git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
- a number of libata core changes to better support NCQ TRIM.
- ahci now supports MSI-X in single IRQ mode to support a new
controller which doesn't implement MSI or INTX.
- ahci now supports edge-triggered IRQ mode to support a new controller
which for some odd reason did edge-triggered IRQ.
- the usual controller support additions and changes.
* 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (27 commits)
libata: Do not blacklist Micron M500DC
ata: ahci_mvebu: add suspend/resume support
ahci, msix: Fix build error for !PCI_MSI
ahci: Add support for Cavium's ThunderX host controller
ahci: Add generic MSI-X support for single interrupts to SATA PCI driver
libata: finally use __initconst in ata_parse_force_one()
drivers: ata: add support for Ceva sata host controller
devicetree:bindings: add devicetree bindings for ceva ahci
ahci: added support for Freescale AHCI sata
ahci: Store irq number in struct ahci_host_priv
ahci: Move interrupt enablement code to a separate function
Doc: libata: Fix spelling typo found in libata.xml
ata:sata_nv - Change 1 to true for bool type variable.
ata: add Broadcom AHCI SATA3 driver for STB chips
Documentation: devicetree: add Broadcom SATA binding
libata: Fix regression when the NCQ Send and Receive log page is absent
ata: hpt366: fix constant cast warning
ata: ahci_xgene: potential NULL dereference in probe
ata: ahci_xgene: Add AHCI Support for 2nd HW version of APM X-Gene SoC AHCI SATA Host controller.
libahci: Add support to handle HOST_IRQ_STAT as edge trigger latch.
It turned out the irq vector of the msix can be obtained from struct
msix_entry. This makes the lookup function for msi_desc obsolete.
This fixes a build error if PCI_MSI is unset:
drivers/ata/ahci.c: In function ‘msix_get_desc’:
drivers/ata/ahci.c:1210:2: error: ‘struct pci_dev’ has no member named ‘msi_list’
Catched by Fengguang's build bot.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Robert Richter <rrichter@cavium.com>
This patch adds support for Cavium's ThunderX host controller. The
controller resides on the SoC and is a AHCI compatible SATA controller
with one port, compliant with Serial ATA 3.1 and AHCI Revision 1.31.
There can exists multiple SATA controllers on the SoC.
The controller depends on MSI-X support since the PCI ECAM controller
on the SoC does not implement MSI nor lagacy intx interrupt support.
Thus, during device initialization, if MSI fails MSI-X will be used to
enable the device's interrupts.
The controller uses non-standard BAR0 for its register range. The
already existing device lookup (vendor and device id) that is already
implemented for other host controllers is used to change the PCI BAR.
This patch adds generic MSI-X support for single interrupts to the
SATA PCI driver. MSI-X support is needed for host controller that only
have MSI-X support implemented, but no MSI or intx. This patch only
adds support for single interrupts, multiple per-port MSI-X interrupts
are not yet implemented.
The new implementation still initializes MSIs first. Only if that
fails, the code tries to enable MSI-X. If that fails too, setup is
continued with intx interrupts.
To not break other chips by this generic code change, there are the
following precautions:
* Interrupt ranges are not enabled at all.
* Only single interrupt mode is enabled for msix cap devices. Thus,
only one interrupt will be setup.
* During the discussion with Tejun we agreed to change the init
sequence from msix-msi-intx to msi-msix-intx. Thus, if a device
offers msi and init does not fail, the msix init code will not be
executed. This is equivalent to current code.
With this, the code only setups single mode msix as a last resort if
msi fails. No interrupt range is enabled at all. Only one interrupt
will be enabled.
tj: comment edits.
Changes of the patch series:
v5:
* updated patch subject that the patch only implements single IRQ
* moved Cavium specific code to a separate patch
* detect Cavium ThunderX device with PCI_CLASS_STORAGE_SATA_AHCI
instead of vendor/dev id
* added more comments to the code
* enable single msix support for all kind of devices (removing strict
check)
* rebased onto update libata/for-4.2 with patch 1, 2 applied
v4:
* removed implementation of ahci_init_intx()
* improved patch descriptions
* rebased onto libata/for-4.2
v3:
* store irq number in struct ahci_host_priv
* change initialization order from msix-msi-intx to msi-msix-intx
* improve comments in ahci_init_msix()
* improve error message in ahci_init_msix()
* do not enable MSI-X if MSI is actively disabled for the device
v2:
* determine irq vector from pci_dev->msi_list
Based on a patch from Sunil Goutham <sgoutham@cavium.com>.
Currently, ahci supports only msi and intx. To also support msix the
handling of the irq number need to be changed. The irq number for msix
devices is taken from msi_list instead of pci_dev. Thus, the irq
number of a device needs to be stored in struct ahci_host_priv now.
This allows the host controller to be activated in a generic way.
This change is only intended for ahci drivers. For that reason the irq
number is stored in struct ahci_host_priv used only by ahci drivers.
Thus, the ABI changes only for ahci_host_activate(), but existing ata
drivers (about 50) are unaffected and keep unchanged. All users of
ahci_host_activate() have been updated.
While touching drivers/ata/libahci.c, doing a small code cleanup in
ahci_port_start().
This patch refactors ahci_init_interrupts() and moves msi code to a
separate function. Need the split since we add msix initialization in
a later patch. The initialization for msix will be done after msi but
before intx.
Avoton AHCI occasionally sees drive probe timeouts at driver load time.
When this happens SCR_STATUS indicates device detected, but no D2H FIS
reception. Reset the internal link state machines by bouncing
port-enable in the PCS register when this occurs.
