path: root/drivers/amba
2018-05-01ARM: amba: Don't read past the end of sysfs "driver_override" bufferGeert Uytterhoeven
commit d2ffed5185df9d8d9ccd150e4340e3b6f96a8381 upstream. When printing the driver_override parameter when it is 4095 and 4094 bytes long, the printing code would access invalid memory because we need count + 1 bytes for printing. Cfr. commits 4efe874aace57dba ("PCI: Don't read past the end of sysfs "driver_override" buffer") and bf563b01c2895a4b ("driver core: platform: Don't read past the end of "driver_override" buffer"). Fixes: 3cf385713460eb2b ("ARM: 8256/1: driver coamba: add device binding path 'driver_override'") Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Todd Kjos <tkjos@google.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-01ARM: amba: Fix race condition with driver_overrideGeert Uytterhoeven
commit 6a7228d90d42bcacfe38786756ba62762b91c20a upstream. The driver_override implementation is susceptible to a race condition when different threads are reading vs storing a different driver override. Add locking to avoid this race condition. Cfr. commits 6265539776a0810b ("driver core: platform: fix race condition with driver_override") and 9561475db680f714 ("PCI: Fix race condition with driver_override"). Fixes: 3cf385713460eb2b ("ARM: 8256/1: driver coamba: add device binding path 'driver_override'") Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Todd Kjos <tkjos@google.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-01ARM: amba: Make driver_override output consistent with other busesGeert Uytterhoeven
commit 5f53624662eaac89598641cee6cd54fc192572d9 upstream. For AMBA devices with unconfigured driver override, the "driver_override" sysfs virtual file is empty, while it contains "(null)" for platform and PCI devices. Make AMBA consistent with other buses by dropping the test for a NULL pointer. Note that contrary to popular belief, sprintf() handles NULL pointers fine; they are printed as "(null)". Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Cc: stable <stable@vger.kernel.org> Reviewed-by: Todd Kjos <tkjos@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-09amba: use dev_groups and not dev_attrs for bus_typeGreg Kroah-Hartman
The dev_attrs field has long been "depreciated" and is finally being removed, so move the driver to use the "correct" dev_groups field instead for struct bus_type. Cc: Russell King <linux@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-12ARM: 8596/1: amba: Support clk parents and rates assigned in DTStephen Boyd
Add the call to of_clk_set_defaults() into the amba probe path so that devices on the amba bus can use the assigned rates and parents feature of the common clock framework. Cc: Michael Turquette <mturquette@baylibre.com> Tested-by: Jorge Ramirez Ortiz <jorge.ramirez-ortiz@linaro.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2016-05-05ARM: 8566/1: drivers: amba: properly handle devices with power domainsMarek Szyprowski
To read pid/cid registers, the probed device need to be properly turned on. When it is inside a power domain, the bus code should ensure that the given power domain is enabled before trying to access device's registers. However in some cases power domain (or clocks) might not be yet available. Returning -EPROBE_DEFER is not a solution in such case, because callers don't handle this special error code. Instead such devices are added to the special list and their registration is retried from periodic worker until all resources are available. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-11-24amba: Hide TEGRA_AHB symbolThierry Reding
The symbol depends on ARCH_TEGRA and will default to y. There are no circumstances under which it is desirable to disable this option. Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-04-02ARM: 8334/1: amba: tegra-ahb: detect and correct bogus base addressPaul Walmsley
amba: tegra-ahb: detect and correct bogus base address From a hardware SoC integration point of view, the starting address of this IP block in the existing Tegra SoC DT files is off by 4 bytes from the actual base address. Since we attempt to make old DT files forward-compatible with newer kernels, we cannot fix the IP block base address in old DT data. This patch works around the problem by detecting the four byte base address offset in the driver code, and correcting it if it's detected. (In general, IP block base addresses almost always have a null low byte.) Future SoC DT data for Tegra AHB should use the correct Tegra AHB base address, in cases where there is no DT data backward compatibility requirement. This patch is a revision of the patch originally titled "amba: tegra-ahb: use correct base address for future chip support". This revision implements changes requested by Russell King: http://marc.info/?l=linux-tegra&m=142658851825062&w=2 http://marc.info/?l=linux-tegra&m=142658873925178&w=2 Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Paul Walmsley <pwalmsley@nvidia.com> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Hiroshi DOYU <hdoyu@nvidia.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-kernel@vger.kernel.org Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-04-02ARM: 8333/1: amba: tegra-ahb: fix register offsets in the macrosPaul Walmsley
