commit 06a8566bcf5cf7db9843a82cde7a33c7bf3947d9 upstream.
This patch fixes the issues indicated by the test results that
ipmi_msg_handler() is invoked in atomic context.
BUG: scheduling while atomic: kipmi0/18933/0x10000100
Modules linked in: ipmi_si acpi_ipmi ...
CPU: 3 PID: 18933 Comm: kipmi0 Tainted: G AW 3.10.0-rc7+ #2
Hardware name: QCI QSSC-S4R/QSSC-S4R, BIOS QSSC-S4R.QCI.01.00.0027.070120100606 07/01/2010
ffff8838245eea00 ffff88103fc63c98 ffffffff814c4a1e ffff88103fc63ca8
ffffffff814bfbab ffff88103fc63d28 ffffffff814c73e0 ffff88103933cbd4
0000000000000096 ffff88103fc63ce8 ffff88102f618000 ffff881035c01fd8
Call Trace:
<IRQ> [<ffffffff814c4a1e>] dump_stack+0x19/0x1b
[<ffffffff814bfbab>] __schedule_bug+0x46/0x54
[<ffffffff814c73e0>] __schedule+0x83/0x59c
[<ffffffff81058853>] __cond_resched+0x22/0x2d
[<ffffffff814c794b>] _cond_resched+0x14/0x1d
[<ffffffff814c6d82>] mutex_lock+0x11/0x32
[<ffffffff8101e1e9>] ? __default_send_IPI_dest_field.constprop.0+0x53/0x58
[<ffffffffa09e3f9c>] ipmi_msg_handler+0x23/0x166 [ipmi_si]
[<ffffffff812bf6e4>] deliver_response+0x55/0x5a
[<ffffffff812c0fd4>] handle_new_recv_msgs+0xb67/0xc65
[<ffffffff81007ad1>] ? read_tsc+0x9/0x19
[<ffffffff814c8620>] ? _raw_spin_lock_irq+0xa/0xc
[<ffffffffa09e1128>] ipmi_thread+0x5c/0x146 [ipmi_si]
Also Tony Camuso says:
We were getting occasional "Scheduling while atomic" call traces
during boot on some systems. Problem was first seen on a Cisco C210
but we were able to reproduce it on a Cisco c220m3. Setting
CONFIG_LOCKDEP and LOCKDEP_SUPPORT to 'y' exposed a lockdep around
tx_msg_lock in acpi_ipmi.c struct acpi_ipmi_device.
[ INFO: inconsistent lock state ]
2.6.32-415.el6.x86_64-debug-splck #1
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
ksoftirqd/3/17 [HC0[0]:SC1[1]:HE1:SE0] takes:
(&ipmi_device->tx_msg_lock){+.?...}, at: [<ffffffff81337a27>] ipmi_msg_handler+0x71/0x126
{SOFTIRQ-ON-W} state was registered at:
[<ffffffff810ba11c>] __lock_acquire+0x63c/0x1570
[<ffffffff810bb0f4>] lock_acquire+0xa4/0x120
[<ffffffff815581cc>] __mutex_lock_common+0x4c/0x400
[<ffffffff815586ea>] mutex_lock_nested+0x4a/0x60
[<ffffffff8133789d>] acpi_ipmi_space_handler+0x11b/0x234
[<ffffffff81321c62>] acpi_ev_address_space_dispatch+0x170/0x1be
The fix implemented by this change has been tested by Tony:
Tested the patch in a boot loop with lockdep debug enabled and never
saw the problem in over 400 reboots.
Reported-and-tested-by: Tony Camuso <tcamuso@redhat.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Reviewed-by: Huang Ying <ying.huang@intel.com>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
commit 524f42fab787a9510be826ce3d736b56d454ac6d upstream.
The ECDT of ASUSTEK L4R doesn't provide correct command and data
I/O ports. The DSDT provides the correct information instead.
For this reason, add this machine to quirk list for ECDT validation
and use the EC information from the DSDT.
[rjw: Changelog]
References: https://bugzilla.kernel.org/show_bug.cgi?id=60765
Reported-and-tested-by: Daniele Esposti <expo@expobrain.net>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
commit 016d5baad04269e8559332df05f89bd95b52d6ad upstream.
The _BIX method returns extended battery info as a package.