Cc: <stable@vger.kernel.org>
Replace occurences of the pci api by appropriate call to the dma api.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
@deprecated@
idexpression id;
position p;
pci_dma_supported@p ( id, ...)
pci_alloc_consistent@p ( id, ...)
@bad1@
idexpression id;
position deprecated.p;
...when != &id->dev
when != pci_get_drvdata ( id )
when != pci_enable_device ( id )
@depends on !bad1@
idexpression id;
expression direction;
- pci_dma_supported@p ( id,
+ dma_supported ( &id->dev,
+ , GFP_ATOMIC
- pci_alloc_consistent@p ( id,
+ dma_alloc_coherent ( &id->dev,
+ , GFP_ATOMIC
Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com>
This patch removes a duplicate AHCI-mode SATA Device ID for the Intel Sunrise Point PCH.
Signed-off-by: James Ralston <james.d.ralston@intel.com>
Just like 0x1600 which got blacklisted by 66a7cbc303f4 ("ahci: disable
MSI instead of NCQ on Samsung pci-e SSDs on macbooks"), 0xa800 chokes
on NCQ commands if MSI is enabled. Disable MSI.
Reported-by: Dominik Mierzejewski <dominik@greysector.net>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=89171
Cc: stable@vger.kernel.org
This patch adds DeviceIDs for Sunrise Point-LP.
Signed-off-by: Devin Ryles <devin.ryles@intel.com>
Changes into the AHCI subsystem have introduced a bug by not taking into
account the force_port_map and mask_port_map parameters when using the
ahci_pci_save_initial_config function. This commit fixes it by setting
the internal parameters of the ahci_port_priv structure.
Fixes: 725c7b570fda
Reported-and-tested-by: Zlatko Calusic <zcalusic@bitsync.net>
Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com>
This patch adds the AHCI-mode SATA Device IDs for the Intel Sunrise Point PCH.
Samsung pci-e SSDs on macbooks failed miserably on NCQ commands, so
67809f85d31e ("ahci: disable NCQ on Samsung pci-e SSDs on macbooks")
disabled NCQ on them. It turns out that NCQ is fine as long as MSI is
not used, so let's turn off MSI and leave NCQ on.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=60731
Tested-by: <dorin@i51.org>
Tested-by: Imre Kaloz <kaloz@openwrt.org>
Fixes: 67809f85d31e ("ahci: disable NCQ on Samsung pci-e SSDs on macbooks")
Pull libata update from Tejun Heo:
"AHCI is getting per-port irq handling and locks for better
scalability. The gain is not huge but measureable with multiple high
iops devices connected to the same host; however, the value of
threaded IRQ handling seems negligible for AHCI and it likely will
revert to non-threaded handling soon.
Another noteworthy change is George Spelvin's "libata: Un-break ATA
blacklist". During 3.17 devel cycle, the libata blacklist glob
matching got generalized and rewritten; unfortunately, the patch
forgot to swap arguments to match the new match function and ended up
breaking blacklist matching completely. It got noticed only a couple
days ago so it couldn't make for-3.17-fixes either. :(
Other than the above two, nothing too interesting - the usual cleanup
churns and device-specific changes"
* 'for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (22 commits)
pata_serverworks: disable 64-KB DMA transfers on Broadcom OSB4 IDE Controller
libata: Un-break ATA blacklist
AHCI: Do not acquire ata_host::lock from single IRQ handler
AHCI: Optimize single IRQ interrupt processing
AHCI: Do not read HOST_IRQ_STAT reg in multi-MSI mode
AHCI: Make few function names more descriptive
AHCI: Move host activation code into ahci_host_activate()
AHCI: Move ahci_host_activate() function to libahci.c
AHCI: Pass SCSI host template as arg to ahci_host_activate()
ata: pata_imx: Use the SIMPLE_DEV_PM_OPS() macro
AHCI: Cleanup checking of multiple MSIs/SLM modes
libata-sff: Fix controllers with no ctl port
ahci_xgene: Fix the error print invalid resource for APM X-Gene SoC AHCI SATA Host Controller driver.
libata: change ata_<foo>_printk routines to return void
ata: qcom: Add device tree bindings information
ahci-platform: Bump max number of clocks to 5
ahci: ahci_p5wdh_workaround - constify DMI table
libahci_platform: Staticize ahci_platform_<en/dis>able_phys()
pata_platform: Remove useless irq_flags field
pata_of_platform: Remove "electra-ide" quirk
Currently host activation done by calling either function
ahci_host_activate() or ata_host_activate(). Consolidate
the code by only calling ahci_host_activate() for all AHCI
devices.
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Cc: linux-ide@vger.kernel.org
This update is a prerequisite for consolidation of
AHCI host activation code within ahci_host_activate()
function.
function.
Sharing Last Message (SLM) mode is currently checked in two
functions: ahci_host_activate() and ahci_init_interrupts().
This update consolidates SLM mode check with activation of
multiple MSIs mode.
Keystone K2E EVM uses Marvel 0x9182 controller. This requires support
for the ID in the ahci driver.
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
After enabled the PM feature that supporting async noirq(76569faa62
(PM / sleep: Asynchronous threads for resume_noirq)),
Jay hit the system resuming issue, that one of the JMicron controller
can not be powered up.
His device tree is like below:
+-1c.4-[02]--+-00.0 JMicron Technology Corp. JMB363 SATA/IDE Controller
| \-00.1 JMicron Technology Corp. JMB363 SATA/IDE Controller
After investigation, we found the the Micron chip 363 included
one SATA controller(0000:02:00.0) and one PATA controller(0000:02:00.1),
these two controllers do not have parent-children relationship,
but the PATA controller only can be powered on after the SATA controller
has finished the powering on.