amba: tegra-ahb: fix register offsets in the macros From a hardware SoC integration point of view, the offsets of the Tegra AHB registers that are currently defined in tegra-ahb.c macros are all off by four bytes. Similarly, the starting address of this IP block in our existing DT files is also off by four bytes. Since we attempt to make old DT files forward-compatible with newer kernels, we cannot fix the IP block base address in old DT data. However, we can fix the offsets in the driver so that they are correct with respect to the hardware, which is what this patch does. And a subsequent patch will allow the offset to be removed for DT 'compatible' strings used in future DT files for newer Tegra chips that the kernel does not yet support. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Paul Walmsley <pwalmsley@nvidia.com> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Hiroshi DOYU <hdoyu@nvidia.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-kernel@vger.kernel.org Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-02-10ARM: 8256/1: driver coamba: add device binding path 'driver_override'Antonios Motakis
As already demonstrated with PCI [1] and the platform bus [2], a driver_override property in sysfs can be used to bypass the id matching of a device to a AMBA driver. This can be used by VFIO to bind to any AMBA device requested by the user. [1] http://lists-archives.com/linux-kernel/28030441-pci-introduce-new-device-binding-path-using-pci_dev-driver_override.html [2] https://www.redhat.com/archives/libvir-list/2014-April/msg00382.html Signed-off-by: Antonios Motakis <a.motakis@virtualopensystems.com> Reviewed-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-12-14Merge tag 'char-misc-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver update for 3.19-rc1 Lots of little things all over the place in different drivers, and a new subsystem, "coresight" has been added. Full details are in the shortlog" * tag 'char-misc-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (73 commits) parport: parport_pc, do not remove parent devices early spmi: Remove shutdown/suspend/resume kernel-doc carma-fpga-program: drop videobuf dependency carma-fpga: drop videobuf dependency carma-fpga-program.c: fix compile errors i8k: Fix temperature bug handling in i8k_get_temp() cxl: Name interrupts in /proc/interrupt CXL: Return error to PSL if IRQ demultiplexing fails & print clearer warning coresight-replicator: remove .owner field for driver coresight: fixed comments in coresight.h coresight: fix typo in comment in coresight-priv.h coresight: bindings for coresight drivers coresight: Adding ABI documentation w1: support auto-load of w1_bq27000 module. w1: avoid potential u16 overflow cn: verify msg->len before making callback mei: export fw status registers through sysfs mei: read and print all six FW status registers mei: txe: add cherrytrail device id mei: kill cached host and me csr values ...
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-12Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "The major updates included in this update are: - Clang compatible stack pointer accesses by Behan Webster. - SA11x0 updates from Dmitry Eremin-Solenikov. - kgdb handling of breakpoints with read-only text/modules - Support for Privileged-no-execute feature on ARMv7 to prevent userspace code execution by the kernel. - AMBA primecell bus handling of irq-safe runtime PM - Unwinding support for memset/memzero/memmove/memcpy functions - VFP fixes for Krait CPUs and improvements in detecting the VFP architecture - A number of code cleanups (using pr_*, removing or reducing the severity of a couple of kernel messages, splitting ftrace asm code out to a separate file, etc.) - Add machine name to stack dump output" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (62 commits) ARM: 8247/2: pcmcia: sa1100: make use of device clock ARM: 8246/2: pcmcia: sa1111: provide device clock ARM: 8245/1: pcmcia: soc-common: enable/disable socket clocks ARM: 8244/1: fbdev: sa1100fb: make use of device clock ARM: 8243/1: sa1100: add a clock alias for sa1111 pcmcia device ARM: 8242/1: sa1100: add cpu clock ARM: 8221/1: PJ4: allow building in Thumb-2 mode ARM: 8234/1: sa1100: reorder IRQ handling code ARM: 8233/1: sa1100: switch to hwirq usage ARM: 8232/1: sa1100: merge GPIO multiplexer IRQ to "normal" irq domain ARM: 8231/1: sa1100: introduce irqdomains support ARM: 8230/1: sa1100: shift IRQs by one ARM: 8229/1: sa1100: replace irq numbers with names in irq driver ARM: 8228/1: sa1100: drop entry-macro.S ARM: 8227/1: sa1100: switch to MULTI_IRQ_HANDLER ARM: 8241/1: Update processor_modes for hyp and monitor mode ARM: 8240/1: MCPM: document mcpm_sync_init() ARM: 8239/1: Introduce {set,clear}_pte_bit ARM: 8238/1: mm: Refine set_memory_* functions ARM: 8237/1: fix flush_pfn_alias ...