According the ACPI spec (ACPI 5, Section 10.2.2.2), the first member
of that package should be "Revision". However, the current ACPI
battery driver treats the first member as "Power Unit" which should
be the second member. This causes the result of _BIX return data
parsing to be incorrect.
Fix this by adding a new member called 'revision' to struct
acpi_battery and adding the offsetof() information on it to
extended_info_offsets[] as the first row.
[rjw: Changelog]
Reported-and-tested-by: Jan Hoffmann <jan.christian.hoffmann@gmail.com>
References: http://bugzilla.kernel.org/show_bug.cgi?id=60519
commit d19f503e22316a84c39bc19445e0e4fdd49b3532 upstream.
device->driver_data needs to be cleared when releasing its data,
mem_device, in an error path of acpi_memory_device_add().
The function evaluates the _CRS of memory device objects, and fails
when it gets an unexpected resource or cannot allocate memory. A
kernel crash or data corruption may occur when the kernel accesses
the stale pointer.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
commit eff9a4b62b14cf0d9913e3caf1f26f8b7a6105c9 upstream.
HP Folio 13's BIOS defines CMOS RTC Operation Region and the EC's
_REG method will access that region. To allow the CMOS RTC region
handler to be installed before the EC _REG method is first invoked,
add ec_skip_dsdt_scan() as HP Folio 13's callback to ec_dmi_table.
References: https://bugzilla.kernel.org/show_bug.cgi?id=54621
Reported-and-tested-by: Stefan Nagy <public@stefan-nagy.at>
commit 780a6ec640a3fed671fc2c40e4dd30c03eca3ac3 upstream.
This patch addresses kernel bug 56661. BIOS reports an incorrect
backlight value, causing the driver to switch off the backlight
completely during startup. This patch ignores the incorrect value from
BIOS.
References: https://bugzilla.kernel.org/show_bug.cgi?id=56661
Signed-off-by: Ash Willis <ashwillis@programmer.net>
commit fedbe9bc6fd3e14b1ffbb3dac407777ac4a3650c upstream.
On HP m4 lapops, BIOS reports minimum backlight on boot and
causes backlight to dim completely. This ignores the initial backlight
values and set to max brightness.
References: https://bugs.launchpad.net/bugs/1184501
Signed-off-by: Alex Hung <alex.hung@canonical.com>
commit 28fe5c825f8e15744d04c7c1b8df197950923ecd upstream.
The EC driver works abnormally with IBF flag always set.
IBF means "The host has written a byte of data to the command
or data port, but the embedded controller has not yet read it".
If IBF is set in the EC status and not cleared, this will cause
all subsequent EC requests to fail with a timeout error.
Change the EC driver so that it doesn't refuse to restart a
transaction if IBF is set in the status. Also increase the
number of transaction restarts to 5, as it turns out that 2
is not sufficient in some cases.
This bug happens on several different machines (Asus V1S,
Dell Latitude E6530, Samsung R719, Acer Aspire 5930G,
Sony Vaio SR19VN and others).
[rjw: Changelog]
References: https://bugzilla.kernel.org/show_bug.cgi?id=14733
References: https://bugzilla.kernel.org/show_bug.cgi?id=15560
References: https://bugzilla.kernel.org/show_bug.cgi?id=15946
References: https://bugzilla.kernel.org/show_bug.cgi?id=42945
References: https://bugzilla.kernel.org/show_bug.cgi?id=48221
commit 61388f9e5d93053cf399a356414f31f9b4814c6d upstream.
Can only happen under these conditions: 1) The DSDT version is 1,
meaning integers are 32-bits. 2) The field is between 33 and 64
bits long.
It applies cleanly back to ACPICA 20100806+ (Linux v2.6.37+).
Signed-off-by: Bob Moore <robert.moore@intel.com>
commit 545d6e189a41c94c11f55045a771118eccc9d9eb upstream.
Found problem on system that firmware that could handle pci aer.
Firmware get error reporting after pci injecting error, before os boots.
But after os boots, firmware can not get report anymore, even pci=noaer
is passed.
Root cause: BIOS _OSC has problem with query bit checking.
It turns out that BIOS vendor is copying example code from ACPI Spec.
In ACPI Spec 5.0, page 290:
If (Not(And(CDW1,1))) // Query flag clear?
{ // Disable GPEs for features granted native control.
