524f (ACPI / video: Default lcd_only to true on Win8-ready and newer machines)
Reported-and-tested-by: James Hogan <jhogan@kernel.org>
Cc: 4.15+ <stable@vger.kernel.org> # 4.15+
commit 78727137fdf49edf9f731bde79d7189067b4047a upstream.
There is a small window whereby ARS scan requests can schedule work that
userspace will miss when polling scrub_show. Hold the init_mutex lock
over calls to report the status to close this potential escape. Also,
make sure that requests to cancel the ARS workqueue are treated as an
idle event.
Cc: Vishal Verma <vishal.l.verma@intel.com>
Fixes: 37b137ff8c83 ("nfit, libnvdimm: allow an ARS scrub...")
Reviewed-by: Dave Jiang <dave.jiang@intel.com>
commit bbf038618a24d72e2efc19146ef421bb1e1eda1a upstream.
Just like many other Samsung models, the 670Z5E needs to use the acpi-video
backlight interface rather then the native one for backlight control to
work, add a quirk for this.
Buglink: https://bugzilla.redhat.com/show_bug.cgi?id=1557060
commit 8d0d8ed3356aa9ed43b819aaedd39b08ca453007 upstream.
Commit 1cf03c00e7c1 "nfit: scrub and register regions in a workqueue"
mistakenly attempts to register a region per BLK aperture. There is
nothing to register for individual apertures as they belong as a set to
a BLK aperture group that are registered with a corresponding
DIMM-control-region. Filter them for registration to prevent some
needless devm_kzalloc() allocations.
Fixes: 1cf03c00e7c1 ("nfit: scrub and register regions in a workqueue")
[ Upstream commit 6f0527b77d9e0129dd8e50945b0d610ed943d6b2 ]
ACPICA commit ed0389cb11a61e63c568ac1f67948fc6a7bd1aeb
An invalid opcode indicates something seriously wrong with the
input AML file. The AML parser is immediately confused and lost,
causing the resulting parse tree to be ill-formed. The actual
disassembly can then cause numerous unrelated errors and faults.
This change aborts the disassembly upon discovery of such an
opcode during the AML parse phase.
Link: https://github.com/acpica/acpica/commit/ed0389cb
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
[ Upstream commit 861ba6351c520328e94a78c923b415faa9116287 ]
ACPICA commit 99bc3beca92c6574ea1d69de42e54f872e6373ce
It is reported that on Linux, RTC driver complains wrong errors on
hardware reduced platform:
[ 4.085420] ACPI Warning: Could not enable fixed event - real_time_clock (4) (20160422/evxface-654)
This patch fixes this by correctly adding runtime reduced hardware check.
Reported by Chandan Tagore, fixed by Lv Zheng.
Link: https://github.com/acpica/acpica/commit/99bc3bec
Tested-by: Chandan Tagore <tagore.chandan@gmail.com>
[ Upstream commit 3522f867c13b63cf62acdf1b8ca5664c549a716a ]
acpi_ec.gpe is "unsigned long", hence treating it as "u32" would expose
the wrong half on big-endian 64-bit systems. Fix this by changing its
type to "u32" and removing the cast, as all other code already uses u32
or sometimes even only u8.
Fixes: 1195a098168fcacf (ACPI: Provide /sys/kernel/debug/ec/...)
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit 5928c281524fe451114e04f1dfa11246a37e859f ]
We're seeing a lot of bogus backlight interfaces on newer machines without
a LCD such as desktops, servers and HDMI sticks. This causes userspace to
show a non-functional brightness slider in e.g. the GNOME3 system menu,
which is undesirable. And, in general, we should simply just not register
a non functional backlight interface.
Checking the LCD flag causes the bogus acpi_video backlight interfaces to
go away (on the machines this was tested on).
This change sets the lcd_only option by default on any machines which
are Win8-ready, to fix this.