2014-12-10Merge tag 'pm+acpi-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "This time we have some more new material than we used to have during the last couple of development cycles. The most important part of it to me is the introduction of a unified interface for accessing device properties provided by platform firmware. It works with Device Trees and ACPI in a uniform way and drivers using it need not worry about where the properties come from as long as the platform firmware (either DT or ACPI) makes them available. It covers both devices and "bare" device node objects without struct device representation as that turns out to be necessary in some cases. This has been in the works for quite a few months (and development cycles) and has been approved by all of the relevant maintainers. On top of that, some drivers are switched over to the new interface (at25, leds-gpio, gpio_keys_polled) and some additional changes are made to the core GPIO subsystem to allow device drivers to manipulate GPIOs in the "canonical" way on platforms that provide GPIO information in their ACPI tables, but don't assign names to GPIO lines (in which case the driver needs to do that on the basis of what it knows about the device in question). That also has been approved by the GPIO core maintainers and the rfkill driver is now going to use it. Second is support for hardware P-states in the intel_pstate driver. It uses CPUID to detect whether or not the feature is supported by the processor in which case it will be enabled by default. However, it can be disabled entirely from the kernel command line if necessary. Next is support for a platform firmware interface based on ACPI operation regions used by the PMIC (Power Management Integrated Circuit) chips on the Intel Baytrail-T and Baytrail-T-CR platforms. That interface is used for manipulating power resources and for thermal management: sensor temperature reporting, trip point setting and so on. Also the ACPI core is now going to support the _DEP configuration information in a limited way. Basically, _DEP it supposed to reflect off-the-hierarchy dependencies between devices which may be very indirect, like when AML for one device accesses locations in an operation region handled by another device's driver (usually, the device depended on this way is a serial bus or GPIO controller). The support added this time is sufficient to make the ACPI battery driver work on Asus T100A, but it is general enough to be able to cover some other use cases in the future. Finally, we have a new cpufreq driver for the Loongson1B processor. In addition to the above, there are fixes and cleanups all over the place as usual and a traditional ACPICA update to a recent upstream release. As far as the fixes go, the ACPI LPSS (Low-power Subsystem) driver for Intel platforms should be able to handle power management of the DMA engine correctly, the cpufreq-dt driver should interact with the thermal subsystem in a better way and the ACPI backlight driver should handle some more corner cases, among other things. On top of the ACPICA update there are fixes for race conditions in the ACPICA's interrupt handling code which might lead to some random and strange looking failures on some systems. In the cleanups department the most visible part is the series of commits targeted at getting rid of the CONFIG_PM_RUNTIME configuration option. That was triggered by a discussion regarding the generic power domains code during which we realized that trying to support certain combinations of PM config options was painful and not really worth it, because nobody would use them in production anyway. For this reason, we decided to make CONFIG_PM_SLEEP select CONFIG_PM_RUNTIME and that lead to the conclusion that the latter became redundant and CONFIG_PM could be used instead of it. The material here makes that replacement in a major part of the tree, but there will be at least one more batch of that in the second part of the merge window. Specifics: - Support for retrieving device properties information from ACPI _DSD device configuration objects and a unified device properties interface for device drivers (and subsystems) on top of that. As stated above, this works with Device Trees and ACPI and allows device drivers to be written in a platform firmware (DT or ACPI) agnostic way. The at25, leds-gpio and gpio_keys_polled drivers are now going to use this new interface and the GPIO subsystem is additionally modified to allow device drivers to assign names to GPIO resources returned by ACPI _CRS objects (in case _DSD is not present or does not provide the expected data). The changes in this set are mostly from Mika Westerberg, Rafael J Wysocki, Aaron Lu, and Darren Hart with some fixes from others (Fabio Estevam, Geert Uytterhoeven). - Support for Hardware Managed Performance States (HWP) as described in Volume 3, section 14.4, of the Intel SDM in the intel_pstate driver. CPUID is used to detect whether or not the feature is supported by the processor. If supported, it will be enabled automatically unless the intel_pstate=no_hwp switch is present in the kernel command line. From Dirk Brandewie. - New Intel Broadwell-H ID for intel_pstate (Dirk Brandewie). - Support for firmware interface based on ACPI operation regions used by the PMIC chips on the Intel Baytrail-T and Baytrail-T-CR platforms for power resource