If we enabled the async noirq(), then the below error is hit during noirq
phase:
pata_jmicron 0000:02:00.1: Refused to change power state, currently in D3
Here for JMicron chip 363/361, we need forcedly to disable the async method.
Bug detail: https://bugzilla.kernel.org/show_bug.cgi?id=81551
Reported-by: Jay <MyMailClone@t-online.de>
Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
The DMI table does not need to be written to, make it r/o.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
This patch adds the AHCI mode SATA Device IDs for the Intel 9 Series PCH.
This patch moves force_port_map and mask_port_map into the
ahci_host_priv structure. This allows to modify them into the AHCI
framework. This is needed by the new dt bindings representing ports as
the port_map mask is computed automatically.
Parameters modifying force_port_map, mask_port_map and flags have been
removed from the ahci_platform_init_host() function, and inputs in the
ahci_host_priv structure are now directly filed.
Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com>
Add support of the Promise FastTrak TX8660 SATA HBA in ahci mode by
registering the board in the ahci_pci_tbl[].
Note: this HBA also provide a hardware RAID mode when activated in
BIOS but specific drivers from the manufacturer are required in this
case.
Signed-off-by: Romain Degez <romain.degez@gmail.com>
Tested-by: Romain Degez <romain.degez@gmail.com>
"Nothing too interesting - another ahci platform driver variant,
additional controller support, minor fixes and cleanups"
* 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ahci: Add Device ID for HighPoint RocketRaid 642L
ata: ep93xx: use dmaengine_prep_slave_sg api instead of internal callback
ahci: add PCI ID for Marvell 88SE91A0 SATA Controller
sata_fsl: remove check for CONFIG_MPC8315_DS
ahci: add support for Hisilicon sata
libahci_platform: add host_flags parameter in ahci_platform_init_host()
ata: ahci: append new hflag AHCI_HFLAG_NO_FBS
ata: use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable in host drivers
ata: ahci_mvebu: new driver for Marvell Armada 380 AHCI interfaces
Documentation: dt-bindings: reformat and order list of ahci-platform compatibles
libata-sff: remove dead code
ata: SATL compliance for Inquiry Product Revision
pata_octeon_cf: use devm_kzalloc() to allocate cf_port
This device normally comes with a proprietary driver, using a web GUI
to configure RAID:
http://www.highpoint-tech.com/USA_new/series_rr600-download.htm
But thankfully it also works out of the box with the AHCI driver,
being just a Marvell 88SE9235.
Devices 640L, 644L, 644LS should also be supported but not tested here.
Signed-off-by: Jérôme Carretero <cJ-ko@zougloub.eu>
Add support for Marvell Technology Group Ltd. 88SE91A0 SATA 6Gb/s
Controller by adding its PCI ID.
Signed-off-by: Andreas Schrägle <ajs124.ajs124@gmail.com>
On Intel Valleyview SoC, SATA device sleep is not reliable. When
DEVSLP is attempted on certain SSDs, port_devslp write would fail
and result in malfunction of AHCI controller. AHCI controller may
be not shown in PCI enumeration after reset. Complete power source
removal may be required to recover from this failure. So we blacklist
this device and override host device reported capabilities such that
device LPM will only attempt slumber but not DEVSLP.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
In multiple MSI mode all AHCI ports (including dummy) get assigned
separate MSI vectors and (as result of execution
pci_enable_msi_exact() function) separate IRQ numbers, (mapped to the
MSI vectors).
Therefore, although interrupts from dummy ports are not desired they
are still enabled. We do not request IRQs for dummy ports, but that
only means we do not assign AHCI-specific ISRs to corresponding IRQ
numbers.
As result, dummy port interrupts still could come and traverse all the
way from the PCI device to the kernel, causing unnecessary overhead.
This update disables IRQs for dummy ports and prevents the described
issue.
Tested-by: David Milburn <dmilburn@redhat.com>
Fixes: 5ca72c4f7c41 ("AHCI: Support multiple MSIs")
The driver calls pci_enable_msi_range() function with the range of
[nvec..nvec] which is what pci_enable_msi_exact() function is for.
The AHCI specification allows hardware to choose to revert to
single MSI mode when fewer messages are allocated than requested.
Yet, at least ICH10 chipset reverts to single MSI mode even when
enough messages are allocated in some cases (see below).
This update forces the driver to not rely on initialization of
multiple MSIs mode alone and always check if "MSI Revert to
Single Message" (MRSM) mode was enforced by the controller and
fallback to the single MSI mode in case it did.
That prevents a situation when the driver configured multiple
per-port IRQ handlers, but the controller sends all port's
interrupts to a single IRQ, which could easily screw up the
interrupt handling and lead to delays and possibly crashes.
The fix was tested on a 6-port controller that successfully
reverted to the single MSI mode:
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA
AHCI Controller (prog-if 01 [AHCI 1.0])
Subsystem: Super Micro Computer Inc Device 10a7
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 101
I/O ports at f110 [size=8]
I/O ports at f100 [size=4]
I/O ports at f0f0 [size=8]
I/O ports at f0e0 [size=4]
I/O ports at f020 [size=32]
Memory at fbf00000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/16 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Capabilities: [b0] PCI Advanced Features
Kernel driver in use: ahci
With 6 ports just 8 MSI vectors should be enough, but the adapter
enforces the MRSM mode when less than 16 vectors are written to
the Multiple Messages Enable PCI register. I instigated MRSM mode
by forcing @nvec to 8 in ahci_init_interrupts().
