[ Upstream commit b1c0330823fe842dbb34641f1410f0afa51c29d3 ]
Some systems have had functional issues since commit 5a8361f7ecce
(ACPICA: Integrate package handling with module-level code) that,
among other things, changed the initial values of the
acpi_gbl_group_module_level_code and acpi_gbl_parse_table_as_term_list
global flags in ACPICA which implicitly caused acpi_ec_ecdt_probe() to
be called before acpi_load_tables() on the vast majority of platforms.
Namely, before commit 5a8361f7ecce, acpi_load_tables() was called from
acpi_early_init() if acpi_gbl_parse_table_as_term_list was FALSE and
acpi_gbl_group_module_level_code was TRUE, which almost always was
the case as FALSE and TRUE were their initial values, respectively.
The acpi_gbl_parse_table_as_term_list value would be changed to TRUE
for a couple of platforms in acpi_quirks_dmi_table[], but it remained
FALSE in the vast majority of cases.
After commit 5a8361f7ecce, the initial values of the two flags have
been reversed, so in effect acpi_load_tables() has not been called
from acpi_early_init() any more. That, in turn, affects
acpi_ec_ecdt_probe() which is invoked before acpi_load_tables() now
and it is not possible to evaluate the _REG method for the EC address
space handler installed by it. That effectively causes the EC address
space to be inaccessible to AML on platforms with an ECDT matching the
EC device definition in the DSDT and functional problems ensue in
there.
Because the default behavior before commit 5a8361f7ecce was to call
acpi_ec_ecdt_probe() after acpi_load_tables(), it should be safe to
do that again. Moreover, the EC address space handler installed by
acpi_ec_ecdt_probe() is only needed for AML to be able to access the
EC address space and the only AML that can run during acpi_load_tables()
is module-level code which only is allowed to access address spaces
with default handlers (memory, I/O and PCI config space).
For this reason, move the acpi_ec_ecdt_probe() invocation back to
acpi_bus_init(), from where it was taken away by commit d737f333b211
(ACPI: probe ECDT before loading AML tables regardless of module-level
code flag), and put it after the invocation of acpi_load_tables() to
restore the original code ordering from before commit 5a8361f7ecce.
Fixes: 5a8361f7ecce ("ACPICA: Integrate package handling with module-level code")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=199981
Reported-by: step-ali <sunmooon15@gmail.com>
Reported-by: Charles Stanhope <charles.stanhope@gmail.com>
Tested-by: Charles Stanhope <charles.stanhope@gmail.com>
Reported-by: Paulo Nascimento <paulo.ulusu@googlemail.com>
Reported-by: David Purton <dcpurton@marshwiggle.net>
Reported-by: Adam Harvey <adam@adamharvey.name>
Reported-by: Zhang Rui <rui.zhang@intel.com>
Tested-by: Zhang Rui <rui.zhang@intel.com>
Tested-by: Jean-Marc Lenoir <archlinux@jihemel.com>
[ Upstream commit 0919871ac37fdcf46c7657da0f1742efe096b399 ]
Possible race accessing memdev structures after dropping the
mutex. Dan Williams says this could race against another thread
that is doing:
# echo "ACPI0012:00" > /sys/bus/acpi/drivers/nfit/unbind
Reported-by: Jane Chu <jane.chu@oracle.com>
Fixes: 23222f8f8dce ("acpi, nfit: Add function to look up nvdimm...")
Signed-off-by: Tony Luck <tony.luck@intel.com>
[ Upstream commit b9ced18acf68dffebe6888c7ec765a2b1db7a039 ]
The addresses of NUMA nodes are not printed correctly on i386-PAE
which is misleading.
Here is a debian9-32bit with PAE in a QEMU guest having more than 4G
of memory:
qemu-system-i386 \
-hda /var/lib/libvirt/images/debian32.qcow2 \
-m 5G \
-enable-kvm \
-smp 10 \
-numa node,mem=512M,nodeid=0,cpus=0 \
-numa node,mem=512M,nodeid=1,cpus=1 \
-numa node,mem=512M,nodeid=2,cpus=2 \
-numa node,mem=512M,nodeid=3,cpus=3 \
-numa node,mem=512M,nodeid=4,cpus=4 \
-numa node,mem=512M,nodeid=5,cpus=5 \
-numa node,mem=512M,nodeid=6,cpus=6 \
-numa node,mem=512M,nodeid=7,cpus=7 \
-numa node,mem=512M,nodeid=8,cpus=8 \
-numa node,mem=512M,nodeid=9,cpus=9 \
-serial stdio
Because of the wrong value type, it prints as below:
[ 0.021049] ACPI: SRAT Memory (0x0 length 0xa0000) in proximity domain 0 enabled
[ 0.021740] ACPI: SRAT Memory (0x100000 length 0x1ff00000) in proximity domain 0 enabled
[ 0.022425] ACPI: SRAT Memory (0x20000000 length 0x20000000) in proximity domain 1 enabled
[ 0.023092] ACPI: SRAT Memory (0x40000000 length 0x20000000) in proximity domain 2 enabled
[ 0.023764] ACPI: SRAT Memory (0x60000000 length 0x20000000) in proximity domain 3 enabled
[ 0.024431] ACPI: SRAT Memory (0x80000000 length 0x20000000) in proximity domain 4 enabled
[ 0.025104] ACPI: SRAT Memory (0xa0000000 length 0x20000000) in proximity domain 5 enabled
[ 0.025791] ACPI: SRAT Memory (0x0 length 0x20000000) in proximity domain 6 enabled
[ 0.026412] ACPI: SRAT Memory (0x20000000 length 0x20000000) in proximity domain 7 enabled
[ 0.027118] ACPI: SRAT Memory (0x40000000 length 0x20000000) in proximity domain 8 enabled
[ 0.027802] ACPI: SRAT Memory (0x60000000 length 0x20000000) in proximity domain 9 enabled
The upper half of the start address of the NUMA domains between 6
and 9 inclusive was cut, so the printed values are incorrect.
Fix the value type, to get the correct values in the log as follows:
[ 0.023698] ACPI: SRAT Memory (0x0 length 0xa0000) in proximity domain 0 enabled
[ 0.024325] ACPI: SRAT Memory (0x100000 length 0x1ff00000) in proximity domain 0 enabled
[ 0.024981] ACPI: SRAT Memory (0x20000000 length 0x20000000) in proximity domain 1 enabled
[ 0.025659] ACPI: SRAT Memory (0x40000000 length 0x20000000) in proximity domain 2 enabled
[ 0.026317] ACPI: SRAT Memory (0x60000000 length 0x20000000) in proximity domain 3 enabled
[ 0.026980] ACPI: SRAT Memory (0x80000000 length 0x20000000) in proximity domain 4 enabled
[ 0.027635] ACPI: SRAT Memory (0xa0000000 length 0x20000000) in proximity domain 5 enabled
[ 0.028311] ACPI: SRAT Memory (0x100000000 length 0x20000000) in proximity domain 6 enabled
[ 0.028985] ACPI: SRAT Memory (0x120000000 length 0x20000000) in proximity domain 7 enabled
[ 0.029667] ACPI: SRAT Memory (0x140000000 length 0x20000000) in proximity domain 8 enabled
[ 0.030334] ACPI: SRAT Memory (0x160000000 length 0x20000000) in proximity domain 9 enabled
Signed-off-by: Chao Fan <fanc.fnst@cn.fujitsu.com>
[ rjw: Subject & changelog ]
[ Upstream commit 98cff8b23ed1c763a029ee81ea300df0d153d07d ]
In __ghes_panic() clear the block status in the APEI generic
error status block for that generic hardware error source before
calling panic() to prevent a second panic() in the crash kernel
for exactly the same fatal error.
Otherwise ghes_probe(), running in the crash kernel, would see
an unhandled error in the APEI generic error status block and
panic again, thereby precluding any crash dump.
Signed-off-by: Lenny Szubowicz <lszubowi@redhat.com>
Signed-off-by: David Arcari <darcari@redhat.com>
Tested-by: Tyler Baicar <baicar.tyler@gmail.com>
Acked-by: Borislav Petkov <bp@suse.de>
[ Upstream commit b413b1abeb21b4a152c0bf8d1379efa30759b6e3 ]
Since SPCR 1.04 [1] the baud rate of 0 means a preconfigured state of UART.
Assume firmware or bootloader configures console correctly.
[1]: https://docs.microsoft.com/en-us/windows-hardware/drivers/serports/serial-port-console-redirection-table
Reviewed-by: Prarit Bhargava <prarit@redhat.com>
commit 11189c1089da413aa4b5fd6be4c4d47c78968819 upstream.
The _DSM function number validation only happens to succeed when the
generic Linux command number translation corresponds with a
DSM-family-specific function number. This breaks NVDIMM-N
implementations that correctly implement _LSR, _LSW, and _LSI, but do
not happen to publish support for DSM function numbers 4, 5, and 6.
Recall that the support for _LS{I,R,W} family of methods results in the
DIMM being marked as supporting those command numbers at
acpi_nfit_register_dimms() time. The DSM function mask is only used for
ND_CMD_CALL support of non-NVDIMM_FAMILY_INTEL devices.
Fixes: 31eca76ba2fc ("nfit, libnvdimm: limited/whitelisted dimm command...")