control and thermal management (Aaron Lu). - Limited support for retrieving off-the-hierarchy dependencies between devices from ACPI _DEP device configuration objects and deferred probing support for the ACPI battery driver based on the _DEP information to make that driver work on Asus T100A (Lan Tianyu). - New cpufreq driver for the Loongson1B processor (Kelvin Cheung). - ACPICA update to upstream revision 20141107 which only affects tools (Bob Moore). - Fixes for race conditions in the ACPICA's interrupt handling code and in the ACPI code related to system suspend and resume (Lv Zheng and Rafael J Wysocki). - ACPI core fix for an RCU-related issue in the ioremap() regions management code that slowed down significantly after CPUs had been allowed to enter idle states even if they'd had RCU callbakcs queued and triggered some problems in certain proprietary graphics driver (and elsewhere). The fix replaces synchronize_rcu() in that code with synchronize_rcu_expedited() which makes the issue go away. From Konstantin Khlebnikov. - ACPI LPSS (Low-Power Subsystem) driver fix to handle power management of the DMA engine included into the LPSS correctly. The problem is that the DMA engine doesn't have ACPI PM support of its own and it simply is turned off when the last LPSS device having ACPI PM support goes into D3cold. To work around that, the PM domain used by the ACPI LPSS driver is redesigned so at least one device with ACPI PM support will be on as long as the DMA engine is in use. From Andy Shevchenko. - ACPI backlight driver fix to avoid using it on "Win8-compatible" systems where it doesn't work and where it was used by default by mistake (Aaron Lu). - Assorted minor ACPI core fixes and cleanups from Tomasz Nowicki, Sudeep Holla, Huang Rui, Hanjun Guo, Fabian Frederick, and Ashwin Chaugule (mostly related to the upcoming ARM64 support). - Intel RAPL (Running Average Power Limit) power capping driver fixes and improvements including new processor IDs (Jacob Pan). - Generic power domains modification to power up domains after attaching devices to them to meet the expectations of device drivers and bus types assuming devices to be accessible at probe time (Ulf Hansson). - Preliminary support for controlling device clocks from the generic power domains core code and modifications of the ARM/shmobile platform to use that feature (Ulf Hansson). - Assorted minor fixes and cleanups of the generic power domains core code (Ulf Hansson, Geert Uytterhoeven). - Assorted minor fixes and cleanups of the device clocks control code in the PM core (Geert Uytterhoeven, Grygorii Strashko). - Consolidation of device power management Kconfig options by making CONFIG_PM_SLEEP select CONFIG_PM_RUNTIME and removing the latter which is now redundant (Rafael J Wysocki and Kevin Hilman). That is the first batch of the changes needed for this purpose. - Core device runtime power management support code cleanup related to the execution of callbacks (Andrzej Hajda). - cpuidle ARM support improvements (Lorenzo Pieralisi). - cpuidle cleanup related to the CPUIDLE_FLAG_TIME_VALID flag and a new MAINTAINERS entry for ARM Exynos cpuidle (Daniel Lezcano and Bartlomiej Zolnierkiewicz). - New cpufreq driver callback (->ready) to be executed when the cpufreq core is ready to use a given policy object and cpufreq-dt driver modification to use that callback for cooling device registration (Viresh Kumar). - cpufreq core fixes and cleanups (Viresh Kumar, Vince Hsu, James Geboski, Tomeu Vizoso). - Assorted fixes and cleanups in the cpufreq-pcc, intel_pstate, cpufreq-dt, pxa2xx cpufreq drivers (Lenny Szubowicz, Ethan Zhao, Stefan Wahren, Petr Cvek). - OPP (Operating Performance Points) framework modification to allow OPPs to be removed too and update of a few cpufreq drivers (cpufreq-dt, exynos5440, imx6q, cpufreq) to remove OPPs (added during initialization) on driver removal (Viresh Kumar). - Hibernation core fixes and cleanups (Tina Ruchandani and Markus Elfring). - PM Kconfig fix related to CPU power management (Pankaj Dubey). - cpupower tool fix (Prarit Bhargava)" * tag 'pm+acpi-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (120 commits) i2c-omap / PM: Drop CONFIG_PM_RUNTIME from i2c-omap.c dmaengine / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM tools: cpupower: fix return checks for sysfs_get_idlestate_count() drivers: sh / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM e1000e / igb / PM: Eliminate CONFIG_PM_RUNTIME MMC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM MFD / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM misc / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM media / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM input / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM leds: leds-gpio: Fix multiple instances registration without 'label' property iio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM hsi / OMAP / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM i2c-hid / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM drm / exynos / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM gpio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM hwrandom / exynos / PM: Use CONFIG_PM in #ifdef block / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM USB / PM: Drop CONFIG_PM_RUNTIME from the USB core PM: Merge the SET*_RUNTIME_PM_OPS() macros ...
