path: root/drivers/ata/Kconfig
2012-09-13ata: add platform driver for Calxeda AHCI controllerMark Langsdorf
Calxeda highbank SATA phy has intermittent problems bringing up a link with Gen3 drives. Retrying the phy hard reset can work-around this issue, but each reset also disables spread spectrum support. The reset function also needs to reprogram the phy to enable spread spectrum support. Create a new driver based on ahci_platform to support the Calxeda Highbank SATA controller. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-08-17[libata] Kconfig: Elaborate that SFF is meant for legacy and PATA stuffPaul Menzel
Building Linux for an ASUS Eee PC 701 4G with ata2.00: CFA: SILICONMOTION SM223AC, , max UDMA/66 ata2.00: 7815024 sectors, multi 0: LBA ata2.00: configured for UDMA/66 scsi 1:0:0:0: Direct-Access ATA SILICONMOTION SM n/a PQ: 0 ANSI: 5 sd 1:0:0:0: [sda] 7815024 512-byte logical blocks: (4.00 GB/3.72 GiB) sd 1:0:0:0: [sda] Write Protect is off sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00 sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA sda: sda1 sd 1:0:0:0: [sda] Attached SCSI disk sd 1:0:0:0: Attached scsi generic sg0 type 0 I followed the advice to not use the deprecated old PATA subsystem ATA/ATAPI/MFM/RLL support (DEPRECATED) ---> and use the ATA subsystem instead. Serial ATA and Parallel ATA drivers ---> Unfortunately I needed several tries to find out, that I needed the SFF menu I had not selected before because I had never heard that term before. I think it would have helped me, to have PATA or legacy IDE in that item’s name. Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-05-22PATA host controller driver for ep93xxRafal Prylowski
Add PATA host controller driver for ep93xx. Signed-off-by: Rafal Prylowski <prylowski@metasoft.pl> Cc: Joao Ramos <joao.ramos@inov.pt> Cc: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-01-08pata_of_platform: remove direct dependency on OF_IRQRob Herring
CONFIG_OF_IRQ is not available on some platforms and using of_irq_* breaks the build. Since resources are already populated in the platform device, get the irq from there instead. Reported-by: David S. Miller <davem@davemloft.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-12-22pata_of_platform: Add missing CONFIG_OF_IRQ dependency.David Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-10-14libata: remove no longer needed pata_qdi driverBartlomiej Zolnierkiewicz
QDI65x0 controllers are fully supported by pata_legacy driver so remove no longer needed pata_qdi driver. Leave PATA_QDI config option for compatibility reasons and teach pata_legacy to preserve the old behavior of pata_qdi driver. Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-10-08ata: Make pata_of_platform.c compile again and work on non-PPC platformsPawel Moll
This patch adds missing #includes, makes the driver selectable on non-PPC OF-enabled platforms and fixes property value accesses to be correct in Little Endian system. Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-08-18ata: Add iMX pata supportArnaud Patard (Rtp)
Add basic support for pata on iMX. It has been tested only on imx51. SDMA support will probably be added later so this version supports only PIO. v2: - enable only when needed IORDY - use dev_get_drvdata v3: - add missing clk_put() calls - use platform_get_irq() - fix resume code to avoid disabling IORDY on resume v4: - Remove EXPERIMENTAL and switch to depends on ARCH_MXC - Use devm_kzalloc() - make clock a must-have - Use only 1 ioremap Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-07-23ata: PATA_ARASAN_CF depends on DMADEVICESRandy Dunlap
Fix kconfig unmet dependency warning: warning: (PATA_ARASAN_CF && VIDEO_TIMBERDALE && SND_SOC_SH4_SIU) selects DMA_ENGINE which has unmet direct dependencies (DMADEVICES) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-14pata_arasan_cf: Adding support for arasan compact flash host controllerViresh Kumar
The Arasan CompactFlash Device Controller has three basic modes of operation: PC card ATA using I/O mode, PC card ATA using memory mode, PC card ATA using true IDE modes. Currently driver supports only True IDE mode. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-02sata_dwc_460ex: add debugging optionsSergei Shtylyov
The driver makes use of the two options (CONFIG_SATA_DWC_[V]DEBUG) to enable the debug output but they both are absent in drivers/ata/Kconfig... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07pata_platform: Remove CONFIG_HAVE_PATA_PLATFORM's dependencies.Nick Bowler