If (And(CTRL,0x01)) // Hot plug control granted?
Store(0,HPCE) // clear the hot plug SCI enable bit
Store(1,HPCS) // clear the hot plug SCI status bit
When Query flag is set, And(CDW1,1) will be 1, Not(1) will return 0xfffffffe.
So it will get into code path that should be for control set only.
BIOS acpi code should be changed to "If (LEqual(And(CDW1,1), 0)))"
Current kernel code is using _OSC query to notify firmware about support
from OS and then use _OSC to set control bits.
During query support, current code is using all possible controls.
So will execute code that should be only for control set stage.
That will have problem when pci=noaer or aer firmware_first is used.
As firmware have that control set for os aer already in query support stage,
but later will not os aer handling.
We should avoid passing all possible controls, just use osc_control_set
instead.
That should workaround BIOS bugs with affected systems on the field
as more bios vendors are copying sample code from ACPI spec.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
commit b88a634a903d9670aa5f2f785aa890628ce0dece upstream.
If cpuidle is disabled, that means that:
per_cpu(acpi_cpuidle_device, pr->id)
is set to NULL as the acpi_processor_power_init ends up failing at
retval = cpuidle_register_driver(&acpi_idle_driver)
(in acpi_processor_power_init) and never sets the per_cpu idle
device. So when acpi_processor_hotplug on CPU online notification
tries to reference said device it crashes:
cpu 3 spinlock event irq 62
BUG: unable to handle kernel NULL pointer dereference at 0000000000000004
IP: [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105
PGD a259b067 PUD ab38b067 PMD 0
Oops: 0002 [#1] SMP
odules linked in: dm_multipath dm_mod xen_evtchn iscsi_boot_sysfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi libcrc32c crc32c nouveau mxm_wmi wmi radeon ttm sg sr_mod sd_mod cdrom ata_generic ata_piix libata crc32c_intel scsi_mod atl1c i915 fbcon tileblit font bitblit softcursor drm_kms_helper video xen_blkfront xen_netfront fb_sys_fops sysimgblt sysfillrect syscopyarea xenfs xen_privcmd mperf
CPU 1
Pid: 3047, comm: bash Not tainted 3.8.0-rc3upstream-00250-g165c029 #1 MSI MS-7680/H61M-P23 (MS-7680)
RIP: e030:[<ffffffff81381013>] [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105
RSP: e02b:ffff88001742dca8 EFLAGS: 00010202
RAX: 0000000000010be9 RBX: ffff8800a0a61800 RCX: ffff880105380000
RDX: 0000000000000003 RSI: 0000000000000200 RDI: ffff8800a0a61800
RBP: ffff88001742dce8 R08: ffffffff81812360 R09: 0000000000000200
R10: aaaaaaaaaaaaaaaa R11: 0000000000000001 R12: ffff8800a0a61800
R13: 00000000ffffff01 R14: 0000000000000000 R15: ffffffff81a907a0
FS: 00007fd6942f7700(0000) GS:ffff880105280000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 0000000000000004 CR3: 00000000a6773000 CR4: 0000000000042660
Process bash (pid: 3047, threadinfo ffff88001742c000, task ffff880017944000)
Stack:
0000000000000150 ffff880100f59e00 ffff88001742dcd8 ffff8800a0a61800
0000000000000000 00000000ffffff01 0000000000000000 ffffffff81a907a0
ffff88001742dd18 ffffffff813815b1 ffff88001742dd08 ffffffff810ae336
Call Trace:
[<ffffffff813815b1>] acpi_processor_hotplug+0x7c/0x9f
[<ffffffff810ae336>] ? schedule_delayed_work_on+0x16/0x20
[<ffffffff8137ee8f>] acpi_cpu_soft_notify+0x90/0xca
[<ffffffff8166023d>] notifier_call_chain+0x4d/0x70
[<ffffffff810bc369>] __raw_notifier_call_chain+0x9/0x10
[<ffffffff81094a4b>] __cpu_notify+0x1b/0x30
[<ffffffff81652cf7>] _cpu_up+0x103/0x14b
[<ffffffff81652e18>] cpu_up+0xd9/0xec
[<ffffffff8164a254>] store_online+0x94/0xd0
[<ffffffff814122fb>] dev_attr_store+0x1b/0x20
[<ffffffff81216404>] sysfs_write_file+0xf4/0x170
This patch fixes it.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit b7e383046c2c7c13ad928cd7407eafff758ddd4b upstream.