Cc: <stable@vger.kernel.org>
Link: https://github.com/pmem/ndctl/issues/78
Reported-by: Sujith Pandel <sujith_pandel@dell.com>
Tested-by: Sujith Pandel <sujith_pandel@dell.com>
Reviewed-by: Vishal Verma <vishal.l.verma@intel.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
commit 5e9e38d0db1d29efed1dd4cf9a70115d33521be7 upstream.
In preparation for using function number 0 as an error value, prevent it
from being considered a valid function value by acpi_nfit_ctl().
Cc: stuart hayes <stuart.w.hayes@gmail.com>
Fixes: e02fb7264d8a ("nfit: add Microsoft NVDIMM DSM command set...")
Reported-by: Jeff Moyer <jmoyer@redhat.com>
commit c7777236dd8f587f6a8d6800c03df318fd4d2627 upstream.
When executed for a PCI_ROOT_COMPLEX type, iort_match_node_callback()
expects the opaque pointer argument to be a PCI bus device. At the
moment rc_dma_get_range() passes the PCI endpoint instead of the bus,
and we've been lucky to have pci_domain_nr(ptr) return 0 instead of
crashing. Pass the bus device to iort_scan_node().
Fixes: 5ac65e8c8941 ("ACPI/IORT: Support address size limit for root complexes")
Reported-by: Eric Auger <eric.auger@redhat.com>
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Cc: stable@vger.kernel.org
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
commit 2b531d71595d2b5b12782a49b23c335869e2621e upstream.
The current-source used for the battery temp-sensor (TS) is shared with the
GPADC. For proper fuel-gauge and charger operation the TS current-source
needs to be permanently on. But to read the GPADC we need to temporary
switch the TS current-source to ondemand, so that the GPADC can use it,
otherwise we will always read an all 0 value.
The switching from on to on-ondemand is not necessary when the TS
current-source is off (this happens on devices which do not have a TS).
Prior to this commit there were 2 issues with our handling of the TS
current-source switching:
1) We were writing hardcoded values to the ADC TS pin-ctrl register,
overwriting various other unrelated bits. Specifically we were overwriting
the current-source setting for the TS and GPIO0 pins, forcing it to 80ųA
independent of its original setting. On a Chuwi Vi10 tablet this was
causing us to get a too high adc value (due to a too high current-source)
resulting in acpi_lpat_raw_to_temp() returning -ENOENT, resulting in:
ACPI Error: AE_ERROR, Returned by Handler for [UserDefinedRegion]
ACPI Error: Method parse/execution failed \_SB.SXP1._TMP, AE_ERROR
This commit fixes this by using regmap_update_bits to change only the
relevant bits.
2) At the end of intel_xpower_pmic_get_raw_temp() we were unconditionally
enabling the TS current-source even on devices where the TS-pin is not used
and the current-source thus was off on entry of the function.
This commit fixes this by checking if the TS current-source is off when
entering intel_xpower_pmic_get_raw_temp() and if so it is left as is.
Fixes: 58eefe2f3f53 (ACPI / PMIC: xpower: Do pinswitch ... reading GPADC)
Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: 4.14+ <stable@vger.kernel.org> # 4.14+
commit 7d7b467cb95bf29597b417d4990160d4ea6d69b9 upstream.
Some ACPI tables contain duplicate power resource references like this:
Name (_PR0, Package (0x04) // _PR0: Power Resources for D0
P28P,
P18P,
P18P,
CLK4
This causes a WARN_ON in sysfs_add_link_to_group() because we end up
adding a link to the same acpi_device twice:
sysfs: cannot create duplicate filename '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/OVTI2680:00/power_resources_D0/LNXPOWER:0a'
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.12-301.fc29.x86_64 #1
Hardware name: Insyde CherryTrail/Type2 - Board Product Name, BIOS jumperx.T87.KFBNEEA02 04/13/2016
Call Trace:
dump_stack+0x5c/0x80
sysfs_warn_dup.cold.3+0x17/0x2a
sysfs_do_create_link_sd.isra.2+0xa9/0xb0
sysfs_add_link_to_group+0x30/0x50
acpi_power_expose_list+0x74/0xa0
acpi_power_add_remove_device+0x50/0xa0
acpi_add_single_object+0x26b/0x5f0
acpi_bus_check_add+0xc4/0x250
To address this issue, make acpi_extract_power_resources() check for
duplicates and simply skip them when found.
Cc: All applicable <stable@vger.kernel.org>
[ rjw: Subject & changelog, comments ]
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm fixes from Dan Williams:
"A regression fix for the Address Range Scrub implementation, yes
another one, and support for platforms that misalign persistent memory
relative to the Linux memory hotplug section constraint. Longer term,
support for sub-section memory hotplug would alleviate alignment
waste, but until then this hack allows a 'struct page' memmap to be
established for these misaligned memory regions.
These have all appeared in a -next release, and thanks to Patrick for
reporting and testing the alignment padding fix.
Summary:
- Unless and until the core mm handles memory hotplug units smaller
than a section (128M), persistent memory namespaces must be padded
to section alignment.
The libnvdimm core already handled section collision with "System
RAM", but some configurations overlap independent "Persistent
Memory" ranges within a section, so additional padding injection is
added for that case.
- The recent reworks of the ARS (address range scrub) state machine
to reduce the number of state flags inadvertantly missed a
conversion of acpi_nfit_ars_rescan() call sites. Fix the regression
whereby user-requested ARS results in a "short" scrub rather than a
"long" scrub.
- Fixup the unit tests to handle / test the 128M section alignment of
mocked test resources.
* tag 'libnvdimm-fixes-4.20-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
acpi/nfit: Fix user-initiated ARS to be "ARS-long" rather than "ARS-short"
libnvdimm, pfn: Pad pfn namespaces relative to other regions
tools/testing/nvdimm: Align test resources to 128M
A "short" ARS (address range scrub) instructs the platform firmware to
return known errors. In contrast, a "long" ARS instructs platform
firmware to arrange every data address on the DIMM to be read / checked
for poisoned data.
The conversion of the flags in commit d3abaf43bab8 "acpi, nfit: Fix
Address Range Scrub completion tracking", changed the meaning of passing
'0' to acpi_nfit_ars_rescan(). Previously '0' meant "not short", now '0'
is ARS_REQ_SHORT. Pass ARS_REQ_LONG to restore the expected scrub-type
behavior of user-initiated ARS sessions.
Fixes: d3abaf43bab8 ("acpi, nfit: Fix Address Range Scrub completion tracking")
Reported-by: Jacek Zloch <jacek.zloch@intel.com>
Cc: Vishal Verma <vishal.l.verma@intel.com>
Reviewed-by: Dave Jiang <dave.jiang@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Catalin Marinas:
- Cortex-A76 erratum workaround
- ftrace fix to enable syscall events on arm64
- Fix uninitialised pointer in iort_get_platform_device_domain()
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
ACPI/IORT: Fix iort_get_platform_device_domain() uninitialized pointer value
arm64: ftrace: Fix to enable syscall events on arm64
arm64: Add workaround for Cortex-A76 erratum 1286807
Running the Clang static analyzer on IORT code detected the following
error:
Logic error: Branch condition evaluates to a garbage value
in
If the named component associated with a given device has no IORT
mappings, iort_get_platform_device_domain() exits its MSI mapping loop
with msi_parent pointer containing garbage, which can lead to erroneous
code path execution.
Initialize the msi_parent pointer, fixing the bug.
Fixes: d4f54a186667 ("ACPI: platform: setup MSI domain for ACPI based
platform device")
Reported-by: Patrick Bellasi <patrick.bellasi@arm.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
* acpica-fixes:
ACPICA: Fix handling of buffer-size in acpi_ex_write_data_to_field()
Many HP AMD based laptops contain an SMB0001 device like this:
Device (SMBD)
Name (_HID, "SMB0001") // _HID: Hardware ID
Name (_CRS, ResourceTemplate () // _CRS: Current Resource Settings
IO (Decode16,
0x0B20, // Range Minimum
0x0B20, // Range Maximum
0x20, // Alignment
0x20, // Length
IRQ (Level, ActiveLow, Shared, )
{7}
The legacy style IRQ resource here causes acpi_dev_get_irqresource() to
be called with legacy=true and this message to show in dmesg:
ACPI: IRQ 7 override to edge, high
This causes issues when later on the AMD0030 GPIO device gets enumerated:
Device (GPIO)
Name (_HID, "AMDI0030") // _HID: Hardware ID
Name (_CID, "AMDI0030") // _CID: Compatible ID
Name (_UID, Zero) // _UID: Unique ID
Method (_CRS, 0, NotSerialized) // _CRS: Current Resource Settings
Name (RBUF, ResourceTemplate ()
Interrupt (ResourceConsumer, Level, ActiveLow, Shared, ,, )
0x00000007,
Memory32Fixed (ReadWrite,
0xFED81500, // Address Base
0x00000400, // Address Length
Return (RBUF) /* \_SB_.GPIO._CRS.RBUF */
Now acpi_dev_get_irqresource() gets called with legacy=false, but because
of the earlier override of the trigger-type acpi_register_gsi() returns
-EBUSY (because we try to register the same interrupt with a different
trigger-type) and we end up setting IORESOURCE_DISABLED in the flags.
The setting of IORESOURCE_DISABLED causes platform_get_irq() to call
acpi_irq_get() which is not implemented on x86 and returns -EINVAL.
resulting in the following in dmesg:
amd_gpio AMDI0030:00: Failed to get gpio IRQ: -22
amd_gpio: probe of AMDI0030:00 failed with error -22
The SMB0001 is a "virtual" device in the sense that the only way the OS
interacts with it is through calling a couple of methods to do SMBus
transfers. As such it is weird that it has IO and IRQ resources at all,
because the driver for it is not expected to ever access the hardware
directly.