CONFIG_HAVE_PATA_PLATFORM, by virtue of where its defined, has a dependency on CONFG_ATA and CONFIG_ATA_SFF. This causes Kconfig warnings when it is selected by various architectures, such as warning: (ARCH_VEXPRESS && <choice> || ARCH_RPC && <choice> || MACH_VPAC270 && ARCH_PXA || MACH_REALVIEW_PB11MP && ARCH_REALVIEW || MACH_REALVIEW_PBA8 && ARCH_REALVIEW || MACH_REALVIEW_PBX && ARCH_REALVIEW || MACH_BAST_IDE && ARCH_S3C2410 || MACH_ANUBIS && ARCH_S3C2410) selects HAVE_PATA_PLATFORM which has unmet direct dependencies (ATA && ATA_SFF) Since this option is only used to control visibility of the CONFIG_PATA_PLATFORM option and isn't itself visible in the menu, it is straightforward to simply remove these dependencies rather than adjust all the architectures. Signed-off-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-01-07pata_hpt3x2n: clarify about HPT371N supportSergei Shtylyov
Commit 28e21c8c0d44cd63bad4c62f94ef0c5a1cb8402c (pata_hpt3x2n: Add HPT371N support and other bits) forgot to update the driver's Kconfig entry, heading comment, and module description (that also wrongly claims support of HPT302) which may confuse users... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-01-05[libata] new driver acard_ahci, for ATP8620 host controllerDavid Milburn
Add support for Acard ATP8620 host controller. Based upon initial version by Jeff Garzik. Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-12-24pata_mpc52xx: driver needs BMDMAWolfram Sang
Found by this build-error if BMDMA is disabled: drivers/ata/pata_mpc52xx.c: In function 'mpc52xx_ata_init_one': drivers/ata/pata_mpc52xx.c:662: error: 'ata_bmdma_interrupt' undeclared (first use in this function) ... Move the Kconfig entry to the proper location as needed since 9a7780c9acb821fe1c2b6fc53f74cc2556ff5364 (libata-sff: make BMDMA optional) Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-12-24pata_cs5536: Add support for non-X86_32 platformsWu Zhangjin
pata_cs5536 does work on the other platforms(e.g. Loongson, a MIPS variant), so, remove the dependency of X86_32 and fix the building errors under the other platforms via only reserving the X86_32 specific parts for X86_32. pata_amd also supports cs5536 IDE controller, but this one saves about 33k for the compressed kernel image(vmlinuz for MIPS). Signed-off-by: Zhang Le <r0bertz@gentoo.org> Signed-off-by: Chen Jie <chenj@lemote.com> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-25libata: remove no longer needed pata_winbond driverBartlomiej Zolnierkiewicz
Winbond W83759A controller is fully supported by pata_legacy driver so remove no longer needed pata_winbond driver. Leave PATA_WINBOND_VLB config option for compatibility reasons and teach pata_legacy to preserve the old behavior of pata_winbond driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-10Merge branches 'master' and 'devel' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mm/Kconfig
2010-08-01[libata] Add Samsung PATA controller driver, pata_samsung_cfAbhilash Kesavan
Adds support for the Samsung PATA controller. This driver is based on the Libata subsystem and references the earlier patches sent for IDE subsystem. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Sergei Shtylyov <sshtylyov@mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-01[libata] Add 460EX on-chip SATA driver, sata_dwc_460exRupjyoti Sarmah
This patch enables the on-chip DWC SATA controller of the AppliedMicro processor 460EX. Signed-off-by: Rupjyoti Sarmah <rsarmah@appliedmicro.com> Signed-off-by: Mark Miesfeld <mmiesfeld@appliedmicro.com> Signed-off-by: Prodyut Hazarika <phazarika@appliedmicro.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-06-18[ARM] pata_pxa: DMA-capable PATA driverMarek Vasut
This patch adds a driver for a harddrive attached to PXA address and data bus. Unlike pata_platform, this driver allows usage of PXA DMA controller, making the transmission speed 3x higher. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-06-02libata-sff: trivial corrections to Kconfig help textStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: make BMDMA optionalTejun Heo
Make BMDMA optional depending on new config variable CONFIG_ATA_BMDMA. In Kconfig, drivers are grouped into five groups - non-SFF native, SFF w/ custom DMA interface, SFF w/ BMDMA, PIO-only SFF, and generic fallback / legacy ones. Kconfig and Makefile are reorganized according to the groups and ordered alphabetically inside each group. ata_ioports.bmdma_addr and ata_port.bmdma_prd[_dma] are put into CONFIG_ATA_BMDMA, as are all bmdma related ops, variables and functions. This increase the binary size slightly when BMDMA is enabled but on both native-only and PIO-only configurations the size is slightly reduced. Either way, the size difference is insignificant. This change is more meaningful to signify the separation between SFF and BMDMA and as a tool to verify the separation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14sata_inic162x: inic162x is not dependent on CONFIG_ATA_SFFTejun Heo