2014-12-04PM: Merge the SET*_RUNTIME_PM_OPS() macrosRafael J. Wysocki
The SET_PM_RUNTIME_PM_OPS() and SET_RUNTIME_PM_OPS() macros are identical except that one of them is not empty for CONFIG_PM set, while the other one is not empty for CONFIG_PM_RUNTIME set, respectively. However, after commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so one of these macros is now redundant. For this reason, replace SET_PM_RUNTIME_PM_OPS() with SET_RUNTIME_PM_OPS() everywhere and redefine the SET_PM_RUNTIME_PM_OPS symbol as SET_RUNTIME_PM_OPS in case new code is starting to use the macro being removed here. Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-11-26ARM: tegra: Move AHB Kconfig to drivers/ambaThierry Reding
This will allow the Kconfig option to be shared among 32-bit and 64-bit ARM. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-11-26amba: Add Kconfig fileThierry Reding
Rather than duplicate the ARM_AMBA Kconfig symbol in both 32-bit and 64-bit ARM architectures, move the common definition to drivers/amba where dependent drivers will be located. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-11-17ARM: 8201/1: amba: Don't unprepare the clocks if device driver wants IRQ ↵Krzysztof Kozlowski
safe runtime PM v12 The AMBA bus driver defines runtime Power Management functions which disable and unprepare AMBA bus clock. This is problematic for runtime PM because unpreparing a clock might sleep so it is not interrupt safe. However some drivers may want to implement runtime PM functions in interrupt-safe way (see pm_runtime_irq_safe()). In such case the AMBA bus driver should only disable/enable the clock in runtime suspend and resume callbacks. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-11-07coresight: add CoreSight core layer frameworkPratik Patel
CoreSight components are compliant with the ARM CoreSight architecture specification and can be connected in various topologies to suit a particular SoC tracing needs. These trace components can generally be classified as sources, links and sinks. Trace data produced by one or more sources flows through the intermediate links connecting the source to the currently selected sink. The CoreSight framework provides an interface for the CoreSight trace drivers to register themselves with. It's intended to build up a topological view of the CoreSight components and configure the correct serie of components on user input via sysfs. For eg., when enabling a source, the framework builds up a path consisting of all the components connecting the source to the currently selected sink(s) and enables all of them. The framework also supports switching between available sinks and provides status information to user space applications through the debugfs interface. Signed-off-by: Pratik Patel <pratikp@codeaurora.org> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20amba: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-30PM / Domains: Move dev_pm_domain_attach|detach() to pm_domain.hUlf Hansson
The commit 46420dd73b80 (PM / Domains: Add APIs to attach/detach a PM domain for a device) started using errno values in pm.h header file. It also failed to include the header for these, thus it caused compiler errors. Instead of including the errno header to pm.h, let's move the functions to pm_domain.h, since it's a better match. Fixes: 46420dd73b80 (PM / Domains: Add APIs to attach/detach a PM domain for a device) Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Mark Brown <broonie@kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-09-22amba: Add support for attach/detach of PM domainsUlf Hansson
AMBA devices may on some SoCs resides in PM domains. To be able to manage these devices from there, let's try to attach devices to their corresponding PM domain during the probe phase. To reverse these actions at the remove phase, we try to detach the device from its PM domain. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Reviewed-by: Kevin Hilman <khilman@linaro.org> Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-17ARM: tegra: Move includes to include/soc/tegraThierry Reding
In order to not clutter the include/linux directory with SoC specific headers, move the Tegra-specific headers out into a separate directory. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-04-05Merge tag 'drivers-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Arnd Bergmann: "These changes are mostly for ARM specific device drivers that either don't have an upstream maintainer, or that had the maintainer ask us to pick up the changes to avoid conflicts. A large chunk of this are clock drivers (bcm281xx, exynos, versatile, shmobile), aside from that, reset controllers for STi as well as a large rework of the Marvell Orion/EBU watchdog driver are notable" * tag 'drivers-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (99 commits) Revert "dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac." Revert "net: stmmac: Add SOCFPGA glue driver" ARM: shmobile: r8a7791: Fix SCIFA3-5 clocks ARM: STi: Add reset controller support to mach-sti Kconfig drivers: reset: stih416: add softreset controller drivers: reset: stih415: add softreset controller drivers: reset: Reset controller driver for STiH416 drivers: reset: Reset controller driver for STiH415 drivers: reset: STi SoC system configuration reset controller support dts: socfpga: Add sysmgr node so the gmac can use to reference dts: socfpga: Add support for SD/MMC on the SOCFPGA platform reset: Add optional resets and stubs ARM: shmobile: r7s72100: fix bus clock calculation Power: Reset: Generalize qnap-poweroff to work on Synology devices. dts: socfpga: Update clock entry to support multiple parents ARM: socfpga: Update socfpga_defconfig dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac. net: stmmac: Add SOCFPGA glue driver watchdog: orion_wdt: Use %pa to print 'phys_addr_t' drivers: cci: Export CCI PMU revision ...