This is not entirely without a risk of regressions, but video_detect.c
already prefers native-backlight interfaces over the acpi_video one
on Win8-ready machines, calling acpi_video_unregister_backlight() as soon
as a native interface shows up. This is done because the ACPI backlight
interface often is broken on Win8-ready machines, because win8 does not
seem to actually use it.
So in practice we already end up not registering the ACPI backlight
interface on (most) Win8-ready machines with a LCD panel, thus this
change does not change anything for (most) machines with a LCD panel
and on machines without a LCD panel we actually don't want to register
any backlight interfaces.
This has been tested on the following machines and fixes a bogus backlight
interface showing up there:
- Desktop with an Asrock B150M Pro4S/D3 m.b. using i5-6500 builtin gfx
- Intel Compute Stick STK1AW32SC
- Meegopad T08 HDMI stick
Bogus backlight interfaces have also been reported on:
- Desktop with Asus H87I-Plus m.b.
- Desktop with ASRock B75M-ITX m.b.
- Desktop with Gigabyte Z87-D3HP m.b.
- Dell PowerEdge T20 desktop
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1097436
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1133327
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1133329
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1133646
commit b1abf6fc49829d89660c961fafe3f90f3d843c55 upstream.
The resource allocation in WDAT watchdog has off-one-by error, it sets
one byte more than the actual end address. This may eventually lead
to unexpected resource conflicts.
Fixes: 058dfc767008 (ACPI / watchdog: Add support for WDAT hardware watchdog)
Cc: 4.9+ <stable@vger.kernel.org> # 4.9+
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit dc9e0a9347e932e3fd3cd03e7ff241022ed6ea8a upstream.
Commit 99759869faf1 "acpi: Add acpi_map_pxm_to_online_node()" added
support for mapping a given proximity to its nearest, by SLIT distance,
online node. However, it sometimes returns unexpected results due to the
fact that it switches from comparing the PXM node to the last node that
was closer than the current max.
for_each_online_node(n) {
dist = node_distance(node, n);
if (dist < min_dist) {
min_dist = dist;
node = n; <---- from this point we're using the
wrong node for node_distance()
Fixes: 99759869faf1 ("acpi: Add acpi_map_pxm_to_online_node()")
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>>
[ Upstream commit 8ece1d83346bcc431090d59a2184276192189cdd ]
Commit 660b1113e0f3 (ACPI / PM: Fix consistency check for power resources
during resume) introduced a check for ACPI power resources which have
been turned on by the BIOS during suspend and turns these back off again.
This is causing problems on a Dell Venue Pro 11 7130 (i5-4300Y) it causes
the following messages to show up in dmesg:
[ 131.014605] ACPI: Waking up from system sleep state S3
[ 131.150271] acpi LNXPOWER:07: Turning OFF
[ 131.150323] acpi LNXPOWER:06: Turning OFF
[ 131.150911] acpi LNXPOWER:00: Turning OFF
[ 131.169014] ACPI : EC: interrupt unblocked
[ 131.181811] xhci_hcd 0000:00:14.0: System wakeup disabled by ACPI
[ 133.535728] pci_raw_set_power_state: 76 callbacks suppressed
[ 133.535735] iwlwifi 0000:01:00.0: Refused to change power state,
currently in D3
[ 133.597672] PM: noirq resume of devices complete after 2428.891 msecs
Followed by a bunch of iwlwifi errors later on and the pcie device
dropping from the bus (acpiphp thinks it has been unplugged).
Disabling the turning off of unused power resources fixes this. Instead
of adding a quirk for this system, this commit fixes this by moving the
disabling of unused power resources to later in the resume sequence
when the iwlwifi card has been moved out of D3 so the ref_count for
its power resource no longer is 0.
This new behavior seems to match the intend of the original commit which
commit-msg says: "(... which means that no devices are going to need them
any time soon) and we should turn them off".
This also avoids power resources which we need when bringing devices out
of D3 from getting bounced off and then back on again.