sata_inic162x no longer uses SFF interface. Move it out of CONFIG_ATA_SFF. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Add platform driverAnton Vorontsov
This can be used for AHCI-compatible interfaces implemented inside System-On-Chip solutions, or AHCI devices connected via localbus. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01libata: Allow pata_legacy to be built on non-ISA but PCI systemsAlan Cox
This is needed for some unsupported hardware setups on strange 64bit mainboards where crazy stuff has been done like putting flash ata adapters on the LPC bus, or where the real hardware is hidden/confused. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-24ACPI: do not select ACPI_DOCK from ATA_ACPICarlos R. Mafra
In March 2008 commit 0ac4a3c2fbbcadc3e96e4dc47d4ae802d66e6f67 ("ACPI: fix ATA_ACPI build") made CONFIG_ACPI_DOCK be selected by CONFIG_ATA_ACPI because of a build error when CONFIG_ATA_ACPI=y and CONFIG_ACPI_DOCK=m. However, in September 2008 commit 898b054f3eec5921320ae8614b5bdd7b07ea5b43 ("dock: make dock driver not a module") removed the possibility of having CONFIG_ACPI_DOCK=m and therefore there is no need for selecting it when CONFIG_ATA_ACPI=y. This makes the kernel ~5 Kb smaller for people who don't have a dock by allowing them to not have ACPI_DOCK compiled-in because of ATA_ACPI=y. Signed-off-by: Carlos R. Mafra <crmafra@aei.mpg.de> Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-09Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Conflicts: include/linux/kvm.h
2009-12-09libata/drivers: Add driver for Apple "MacIO" IDE controllerBenjamin Herrenschmidt
This is a libata driver for the "macio" IDE controller used on most Apple PowerMac and PowerBooks. It's a libata equivalent of drivers/ide/ppc/pmac.c It supports all the features of its predecessor, including mediabay hotplug and suspend/resume. It should also support module load/unload. The timing calculations have been simplified to use pre-calculated tables compared to drivers/ide/pmac.c and it uses the new mediabay interface provided by a previous patch. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Tejun Heo <tj@kernel.org>
2009-12-03pata_piccolo: Driver for old Toshiba chipsetsAlan Cox
We were never able to get docs for this out of Toshiba for years. Dave Barnes produced a NetBSD driver however and from that we can fill in the needed tables. As we correct the PCI identifiers a bit also update the old ide generic driver at the same time so it stays compiling. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03[libata] PATA: Update experimental tagsAlan Cox
2009-12-03libata: remove experimental tag on PATA driversRobert Hancock
Remove the experimental tag on Parallel ATA drivers. Though some of the individual PATA drivers are still marked as experimental, as a group they can hardly be considered to be, given they've been used in various distros for some time. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-17libata: Add pata_atp867x driver for Artop/Acard ATP867X controllersJohn(Jung-Ik) Lee
This is a new pata driver for ARTOP 867X 64bit 4-channel UDMA133 ATA ctrls. Based on the Atp867 data sheet rev 1.2, Acard, and in part on early ide codes from Eric Uhrhane <ericu@google.com>. Signed-off-by: John(Jung-Ik) Lee <jilee@google.com> Reviewed-by: Grant Grundler <grundler@google.com> Reviewed-by: Gwendal Gringo <gwendal@google.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01[libata] Add pata_rdc driver for RDC ATA devicesAlan Cox
From: Alan Cox <alan@linux.intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01libata: add command name parsing for error outputRobert Hancock
This patch improve libata's output for error/notification messages to allow easier comprehension and debugging: When ATAPI commands issued through the SCSI layer fail, use SCSI functions to print the CDB in human-readable form instead of just dumping out the CDB in hex. Print out the name of the failed command (as defined by the ATA specification) in error handling output along with the raw register contents. When reporting status of ACPI taskfile commands executed on resume, also output the names of the commands being executed (or not) in readable form. Since the extra data for printing command names increases kernel size slightly, a config option has been added to allow disabling command name output (as well as some of the error register parsing) for those highly sensitive to kernel text size. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-23[libata] PATA driver for CF interface on AT91SAM9260 SoCSergey Matyukevich