The Linux driver for the SMB0001 device directly binds to the acpi_device
through the acpi_bus, so we do not need to instantiate a platform_device
for this ACPI device. This commit adds the SMB0001 HID to the
forbidden_id_list, avoiding the instantiating of a platform_device for it.
Not instantiating a platform_device means we will no longer call
acpi_dev_get_irqresource() for the legacy IRQ resource fixing the probe of
the AMDI0030 device failing.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1644013
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=198715
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=199523
Reported-by: Lukas Kahnert <openproggerfreak@gmail.com>
Tested-by: Marc <suaefar@googlemail.com>
Generic Serial Bus transfers use a data struct like this:
struct gsb_buffer {
u8 status;
u8 len;
u8 data[0];
acpi_ex_write_data_to_field() copies the data which is to be written from
the source-buffer to a temp-buffer. This is done because the OpReg-handler
overwrites the status field and some transfers do a write + read-back.
Commit f99b89eefeb6 ("ACPICA: Update for generic_serial_bus and
attrib_raw_process_bytes protocol") acpi_ex_write_data_to_field()
introduces a number of problems with this:
1) It drops a "length += 2" statement used to calculate the temp-buffer
size causing the temp-buffer to only be 1/2 bytes large for byte/word
transfers while it should be 3/4 bytes (taking the status and len field
into account). This is already fixed in commit e324e10109fc ("ACPICA:
Update for field unit access") which refactors the code.
The ACPI 6.0 spec (ACPI_6.0.pdf) "5.5.2.4.5.2 Declaring and Using a
GenericSerialBusData Buffer" (page 232) states that the GenericSerialBus
Data Buffer Length field is only valid when doing a Read/Write Block
(AttribBlock) transfer, but since the troublesome commit we unconditionally
use the len field to determine how much data to copy from the source-buffer
into the temp-buffer passed to the OpRegion.
This causes 3 further issues:
2) This may lead to not copying enough data to the temp-buffer causing the
OpRegion handler for the serial-bus to write garbage to the hardware.
3) The temp-buffer passed to the OpRegion is allocated to the size
returned by acpi_ex_get_serial_access_length(), which may be as little
as 1, so potentially this may lead to a write overflow of the temp-buffer.
4) Commit e324e10109fc ("ACPICA: Update for field unit access") drops a
length check on the source-buffer, leading to a potential read overflow
of the source-buffer.
This commit fixes all 3 remaining issues by not looking at the len field at
all (the interpretation of this field is left up to the OpRegion handler),
and copying the minimum of the source- and temp-buffer sizes from the
source-buffer to the temp-buffer.
This fixes e.g. an Acer S1003 no longer booting since the troublesome
commit.
Fixes: f99b89eefeb6 (ACPICA: Update for generic_serial_bus and ...)
Fixes: e324e10109fc (ACPICA: Update for field unit access)
"A small batch of fixes for v4.20-rc3.
The overflow continuation fix addresses something that has been broken
for several releases. Arguably it could wait even longer, but it's a
one line fix and this finishes the last of the known address range
scrub bug reports. The revert addresses a lockdep regression. The unit
tests are not critical to fix, but no reason to hold this fix back.
Summary:
- Address Range Scrub overflow continuation handling has been broken
since it was initially merged. It was only recently that error
injection and platform-BIOS support enabled this corner case to be
exercised.
- The recent attempt to provide more isolation for the kernel Address
Range Scrub state machine from userapace initiated sessions
triggers a lockdep report. Revert and try again at the next merge
window.
- Fix a kasan reported buffer overflow in libnvdimm unit test
infrastrucutre (nfit_test)"
* tag 'libnvdimm-fixes-4.20-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
Revert "acpi, nfit: Further restrict userspace ARS start requests"
acpi, nfit: Fix ARS overflow continuation
tools/testing/nvdimm: Fix the array size for dimm devices.
Pull ACPI fix from Rafael Wysocki:
"Fix a recently introduced build issue in the xpower PMIC driver (Arnd
Bergmann)"
* tag 'acpi-4.20-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / PMIC: xpower: fix IOSF_MBI dependency
The following lockdep splat results from acquiring the init_mutex in
acpi_nfit_clear_to_send():
WARNING: possible circular locking dependency detected
lt-daxdev-error/7216 is trying to acquire lock:
00000000f694db15 (&acpi_desc->init_mutex){+.+.}, at: acpi_nfit_clear_to_send+0x27/0x80 [nfit]
but task is already holding lock:
00000000182298f2 (&nvdimm_bus->reconfig_mutex){+.+.}, at: __nd_ioctl+0x457/0x610 [libnvdimm]
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&nvdimm_bus->reconfig_mutex){+.+.}:
nvdimm_badblocks_populate+0x41/0x150 [libnvdimm]
nd_region_notify+0x95/0xb0 [libnvdimm]
nd_device_notify+0x40/0x50 [libnvdimm]
ars_complete+0x7f/0xd0 [nfit]
acpi_nfit_scrub+0xbb/0x410 [nfit]
process_one_work+0x22b/0x5c0
worker_thread+0x3c/0x390
kthread+0x11e/0x140
ret_from_fork+0x3a/0x50
-> #0 (&acpi_desc->init_mutex){+.+.}:
__mutex_lock+0x83/0x980
__nd_ioctl+0x474/0x610 [libnvdimm]
nd_ioctl+0xa4/0xb0 [libnvdimm]
do_vfs_ioctl+0xa5/0x6e0
ksys_ioctl+0x70/0x80
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x60/0x210
entry_SYSCALL_64_after_hwframe+0x49/0xbe
New infrastructure is needed to be able to perform this check without
acquiring the lock.
Fixes: 594861215c83 ("acpi, nfit: Further restrict userspace ARS start")
Cc: Dave Jiang <dave.jiang@intel.com>
When the platform BIOS is unable to report all the media error records
it requires the OS to restart the scrub at a prescribed location. The
driver detects the overflow condition, but then fails to report it to
the ARS state machine after reaping the records. Propagate -ENOSPC
correctly to continue the ARS operation.
Fixes: 1cf03c00e7c1 ("nfit: scrub and register regions in a workqueue")
We still get a link failure with IOSF_MBI=m when the xpower driver
is built-in:
drivers/acpi/pmic/intel_pmic_xpower.o: In function `intel_xpower_pmic_update_power':
intel_pmic_xpower.c:(.text+0x4f2): undefined reference to `iosf_mbi_block_punit_i2c_access'
intel_pmic_xpower.c:(.text+0x5e2): undefined reference to `iosf_mbi_unblock_punit_i2c_access'
This makes the dependency stronger, so we can only build when IOSF_MBI
is built-in.
Fixes: 6a9b593d4b6f (ACPI / PMIC: xpower: Add depends on IOSF_MBI to Kconfig entry)
The NFIT machine check handler uses the physical address from the mce
structure, and compares it against information in the ACPI NFIT table
to determine whether that location lies on an NVDIMM. The mce->addr
field however may not always be valid, and this is indicated by the
MCI_STATUS_ADDRV bit in the status field.
Export mce_usable_address() which already performs validation for the
address, and use it in the NFIT handler.
Fixes: 6839a6d96f4e ("nfit: do an ARS scrub on hitting a latent media error")
Reported-by: Robert Elliott <elliott@hpe.com>
Signed-off-by: Vishal Verma <vishal.l.verma@intel.com>
CC: Arnd Bergmann <arnd@arndb.de>
Cc: Dan Williams <dan.j.williams@intel.com>
CC: Dave Jiang <dave.jiang@intel.com>
CC: elliott@hpe.com
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: Ingo Molnar <mingo@redhat.com>
CC: Len Brown <lenb@kernel.org>
CC: linux-acpi@vger.kernel.org
CC: linux-edac <linux-edac@vger.kernel.org>
CC: linux-nvdimm@lists.01.org
CC: Qiuxu Zhuo <qiuxu.zhuo@intel.com>
CC: "Rafael J. Wysocki" <rjw@rjwysocki.net>
CC: Ross Zwisler <zwisler@kernel.org>
CC: stable <stable@vger.kernel.org>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Tony Luck <tony.luck@intel.com>
CC: x86-ml <x86@kernel.org>
CC: Yazen Ghannam <yazen.ghannam@amd.com>
Link: http://lkml.kernel.org/r/20181026003729.8420-2-vishal.l.verma@intel.com
The MCE handler for nfit devices is called for memory errors on a
Non-Volatile DIMM and adds the error location to a 'badblocks' list.
This list is used by the various NVDIMM drivers to avoid consuming known
poison locations during IO.
The MCE handler gets called for both corrected and uncorrectable errors.
Until now, both kinds of errors have been added to the badblocks list.
However, corrected memory errors indicate that the problem has already
been fixed by hardware, and the resulting interrupt is merely a
notification to Linux.
As far as future accesses to that location are concerned, it is
perfectly fine to use, and thus doesn't need to be included in the above
badblocks list.
Add a check in the nfit MCE handler to filter out corrected mce events,
and only process uncorrectable errors.