2014-02-18ARM: 7958/1: amba: Let runtime PM callbacks be available for CONFIG_PMUlf Hansson
Convert to the SET_PM_RUNTIME_PM macro while defining the runtime PM callbacks. This means the callbacks becomes available for both CONFIG_PM_SLEEP and CONFIG_PM_RUNTIME, which is needed by drivers and power domains. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-02-05drivers/amba: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-09ARM: 7916/1: amba: Add clk_prepare|unprepare in runtime PM callbacksUlf Hansson
To fully gate the clock and thus potentially also save more power in runtime suspend state, extend clock handling with clk_prepare|unprepare in the runtime PM callbacks. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-12-09ARM: 7915/1: amba: Convert to clk_prepare_enable and clk_disable_unprepareUlf Hansson
To simplify code and error handling let's use clk_prepare_enable and clk_disable_unprepare. No functional change. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-12-09ARM: 7914/1: amba: Drop legacy PM support and use the pm_generic functionsUlf Hansson
All AMBA drivers have converted to use the modern PM ops thus we can safely drop the legacy PM support from the bus. While using the modern PM ops it also makes sense to convert to use the pm_generic callback functions. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-31DMA-API: amba: get rid of separate dma_maskRussell King
AMBA Primecell devices always treat streaming and coherent DMA exactly the same, so there's no point in having the masks separated. Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-03PM / Runtime: Rework the "runtime idle" helper routineRafael J. Wysocki
The "runtime idle" helper routine, rpm_idle(), currently ignores return values from .runtime_idle() callbacks executed by it. However, it turns out that many subsystems use pm_generic_runtime_idle() which checks the return value of the driver's callback and executes pm_runtime_suspend() for the device unless that value is not 0. If that logic is moved to rpm_idle() instead, pm_generic_runtime_idle() can be dropped and its users will not need any .runtime_idle() callbacks any more. Moreover, the PCI, SCSI, and SATA subsystems' .runtime_idle() routines, pci_pm_runtime_idle(), scsi_runtime_idle(), and ata_port_runtime_idle(), respectively, as well as a few drivers' ones may be simplified if rpm_idle() calls rpm_suspend() after 0 has been returned by the .runtime_idle() callback executed by it. To reduce overall code bloat, make the changes described above. Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Kevin Hilman <khilman@linaro.org> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu>
2013-03-15ARM: 7675/1: amba: tegra-ahb: Fix build error w/ PM_SLEEP w/o PM_RUNTIMEHiroshi Doyu
Make this depend on CONFIG_PM. This protection is necessary to not cause any build errors with any combination of PM features especially when supporting a new SoC where each PM features are being enabled one-by-one during its depelopment. Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-03-03Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull late ARM updates from Russell King: "Here is the late set of ARM updates for this merge window; in here is: - The ARM parts of the broadcast timer support, core parts merged through tglx's tree. This was left over from the previous merge to allow the dependency on tglx's tree to be resolved. - A fix to the VFP code which shows up on Raspberry Pi's, as well as fixing the fallout from a previous commit in this area. - A number of smaller fixes scattered throughout the ARM