This patch provides PATA driver for CompactFlash interface in True IDE mode on AT91SAM9260 SoC. Signed-off-by: Sergey Matyukevich <geomatsi@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-05-31[ARM] 5522/1: PalmLD: IDE supportMarek Vašut
Support for Palm LifeDrive's internal harddrive. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-26sata_mv: no longer experimental (v2)Mark Lord
Update Kconfig for sata_mv with full list of chips supported, and (finally!) remove the "EXPERIMENTAL" designations. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16libata: New driver for OCTEON SOC Compact Flash interface (v7).David Daney
Cavium OCTEON processor support was recently merged, so now we have this CF driver for your consideration. Most OCTEON variants have *no* DMA or interrupt support on the CF interface so for these, only PIO is supported. Although if DMA is available, we do take advantage of it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-21powerpc/mpc5200: Add MDMA/UDMA support to MPC5200 ATA driverTim Yamin
This patch adds MDMA/UDMA support using BestComm for DMA on the MPC5200 platform. Based heavily on previous work by Freescale (Bernard Kuhn, John Rigby) and Domen Puncer. With this patch, a SanDisk Extreme IV CF card gets read speeds of approximately 26.70 MB/sec. Signed-off-by: Tim Yamin <plasm@roo.me.uk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-12-09ata: Fix experimental tagsAlan Cox
Various tags are now way out of date Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: sound/core/memalloc.c
2008-09-29PATA: RPC now selects HAVE_PATA_PLATFORM for pata platform driverBen Dooks
The RPC machine type now selects HAVE_PATA_PLATFORM so we can remove the special case in the PATA_PLATFORM configuration code. Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6 Conflicts: arch/sparc64/kernel/pci_psycho.c
2008-09-08ahci, pata_marvell: play nicely togetherAlan Cox
I've been chasing Jeff about this for months. Jeff added the Marvell device identifiers to the ahci driver without making the AHCI driver handle the PATA port. This means a lot of users can't use current kernels and in most distro cases can't even install. This has been going on since March 2008 for the 6121 Marvell, and late 2007 for the 6145!!! This was all pointed out at the time and repeatedly ignored. Bugs assigned to Jeff about this are ignored also. To quote Jeff in email > "Just switch the order of 'ahci' and 'pata_marvell' in > /etc/modprobe.conf, then use Fedora's tools regenerate the initrd. > See? It's not rocket science, and the current configuration can be > easily made to work for Fedora users." (Which isn't trivial, isn't end user, shouldn't be needed, and as it usually breaks at install time is in fact impossible) To quote Jeff in August 2007 > " mv-ahci-pata > Marvell 6121/6141 PATA support. Needs fixing in the 'PATA controller > command' area before it is usable, and can go upstream." Only he add the ids anyway later and caused regressions, adding a further id in March causing more regresions. The actual fix for the moment is very simple. If the user has included the pata_marvell driver let it drive the ports. If they've only selected for SATA support give them the AHCI driver which will run the port a fraction faster. Allow the user to control this decision via ahci.marvell_enable as a module parameter so that distributions can ship 'it works' defaults and smarter users (or config tools) can then flip it over it desired. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-31sparc: remove CONFIG_SUN4Adrian Bunk
While doing some easy cleanups on the sparc code I noticed that the CONFIG_SUN4 code seems to be worse than the rest - there were some "I don't know how it should work, but the current code definitely cannot work." places. And while I have seen people running Linux on machines like a SPARCstation 5 a few years ago I don't recall having seen sun4 machines, even less ones running Linux. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-18LIBATA: Add HAVE_PATA_PLATFORM to select PATA_PLATFORM driverBen Dooks
Add HAVE_PATA_PLATFORM to select the pata platform driver to ensure that we do not end up with a long 'depends on' list when other users of this driver turn up. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-06sata_inic162x: update intro comment, up the version and drop EXPERIMENTALTejun Heo
sata_inic162x is now ready for production use. Bump the version, explain what's working and what's not and drop EXPERIMENTAL. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