[ Upstream commit 2bde7c32b1db162692f05c6be066b5bcd3d9fdbe ]
The power table addresses should be contiguous, but there was a hole
where 0x34 was missing. On most devices this is not a problem as
addresses above 0x34 are used for the BUC# convertors which are not
used in the DSDTs I've access to but after the BUC# convertors
there is a field named GPI1 in the DSTDs, which does get used in some
cases and ended up turning BUC6 on and off due to the wrong addresses,
resulting in turning the entire device off (or causing it to reboot).
Removing the hole in the addresses fixes this, fixing one of my
Bay Trail tablets turning off while booting the mainline kernel.
While at it add comments with the field names used in the DSDTs to
make it easier to compare the register and bits used at each address
with the datasheet.
[ Upstream commit 8153f9ac43897f9f4786b30badc134fcc1a4fb11 ]
acpi_processor_get_throttling() requires to invoke the getter function on
the target CPU. This is achieved by temporarily setting the affinity of the
calling user space thread to the requested CPU and reset it to the original
affinity afterwards.
That's racy vs. CPU hotplug and concurrent affinity settings for that
thread resulting in code executing on the wrong CPU and overwriting the
new affinity setting.
acpi_processor_get_throttling() is invoked in two ways:
1) The CPU online callback, which is already running on the target CPU and
obviously protected against hotplug and not affected by affinity
settings.
2) The ACPI driver probe function, which is not protected against hotplug
during modprobe.
Switch it over to work_on_cpu() and protect the probe function against CPU
hotplug.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Lai Jiangshan <jiangshanlai@gmail.com>
Cc: linux-acpi@vger.kernel.org
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Tejun Heo <tj@kernel.org>
Cc: Len Brown <lenb@kernel.org>
Link: http://lkml.kernel.org/r/20170412201042.785920903@linutronix.de
[ Upstream commit a5cbdf693a60d5b86d4d21dfedd90f17754eb273 ]
When acpi_install_notify_handler() fails the cooling device stays
registered and the sysfs files created via acpi_pss_perf_init() are
leaked and the function returns success.
Undo acpi_pss_perf_init() and return a proper error code.
Link: http://lkml.kernel.org/r/20170412201042.695499645@linutronix.de
commit 23fbd7c70aec7600e3227eb24259fc55bf6e4881 upstream.
A NULL pointer reference kernel bug was observed when
acpi_nfit_add_dimm() called in acpi_nfit_register_dimms() failed. This
error path does not set nfit_mem->nvdimm, but the 2nd
list_for_each_entry() loop in the function assumes it's always set. Add
a check to nfit_mem->nvdimm.
Fixes: ba9c8dd3c222 ("acpi, nfit: add dimm device notification support")
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
commit 43cdd1b716b26f6af16da4e145b6578f98798bf6 upstream.
There's no need to be printing a raw kernel pointer to the kernel log at
every boot. So just remove it, and change the whole message to use the
correct dev_info() call at the same time.
Reported-by: Wang Qize <wang_qize@venustech.com.cn>
[ Upstream commit 10809bb976648ac58194a629e3d7af99e7400297 ]
Most Bay and Cherry Trail devices use a generic DSDT with all possible
peripheral devices present in the DSDT, with their _STA returning 0x00 or
0x0f based on AML variables which describe what is actually present on
the board.
Since ACPI device objects with a 0x00 status (not present) still get an
entry under /sys/bus/acpi/devices, and those entry had an acpi:PNPID
modalias, userspace would end up loading modules for non present hardware.
This commit fixes this by leaving the modalias empty for non present
devices. This results in 10 modules less being loaded with a generic
distro kernel config on my Cherry Trail test-device (a GPD pocket).
commit 3b2d69114fefa474fca542e51119036dceb4aa6f upstream.
ACPICA commit a23325b2e583556eae88ed3f764e457786bf4df6
I found some ACPI operand cache leaks in ACPI early abort cases.