tree" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: ARM: Fix broken commit 0cc41e4a21d43 corrupting kernel messages ARM: fix scheduling while atomic warning in alignment handling code ARM: VFP: fix emulation of second VFP instruction ARM: 7656/1: uImage: Error out on build of multiplatform without LOADADDR ARM: 7640/1: memory: tegra_ahb_enable_smmu() depends on TEGRA_IOMMU_SMMU ARM: 7654/1: Preserve L_PTE_VALID in pte_modify() ARM: 7653/2: do not scale loops_per_jiffy when using a constant delay clock ARM: 7651/1: remove unused smp_timer_broadcast #define
2013-02-21ARM: 7640/1: memory: tegra_ahb_enable_smmu() depends on TEGRA_IOMMU_SMMUHiroshi Doyu
New SoC, Tegra114 also uses SMMU. Change tegra_ahb_enable_smmu()'s dependency from ARCH_TEGRA_3x_SOC to TEGRA_IOMMU_SMMU. No need to edit whenever a new Tegra SoC comes. The following combination caused build error, which this patch fixes. CONFIG_ARCH_TEGRA_2x_SOC=y CONFIG_ARCH_TEGRA_114_SOC=y drivers/iommu/tegra-smmu.c:485: undefined reference to gra_ahb_enable_smmu' Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-25amba: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03Drivers: amba: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed, as well as the use of CONFIG_HOTPLUG. This patch does both, removing the use of CONFIG_HOTPLUG in the amba/bus.c file, and __devinit and __devinitconst in the tegra-ahb.c driver. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17Merge tag 'tegra-for-3.8-fixes-for-rc1' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into fixes ARM: tegra: fixes for 3.8 This branch contains a few miscellaneous fixes that have shown up in the last few weeks. By Sivaram Nair (2) and Hiroshi Doyu (1) via Stephen Warren * tag 'tegra-for-3.8-fixes-for-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra: amba: tegra-ahb: Fix warning w/o PM_SLEEP ARM: tegra: fix comment in dsib clk set_parent ARM: tegra: select correct parent clk for pll_p Signed-off-by: Olof Johansson <olof@lixom.net>
2012-12-12Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups on various subarchitectures from Olof Johansson: "Cleanup patches for various ARM platforms and some of their associated drivers. There's also a branch in here that enables Freescale i.MX to be part of the multiplatform support -- the first "big" SoC that is moved over (more multiplatform work comes in a separate branch later during the merge window)." Conflicts fixed as per Olof, including a silent semantic one in arch/arm/mach-omap2/board-generic.c (omap_prcm_restart() was renamed to omap3xxx_restart(), and a new user of the old name was added). * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (189 commits) ARM: omap: fix typo on timer cleanup ARM: EXYNOS: Remove unused regs-mem.h file ARM: EXYNOS: Remove unused non-dt support for dwmci controller ARM: Kirkwood: Use hw_pci.ops instead of hw_pci.scan ARM: OMAP3: cm-t3517: use GPTIMER for system clock ARM: OMAP2+: timer: remove CONFIG_OMAP_32K_TIMER ARM: SAMSUNG: use devm_ functions for ADC driver ARM: EXYNOS: no duplicate mask/unmask in eint0_15 ARM: S3C24XX: SPI clock channel setup is fixed for S3C2443 ARM: EXYNOS: Remove i2c0 resource information and setting of device names ARM: Kirkwood: checkpatch cleanups ARM: Kirkwood: Fix sparse warnings. ARM: Kirkwood: Remove unused includes ARM: kirkwood: cleanup lsxl board includes ARM: integrator: use BUG_ON where possible ARM: integrator: push down SC dependencies ARM: integrator: delete static UART1 mapping ARM: integrator: delete SC mapping on the CP ARM: integrator: remove static CP syscon mapping ARM: integrator: remove static AP syscon mapping ...
