commit b2a6d1b999a4c13e5997bb864694e77172d45250 upstream.
Commit c4ea41ba195d ("binder: use group leader instead of open thread")'
was incomplete and didn't update a check in binder_mmap(), causing all
mmap() calls into the binder driver to fail.
Signed-off-by: Martijn Coenen <maco@android.com>
Tested-by: John Stultz <john.stultz@linaro.org>
commit 00b40d613352c623aaae88a44e5ded7c912909d7 upstream.
Use wake_up_interruptible_sync() to hint to the scheduler binder
transactions are synchronous wakeups. Disable preemption while waking
to avoid ping-ponging on the binder lock.
Signed-off-by: Todd Kjos <tkjos@google.com>
Signed-off-by: Omprakash Dhyade <odhyade@codeaurora.org>
commit c4ea41ba195d01c9af66fb28711a16cc97caa9c5 upstream.
The binder allocator assumes that the thread that
called binder_open will never die for the lifetime of
that proc. That thread is normally the group_leader,
however it may not be. Use the group_leader instead
of current.
commit a2b18708ee14baec4ef9c0fba96070bba14d0081 upstream.
This reverts commit a906d6931f3ccaf7de805643190765ddd7378e27.
The patch introduced a race in the binder driver. An attempt to fix the
race was submitted in "[PATCH v2] android: binder: fix dangling pointer
comparison", however the conclusion in the discussion for that patch
was that the original patch should be reverted.
The reversion is being done as part of the fine-grained locking
patchset since the patch would need to be refactored when
proc->vmm_vm_mm is removed from struct binder_proc and added
in the binder allocator.
struct
Prevents leaking pointers between processes
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Cc: stable <stable@vger.kernel.org>
Prevent using a binder_ref with only weak references where a strong
reference is required.
The workqueue is being used to run deferred work for the android binder.
The "binder_deferred_workqueue" queues only a single work item and hence
does not require ordering. Also, this workqueue is not being used on a
memory recliam path. Hence, the singlethreaded workqueue has been
replaced with the use of system_wq.
System workqueues have been able to handle high level of concurrency
for a long time now and hence it's not required to have a singlethreaded
workqueue just to gain concurrency. Unlike a dedicated per-cpu workqueue
created with create_singlethread_workqueue(), system_wq allows multiple
work items to overlap executions even on the same CPU; however, a
per-cpu workqueue doesn't have any CPU locality or global ordering
guarantee unless the target CPU is explicitly specified and thus the
increase of local concurrency shouldn't make any difference.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
We want the staging fixes in here as well.
This resolves the merge issues and confusions people were having with
the goldfish drivers due to changes for them showing up in two different
trees.
BC_DEAD_BINDER_DONE
There's one point was missed in the patch commit da49889deb34 ("staging:
binder: Support concurrent 32 bit and 64 bit processes."). When configure
BINDER_IPC_32BIT, the size of binder_uintptr_t was 32bits, but size of
void * is 64bit on 64bit system. Correct it here.
Signed-off-by: Lisa Du <cldu@marvell.com>
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Fixes: da49889deb34 ("staging: binder: Support concurrent 32 bit and 64 bit processes.")
Cc: <stable@vger.kernel.org>
Acked-by: Olof Johansson <olof@lixom.net>
If a /d/binder/proc/[pid] entry is kept open after linux has
torn down the associated process, binder_proc_show can deference
an invalid binder_proc that has been stashed in the debugfs
inode. Validate that the binder_proc ptr passed into binder_proc_show
has not been freed by looking for it within the global process list
whilst the global lock is held. If the ptr is not valid, print nothing.
Cc: Colin Cross <ccross@android.com>
Cc: Arve Hjønnevåg <arve@android.com>
Cc: Dmitry Shmidt <dimitrysh@google.com>
Cc: Rom Lemarchand <romlem@google.com>
Cc: Serban Constantinescu <serban.constantinescu@arm.com>
Cc: Android Kernel Team <kernel-team@android.com>
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
[jstultz: Minor commit message tweaks]
Signed-off-by: John Stultz <john.stultz@linaro.org>
Make sure offsets don't point to overlapping flat_binder_object
structs.
Sanity check at binder ioctl function,
Only allow the shared mm_struct to use the same binder-object
to do binder operate.
And add proc->vma_vm_mm = current->mm at the open function.
The libbinder do ioctl before mmap called.
