path: root/drivers/android
2015-03-01android: binder: fix binder mmap failuresAndrey Ryabinin
binder_update_page_range() initializes only addr and size fields in 'struct vm_struct tmp_area;' and passes it to map_vm_area(). Before 71394fe50146 ("mm: vmalloc: add flag preventing guard hole allocation") this was because map_vm_area() didn't use any other fields in vm_struct except addr and size. Now get_vm_area_size() (used in map_vm_area()) reads vm_struct's flags to determine whether vm area has guard hole or not. binder_update_page_range() don't initialize flags field, so this causes following binder mmap failures: -----------[ cut here ]------------ WARNING: CPU: 0 PID: 1971 at mm/vmalloc.c:130 vmap_page_range_noflush+0x119/0x144() CPU: 0 PID: 1971 Comm: healthd Not tainted 4.0.0-rc1-00399-g7da3fdc-dirty #157 Hardware name: ARM-Versatile Express [<c001246d>] (unwind_backtrace) from [<c000f7f9>] (show_stack+0x11/0x14) [<c000f7f9>] (show_stack) from [<c049a221>] (dump_stack+0x59/0x7c) [<c049a221>] (dump_stack) from [<c001cf21>] (warn_slowpath_common+0x55/0x84) [<c001cf21>] (warn_slowpath_common) from [<c001cfe3>] (warn_slowpath_null+0x17/0x1c) [<c001cfe3>] (warn_slowpath_null) from [<c00c66c5>] (vmap_page_range_noflush+0x119/0x144) [<c00c66c5>] (vmap_page_range_noflush) from [<c00c716b>] (map_vm_area+0x27/0x48) [<c00c716b>] (map_vm_area) from [<c038ddaf>] (binder_update_page_range+0x12f/0x27c) [<c038ddaf>] (binder_update_page_range) from [<c038e857>] (binder_mmap+0xbf/0x1ac) [<c038e857>] (binder_mmap) from [<c00c2dc7>] (mmap_region+0x2eb/0x4d4) [<c00c2dc7>] (mmap_region) from [<c00c3197>] (do_mmap_pgoff+0x1e7/0x250) [<c00c3197>] (do_mmap_pgoff) from [<c00b35b5>] (vm_mmap_pgoff+0x45/0x60) [<c00b35b5>] (vm_mmap_pgoff) from [<c00c1f39>] (SyS_mmap_pgoff+0x5d/0x80) [<c00c1f39>] (SyS_mmap_pgoff) from [<c000ce81>] (ret_fast_syscall+0x1/0x5c) ---[ end trace 48c2c4b9a1349e54 ]--- binder: 1982: binder_alloc_buf failed to map page at f0e00000 in kernel binder: binder_mmap: 1982 b6bde000-b6cdc000 alloc small buf failed -12 Use map_kernel_range_noflush() instead of map_vm_area() as this is better API for binder's purposes and it allows to get rid of 'vm_struct tmp_area' at all. Fixes: 71394fe50146 ("mm: vmalloc: add flag preventing guard hole allocation") Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Reported-by: Amit Pundir <amit.pundir@linaro.org> Tested-by: Amit Pundir <amit.pundir@linaro.org> Acked-by: David Rientjes <rientjes@google.com> Tested-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-25Add security hooks to binder and implement the hooks for SELinux.Stephen Smalley
Add security hooks to the binder and implement the hooks for SELinux. The security hooks enable security modules such as SELinux to implement controls over binder IPC. The security hooks include support for controlling what process can become the binder context manager (binder_set_context_mgr), controlling the ability of a process to invoke a binder transaction/IPC to another process (binder_transaction), controlling the ability of a process to transfer a binder reference to another process (binder_transfer_binder), and controlling the ability of a process to transfer an open file to another process (binder_transfer_file). These hooks have been included in the Android kernel trees since Android 4.3. (Updated to reflect upstream relocation and changes to the binder driver, changes to the LSM audit data structures, coding style cleanups, and to add inline documentation for the hooks). Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Nick Kralevich <nnk@google.com> Acked-by: Jeffrey Vander Stoep <jeffv@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20android: binder: remove binder.hGreg Kroah-Hartman
binder.h isn't needed to just include a uapi file and set a single define, so move it into binder.c to save a few lines of code. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20staging: android: binder: move to the "real" part of the kernelGreg Kroah-Hartman
The Android binder code has been "stable" for many years now. No matter what comes in the future, we are going to have to support this API, so might as well move it to the "real" part of the kernel as there's no real work that needs to be done to the existing code. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