2012-12-03ARM: 7588/1: amba: create a resource parent registratorLinus Walleij
This creates amba_apb_device_add_res() and amba_ahb_device_add_res() respectively, to add devices with another parent than iomem_resource. This is needed to specify that a device is contained in a specific IO range. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-11-26amba: tegra-ahb: Fix warning w/o PM_SLEEPHiroshi Doyu
Fix build warning w/o PM_SLEEP. Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-05ARM: tegra: move tegra-ahb.h out of arch/arm/mach-tegra/Stephen Warren
We wish to empty arch/arm/mach-tegra/include/mach/ as much as possible to enable single zImage. Move tegra-ahb.h to a more central location (suggested by Arnd, OK'd by Greg KH), and actually make tegra-ahb.c include the header to ensure client and provider agree on the prototype. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-07-27Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "First ARM push of this merge window, post me coming back from holiday. This is what has been in linux-next for the last few weeks. Not much to say which isn't described by the commit summaries." * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (32 commits) ARM: 7463/1: topology: Update cpu_power according to DT information ARM: 7462/1: topology: factorize the update of sibling masks ARM: 7461/1: topology: Add arch_scale_freq_power function ARM: 7456/1: ptrace: provide separate functions for tracing syscall {entry,exit} ARM: 7455/1: audit: move syscall auditing until after ptrace SIGTRAP handling ARM: 7454/1: entry: don't bother with syscall tracing on ret_from_fork path ARM: 7453/1: audit: only allow syscall auditing for pure EABI userspace ARM: 7452/1: delay: allow timer-based delay implementation to be selected ARM: 7451/1: arch timer: implement read_current_timer and get_cycles ARM: 7450/1: dcache: select DCACHE_WORD_ACCESS for little-endian ARMv6+ CPUs ARM: 7449/1: use generic strnlen_user and strncpy_from_user functions ARM: 7448/1: perf: remove arm_perf_pmu_ids global enumeration ARM: 7447/1: rwlocks: remove unused branch labels from trylock routines ARM: 7446/1: spinlock: use ticket algorithm for ARMv6+ locking implementation ARM: 7445/1: mm: update CONTEXTIDR register to contain PID of current process ARM: 7444/1: kernel: add arch-timer C3STOP feature ARM: 7460/1: remove asm/locks.h ARM: 7439/1: head.S: simplify initial page table mapping ARM: 7437/1: zImage: Allow DTB command line concatenation with ATAG_CMDLINE ARM: 7436/1: Do not map the vectors page as write-through on UP systems ...
2012-06-28ARM: 7431/1: amba: use the new linux/sizes.hAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Giancarlo Asnaghi <giancarlo.asnaghi@st.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-06-11amba: tegra-ahb: Remove empty *_remove()hdoyu@nvidia.com
Remove unnecessary empty function. Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-05-26Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc driver specific updates from Olof Johansson: "These changes are specific to some driver that may be used by multiple boards or socs. The most significant change in here is the move of the samsung iommu code from a platform specific in-kernel interface to the generic iommu subsystem." Fix up trivial conflicts in arch/arm/mach-exynos/Kconfig * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits) mmc: dt: Consolidate DT bindings iommu/exynos: Add iommu driver for EXYNOS Platforms ARM: davinci: optimize the DMA ISR ARM: davinci: implement DEBUG_LL port choice ARM: tegra: Add SMMU enabler in AHB ARM: tegra: Add Tegra AHB driver Input: pxa27x_keypad add choice to set direct_key_mask Input: pxa27x_keypad direct key may be low active Input: pxa27x_keypad bug fix for direct_key_mask Input: pxa27x_keypad keep clock on as wakeup source ARM: dt: tegra: pinmux changes for USB ULPI ARM: tegra: add USB ULPI PHY reset GPIO to device tree ARM: tegra: don't hard-code USB ULPI PHY reset_gpio ARM: tegra: change pll_p_out4's rate to 24MHz ARM: tegra: fix pclk rate ARM: tegra: reparent sclk to pll_c_out1 ARM: tegra: Add pllc clock init table ARM: dt: tegra cardhu: basic audio support ARM: dt: tegra30.dtsi: Add audio-related nodes ARM: tegra: add AUXDATA required for audio ...
2012-05-08ARM: tegra: Add SMMU enabler in AHBHiroshi DOYU
Add extern func, "tegra_ahb_enable_smmu()" to inform AHB that SMMU is ready. Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-05-08ARM: tegra: Add Tegra AHB driverHiroshi DOYU
Tegra AHB Bus conforms to the AMBA Specification (Rev 2.0) Advanced High-performance Bus (AHB) architecture. The AHB Arbiter controls AHB bus master arbitration. This effectively forms a second level of arbitration for access to the memory controller through the AHB Slave Memory device. The AHB pre-fetch logic can be configured to enhance performance for devices doing sequential access. Each AHB master is assigned to either the high or low priority bin. Both Tegra20/30 have this AHB bus. Some of configuration params could be passed from DT too if needed. Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-05-03AMBA: get rid of last two uses of NO_IRQRussell King
This gets rid of the last two users of NO_IRQ in AMBA primecell drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-19ARM: 7369/1: amba: add functions to add devices dynamicallyLinus Walleij
Add two functions to add APB and AHB devices to the amba (PrimeCell) bus dynamically. This is modeled after the static definition macros recently introduced into <linux/amba/bus.h> and can help us in factoring out a bunch of code across the kernel. Since a lot of call sites seem to be using a returned struct amba device* pointer, let's use that. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