When system enters power off, the _PSW of Lid device is enabled.
But this may cause the system to reboot instead of power off.
A proper way to fix this is to always disable lid wakeup capability for S5.
References: https://bugzilla.kernel.org/show_bug.cgi?id=35262
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Cc: Joseph Salisbury <joseph.salisbury@canonical.com>
commit 4f5f64cf0cc916220aaa055992e31195470cfe37 upstream.
At one point acpi_device_set_id() checks if acpi_device_hid(device)
returns NULL, but that never happens, so system bus devices with an
empty list of PNP IDs are given the dummy HID ("device") instead of
the "system bus HID" ("LNXSYBUS"). Fix the code to use the right
check.
commit 129ff8f8d58297b04f47b5d6fad81aa2d08404e1 upstream.
Or else the laptop will boot with a dimmed screen.
References: https://bugzilla.kernel.org/show_bug.cgi?id=51141
Tested-by: Stefan Nagy <public@stefan-nagy.at>
commit 4000e626156935dfb626321ce09cae2c833eabbb upstream.
Add a quirk to correctly report battery capacity on 2010 and 2011
Lenovo Thinkpad models.
The affected models that I tested (x201, t410, t410s, and x220)
exhibit a problem where, when battery capacity reporting unit is mAh,
the values being reported are wrong. Pre-2010 and 2012 models appear
to always report in mWh and are thus unaffected. Also, in mid-2012
Lenovo issued a BIOS update for the 2011 models that fixes the issue
(tested on x220 with a post-1.29 BIOS). No such update is available
for the 2010 models, so those still need this patch.
Problem description: for some reason, the affected Thinkpads switch
the reporting unit between mAh and mWh; generally, mAh is used when a
laptop is plugged in and mWh when it's unplugged, although a
suspend/resume or rmmod/modprobe is needed for the switch to take
effect. The values reported in mAh are *always* wrong. This does
not appear to be a kernel regression; I believe that the values were
never reported correctly. I tested back to kernel 2.6.34, with
multiple machines and BIOS versions.
Simply plugging a laptop into mains before turning it on is enough to
reproduce the problem. Here's a sample /proc/acpi/battery/BAT0/info
from Thinkpad x220 (before a BIOS update) with a 4-cell battery:
present: yes
design capacity: 2886 mAh
last full capacity: 2909 mAh
battery technology: rechargeable
design voltage: 14800 mV
design capacity warning: 145 mAh
design capacity low: 13 mAh
cycle count: 0
capacity granularity 1: 1 mAh
capacity granularity 2: 1 mAh
model number: 42T4899
serial number: 21064
battery type: LION
OEM info: SANYO
Once the laptop switches the unit to mWh (unplug from mains, suspend,
resume), the output changes to:
present: yes
design capacity: 28860 mWh
last full capacity: 29090 mWh
design capacity warning: 1454 mWh
design capacity low: 200 mWh
cycle count: 0
capacity granularity 1: 1 mWh
capacity granularity 2: 1 mWh
battery type: LION
OEM info: SANYO
Can you see how the values for "design capacity", etc., differ by a
factor of 10 instead of 14.8 (the design voltage of this battery)?
On the battery itself it says: 14.8V, 1.95Ah, 29Wh, so clearly the
values reported in mWh are correct and the ones in mAh are not.
My guess is that this problem has been around ever since those
machines were released, but because the most common Thinkpad
batteries are rated at 10.8V, the error (8%) is small enough that it
simply hasn't been noticed or at least nobody could be bothered to
look into it.
My patch works around the problem by adjusting the incorrectly
reported mAh values by "10000 / design_voltage". The patch also has
code to figure out if it should be activated or not. It only
activates on Lenovo Thinkpads, only when the unit is mAh, and, as an
extra precaution, only when the battery capacity reported through
ACPI does not match what is reported through DMI (I've never
encountered a machine where the first two conditions would be true
but the last would not, but better safe than sorry).
I've been using this patch for close to a year on several systems
without any problems.
References: https://bugzilla.kernel.org/show_bug.cgi?id=41062
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
commit 879dca019dc43a1622edca3e7dde644b14b5acc5 upstream.