Reported-by: Omar Avelar <omar.avelar@intel.com>
CC: Dan Williams <dan.j.williams@intel.com>
CC: elliott@hpe.com
Link: http://lkml.kernel.org/r/20181026003729.8420-1-vishal.l.verma@intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"This series contains a number of improvements to existing drivers,
such as LPSS. Some drivers, such as renesas-tpu and rcar get support
for more SoC generations. To round things off this fixes an issue with
the sysfs interface"
* tag 'pwm/for-4.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm:
pwm: lpss: Only set update bit if we are actually changing the settings
pwm: lpss: Force runtime-resume on suspend on Cherry Trail
pwm: Enable TI ECAP driver for ARCH_K3
dt-bindings: pwm: tiecap: Add TI AM654 SoC specific compatible
dt-bindings: pwm: rcar: Add r8a774a1 support
pwm: Send a uevent on the pwmchip device upon channel sysfs (un)export
Revert "pwm: Set class for exported channels in sysfs"
dt-bindings: pwm: renesas-tpu: Document r8a7744 support
dt-bindings: pwm: rcar: Add r8a7744 support
dt-bindings: pwm: renesas: tpu: Document R8A779{7|8}0 bindings
dt-bindings: pwm: renesas: pwm-rcar: Document R8A779{7|8}0 bindings
dt-bindings: pwm: renesas: tpu: Fix "compatible" prop description
pwm: Use SPDX identifier for Renesas drivers
pwm: lpss: Add get_state callback
pwm: lpss: Release runtime-pm reference from the driver's remove callback
pwm: lpss: Check PWM powerstate after resume on Cherry Trail devices
pwm: lpss: Move struct pwm_lpss_chip definition to the header file
pwm: lpss: Add ACPI HID for second PWM controller on Cherry Trail devices
ACPI / PM: Export acpi_device_get_power() for use by modular build drivers
pwm: tegra: Remove gratuituous blank line
add_memory() currently does not take the device_hotplug_lock, however
is aleady called under the lock from
arch/powerpc/platforms/pseries/hotplug-memory.c
drivers/acpi/acpi_memhotplug.c
to synchronize against CPU hot-remove and similar.
In general, we should hold the device_hotplug_lock when adding memory to
synchronize against online/offline request (e.g. from user space) - which
already resulted in lock inversions due to device_lock() and
mem_hotplug_lock - see 30467e0b3be ("mm, hotplug: fix concurrent memory
hot-add deadlock"). add_memory()/add_memory_resource() will create memory
block devices, so this really feels like the right thing to do.
Holding the device_hotplug_lock makes sure that a memory block device
can really only be accessed (e.g. via .online/.state) from user space,
once the memory has been fully added to the system.
The lock is not held yet in
drivers/xen/balloon.c
arch/powerpc/platforms/powernv/memtrace.c
drivers/s390/char/sclp_cmd.c
drivers/hv/hv_balloon.c
So, let's either use the locked variants or take the lock.
Don't export add_memory_resource(), as it once was exported to be used by
XEN, which is never built as a module. If somebody requires it, we also
have to export a locked variant (as device_hotplug_lock is never
exported).
Link: http://lkml.kernel.org/r/20180925091457.28651-3-david@redhat.com
Signed-off-by: David Hildenbrand <david@redhat.com>
Reviewed-by: Pavel Tatashin <pavel.tatashin@microsoft.com>
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Reviewed-by: Rashmica Gupta <rashmica.g@gmail.com>
Reviewed-by: Oscar Salvador <osalvador@suse.de>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Len Brown <lenb@kernel.org>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: John Allen <jallen@linux.vnet.ibm.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Mathieu Malaterre <malat@debian.org>
Cc: Pavel Tatashin <pavel.tatashin@microsoft.com>
Cc: YASUAKI ISHIMATSU <yasu.isimatu@gmail.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Cc: Stephen Hemminger <sthemmin@microsoft.com>
Patch series "mm: online/offline_pages called w.o. mem_hotplug_lock", v3.
Reading through the code and studying how mem_hotplug_lock is to be used,
I noticed that there are two places where we can end up calling
device_online()/device_offline() - online_pages()/offline_pages() without
the mem_hotplug_lock. And there are other places where we call
device_online()/device_offline() without the device_hotplug_lock.
While e.g.
echo "online" > /sys/devices/system/memory/memory9/state
is fine, e.g.
echo 1 > /sys/devices/system/memory/memory9/online
Will not take the mem_hotplug_lock. However the device_lock() and
E.g. via memory_probe_store(), we can end up calling
add_memory()->online_pages() without the device_hotplug_lock. So we can
have concurrent callers in online_pages(). We e.g. touch in
online_pages() basically unprotected zone->present_pages then.
Looks like there is a longer history to that (see Patch #2 for details),
and fixing it to work the way it was intended is not really possible. We
would e.g. have to take the mem_hotplug_lock in device/base/core.c, which
sounds wrong.
Summary: We had a lock inversion on mem_hotplug_lock and device_lock().
More details can be found in patch 3 and patch 6.
I propose the general rules (documentation added in patch 6):
1. add_memory/add_memory_resource() must only be called with
2. remove_memory() must only be called with device_hotplug_lock. This is
already documented and holds for all callers.
3. device_online()/device_offline() must only be called with
device_hotplug_lock. This is already documented and true for now in core
code. Other callers (related to memory hotplug) have to be fixed up.
4. mem_hotplug_lock is taken inside of add_memory/remove_memory/
online_pages/offline_pages.
To me, this looks way cleaner than what we have right now (and easier to
verify). And looking at the documentation of remove_memory, using
lock_device_hotplug also for add_memory() feels natural.
This patch (of 6):
remove_memory() is exported right now but requires the
device_hotplug_lock, which is not exported. So let's provide a variant
that takes the lock and only export that one.
The lock is already held in
Apart from that, there are not other users in the tree.
Link: http://lkml.kernel.org/r/20180925091457.28651-2-david@redhat.com
Cc: Rashmica Gupta <rashmica.g@gmail.com>
Move remaining definitions and declarations from include/linux/bootmem.h
into include/linux/memblock.h and remove the redundant header.
The includes were replaced with the semantic patch below and then
semi-automated removal of duplicated '#include <linux/memblock.h>
- #include <linux/bootmem.h>
+ #include <linux/memblock.h>
[sfr@canb.auug.org.au: dma-direct: fix up for the removal of linux/bootmem.h]
Link: http://lkml.kernel.org/r/20181002185342.133d1680@canb.auug.org.au
[sfr@canb.auug.org.au: powerpc: fix up for removal of linux/bootmem.h]
Link: http://lkml.kernel.org/r/20181005161406.73ef8727@canb.auug.org.au
[sfr@canb.auug.org.au: x86/kaslr, ACPI/NUMA: fix for linux/bootmem.h removal]
Link: http://lkml.kernel.org/r/20181008190341.5e396491@canb.auug.org.au
Link: http://lkml.kernel.org/r/1536927045-23536-30-git-send-email-rppt@linux.vnet.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Greentime Hu <green.hu@gmail.com>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Palmer Dabbelt <palmer@sifive.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: Rich Felker <dalias@libc.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Serge Semin <fancer.lancer@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
This is necessary to avoid compilation issues on non x86 systems (where the
asm/iosf_mbi.h header is not available) and on x86 systems in case IOSF_MBI
support is not enabled there.
Note that the AXP288 PMIC is connected through the LPSS i2c controller, so
either we have IOSF_MBI support selected through the X86_INTEL_LPSS option,
or we have a kernel where the OpRegion will never work anyways.
intel_xpower_pmic_update_power() does a read-modify-write of the output
control register. The i2c-designware code blocks the P-Unit I2C access
during the read and write by taking the P-Unit's PMIC bus semaphore.
But between the read and the write that semaphore is released and the
P-Unit could make changes to the register which we then end up overwriting.
This commit makes intel_xpower_pmic_update_power() take the semaphore
itself so that it is held over the entire read-modify-write, avoiding this
race.