System may crash in ahci_hw_interrupt() or ahci_thread_fn() when
accessing the interrupt status in a port's private_data if the port is
actually a DUMMY port.
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller
<snip console output for linux-3.15-rc1>
[ 9.352080] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x1 impl SATA mode
[ 9.352084] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ccc
[ 9.368155] Console: switching to colour frame buffer device 128x48
[ 9.439759] mgag200 0000:11:00.0: fb0: mgadrmfb frame buffer device
[ 9.446765] mgag200 0000:11:00.0: registered panic notifier
[ 9.470166] scsi1 : ahci
[ 9.479166] scsi2 : ahci
[ 9.488172] scsi3 : ahci
[ 9.497174] scsi4 : ahci
[ 9.506175] scsi5 : ahci
[ 9.515174] scsi6 : ahci
[ 9.518181] ata1: SATA max UDMA/133 abar m2048@0x95c00000 port 0x95c00100 irq 91
[ 9.526448] ata2: DUMMY
[ 9.529182] ata3: DUMMY
[ 9.531916] ata4: DUMMY
[ 9.534650] ata5: DUMMY
[ 9.537382] ata6: DUMMY
[ 9.576196] [drm] Initialized mgag200 1.0.0 20110418 for 0000:11:00.0 on minor 0
[ 9.845257] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 9.865161] ata1.00: ATAPI: Optiarc DVD RW AD-7580S, FX04, max UDMA/100
[ 9.891407] ata1.00: configured for UDMA/100
[ 9.900525] scsi 1:0:0:0: CD-ROM Optiarc DVD RW AD-7580S FX04 PQ: 0 ANSI: 5
[ 10.247399] iTCO_vendor_support: vendor-support=0
[ 10.261572] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 10.269764] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 10.301932] sd 0:2:0:0: [sda] 570310656 512-byte logical blocks: (291 GB/271 GiB)
[ 10.317085] sd 0:2:0:0: [sda] Write Protect is off
[ 10.328326] sd 0:2:0:0: [sda] Write cache: disabled, read cache: disabled, supports DPO and FUA
[ 10.375452] BUG: unable to handle kernel NULL pointer dereference at 000000000000003c
[ 10.384217] IP: [<ffffffffa0133df0>] ahci_hw_interrupt+0x100/0x130 [libahci]
[ 10.392101] PGD 0
[ 10.394353] Oops: 0000 [#1] SMP
[ 10.397978] Modules linked in: sr_mod(+) cdrom sd_mod iTCO_wdt crc_t10dif iTCO_vendor_support crct10dif_common ahci libahci libata lpc_ich mfd_core mgag200 syscopyarea sysfillrect sysimgblt i2c_algo_bit drm_kms_helper ttm drm i2c_core megaraid_sas dm_mirror dm_region_hash
dm_log dm_mod
[ 10.426499] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.15.0-rc1 #1
[ 10.433495] Hardware name: QCI QSSC-S4R/QSSC-S4R, BIOS QSSC-S4R.QCI.01.00.S013.032920111005 03/29/2011
[ 10.443886] task: ffffffff81906460 ti: ffffffff818f0000 task.ti: ffffffff818f0000
[ 10.452239] RIP: 0010:[<ffffffffa0133df0>] [<ffffffffa0133df0>] ahci_hw_interrupt+0x100/0x130 [libahci]
[ 10.462838] RSP: 0018:ffff880033c03d98 EFLAGS: 00010046
[ 10.468767] RAX: 0000000000a400a4 RBX: ffff880029a6bc18 RCX: 00000000fffffffa
[ 10.476731] RDX: 00000000000000a4 RSI: ffff880029bb0000 RDI: ffff880029a6bc18
[ 10.484696] RBP: ffff880033c03dc8 R08: 0000000000000000 R09: ffff88002f800490
[ 10.492661] R10: 0000000000000000 R11: 0000000000000005 R12: 0000000000000000
[ 10.500625] R13: ffff880029a6bd98 R14: 0000000000000000 R15: ffffc90000194000
[ 10.508590] FS: 0000000000000000(0000) GS:ffff880033c00000(0000) knlGS:0000000000000000
[ 10.517623] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 10.524035] CR2: 000000000000003c CR3: 00000000328ff000 CR4: 00000000000007b0
[ 10.531999] Stack:
[ 10.534241] 0000000000000017 ffff880031ba7d00 000000000000005c ffff880031ba7d00
[ 10.542535] 0000000000000000 000000000000005c ffff880033c03e10 ffffffff810c2a1e
[ 10.550827] ffff880031ae2900 000000008108fb4f ffff880031ae2900 ffff880031ae2984
[ 10.559121] Call Trace:
[ 10.561849] <IRQ>
[ 10.563994] [<ffffffff810c2a1e>] handle_irq_event_percpu+0x3e/0x1a0
[ 10.571309] [<ffffffff810c2bbd>] handle_irq_event+0x3d/0x60
[ 10.577631] [<ffffffff810c4fdd>] try_one_irq.isra.6+0x8d/0xf0
[ 10.584142] [<ffffffff810c5313>] note_interrupt+0x173/0x1f0
[ 10.590460] [<ffffffff810c2a8e>] handle_irq_event_percpu+0xae/0x1a0
[ 10.597554] [<ffffffff810c2bbd>] handle_irq_event+0x3d/0x60
[ 10.603872] [<ffffffff810c5727>] handle_edge_irq+0x77/0x130
[ 10.610199] [<ffffffff81014b8f>] handle_irq+0xbf/0x150
[ 10.616040] [<ffffffff8109ff4e>] ? vtime_account_idle+0xe/0x50
[ 10.622654] [<ffffffff815fca1a>] ? atomic_notifier_call_chain+0x1a/0x20