>[ 0.174332] ACPI: Added _OSI(Module Device)
>[ 0.175504] ACPI: Added _OSI(Processor Device)
>[ 0.176010] ACPI: Added _OSI(3.0 _SCP Extensions)
>[ 0.177032] ACPI: Added _OSI(Processor Aggregator Device)
>[ 0.178284] ACPI: SCI (IRQ16705) allocation failed
>[ 0.179352] ACPI Exception: AE_NOT_ACQUIRED, Unable to install
System Control Interrupt handler (20160930/evevent-131)
>[ 0.180008] ACPI: Unable to start the ACPI Interpreter
>[ 0.181125] ACPI Error: Could not remove SCI handler
(20160930/evmisc-281)
>[ 0.184068] kmem_cache_destroy Acpi-Operand: Slab cache still has
objects
>[ 0.185358] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.10.0-rc3 #2
>[ 0.186820] Hardware name: innotek gmb_h virtual_box/virtual_box, BIOS
>[ 0.188000] Call Trace:
>[ 0.188000] ? dump_stack+0x5c/0x7d
>[ 0.188000] ? kmem_cache_destroy+0x224/0x230
>[ 0.188000] ? acpi_sleep_proc_init+0x22/0x22
>[ 0.188000] ? acpi_os_delete_cache+0xa/0xd
>[ 0.188000] ? acpi_ut_delete_caches+0x3f/0x7b
>[ 0.188000] ? acpi_terminate+0x5/0xf
>[ 0.188000] ? acpi_init+0x288/0x32e
>[ 0.188000] ? __class_create+0x4c/0x80
>[ 0.188000] ? video_setup+0x7a/0x7a
>[ 0.188000] ? do_one_initcall+0x4e/0x1b0
>[ 0.188000] ? kernel_init_freeable+0x194/0x21a
>[ 0.188000] ? rest_init+0x80/0x80
>[ 0.188000] ? kernel_init+0xa/0x100
>[ 0.188000] ? ret_from_fork+0x25/0x30
When early abort is occurred due to invalid ACPI information, Linux kernel
terminates ACPI by calling acpi_terminate() function. The function calls
acpi_ns_terminate() function to delete namespace data and ACPI operand cache
(acpi_gbl_module_code_list).
But the deletion code in acpi_ns_terminate() function is wrapped in
ACPI_EXEC_APP definition, therefore the code is only executed when the
definition exists. If the define doesn't exist, ACPI operand cache
(acpi_gbl_module_code_list) is leaked, and stack dump is shown in kernel log.
This causes a security threat because the old kernel (<= 4.9) shows memory
locations of kernel functions in stack dump, therefore kernel ASLR can be
neutralized.
To fix ACPI operand leak for enhancing security, I made a patch which
removes the ACPI_EXEC_APP define in acpi_ns_terminate() function for
executing the deletion code unconditionally.
Link: https://github.com/acpica/acpica/commit/a23325b2
Acked-by: Lee, Chun-Yi <jlee@suse.com>
commit c2a6bbaf0c5f90463a7011a295bbdb7e33c80b51 upstream.
The way acpi_find_child_device() works currently is that, if there
are two (or more) devices with the same _ADR value in the same
namespace scope (which is not specifically allowed by the spec and
the OS behavior in that case is not defined), the first one of them
found to be present (with the help of _STA) will be returned.
This covers the majority of cases, but is not sufficient if some of
the devices in question have a _HID (or _CID) returning some valid
ACPI/PNP device IDs (which is disallowed by the spec) and the
ASL writers' expectation appears to be that the OS will match
devices without a valid ACPI/PNP device ID against a given bus
address first.
To cover this special case as well, modify find_child_checks()
to prefer devices without ACPI/PNP device IDs over devices that
have them.
Suggested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
commit adf6895754e2503d994a765535fd1813f8834674 upstream.