We handle NOTIFY_THROTTLING so don't then fall through to unsupported event.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
commit 67bfa9b60bd689601554526d144b21d529f78a09 upstream.
By enlarging the GPE storm threshold back to 20, that laptop's
EC works fine with interrupt mode instead of polling mode.
https://bugzilla.kernel.org/show_bug.cgi?id=45151
Reported-and-Tested-by: Francesco <trentini@dei.unipd.it>
Signed-off-by: Feng Tang <feng.tang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit a520d52e99b14ba7db135e916348f12f2a6e09be upstream.
The Linux EC driver includes a mechanism to detect GPE storms,
and switch from interrupt-mode to polling mode. However, polling
mode sometimes doesn't work, so the workaround is problematic.
Also, different systems seem to need the threshold for detecting
the GPE storm at different levels.
ACPI_EC_STORM_THRESHOLD was initially 20 when it's created, and
was changed to 8 in 2.6.28 commit 06cf7d3c7 "ACPI: EC: lower interrupt storm
threshold" to fix kernel bug 11892 by forcing the laptop in that bug to
work in polling mode. However in bug 45151, it works fine in interrupt
mode if we lift the threshold back to 20.
This patch makes the threshold a module parameter so that user has a
flexible option to debug/workaround this issue.
The default is unchanged.
This is also a preparation patch to fix specific systems:
commit fc54ab72959edbf229b65ac74b2f122d799ca002 upstream.
The _OSC method may exist in module level code,
so it must be called after ACPI_FULL_INITIALIZATION
On some new platforms with Zero-Power-Optical-Disk-Drive (ZPODD)
support, this fix is necessary to save power.
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Tested-by: Aaron Lu <aaron.lu@intel.com>
commit c4686c71a9183f76e3ef59098da5c098748672f6 upstream.
Commit d640113fe80e45ebd4a5b420b introduced a regression on SMP
systems where the processor core with ACPI id zero is disabled
(typically should be the case because of hyperthreading).
The regression got spread through stable kernels.
On 3.0.X it got introduced via 3.0.18.
Such platforms may be rare, but do exist.
Look out for a disabled processor with acpi_id 0 in dmesg:
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x10] disabled)
This problem has been observed on a:
HP Proliant BL280c G6 blade
This patch restricts the introduced workaround to platforms
with nr_cpu_ids <= 1.
Signed-off-by: Thomas Renninger <trenn@suse.de>
commit 4f81f986761a7663db7d24d24cd6ae68008f1fc2 upstream.
We need it in the radeon drm module to fetch
and verify the vbios image on UEFI systems.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
power_supply_register() return value check
commit f197ac13f6eeb351b31250b9ab7d0da17434ea36 upstream.
In the ac.c, power_supply_register()'s return value is not checked.
As a result, the driver's add() ops may return success
even though the device failed to initialize.
For example, some BIOS may describe two ACADs in the same DSDT.
The second ACAD device will fail to register,
but ACPI driver's add() ops returns sucessfully.
The ACPI device will receive ACPI notification and cause OOPS.
https://bugzilla.redhat.com/show_bug.cgi?id=772730
commit 9f132652d94c96476b0b0a8caf0c10e96ab10fa8 upstream.
Current code is ignoring the last character of "enable" and "disable"
in comparisons.
https://bugzilla.kernel.org/show_bug.cgi?id=33732
commit 5f1601261050251a5ca293378b492a69d590dacb upstream.
The acpi_pad driver can get stuck in destroy_power_saving_task()
waiting for kthread_stop() to stop a power_saving thread. The problem
is that the isolated_cpus_lock mutex is owned when
destroy_power_saving_task() calls kthread_stop(), which waits for a
power_saving thread to end, and the power_saving thread tries to
acquire the isolated_cpus_lock when it calls round_robin_cpu(). This
patch fixes the issue by making round_robin_cpu() use its own mutex.
https://bugzilla.kernel.org/show_bug.cgi?id=42981
Signed-off-by: Stuart Hayes <Stuart_Hayes@Dell.com>
commit cfb46f433a4da97c31780e08a259fac2cb6bd61f upstream.
Acked-by: Matthew Garrett <mjg@redhat.com>
commit c5971456964290da7e98222892797b71ef793e62 upstream.
We only need to regenerate the sysfs files when the capacity units
change, avoid the update otherwise.