[ 10.630140] [<ffffffff816038cf>] do_IRQ+0x4f/0xf0
[ 10.635490] [<ffffffff815f8aed>] common_interrupt+0x6d/0x6d
[ 10.641805] <EOI>
[ 10.643950] [<ffffffff8149ca9f>] ? cpuidle_enter_state+0x4f/0xc0
[ 10.650972] [<ffffffff8149ca98>] ? cpuidle_enter_state+0x48/0xc0
[ 10.657775] [<ffffffff8149cb47>] cpuidle_enter+0x17/0x20
[ 10.663807] [<ffffffff810b0070>] cpu_startup_entry+0x2c0/0x3d0
[ 10.670423] [<ffffffff815dfcc7>] rest_init+0x77/0x80
[ 10.676065] [<ffffffff81a60f47>] start_kernel+0x40f/0x41a
[ 10.682190] [<ffffffff81a60941>] ? repair_env_string+0x5c/0x5c
[ 10.688799] [<ffffffff81a60120>] ? early_idt_handlers+0x120/0x120
[ 10.695699] [<ffffffff81a605ee>] x86_64_start_reservations+0x2a/0x2c
[ 10.702889] [<ffffffff81a60733>] x86_64_start_kernel+0x143/0x152
[ 10.709689] Code: a0 fc ff 85 c0 8b 4d d4 74 c3 48 8b 7b 08 89 ca 48 c7 c6 60 66 13 a0 31 c0 e8 9d 70 28 e1 8b 4d d4 eb aa 0f 1f 84 00 00 00 00 00 <45> 8b 64 24 3c 48 89 df e8 23 47 4c e1 41 83 fc 01 19 c0 48 83
[ 10.731470] RIP [<ffffffffa0133df0>] ahci_hw_interrupt+0x100/0x130 [libahci]
[ 10.739441] RSP <ffff880033c03d98>
[ 10.743333] CR2: 000000000000003c
[ 10.747032] ---[ end trace b6e82636970e2690 ]---
[ 10.760190] Kernel panic - not syncing: Fatal exception in interrupt
[ 10.767291] Kernel Offset: 0x0 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffff9fffffff)
Cc: Alexander Gordeev <agordeev@redhat.com>
Cc: Tejun Heo <tj@kernel.org>
Signed-of-by: David Milburn <dmilburn@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Enumeration
- Increment max correctly in pci_scan_bridge() (Andreas Noever)
- Clarify the "scan anyway" comment in pci_scan_bridge() (Andreas Noever)
- Assign CardBus bus number only during the second pass (Andreas Noever)
- Use request_resource_conflict() instead of insert_ for bus numbers (Andreas Noever)
- Make sure bus number resources stay within their parents bounds (Andreas Noever)
- Remove pci_fixup_parent_subordinate_busnr() (Andreas Noever)
- Check for child busses which use more bus numbers than allocated (Andreas Noever)
- Don't scan random busses in pci_scan_bridge() (Andreas Noever)
- x86: Drop pcibios_scan_root() check for bus already scanned (Bjorn Helgaas)
- x86: Use pcibios_scan_root() instead of pci_scan_bus_with_sysdata() (Bjorn Helgaas)
- x86: Use pcibios_scan_root() instead of pci_scan_bus_on_node() (Bjorn Helgaas)
- x86: Merge pci_scan_bus_on_node() into pcibios_scan_root() (Bjorn Helgaas)
- x86: Drop return value of pcibios_scan_root() (Bjorn Helgaas)
NUMA
- x86: Add x86_pci_root_bus_node() to look up NUMA node from PCI bus (Bjorn Helgaas)
- x86: Use x86_pci_root_bus_node() instead of get_mp_bus_to_node() (Bjorn Helgaas)
- x86: Remove mp_bus_to_node[], set_mp_bus_to_node(), get_mp_bus_to_node() (Bjorn Helgaas)
- x86: Use NUMA_NO_NODE, not -1, for unknown node (Bjorn Helgaas)
- x86: Remove acpi_get_pxm() usage (Bjorn Helgaas)
- ia64: Use NUMA_NO_NODE, not MAX_NUMNODES, for unknown node (Bjorn Helgaas)
- ia64: Remove acpi_get_pxm() usage (Bjorn Helgaas)
- ACPI: Fix acpi_get_node() prototype (Bjorn Helgaas)
Resource management
- i2o: Fix and refactor PCI space allocation (Bjorn Helgaas)
- Add resource_contains() (Bjorn Helgaas)
- Add %pR support for IORESOURCE_UNSET (Bjorn Helgaas)
- Mark resources as IORESOURCE_UNSET if we can't assign them (Bjorn Helgaas)
- Don't clear IORESOURCE_UNSET when updating BAR (Bjorn Helgaas)
- Check IORESOURCE_UNSET before updating BAR (Bjorn Helgaas)
- Don't try to claim IORESOURCE_UNSET resources (Bjorn Helgaas)
- Mark 64-bit resource as IORESOURCE_UNSET if we only support 32-bit (Bjorn Helgaas)
- Don't enable decoding if BAR hasn't been assigned an address (Bjorn Helgaas)
- Add "weak" generic pcibios_enable_device() implementation (Bjorn Helgaas)
- alpha, microblaze, sh, sparc, tile: Use default pcibios_enable_device() (Bjorn Helgaas)
- s390: Use generic pci_enable_resources() (Bjorn Helgaas)
- Don't check resource_size() in pci_bus_alloc_resource() (Bjorn Helgaas)
- Set type in __request_region() (Bjorn Helgaas)
- Check all IORESOURCE_TYPE_BITS in pci_bus_alloc_from_region() (Bjorn Helgaas)
- Change pci_bus_alloc_resource() type_mask to unsigned long (Bjorn Helgaas)
- Log IDE resource quirk in dmesg (Bjorn Helgaas)