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- Fix ASPM link_state teardown on removal (Lukas Wunner)
- Fix misleading _OSC ASPM message (Sinan Kaya)
- Make _OSC optional for PCI (Sinan Kaya)
- Don't initialize ASPM link state when ACPI_FADT_NO_ASPM is set
(Patrick Talbert)
- Remove x86 and arm64 node-local allocation for host bridge structures
(Punit Agrawal)
- Pay attention to device-specific _PXM node values (Jonathan Cameron)
- Support new Immediate Readiness bit (Felipe Balbi)
- Differentiate between pciehp surprise and safe removal (Lukas Wunner)
- Remove unnecessary pciehp includes (Lukas Wunner)
- Drop pciehp hotplug_slot_ops wrappers (Lukas Wunner)
- Tolerate PCIe Slot Presence Detect being hardwired to zero to
workaround broken hardware, e.g., the Wilocity switch/wireless device
(Lukas Wunner)
- Unify pciehp controller & slot structs (Lukas Wunner)
- Constify hotplug_slot_ops (Lukas Wunner)
- Drop hotplug_slot_info (Lukas Wunner)
- Embed hotplug_slot struct into users instead of allocating it
separately (Lukas Wunner)
- Initialize PCIe port service drivers directly instead of relying on
initcall ordering (Keith Busch)
- Restore PCI config state after a slot reset (Keith Busch)
- Save/restore DPC config state along with other PCI config state
(Keith Busch)
- Reference count devices during AER handling to avoid race issue with
concurrent hot removal (Keith Busch)
- If an Upstream Port reports ERR_FATAL, don't try to read the Port's
config space because it is probably unreachable (Keith Busch)
- During error handling, use slot-specific reset instead of secondary
bus reset to avoid link up/down issues on hotplug ports (Keith Busch)
- Restore previous AER/DPC handling that does not remove and
re-enumerate devices on ERR_FATAL (Keith Busch)
- Notify all drivers that may be affected by error recovery resets
(Keith Busch)
- Always generate error recovery uevents, even if a driver doesn't have
error callbacks (Keith Busch)
- Make PCIe link active reporting detection generic (Keith Busch)
- Support D3cold in PCIe hierarchies during system sleep and runtime,
including hotplug and Thunderbolt ports (Mika Westerberg)
- Handle hpmemsize/hpiosize kernel parameters uniformly, whether slots
are empty or occupied (Jon Derrick)
- Remove duplicated include from pci/pcie/err.c and unused variable
from cpqphp (YueHaibing)
- Remove driver pci_cleanup_aer_uncorrect_error_status() calls (Oza
Pawandeep)
- Uninline PCI bus accessors for better ftracing (Keith Busch)
- Remove unused AER Root Port .error_resume method (Keith Busch)
- Use kfifo in AER instead of a local version (Keith Busch)
- Use threaded IRQ in AER bottom half (Keith Busch)
- Use managed resources in AER core (Keith Busch)
- Reuse pcie_port_find_device() for AER injection (Keith Busch)
- Abstract AER interrupt handling to disconnect error injection (Keith
Busch)
- Refactor AER injection callbacks to simplify future improvments
(Keith Busch)
- Remove unused Netronome NFP32xx Device IDs (Jakub Kicinski)
- Use bitmap_zalloc() for dma_alias_mask (Andy Shevchenko)
- Add switch fall-through annotations (Gustavo A. R. Silva)
- Remove unused Switchtec quirk variable (Joshua Abraham)
- Fix pci.c kernel-doc warning (Randy Dunlap)
- Remove trivial PCI wrappers for DMA APIs (Christoph Hellwig)
- Add Intel GPU device IDs to spurious interrupt quirk (Bin Meng)
- Run Switchtec DMA aliasing quirk only on NTB endpoints to avoid
useless dmesg errors (Logan Gunthorpe)
- Update Switchtec NTB documentation (Wesley Yung)
- Remove redundant "default n" from Kconfig (Bartlomiej Zolnierkiewicz)
- Avoid panic when drivers enable MSI/MSI-X twice (Tonghao Zhang)
- Add PCI support for peer-to-peer DMA (Logan Gunthorpe)
- Add sysfs group for PCI peer-to-peer memory statistics (Logan
Gunthorpe)
- Add PCI peer-to-peer DMA scatterlist mapping interface (Logan
Gunthorpe)
- Add PCI configfs/sysfs helpers for use by peer-to-peer users (Logan
Gunthorpe)
- Add PCI peer-to-peer DMA driver writer's documentation (Logan
Gunthorpe)
- Add block layer flag to indicate driver support for PCI peer-to-peer
- Map Infiniband scatterlists for peer-to-peer DMA if they contain P2P
memory (Logan Gunthorpe)
- Register nvme-pci CMB buffer as PCI peer-to-peer memory (Logan
Gunthorpe)
- Add nvme-pci support for PCI peer-to-peer memory in requests (Logan
Gunthorpe)
- Use PCI peer-to-peer memory in nvme (Stephen Bates, Steve Wise,
Christoph Hellwig, Logan Gunthorpe)
- Cache VF config space size to optimize enumeration of many VFs
(KarimAllah Ahmed)
- Remove unnecessary <linux/pci-ats.h> include (Bjorn Helgaas)
- Fix VMD AERSID quirk Device ID matching (Jon Derrick)
- Fix Cadence PHY handling during probe (Alan Douglas)
- Signal Cadence Endpoint interrupts via AXI region 0 instead of last
region (Alan Douglas)
- Write Cadence Endpoint MSI interrupts with 32 bits of data (Alan
Douglas)
- Remove redundant controller tests for "device_type == pci" (Rob
Herring)
- Document R-Car E3 (R8A77990) bindings (Tho Vu)
- Add device tree support for R-Car r8a7744 (Biju Das)
- Drop unused mvebu PCIe capability code (Thomas Petazzoni)
- Add shared PCI bridge emulation code (Thomas Petazzoni)
- Convert mvebu to use shared PCI bridge emulation (Thomas Petazzoni)
- Add aardvark Root Port emulation (Thomas Petazzoni)
- Support 100MHz/200MHz refclocks for i.MX6 (Lucas Stach)
- Add initial power management for i.MX7 (Leonard Crestez)
- Add PME_Turn_Off support for i.MX7 (Leonard Crestez)
- Fix qcom runtime power management error handling (Bjorn Andersson)
- Update TI dra7xx unaligned access errata workaround for host mode as
well as endpoint mode (Vignesh R)
- Fix kirin section mismatch warning (Nathan Chancellor)
- Remove iproc PAXC slot check to allow VF support (Jitendra Bhivare)
- Quirk Keystone K2G to limit MRRS to 256 (Kishon Vijay Abraham I)
- Update Keystone to use MRRS quirk for host bridge instead of open
coding (Kishon Vijay Abraham I)
- Refactor Keystone link establishment (Kishon Vijay Abraham I)
- Simplify and speed up Keystone link training (Kishon Vijay Abraham I)
- Remove unused Keystone host_init argument (Kishon Vijay Abraham I)
- Merge Keystone driver files into one (Kishon Vijay Abraham I)
- Remove redundant Keystone platform_set_drvdata() (Kishon Vijay
Abraham I)
- Rename Keystone functions for uniformity (Kishon Vijay Abraham I)
- Add Keystone device control module DT binding (Kishon Vijay Abraham
I)
- Use SYSCON API to get Keystone control module device IDs (Kishon
Vijay Abraham I)
- Clean up Keystone PHY handling (Kishon Vijay Abraham I)
- Use runtime PM APIs to enable Keystone clock (Kishon Vijay Abraham I)
- Clean up Keystone config space access checks (Kishon Vijay Abraham I)
- Get Keystone outbound window count from DT (Kishon Vijay Abraham I)
- Clean up Keystone outbound window configuration (Kishon Vijay Abraham
I)
- Clean up Keystone DBI setup (Kishon Vijay Abraham I)
- Clean up Keystone ks_pcie_link_up() (Kishon Vijay Abraham I)
- Fix Keystone IRQ status checking (Kishon Vijay Abraham I)
- Add debug messages for all Keystone errors (Kishon Vijay Abraham I)
- Clean up Keystone includes and macros (Kishon Vijay Abraham I)
- Fix Mediatek unchecked return value from devm_pci_remap_iospace()
- Fix Mediatek endpoint/port matching logic (Honghui Zhang)
- Change Mediatek Root Port Class Code to PCI_CLASS_BRIDGE_PCI (Honghui
Zhang)
- Remove redundant Mediatek PM domain check (Honghui Zhang)
- Convert Mediatek to pci_host_probe() (Honghui Zhang)
- Fix Mediatek MSI enablement (Honghui Zhang)
- Add Mediatek system PM support for MT2712 and MT7622 (Honghui Zhang)
- Add Mediatek loadable module support (Honghui Zhang)
- Detach VMD resources after stopping root bus to prevent orphan
resources (Jon Derrick)
- Convert pcitest build process to that used by other tools (iio, perf,
etc) (Gustavo Pimentel)
* tag 'pci-v4.20-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (140 commits)
PCI/AER: Refactor error injection fallbacks
PCI/AER: Abstract AER interrupt handling
PCI/AER: Reuse existing pcie_port_find_device() interface
PCI/AER: Use managed resource allocations
PCI: pcie: Remove redundant 'default n' from Kconfig
PCI: aardvark: Implement emulated root PCI bridge config space
PCI: mvebu: Convert to PCI emulated bridge config space
PCI: mvebu: Drop unused PCI express capability code
PCI: Introduce PCI bridge emulated config space common logic
PCI: vmd: Detach resources after stopping root bus
nvmet: Optionally use PCI P2P memory
nvmet: Introduce helper functions to allocate and free request SGLs
nvme-pci: Add support for P2P memory in requests
nvme-pci: Use PCI p2pmem subsystem to manage the CMB
IB/core: Ensure we map P2P memory correctly in rdma_rw_ctx_[init|destroy]()
block: Add PCI P2P flag for request queue
PCI/P2PDMA: Add P2P DMA driver writer's documentation
docs-rst: Add a new directory for PCI documentation
PCI/P2PDMA: Introduce configfs/sysfs enable attribute helpers
PCI/P2PDMA: Add PCI p2pmem DMA mappings to adjust the bus offset
Pull EDAC updates from Borislav Petkov:
"The EDAC tree was busier than usual this cycle as the shortlog below
shows.
Also, this pull request is carrying an ACPI DSM driver which is used
to ask the platform to supply the DIMM location of a reported hardware
error and thus simplify all the EDAC logic when trying to map the
error address to the respective DIMM.