Integration testing with a BIOS that generates injected health event
notifications fails to communicate those events to userspace. The nfit
driver neglects to link the ACPI DIMM device with the necessary driver
data so acpi_nvdimm_notify() fails this lookup:
nfit_mem = dev_get_drvdata(dev);
if (nfit_mem && nfit_mem->flags_attr)
sysfs_notify_dirent(nfit_mem->flags_attr);
Add the necessary linkage when installing the notification handler and
clean it up when the nfit driver instance is torn down.
Cc: Toshi Kani <toshi.kani@hpe.com>
Reported-by: Daniel Osawa <daniel.k.osawa@intel.com>
Tested-by: Daniel Osawa <daniel.k.osawa@intel.com>
commit bb82e0b4a7e96494f0c1004ce50cec3d7b5fb3d1 upstream.
The commit f6f828513290 ("pstore: pass allocated memory region back to
caller") changed the check of the return value from erst_read() in
erst_reader() in the following way:
if (len == -ENOENT)
goto skip;
- else if (len < 0) {
- rc = -1;
+ else if (len < sizeof(*rcd)) {
+ rc = -EIO;
goto out;
This introduced another bug: since the comparison with sizeof() is
cast to unsigned, a negative len value doesn't hit any longer.
As a result, when an error is returned from erst_read(), the code
falls through, and it may eventually lead to some weird thing like
memory corruption.
This patch adds the negative error value check more explicitly for
addressing the issue.
Fixes: f6f828513290 (pstore: pass allocated memory region back to caller)
Tested-by: Jerry Tang <jtang@suse.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
[ Upstream commit c962cff17dfa11f4a8227ac16de2b28aea3312e4 ]
Revert: dc6db24d2476 ("x86/acpi: Set persistent cpuid <-> nodeid mapping when booting")
The mapping of "cpuid <-> nodeid" is established at boot time via ACPI
tables to keep associations of workqueues and other node related items
consistent across cpu hotplug.
But, ACPI tables are unreliable and failures with that boot time mapping
have been reported on machines where the ACPI table and the physical
information which is retrieved at actual hotplug is inconsistent.
Revert the mapping implementation so it can be replaced with a less error
prone approach.
Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Tested-by: Xiaolong Ye <xiaolong.ye@intel.com>
Cc: rjw@rjwysocki.net
Cc: guzheng1@huawei.com
Cc: izumi.taku@jp.fujitsu.com
Cc: lenb@kernel.org
Link: http://lkml.kernel.org/r/1488528147-2279-2-git-send-email-douly.fnst@cn.fujitsu.com
commit 53c5eaabaea9a1b7a96f95ccc486d2ad721d95bb upstream.
Originally the Samsung quirks removed by commit 4c237371 can be covered
by commit e923e8e7 and ec_freeze_events=Y mode. But commit 9c40f956
changed ec_freeze_events=Y back to N, making this problem re-surface.
Actually, if commit e923e8e7 is robust enough, we can freely change
ec_freeze_events mode, so this patch fixes the issue by improving
commit e923e8e7.
Related commits listed in the merged order:
Commit: e923e8e79e18fd6be9162f1be6b99a002e9df2cb
Subject: ACPI / EC: Fix an issue that SCI_EVT cannot be detected
after event is enabled
Commit: 4c237371f290d1ed3b2071dd43554362137b1cce
Subject: ACPI / EC: Remove old CLEAR_ON_RESUME quirk
Commit: 9c40f956ce9b331493347d1b3cb7e384f7dc0581
Subject: Revert "ACPI / EC: Enable event freeze mode..." to fix
a regression
This patch not only fixes the reported post-resume EC event triggering
source issue, but also fixes an unreported similar issue related to the
driver bind by adding EC event triggering source in ec_install_handlers().