The origin of this issue is dates way back to 2.6.38:
da8aeb92d4853f37e281f11fddf61f9c7d84c3cd
(ACPI / Battery: Update information on info notification and resume)
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Tested-by: Ralf Jung <post@ralfj.de>
commit 93f770846e8dedc5d9117bd4ad9d7efd18420627 upstream.
Sony Vaio VPCCW29FX does not resume correctly without
acpi_sleep=nonvs, so add it to the ACPI sleep blacklist.
https://bugzilla.kernel.org/show_bug.cgi?id=34722
commit 8931d9ea78848b073bf299594f148b83abde4a5e upstream.
Allow referenced objects to be in a different scope.
http://www.acpica.org/bugzilla/show_bug.cgi?id=937
http://marc.info/?l=linux-acpi&m=131636632718222&w=2
ACPI Error: [RAMB] Namespace lookup failure, AE_NOT_FOUND (20110112/psargs-359)
ACPI Exception: AE_NOT_FOUND, Could not execute arguments for [RAMW] (Region) (20110112/nsinit-349)
Scope (_SB)
Name (RAMB, 0xDF5A1018)
OperationRegion (\RAMW, SystemMemory, RAMB, 0x00010000)
For above ASL code, we need to save scope node(\_SB) to lookup
the argument node(\_SB.RAMB).
Reported-by: Jim Green <student.northwestern@gmail.com>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
commit 3e80acd1af40fcd91a200b0416a7616b20c5d647 upstream.
commit 64b3db22c04586997ab4be46dd5a5b99f8a2d390 (2.6.39),
"Remove use of unreliable FADT revision field" causes regression
for old P4 systems because now cst_control and other fields are
not reset to 0.
The effect is that acpi_processor_power_init will notice
cst_control != 0 and a write to CST_CNT register is performed
that should not happen. As result, the system oopses after the
"No _CST, giving up" message, sometimes in acpi_ns_internalize_name,
sometimes in acpi_ns_get_type, usually at random places. May be
during migration to CPU 1 in acpi_processor_get_throttling.
Every one of these settings help to avoid this problem:
- acpi=off
- processor.nocst=1
- maxcpus=1
The fix is to update acpi_gbl_FADT.header.length after
the original value is used to check for old revisions.
https://bugzilla.kernel.org/show_bug.cgi?id=42700
https://bugzilla.redhat.com/show_bug.cgi?id=727865
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Acked-by: Bob Moore <robert.moore@intel.com>
Cc: Jonathan Nieder <jrnieder@gmail.com>
Cc: Josh Boyer <jwboyer@gmail.com>
commit 2815ab92ba3ab27556212cc306288dc95692824b upstream.
On Intel CPUs the processor typically uses the highest frequency
set by any logical CPU. When the system overheats
Linux first forces the frequency to the lowest available one
to lower the temperature.
However this was done only per logical CPU, which means all
logical CPUs in a package would need to go through this before
the frequency is actually lowered.
Worse this delay actually prevents real throttling, because
the real throttle code only proceeds when the lowest frequency
is already reached.
So when a throttle event happens force the lowest frequency
for all CPUs in the package where it happened. The per CPU
state is now kept per package, not per logical CPU. An alternative
would be to do it per cpufreq unit, but since we want to bring
down the temperature of the complete chip it's better
to do it for all.
In principle it may even make sense to do it for all CPUs,
but I kept it on the package for now.
With this change the frequency is actually lowered, which
in terms also allows real throttling to proceed.
I also removed an unnecessary per cpu variable initialization.
v2: Fix package mapping
commit 5a50a7c32d630d6cdb13d69afabb0cc81b2f379c upstream.
The models do not resume correctly without acpi_sleep=nonvs.
Signed-off-by: Keng-Yu Lin <kengyu@canonical.com>
Cc: Tim Gardner <tim.gardner@canonical.com>
commit 3c076351c4027a56d5005a39a0b518a4ba393ce2 upstream.
Right now we forcibly clear ASPM state on all devices if the BIOS indicates
that the feature isn't supported. Based on the Microsoft presentation
"PCI Express In Depth for Windows Vista and Beyond", I'm starting to think
that this may be an error. The implication is that unless the platform
grants full control via _OSC, Windows will not touch any PCIe features -
including ASPM. In that case clearing ASPM state would be an error unless
the platform has granted us that control.