Core EDAC updates:
- amd64_edac: AMD family 0x17, models 0x10-0x2f support (Michael Jin)
Hygon Dhyana support (Pu Wen)
- sb_edac: New maintainer + fixes (Tony Luck) Error reporting
improvements and fixes (Qiuxu Zhuo)
- ghes_edac: SMBIOS handle type 17 for DIMM locating and per-DIMM
error accounting (Fan Wu)
- altera_edac: Stratix10 support and refactoring (Thor Thayer)
Out of tree addition:
- acpi_adxl: Address Translation interface using an ACPI DSM (Tony
Luck)
- the usual amount of other misc fixes and cleanups all over"
* tag 'edac_for_4.20' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: (22 commits)
ACPI/ADXL: Add address translation interface using an ACPI DSM
EDAC, thunderx: Fix memory leak in thunderx_l2c_threaded_isr()
EDAC, skx_edac: Fix logical channel intermediate decoding
EDAC, {i7core,sb,skx}_edac: Fix uncorrected error counting
EDAC, altera: Work around int-to-pointer-cast warnings
EDAC, amd64: Add Hygon Dhyana support
EDAC: Raise the maximum number of memory controllers
arm64: dts: stratix10: Add peripheral EDAC nodes
EDAC, altera: Add Stratix10 peripheral support
EDAC, altera: Merge Stratix10 into the Arria10 SDRAM probe routine
arm64: dts: stratix10: Add SDRAM node
EDAC, altera: Combine Stratix10 and Arria10 probe functions
arm64: dts: stratix10: Additions to EDAC System Manager
EDAC, i7core: Remove set but not used variable pvt
EDAC, ghes: Use CPER module handles to locate DIMMs
EDAC: Correct DIMM capacity unit symbol
EDAC, sb_edac: Fix signedness bugs in *_get_ha() functions
EDAC, sb_edac: Fix reporting for patrol scrubber errors
EDAC, sb_edac: Return early on ADDRV bit and address type test
MAINTAINERS: Update maintainer for drivers/edac/sb_edac.c
Pull libnvdimm updates from Dan Williams:
- Improve the efficiency and performance of reading nvdimm-namespace
labels. Reduce the amount of label data read at driver load time by a
few orders of magnitude. Reduce heavyweight call-outs to
platform-firmware routines.
- Handle media errors located in the 'struct page' array stored on a
persistent memory namespace. Let the kernel clear these errors rather
than an awkward userspace workaround.
- Fix Address Range Scrub (ARS) completion tracking. Correct occasions
where the kernel indicates completion of ARS before submission.
- Fix asynchronous device registration reference counting.
- Add support for reporting an nvdimm dirty-shutdown-count via sysfs.
- Fix various small libnvdimm core and uapi issues.
* tag 'libnvdimm-for-4.20' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (21 commits)
UAPI: ndctl: Remove use of PAGE_SIZE
UAPI: ndctl: Fix g++-unsupported initialisation in headers
tools/testing/nvdimm: Populate dirty shutdown data
acpi, nfit: Collect shutdown status
acpi, nfit: Introduce nfit_mem flags
libnvdimm, label: Fix sparse warning
nvdimm: Use namespace index data to reduce number of label reads needed
nvdimm: Split label init out from the logic for getting config data
nvdimm: Remove empty if statement
nvdimm: Clarify comment in sizeof_namespace_index
nvdimm: Sanity check labeloff
libnvdimm, dimm: Maximize label transfer size
libnvdimm, pmem: Fix badblocks population for 'raw' namespaces
libnvdimm, namespace: Drop the repeat assignment for variable dev->parent
libnvdimm, region: Fail badblocks listing for inactive regions
libnvdimm, pfn: during init, clear errors in the metadata area
libnvdimm: Set device node in nd_device_register
libnvdimm: Hold reference on parent while scheduling async init
Pull x86 cpu updates from Ingo Molnar:
"The main changes in this cycle were:
- Add support for the "Dhyana" x86 CPUs by Hygon: these are licensed
based on the AMD Zen architecture, and are built and sold in China,
for domestic datacenter use. The code is pretty close to AMD
support, mostly with a few quirks and enumeration differences. (Pu
Wen)
- Enable CPUID support on Cyrix 6x86/6x86L processors"
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tools/cpupower: Add Hygon Dhyana support
cpufreq: Add Hygon Dhyana support
ACPI: Add Hygon Dhyana support
x86/xen: Add Hygon Dhyana support to Xen
x86/kvm: Add Hygon Dhyana support to KVM
x86/mce: Add Hygon Dhyana support to the MCA infrastructure
x86/bugs: Add Hygon Dhyana to the respective mitigation machinery
x86/apic: Add Hygon Dhyana support
x86/pci, x86/amd_nb: Add Hygon Dhyana support to PCI and northbridge
x86/amd_nb: Check vendor in AMD-only functions
x86/alternative: Init ideal_nops for Hygon Dhyana
x86/events: Add Hygon Dhyana support to PMU infrastructure
x86/smpboot: Do not use BSP INIT delay and MWAIT to idle on Dhyana
x86/cpu/mtrr: Support TOP_MEM2 and get MTRR number
x86/cpu: Get cache info and setup cache cpumap for Hygon Dhyana
x86/cpu: Create Hygon Dhyana architecture support file
x86/CPU: Change query logic so CPUID is enabled before testing
x86/CPU: Use correct macros for Cyrix calls
Pull perf updates from Ingo Molnar:
"The main updates in this cycle were:
- Lots of perf tooling changes too voluminous to list (big perf trace
and perf stat improvements, lots of libtraceevent reorganization,
etc.), so I'll list the authors and refer to the changelog for
details:
Benjamin Peterson, Jérémie Galarneau, Kim Phillips, Peter
Zijlstra, Ravi Bangoria, Sangwon Hong, Sean V Kelley, Steven
Rostedt, Thomas Gleixner, Ding Xiang, Eduardo Habkost, Thomas
Richter, Andi Kleen, Sanskriti Sharma, Adrian Hunter, Tzvetomir
Stoyanov, Arnaldo Carvalho de Melo, Jiri Olsa.
... with the bulk of the changes written by Jiri Olsa, Tzvetomir
Stoyanov and Arnaldo Carvalho de Melo.
- Continued intel_rdt work with a focus on playing well with perf
events. This also imported some non-perf RDT work due to
dependencies. (Reinette Chatre)
- Implement counter freezing for Arch Perfmon v4 (Skylake and newer).
This allows to speed up the PMI handler by avoiding unnecessary MSR
writes and make it more accurate. (Andi Kleen)
- kprobes cleanups and simplification (Masami Hiramatsu)
- Intel Goldmont PMU updates (Kan Liang)
- ... plus misc other fixes and updates"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (155 commits)
kprobes/x86: Use preempt_enable() in optimized_callback()
x86/intel_rdt: Prevent pseudo-locking from using stale pointers
kprobes, x86/ptrace.h: Make regs_get_kernel_stack_nth() not fault on bad stack
perf/x86/intel: Export mem events only if there's PEBS support
x86/cpu: Drop pointless static qualifier in punit_dev_state_show()
x86/intel_rdt: Fix initial allocation to consider CDP
x86/intel_rdt: CBM overlap should also check for overlap with CDP peer
x86/intel_rdt: Introduce utility to obtain CDP peer
tools lib traceevent, perf tools: Move struct tep_handler definition in a local header file
tools lib traceevent: Separate out tep_strerror() for strerror_r() issues
perf python: More portable way to make CFLAGS work with clang
perf python: Make clang_has_option() work on Python 3
perf tools: Free temporary 'sys' string in read_event_files()
perf tools: Avoid double free in read_event_file()
perf tools: Free 'printk' string in parse_ftrace_printk()
perf tools: Cleanup trace-event-info 'tdata' leak
perf strbuf: Match va_{add,copy} with va_end
perf test: S390 does not support watchpoints in test 22
perf auxtrace: Include missing asm/bitsperlong.h to get BITS_PER_LONG
tools include: Adopt linux/bits.h
Pull ACPI updates from Rafael Wysocki:
"These fix ACPICA issues related to the handling of module-level AML,
fix an ordering issue during ACPI initialization, update ACPICA to
upstream revision 20181003 (including fixes mostly), fix issues with
system-wide suspend/resume related to the ACPI driver for Intel SoCs
(LPSS), fix device enumeration issues on boards with Dollar Cove or
Whiskey Cove Intel PMICs, prevent ACPICA from calling ktime_get() in
unsuitable conditions, update a few drivers and clean up some code in
several places.
Specifics:
- Fix ACPICA issues related to the handling of module-level AML and
make the ACPI initialization code parse ECDT before loading the
definition block tables (Erik Schmauss).
- Update ACPICA to upstream revision 20181003 including fixes related
to the ill-defined "generic serial bus" and the handling of the
_REG object (Bob Moore).
- Fix some issues with system-wide suspend/resume on Intel BYT/CHT
related to the handling of I2C controllers in the ACPI LPSS driver
for Intel SoCs (Hans de Goede).
- Modify the ACPI namespace scanning code to enumerate INT33FE HID
devices as platform devices with I2C resources to avoid device
enumeration problems on boards with Dollar Cove or Whiskey Cove
Intel PMICs (Hans de Goede).
- Prevent ACPICA from using ktime_get() during early resume from
system-wide suspend before resuming the timekeeping which generally
is unsafe and triggers a warning from the timekeeping code (Bart
Van Assche).
- Add low-level real time clock support to the ACPI Time and Aalarm
Device (TAD) driver (Rafael Wysocki).
- Fix the ACPI SBS driver to avoid GPE storms on MacBook Pro and
Oopses when removing modules (Ronald Tschalär).
- Fix the ACPI PPTT parsing code to handle architecturally unknown
cache types properly (Jeffrey Hugo).
- Fix initialization issue in the ACPI processor driver (Dou Liyang).