Fixes: e923e8e79e18 (ACPI / EC: Fix an issue that SCI_EVT cannot be detected after event is enabled)
Fixes: 4c237371f290 (ACPI / EC: Remove old CLEAR_ON_RESUME quirk)
Fixes: 9c40f956ce9b (Revert "ACPI / EC: Enable event freeze mode..." to fix a regression)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196833
Reported-by: Alistair Hamilton <ahpatent@gmail.com>
Tested-by: Alistair Hamilton <ahpatent@gmail.com>
commit 98529b9272e06a7767034fb8a32e43cdecda240a upstream.
Commit 2a5708409e4e (ACPI / EC: Fix a gap that ECDT EC cannot handle
EC events) introduced acpi_ec_ecdt_start(), but that function is
invoked before acpi_ec_query_init(), which is too early. This causes
the kernel to crash if an EC event occurs after boot, when ec_query_wq
is not valid:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000102
Workqueue: events acpi_ec_event_handler
task: ffff9f539790dac0 task.stack: ffffb437c0e10000
RIP: 0010:__queue_work+0x32/0x430
Normally, the DSDT EC should always be valid, so acpi_ec_ecdt_start()
is actually a no-op in the majority of cases. However, commit
c712bb58d827 (ACPI / EC: Add support to skip boot stage DSDT probe)
caused the probing of the DSDT EC as the "boot EC" to be skipped when
the ECDT EC is valid and uncovered the bug.
Fix this issue by invoking acpi_ec_ecdt_start() after acpi_ec_query_init()
in acpi_ec_init().
Link: https://jira01.devtools.intel.com/browse/LCK-4348
Fixes: 2a5708409e4e (ACPI / EC: Fix a gap that ECDT EC cannot handle EC events)
Fixes: c712bb58d827 (ACPI / EC: Add support to skip boot stage DSDT probe)
Reported-by: Wang Wendy <wendy.wang@intel.com>
Tested-by: Feng Chenzhou <chenzhoux.feng@intel.com>
[ rjw: Changelog ]
commit 7d64f82cceb21e6d95db312d284f5f195e120154 upstream.
When removing a GHES device notified by SCI, list_del_rcu() is used,
ghes_remove() should call synchronize_rcu() before it goes on to call
kfree(ghes), otherwise concurrent RCU readers may still hold this list
entry after it has been freed.
Signed-off-by: James Morse <james.morse@arm.com>
Reviewed-by: "Huang, Ying" <ying.huang@intel.com>
Fixes: 81e88fdc432a (ACPI, APEI, Generic Hardware Error Source POLL/IRQ/NMI notification type support)
commit e3d5092b6756b9e0b08f94bbeafcc7afe19f0996 upstream.
The on-stack resource-window 'win' in setup_res() is not
properly initialized. This causes the pointers in the
embedded 'struct resource' to contain stale addresses.
These pointers (in my case the ->child pointer) later get
propagated to the global iomem_resources list, causing a #GP
exception when the list is traversed in
iomem_map_sanity_check().
Fixes: c183619b63ec (x86/irq, ACPI: Implement ACPI driver to support IOAPIC hotplug)
Signed-off-by: Joerg Roedel <jroedel@suse.de>
[ Upstream commit c2a6bbaf0c5f90463a7011a295bbdb7e33c80b51 ]
address first.
have them.
commit 7e700d2c59e5853c9126642976b4f5768f64c9b3 upstream.
nfit_init() calls nfit_mce_register() on module load. When the module
load fails the nfit mce decoder is not unregistered. The module's
memory is freed leaving the decoder chain referencing junk. This will
cause panics as future registrations will reference the free'd memory.
Unregister the nfit mce decoder on module init failure.
[v2]: register and then unregister mce handler to avoid losing mce events
[v3]: also cleanup nfit workqueue
Fixes: 6839a6d96f4e ("nfit: do an ARS scrub on hitting a latent media error")
Cc: "Lee, Chun-Yi" <joeyli.kernel@gmail.com>
Cc: Linda Knippers <linda.knippers@hpe.com>
Cc: lszubowi@redhat.com
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