This patch reworks the ASPM disabling code such that the actual clearing
of state is triggered by a successful handoff of PCIe control to the OS.
The general ASPM code undergoes some changes in order to ensure that the
ability to clear the bits isn't overridden by ASPM having already been
disabled. Further, this theoretically now allows for situations where
only a subset of PCIe roots hand over control, leaving the others in the
BIOS state.
It's difficult to know for sure that this is the right thing to do -
there's zero public documentation on the interaction between all of these
components. But enough vendors enable ASPM on platforms and then set this
bit that it seems likely that they're expecting the OS to leave them alone.
Measured to save around 5W on an idle Thinkpad X220.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit d640113fe80e45ebd4a5b420b220d3f6bf37f682 upstream.
For UP processor, it is likely that no _MAT method or MADT table defined.
So currently acpi_get_cpuid(...) always return -1 for UP processor.
This is wrong. It should return valid value for CPU0.
In the other hand, BIOS may define multiple CPU handles even for UP
processor, for example
Scope (_PR)
Processor (CPU0, 0x00, 0x00000410, 0x06) {}
Processor (CPU1, 0x01, 0x00000410, 0x06) {}
Processor (CPU2, 0x02, 0x00000410, 0x06) {}
Processor (CPU3, 0x03, 0x00000410, 0x06) {}
We should only return valid value for CPU0's acpi handle.
And return invalid value for others.
http://marc.info/?t=132329819900003&r=1&w=2
Reported-and-tested-by: wallak@free.fr
commit da4d8b287abe783d30e968155614531a0937d090 upstream.
The call to acpi_os_validate_address in acpi_ds_get_region_arguments was
removed by mistake in commit 9ad19ac(ACPICA: Split large dsopcode and
dsload.c files).
Put it back.
Reported-and-bisected-by: Luca Tettamanti <kronos.it@gmail.com>
commit 8df0eb7c9d96f9e82f233ee8b74e0f0c8471f868 upstream.
In SRAT v1, we had 8bit proximity domain (PXM) fields; SRAT v2 provides
32bits for these. The new fields were reserved before.
According to the ACPI spec, the OS must disregrard reserved fields.
In order to know whether or not, we must know what version the SRAT
table has.
This patch stores the SRAT table revision for later consumption
by arch specific __init functions.
Signed-off-by: Kurt Garloff <kurt@garloff.de>
commit 3bf3f8b19d2bfccc40f13c456bf339fd8f535ebc upstream.
Callers to __acpi_ioremap_fast() pass the bit_width that they found in the
acpi_generic_address structure. Convert from bits to bytes when passing to
__acpi_find_iomap() - as it wants to see bytes, not bits.
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit b33c25d6a62ac253caabda2b5f43258abff451c0 upstream.
This limit is a workaround for AML that sleeps too long,
but the workaround didn't work b/c of a typo.
https://bugzilla.kernel.org/show_bug.cgi?id=13195
commit 8f9c91273e36e5762c617c23e4fd48d5172e0dac upstream.
We can only sort the _TSS return package if there is no _PSS
in the same scope. This is because if _PSS is present, the ACPI
specification dictates that the _TSS Power Dissipation field is
to be ignored, and therefore some BIOSs leave garbage values in
the _TSS Power field(s). In this case, it is best to just return
the _TSS package as-is.
Reported-by: Fenghua Yu <fenghua.yu@intel.com>
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
The firmware on some machine will report duplicated hardware error
source ID in HEST. This is considered a firmware bug. To provide
better warning message, this patch adds duplicated hardware error
source ID detecting and corresponding printk.
This patch fixes #37412 on kernel bugzilla:
https://bugzilla.kernel.org/show_bug.cgi?id=37412
Reported-by: marconifabio@ubuntu-it.org
Signed-off-by: Huang Ying <ying.huang@intel.com>
Tested-by: Mathias <janedo.spam@gmail.com>
All ACPICA locks are allocated by the same function,
acpi_os_create_lock(), with the help of a local variable called
"lock". Thus, when lockdep is enabled, it uses "lock" as the
name of all those locks and regards them as instances of the same
lock, which causes it to report possible locking problems with them
when there aren't any.