- Clean up the code in several places (Andy Shevchenko, Bartlomiej
Zolnierkiewicz, David Arcari, zhong jiang)"
* tag 'acpi-4.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (33 commits)
ACPI / scan: Create platform device for INT33FE ACPI nodes
ACPI / OSL: Use 'jiffies' as the time bassis for acpi_os_get_timer()
ACPI: probe ECDT before loading AML tables regardless of module-level code flag
ACPICA: Remove acpi_gbl_group_module_level_code and only use acpi_gbl_execute_tables_as_methods instead
ACPICA: AML Parser: fix parse loop to correctly skip erroneous extended opcodes
ACPICA: AML interpreter: add region addresses in global list during initialization
ACPI: TAD: Add low-level support for real time capability
ACPI: remove redundant 'default n' from Kconfig
ACPI / SBS: Fix rare oops when removing modules
ACPI / SBS: Fix GPE storm on recent MacBookPro's
ACPI/PPTT: Handle architecturally unknown cache types
drivers: base: cacheinfo: Do not populate sysfs for unknown cache types
ACPICA: Update version to 20181003
ACPICA: Never run _REG on system_memory and system_IO
ACPICA: Split large interpreter file
ACPICA: Rename some of the Field Attribute defines
ACPICA: Update for generic_serial_bus and attrib_raw_process_bytes protocol
ACPI / processor: Fix the return value of acpi_processor_ids_walk()
ACPI / LPSS: Resume BYT/CHT I2C controllers from resume_noirq
Pull power management updates from Rafael Wysocki:
"These make hibernation on 32-bit x86 systems work in all of the cases
in which it works on 64-bit x86 ones, update the menu cpuidle governor
and the "polling" state to make them more efficient, add more hardware
support to cpufreq drivers and fix issues with some of them, fix a bug
in the conservative cpufreq governor, fix the operating performance
points (OPP) framework and make it more stable, update the devfreq
subsystem to take changes in the APIs used by into account and clean
up some things all over.
Specifics:
- Backport hibernation bug fixes from x86-64 to x86-32 and
consolidate hibernation handling on x86 to allow 32-bit systems to
work in all of the cases in which 64-bit ones work (Zhimin Gu, Chen
Yu).
- Fix hibernation documentation (Vladimir D. Seleznev).
- Update the menu cpuidle governor to fix a couple of issues with it,
make it more efficient in some cases and clean it up (Rafael
Wysocki).
- Rework the cpuidle polling state implementation to make it more
efficient (Rafael Wysocki).
- Clean up the cpuidle core somewhat (Fieah Lim).
- Fix the cpufreq conservative governor to take policy limits into
account properly in some cases (Rafael Wysocki).
- Add support for retrieving guaranteed performance information to
the ACPI CPPC library and make the intel_pstate driver use it to
expose the CPU base frequency via sysfs on systems with the
hardware-managed P-states (HWP) feature enabled (Srinivas
Pandruvada).
- Fix clang warning in the CPPC cpufreq driver (Nathan Chancellor).
- Get rid of device_node.name printing from cpufreq (Rob Herring).
- Remove unnecessary unlikely() from the cpufreq core (Igor Stoppa).
- Add support for the r8a7744 SoC to the cpufreq-dt driver (Biju
Das).
- Update the dt-platdev cpufreq driver to allow RK3399 to have
separate tunables per cluster (Dmitry Torokhov).
- Fix the dma_alloc_coherent() usage in the tegra186 cpufreq driver
(Christoph Hellwig).
- Make the imx6q cpufreq driver read OCOTP through nvmem for
imx6ul/imx6ull (Anson Huang).
- Fix several bugs in the operating performance points (OPP)
framework and make it more stable (Viresh Kumar, Dave Gerlach).
- Update the devfreq subsystem to take changes in the APIs used by
into account, fix some issues with it and make it stop print
device_node.name directly (Bjorn Andersson, Enric Balletbo i Serra,
Matthias Kaehlcke, Rob Herring, Vincent Donnefort, zhong jiang).
- Prepare the generic power domains (genpd) framework for dealing
with domains containing CPUs (Ulf Hansson).
- Prevent sysfs attributes representing low-power S0 residency
counters from being exposed if low-power S0 support is not
indicated in ACPI FADT (Rajneesh Bhardwaj).
- Get rid of custom CPU features macros for Intel CPUs from the
intel_idle and RAPL drivers (Andy Shevchenko).
- Update the tasks freezer to list tasks that refused to freeze and
caused a system transition to a sleep state to be aborted (Todd
Brandt).
- Update the pm-graph set of tools to v5.2 (Todd Brandt).
- Fix some issues in the cpupower utility (Anders Roxell, Prarit
Bhargava)"
* tag 'pm-4.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (73 commits)
PM / Domains: Document flags for genpd
PM / Domains: Deal with multiple states but no governor in genpd
PM / Domains: Don't treat zero found compatible idle states as an error
cpuidle: menu: Avoid computations when result will be discarded
cpuidle: menu: Drop redundant comparison
cpufreq: tegra186: don't pass GFP_DMA32 to dma_alloc_coherent()
cpufreq: conservative: Take limits changes into account properly
Documentation: intel_pstate: Add base_frequency information
cpufreq: intel_pstate: Add base_frequency attribute
ACPI / CPPC: Add support for guaranteed performance
cpuidle: menu: Simplify checks related to the polling state
PM / tools: sleepgraph and bootgraph: upgrade to v5.2
PM / tools: sleepgraph: first batch of v5.2 changes
cpupower: Fix coredump on VMWare
cpupower: Fix AMD Family 0x17 msr_pstate size
cpufreq: imx6q: read OCOTP through nvmem for imx6ul/imx6ull
cpufreq: dt-platdev: allow RK3399 to have separate tunables per cluster
cpuidle: poll_state: Revise loop termination condition
cpuidle: menu: Move the latency_req == 0 special case check
cpuidle: menu: Avoid computations for very close timers
Pull IPMI updates from Corey Minyard:
"Lots of small changes to the IPMI driver. Most of the changes are
logging cleanup and style fixes. There are a few smaller bug fixes"
* tag 'for-linus-4.20' of https://github.com/cminyard/linux-ipmi: (21 commits)
ipmi: Fix timer race with module unload
ipmi:ssif: Add support for multi-part transmit messages > 2 parts
MAINTAINERS: Add file patterns for ipmi device tree bindings
ipmi: Remove platform driver overrides and use the id_table
ipmi: Free the address list on module cleanup
ipmi: Don't leave holes in the I2C address list in the ssif driver
ipmi: fix return value of ipmi_set_my_LUN
ipmi: Convert pr_xxx() to dev_xxx() in the BT code
ipmi:dmi: Ignore IPMI SMBIOS entries with a zero base address
ipmi:dmi: Use pr_fmt in the IPMI DMI code
ipmi: Change to ktime_get_ts64()
ipmi_si: fix potential integer overflow on large shift
ipmi_si_pci: fix NULL device in ipmi_si error message
ipmi: Convert printk(KERN_<level> to pr_<level>(
ipmi: Use more common logging styles
ipmi: msghandler: Add and use pr_fmt and dev_fmt, remove PFX
pci:ipmi: Move IPMI PCI class id defines to pci_ids.h
ipmi: Finally get rid of ipmi_user_t and ipmi_smi_t
ipmi:powernv: Convert ipmi_smi_t to struct ipmi_smi
hwmon:ibm: Change ipmi_user_t to struct ipmi_user *
(Lukas Wunner)
- Save/restore DPC config state along with other PCI config state (Keith
Busch)
- Restore previous AER/DPC handling that does not remove and re-enumerate
- Notify all drivers that may be affected by error recovery resets (Keith
Busch)
- Remove duplicated include from pci/pcie/err.c and unused variable from
cpqphp (YueHaibing)
Pawandeep)
Busch)
- Refactor AER injection callbacks to simplify future improvments (Keith
Busch)
* pci/hotplug:
PCI/AER: Use threaded IRQ for bottom half
PCI/AER: Use kfifo_in_spinlocked() to insert locked elements
PCI/AER: Use kfifo for tracking events instead of reimplementing it
PCI/AER: Remove error source from AER struct aer_rpc
PCI/AER: Remove unused aer_error_resume()
PCI: Uninline PCI bus accessors for better ftracing
PCI/AER: Remove pci_cleanup_aer_uncorrect_error_status() calls
PCI: pnv_php: Use kmemdup()
PCI: cpqphp: Remove set but not used variable 'physical_slot'
PCI/ERR: Remove duplicated include from err.c
PCI: Equalize hotplug memory and io for occupied and empty slots
PCI / ACPI: Whitelist D3 for more PCIe hotplug ports
ACPI / property: Allow multiple property compatible _DSD entries
PCI/PME: Implement runtime PM callbacks
PCI: pciehp: Implement runtime PM callbacks
PCI/portdrv: Add runtime PM hooks for port service drivers
PCI/portdrv: Resume upon exit from system suspend if left runtime suspended
PCI: pciehp: Do not handle events if interrupts are masked
PCI: pciehp: Disable hotplug interrupt during suspend
PCI / ACPI: Enable wake automatically for power managed bridges
PCI: Do not skip power-managed bridges in pci_enable_wake()
PCI: Make link active reporting detection generic
PCI: Unify device inaccessible
PCI/ERR: Always report current recovery status for udev
PCI/ERR: Simplify broadcast callouts
PCI/ERR: Run error recovery callbacks for all affected devices
PCI/ERR: Handle fatal error recovery
PCI/ERR: Use slot reset if available
PCI/AER: Don't read upstream ports below fatal errors
PCI/AER: Take reference on error devices
PCI/DPC: Save and restore config state