- Revert "[PATCH] Insert GART region into resource map" (Bjorn Helgaas)
PCI device hotplug
- Make check_link_active() non-static (Rajat Jain)
- Use link change notifications for hot-plug and removal (Rajat Jain)
- Enable link state change notifications (Rajat Jain)
- Don't disable the link permanently during removal (Rajat Jain)
- Don't check adapter or latch status while disabling (Rajat Jain)
- Disable link notification across slot reset (Rajat Jain)
- Ensure very fast hotplug events are also processed (Rajat Jain)
- Add hotplug_lock to serialize hotplug events (Rajat Jain)
- Remove a non-existent card, regardless of "surprise" capability (Rajat Jain)
- Don't turn slot off when hot-added device already exists (Yijing Wang)
MSI
- Keep pci_enable_msi() documentation (Alexander Gordeev)
- ahci: Fix broken single MSI fallback (Alexander Gordeev)
- ahci, vfio: Use pci_enable_msi_range() (Alexander Gordeev)
- Check kmalloc() return value, fix leak of name (Greg Kroah-Hartman)
- Fix leak of msi_attrs (Greg Kroah-Hartman)
- Fix pci_msix_vec_count() htmldocs failure (Masanari Iida)
Virtualization
- Device-specific ACS support (Alex Williamson)
Freescale i.MX6
- Wait for retraining (Marek Vasut)
Marvell MVEBU
- Use Device ID and revision from underlying endpoint (Andrew Lunn)
- Fix incorrect size for PCI aperture resources (Jason Gunthorpe)
- Call request_resource() on the apertures (Jason Gunthorpe)
- Fix potential issue in range parsing (Jean-Jacques Hiblot)
Renesas R-Car
- Check platform_get_irq() return code (Ben Dooks)
- Add error interrupt handling (Ben Dooks)
- Fix bridge logic configuration accesses (Ben Dooks)
- Register each instance independently (Magnus Damm)
- Break out window size handling (Magnus Damm)
- Make the Kconfig dependencies more generic (Magnus Damm)
Synopsys DesignWare
- Fix RC BAR to be single 64-bit non-prefetchable memory (Mohit Kumar)
Miscellaneous
- Remove unused SR-IOV VF Migration support (Bjorn Helgaas)
- Enable INTx if BIOS left them disabled (Bjorn Helgaas)
- Fix hex vs decimal typo in cpqhpc_probe() (Dan Carpenter)
- Clean up par-arch object file list (Liviu Dudau)
- Set IORESOURCE_ROM_SHADOW only for the default VGA device (Sander Eikelenboom)
- ACPI, ARM, drm, powerpc, pcmcia, PCI: Use list_for_each_entry() for bus traversal (Yijing Wang)
- Fix pci_bus_b() build failure (Paul Gortmaker)"
* tag 'pci-v3.15-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (108 commits)
PCI: Log IDE resource quirk in dmesg
PCI: Change pci_bus_alloc_resource() type_mask to unsigned long
PCI: Check all IORESOURCE_TYPE_BITS in pci_bus_alloc_from_region()
resources: Set type in __request_region()
PCI: Don't check resource_size() in pci_bus_alloc_resource()
s390/PCI: Use generic pci_enable_resources()
tile PCI RC: Use default pcibios_enable_device()
sparc/PCI: Use default pcibios_enable_device() (Leon only)
sh/PCI: Use default pcibios_enable_device()
microblaze/PCI: Use default pcibios_enable_device()
alpha/PCI: Use default pcibios_enable_device()
PCI: Add "weak" generic pcibios_enable_device() implementation
PCI: Don't enable decoding if BAR hasn't been assigned an address
PCI: Enable INTx in pci_reenable_device() only when MSI/MSI-X not enabled
PCI: Mark 64-bit resource as IORESOURCE_UNSET if we only support 32-bit
PCI: Don't try to claim IORESOURCE_UNSET resources
PCI: Check IORESOURCE_UNSET before updating BAR
PCI: Don't clear IORESOURCE_UNSET when updating BAR
PCI: Mark resources as IORESOURCE_UNSET if we can't assign them
arch/x86/include/asm/topology.h
drivers/ata/ahci.c
"A lot of activities on libata side this time.
- A lot of changes around ahci. Various embedded platforms are
implementing ahci controllers. Some were built atop ahci_platform,
others were doing their own things. Hans made some structural
changes to libahci and librarized ahci_platform so that ahci
platform drivers can share more common code. A couple platform
drivers are added on top of that and several are added to replace
older drivers which were doing their own things (older ones are
scheduled to be removed).
- Dan finishes the patchset to make libata PM operations
asynchronous. Combined with one patch being routed through scsi,
this should speed resume measurably.