To work around this problem, define acpi_os_create_lock() as a macro
and make it pass its argument to spin_lock_init(), so that lockdep
uses it as the name of the new lock. Define this macron in a
Linux-specific file, to minimize the resulting modifications of
the OS-independent ACPICA parts.
This change is based on an earlier patch from Andrea Righi and it
addresses a regression from 2.6.39 tracked as
https://bugzilla.kernel.org/show_bug.cgi?id=38152
Reported-and-tested-by: Borislav Petkov <bp@alien8.de>
Tested-by: Andrea Righi <andrea@betterlinux.com>
Reviewed-by: Florian Mickler <florian@mickler.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI EC: remove redundant code
ACPI: Add D3 cold state
ACPI: processor: fix processor_physically_present in UP kernel
ACPI: Split out custom_method functionality into an own driver
ACPI: Cleanup custom_method debug stuff
ACPI EC: enable MSI workaround for Quanta laptops
ACPICA: Update to version 20110413
ACPICA: Execute an orphan _REG method under the EC device
ACPICA: Move ACPI_NUM_PREDEFINED_REGIONS to a more appropriate place
ACPICA: Update internal address SpaceID for DataTable regions
ACPICA: Add more methods eligible for NULL package element removal
ACPICA: Split all internal Global Lock functions to new file - evglock
ACPI: EC: add another DMI check for ASUS hardware
ACPI EC: remove dead code
ACPICA: Fix code divergence of global lock handling
ACPICA: Use acpi_os_create_lock interface
ACPI: osl, add acpi_os_create_lock interface
ACPI:Fix goto flows in thermal-sys
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param
x86 idle: deprecate "no-hlt" cmdline param
x86 idle APM: deprecate CONFIG_APM_CPU_IDLE
x86 idle floppy: deprecate disable_hlt()
x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it
x86 idle: clarify AMD erratum 400 workaround
idle governor: Avoid lock acquisition to read pm_qos before entering idle
cpuidle: menu: fixed wrapping timers at 4.294 seconds
drivers/platform/x86/compal-laptop.c
'd3-cold', 'ec-asus' and 'thermal-fix' into release
The workaround for AMD erratum 400 uses the term "c1e" falsely suggesting:
1. Intel C1E is somehow involved
2. All AMD processors with C1E are involved
Use the string "amd_c1e" instead of simply "c1e" to clarify that
this workaround is specific to AMD's version of C1E.
Use the string "e400" to clarify that the workaround is specific
to AMD processors with Erratum 400.
This patch is text-substitution only, with no functional change.
cc: x86@kernel.org
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
ec->handle is set in ec_parse_device(), so don't bother to set it again.
_SxW returns an Integer containing the lowest D-state supported in state
Sx. If OSPM has not indicated that it supports _PR3, then the value “3”
corresponds to D3. If it has indicated _PR3 support, the value “3”
represents D3hot and the value “4” represents D3cold.
Linux does set _OSC._PR3, so we should fix it to expect that _SxW can
return 4.
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Usually, there are multiple processors defined in ACPI table, for
example
Scope (_PR)
processor_physically_present(...) will be called to check whether those
processors are physically present.
Currently we have below codes in processor_physically_present,
cpuid = acpi_get_cpuid(...);
if ((cpuid == -1) && (num_possible_cpus() > 1))
return false;
return true;
In UP kernel, acpi_get_cpuid(...) always return -1 and
num_possible_cpus() always return 1, so
processor_physically_present(...) always returns true for all passed in
processor handles.
This is wrong for UP processor or SMP processor running UP kernel.
This patch removes the !SMP version of acpi_get_cpuid(), so both UP and
SMP kernel use the same acpi_get_cpuid function.
And for UP kernel, only processor 0 is valid.
https://bugzilla.kernel.org/show_bug.cgi?id=16548
https://bugzilla.kernel.org/show_bug.cgi?id=16357
Tested-by: Anton Kochkov <anton.kochkov@gmail.com>
Tested-by: Ambroz Bizjak <ambrop7@gmail.com>
With /sys/kernel/debug/acpi/custom_method root can write
to arbitrary memory and increase his priveleges, even if
these are restricted.
-> Make this an own debug .config option and warn about the
security issue in the config description.
-> Still keep acpi/debugfs.c which now only creates an empty
/sys/kernel/debug/acpi directory. There might be other
users of it later.
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Acked-by: rui.zhang@intel.com