V2: Fix compile error for error commit
V3: Change the condition to proc->vma_vm_mm
Signed-off-by: Chen Feng <puck.chen@hisilicon.com>
Signed-off-by: Wei Dong <weidong2@hisilicon.com>
Signed-off-by: Junmin Zhao <zhaojunmin@huawei.com>
Reviewed-by: Zhuangluan Su <suzhuangluan@hisilicon.com>
With two exceptions (drm/qxl and drm/radeon) all vm_operations_struct
structs should be constant.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Minchan Kim <minchan@kernel.org>
binder_update_page_range() initializes only addr and size
fields in 'struct vm_struct tmp_area;' and passes it to
map_vm_area().
Before 71394fe50146 ("mm: vmalloc: add flag preventing guard hole allocation")
this was because map_vm_area() didn't use any other fields
in vm_struct except addr and size.
Now get_vm_area_size() (used in map_vm_area()) reads vm_struct's
flags to determine whether vm area has guard hole or not.
binder_update_page_range() don't initialize flags field, so
this causes following binder mmap failures:
-----------[ cut here ]------------
WARNING: CPU: 0 PID: 1971 at mm/vmalloc.c:130
vmap_page_range_noflush+0x119/0x144()
CPU: 0 PID: 1971 Comm: healthd Not tainted 4.0.0-rc1-00399-g7da3fdc-dirty #157
Hardware name: ARM-Versatile Express
[<c001246d>] (unwind_backtrace) from [<c000f7f9>] (show_stack+0x11/0x14)
[<c000f7f9>] (show_stack) from [<c049a221>] (dump_stack+0x59/0x7c)
[<c049a221>] (dump_stack) from [<c001cf21>] (warn_slowpath_common+0x55/0x84)
[<c001cf21>] (warn_slowpath_common) from [<c001cfe3>]
(warn_slowpath_null+0x17/0x1c)
[<c001cfe3>] (warn_slowpath_null) from [<c00c66c5>]
(vmap_page_range_noflush+0x119/0x144)
[<c00c66c5>] (vmap_page_range_noflush) from [<c00c716b>] (map_vm_area+0x27/0x48)
[<c00c716b>] (map_vm_area) from [<c038ddaf>]
(binder_update_page_range+0x12f/0x27c)
[<c038ddaf>] (binder_update_page_range) from [<c038e857>]
(binder_mmap+0xbf/0x1ac)
[<c038e857>] (binder_mmap) from [<c00c2dc7>] (mmap_region+0x2eb/0x4d4)
[<c00c2dc7>] (mmap_region) from [<c00c3197>] (do_mmap_pgoff+0x1e7/0x250)
[<c00c3197>] (do_mmap_pgoff) from [<c00b35b5>] (vm_mmap_pgoff+0x45/0x60)
[<c00b35b5>] (vm_mmap_pgoff) from [<c00c1f39>] (SyS_mmap_pgoff+0x5d/0x80)
[<c00c1f39>] (SyS_mmap_pgoff) from [<c000ce81>] (ret_fast_syscall+0x1/0x5c)
---[ end trace 48c2c4b9a1349e54 ]---
binder: 1982: binder_alloc_buf failed to map page at f0e00000 in kernel
binder: binder_mmap: 1982 b6bde000-b6cdc000 alloc small buf failed -12
Use map_kernel_range_noflush() instead of map_vm_area() as this is better
API for binder's purposes and it allows to get rid of 'vm_struct tmp_area' at all.
Fixes: 71394fe50146 ("mm: vmalloc: add flag preventing guard hole allocation")
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Reported-by: Amit Pundir <amit.pundir@linaro.org>
Tested-by: Amit Pundir <amit.pundir@linaro.org>
Acked-by: David Rientjes <rientjes@google.com>
Add security hooks to the binder and implement the hooks for SELinux.
The security hooks enable security modules such as SELinux to implement
controls over binder IPC. The security hooks include support for
controlling what process can become the binder context manager
(binder_set_context_mgr), controlling the ability of a process
to invoke a binder transaction/IPC to another process (binder_transaction),
controlling the ability of a process to transfer a binder reference to
another process (binder_transfer_binder), and controlling the ability
of a process to transfer an open file to another process (binder_transfer_file).
These hooks have been included in the Android kernel trees since Android 4.3.
(Updated to reflect upstream relocation and changes to the binder driver,
changes to the LSM audit data structures, coding style cleanups, and
to add inline documentation for the hooks).
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Nick Kralevich <nnk@google.com>
Acked-by: Jeffrey Vander Stoep <jeffv@google.com>
binder.h isn't needed to just include a uapi file and set a single
define, so move it into binder.c to save a few lines of code.
The Android binder code has been "stable" for many years now. No matter
what comes in the future, we are going to have to support this API, so
might as well move it to the "real" part of the kernel as there's no
real work that needs to be done to the existing code.