- Various fixes and cleanups from Bartlomiej and others"
* 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (61 commits)
ata: fix Marvell SATA driver dependencies
ata: fix ARASAN CompactFlash PATA driver dependencies
ata: remove superfluous casts
ata: sata_highbank: remove superfluous cast
ata: fix Calxeda Highbank SATA driver dependencies
ata: fix R-Car SATA driver dependencies
ARM: davinci: da850: update SATA AHCI support
ata: add new-style AHCI platform driver for DaVinci DA850 AHCI controller
ata: move library code from ahci_platform.c to libahci_platform.c
ata: ahci_platform: fix ahci_platform_data->suspend method handling
libata: remove unused ata_sas_port_async_resume() stub
libata.h: add stub for ata_sas_port_resume
libata: async resume
libata, libsas: kill pm_result and related cleanup
ata: Fix compiler warning with APM X-Gene host controller driver
arm64: Add APM X-Gene SoC AHCI SATA host controller DTS entries
ata: Add APM X-Gene SoC AHCI SATA host controller driver
Documentation: Add documentation for the APM X-Gene SoC SATA host controller DTS binding
arm64: Add APM X-Gene SoC 15Gbps Multi-purpose PHY DTS entries
ata: ahci_sunxi: fix code formatting
Allwinner A10 and A20 ARM SoCs have an AHCI sata controller which needs a
special register to be poked before starting the DMA engine.
This register gets reset on an ahci_stop_engine call, so there is no other
place then ahci_start_engine where this poking can be done.
This commit allows drivers to override ahci_start_engine behavior for use by
the Allwinner AHCI driver (and potentially other drivers in the future).
Pull PCI updates from Bjorn Helgaas:
"The most interesting thing here is the change to enable INTx (by
clearing PCI_COMMAND_INTX_DISABLE) if the BIOS left INTx disabled.
Apparently the Baytrail BIOS does this, which means EHCI doesn't work.
Also, fix an AHCI MSI regression and other issues with the recent MSI
changes. This also adds pci_enable_msi_exact() and
pci_enable_msix_exact(), which aren't regression fixes, but will keep
us from touching drivers twice (once to stop using the deprecated
pci_enable_msi(), etc., and again to use the *_exact() variants).
There's also a minor MVEBU fix.
Summary:
MSI:
- Fix AHCI single-MSI fallback (Alexander Gordeev)
- Fix populate_msi_sysfs() error paths (Greg Kroah-Hartman)
- Fix htmldocs problem (Masanari Iida)
- Add pci_enable_msi_exact() and pci_enable_msix_exact() (Alexander Gordeev)
- Update documentation (Alexander Gordeev)
Miscellaneous:
- mvebu: expose device ID & revision via lspci (Andrew Lunn)
- Enable INTx if the BIOS left them disabled (Bjorn Helgaas)"
* tag 'pci-v3.14-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
ahci: Fix broken fallback to single MSI mode
PCI: Enable INTx if BIOS left them disabled
PCI/MSI: Add pci_enable_msi_exact() and pci_enable_msix_exact()
PCI/MSI: Fix cut-and-paste errors in documentation
PCI/MSI: Add pci_enable_msi() documentation back
PCI/MSI: Fix pci_msix_vec_count() htmldocs failure
PCI/MSI: Fix leak of msi_attrs
PCI/MSI: Check kmalloc() return value, fix leak of name
PCI: mvebu: Use Device ID and revision from underlying endpoint
Samsung's pci-e SSDs with device ID 0x1600 which are found on some
macbooks time out on NCQ commands. Blacklist NCQ on the device so
that the affected machines can at least boot.
Original-patch-by: Levente Kurusa <levex@linux.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=60731
Commit 7b92b4f61ec4 ("PCI/MSI: Remove pci_enable_msi_block_auto()")
introduced a regression: if multiple MSI initialization fails, the code
falls back to INTx rather than to single MSI.
Fixes: 7b92b4f61ec4 ("PCI/MSI: Remove pci_enable_msi_block_auto()")
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
pci_enable_msi_block() has been deprecated; use pci_enable_msi_range()
instead.
[bhelgaas: changelog]
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
"PCI changes for the v3.14 merge window:
Resource management
- Change pci_bus_region addresses to dma_addr_t (Bjorn Helgaas)
- Support 64-bit AGP BARs (Bjorn Helgaas, Yinghai Lu)
- Add pci_bus_address() to get bus address of a BAR (Bjorn Helgaas)
- Use pci_resource_start() for CPU address of AGP BARs (Bjorn Helgaas)
- Enforce bus address limits in resource allocation (Yinghai Lu)
- Allocate 64-bit BARs above 4G when possible (Yinghai Lu)
- Convert pcibios_resource_to_bus() to take pci_bus, not pci_dev (Yinghai Lu)
PCI device hotplug
- Major rescan/remove locking update (Rafael J. Wysocki)
- Make ioapic builtin only (not modular) (Yinghai Lu)
- Fix release/free issues (Yinghai Lu)
- Clean up pciehp (Bjorn Helgaas)
- Announce pciehp slot info during enumeration (Bjorn Helgaas)
MSI
- Add pci_msi_vec_count(), pci_msix_vec_count() (Alexander Gordeev)
- Add pci_enable_msi_range(), pci_enable_msix_range() (Alexander Gordeev)
- Deprecate "tri-state" interfaces: fail/success/fail+info (Alexander Gordeev)
- Export MSI mode using attributes, not kobjects (Greg Kroah-Hartman)
- Drop "irq" param from *_restore_msi_irqs() (DuanZhenzhong)
SR-IOV
- Clear NumVFs when disabling SR-IOV in sriov_init() (ethan.zhao)
Virtualization