PCI: portdrv: Restore PCI config state on slot reset
PCI: portdrv: Initialize service drivers directly
PCI: hotplug: Document TODOs
PCI: hotplug: Embed hotplug_slot
PCI: hotplug: Drop hotplug_slot_info
PCI: hotplug: Constify hotplug_slot_ops
PCI: pciehp: Reshuffle controller struct for clarity
PCI: pciehp: Rename controller struct members for clarity
PCI: pciehp: Unify controller and slot structs
PCI: pciehp: Tolerate Presence Detect hardwired to zero
PCI: pciehp: Drop hotplug_slot_ops wrappers
PCI: pciehp: Drop unnecessary includes
PCI: pciehp: Differentiate between surprise and safe removal
PCI: Simplify disconnected marking
* acpi-property:
ACPI / property: Switch to bitmap_zalloc()
* acpi-sbs:
'acpi-tad'
* acpi-soc:
ACPI / LPSS: Add a device link from the GPU to the BYT I2C5 controller
ACPI / LPSS: Add a device link from the GPU to the CHT I2C7 controller
ACPI / LPSS: Make acpi_lpss_find_device() also find PCI devices
ACPI / LPSS: Make hid_uid_match helper accept a NULL uid argument
ACPI / LPSS: Make hid_uid_match helper take an acpi_device as first argument
ACPI / LPSS: Exclude I2C busses shared with PUNIT from pmc_atom_d3_mask
ACPI / LPSS: Add alternative ACPI HIDs for Cherry Trail DMA controllers
* acpi-processor:
* acpi-pmic:
ACPI / PMIC: Convert drivers to use SPDX identifier
ACPI / PMIC: Sort headers alphabetically
* acpi-cppc:
mailbox: PCC: handle parse error
* acpi-tad:
'acpi-misc'
* acpi-init:
* acpi-osl:
* acpi-bus:
ACPI / glue: Split dev_is_platform() out of module for wide use
* acpi-tables:
* acpi-misc:
ACPI: custom_method: remove meaningless null check before debugfs_remove()
* acpi-pm:
ACPI / PM: LPIT: Register sysfs attributes based on FADT
* pm-sleep:
x86-32, hibernate: Adjust in_suspend after resumed on 32bit system
x86-32, hibernate: Set up temporary text mapping for 32bit system
x86-32, hibernate: Switch to relocated restore code during resume on 32bit system
x86-32, hibernate: Switch to original page table after resumed
x86-32, hibernate: Use the page size macro instead of constant value
x86-32, hibernate: Use temp_pgt as the temporary page table
x86, hibernate: Rename temp_level4_pgt to temp_pgt
x86-32, hibernate: Enable CONFIG_ARCH_HIBERNATION_HEADER on 32bit system
x86, hibernate: Extract the common code of 64/32 bit system
x86-32/asm/power: Create stack frames in hibernate_asm_32.S
PM / hibernate: Check the success of generating md5 digest before hibernation
x86, hibernate: Fix nosave_regions setup for hibernation
PM / sleep: Show freezing tasks that caused a suspend abort
PM / hibernate: Documentation: fix image_size default value
* acpica:
Bay and Cherry Trail devices with a Dollar Cove or Whiskey Cove PMIC
have an ACPI node with a HID of INT33FE which is a "virtual" battery
device implementing a standard ACPI battery interface which depends upon
a proprietary, undocument OpRegion called BMOP. Since we do have docs
for the actual fuel-gauges used on these boards we instead use native
fuel-gauge drivers talking directly to the fuel-gauge ICs on boards which
rely on this INT33FE device for their battery monitoring.
On boards with a Dollar Cove PMIC the INT33FE device's resources (_CRS)
describe a non-existing I2C client at address 0x6b with a bus-speed of
100KHz. This is a problem on some boards since there are actual devices
on that same bus which need a speed of 400KHz to function properly.
This commit adds the INT33FE HID to the list of devices with I2C resources
which should be enumerated as a platform-device rather then letting the
i2c-core instantiate an i2c-client matching the first I2C resource,
so that its bus-speed will not influence the max speed of the I2C bus.
This fixes e.g. the touchscreen not working on the Teclast X98 II Plus.
The INT33FE device on boards with a Whiskey Cove PMIC is somewhat special.
Its first I2C resource is for a secondary I2C address of the PMIC itself,
which is already described in an ACPI device with an INT34D3 HID.
But it has 3 more I2C resources describing 3 other chips for which we do
need to instantiate I2C clients and which need device-connections added
between them for things to work properly. This special case is handled by
the drivers/platform/x86/intel_cht_int33fe.c code.
Before this commit that code was binding to the i2c-client instantiated
for the secondary I2C address of the PMIC, since we now instantiate a
platform device for the INT33FE device instead, this commit also changes
the intel_cht_int33fe driver from an i2c driver to a platform driver.
This also brings the intel_cht_int33fe drv inline with how we instantiate
multiple i2c clients from a single ACPI device in other cases, as done
by the drivers/platform/x86/i2c-multi-instantiate.c code.
Reported-and-tested-by: Alexander Meiler <alex.meiler@protonmail.com>
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Since acpi_os_get_timer() may be called after the timer subsystem has
been suspended, use the jiffies counter instead of ktime_get(). This
patch avoids that the following warning is reported during hibernation:
WARNING: CPU: 0 PID: 612 at kernel/time/timekeeping.c:751 ktime_get+0x116/0x120
RIP: 0010:ktime_get+0x116/0x120
Call Trace:
acpi_os_get_timer+0xe/0x30
acpi_ds_exec_begin_control_op+0x175/0x1de
acpi_ds_exec_begin_op+0x2c7/0x39a
acpi_ps_create_op+0x573/0x5e4
acpi_ps_parse_loop+0x349/0x1220
acpi_ps_parse_aml+0x25b/0x6da
acpi_ps_execute_method+0x327/0x41b
acpi_ns_evaluate+0x4e9/0x6f5
acpi_ut_evaluate_object+0xd9/0x2f2
acpi_rs_get_method_data+0x8f/0x114
acpi_walk_resources+0x122/0x1b6
acpi_pci_link_get_current.isra.2+0x157/0x280
acpi_pci_link_set+0x32f/0x4a0
irqrouter_resume+0x58/0x80
syscore_resume+0x84/0x380
hibernation_snapshot+0x20c/0x4f0
hibernate+0x22d/0x3a6
state_store+0x99/0xa0
kobj_attr_store+0x37/0x50
sysfs_kf_write+0x87/0xa0
kernfs_fop_write+0x1a5/0x240
__vfs_write+0xd2/0x410
vfs_write+0x101/0x250
ksys_write+0xab/0x120
__x64_sys_write+0x43/0x50
do_syscall_64+0x71/0x220
Fixes: 164a08cee135 (ACPICA: Dispatcher: Introduce timeout mechanism for infinite loop detection)
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
References: https://lists.01.org/pipermail/lkp/2018-April/008406.html
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: 4.16+ <stable@vger.kernel.org> # 4.16+
It was discovered that AML tables were loaded before or after the
ECDT depending on acpi_gbl_execute_tables_as_methods. According to
the ACPI spec, the ECDT should be loaded before the namespace is
populated by loading AML tables (DSDT and SSDT). Since the ECDT
should be loaded early in the boot process, this change moves the
ECDT probing to acpi_early_init.
Signed-off-by: Erik Schmauss <erik.schmauss@intel.com>
acpi_gbl_group_module_level_code and acpi_gbl_execute_tables_as_methods were
used to enable different table load behavior. The different table
load behaviors are as follows:
A.) acpi_gbl_group_module_level_code enabled the legacy approach where
ASL if statements are executed after the namespace object has
been loaded.
B.) acpi_gbl_execute_tables_as_methods is currently used to enable the
table load to be a method invocation. This meaning that ASL If
statements are executed in-line rather than deferred until after
the ACPI namespace has been populated. This is the correct
behavior and option A will be removed in the future.
We do not support a table load behavior where these variables are
assigned the same value. In otherwords, we only support option A or B
and do not need acpi_gbl_group_module_level_code to enable A. From now on,
acpi_gbl_execute_tables_as_methods == 0 enables option A and
acpi_gbl_execute_tables_as_methods == 1 enables option B.
Note: option A is expected to be removed in the future and option B
will become the only supported table load behavior.
AML opcodes come in two lengths: 1-byte opcodes and 2-byte, extended opcodes.
If an error occurs due to illegal opcodes during table load, the AML parser
needs to continue loading the table. In order to do this, it needs to skip
parsing of the offending opcode and operands associated with that opcode.
This change fixes the AML parse loop to correctly skip parsing of incorrect
extended opcodes. Previously, only the short opcodes were skipped correctly.
Cc: All applicable <stable@vger.kernel.org>
initialization
The table load process omitted adding the operation region address
range to the global list. This omission is problematic because the OS
queries the global list to check for address range conflicts before
deciding which drivers to load. This commit may result in warning
messages that look like the following:
[ 7.871761] ACPI Warning: system_IO range 0x00000428-0x0000042F conflicts with op_region 0x00000400-0x0000047F (\PMIO) (20180531/utaddress-213)
[ 7.871769] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
However, these messages do not signify regressions. It is a result of
properly adding address ranges within the global address list.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=200011
Tested-by: Jean-Marc Lenoir <archlinux@jihemel.com>