- Add support for save/restore of extended capabilities (Alex Williamson)
- Add Virtual Channel to save/restore support (Alex Williamson)
- Never treat a VF as a multifunction device (Alex Williamson)
- Add pci_try_reset_function(), et al (Alex Williamson)
AER
- Ignore non-PCIe error sources (Betty Dall)
- Support ACPI HEST error sources for domains other than 0 (Betty Dall)
- Consolidate HEST error source parsers (Bjorn Helgaas)
- Add a TLP header print helper (Borislav Petkov)
Freescale i.MX6
- Remove unnecessary code (Fabio Estevam)
- Make reset-gpio optional (Marek Vasut)
- Report "link up" only after link training completes (Marek Vasut)
- Start link in Gen1 before negotiating for Gen2 mode (Marek Vasut)
- Fix PCIe startup code (Richard Zhu)
Marvell MVEBU
- Remove duplicate of_clk_get_by_name() call (Andrew Lunn)
- Drop writes to bridge Secondary Status register (Jason Gunthorpe)
- Obey bridge PCI_COMMAND_MEM and PCI_COMMAND_IO bits (Jason Gunthorpe)
- Support a bridge with no IO port window (Jason Gunthorpe)
- Use max_t() instead of max(resource_size_t,) (Jingoo Han)
- Remove redundant of_match_ptr (Sachin Kamat)
- Call pci_ioremap_io() at startup instead of dynamically (Thomas Petazzoni)
NVIDIA Tegra
- Disable Gen2 for Tegra20 and Tegra30 (Eric Brower)
Renesas R-Car
- Add runtime PM support (Valentine Barshak)
- Fix rcar_pci_probe() return value check (Wei Yongjun)
Synopsys DesignWare
- Fix crash in dw_msi_teardown_irq() (Bjørn Erik Nilsen)
- Remove redundant call to pci_write_config_word() (Bjørn Erik Nilsen)
- Fix missing MSI IRQs (Harro Haan)
- Add dw_pcie prefix before cfg_read/write (Pratyush Anand)
- Fix I/O transfers by using CPU (not realio) address (Pratyush Anand)
- Whitespace cleanup (Jingoo Han)
EISA
- Call put_device() if device_register() fails (Levente Kurusa)
- Revert EISA initialization breakage ((Bjorn Helgaas)
Miscellaneous
- Remove unused code, including PCIe 3.0 interfaces (Stephen Hemminger)
- Prevent bus conflicts while checking for bridge apertures (Bjorn Helgaas)
- Stop clearing bridge Secondary Status when setting up I/O aperture (Bjorn Helgaas)
- Use dev_is_pci() to identify PCI devices (Yijing Wang)
- Deprecate DEFINE_PCI_DEVICE_TABLE (Joe Perches)
- Update documentation 00-INDEX (Erik Ekman)"
* tag 'pci-v3.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (119 commits)
Revert "EISA: Initialize device before its resources"
Revert "EISA: Log device resources in dmesg"
vfio-pci: Use pci "try" reset interface
PCI: Check parent kobject in pci_destroy_dev()
xen/pcifront: Use global PCI rescan-remove locking
powerpc/eeh: Use global PCI rescan-remove locking
PCI: Fix pci_check_and_unmask_intx() comment typos
PCI: Add pci_try_reset_function(), pci_try_reset_slot(), pci_try_reset_bus()
MPT / PCI: Use pci_stop_and_remove_bus_device_locked()
platform / x86: Use global PCI rescan-remove locking
PCI: hotplug: Use global PCI rescan-remove locking
pcmcia: Use global PCI rescan-remove locking
ACPI / hotplug / PCI: Use global PCI rescan-remove locking
ACPI / PCI: Use global PCI rescan-remove locking in PCI root hotplug
PCI: Add global pci_lock_rescan_remove()
PCI: Cleanup pci.h whitespace
PCI: Reorder so actual code comes before stubs
PCI/AER: Support ACPI HEST AER error sources for PCI domains other than 0
ACPICA: Add helper macros to extract bus/segment numbers from HEST table.
PCI: Make local functions static
A scheduled horkage patch will conflict with HORKAGE changes in
for-3.13-fixes. Pull in to avoid unnecessary merge conflicts.
The new pci_msi_vec_count() interface makes pci_enable_msi_block_auto()
superfluous.
Drivers can use pci_msi_vec_count() to learn the maximum number of MSIs
supported by the device, and then call pci_enable_msi_block().
pci_enable_msi_block_auto() was introduced recently, and its only user is
the AHCI driver, which is also updated by this change.
This patch adds support for the PCI ID provided by the Marvell 88SE9170
SATA controller.
Signed-off-by: Simon Guinot <sguinot@lacie.com>
The check for "combined mode" (which disables ahci support) on ICH6 is
done after the first use of AHCI BAR. But if ahci is not enabled AHCI
BAR is initialized to 0x00000000. (At least it is on the ICH6-M I tested
this on. If I understand the datasheet correctly it should also be on
ICH6R.) This apparently makes the call of
pcim_iomap_regions_request_all() return -EINVAL. And we end up with
ahci: probe of 0000:00:1f.2 failed with error -22
(at warning level) in the logs.
So check for "combined mode" before calling
pcim_iomap_regions_request_all().
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
This patch marks the function ahci_init_interrupts() as static in ahci.c
because it is not used outside this file.
Thus, it also eliminates the following warning in ahci.c:
drivers/ata/ahci.c:1099:5: warning: no previous prototype for ‘ahci_init_interrupts’ [-Wmissing-prototypes]
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Pulling in for-3.13-fixes for the ahci_imx fix as further changes
depend on it.
Tested with a DAWICONTROL DC-624e on 3.10.10
Signed-off-by: Samir Benmendil <samir.benmendil@gmail.com>
Reviewed-by: Levente Kurusa <levex@linux.com>
